CCSTUDIO-C2000: Compiler (22.6.0) - Error with __fp_single_precision_constant enabled
Part Number: CCSTUDIO-C2000
Platform: CCS 11.1 on Windows 10.
Target: F28379D
Compiler: ti-cgt-c2000_22.6.0.LTS
Flags:
__float_operations_allowed=32
The stlport/s__limit.h file fails with the following #30 floating constant is out of range errors:
"C:/ti/ccs1110/ccs/tools/compiler/ti-cgt-c2000_22.6.0.LTS/include/stlport/s__limits.h", line 516: error #30: floating constant is out of range
    static double (_STLP_CALL min)() _STLP_NOTHROW { return DBL_MIN; }
"C:/ti/ccs1110/ccs/tools/compiler/ti-cgt-c2000_22.6.0.LTS/include/stlport/s__limits.h", line 521: error #30: floating constant is out of range
    { return _STLP_DBL_DENORM_STYLE ? _STLP_PRIV _LimG<bool>::get_D_denormMin() : DBL_MIN; }
"C:/ti/ccs1110/ccs/tools/compiler/ti-cgt-c2000_22.6.0.LTS/include/stlport/s__limits.h", line 523: error #30: floating constant is out of range
    static double (_STLP_CALL max)() _STLP_NOTHROW { return DBL_MAX; }
    Can you share the code? What are the values that are being assigned?
    -Shantanu
  • Shantanu,
    I am sorry for being unclear.
    This is the stlport that comes with the compiler tools - check the path of the file of the error:
    I understand the error but can you share the code snippet, values and compiler option so i can reproduce it at my end?
    _Shantanu
  • Shanty,
    I just spent some time trying to get STL port to work on a fresh project with EABI but, could not get it to compile at all, I am no help here.
    My unfortunately export-controlled project uses string and vector from STL port. I can make that error appear by enabling the __fp_single_precision_constant flag and disappear when disabling it.
  • This looks like a compiler related issue. Will re - assign to an expert. Please wait for a day for them to get back to you.
  • Thank you for notifying us of this issue.  I am able to reproduce the behavior.  I filed EXT_EP-10848 to have this investigated.  You are welcome to follow it with that link.
    The best workaround for now is to avoid using the compiler option --fp_single_precision_constant.
    For those who are following along ... I was able to reproduce the behavior based only on the customer's description.  Please understand this is a rare event.  It is almost always the case that, to reproduce the behavior, a test case must be obtained.
    Thanks and regards,
    -George
