TMS320F28P650DK: CLA code compilation failure on float variable residing in LSRAM (shared CPU1/CLA memory)
Part Number: TMS320F28P650DK
Dear Experts,
CCS12.8.1
Compiler TI v22.6.2.LTS
I have a floating point variable declared as follows, in a CPU1 .c file:
#pragma DATA_SECTION(t,"ramls1_RAMCMD");
float32_t t;
where ramls1_RAMCMD is set as RAMLS1 in CMD, which is declared "CPU/CLA shared data memory" in MEMCFG.
When trying to compile the following CLA code:
extern float32_t t;
__interrupt void Cla1Task3 ( void )
t = 1.0f;
I get the following error:
"C:\Users\alon.g\AppData\Local\Temp\{0EC771BC-7449-406D-8A90-D7FD69504070}", ERROR! at line 419: [E0003] 16-bit register address not valid.
MMOV32 @t,MR0 ; [CPU_FPU] |89|
"C:\Users\alon.g\AppData\Local\Temp\{0EC771BC-7449-406D-8A90-D7FD69504070}", ERROR! at line 419: [E0003] Illegal register addressing operand
"C:\Users\alon.g\AppData\Local\Temp\{0EC771BC-7449-406D-8A90-D7FD69504070}", ERROR! at line 419: [E0004] Illegal operand combination
Errors in Source - Assembler Aborted
When t is defined as uint16_t or uint32_t, no such error occurs.
The following code where t is defined locally in the .CLA file also compiles OK:
float t;
t=1.0f;
If I define TWO variables in the CPU1 .c file as follows:
#pragma DATA_SECTION(x,"ramls1_RAMCMD");
float t;
float x;
then the following .cla code compiles OK:
extern float x;
x = 1.0f;
The map file shows:
GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
address data page name
00000400 10 (00000400) __stack
00008800 220 (00008800) V
00008802 220 (00008800) t
00008804 220 (00008800) x
Not only is there a bug, the error codes are not pointing to the allegedly problematic source line.
Thank You,
-Alon.
  • I am unable to reproduce the following behavior ...
    extern float32_t t;
    t = 1.0f;
    I presume this is all the source code.  I presume float32_t is float.  Please show all the build options, exactly as cl2000 sees them.  Please copy and paste the text, and do not use a screenshot.
    Thanks and regards,
    -George
  • Hello George
    Thank you for your reply.
    The project is a large project with several other CPU1 source code files. I am attaching the build flags and what I believe is the relevant part of the memory map.
    Thank You,
    -Alon.
    -v28 -ml -mt --cla_support=cla2 --float_support=fpu64 --tmu_support=tmu1 --vcu_support=vcrc -Ooff --opt_for_speed=5 --fp_mode=relaxed --include_path="C:/Users/alon.g/workspace_v12/v5" --include_path="C:/ti/c2000/C2000Ware_5_04_00_00" --include_path="C:/Users/alon.g/workspace_v12/v5/device" --include_path="C:/ti/c2000/C2000Ware_5_04_00_00/driverlib/f28p65x/driverlib" --include_path="C:/ti/ccs1281/ccs/tools/compiler/ti-cgt-c2000_22.6.1.LTS/include" --advice:performance=all --define=RAM --define=CPU1 --diag_suppress=10063 --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --cla_background_task=off --cla_signed_compare_workaround=on --asm_listing --include_path="C:/Users/alon.g/workspace_v12/v5/CPU1_RAM/syscfg"
    MEMORY CONFIGURATION
    name origin length used unused attr fill
    RAMM0_BEGIN 00000000 00000002 00000002 00000000 RWIX
    RAMM0 000001b1 0000024f 000000fe 00000151 RWIX
    RAMM1 00000400 00000400 000003f8 00000008 RWIX
    CLATOCPURAM 00001480 00000080 00000000 00000080 RWIX
    CPUTOCLARAM 00001500 00000080 00000000 00000080 RWIX
    CLATODMARAM 00001680 00000080 00000000 00000080 RWIX
    DMATOCLARAM 00001700 00000080 00000000 00000080 RWIX
    RAMLS8_CLA 00004000 00002000 00000000 00002000 RWIX
    RAMLS9_CLA 00006000 00002000 00000000 00002000 RWIX
    RAMLS0 00008000 00000800 000001b4 0000064c RWIX
    RAMLS1 00008800 00000800 00000065 0000079b RWIX
    RAMLS2 00009000 00000800 00000000 00000800 RWIX
    RAMLS3 00009800 00000800 00000000 00000800 RWIX
    RAMLS4 0000a000 00000800 00000000 00000800 RWIX
    RAMLS5 0000a800 00000800 00000527 000002d9 RWIX
    RAMLS6 0000b000 00000800 00000000 00000800 RWIX
    RAMLS7 0000b800 00000800 00000000 00000800 RWIX
    RAMD0 0000c000 00002000 00002000 00000000 RWIX
    RAMD1 0000e000 00002000 00001fd6 0000002a RWIX
    RAMGS0 00010000 00002000 00000000 00002000 RWIX
    RAMGS1 00012000 00002000 00000000 00002000 RWIX
    RAMGS2 00014000 00002000 00000000 00002000 RWIX
    RAMGS3 00016000 00002000 00000000 00002000 RWIX
    RAMGS4 00018000 00002000 00000000 00002000 RWIX
    RAMD2 0001a000 00002000 00000000 00002000 RWIX
    RAMD3 0001c000 00002000 00000000 00002000 RWIX
    RAMD4 0001e000 00002000 00000000 00002000 RWIX
    RAMD5 00020000 00002000 00000000 00002000 RWIX
    RAMLS8 00022000 00002000 00000000 00002000 RWIX
    RAMLS9 00024000 00002000 00000000 00002000 RWIX
    CPU1TOCPU2RAM 0003a000 00000800 00000000 00000800 RWIX
    CPU2TOCPU1RAM 0003b000 00000800 00000000 00000800 RWIX
    CANA_MSG_RAM 00049000 00000800 00000000 00000800 RWIX
    CANB_MSG_RAM 0004b000 00000800 00000000 00000800 RWIX
    FLASH_BANK0 00080000 00020000 00000000 00020000 RWIX
    FLASH_BANK1 000a0000 00020000 00000000 00020000 RWIX
    FLASH_BANK2 000c0000 00020000 00000000 00020000 RWIX
    FLASH_BANK3 000e0000 00020000 00000000 00020000 RWIX
    FLASH_BANK4 00100000 00020000 00000000 00020000 RWIX
    RESET 003fffc0 00000002 00000000 00000002 RWIX
    SECTION ALLOCATION MAP
    output attributes/
    section page origin length input sections
    .reset 0 003fffc0 00000000 DSECT
    codestart
    * 0 00000000 00000002
    00000000 00000002 f28p65x_codestartbranch.obj (codestart)
    .TI.ramfunc
    * 0 000001b1 00000004
    000001b1 00000004 driverlib.lib : sysctl.obj (.TI.ramfunc)
    .cinit 0 000001b6 000000fa
    000001b6 000000c8 (.cinit..data.load) [load image, compression = lzss]
    0000027e 00000006 (__TI_handler_table)
    00000284 00000004 (.cinit..bss.1.load) [load image, compression = zero_init]
    00000288 00000004 (.cinit..bss.2.load) [load image, compression = zero_init]
    0000028c 00000004 (.cinit..scratchpad.1.load) [load image, compression = zero_init]
    00000290 00000004 (.cinit..scratchpad.2.load) [load image, compression = zero_init]
    00000294 00000004 (.cinit.ramls1_RAMCMD.load) [load image, compression = zero_init]
    00000298 00000018 (__TI_cinit_table)
    .stack 0 00000400 000003f8 UNINITIALIZED
    00000400 000003f8 --HOLE--
    .init_array
    * 0 000001b1 00000000 UNINITIALIZED
    .data 0 0000a800 00000145 UNINITIALIZED
    0000a800 00000090 c2000ware_libraries.obj (.data:ePWM)
    0000a890 0000002c control.obj (.data)
    0000a8bc 00000004 adc.obj (.data)
    0000a8c0 0000006a c2000ware_libraries.obj (.data)
    0000a92a 00000008 ntc.obj (.data)
    0000a932 00000006 v5.obj (.data)
    0000a938 00000006 rts2800_fpu64_eabi.lib : exit.c.obj (.data)
    0000a93e 00000002 : _lock.c.obj (.data:_lock)
    0000a940 00000002 : _lock.c.obj (.data:_unlock)
    0000a942 00000002 my_sci.obj (.data)
    0000a944 00000001 SFO_v8_fpu_lib_build_c28_driverlib.lib : SFO_v8_fpu_lib_build_c28_driverlib.obj (.data)
    ramls1_RAMCMD
    * 0 00008800 0000001b UNINITIALIZED
    00008800 00000016 adc.obj (ramls1_RAMCMD)
    00008816 00000004 v5.obj (ramls1_RAMCMD)
    0000881a 00000001 epwm.obj (ramls1_RAMCMD)
    Cla1Prog 0 00008000 000001b4
    00008000 00000114 v5_CLA_code.obj (Cla1Prog:Cla1Task1)
    00008114 00000058 v5_CLA_code.obj (Cla1Prog:my_GPIO_writePin)
    0000816c 00000038 v5_CLA_code.obj (Cla1Prog:HRPWM_setCounterCompareValue)
    000081a4 00000008 v5_CLA_code.obj (Cla1Prog:Cla1Task2)
    000081ac 00000008 v5_CLA_code.obj (Cla1Prog:Cla1Task3)
    .const_cla
    * 0 0000881c 00000040
    0000881c 00000040 v5_CLA_code.obj (.const_cla:bitmap)
    .scratchpad.1
    * 0 0000885c 00000006 UNINITIALIZED
    0000885c 00000006 v5_CLA_code.obj (.scratchpad:Cla1Prog:HRPWM_setCounterCompareValue)
    .scratchpad.2
    * 0 0000885c 0000000a UNINITIALIZED
    0000885c 00000008 v5_CLA_code.obj (.scratchpad:Cla1Prog:my_GPIO_writePin)
    00008864 00000002 v5_CLA_code.obj (.scratchpad:Cla1Prog:Cla1Task1)
  • Thank you for the build options.  I can reproduce the same behavior.  I filed EXT_EP-12238 to have this investigated.  You are welcome to follow it with that link.
    As workaround, rename the variable t to something else, like temp.
    Thanks and regards,
    -George
