C2000-GANG: C2000-GANG: ERROR23: MCU device init
Part Number: C2000-GANG
Other Parts Discussed in Thread: TMS320F28069
Hi everyone,
I am trying to program TMS320F28069 MCU with the C2000-GANG and i am getting the Error 23: MCU device init.
I did the self test and i get the following error: "189: Image Flash Access (get ID)   0x0002   (0x0001  - 0x0003)  Result:  0x04     ... >> ERROR <<"
=== C2000-GANG Self test results ( Monday, May 17, 2021,  15:13:42 ) ===
Adapter SN ------:  20070845
Hardware --------:  C2K :  01.05
Access key ------:  C2000 - Gang Programmer
Silicon Number --:  588C 886E 1A00 2800
API Firmware ----:  C2K-Gang   AC28:  01.01.03.05
BOOT Firmware ---:  G430BOOT   B430:  01.00.02.00
GUI Software ----:  C2000-Gang-GUI   G28x:  01.01.03.06
DLL Software ----:  C2000-Gang-DLL   D280:  01.01.03.06
================ Test results =============
No.       name                   parameter       limits               result         status
  1: Data Bus   (ALL LOW)          0x0000   (0x0000  - 0x0000)  Result:  0x00     ... >>  OK   <<
  2: Data Bus   (ALL HIGH)         0x00FF   (0xFFFF  - 0xFFFF)  Result:  0xFFFF   ... >>  OK   <<
  3: Data Bus   (D-0 HI )          0x0001   (0x0101  - 0x0101)  Result:  0x0101   ... >>  OK   <<
  4: Data Bus   (D-1 HI )          0x0002   (0x0202  - 0x0202)  Result:  0x0202   ... >>  OK   <<
  5: Data Bus   (D-2 HI )          0x0004   (0x0404  - 0x0404)  Result:  0x0404   ... >>  OK   <<
  6: Data Bus   (D-3 HI )          0x0008   (0x0808  - 0x0808)  Result:  0x0808   ... >>  OK   <<
  7: Data Bus   (D-4 HI )          0x0010   (0x1010  - 0x1010)  Result:  0x1010   ... >>  OK   <<
  8: Data Bus   (D-5 HI )          0x0020   (0x2020  - 0x2020)  Result:  0x2020   ... >>  OK   <<
  9: Data Bus   (D-6 HI )          0x0040   (0x4040  - 0x4040)  Result:  0x4040   ... >>  OK   <<
 10: Data Bus   (D-7 HI )          0x0080   (0x8080  - 0x8080)  Result:  0x8080   ... >>  OK   <<
 11: Data-2 Bus  (ALL LOW)         0x0000   (0x0000  - 0x0000)  Result:  0x00     ... >>  OK   <<
 12: Data-2 Bus  (ALL HIGH)        0x00FF   (0xFFFF  - 0xFFFF)  Result:  0xFFFF   ... >>  OK   <<
 13: Data-2 Bus  (D2-0 HI )        0x0001   (0x0101  - 0x0101)  Result:  0x0101   ... >>  OK   <<
 14: Data-2 Bus  (D2-1 HI )        0x0002   (0x0202  - 0x0202)  Result:  0x0202   ... >>  OK   <<
 15: Data-2 Bus  (D2-2 HI )        0x0004   (0x0404  - 0x0404)  Result:  0x0404   ... >>  OK   <<
 16: Data-2 Bus  (D2-3 HI )        0x0008   (0x0808  - 0x0808)  Result:  0x0808   ... >>  OK   <<
 17: Data-2 Bus  (D2-4 HI )        0x0010   (0x1010  - 0x1010)  Result:  0x1010   ... >>  OK   <<
 18: Data-2 Bus  (D2-5 HI )        0x0020   (0x2020  - 0x2020)  Result:  0x2020   ... >>  OK   <<
 19: Data-2 Bus  (D2-6 HI )        0x0040   (0x4040  - 0x4040)  Result:  0x4040   ... >>  OK   <<
 20: Data-2 Bus  (D2-7 HI )        0x0080   (0x8080  - 0x8080)  Result:  0x8080   ... >>  OK   <<
 21: Vcc Target-1 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.02 V   ... >>  OK   <<
 22: Vcc Target-2 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 23: Vcc Target-3 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 24: Vcc Target-4 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 25: Vcc Target-5 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 26: Vcc Target-6 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 27: Vcc Target-7 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 28: Vcc Target-8 (ALL OFF)         0.00 V  (  0.00 to   0.30)  Result:  0.01 V   ... >>  OK   <<
 29: Translators VT (OFF)           0.00 V  (  0.00 to   0.50)  Result:  0.01 V   ... >>  OK   <<
 30: Translators VT (ON 3.3V)       3.30 V  (  3.10 to   3.50)  Result:  3.20 V   ... >>  OK   <<
 31: Vpp Voltage-in                10.00 V  (  8.00 to  12.00)  Result: 10.61 V   ... >>  OK   <<
 32: Vpp Voltage                    7.00 V  (  6.50 to   7.30)  Result:  6.87 V   ... >>  OK   <<
 33: Internal Vcc-3.3V              3.30 V  (  3.20 to   3.40)  Result:  3.31 V   ... >>  OK   <<
 34: Vcc Target-1 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.28 V   ... >>  OK   <<
 35: Vcc Target-2 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.30 V   ... >>  OK   <<
 36: Vcc Target-3 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.29 V   ... >>  OK   <<
 37: Vcc Target-4 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.30 V   ... >>  OK   <<
 38: Vcc Target-5 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.29 V   ... >>  OK   <<
 39: Vcc Target-6 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.28 V   ... >>  OK   <<
 40: Vcc Target-7 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.29 V   ... >>  OK   <<
 41: Vcc Target-8 (ALL ON 3.3V)     3.30 V  (  3.10 to   3.50)  Result:  3.29 V   ... >>  OK   <<
 42: Vcc discharge (250ms)Target-1  3.30 V  (  0.30 to   1.50)  Result:  0.82 V   ... >>  OK   <<
 43: Vcc discharge (250ms)Target-2  3.30 V  (  0.30 to   1.50)  Result:  0.84 V   ... >>  OK   <<
 44: Vcc discharge (250ms)Target-3  3.30 V  (  0.30 to   1.50)  Result:  0.82 V   ... >>  OK   <<
 45: Vcc discharge (250ms)Target-4  3.30 V  (  0.30 to   1.50)  Result:  0.78 V   ... >>  OK   <<
 46: Vcc discharge (250ms)Target-5  3.30 V  (  0.30 to   1.50)  Result:  0.78 V   ... >>  OK   <<
 47: Vcc discharge (250ms)Target-6  3.30 V  (  0.30 to   1.50)  Result:  0.80 V   ... >>  OK   <<
 48: Vcc discharge (250ms)Target-7  3.30 V  (  0.30 to   1.50)  Result:  0.80 V   ... >>  OK   <<
 49: Vcc discharge (250ms)Target-8  3.30 V  (  0.30 to   1.50)  Result:  0.80 V   ... >>  OK   <<
 50: Vcc Target-1 ( #1 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.28 V   ... >>  OK   <<
 51: Vcc Target-2 ( #1 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 52: Vcc Target-3 ( #1 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 53: Vcc Target-4 ( #1 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 54: Vcc Target-5 ( #1 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 55: Vcc Target-6 ( #1 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 56: Vcc Target-7 ( #1 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 57: Vcc Target-8 ( #1 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 58: Vcc Target-1 ( #2 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 59: Vcc Target-2 ( #2 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.30 V   ... >>  OK   <<
 60: Vcc Target-3 ( #2 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 61: Vcc Target-4 ( #2 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 62: Vcc Target-5 ( #2 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 63: Vcc Target-6 ( #2 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 64: Vcc Target-7 ( #2 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 65: Vcc Target-8 ( #2 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 66: Vcc Target-1 ( #3 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 67: Vcc Target-2 ( #3 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 68: Vcc Target-3 ( #3 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.28 V   ... >>  OK   <<
 69: Vcc Target-4 ( #3 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 70: Vcc Target-5 ( #3 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 71: Vcc Target-6 ( #3 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 72: Vcc Target-7 ( #3 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 73: Vcc Target-8 ( #3 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 74: Vcc Target-1 ( #4 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 75: Vcc Target-2 ( #4 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 76: Vcc Target-3 ( #4 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 77: Vcc Target-4 ( #4 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.30 V   ... >>  OK   <<
 78: Vcc Target-5 ( #4 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 79: Vcc Target-6 ( #4 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 80: Vcc Target-7 ( #4 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 81: Vcc Target-8 ( #4 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 82: Vcc Target-1 ( #5 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 83: Vcc Target-2 ( #5 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 84: Vcc Target-3 ( #5 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 85: Vcc Target-4 ( #5 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 86: Vcc Target-5 ( #5 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.28 V   ... >>  OK   <<
 87: Vcc Target-6 ( #5 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 88: Vcc Target-7 ( #5 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 89: Vcc Target-8 ( #5 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 90: Vcc Target-1 ( #6 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 91: Vcc Target-2 ( #6 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 92: Vcc Target-3 ( #6 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 93: Vcc Target-4 ( #6 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 94: Vcc Target-5 ( #6 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 95: Vcc Target-6 ( #6 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.28 V   ... >>  OK   <<
 96: Vcc Target-7 ( #6 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
 97: Vcc Target-8 ( #6 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
 98: Vcc Target-1 ( #7 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
 99: Vcc Target-2 ( #7 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
100: Vcc Target-3 ( #7 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
101: Vcc Target-4 ( #7 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
102: Vcc Target-5 ( #7 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
103: Vcc Target-6 ( #7 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
104: Vcc Target-7 ( #7 ON )         0.00 V  (  3.10 to   3.50)  Result:  3.29 V   ... >>  OK   <<
105: Vcc Target-8 ( #7 ON )         3.30 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
106: Vcc Target-1 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.18 V   ... >>  OK   <<
107: Vcc Target-2 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
108: Vcc Target-3 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
109: Vcc Target-4 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
110: Vcc Target-5 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
111: Vcc Target-6 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.16 V   ... >>  OK   <<
112: Vcc Target-7 ( #8 ON )         0.00 V  (  0.00 to   0.50)  Result:  0.17 V   ... >>  OK   <<
113: Vcc Target-8 ( #8 ON )         3.30 V  (  3.10 to   3.50)  Result:  3.29 V   ... >>  OK   <<
114: SD Power OFF                  0x0000   (0x0000  - 0x0000)  Result:  0x00     ... >>  OK   <<
115: SD Power ON                   0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
116: SD Discharge -  delay 2ms     0x0010   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
117: SD Discharge -  delay 50ms    0x0010   (0x0000  - 0x0000)  Result:  0x00     ... >>  OK   <<
118: BSL RX bus (#1 HIGH)          0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
119: BSL RX bus (#2 HIGH)          0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
120: BSL RX bus (#3 HIGH)          0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
121: BSL RX bus (#4 HIGH)          0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
122: BSL RX bus (#5 HIGH)          0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
123: BSL RX bus (#6 HIGH)          0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
124: BSL RX bus (#7 HIGH)          0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
125: BSL RX bus (#8 HIGH)          0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
126: BSL TX bus (#1 HIGH)          0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
127: BSL TX bus (#2 HIGH)          0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
128: BSL TX bus (#3 HIGH)          0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
129: BSL TX bus (#4 HIGH)          0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
130: BSL TX bus (#5 HIGH)          0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
131: BSL TX bus (#6 HIGH)          0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
132: BSL TX bus (#7 HIGH)          0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
133: BSL TX bus (#8 HIGH)          0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
134: TDI bus  (#8 HIGH)            0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
135: TDI bus  (#1 HIGH)            0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
136: TDI bus  (#2 HIGH)            0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
137: TDI bus  (#3 HIGH)            0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
138: TDI bus  (#4 HIGH)            0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
139: TDI bus  (#5 HIGH)            0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
140: TDI bus  (#6 HIGH)            0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
141: TDI bus  (#7 HIGH)            0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
142: TDIO Tx-bus (#1 HIGH)         0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
143: TDIO Tx-bus (#2 HIGH)         0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
144: TDIO Tx-bus (#3 HIGH)         0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
145: TDIO Tx-bus (#4 HIGH)         0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
146: TDIO Tx-bus (#5 HIGH)         0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
147: TDIO Tx-bus (#6 HIGH)         0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
148: TDIO Tx-bus (#7 HIGH)         0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
149: TDIO Tx-bus (#8 HIGH)         0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
150: TDIO Tx-Rx (#1 HIGH)          0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
151: TDIO Tx-Rx (#2 HIGH)          0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
152: TDIO Tx-Rx (#3 HIGH)          0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
153: TDIO Tx-Rx (#4 HIGH)          0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
154: TDIO Tx-Rx (#5 HIGH)          0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
155: TDIO Tx-Rx (#6 HIGH)          0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
156: TDIO Tx-Rx (#7 HIGH)          0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
157: TDIO Tx-Rx (#8 HIGH)          0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
158: TDIO Rx-bus (#1 HIGH)         0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
159: TDIO Rx-bus (#2 HIGH)         0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
160: TDIO Rx-bus (#3 HIGH)         0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
161: TDIO Rx-bus (#4 HIGH)         0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
162: TDIO Rx-bus (#5 HIGH)         0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
163: TDIO Rx-bus (#6 HIGH)         0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
164: TDIO Rx-bus (#7 HIGH)         0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
165: TDIO Rx-bus (#84 HIGH)        0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
166: TMS bus (All HIGH)            0x00FF   (0x00FF  - 0x00FF)  Result:  0xFF     ... >>  OK   <<
167: TMS bus (All LOW)             0x0000   (0x0000  - 0x0000)  Result:  0x00     ... >>  OK   <<
168: TMS bus (#1 HIGH)             0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
169: TMS bus (#2 HIGH)             0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
170: TMS bus (#3 HIGH)             0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
171: TMS bus (#4 HIGH)             0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
172: TMS bus (#5 HIGH)             0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
173: TMS bus (#6 HIGH)             0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
174: TMS bus (#7 HIGH)             0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
175: TMS bus (#8 HIGH)             0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
176: RST bus (All HIGH)            0x00FF   (0x00FF  - 0x00FF)  Result:  0xFF     ... >>  OK   <<
177: RST bus (All LOW)             0x0000   (0x0000  - 0x0000)  Result:  0x00     ... >>  OK   <<
178: RST bus (#1 HIGH)             0x0001   (0x0001  - 0x0001)  Result:  0x01     ... >>  OK   <<
179: RST bus (#2 HIGH)             0x0002   (0x0002  - 0x0002)  Result:  0x02     ... >>  OK   <<
180: RST bus (#3 HIGH)             0x0004   (0x0004  - 0x0004)  Result:  0x04     ... >>  OK   <<
181: RST bus (#4 HIGH)             0x0008   (0x0008  - 0x0008)  Result:  0x08     ... >>  OK   <<
182: RST bus (#5 HIGH)             0x0010   (0x0010  - 0x0010)  Result:  0x10     ... >>  OK   <<
183: RST bus (#6 HIGH)             0x0020   (0x0020  - 0x0020)  Result:  0x20     ... >>  OK   <<
184: RST bus (#7 HIGH)             0x0040   (0x0040  - 0x0040)  Result:  0x40     ... >>  OK   <<
185: RST bus (#8 HIGH)             0x0080   (0x0080  - 0x0080)  Result:  0x80     ... >>  OK   <<
186: Keys buffer (All pull-up)     0x001F   (0x001F  - 0x001F)  Result:  0x1F     ... >>  OK   <<
187: Access to LCD RAM (0xAA)      0x00AA   (0x00AA  - 0x00AA)  Result:  0xAA     ... >>  OK   <<
188: Access to LCD RAM (0x99)      0x0099   (0x0099  - 0x0099)  Result:  0x99     ... >>  OK   <<
============== Finished =================================
*  Test failed!!  1 error(s).
Any advice to solver this issue?
