LAUNCHXL-F280049C: ECAP, confused about event capture time stamp ticks
Part Number: LAUNCHXL-F280049C
I read the ecap section from the technical reference manual but I'm having difficulty understanding the "ecap_ex2_capture_pwm.c" example from the C2000 driverlib examples.
I made the following modifications to the example:
1) I changed the value of the EPWM clock prescaler from "1" to "128" and I changed the EPWM high speed prescaler from "2"  to "10".
2) I changed PWM3_TIMER_MIN from "500U" to 39000U.
3) I commented  a section of the ISR code (lines 294 to 346)
The expected pulse width of my signal is 499-500 ms based on changes 1) and 2) above. I get the expected signal with the proper pulse width on my oscilloscope but I don't understand the time stamp readings from the TSCTR register.
From my understanding the TSCTR register is synced to the system clock of 100 MHZ and therefore the number of ticks should increment every 10 ns. In this example they reset the number of ticks with each event capture to measure pulse width. I  was expecting 50,000,000 ticks with a pulse width of 500ms but the registers are capturing 48383 ticks on each event capture.
Clarification would be appreciated.
Modified Code:
// FILE: ecap_capture_pwm.c
// TITLE: Capture ePWM3.
//! \addtogroup driver_example_list
//! <h1>eCAP Capture PWM Example</h1>
//! This example configures ePWM3A for:
//! - Up count mode
//! - Period starts at 500 and goes up to 8000
//! - Toggle output on PRD
//! eCAP1 is configured to capture the time between rising
//! and falling edge of the ePWM3A output.
//! \b External \b Connections for Control Card and Launch Pad \n
//! - eCAP1 is on GPIO16
//! - ePWM3A is on GPIO4
//! - Connect GPIO4 to GPIO16.
//! \b Watch \b Variables \n
//! - \b ecap1PassCount - Successful captures.
//! - \b ecap1IntCount - Interrupt counts.
// $TI Release: F28004x Support Library v1.12.00.00 $
// $Release Date: Fri Feb 12 18:57:27 IST 2021 $
// $Copyright:
// Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#define PWM3_TIMER_MIN 39000U
#define PWM3_TIMER_MAX 8000U
#define EPWM_TIMER_UP 1U
#define EPWM_TIMER_DOWN 0U
// Globals
uint32_t ecap1IntCount;
uint32_t ecap1PassCount;
uint32_t epwm3TimerDirection;
volatile uint16_t cap2Count;
volatile uint16_t cap3Count;
volatile uint16_t cap4Count;
volatile uint16_t epwm3PeriodCount;
// Function Prototypes
void error(void);
void initECAP(void);
void initEPWM(void);
__interrupt void ecap1ISR(void);
// Main
void main(void)
// Initialize device clock and peripherals
Device_init();
// Disable pin locks and enable internal pullups.
Device_initGPIO();
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Configure GPIO4/5 as ePWM3A/3B
GPIO_setPadConfig(4,GPIO_PIN_TYPE_STD);
GPIO_setPinConfig(GPIO_4_EPWM3_A);
GPIO_setPadConfig(5,GPIO_PIN_TYPE_STD);
GPIO_setPinConfig(GPIO_5_EPWM3_B);
// Configure GPIO 16 as eCAP input
XBAR_setInputPin(XBAR_INPUT7, 16);
GPIO_setPinConfig(GPIO_16_GPIO16);
GPIO_setDirectionMode(16, GPIO_DIR_MODE_IN);
GPIO_setQualificationMode(16,GPIO_QUAL_ASYNC);
// Interrupts that are used in this example are re-mapped to ISR functions
// found within this file.
Interrupt_register(INT_ECAP1, &ecap1ISR);
// Configure ePWM and eCAP
initEPWM();
initECAP();
// Initialize counters:
cap2Count = 0U;
cap3Count = 0U;
cap4Count = 0U;
ecap1IntCount = 0U;
ecap1PassCount = 0U;
epwm3PeriodCount = 0U;
// Enable interrupts required for this example
Interrupt_enable(INT_ECAP1);
// Enable Global Interrupt (INTM) and Real time interrupt (DBGM)
EINT;
ERTM;
// Loop forever. Suspend or place breakpoints to observe the buffers.
for(;;)
NOP;
// initEPWM - Configure ePWM
void initEPWM()
// Disable sync(Freeze clock to PWM as well)
SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// Configure ePWM
// Counter runs in up-count mode.
// Action qualifier will toggle output on period match
EPWM_setTimeBaseCounterMode(EPWM3_BASE, EPWM_COUNTER_MODE_UP);
EPWM_setTimeBasePeriod(EPWM3_BASE, PWM3_TIMER_MIN);
EPWM_setPhaseShift(EPWM3_BASE, 0U);
EPWM_setActionQualifierAction(EPWM3_BASE,
EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_TOGGLE,
EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
EPWM_setClockPrescaler(EPWM3_BASE,
EPWM_CLOCK_DIVIDER_128,
EPWM_HSCLOCK_DIVIDER_10);
epwm3TimerDirection = EPWM_TIMER_UP;
// Enable sync and clock to PWM
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// initECAP - Configure eCAP
void initECAP()
// Disable ,clear all capture flags and interrupts
ECAP_disableInterrupt(ECAP1_BASE,
(ECAP_ISR_SOURCE_CAPTURE_EVENT_1 |
ECAP_ISR_SOURCE_CAPTURE_EVENT_2 |
ECAP_ISR_SOURCE_CAPTURE_EVENT_3 |
ECAP_ISR_SOURCE_CAPTURE_EVENT_4 |
ECAP_ISR_SOURCE_COUNTER_OVERFLOW |
ECAP_ISR_SOURCE_COUNTER_PERIOD |
ECAP_ISR_SOURCE_COUNTER_COMPARE));
ECAP_clearInterrupt(ECAP1_BASE,
// Disable CAP1-CAP4 register loads
ECAP_disableTimeStampCapture(ECAP1_BASE);
// Configure eCAP
// Enable capture mode.
// One shot mode, stop capture at event 4.
// Set polarity of the events to rising, falling, rising, falling edge.
// Set capture in time difference mode.
// Select input from XBAR7.
// Enable eCAP module.
// Enable interrupt.
ECAP_stopCounter(ECAP1_BASE);
ECAP_enableCaptureMode(ECAP1_BASE);
ECAP_setCaptureMode(ECAP1_BASE, ECAP_ONE_SHOT_CAPTURE_MODE, ECAP_EVENT_4);
ECAP_setEventPolarity(ECAP1_BASE, ECAP_EVENT_1, ECAP_EVNT_FALLING_EDGE);
ECAP_setEventPolarity(ECAP1_BASE, ECAP_EVENT_2, ECAP_EVNT_RISING_EDGE);
ECAP_setEventPolarity(ECAP1_BASE, ECAP_EVENT_3, ECAP_EVNT_FALLING_EDGE);
ECAP_setEventPolarity(ECAP1_BASE, ECAP_EVENT_4, ECAP_EVNT_RISING_EDGE);
ECAP_enableCounterResetOnEvent(ECAP1_BASE, ECAP_EVENT_1);
ECAP_enableCounterResetOnEvent(ECAP1_BASE, ECAP_EVENT_2);
ECAP_enableCounterResetOnEvent(ECAP1_BASE, ECAP_EVENT_3);
ECAP_enableCounterResetOnEvent(ECAP1_BASE, ECAP_EVENT_4);
ECAP_selectECAPInput(ECAP1_BASE, ECAP_INPUT_INPUTXBAR7);
ECAP_enableLoadCounter(ECAP1_BASE);
ECAP_setSyncOutMode(ECAP1_BASE, ECAP_SYNC_OUT_SYNCI);
ECAP_startCounter(ECAP1_BASE);
ECAP_enableTimeStampCapture(ECAP1_BASE);
ECAP_reArm(ECAP1_BASE);
ECAP_enableInterrupt(ECAP1_BASE, ECAP_ISR_SOURCE_CAPTURE_EVENT_4);
// eCAP 1 ISR
// Get the capture counts. Each capture should be 2x the ePWM count
// because of the ePWM clock divider.
cap2Count = ECAP_getEventTimeStamp(ECAP1_BASE, ECAP_EVENT_2);
cap3Count = ECAP_getEventTimeStamp(ECAP1_BASE, ECAP_EVENT_3);
cap4Count = ECAP_getEventTimeStamp(ECAP1_BASE, ECAP_EVENT_4);
// Compare the period value with the captured count
/* epwm3PeriodCount = EPWM_getTimeBasePeriod(EPWM3_BASE);
if(cap2Count > ((epwm3PeriodCount *2) + 2U) ||
cap2Count < ((epwm3PeriodCount *2) - 2U))
error();
if(cap3Count > ((epwm3PeriodCount *2) + 2U) ||
cap3Count < ((epwm3PeriodCount *2) - 2U))
error();
if(cap4Count > ((epwm3PeriodCount *2) + 2U) ||
cap4Count < ((epwm3PeriodCount *2) - 2U))
error();
ecap1IntCount++;*/
// Keep track of the ePWM direction and adjust period accordingly to
// generate a variable frequency PWM.
/* if(epwm3TimerDirection == EPWM_TIMER_UP)
if(epwm3PeriodCount < PWM3_TIMER_MAX)
EPWM_setTimeBasePeriod(EPWM3_BASE, ++epwm3PeriodCount);
else
epwm3TimerDirection = EPWM_TIMER_DOWN;
else
if(epwm3PeriodCount > PWM3_TIMER_MIN)
EPWM_setTimeBasePeriod(EPWM3_BASE, --epwm3PeriodCount);
else
// Count correct captures
ecap1PassCount++;
// Clear interrupt flags for more interrupts.
ECAP_clearInterrupt(ECAP1_BASE,ECAP_ISR_SOURCE_CAPTURE_EVENT_4);
ECAP_clearGlobalInterrupt(ECAP1_BASE);
// Start eCAP
// Acknowledge the group interrupt for more interrupts.
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP4);
// error - Error function
void error()
ESTOP0;
Thanks everyone
