Part Number: TMS320F28377S
Hi Team,
Can you please check and advise with following request?
We made our first tests with Code Composer version 6.2 using the LAUNCHXL-F28377S development board. We used the V210 Header and library files available in the control suite. It worked without any problems.
Later, we did our experiments using Code composer studio 9.3 and code composer studio 10.3 versions. We encountered constant library errors, obj file errors, gmakefile errors in these versions. We could not find suitable header files and libraries to work with these versions on Texas Instrument site. It again recommends the V210 library in the forums, but it gives too many errors. We look forward to your support about the current library files.
In addition, interrupt times, ram areas, etc. that we have set in code composer studio version 6.2. It differs when we switch to the new version. We cannot run the software we wrote with 6.2 version as we want in 10.3 version.
For example, in Code composer studio 6.2, we set the PWM interrupts to 100 micro seconds. When we compile and run the same code in code composer version 10.3, the interrupt time increases to 200 micro seconds. We also expect your support in this regard.
Thanks in advance
Best Regards
Furkan Sefiloglu
