I found the following passage in TI literature spraa85e in section 8.1.
"Every function has been documented in detail, explaining the purpose of the function, how to use it, the
meaning of the return value (if not void), and the values that are valid for each parameter. It is important to
read this documentation to look for possible usage notes. For example, the function
ADC_enableConverter() advises that a delay is required between calling the function and beginning
sampling to allow the ADC time to power up. This documentation is found in both PDF and HTML formats
in C2000Ware and also in the driver library header files."
But I can not find the documentation for driverlib functions in C2000Ware as mentioned in above passage. Where to find such documentation?
Thanks!
Duman
