Part Number: TMS320F280049C
Other Parts Discussed in Thread: AMC1306EVM, C2000WARE
Hi
I try to use AMC1306EVM to test SDFM program. I made some changes on file sdfm_ex4_pwm_sync_cpuread.c
under folder //ti/c2000/C2000Ware_3_02_00_00/drivelib/f28004x/examples/sdfm.
// FILE: sdfm_ex4_pwm_sync_cpuread.c
// TITLE: SDFM PWM Sync Example
//! \addtogroup driver_example_list
//! <h1> SDFM PWM Sync </h1>
//! In this example, SDFM filter data is read by CPU in SDFM ISR routine. The
//! SDFM configuration is shown below:
//! - SDFM1 is used in this example.
//! - MODE0 Input control mode selected
//! - Comparator settings
//! - Sinc3 filter selected
//! - OSR = 32
//! - hlt = 0x7FFF (Higher threshold setting)
//! - llt = 0x0000(Lower threshold setting)
//! - Data filter settings
//! - All the 4 filter modules enabled
//! - OSR = 256
//! - All the 4 filters are synchronized by using PWM
//! (Master Filter enable bit)
//! - Filter output represented in 16 bit format
//! - In order to convert 25 bit Data filter
//! into 16 bit format user needs to right shift by 10 bits for
//! Sinc3 filter with OSR = 256
//! - Interrupt module settings for SDFM filter
//! - All the 4 higher threshold comparator interrupts disabled
//! - All the 4 lower threshold comparator interrupts disabled
//! - All the 4 modulator failure interrupts disabled
//! - All the 4 filter will generate interrupt when a new filter data
//! is available
//! \b External \b Connections \n
//! Connect Sigma-Delta streams to (SD-D1, SD-C1 to SD-D4,SD-C4)
//! on GPIO24-GPIO31
//! \b Watch \b Variables \n
//! - \b filter1Result - Output of filter 1
//! - \b filter2Result - Output of filter 2
//! - \b filter3Result - Output of filter 3
//! - \b filter4Result - Output of filter 4
// $TI Release: F28004x Support Library v1.10.00.00 $
// $Release Date: Tue May 26 17:06:03 IST 2020 $
// $Copyright:
// Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
#include <stdio.h>
// Defines
#define MAX_SAMPLES 1024
#define EPWM_TIMER_TBPRD 65535 // ePWM Period register
#define JIAKAI
// Globals
uint32_t sdfmInstance;
uint32_t pwmInstance = EPWM8_BASE; // ePWM 8 for synchronizing SDFM1 filters
int16_t filter1Result[MAX_SAMPLES];
int16_t filter2Result[MAX_SAMPLES];
int16_t filter3Result[MAX_SAMPLES];
int16_t filter4Result[MAX_SAMPLES];
#pragma DATA_SECTION(filter1Result, "Filter1_RegsFile");
#pragma DATA_SECTION(filter2Result, "Filter2_RegsFile");
#pragma DATA_SECTION(filter3Result, "Filter3_RegsFile");
#pragma DATA_SECTION(filter4Result, "Filter4_RegsFile");
// Function Prototypes
void configureSDFMPins(void);
void initEPWM(uint32_t epwmInstance);
__interrupt void sdfm1ErrorISR(void);
__interrupt void sdfmDR1ISR(void);
// Main
void main(void)
uint16_t hlt, llt;
// Initialize device clock and peripherals
Device_init();
// Setup GPIO by disabling pin locks and enabling pullups
Device_initGPIO();
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP5);
Interrupt_register(INT_SDFM1DR1, sdfmDR1ISR);
Interrupt_register(INT_SDFM1, sdfm1ErrorISR);
// Enable SDFM1 Error and DR interrupts
Interrupt_enable(INT_SDFM1);
Interrupt_enable(INT_SDFM1DR1);
// Configure GPIO pins as SDFM pins
configureSDFMPins();
// Select SDFM1
sdfmInstance = SDFM1_BASE;
// Input Control Module:
// Configure Modulator Clock rate = Modulator data rate
SDFM_setupModulatorClock(sdfmInstance, SDFM_FILTER_1,
SDFM_MODULATOR_CLK_EQUAL_DATA_RATE);
#ifndef JIAKAI
SDFM_setupModulatorClock(sdfmInstance, SDFM_FILTER_2,
SDFM_setupModulatorClock(sdfmInstance, SDFM_FILTER_3,
SDFM_setupModulatorClock(sdfmInstance, SDFM_FILTER_4,
#endif
// Comparator Module
hlt = 0x7FFF; //Over value threshold settings
llt = 0x0000; //Under value threshold settings
// Configure Comparator module's comparator filter type and comparator's OSR
// value, higher threshold, lower threshold
SDFM_configComparator(sdfmInstance,
(SDFM_FILTER_1 | SDFM_FILTER_SINC_3 | SDFM_SET_OSR(32)),
(SDFM_GET_LOW_THRESHOLD(llt) | SDFM_GET_HIGH_THRESHOLD(hlt)), 0);
#ifndef JIAKAI
(SDFM_FILTER_2 | SDFM_FILTER_SINC_3 | SDFM_SET_OSR(32)),
(SDFM_FILTER_3 | SDFM_FILTER_SINC_3 | SDFM_SET_OSR(32)),
(SDFM_FILTER_4 | SDFM_FILTER_SINC_3 | SDFM_SET_OSR(32)),
#endif
// Data filter Module
// Configure Data filter modules filter type, OSR value and
// enable / disable data filter
SDFM_configDataFilter(sdfmInstance, (SDFM_FILTER_1 | SDFM_FILTER_SINC_3 |
SDFM_SET_OSR(256)), (SDFM_DATA_FORMAT_16_BIT | SDFM_FILTER_ENABLE |
SDFM_SHIFT_VALUE(0x000A)));
#ifndef JIAKAI
SDFM_configDataFilter(sdfmInstance, (SDFM_FILTER_2 | SDFM_FILTER_SINC_3 |
SDFM_configDataFilter(sdfmInstance, (SDFM_FILTER_3 | SDFM_FILTER_SINC_3 |
SDFM_configDataFilter(sdfmInstance, (SDFM_FILTER_4 | SDFM_FILTER_SINC_3 |
#endif
// Enable Master filter bit: Unless this bit is set none of the filter modules
// can be enabled. All the filter modules are synchronized when master filter
// bit is enabled after individual filter modules are enabled.
SDFM_enableMasterFilter(sdfmInstance);
// PWM signals can synchronize SDFM1 filters. Enabling PWM sync for SDFM
// filters.
SDFM_enableExternalReset(sdfmInstance, SDFM_FILTER_1);
#ifndef JIAKAI
SDFM_enableExternalReset(sdfmInstance, SDFM_FILTER_2);
SDFM_enableExternalReset(sdfmInstance, SDFM_FILTER_3);
SDFM_enableExternalReset(sdfmInstance, SDFM_FILTER_4);
#endif
SDFM_setPWMSyncSource(sdfmInstance, SDFM_FILTER_1, SDFM_SYNC_PWM8_SOCA);
#ifndef JIAKAI
SDFM_setPWMSyncSource(sdfmInstance, SDFM_FILTER_2, SDFM_SYNC_PWM8_SOCA);
SDFM_setPWMSyncSource(sdfmInstance, SDFM_FILTER_3, SDFM_SYNC_PWM8_SOCA);
SDFM_setPWMSyncSource(sdfmInstance, SDFM_FILTER_4, SDFM_SYNC_PWM8_SOCA);
#endif
// Init EPWMs
initEPWM(pwmInstance);
// Enable interrupts
// Following SDFM interrupts can be enabled / disabled using this function.
// Enable / disable comparator high threshold
// Enable / disable comparator low threshold
// Enable / disable modulator clock failure
// Enable / disable filter acknowledge
SDFM_enableInterrupt(sdfmInstance, SDFM_FILTER_1,
(SDFM_MODULATOR_FAILURE_INTERRUPT |
SDFM_DATA_FILTER_ACKNOWLEDGE_INTERRUPT));
#ifndef JIAKAI
SDFM_enableInterrupt(sdfmInstance, SDFM_FILTER_2,
SDFM_enableInterrupt(sdfmInstance, SDFM_FILTER_3,
SDFM_enableInterrupt(sdfmInstance, SDFM_FILTER_4,
#endif
SDFM_disableInterrupt(sdfmInstance, SDFM_FILTER_1,
(SDFM_HIGH_LEVEL_THRESHOLD_INTERRUPT |
SDFM_LOW_LEVEL_THRESHOLD_INTERRUPT));
#ifndef JIAKAI
SDFM_disableInterrupt(sdfmInstance, SDFM_FILTER_2,
SDFM_disableInterrupt(sdfmInstance, SDFM_FILTER_3,
SDFM_disableInterrupt(sdfmInstance, SDFM_FILTER_4,
#endif
while((HWREGH(pwmInstance + EPWM_O_TBCTR)) < 550);
// Enable master interrupt so that any of the filter interrupts can trigger
// by SDFM interrupt to CPU
SDFM_enableMasterInterrupt(sdfmInstance);
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
while(1);
// sdfm1ErrorISR - SDFM1 Error ISR
// Clear SDFM flag register (SDIFLG)
SDFM_clearInterruptFlag(SDFM1_BASE, SDFM_MASTER_INTERRUPT_FLAG |
0xFFFF);
// Acknowledge this interrupt to receive more interrupts from group 5
// sdfmDR1ISR - SDFM DR1 ISR
static uint16_t loopCounter1 = 0;
SDFM_setOutputDataFormat(SDFM1_BASE, SDFM_FILTER_1,
SDFM_DATA_FORMAT_16_BIT);
// Read SDFM flag register (SDIFLG)
if(loopCounter1 >= MAX_SAMPLES)
loopCounter1 = 0;
while((HWREG(SDFM1_BASE + SDFM_O_SDIFLG) & 0xF000U) != 0xF000U)
#ifdef JIAKAI
filter1Result[loopCounter1++] =
(int16_t)(SDFM_getFilterData(SDFM1_BASE, SDFM_FILTER_1) >> 16U);
#else
filter1Result[loopCounter1] =
filter2Result[loopCounter1] =
(int16_t)(SDFM_getFilterData(SDFM1_BASE, SDFM_FILTER_2) >> 16U);
filter3Result[loopCounter1] =
(int16_t)(SDFM_getFilterData(SDFM1_BASE, SDFM_FILTER_3) >> 16U);
filter4Result[loopCounter1++] =
(int16_t)(SDFM_getFilterData(SDFM1_BASE, SDFM_FILTER_4) >> 16U);
#endif
SDFM_FILTER_1_NEW_DATA_FLAG |
SDFM_FILTER_2_NEW_DATA_FLAG |
SDFM_FILTER_3_NEW_DATA_FLAG |
SDFM_FILTER_4_NEW_DATA_FLAG);
// configureSDFMPins - Configure SDFM GPIOs
uint16_t pin;
// Configure GPIO16-GPIO31 as SDFM pins
#ifdef JIAKAI
for(pin = 16; pin <= 17; pin++)
GPIO_setDirectionMode(pin, GPIO_DIR_MODE_IN);
GPIO_setMasterCore(pin, GPIO_CORE_CPU1);
GPIO_setPadConfig(pin, GPIO_PIN_TYPE_STD);
GPIO_setQualificationMode(pin, GPIO_QUAL_ASYNC);
GPIO_setPinConfig(GPIO_16_SD_D1);
GPIO_setPinConfig(GPIO_17_SD_C1);
#else
for(pin = 24; pin <= 31; pin++)
GPIO_setPinConfig(GPIO_24_SD_D1);
GPIO_setPinConfig(GPIO_25_SD_C1);
GPIO_setPinConfig(GPIO_26_SD_D2);
GPIO_setPinConfig(GPIO_27_SD_C2);
GPIO_setPinConfig(GPIO_28_SD_D3);
GPIO_setPinConfig(GPIO_29_SD_C3);
GPIO_setPinConfig(GPIO_30_SD_D4);
GPIO_setPinConfig(GPIO_31_SD_C4);
#endif
// done - Function to halt debugger and stop application
void done(void)
asm(" ESTOP0");
for(;;);
// initEPWM - Initialize specified EPWM settings
// Disable sync(Freeze clock to PWM as well)
SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// Setup TBCLK: Configure timer period = 801 TBCLKs, phase = 0 &
// clear counter
EPWM_setTimeBasePeriod(epwmInstance, EPWM_TIMER_TBPRD);
EPWM_setPhaseShift(epwmInstance, 0U);
EPWM_setTimeBaseCounter(epwmInstance, 0U);
// Set CMPA value
EPWM_setCounterCompareValue(epwmInstance, EPWM_COUNTER_COMPARE_A, 200U);
// Setup counter mode
EPWM_setTimeBaseCounterMode(epwmInstance, EPWM_COUNTER_MODE_UP);
EPWM_setClockPrescaler(epwmInstance,
EPWM_CLOCK_DIVIDER_1,
EPWM_HSCLOCK_DIVIDER_1);
// Set actions:
// Toggle PWMxA on event A, up-count
// Toggle PWMxB on event A, up-count
GPIO_setPadConfig(0, GPIO_PIN_TYPE_STD);
GPIO_setPinConfig(GPIO_0_EPWM1A);
GPIO_setPadConfig(1, GPIO_PIN_TYPE_STD);
GPIO_setPinConfig(GPIO_1_EPWM1B);
EPWM_setTimeBasePeriod(EPWM1_BASE, 24); // PWM1 period: 0.5us
EPWM_setTimeBaseCounterMode(EPWM1_BASE, EPWM_COUNTER_MODE_UP);
EPWM_setClockPrescaler(EPWM1_BASE,
EPWM_setActionQualifierAction(EPWM1_BASE,
EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_TOGGLE,
EPWM_AQ_OUTPUT_ON_TIMEBASE_PERIOD);
// EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
EPWM_AQ_OUTPUT_B,
// EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPB);
#ifndef JIAKAI
// Configure SOCA signal
EPWM_setADCTriggerSource(EPWM1_BASE, EPWM_SOC_A, EPWM_SOC_TBCTR_U_CMPA);
EPWM_setADCTriggerEventPrescale(EPWM1_BASE, EPWM_SOC_A, 1);
#endif
// Enable sync and clock to PWM
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// End of file
The main changes are as follows (Marks "JAIKAI" in the code):
1. Change Sdfm1.CH1 GPIO to GPIO16 and GPIO17.
2. Change PWM1 to generate a 2MHz 50/50 duty cycle (PWM1A offers clock for both Sdfm1.CH1 and AMC1306EVM).
I run the code but the program never enters interrupt routine sdfmDR1ISR and sdfm1ErrorISR.
if PWM1 doesn't connect to GPIO17, the program enters sdfmErrorISR but still doesn't enter sdfmDR1ISR.
thanks,
Jiakai
