Part Number: TMS320C28344
As there are so many configuration options when building a project in CCS, Does Ti provide a guide for each setup and their
explation?
explation?
Can you let me know which TI C2000 project you are referring to? Are you using the examples from C2000Ware?
Pls take a look at this doc and see if it helps.
https://dev.ti.com/tirex/explore/node?node=AEscqymkM-Gi5wQjrRp85Q__coGQ502__LATEST
Best Regards
Siddharth
However, when I go througth this docement, the content about the configuration of CCS in the 2 chapter only has 9 pages, which may be enough for starting up. But It seemf not very comphrensive for all the confurations introduction, as there are so many options.
What do you mean by configurations? Are you referring to CCS setup?
If so, this link will help you in getting started with CCS.
https://software-dl.ti.com/ccs/esd/documents/users_guide/index_overview.html
Best Regards
Siddharth
Thanks for your reply, for the configuration , I mean setting the properties of the prject. For example, when you right click the project name in Project explorer, then you can set the properties of the project.
Hi ,
https://software-dl.ti.com/ccs/esd/documents/users_guide/ccs_project-management.html#general-properties is the link that has this information.
Best Regards
Siddharth
Hi Chao,
Did my response resolve my query? If so, can I close this thread?
Best Regards
Siddharth
