Part Number: TMS320F28335
Please tell me how to import the C code generated by simulink into ccs? I am importing the folder directly, and the files in the folder are not visible. Thank you!
When you try to import the project, it does not see any project at this location or you encounter any issue in importing?
I see .project file but no sure if it has .cproject file also.
What is CCS version you are using?
Looks like project file was not generated properly. I have contacted MathWorks team to take a look at this.
Hi Chaozhen,
Please refer the below link on how to import the Simulink project into CCS.
Creating CCS Project from a Model - MATLAB & Simulink (mathworks.com)
Venkatesh C
hi, Venkatesh,i'm chaozhen,now I have a new problem. when i generated code,the path does not exist, can u telll me how to solve it.
Hi Chaozhen,
Please can you send the full path to the code gen folder.
It is likely that the path has some space(s).
Venkatesh C
The full path is C:\Users\DELL\Desktop\simulinkfold. I check the path which does not have some space(s), and still not succeed.
and i have a new question: the code folder that I generated in simulink is copied to ccs or is shared to ccs in simulink?
Hi Chaozhen,
As we need more information to understand the issue better, it would be best for you to get in touch with our support channel. When we have a support ticket, our internal process enables us to involve the right people on this issue and we will immediately get in touch with you to understand the case in a more detailed way.
Please connect to us at:
https://www.mathworks.com/support.html
Venkatesh C
Chaozhen,
As you are creating a new support ticket on MathWorks forum, I will close this thread.
