Part Number: LAUNCHXL-F280049C
I try to go through blink LED example or other examples:
www.mathworks.com/.../getting-started-example.html
When I try to build/deploy the model, there is an error occurred. Error report is attached.
Hi Shengnan,
Can you try a different path for the build.
Currently, the "shengnan.li" in the build path may the issue.
Venkatesh C
Hi, Venkatesh,
Thanks for your response. where to change the build directory?
The original file is under C:/c2000 folder. the directory with shengnan.li is auto generated while building.
Shengnan
Hi Shengnan,
Please contact our technical support as I see we may need to have a WebEx call to further help you.
Contact Us - MATLAB & Simulink (mathworks.com)
From the above link create a service request.
Venkatesh C
