How to add content of PDO? For example, do how we add Actual Velocity (0x606C in CIA 402) to PDO Content (① in figure 2.1).
Figure 2.1
Figure 2.1
MaoShun,
I've assigned you post to someone inside C2000, in the meantime please see if this post helps your issue. https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1004022/tms320f28388d-f28388d-ethercat-sdo
Matthew
AFAIK, the recommended approach is to use the SSC tool to add/update objects and then regenerate the ssc code and ESI files. You may refer to the SSC user guide, specifically chapter 13
https://download.beckhoff.com/download/document/io/ethercat-development-products/an_et9300_v1i8.pdf
