Part Number: TMS320F28379D
Hello TI Team,
I want help to enable printf on TMS320F28379D launchpad ,how can i use printf function using uart pin 42 and 43.
Hello TI Team,
Hi Atul,
I recommend taking a look at the following example within the C2000Ware SDK. It includes the required files to use printf and then utilizes it within the example.
C2000Ware_version\device_support\f2837xd\examples\cpu1\launchxl_f28379d
Marlyn
Hi Marlyn,
I am using C2000Ware_3_04_00_00_Software\driverlib\f2837xd\examples\cpu1\sci\sci_ex1_loopback.c this example and add printf supported file . but here uart not working .on console shows garbage value.
following code and file for printf
status = add_device("scia", _SSA, SCI_open, SCI_close, SCI_read, SCI_write,
SCI_lseek, SCI_unlink, SCI_rename);
fid = fopen("scia","w");
freopen("scia:", "w", stdout);
setvbuf(stdout, NULL, _IONBF, 0);
//! \brief Contains the various functions related to the serial
//! communications interface (SCI) object
// Group: C2000
// Target Device: TMS320F2802x
// (C) Copyright 2012, Texas Instruments, Inc.
// $TI Release: F2837xD Support Library v3.12.00.00 $
// $Release Date: Fri Feb 12 19:03:23 IST 2021 $
// $Copyright:
// Copyright (C) 2013-2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include <stdio.h>
#include <file.h>
#include <stdint.h>
#include <stdbool.h>
//#include "F28x_Project.h"
#include "driverlib.h"
#include "device.h"
#include "board.h"
#include "sci_io.h"
// Defines
// Globals
uint16_t deviceOpen = 0;
// Functions
// SCI_open -
int SCI_open(const char * path, unsigned flags, int llv_fd)
if(deviceOpen)
return (-1);
else
deviceOpen = 1;
return (1);
// SCI_close -
int SCI_close(int dev_fd)
if((dev_fd != 1) || (!deviceOpen))
return (-1);
else
deviceOpen = 0;
return (0);
// SCI_read -
int SCI_read(int dev_fd, char * buf, unsigned count)
uint16_t readCount = 0;
uint16_t * bufPtr = (uint16_t *) buf;
if(count == 0)
return (0);
// while((readCount < count) && SciaRegs.SCIRXST.bit.RXRDY)
while((readCount < count) && (SCI_getRxFIFOStatus(mySCI0_BASE) == SCI_FIFO_RX0))
// *bufPtr = SciaRegs.SCIRXBUF.all;
*bufPtr =SCI_readCharBlockingFIFO(mySCI0_BASE);//,*bufPtr);
readCount++;
bufPtr++;
return (readCount);
// SCI_write -
int SCI_write(int dev_fd, const char * buf, unsigned count)
uint16_t writeCount = 0;
if(count == 0)
return (0);
// SCI_writeCharArray(mySCI0_BASE,buf,count);
while(writeCount < count)
// while(!SciaRegs.SCICTL2.bit.TXRDY);
while(!SCI_isSpaceAvailableNonFIFO(mySCI0_BASE));
// SciaRegs.SCITXBUF.all = *bufPtr;
SCI_writeCharNonBlocking(mySCI0_BASE,*bufPtr);
writeCount++;
bufPtr++;
return (count);
// SCI_lseek -
off_t SCI_lseek(int dev_fd, off_t offset, int origin)
return (0);
// SCI_unlink -
int SCI_unlink(const char * path)
return (0);
// SCI_rename -
int SCI_rename(const char * old_name, const char * new_name)
return (0);
// End of File
Hi Atul,
Have you added the pre-define "_LAUNCHXL_F28379D" to your project? This is required to setup the proper device clocking when using the launchpad.
Marlyn
