TMDSCNCD28379D: Memory related error
Part Number: TMDSCNCD28379D
I added few lines into my code and on compilation, I am getting the following error:
<Linking>
"../2837x_RAM_lnk_cpu1.cmd", line 60: error #10099-D: program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment/blocking fails for section ".text" size 0x1ffdpage 0.  Available memory ranges:
   RAMM0        size: 0x2de        unused: 0x0          max hole: 0x0
   RAMD0        size: 0x800        unused: 0x5          max hole: 0x5
   RAMLS0       size: 0x800        unused: 0x6          max hole: 0x6
   RAMLS1       size: 0x800        unused: 0x9c         max hole: 0x9c
   RAMLS2       size: 0x800        unused: 0x800        max hole: 0x800
   RAMLS3       size: 0x800        unused: 0x800        max hole: 0x800
   RAMLS4       size: 0x800        unused: 0x800        max hole: 0x800
error #10010: errors encountered during linking; "TotalAlgo.out" not built
The memory map file is given below. Kindly let me know the changes I need to make in this.
             TMS320C2000 Linker PC v18.1.2
>> Linked Tue Aug  6 17:52:16 2019
OUTPUT FILE NAME:   <TotalAlgo1.out>
ENTRY POINT SYMBOL: "_c_int00"  address: 000095b8
MEMORY CONFIGURATION
         name            origin    length      used     unused   attr    fill
PAGE 0:
  BEGIN                 00000000   00000002  00000002  00000000  RWIX
  RAMM0                 00000122   000002de  000002de  00000000  RWIX
  RAMLS0                00008000   00000800  000007f5  0000000b  RWIX
  RAMLS1                00008800   00000800  00000800  00000000  RWIX
  RAMLS2                00009000   00000800  00000691  0000016f  RWIX
  RAMLS3                00009800   00000800  00000000  00000800  RWIX
  RAMLS4                0000a000   00000800  00000000  00000800  RWIX
  RAMD0                 0000b000   00000800  00000800  00000000  RWIX
  RESET                 003fffc0   00000002  00000000  00000002  RWIX
PAGE 1:
  BOOT_RSVD             00000002   00000120  00000000  00000120  RWIX
  RAMM1                 00000400   00000400  00000200  00000200  RWIX
  ADCA_RESULT           00000b00   00000020  00000018  00000008  RWIX
  ADCB_RESULT           00000b20   00000020  00000018  00000008  RWIX
  ADCC_RESULT           00000b40   00000020  00000018  00000008  RWIX
  ADCD_RESULT           00000b60   00000020  00000018  00000008  RWIX
  CPU_TIMER0            00000c00   00000008  00000008  00000000  RWIX
  CPU_TIMER1            00000c08   00000008  00000008  00000000  RWIX
  CPU_TIMER2            00000c10   00000008  00000008  00000000  RWIX
  PIE_CTRL              00000ce0   00000020  0000001a  00000006  RWIX
  PIE_VECT              00000d00   00000200  000001c0  00000040  RWIX
  DMA                   00001000   00000200  000000e0  00000120  RWIX
  CLA1                  00001400   00000040  0000003e  00000002  RWIX
  EPWM1                 00004000   00000100  00000100  00000000  RWIX
  EPWM2                 00004100   00000100  00000100  00000000  RWIX
  EPWM3                 00004200   00000100  00000100  00000000  RWIX
  EPWM4                 00004300   00000100  00000100  00000000  RWIX
  EPWM5                 00004400   00000100  00000100  00000000  RWIX
  EPWM6                 00004500   00000100  00000100  00000000  RWIX
  EPWM7                 00004600   00000100  00000100  00000000  RWIX
  EPWM8                 00004700   00000100  00000100  00000000  RWIX
  EPWM9                 00004800   00000100  00000100  00000000  RWIX
  EPWM10                00004900   00000100  00000100  00000000  RWIX
  EPWM11                00004a00   00000100  00000100  00000000  RWIX
  EPWM12                00004b00   00000100  00000100  00000000  RWIX
  ECAP1                 00005000   00000020  00000020  00000000  RWIX
  ECAP2                 00005020   00000020  00000020  00000000  RWIX
  ECAP3                 00005040   00000020  00000020  00000000  RWIX
  ECAP4                 00005060   00000020  00000020  00000000  RWIX
  ECAP5                 00005080   00000020  00000020  00000000  RWIX
  ECAP6                 000050a0   00000020  00000020  00000000  RWIX
  EQEP1                 00005100   00000040  00000022  0000001e  RWIX
  EQEP2                 00005140   00000040  00000022  0000001e  RWIX
  EQEP3                 00005180   00000040  00000022  0000001e  RWIX
  DACA                  00005c00   00000010  00000008  00000008  RWIX
  DACB                  00005c10   00000010  00000008  00000008  RWIX
  DACC                  00005c20   00000010  00000008  00000008  RWIX
  CMPSS1                00005c80   00000020  00000020  00000000  RWIX
  CMPSS2                00005ca0   00000020  00000020  00000000  RWIX
  CMPSS3                00005cc0   00000020  00000020  00000000  RWIX
  CMPSS4                00005ce0   00000020  00000020  00000000  RWIX
  CMPSS5                00005d00   00000020  00000020  00000000  RWIX
  CMPSS6                00005d20   00000020  00000020  00000000  RWIX
  CMPSS7                00005d40   00000020  00000020  00000000  RWIX
  CMPSS8                00005d60   00000020  00000020  00000000  RWIX
  SDFM1                 00005e00   00000080  00000080  00000000  RWIX
  SDFM2                 00005e80   00000080  00000080  00000000  RWIX
  MCBSPA                00006000   00000040  00000024  0000001c  RWIX
  MCBSPB                00006040   00000040  00000024  0000001c  RWIX
  SPIA                  00006100   00000010  00000010  00000000  RWIX
  SPIB                  00006110   00000010  00000010  00000000  RWIX
  SPIC                  00006120   00000010  00000010  00000000  RWIX
  SPID                  00006130   00000010  00000000  00000010  RWIX
  UPP                   00006200   00000100  00000048  000000b8  RWIX
  WD                    00007000   00000040  0000002b  00000015  RWIX
  NMIINTRUPT            00007060   00000010  00000007  00000009  RWIX
  XINT                  00007070   00000010  0000000b  00000005  RWIX
  SCIA                  00007200   00000010  00000010  00000000  RWIX
  SCIB                  00007210   00000010  00000010  00000000  RWIX
  SCIC                  00007220   00000010  00000010  00000000  RWIX
  SCID                  00007230   00000010  00000010  00000000  RWIX
  I2CA                  00007300   00000040  00000022  0000001e  RWIX
  I2CB                  00007340   00000040  00000022  0000001e  RWIX
  ADCA                  00007400   00000080  00000080  00000000  RWIX
  ADCB                  00007480   00000080  00000080  00000000  RWIX
  ADCC                  00007500   00000080  00000080  00000000  RWIX
  ADCD                  00007580   00000080  00000080  00000000  RWIX
  INPUT_XBAR            00007900   00000020  00000020  00000000  RWIX
  XBAR                  00007920   00000020  00000020  00000000  RWIX
  SYNC_SOC              00007940   00000010  00000006  0000000a  RWIX
  DMACLASRCSEL          00007980   00000040  0000001a  00000026  RWIX
  EPWM_XBAR             00007a00   00000040  00000040  00000000  RWIX
  CLB_XBAR              00007a40   00000040  00000000  00000040  RWIX
  OUTPUT_XBAR           00007a80   00000040  00000040  00000000  RWIX
  GPIOCTRL              00007c00   00000180  00000180  00000000  RWIX
  GPIODAT               00007f00   00000030  00000030  00000000  RWIX
  RAMLS5                0000a800   00000800  00000754  000000ac  RWIX
  RAMD1                 0000b800   00000800  00000000  00000800  RWIX
  RAMGS0                0000c000   00001000  00000000  00001000  RWIX
  RAMGS1                0000d000   00001000  00000000  00001000  RWIX
  RAMGS2                0000e000   00001000  00000000  00001000  RWIX
  RAMGS3                0000f000   00001000  00000000  00001000  RWIX
  RAMGS4                00010000   00001000  00000000  00001000  RWIX
  RAMGS5                00011000   00001000  00000000  00001000  RWIX
  RAMGS6                00012000   00001000  00000000  00001000  RWIX
  RAMGS7                00013000   00001000  00000000  00001000  RWIX
  RAMGS8                00014000   00001000  00000000  00001000  RWIX
  RAMGS9                00015000   00001000  00000000  00001000  RWIX
  RAMGS10               00016000   00001000  00000000  00001000  RWIX
  RAMGS11               00017000   00001000  00000000  00001000  RWIX
  RAMGS12               00018000   00001000  00000000  00001000  RWIX
  RAMGS13               00019000   00001000  00000000  00001000  RWIX
  RAMGS14               0001a000   00001000  00000000  00001000  RWIX
  RAMGS15               0001b000   00001000  00000000  00001000  RWIX
  CPU2TOCPU1RAM         0003f800   00000400  00000000  00000400  RWIX
  CPU1TOCPU2RAM         0003fc00   00000400  00000000  00000400  RWIX
  EMIF1                 00047000   00000800  00000070  00000790  RWIX
  EMIF2                 00047800   00000800  00000070  00000790  RWIX
  CANA                  00048000   00000800  00000164  0000069c  RWIX
  CANB                  0004a000   00000800  00000164  0000069c  RWIX
  IPC                   00050000   00000024  00000024  00000000  RWIX
  FLASHPUMPSEMAPHORE    00050024   00000002  00000002  00000000  RWIX
  DEV_CFG               0005d000   00000180  0000012e  00000052  RWIX
  ANALOG_SUBSYS         0005d180   00000080  00000048  00000038  RWIX
  CLK_CFG               0005d200   00000100  00000032  000000ce  RWIX
  CPU_SYS               0005d300   00000100  00000082  0000007e  RWIX
  ROMPREFETCH           0005e608   00000002  00000002  00000000  RWIX
  DCSM_Z1               0005f000   00000030  00000024  0000000c  RWIX
  DCSM_Z2               0005f040   00000030  00000024  0000000c  RWIX
  DCSM_COMMON           0005f070   00000010  00000008  00000008  RWIX
  MEMCFG                0005f400   00000080  00000080  00000000  RWIX
  EMIF1CONFIG           0005f480   00000020  00000020  00000000  RWIX
  EMIF2CONFIG           0005f4a0   00000020  00000020  00000000  RWIX
  ACCESSPROTECTION      0005f4c0   00000040  00000040  00000000  RWIX
  MEMORYERROR           0005f500   00000040  00000040  00000000  RWIX
  ROMWAITSTATE          0005f540   00000002  00000002  00000000  RWIX
  FLASH0_CTRL           0005f800   00000300  00000182  0000017e  RWIX
  FLASH0_ECC            0005fb00   00000040  00000028  00000018  RWIX
  DCSM_Z1_OTP           00078000   00000020  00000020  00000000  RWIX
  DCSM_Z2_OTP           00078200   00000020  00000020  00000000  RWIX
SECTION ALLOCATION MAP
 output                                  attributes/
section   page    origin      length       input sections
codestart
*          0    00000000    00000002
                  00000000    00000002     F2837xD_CodeStartBranch.obj (codestart)
.cinit     0    00000122    00000170
                  00000122    00000132     main.obj (.cinit)
                  00000254    00000024     EPwm.obj (.cinit)
                  00000278    0000000e     rts2800_fpu32.lib : exit.c.obj (.cinit)
                  00000286    00000005                       : _lock.c.obj (.cinit:__lock)
                  0000028b    00000005                       : _lock.c.obj (.cinit:__unlock)
                  00000290    00000002     --HOLE-- [fill = 0]
.TI.ramfunc
*          0    00000292    00000004
                  00000292    00000004     F2837xD_usDelay.obj (.TI.ramfunc)
.pinit     0    00000122    00000000     UNINITIALIZED
.reset     0    003fffc0    00000002     DSECT
                  003fffc0    00000002     rts2800_fpu32.lib : boot28.asm.obj (.reset)
.stack     1    00000400    00000200     UNINITIALIZED
                  00000400    00000200     --HOLE--
AdcaResultFile
*          1    00000b00    00000018     UNINITIALIZED
                  00000b00    00000018     F2837xD_GlobalVariableDefs.obj (AdcaResultFile)
AdcbResultFile
*          1    00000b20    00000018     UNINITIALIZED
                  00000b20    00000018     F2837xD_GlobalVariableDefs.obj (AdcbResultFile)
AdccResultFile
*          1    00000b40    00000018     UNINITIALIZED
                  00000b40    00000018     F2837xD_GlobalVariableDefs.obj (AdccResultFile)
AdcdResultFile
*          1    00000b60    00000018     UNINITIALIZED
                  00000b60    00000018     F2837xD_GlobalVariableDefs.obj (AdcdResultFile)
Cla1RegsFile
*          1    00001400    0000003e     UNINITIALIZED
                  00001400    0000003e     F2837xD_GlobalVariableDefs.obj (Cla1RegsFile)
.ebss      1    0000a800    00000594     UNINITIALIZED
                  0000a800    00000568     main.obj (.ebss)
                  0000ad68    00000018     F2837xD_CpuTimers.obj (.ebss)
                  0000ad80    00000009     EPwm.obj (.ebss)
                  0000ad89    00000001     --HOLE--
                  0000ad8a    00000006     rts2800_fpu32.lib : exit.c.obj (.ebss)
                  0000ad90    00000002                       : _lock.c.obj (.ebss:__lock)
                  0000ad92    00000002                       : _lock.c.obj (.ebss:__unlock)
.econst    1    0000ad94    000001c0
                  0000ad94    000001c0     F2837xD_PieVect.obj (.econst:_PieVectTableInit)
GETBUFFER
*          0    0003f800    00000000     DSECT
GETWRITEIDX
PUTREADIDX
CpuTimer0RegsFile
*          1    00000c00    00000008     UNINITIALIZED
                  00000c00    00000008     F2837xD_GlobalVariableDefs.obj (CpuTimer0RegsFile)
CpuTimer1RegsFile
*          1    00000c08    00000008     UNINITIALIZED
                  00000c08    00000008     F2837xD_GlobalVariableDefs.obj (CpuTimer1RegsFile)
CpuTimer2RegsFile
*          1    00000c10    00000008     UNINITIALIZED
                  00000c10    00000008     F2837xD_GlobalVariableDefs.obj (CpuTimer2RegsFile)
PieVectTableFile
*          1    00000d00    000001c0     UNINITIALIZED
                  00000d00    000001c0     F2837xD_GlobalVariableDefs.obj (PieVectTableFile)
EmuKeyVar
*          1    00000d00    00000001     UNINITIALIZED
                  00000d00    00000001     F2837xD_GlobalVariableDefs.obj (EmuKeyVar)
EmuBModeVar
*          1    00000d01    00000001     UNINITIALIZED
                  00000d01    00000001     F2837xD_GlobalVariableDefs.obj (EmuBModeVar)
FlashCallbackVar
*          1    00000d02    00000000     UNINITIALIZED
FlashScalingVar
DacaRegsFile
*          1    00005c00    00000008     UNINITIALIZED
                  00005c00    00000008     F2837xD_GlobalVariableDefs.obj (DacaRegsFile)
DacbRegsFile
*          1    00005c10    00000008     UNINITIALIZED
                  00005c10    00000008     F2837xD_GlobalVariableDefs.obj (DacbRegsFile)
DaccRegsFile
*          1    00005c20    00000008     UNINITIALIZED
                  00005c20    00000008     F2837xD_GlobalVariableDefs.obj (DaccRegsFile)
AdcaRegsFile
*          1    00007400    00000080     UNINITIALIZED
                  00007400    00000080     F2837xD_GlobalVariableDefs.obj (AdcaRegsFile)
AdcbRegsFile
*          1    00007480    00000080     UNINITIALIZED
                  00007480    00000080     F2837xD_GlobalVariableDefs.obj (AdcbRegsFile)
AdccRegsFile
*          1    00007500    00000080     UNINITIALIZED
                  00007500    00000080     F2837xD_GlobalVariableDefs.obj (AdccRegsFile)
AdcdRegsFile
*          1    00007580    00000080     UNINITIALIZED
                  00007580    00000080     F2837xD_GlobalVariableDefs.obj (AdcdRegsFile)
CanaRegsFile
*          1    00048000    00000164     UNINITIALIZED
                  00048000    00000164     F2837xD_GlobalVariableDefs.obj (CanaRegsFile)
CanbRegsFile
*          1    0004a000    00000164     UNINITIALIZED
                  0004a000    00000164     F2837xD_GlobalVariableDefs.obj (CanbRegsFile)
AnalogSubsysRegsFile
*          1    0005d180    00000048     UNINITIALIZED
                  0005d180    00000048     F2837xD_GlobalVariableDefs.obj (AnalogSubsysRegsFile)
Cla1SoftIntRegsFile
*          1    00000ce0    00000004     DSECT
                  00000ce0    00000004     F2837xD_GlobalVariableDefs.obj (Cla1SoftIntRegsFile)
PieCtrlRegsFile
*          1    00000ce0    0000001a     UNINITIALIZED
                  00000ce0    0000001a     F2837xD_GlobalVariableDefs.obj (PieCtrlRegsFile)
DmaRegsFile
*          1    00001000    000000e0     UNINITIALIZED
                  00001000    000000e0     F2837xD_GlobalVariableDefs.obj (DmaRegsFile)
EPwm1RegsFile
*          1    00004000    00000100     UNINITIALIZED
                  00004000    00000100     F2837xD_GlobalVariableDefs.obj (EPwm1RegsFile)
EPwm2RegsFile
*          1    00004100    00000100     UNINITIALIZED
                  00004100    00000100     F2837xD_GlobalVariableDefs.obj (EPwm2RegsFile)
EPwm3RegsFile
*          1    00004200    00000100     UNINITIALIZED
                  00004200    00000100     F2837xD_GlobalVariableDefs.obj (EPwm3RegsFile)
EPwm4RegsFile
*          1    00004300    00000100     UNINITIALIZED
                  00004300    00000100     F2837xD_GlobalVariableDefs.obj (EPwm4RegsFile)
EPwm5RegsFile
*          1    00004400    00000100     UNINITIALIZED
                  00004400    00000100     F2837xD_GlobalVariableDefs.obj (EPwm5RegsFile)
EPwm6RegsFile
*          1    00004500    00000100     UNINITIALIZED
                  00004500    00000100     F2837xD_GlobalVariableDefs.obj (EPwm6RegsFile)
EPwm7RegsFile
*          1    00004600    00000100     UNINITIALIZED
                  00004600    00000100     F2837xD_GlobalVariableDefs.obj (EPwm7RegsFile)
EPwm8RegsFile
*          1    00004700    00000100     UNINITIALIZED
                  00004700    00000100     F2837xD_GlobalVariableDefs.obj (EPwm8RegsFile)
EPwm9RegsFile
*          1    00004800    00000100     UNINITIALIZED
                  00004800    00000100     F2837xD_GlobalVariableDefs.obj (EPwm9RegsFile)
EPwm10RegsFile
*          1    00004900    00000100     UNINITIALIZED
                  00004900    00000100     F2837xD_GlobalVariableDefs.obj (EPwm10RegsFile)
EPwm11RegsFile
*          1    00004a00    00000100     UNINITIALIZED
                  00004a00    00000100     F2837xD_GlobalVariableDefs.obj (EPwm11RegsFile)
EPwm12RegsFile
*          1    00004b00    00000100     UNINITIALIZED
                  00004b00    00000100     F2837xD_GlobalVariableDefs.obj (EPwm12RegsFile)
ECap1RegsFile
*          1    00005000    00000020     UNINITIALIZED
                  00005000    00000020     F2837xD_GlobalVariableDefs.obj (ECap1RegsFile)
ECap2RegsFile
*          1    00005020    00000020     UNINITIALIZED
                  00005020    00000020     F2837xD_GlobalVariableDefs.obj (ECap2RegsFile)
ECap3RegsFile
*          1    00005040    00000020     UNINITIALIZED
                  00005040    00000020     F2837xD_GlobalVariableDefs.obj (ECap3RegsFile)
ECap4RegsFile
*          1    00005060    00000020     UNINITIALIZED
                  00005060    00000020     F2837xD_GlobalVariableDefs.obj (ECap4RegsFile)
ECap5RegsFile
*          1    00005080    00000020     UNINITIALIZED
                  00005080    00000020     F2837xD_GlobalVariableDefs.obj (ECap5RegsFile)
ECap6RegsFile
*          1    000050a0    00000020     UNINITIALIZED
                  000050a0    00000020     F2837xD_GlobalVariableDefs.obj (ECap6RegsFile)
EQep1RegsFile
*          1    00005100    00000022     UNINITIALIZED
                  00005100    00000022     F2837xD_GlobalVariableDefs.obj (EQep1RegsFile)
EQep2RegsFile
*          1    00005140    00000022     UNINITIALIZED
                  00005140    00000022     F2837xD_GlobalVariableDefs.obj (EQep2RegsFile)
EQep3RegsFile
*          1    00005180    00000022     UNINITIALIZED
                  00005180    00000022     F2837xD_GlobalVariableDefs.obj (EQep3RegsFile)
Cmpss1RegsFile
*          1    00005c80    00000020     UNINITIALIZED
                  00005c80    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss1RegsFile)
Cmpss2RegsFile
*          1    00005ca0    00000020     UNINITIALIZED
                  00005ca0    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss2RegsFile)
Cmpss3RegsFile
*          1    00005cc0    00000020     UNINITIALIZED
                  00005cc0    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss3RegsFile)
Cmpss4RegsFile
*          1    00005ce0    00000020     UNINITIALIZED
                  00005ce0    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss4RegsFile)
Cmpss5RegsFile
*          1    00005d00    00000020     UNINITIALIZED
                  00005d00    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss5RegsFile)
Cmpss6RegsFile
*          1    00005d20    00000020     UNINITIALIZED
                  00005d20    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss6RegsFile)
Cmpss7RegsFile
*          1    00005d40    00000020     UNINITIALIZED
                  00005d40    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss7RegsFile)
Cmpss8RegsFile
*          1    00005d60    00000020     UNINITIALIZED
                  00005d60    00000020     F2837xD_GlobalVariableDefs.obj (Cmpss8RegsFile)
Sdfm1RegsFile
*          1    00005e00    00000080     UNINITIALIZED
                  00005e00    00000080     F2837xD_GlobalVariableDefs.obj (Sdfm1RegsFile)
Sdfm2RegsFile
*          1    00005e80    00000080     UNINITIALIZED
                  00005e80    00000080     F2837xD_GlobalVariableDefs.obj (Sdfm2RegsFile)
McbspaRegsFile
*          1    00006000    00000024     UNINITIALIZED
                  00006000    00000024     F2837xD_GlobalVariableDefs.obj (McbspaRegsFile)
McbspbRegsFile
*          1    00006040    00000024     UNINITIALIZED
                  00006040    00000024     F2837xD_GlobalVariableDefs.obj (McbspbRegsFile)
SpiaRegsFile
*          1    00006100    00000010     UNINITIALIZED
                  00006100    00000010     F2837xD_GlobalVariableDefs.obj (SpiaRegsFile)
SpibRegsFile
*          1    00006110    00000010     UNINITIALIZED
                  00006110    00000010     F2837xD_GlobalVariableDefs.obj (SpibRegsFile)
SpicRegsFile
*          1    00006120    00000010     UNINITIALIZED
                  00006120    00000010     F2837xD_GlobalVariableDefs.obj (SpicRegsFile)
UppRegsFile
*          1    00006200    00000048     UNINITIALIZED
                  00006200    00000048     F2837xD_GlobalVariableDefs.obj (UppRegsFile)
WdRegsFile
*          1    00007000    0000002b     UNINITIALIZED
                  00007000    0000002b     F2837xD_GlobalVariableDefs.obj (WdRegsFile)
NmiIntruptRegsFile
*          1    00007060    00000007     UNINITIALIZED
                  00007060    00000007     F2837xD_GlobalVariableDefs.obj (NmiIntruptRegsFile)
XintRegsFile
*          1    00007070    0000000b     UNINITIALIZED
                  00007070    0000000b     F2837xD_GlobalVariableDefs.obj (XintRegsFile)
SciaRegsFile
*          1    00007200    00000010     UNINITIALIZED
                  00007200    00000010     F2837xD_GlobalVariableDefs.obj (SciaRegsFile)
ScibRegsFile
*          1    00007210    00000010     UNINITIALIZED
                  00007210    00000010     F2837xD_GlobalVariableDefs.obj (ScibRegsFile)
ScicRegsFile
*          1    00007220    00000010     UNINITIALIZED
                  00007220    00000010     F2837xD_GlobalVariableDefs.obj (ScicRegsFile)
ScidRegsFile
*          1    00007230    00000010     UNINITIALIZED
                  00007230    00000010     F2837xD_GlobalVariableDefs.obj (ScidRegsFile)
I2caRegsFile
*          1    00007300    00000022     UNINITIALIZED
                  00007300    00000022     F2837xD_GlobalVariableDefs.obj (I2caRegsFile)
I2cbRegsFile
*          1    00007340    00000022     UNINITIALIZED
                  00007340    00000022     F2837xD_GlobalVariableDefs.obj (I2cbRegsFile)
InputXbarRegsFile
*          1    00007900    00000020     UNINITIALIZED
                  00007900    00000020     F2837xD_GlobalVariableDefs.obj (InputXbarRegsFile)
XbarRegsFile
*          1    00007920    00000020     UNINITIALIZED
                  00007920    00000020     F2837xD_GlobalVariableDefs.obj (XbarRegsFile)
SyncSocRegsFile
*          1    00007940    00000006     UNINITIALIZED
                  00007940    00000006     F2837xD_GlobalVariableDefs.obj (SyncSocRegsFile)
DmaClaSrcSelRegsFile
*          1    00007980    0000001a     UNINITIALIZED
                  00007980    0000001a     F2837xD_GlobalVariableDefs.obj (DmaClaSrcSelRegsFile)
EPwmXbarRegsFile
*          1    00007a00    00000040     UNINITIALIZED
                  00007a00    00000040     F2837xD_GlobalVariableDefs.obj (EPwmXbarRegsFile)
OutputXbarRegsFile
*          1    00007a80    00000040     UNINITIALIZED
                  00007a80    00000040     F2837xD_GlobalVariableDefs.obj (OutputXbarRegsFile)
GpioCtrlRegsFile
*          1    00007c00    00000180     UNINITIALIZED
                  00007c00    00000180     F2837xD_GlobalVariableDefs.obj (GpioCtrlRegsFile)
GpioDataRegsFile
*          1    00007f00    00000030     UNINITIALIZED
                  00007f00    00000030     F2837xD_GlobalVariableDefs.obj (GpioDataRegsFile)
Emif1RegsFile
*          1    00047000    00000070     UNINITIALIZED
                  00047000    00000070     F2837xD_GlobalVariableDefs.obj (Emif1RegsFile)
Emif2RegsFile
*          1    00047800    00000070     UNINITIALIZED
                  00047800    00000070     F2837xD_GlobalVariableDefs.obj (Emif2RegsFile)
IpcRegsFile
*          1    00050000    00000024     UNINITIALIZED
                  00050000    00000024     F2837xD_GlobalVariableDefs.obj (IpcRegsFile)
FlashPumpSemaphoreRegsFile
*          1    00050024    00000002     UNINITIALIZED
                  00050024    00000002     F2837xD_GlobalVariableDefs.obj (FlashPumpSemaphoreRegsFile)
RomPrefetchRegsFile
*          1    0005e608    00000002     UNINITIALIZED
                  0005e608    00000002     F2837xD_GlobalVariableDefs.obj (RomPrefetchRegsFile)
DcsmZ1RegsFile
*          1    0005f000    00000024     UNINITIALIZED
                  0005f000    00000024     F2837xD_GlobalVariableDefs.obj (DcsmZ1RegsFile)
DcsmZ2RegsFile
*          1    0005f040    00000024     UNINITIALIZED
                  0005f040    00000024     F2837xD_GlobalVariableDefs.obj (DcsmZ2RegsFile)
DcsmCommonRegsFile
*          1    0005f070    00000008     UNINITIALIZED
                  0005f070    00000008     F2837xD_GlobalVariableDefs.obj (DcsmCommonRegsFile)
MemCfgRegsFile
*          1    0005f400    00000080     UNINITIALIZED
                  0005f400    00000080     F2837xD_GlobalVariableDefs.obj (MemCfgRegsFile)
Emif1ConfigRegsFile
*          1    0005f480    00000020     UNINITIALIZED
                  0005f480    00000020     F2837xD_GlobalVariableDefs.obj (Emif1ConfigRegsFile)
Emif2ConfigRegsFile
*          1    0005f4a0    00000020     UNINITIALIZED
                  0005f4a0    00000020     F2837xD_GlobalVariableDefs.obj (Emif2ConfigRegsFile)
AccessProtectionRegsFile
*          1    0005f4c0    00000040     UNINITIALIZED
                  0005f4c0    00000040     F2837xD_GlobalVariableDefs.obj (AccessProtectionRegsFile)
MemoryErrorRegsFile
*          1    0005f500    00000040     UNINITIALIZED
                  0005f500    00000040     F2837xD_GlobalVariableDefs.obj (MemoryErrorRegsFile)
RomWaitStateRegsFile
*          1    0005f540    00000002     UNINITIALIZED
                  0005f540    00000002     F2837xD_GlobalVariableDefs.obj (RomWaitStateRegsFile)
Flash0CtrlRegsFile
*          1    0005f800    00000182     UNINITIALIZED
                  0005f800    00000182     F2837xD_GlobalVariableDefs.obj (Flash0CtrlRegsFile)
Flash0EccRegsFile
*          1    0005fb00    00000028     UNINITIALIZED
                  0005fb00    00000028     F2837xD_GlobalVariableDefs.obj (Flash0EccRegsFile)
DcsmZ1OtpFile
*          1    00078000    00000020     NOLOAD SECTION
                  00078000    00000020     F2837xD_GlobalVariableDefs.obj (DcsmZ1OtpFile)
DcsmZ2OtpFile
*          1    00078200    00000020     NOLOAD SECTION
                  00078200    00000020     F2837xD_GlobalVariableDefs.obj (DcsmZ2OtpFile)
DevCfgRegsFile
*          1    0005d000    0000012e     UNINITIALIZED
                  0005d000    0000012e     F2837xD_GlobalVariableDefs.obj (DevCfgRegsFile)
ClkCfgRegsFile
*          1    0005d200    00000032     UNINITIALIZED
                  0005d200    00000032     F2837xD_GlobalVariableDefs.obj (ClkCfgRegsFile)
CpuSysRegsFile
*          1    0005d300    00000082     UNINITIALIZED
                  0005d300    00000082     F2837xD_GlobalVariableDefs.obj (CpuSysRegsFile)
.text.1    0    00000296    0000016a
                  00000296    0000016a     Adc.obj (.text)
.text.2    0    00008000    000007f5
                  00008000    00000585     F2837xD_DefaultISR.obj (.text:retain)
                  00008585    00000244     F2837xD_Gpio.obj (.text)
                  000087c9    00000029     rts2800_fpu32.lib : exit.c.obj (.text)
                  000087f2    00000002                       : pre_init.c.obj (.text)
                  000087f4    00000001                       : startup.c.obj (.text)
.text.3    0    00008800    00000800
                  00008800    000003a6     Gpio.obj (.text)
                  00008ba6    0000038a     EPwm.obj (.text)
                  00008f30    000000aa     DQ0_ABC_F.obj (.text)
                  00008fda    00000026     F2837xD_PieVect.obj (.text)
.text.4    0    00009000    00000691
                  00009000    0000033b     F2837xD_SysCtrl.obj (.text)
                  0000933b    000000a2     ABC_DQ0_POS_F.obj (.text)
                  000093dd    00000088     rts2800_fpu32.lib : fs_div28.asm.obj (.text)
                  00009465    0000007f     main.obj (.text)
                  000094e4    0000007c     F2837xD_CpuTimers.obj (.text)
                  00009560    00000058     rts2800_fpu32.lib : s_sinf.c.obj (.text)
                  000095b8    00000056                       : boot28.asm.obj (.text)
                  0000960e    00000028     F2837xD_PieCtrl.obj (.text)
                  00009636    00000024     rts2800_fpu32.lib : cpy_tbl.c.obj (.text)
                  0000965a    0000001e                       : memcpy.c.obj (.text)
                  00009678    00000019                       : args_main.c.obj (.text)
.text.5    0    0000b000    00000800
                  0000b000    000005ea     main.obj (.text:retain)
                  0000b5ea    000000dd     F2837xD_Adc.obj (.text)
                  0000b6c7    000000cf     SPLL_3PH_SRF_F.obj (.text)
                  0000b796    00000061     rts2800_fpu32.lib : s_cosf.c.obj (.text)
                  0000b7f7    00000009                       : _lock.c.obj (.text)
MODULE SUMMARY
       Module                           code   initialized data   uninitialized data
       F2837xD_GlobalVariableDefs.obj   0      0                  8759
       main.obj                         1641   306                1384
       F2837xD_DefaultISR.obj           1413   0                  0
       EPwm.obj                         906    36                 9
       Gpio.obj                         934    0                  0
       F2837xD_SysCtrl.obj              827    0                  0
       F2837xD_Gpio.obj                 580    0                  0
       F2837xD_PieVect.obj              38     448                0
       Adc.obj                          362    0                  0
       F2837xD_Adc.obj                  221    0                  0
       SPLL_3PH_SRF_F.obj               207    0                  0
       DQ0_ABC_F.obj                    170    0                  0
       ABC_DQ0_POS_F.obj                162    0                  0
       F2837xD_CpuTimers.obj            124    0                  24
       F2837xD_PieCtrl.obj              40     0                  0
       F2837xD_usDelay.obj              4      0                  0
       F2837xD_CodeStartBranch.obj      2      0                  0
       Total:                           7631   790                10176
    C:\ti\ccsv8\tools\compiler\ti-cgt-c2000_18.1.2.LTS\lib\rts2800_fpu32.lib
       fs_div28.asm.obj                 136    0                  0
       s_cosf.c.obj                     97     0                  0
       s_sinf.c.obj                     88     0                  0
       boot28.asm.obj                   86     0                  0
       exit.c.obj                       41     14                 6
       cpy_tbl.c.obj                    36     0                  0
       memcpy.c.obj                     30     0                  0
       args_main.c.obj                  25     0                  0
       _lock.c.obj                      9      10                 4
       pre_init.c.obj                   2      0                  0
       startup.c.obj                    1      0                  0
       Total:                           551    24                 10
       Stack:                           0      0                  512
       Grand Total:                     8182   814                10698
GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
address     data page           name
00000400      10 (00000400)     __stack
00000b00      2c (00000b00)     _AdcaResultRegs
00000b20      2c (00000b00)     _AdcbResultRegs
00000b40      2d (00000b40)     _AdccResultRegs
00000b60      2d (00000b40)     _AdcdResultRegs
00000c00      30 (00000c00)     _CpuTimer0Regs
00000c08      30 (00000c00)     _CpuTimer1Regs
00000c10      30 (00000c00)     _CpuTimer2Regs
00000ce0      33 (00000cc0)     _Cla1SoftIntRegs
00000ce0      33 (00000cc0)     _PieCtrlRegs
00000d00      34 (00000d00)     _EmuKey
00000d00      34 (00000d00)     _PieVectTable
00000d01      34 (00000d00)     _EmuBMode
00001000      40 (00001000)     _DmaRegs
00001400      50 (00001400)     _Cla1Regs
00004000     100 (00004000)     _EPwm1Regs
00004100     104 (00004100)     _EPwm2Regs
00004200     108 (00004200)     _EPwm3Regs
00004300     10c (00004300)     _EPwm4Regs
00004400     110 (00004400)     _EPwm5Regs
00004500     114 (00004500)     _EPwm6Regs
00004600     118 (00004600)     _EPwm7Regs
00004700     11c (00004700)     _EPwm8Regs
00004800     120 (00004800)     _EPwm9Regs
00004900     124 (00004900)     _EPwm10Regs
00004a00     128 (00004a00)     _EPwm11Regs
00004b00     12c (00004b00)     _EPwm12Regs
00005000     140 (00005000)     _ECap1Regs
00005020     140 (00005000)     _ECap2Regs
00005040     141 (00005040)     _ECap3Regs
00005060     141 (00005040)     _ECap4Regs
00005080     142 (00005080)     _ECap5Regs
000050a0     142 (00005080)     _ECap6Regs
00005100     144 (00005100)     _EQep1Regs
00005140     145 (00005140)     _EQep2Regs
00005180     146 (00005180)     _EQep3Regs
00005c00     170 (00005c00)     _DacaRegs
00005c10     170 (00005c00)     _DacbRegs
00005c20     170 (00005c00)     _DaccRegs
00005c80     172 (00005c80)     _Cmpss1Regs
00005ca0     172 (00005c80)     _Cmpss2Regs
00005cc0     173 (00005cc0)     _Cmpss3Regs
00005ce0     173 (00005cc0)     _Cmpss4Regs
00005d00     174 (00005d00)     _Cmpss5Regs
00005d20     174 (00005d00)     _Cmpss6Regs
00005d40     175 (00005d40)     _Cmpss7Regs
00005d60     175 (00005d40)     _Cmpss8Regs
00005e00     178 (00005e00)     _Sdfm1Regs
00005e80     17a (00005e80)     _Sdfm2Regs
00006000     180 (00006000)     _McbspaRegs
00006040     181 (00006040)     _McbspbRegs
00006100     184 (00006100)     _SpiaRegs
00006110     184 (00006100)     _SpibRegs
00006120     184 (00006100)     _SpicRegs
00006200     188 (00006200)     _UppRegs
00007000     1c0 (00007000)     _WdRegs
00007060     1c1 (00007040)     _NmiIntruptRegs
00007070     1c1 (00007040)     _XintRegs
00007200     1c8 (00007200)     _SciaRegs
00007210     1c8 (00007200)     _ScibRegs
00007220     1c8 (00007200)     _ScicRegs
00007230     1c8 (00007200)     _ScidRegs
00007300     1cc (00007300)     _I2caRegs
00007340     1cd (00007340)     _I2cbRegs
00007400     1d0 (00007400)     _AdcaRegs
00007480     1d2 (00007480)     _AdcbRegs
00007500     1d4 (00007500)     _AdccRegs
00007580     1d6 (00007580)     _AdcdRegs
00007900     1e4 (00007900)     _InputXbarRegs
00007920     1e4 (00007900)     _XbarRegs
00007940     1e5 (00007940)     _SyncSocRegs
00007980     1e6 (00007980)     _DmaClaSrcSelRegs
00007a00     1e8 (00007a00)     _EPwmXbarRegs
00007a80     1ea (00007a80)     _OutputXbarRegs
00007c00     1f0 (00007c00)     _GpioCtrlRegs
00007f00     1fc (00007f00)     _GpioDataRegs
0000a800     2a0 (0000a800)     _dacval
0000a801     2a0 (0000a800)     _i
0000a802     2a0 (0000a800)     _fault
0000a803     2a0 (0000a800)     _transient
0000a804     2a0 (0000a800)     _Fi
0000a805     2a0 (0000a800)     _bufferFull
0000a806     2a0 (0000a800)     _start
0000a808     2a0 (0000a800)     _N1
0000a80a     2a0 (0000a800)     _N2
0000a80c     2a0 (0000a800)     _n1
0000a80e     2a0 (0000a800)     _d2
0000a810     2a0 (0000a800)     _N0
0000a812     2a0 (0000a800)     _d0
0000a814     2a0 (0000a800)     _d1
0000a816     2a0 (0000a800)     _Vdc_mvng_avr
0000a818     2a0 (0000a800)     _vdc_A_1
0000a81a     2a0 (0000a800)     _D_ref
0000a81c     2a0 (0000a800)     _V_d_ref
0000a81e     2a0 (0000a800)     _n0
0000a820     2a0 (0000a800)     _n2
0000a822     2a0 (0000a800)     _vdc_A_0
0000a824     2a0 (0000a800)     _V_dc_ref
0000a826     2a0 (0000a800)     _V_q_ref
0000a828     2a0 (0000a800)     _I_d
0000a82a     2a0 (0000a800)     _I_q
0000a82c     2a0 (0000a800)     _I_d_ref
0000a82e     2a0 (0000a800)     _I_q_ref
0000a830     2a0 (0000a800)     _dq_A_0
0000a832     2a0 (0000a800)     _dq_A_1
0000a834     2a0 (0000a800)     _d_decouple
0000a836     2a0 (0000a800)     _q_decouple
0000a838     2a0 (0000a800)     _D2
0000a83a     2a0 (0000a800)     _T_s
0000a83c     2a0 (0000a800)     _D0
0000a83e     2a0 (0000a800)     _D1
0000a840     2a1 (0000a840)     _Theta
0000a842     2a1 (0000a840)     _Fo
0000a844     2a1 (0000a840)     _V_d
0000a846     2a1 (0000a840)     _Ib_adc
0000a848     2a1 (0000a840)     _Ic_adc
0000a84a     2a1 (0000a840)     _Vdc_adc
0000a84c     2a1 (0000a840)     _Ia_adc
0000a84e     2a1 (0000a840)     _Vc_adc
0000a850     2a1 (0000a840)     _V_dcoff
0000a852     2a1 (0000a840)     _I_aoff
0000a854     2a1 (0000a840)     _V_boff
0000a856     2a1 (0000a840)     _V_coff
0000a858     2a1 (0000a840)     _Mb_ref1
0000a85a     2a1 (0000a840)     _Ma_ref1
0000a85c     2a1 (0000a840)     _Mc_ref1
0000a85e     2a1 (0000a840)     _Vb_adc
0000a860     2a1 (0000a840)     _V_aoff
0000a862     2a1 (0000a840)     _TIMINTCNT1
0000a864     2a1 (0000a840)     _Va_adc
0000a866     2a1 (0000a840)     _Mc_ref
0000a868     2a1 (0000a840)     _Mb_ref
0000a86a     2a1 (0000a840)     _i_gain_b
0000a86c     2a1 (0000a840)     _Q_ref
0000a86e     2a1 (0000a840)     _V_q
0000a870     2a1 (0000a840)     _i_gain_c
0000a872     2a1 (0000a840)     _Ma_ref
0000a874     2a1 (0000a840)     _i_gain_a
0000a876     2a1 (0000a840)     _v_gain_a
0000a878     2a1 (0000a840)     _v_gain_b
0000a87a     2a1 (0000a840)     _I_boff
0000a87c     2a1 (0000a840)     _I_coff
0000a87e     2a1 (0000a840)     _ADCINTCNT1
0000a880     2a2 (0000a880)     _v_gain_dc
0000a882     2a2 (0000a880)     _v_gain_c
0000a884     2a2 (0000a880)     _I_q_err
0000a888     2a2 (0000a880)     _PI_out_dframe
0000a88c     2a2 (0000a880)     _PI_out_qframe
0000a890     2a2 (0000a880)     _PI_out_vdc
0000a894     2a2 (0000a880)     _I_d_err
0000a898     2a2 (0000a880)     _V_dc_err
0000a89c     2a2 (0000a880)     _Va_f
0000a8a2     2a2 (0000a880)     _Vdc
0000a8a8     2a2 (0000a880)     _Vc_f
0000a8ae     2a2 (0000a880)     _Vb
0000a8b4     2a2 (0000a880)     _Va
0000a8ba     2a2 (0000a880)     _Vb_f
0000a8c0     2a3 (0000a8c0)     _Vc
0000a8c6     2a3 (0000a8c0)     _Ia_f
0000a8cc     2a3 (0000a8c0)     _Ic
0000a8d2     2a3 (0000a8c0)     _Ic_f
0000a8d8     2a3 (0000a8c0)     _Ia
0000a8de     2a3 (0000a8c0)     _Vdc_f
0000a8e4     2a3 (0000a8c0)     _Ib_f
0000a8ea     2a3 (0000a8c0)     _Ib
0000a8f0     2a3 (0000a8c0)     _DAC_PTR
0000a900     2a4 (0000a900)     _dq0_abc1
0000a914     2a4 (0000a900)     _abc_dq0_pos2
0000a928     2a4 (0000a900)     _abc_dq0_pos1
0000a940     2a5 (0000a940)     _spll1
0000a980     2a6 (0000a980)     _temp
0000ad68     2b5 (0000ad40)     _CpuTimer1
0000ad70     2b5 (0000ad40)     _CpuTimer2
0000ad78     2b5 (0000ad40)     _CpuTimer0
0000ad80     2b6 (0000ad80)     _CcarrierPhase
0000ad81     2b6 (0000ad80)     _Ma
0000ad82     2b6 (0000ad80)     _Switch_Freq_counter
0000ad83     2b6 (0000ad80)     _BcarrierPhase
0000ad84     2b6 (0000ad80)     _Mr
0000ad85     2b6 (0000ad80)     _PhaseShift
0000ad86     2b6 (0000ad80)     _Mb
0000ad87     2b6 (0000ad80)     _Mc
0000ad88     2b6 (0000ad80)     _DeadBand
0000ad8a     2b6 (0000ad80)     ___TI_enable_exit_profile_output
0000ad8c     2b6 (0000ad80)     ___TI_cleanup_ptr
0000ad8e     2b6 (0000ad80)     ___TI_dtors_ptr
0000ad90     2b6 (0000ad80)     __lock
0000ad92     2b6 (0000ad80)     __unlock
0000ad94     2b6 (0000ad80)     _PieVectTableInit
00047000    11c0 (00047000)     _Emif1Regs
00047800    11e0 (00047800)     _Emif2Regs
00048000    1200 (00048000)     _CanaRegs
0004a000    1280 (0004a000)     _CanbRegs
00050000    1400 (00050000)     _IpcRegs
00050024    1400 (00050000)     _FlashPumpSemaphoreRegs
0005d000    1740 (0005d000)     _DevCfgRegs
0005d180    1746 (0005d180)     _AnalogSubsysRegs
0005d200    1748 (0005d200)     _ClkCfgRegs
0005d300    174c (0005d300)     _CpuSysRegs
0005e608    1798 (0005e600)     _RomPrefetchRegs
0005f000    17c0 (0005f000)     _DcsmZ1Regs
0005f040    17c1 (0005f040)     _DcsmZ2Regs
0005f070    17c1 (0005f040)     _DcsmCommonRegs
0005f400    17d0 (0005f400)     _MemCfgRegs
0005f480    17d2 (0005f480)     _Emif1ConfigRegs
0005f4a0    17d2 (0005f480)     _Emif2ConfigRegs
0005f4c0    17d3 (0005f4c0)     _AccessProtectionRegs
0005f500    17d4 (0005f500)     _MemoryErrorRegs
0005f540    17d5 (0005f540)     _RomWaitStateRegs
0005f800    17e0 (0005f800)     _Flash0CtrlRegs
0005fb00    17ec (0005fb00)     _Flash0EccRegs
00078000    1e00 (00078000)     _DcsmZ1Otp
00078200    1e08 (00078200)     _DcsmZ2Otp
GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
page  address   name
abs   ffffffff  .text
0     000087c9  C$$EXIT
0     000093dd  FS$$DIV
0     0000935f  _ABC_DQ0_POS_F_FUNC
0     0000933b  _ABC_DQ0_POS_F_init
0     000080be  _ADCA1_ISR
0     0000833e  _ADCA2_ISR
0     00008348  _ADCA3_ISR
0     00008352  _ADCA4_ISR
0     00008334  _ADCA_EVT_ISR
0     000080c8  _ADCB1_ISR
0     00008366  _ADCB2_ISR
0     00008370  _ADCB3_ISR
0     0000837a  _ADCB4_ISR
0     0000835c  _ADCB_EVT_ISR
0     000080d2  _ADCC1_ISR
0     000084ce  _ADCC2_ISR
0     000084d8  _ADCC3_ISR
0     000084e2  _ADCC4_ISR
0     000084c4  _ADCC_EVT_ISR
0     000080f0  _ADCD1_ISR
0     000084f6  _ADCD2_ISR
0     00008500  _ADCD3_ISR
0     0000850a  _ADCD4_ISR
0     000084ec  _ADCD_EVT_ISR
1     0000a87e  _ADCINTCNT1
0     00008546  _AUX_PLL_SLIP_ISR
1     0005f4c0  _AccessProtectionRegs
0     0000b5ea  _AdcSetMode
1     00007400  _AdcaRegs
1     00000b00  _AdcaResultRegs
1     00007480  _AdcbRegs
1     00000b20  _AdcbResultRegs
1     00007500  _AdccRegs
1     00000b40  _AdccResultRegs
1     00007580  _AdcdRegs
1     00000b60  _AdcdResultRegs
1     0005d180  _AnalogSubsysRegs
0     000092e7  _AuxAuxClkSel
0     000092d1  _AuxIntOsc2Sel
0     000092db  _AuxXtalOscSel
1     0000ad83  _BcarrierPhase
0     0000830c  _CANA0_ISR
0     00008316  _CANA1_ISR
0     00008320  _CANB0_ISR
0     0000832a  _CANB1_ISR
0     00008384  _CLA1_1_ISR
0     0000838e  _CLA1_2_ISR
0     00008398  _CLA1_3_ISR
0     000083a2  _CLA1_4_ISR
0     000083ac  _CLA1_5_ISR
0     000083b6  _CLA1_6_ISR
0     000083c0  _CLA1_7_ISR
0     000083ca  _CLA1_8_ISR
0     00008550  _CLA_OVERFLOW_ISR
0     0000855a  _CLA_UNDERFLOW_ISR
0     0000b68d  _CalAdcINL
1     00048000  _CanaRegs
1     0004a000  _CanbRegs
1     0000ad80  _CcarrierPhase
1     00001400  _Cla1Regs
0     00000ce0  _Cla1SoftIntRegs
1     0005d200  _ClkCfgRegs
1     00005c80  _Cmpss1Regs
1     00005ca0  _Cmpss2Regs
1     00005cc0  _Cmpss3Regs
1     00005ce0  _Cmpss4Regs
1     00005d00  _Cmpss5Regs
1     00005d20  _Cmpss6Regs
1     00005d40  _Cmpss7Regs
1     00005d60  _Cmpss8Regs
0     00009525  _ConfigCpuTimer
1     0005d300  _CpuSysRegs
1     0000ad78  _CpuTimer0
1     00000c00  _CpuTimer0Regs
1     0000ad68  _CpuTimer1
1     00000c08  _CpuTimer1Regs
1     0000ad70  _CpuTimer2
1     00000c10  _CpuTimer2Regs
0     00009290  _CsmUnlock
1     0000a83c  _D0
1     0000a83e  _D1
1     0000a838  _D2
1     0000a8f0  _DAC_PTR
0     00008014  _DATALOG_ISR
0     00008258  _DMA_CH1_ISR
0     00008262  _DMA_CH2_ISR
0     0000826c  _DMA_CH3_ISR
0     00008276  _DMA_CH4_ISR
0     00008280  _DMA_CH5_ISR
0     0000828a  _DMA_CH6_ISR
0     00008f54  _DQ0_ABC_F_FUNC
0     00008f30  _DQ0_ABC_F_init
1     0000a81a  _D_ref
1     00005c00  _DacaRegs
1     00005c10  _DacbRegs
1     00005c20  _DaccRegs
1     0005f070  _DcsmCommonRegs
1     00078000  _DcsmZ1Otp
1     0005f000  _DcsmZ1Regs
1     00078200  _DcsmZ2Otp
1     0005f040  _DcsmZ2Regs
1     0000ad88  _DeadBand
1     0005d000  _DevCfgRegs
0     000090f4  _DisableDog
0     000090b5  _DisablePeripheralClocks
1     00007980  _DmaClaSrcSelRegs
1     00001000  _DmaRegs
0     000081ae  _ECAP1_ISR
0     000081b8  _ECAP2_ISR
0     000081c2  _ECAP3_ISR
0     000081cc  _ECAP4_ISR
0     000081d6  _ECAP5_ISR
0     000081e0  _ECAP6_ISR
1     00005000  _ECap1Regs
1     00005020  _ECap2Regs
1     00005040  _ECap3Regs
1     00005060  _ECap4Regs
1     00005080  _ECap5Regs
1     000050a0  _ECap6Regs
0     00008514  _EMIF_ERROR_ISR
0     0000856e  _EMPTY_ISR
0     00008028  _EMU_ISR
0     0000846a  _EPWM10_ISR
0     00008442  _EPWM10_TZ_ISR
0     00008474  _EPWM11_ISR
0     0000844c  _EPWM11_TZ_ISR
0     0000847e  _EPWM12_ISR
0     00008456  _EPWM12_TZ_ISR
0     0000815e  _EPWM1_ISR
0     0000810e  _EPWM1_TZ_ISR
0     00008168  _EPWM2_ISR
0     00008118  _EPWM2_TZ_ISR
0     00008172  _EPWM3_ISR
0     00008122  _EPWM3_TZ_ISR
0     0000817c  _EPWM4_ISR
0     0000812c  _EPWM4_TZ_ISR
0     00008186  _EPWM5_ISR
0     00008136  _EPWM5_TZ_ISR
0     00008190  _EPWM6_ISR
0     00008140  _EPWM6_TZ_ISR
0     0000819a  _EPWM7_ISR
0     0000814a  _EPWM7_TZ_ISR
0     000081a4  _EPWM8_ISR
0     00008154  _EPWM8_TZ_ISR
0     00008460  _EPWM9_ISR
0     00008438  _EPWM9_TZ_ISR
1     00004900  _EPwm10Regs
1     00004a00  _EPwm11Regs
1     00004b00  _EPwm12Regs
1     00004000  _EPwm1Regs
1     00004100  _EPwm2Regs
1     00004200  _EPwm3Regs
1     00004300  _EPwm4Regs
1     00004400  _EPwm5Regs
1     00004500  _EPwm6Regs
1     00004600  _EPwm7Regs
1     00004700  _EPwm8Regs
1     00004800  _EPwm9Regs
1     00007a00  _EPwmXbarRegs
0     000081ea  _EQEP1_ISR
0     000081f4  _EQEP2_ISR
0     000081fe  _EQEP3_ISR
1     00005100  _EQep1Regs
1     00005140  _EQep2Regs
1     00005180  _EQep3Regs
1     0005f480  _Emif1ConfigRegs
1     00047000  _Emif1Regs
1     0005f4a0  _Emif2ConfigRegs
1     00047800  _Emif2Regs
1     00000d01  _EmuBMode
1     00000d00  _EmuKey
0     0000962d  _EnableInterrupts
0     00000292  _F28x_usDelay
0     00008528  _FLASH_CORRECTABLE_ERROR_ISR
0     000083fc  _FPU_OVERFLOW_ISR
0     00008406  _FPU_UNDERFLOW_ISR
1     0000a804  _Fi
1     0005f800  _Flash0CtrlRegs
1     0005fb00  _Flash0EccRegs
1     00050024  _FlashPumpSemaphoreRegs
1     0000a842  _Fo
0     0000877e  _GPIO_EnableUnbondedIOPullups
0     00008759  _GPIO_EnableUnbondedIOPullupsFor100Pin
0     00008740  _GPIO_EnableUnbondedIOPullupsFor176Pin
0     00008794  _GPIO_ReadPin
0     000086e5  _GPIO_SetupLock
0     000085c5  _GPIO_SetupPinMux
0     00008651  _GPIO_SetupPinOptions
0     0000870e  _GPIO_SetupXINT1Gpio
0     00008718  _GPIO_SetupXINT2Gpio
0     00008722  _GPIO_SetupXINT3Gpio
0     0000872c  _GPIO_SetupXINT4Gpio
0     00008736  _GPIO_SetupXINT5Gpio
0     000087ab  _GPIO_WritePin
1     00007c00  _GpioCtrlRegs
1     00007f00  _GpioDataRegs
0     00009305  _HALT
0     0000931e  _HIB
0     0000829e  _I2CA_FIFO_ISR
0     00008294  _I2CA_ISR
0     000082b2  _I2CB_FIFO_ISR
0     000082a8  _I2CB_ISR
1     00007300  _I2caRegs
1     00007340  _I2cbRegs
0     000092f1  _IDLE
0     0000803c  _ILLEGAL_ISR
0     00008410  _IPC0_ISR
0     0000841a  _IPC1_ISR
0     00008424  _IPC2_ISR
0     0000842e  _IPC3_ISR
1     0000a852  _I_aoff
1     0000a87a  _I_boff
1     0000a87c  _I_coff
1     0000a828  _I_d
1     0000a894  _I_d_err
1     0000a82c  _I_d_ref
1     0000a82a  _I_q
1     0000a884  _I_q_err
1     0000a82e  _I_q_ref
1     0000a8d8  _Ia
1     0000a84c  _Ia_adc
1     0000a8c6  _Ia_f
1     0000a8ea  _Ib
1     0000a846  _Ib_adc
1     0000a8e4  _Ib_f
1     0000a8cc  _Ic
1     0000a848  _Ic_adc
1     0000a8d2  _Ic_f
0     00000296  _InitAdc_complete
0     000091c8  _InitAuxPll
0     000094e4  _InitCpuTimers
0     00008ba6  _InitEPwm_complete
0     00008585  _InitGpio
0     00008800  _InitGpio_complete
0     00009031  _InitPeripheralClocks
0     0000960e  _InitPieCtrl
0     00008fda  _InitPieVectTable
0     00009000  _InitSysCtrl
0     00009102  _InitSysPll
1     00007900  _InputXbarRegs
1     00050000  _IpcRegs
0     00008230  _MCBSPA_RX_ISR
0     0000823a  _MCBSPA_TX_ISR
0     00008244  _MCBSPB_RX_ISR
0     0000824e  _MCBSPB_TX_ISR
1     0000ad81  _Ma
1     0000a872  _Ma_ref
1     0000a85a  _Ma_ref1
1     0000ad86  _Mb
1     0000a868  _Mb_ref
1     0000a858  _Mb_ref1
1     0000ad87  _Mc
1     0000a866  _Mc_ref
1     0000a85c  _Mc_ref1
1     00006000  _McbspaRegs
1     00006040  _McbspbRegs
1     0005f400  _MemCfgRegs
1     0005f500  _MemoryErrorRegs
1     0000ad84  _Mr
1     0000a810  _N0
1     0000a808  _N1
1     0000a80a  _N2
0     00008032  _NMI_ISR
0     0000857b  _NOTUSED_ISR
1     00007060  _NmiIntruptRegs
1     00007a80  _OutputXbarRegs
0     00008564  _PIE_RESERVED_ISR
1     0000a888  _PI_out_dframe
1     0000a88c  _PI_out_qframe
1     0000a890  _PI_out_vdc
1     0000ad85  _PhaseShift
1     00000ce0  _PieCtrlRegs
1     00000d00  _PieVectTable
1     0000ad94  _PieVectTableInit
1     0000a86c  _Q_ref
0     00008532  _RAM_ACCESS_VIOLATION_ISR
0     0000851e  _RAM_CORRECTABLE_ERROR_ISR
0     0000801e  _RTOS_ISR
0     000090dc  _ReleaseFlashPump
1     0005e608  _RomPrefetchRegs
1     0005f540  _RomWaitStateRegs
0     000082e4  _SCIA_RX_ISR
0     000082ee  _SCIA_TX_ISR
0     000082f8  _SCIB_RX_ISR
0     00008302  _SCIB_TX_ISR
0     000082bc  _SCIC_RX_ISR
0     000082c6  _SCIC_TX_ISR
0     000082d0  _SCID_RX_ISR
0     000082da  _SCID_TX_ISR
0     00008488  _SD1_ISR
0     00008492  _SD2_ISR
0     00008208  _SPIA_RX_ISR
0     00008212  _SPIA_TX_ISR
0     0000821c  _SPIB_RX_ISR
0     00008226  _SPIB_TX_ISR
0     0000849c  _SPIC_RX_ISR
0     000084a6  _SPIC_TX_ISR
0     0000b70f  _SPLL_3ph_SRF_F_FUNC
0     0000b6c7  _SPLL_3ph_SRF_F_init
0     000092fa  _STANDBY
0     0000853c  _SYS_PLL_SLIP_ISR
1     00007200  _SciaRegs
1     00007210  _ScibRegs
1     00007220  _ScicRegs
1     00007230  _ScidRegs
1     00005e00  _Sdfm1Regs
1     00005e80  _Sdfm2Regs
0     000090cd  _SeizeFlashPump
0     000090e6  _ServiceDog
1     00006100  _SpiaRegs
1     00006110  _SpibRegs
1     00006120  _SpicRegs
1     0000ad82  _Switch_Freq_counter
1     00007940  _SyncSocRegs
0     000092b1  _SysIntOsc1Sel
0     000092bb  _SysIntOsc2Sel
0     000092c5  _SysXtalOscSel
0     000080fa  _TIMER0_ISR
0     00008000  _TIMER1_ISR
0     0000800a  _TIMER2_ISR
1     0000a862  _TIMINTCNT1
1     0000a83a  _T_s
1     0000a840  _Theta
0     000084b0  _UPPA_ISR
0     000084ba  _USBA_ISR
0     000080a0  _USER10_ISR
0     000080aa  _USER11_ISR
0     000080b4  _USER12_ISR
0     00008046  _USER1_ISR
0     00008050  _USER2_ISR
0     0000805a  _USER3_ISR
0     00008064  _USER4_ISR
0     0000806e  _USER5_ISR
0     00008078  _USER6_ISR
0     00008082  _USER7_ISR
0     0000808c  _USER8_ISR
0     00008096  _USER9_ISR
1     00006200  _UppRegs
0     000083f2  _VCU_ISR
1     0000a860  _V_aoff
1     0000a854  _V_boff
1     0000a856  _V_coff
1     0000a844  _V_d
1     0000a81c  _V_d_ref
1     0000a898  _V_dc_err
1     0000a824  _V_dc_ref
1     0000a850  _V_dcoff
1     0000a86e  _V_q
1     0000a826  _V_q_ref
1     0000a8b4  _Va
1     0000a864  _Va_adc
1     0000a89c  _Va_f
1     0000a8ae  _Vb
1     0000a85e  _Vb_adc
1     0000a8ba  _Vb_f
1     0000a8c0  _Vc
1     0000a84e  _Vc_adc
1     0000a8a8  _Vc_f
1     0000a8a2  _Vdc
1     0000a84a  _Vdc_adc
1     0000a8de  _Vdc_f
1     0000a816  _Vdc_mvng_avr
0     00008104  _WAKE_ISR
1     00007000  _WdRegs
0     000080dc  _XINT1_ISR
0     000080e6  _XINT2_ISR
0     000083d4  _XINT3_ISR
0     000083de  _XINT4_ISR
0     000083e8  _XINT5_ISR
1     00007920  _XbarRegs
1     00007070  _XintRegs
1     00000600  __STACK_END
abs   00000200  __STACK_SIZE
1     0000ad8c  ___TI_cleanup_ptr
1     0000ad8e  ___TI_dtors_ptr
1     0000ad8a  ___TI_enable_exit_profile_output
abs   ffffffff  ___TI_pprof_out_hndl
abs   ffffffff  ___TI_prof_data_size
abs   ffffffff  ___TI_prof_data_start
abs   ffffffff  ___binit__
abs   ffffffff  ___c_args__
0     00000122  ___cinit__
abs   ffffffff  ___etext__
abs   ffffffff  ___pinit__
abs   ffffffff  ___text__
0     00009678  __args_main
1     0000ad90  __lock
0     0000b7ff  __nop
0     0000b7fb  __register_lock
0     0000b7f7  __register_unlock
1     00000400  __stack
0     000087f4  __system_post_cinit
0     000087f2  __system_pre_init
1     0000ad92  __unlock
1     0000a928  _abc_dq0_pos1
1     0000a914  _abc_dq0_pos2
0     000087c9  _abort
0     0000b31d  _adca1_isr
1     0000a805  _bufferFull
0     000095b8  _c_int00
0     000094bc  _configureDAC
0     00009636  _copy_in
0     0000b796  _cos
0     0000b796  _cosf
0     0000b000  _cpu_timer1_isr
1     0000a812  _d0
1     0000a814  _d1
1     0000a80e  _d2
1     0000a834  _d_decouple
1     0000a800  _dacval
1     0000a900  _dq0_abc1
1     0000a830  _dq_A_0
1     0000a832  _dq_A_1
0     000087cb  _exit
1     0000a802  _fault
1     0000a801  _i
1     0000a874  _i_gain_a
1     0000a86a  _i_gain_b
1     0000a870  _i_gain_c
0     00009465  _main
0     0000965a  _memcpy
1     0000a81e  _n0
1     0000a80c  _n1
1     0000a820  _n2
1     0000a836  _q_decouple
0     00009560  _sin
0     00009560  _sinf
1     0000a940  _spll1
1     0000a806  _start
1     0000a980  _temp
1     0000a803  _transient
1     0000a876  _v_gain_a
1     0000a878  _v_gain_b
1     0000a882  _v_gain_c
1     0000a880  _v_gain_dc
1     0000a822  _vdc_A_0
1     0000a818  _vdc_A_1
abs   ffffffff  binit
0     00000122  cinit
0     00000000  code_start
abs   ffffffff  etext
abs   ffffffff  pinit
GLOBAL SYMBOLS: SORTED BY Symbol Address
page  address   name
0     00000122  cinit
0     00008028  _EMU_ISR
0     00008032  _NMI_ISR
0     000083f2  _VCU_ISR
0     00008488  _SD1_ISR
0     00008492  _SD2_ISR
0     000087c9  C$$EXIT
0     000087c9  _abort
0     000087cb  _exit
0     000092f1  _IDLE
0     000092fa  _STANDBY
0     00009305  _HALT
0     0000931e  _HIB
0     000093dd  FS$$DIV
0     00009465  _main
0     00009560  _sin
0     00009560  _sinf
0     000095b8  _c_int00
0     00009636  _copy_in
0     0000965a  _memcpy
0     0000b796  _cos
0     0000b796  _cosf
0     0000b7ff  __nop
1     00000400  __stack
1     00000d00  _EmuKey
1     00001000  _DmaRegs
1     00006200  _UppRegs
1     00007000  _WdRegs
1     0000a800  _dacval
1     0000a801  _i
1     0000a802  _fault
1     0000a804  _Fi
1     0000a806  _start
1     0000a808  _N1
1     0000a80a  _N2
1     0000a80c  _n1
1     0000a80e  _d2
1     0000a810  _N0
1     0000a812  _d0
1     0000a814  _d1
1     0000a818  _vdc_A_1
1     0000a81a  _D_ref
1     0000a81c  _V_d_ref
1     0000a81e  _n0
1     0000a820  _n2
1     0000a822  _vdc_A_0
1     0000a826  _V_q_ref
1     0000a828  _I_d
1     0000a82a  _I_q
1     0000a82c  _I_d_ref
1     0000a82e  _I_q_ref
1     0000a830  _dq_A_0
1     0000a832  _dq_A_1
1     0000a838  _D2
1     0000a83a  _T_s
1     0000a83c  _D0
1     0000a83e  _D1
1     0000a840  _Theta
1     0000a842  _Fo
1     0000a844  _V_d
1     0000a846  _Ib_adc
1     0000a848  _Ic_adc
1     0000a84a  _Vdc_adc
1     0000a84c  _Ia_adc
1     0000a84e  _Vc_adc
1     0000a850  _V_dcoff
1     0000a852  _I_aoff
1     0000a854  _V_boff
1     0000a856  _V_coff
1     0000a858  _Mb_ref1
1     0000a85a  _Ma_ref1
1     0000a85c  _Mc_ref1
1     0000a85e  _Vb_adc
1     0000a860  _V_aoff
1     0000a864  _Va_adc
1     0000a866  _Mc_ref
1     0000a868  _Mb_ref
1     0000a86c  _Q_ref
1     0000a86e  _V_q
1     0000a872  _Ma_ref
1     0000a87a  _I_boff
1     0000a87c  _I_coff
1     0000a884  _I_q_err
1     0000a894  _I_d_err
1     0000a89c  _Va_f
1     0000a8a2  _Vdc
1     0000a8a8  _Vc_f
1     0000a8ae  _Vb
1     0000a8b4  _Va
1     0000a8ba  _Vb_f
1     0000a8c0  _Vc
1     0000a8c6  _Ia_f
1     0000a8cc  _Ic
1     0000a8d2  _Ic_f
1     0000a8d8  _Ia
1     0000a8de  _Vdc_f
1     0000a8e4  _Ib_f
1     0000a8ea  _Ib
1     0000a8f0  _DAC_PTR
1     0000a940  _spll1
1     0000a980  _temp
1     0000ad81  _Ma
1     0000ad84  _Mr
1     0000ad86  _Mb
1     0000ad87  _Mc
1     0000ad90  __lock
1     0000ad92  __unlock
1     00050000  _IpcRegs
abs   ffffffff  .text
abs   ffffffff  binit
abs   ffffffff  etext
abs   ffffffff  pinit
[443 symbols]
  • Shyam,
    I believe this error occurs when a function can't fit into a defined section of memory.  Even if you have defined .text to span multiple RAM blocks the linker won't break a function across a boundary.  An example would be if you have .text allocated to RAMLS3 and RAMLS4; even though there is 0x1000 words with both combined, if a function would cross the RAMLS3 address space into the RAMLS4 space you'll get this error.
    The solution is to combine the RAMs into an artificial larger section(let's call it RAMLS34) with 2x the size of the previous instance.
    I think the error is because the linker doesn't understand that the sections are contiguous addresses and gives this error.
    Matthew
