LAUNCHXL-F28379D: Resource Explorer - Import Error
Part Number: LAUNCHXL-F28379D
I am facing an error when trying to import ipc_ex1_gpio_toggle project from examples. The error says 'Location cannot be resolved' but the path is exactly where the projectspec file is placed.
  • Rashmitha,
    Apologies for the delay in replying back to you on the above question.  Are you still seeing the issue you've described above?  I tried to reproduce it locally and was unable to get this error from the cloud tools.
    Best
    Matthew
    I too am unable to preproduce the error. What version of CCS are you using? Can you also let us know what version of REX you are using?
    Please double check that you have C2000Ware installed the in the referenced path in your sceenshot.
    Ozino
  • Hi Mathew/Ozino,
    The problem was with the folder name C2000Ware_3_04_00_00_Software, this folder was named as 'C2000Ware_3_04_00_00' and the REX path had '_Software' additional. I renamed the folder and its working now.
    I had not changed anything in the C2000Ware folder after installation, I am not sure how this mismatch occurred for me and not for you.
    Thank you for your help.
    Rashmitha
