Part Number: TMS320F280049C
Can you please check my jtag connection, if everything is proper?
Specifically: does TCK need pull up?
if i am not ussing gpioin/gpioout pins, should them be pulled up or connect to ground?
Thanks.
Thanks.
Hi Shengnan,
You don't need a pull up TCK. The connections to the MCU look ok.
Not sure about the connections for GPIOIN/GPIOOUT, I believe that would depend on the emulator probe you plan to use. Having pull-ups seems reasonable.
