Part Number: TMDSCNCD28335
Other Parts Discussed in Thread: TMS320F28379D, CONTROLSUITE
I am using TMDSCNCD28335 for high speed machine control application. The speed needs to be sensed through a resolver (Part no. RO2010, Datasheet link: www.admotec.com/.../RO-Data-Sheet-1607.pdf). Please clear my following doubts:
- How speed can be calculated from the analog output of a Resolver?
- Does TMDSCNCD28335 has the feature of implementing resolver to digital conversion? If not, then could you suggest other high clock frequency DSP suitable for RDC.
- Is there any dedicated ICs available to incorporate RDC for high speed (around 1Lakh RPM) calculation. If yes, then could u suggest the suitable part number for the attached resolver. Also, please guide me regarding interfacing the RDC ICs and the DSP?
- Do any model of DSP have independent capability of interfacing with resolvers without use of an RDC kit? TMS320F28379d is developed for motor control applications and has the capability to interface with a resolver. So can i use TMS320F28379d for the attached high speed resolver?
