Dear team,
I used 28379d launchpad(with USB-CAN) to test can_ex4_simple_transmit at first. It runs well. The USB-CAN software can receive the packet.
And then, i used the code (can_ex4_simple_transmit ) with 280049 launchpad. I changed the IO setting and added "_LAUNCHXL_F280049C".
#define DEVICE_GPIO_CFG_CANRXA GPIO_33_CANA_RX // "pinConfig" for CANA RX
#define DEVICE_GPIO_CFG_CANTXA GPIO_32_CANA_TX // "pinConfig" for CANA TX
It showed that 280049C can transmit, but the USB-CAN software can NOT receive the packet. What did i miss?
Please help to check it.
// FILE: can_ex4_simple_transmit.c
// TITLE: CAN simple External Transmit Example
//! \addtogroup driver_example_list
//! <h1> CAN-A External Transmit </h1>
//! This example initializes CAN module A for external communication.
//! CAN-A module is setup to transmit data for "n" number of times,
//! where "n" is the value of TXCOUNT. Another CAN node configured for the
//! same bit-rate is needed to provide the ACK. No interrupts are used.
//! \b Hardware \b Required \n
//! - A C2000 board with CAN transceiver and another CAN node configured
//! for the same bit-rate to provide the ACK.
//! \b Watch \b Variables \n
//! - TXCOUNT - Adjust to set the number of messages to be transmitted
//! - txMsgCount - A counter for the number of messages sent
//! - txMsgData - An array with the data being sent
// $TI Release: F2837xS Support Library v3.12.00.00 $
// $Release Date: Fri Feb 12 19:06:50 IST 2021 $
// $Copyright:
// Copyright (C) 2014-2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#define TXCOUNT 100000
#define MSG_DATA_LENGTH 8
#define TX_MSG_OBJ_ID 1
// Globals
volatile unsigned long i;
volatile uint32_t txMsgCount = 0;
uint16_t txMsgData[8];
// Main
void main(void)
// Initialize device clock and peripherals
Device_init();
// Initialize GPIO and configure GPIO pins for CANTX/CANRX
// on module A
Device_initGPIO();
GPIO_setPinConfig(DEVICE_GPIO_CFG_CANRXA);
GPIO_setPinConfig(DEVICE_GPIO_CFG_CANTXA);
// Initialize the CAN controllers
CAN_initModule(CANA_BASE);
// Set up the CAN bus bit rate to 500kHz for each module
// Refer to the Driver Library User Guide for information on how to set
// tighter timing control. Additionally, consult the device data sheet
// for more information about the CAN module clocking.
CAN_setBitRate(CANA_BASE, DEVICE_SYSCLK_FREQ, 500000, 16);
// Initialize the transmit message object used for sending CAN messages.
// Message Object Parameters:
// CAN Module: A
// Message Object ID Number: 1
// Message Identifier: 0x95555555
// Message Frame: Extended
// Message Type: Transmit
// Message ID Mask: 0x0
// Message Object Flags: None
// Message Data Length: 4 Bytes
CAN_setupMessageObject(CANA_BASE, TX_MSG_OBJ_ID, 0x95555555,
CAN_MSG_FRAME_EXT, CAN_MSG_OBJ_TYPE_TX, 0,
CAN_MSG_OBJ_NO_FLAGS, MSG_DATA_LENGTH);
// Initialize the transmit message object data buffer to be sent
txMsgData[0] = 0x01;
txMsgData[1] = 0x23;
txMsgData[2] = 0x45;
txMsgData[3] = 0x67;
txMsgData[4] = 0x89;
txMsgData[5] = 0xAB;
txMsgData[6] = 0xCD;
txMsgData[7] = 0xEF;
// Start CAN module A operations
CAN_startModule(CANA_BASE);
// Transmit messages from CAN-A
while(1)
// Comment for infinite transmissions
//for(i = 0; i < TXCOUNT; i++)
CAN_sendMessage(CANA_BASE, TX_MSG_OBJ_ID, MSG_DATA_LENGTH, txMsgData);
// Poll TxOk bit in CAN_ES register to check completion of transmission
while(((HWREGH(CANA_BASE + CAN_O_ES) & CAN_ES_TXOK)) != CAN_ES_TXOK)
txMsgCount++;
// Stop application
asm(" ESTOP0");
// End of File
