Part Number: TMS320F280049C
Other Parts Discussed in Thread: LAUNCHXL-F280049C, BOOSTXL-BUCKCONV, SFRA, POWERSUITE, C2000WARE
I connected the LAUNCHXL-F280049C to a custom buck converter instead of the BOOSTXL-BUCKCONV board
I followed the instructions in the tidm_dc_dc_users_guide manual to generate the SFRAData.csv file.
When I call the "Compensation Designer" from "main.syscfg" the graphic matches the graphic generated in the SFRA_GUI, but if I run the CompDesiger software directly from the powerSUITE/source/utils directory and load the same generated SFRAData.csv file, the frequency axis starts from 1HZ instead of 100HZ. Why does it happen?
How to generate new coefficients for a board other than BOOSTXL-BUCKCONV?
Do you have a matlab script available that allows you to read the SFRAData.csv file and generate the controller coefficients corresponding to the plant's frequency response?
