Part Number: TMS320F280049C
Other Parts Discussed in Thread: TMDXIDDK379D
i am getting following error when trying to open existing projects..
I only see one .*project file. A valid CCS project has three. However, I see a .projectspec file. This file can be imported to create a valid project. I looks like you copied the tmdxiddk379d folder from the Motor Control SDK to your desktop and then tried to import the sensored_foc projectspec into the same location. That may have cased some strange import issue. Please try importing the original projectspec (in the original location) and import it to a different location (like your workspace).
ki
Ki is out today.
If I look at a stock MotorControl SDK that .project file is not present. Ki is likely correct that it got created when previously attempting to import the project. That folder should just have the .projectspec file. Think of a .projectspec as a template that CCS reads and then uses that to generate an actual project.
You could try the following.
Delete the .project
Try importing again.
John
