Hi.
I saw the following error while importing 28388d_PIDF64 of the DCL examples.
How can I import the above example correctly?
Hi.
6th Sep is a holiday in US and hence please expect a delay in response.
What CCS version are you running on your machine? You may need to update your CCS to latest version following the advice in the error message and try again. Thanks.
Han
This issue is happening as the example project specifies the device as "F2838x". This does not exist. If I update it to have the correct device "TMS320F28388D" then it imports fine.
The file that needs to be updated is the .projectspec file. It is located in
<C2000Ware install dir>/libraries/control/DCL/c28/examples/F28388D_PIDF64/CCS
I will send this back over to the C2000 team to figure out why the device is not specified correctly.
John
