TMS320F2812: Jump to Bootloader from Application
Part Number: TMS320F2812
Hi team,
I got  questions from customer.
"1. After setting GPIO F2, F3, F4 and F12 registers to SCI-A boot state, does the chip allow for executing the power on bootloader from software? If yes, what address must be execute to launch the built in bootloader?
2. When generating a reset want to attempt a power on bootloader entry, what is the minimum RESET time to properly reset the chip and enter bootload mode?"
Thank you very much for your help.
  • Hi Zhonghui,
    After a reset the boot process will run and call the SCI_BOOT function to load from SCI-A. This is discussed further in the Boot ROM Reference Guide: https://www.ti.com/lit/spru095
    Please see section 8.12.3 Reset Timing of the device datasheet for these timing details.
    Kevin
