Part Number: TMDXIDDK379D
Dear team:
C:\ti\c2000\C2000Ware_MotorControl_SDK_3_03_00_00\solutions\tmdxiddk379d\docs
In the document, the current sampling method used in the FCL routine for 28388D is to sample two of the three-phase currents. Namely: 2 Hall current sensors are connected in series with 2 phases, or 2 sampling resistors are connected in series with 2 phases.
My customer wants to know: If the method of connecting 3 sampling resistors in series between the 3 bridge arm downtubes and the DC negative terminal respectively, can the FCL library in the example be applied?
If not applicable, how to modify the FCL library if the customer wants to use the above method to sample?
Best regards
