problem with I2C multiple device
i'm working with IMU 9dof  http://www.sparkfun.com/products/10321 which contain accelerometor,gyro and magnetometer.Each device also have slave address.I done with the data from each devide with but i can't combine three devices in one code.Please tell me how can comunicate with this IMU.Here is my code
 * File: combine_3.c
 * Real-Time Workshop code generated for Simulink model combine_3.
 * Model version                        : 1.2
 * Real-Time Workshop file version      : 7.4  (R2009b)  29-Jun-2009
 * Real-Time Workshop file generated on : Sun Apr 10 15:07:11 2011
 * TLC version                          : 7.4 (Jul 14 2009)
 * C/C++ source code generated on       : Sun Apr 10 15:07:12 2011
 * Target selection: ccslink_ert.tlc
 * Embedded hardware selection: Texas Instruments->C2000
 * Code generation objectives: Unspecified
 * Validation result: Not run
#include "combine_3.h"
#include "combine_3_private.h"
/* user code (top of source file) */
/* System '<Root>' */
int counter;
/* Exported block signals */
real_T fgyro[3];                       /* '<Root>/Magnetic sensor' */
real_T facc[3];                        /* '<Root>/Magnetic sensor1' */
real_T fmag[3];                        /* '<Root>/Magnetic sensor2' */
uint8_T Rcv;                           /* '<Root>/SCI Receive' */
/* Block signals (auto storage) */
BlockIO_combine_3 combine_3_B;
/* Real-time model */
RT_MODEL_combine_3 combine_3_M_;
RT_MODEL_combine_3 *combine_3_M = &combine_3_M_;
/* Model step function */
void combine_3_step(void)
  /* local block i/o variables */
  uint8_T rtb_TmpSignalConversionAtSCITra[56];
    int16_T i;
    real_T tmp;
      /* user code (Output function Header) */
      int16 gyro[3], acc[3],mag[3], dummy, i, j, k;
      /////////////////////////////doc gyro
      if (counter==0) {
        /////////////////////////////////////////doc cam bien gyro/////////////////////////////////////
       I2caRegs.I2CSAR = 0x68;        // Set slave address
   I2caRegs.I2CMDR.all = 0x64A0;
        I2caRegs.I2CDXR = 0x1D;
        gyro[0] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        gyro[0] |= I2caRegs.I2CDRR;
        gyro[1] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        gyro[1] |= I2caRegs.I2CDRR;
        gyro[2] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        gyro[2] |= I2caRegs.I2CDRR;
        for (i=0; i<3; i++) {
          if (gyro[i] >= 0x2000)
            fgyro[i] = (float)(gyro[i] - 0x3FFF) * 0.07326;
          else
            fgyro[i] = (float)gyro[i] * 0.07326;
        ///////////////////////////////////////////doc cam bien acc/////////////////////////////
        I2caRegs.I2CSAR = 0x53;
        I2caRegs.I2CDXR = 0x03;
        acc[0] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        acc[0] |= I2caRegs.I2CDRR;
        acc[1] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        acc[1] |= I2caRegs.I2CDRR;
        acc[2] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        acc[2] |= I2caRegs.I2CDRR;
          if (acc[i] >= 0x2000)
            facc[i] = (float)(acc[i] - 0x3FFF) * 0.07326;
          else
            facc[i] = (float)acc[i] * 0.07326;
   ////////////////////////////////////mag
      I2caRegs.I2CSAR = 0x1E;
   I2caRegs.I2CDXR = 0x32;
     mag[0] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        mag[0] |= I2caRegs.I2CDRR;
        mag[1] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        mag[1] |= I2caRegs.I2CDRR;
        mag[2] = (I2caRegs.I2CDRR <<8) & 0xFF00;
        mag[2] |= I2caRegs.I2CDRR;
          if (mag[i] >= 0x2000)
            fmag[i] = (float)(mag[i] - 0x3FFF) * 0.07326;
          else
            fmag[i] = (float)mag[i] * 0.07326;
      } else if (counter==3)           // read data via I2C
        //I2caRegs.I2CCNT = 6;
        // I2caRegs.I2CMDR.all = 0x6C20;
  I2caRegs.I2CDXR = 0x1d;
      counter++;
      if (counter==4)
        counter = 0;
      /* S-Function Block: <Root>/SCI Receive (c28xsci_rx) */
        int i;
        char recbuff[1];
        int errFlg = NOERROR;
        for (i = 0; i < 1; i++)
          recbuff[i] = 0;
        /* Receiving data */
        errFlg = scib_rcv(recbuff, 1, LONGLOOP);
        if (errFlg != NOERROR)
          goto RXERRB;
        memcpy( &Rcv, recbuff, 1);
       RXERRB:
        asm(" NOP");
      /* DataTypeConversion: '<S3>/Data Type Conversion' incorporates:
       *  Inport: '<Root>/Magnetic sensor'
      if (rtIsNaN(fgyro[0]) || rtIsInf(fgyro[0])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(fgyro[0]), 65536.0);
      combine_3_B.DataTypeConversion[0] = tmp < 0.0 ? -((int16_T)(uint16_T)(-tmp))
        : (int16_T)(uint16_T)tmp;
      if (rtIsNaN(fgyro[1]) || rtIsInf(fgyro[1])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(fgyro[1]), 65536.0);
      combine_3_B.DataTypeConversion[1] = tmp < 0.0 ? -((int16_T)(uint16_T)(-tmp))
      if (rtIsNaN(fgyro[2]) || rtIsInf(fgyro[2])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(fgyro[2]), 65536.0);
      combine_3_B.DataTypeConversion[2] = tmp < 0.0 ? -((int16_T)(uint16_T)(-tmp))
      /* S-Function (IntToStr5): '<S3>/S-Function Builder 1' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion[0],
        combine_3_B.SFunctionBuilder1 );
      /* S-Function (IntToStr5): '<S3>/S-Function Builder 2' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion[1],
        combine_3_B.SFunctionBuilder2 );
      /* S-Function (IntToStr5): '<S3>/S-Function Builder 3' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion[2],
        combine_3_B.SFunctionBuilder3 );
      /* DataTypeConversion: '<S2>/Data Type Conversion' incorporates:
       *  Inport: '<Root>/Magnetic sensor1'
      if (rtIsNaN(facc[0]) || rtIsInf(facc[0])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(facc[0]), 65536.0);
      combine_3_B.DataTypeConversion_f[0] = tmp < 0.0 ? -((int16_T)(uint16_T)
        (-tmp)) : (int16_T)(uint16_T)tmp;
      if (rtIsNaN(facc[1]) || rtIsInf(facc[1])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(facc[1]), 65536.0);
      combine_3_B.DataTypeConversion_f[1] = tmp < 0.0 ? -((int16_T)(uint16_T)
      if (rtIsNaN(facc[2]) || rtIsInf(facc[2])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(facc[2]), 65536.0);
      combine_3_B.DataTypeConversion_f[2] = tmp < 0.0 ? -((int16_T)(uint16_T)
      /* S-Function (IntToStr5): '<S2>/S-Function Builder 1' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion_f[0],
        combine_3_B.SFunctionBuilder1_h );
      /* S-Function (IntToStr5): '<S2>/S-Function Builder 2' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion_f[1],
        combine_3_B.SFunctionBuilder2_n );
      /* S-Function (IntToStr5): '<S2>/S-Function Builder 3' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion_f[2],
        combine_3_B.SFunctionBuilder3_a );
      /* DataTypeConversion: '<S4>/Data Type Conversion' incorporates:
       *  Inport: '<Root>/Magnetic sensor2'
      if (rtIsNaN(fmag[0]) || rtIsInf(fmag[0])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(fmag[0]), 65536.0);
      combine_3_B.DataTypeConversion_c[0] = tmp < 0.0 ? -((int16_T)(uint16_T)
      if (rtIsNaN(fmag[1]) || rtIsInf(fmag[1])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(fmag[1]), 65536.0);
      combine_3_B.DataTypeConversion_c[1] = tmp < 0.0 ? -((int16_T)(uint16_T)
      if (rtIsNaN(fmag[2]) || rtIsInf(fmag[2])) {
        tmp = 0.0;
      } else {
        tmp = fmod(floor(fmag[2]), 65536.0);
      combine_3_B.DataTypeConversion_c[2] = tmp < 0.0 ? -((int16_T)(uint16_T)
      /* S-Function (IntToStr5): '<S4>/S-Function Builder 1' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion_c[0],
        combine_3_B.SFunctionBuilder1_m );
      /* S-Function (IntToStr5): '<S4>/S-Function Builder 2' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion_c[1],
        combine_3_B.SFunctionBuilder2_b );
      /* S-Function (IntToStr5): '<S4>/S-Function Builder 3' */
      IntToStr5_Outputs_wrapper(&combine_3_B.DataTypeConversion_c[2],
        combine_3_B.SFunctionBuilder3_p );
      /* SignalConversion: '<Root>/TmpSignal ConversionAtSCI TransmitInport1' incorporates:
       *  Constant: '<Root>/Constant0'
       *  Constant: '<Root>/Constant2'
       *  Constant: '<Root>/Constant3'
       *  Constant: '<Root>/Constant4'
       *  Constant: '<Root>/Constant6'
       *  Constant: '<S2>/Constant1'
       *  Constant: '<S2>/Constant2'
       *  Constant: '<S3>/Constant1'
       *  Constant: '<S3>/Constant2'
       *  Constant: '<S4>/Constant1'
       *  Constant: '<S4>/Constant2'
      rtb_TmpSignalConversionAtSCITra[0] = combine_3_P.Constant0_Value;
      rtb_TmpSignalConversionAtSCITra[1] = combine_3_P.Constant2_Value;
      for (i = 0; i < 5; i++) {
        rtb_TmpSignalConversionAtSCITra[i + 2] = combine_3_B.SFunctionBuilder1[i];
      rtb_TmpSignalConversionAtSCITra[7] = combine_3_P.Constant1_Value_b;
        rtb_TmpSignalConversionAtSCITra[i + 8] = combine_3_B.SFunctionBuilder2[i];
      rtb_TmpSignalConversionAtSCITra[13] = combine_3_P.Constant2_Value_b;
        rtb_TmpSignalConversionAtSCITra[i + 14] =
          combine_3_B.SFunctionBuilder3[i];
      rtb_TmpSignalConversionAtSCITra[19] = combine_3_P.Constant4_Value;
        rtb_TmpSignalConversionAtSCITra[i + 20] =
          combine_3_B.SFunctionBuilder1_h[i];
      rtb_TmpSignalConversionAtSCITra[25] = combine_3_P.Constant1_Value_c;
        rtb_TmpSignalConversionAtSCITra[i + 26] =
          combine_3_B.SFunctionBuilder2_n[i];
      rtb_TmpSignalConversionAtSCITra[31] = combine_3_P.Constant2_Value_o;
        rtb_TmpSignalConversionAtSCITra[i + 32] =
          combine_3_B.SFunctionBuilder3_a[i];
      rtb_TmpSignalConversionAtSCITra[37] = combine_3_P.Constant6_Value;
        rtb_TmpSignalConversionAtSCITra[i + 38] =
          combine_3_B.SFunctionBuilder1_m[i];
      rtb_TmpSignalConversionAtSCITra[43] = combine_3_P.Constant1_Value_e;
        rtb_TmpSignalConversionAtSCITra[i + 44] =
          combine_3_B.SFunctionBuilder2_b[i];
      rtb_TmpSignalConversionAtSCITra[49] = combine_3_P.Constant2_Value_n;
        rtb_TmpSignalConversionAtSCITra[i + 50] =
          combine_3_B.SFunctionBuilder3_p[i];
      rtb_TmpSignalConversionAtSCITra[55] = combine_3_P.Constant3_Value;
      /* S-Function Block: <Root>/SCI Transmit (c28xsci_tx) */
        scib_xmit((char*)rtb_TmpSignalConversionAtSCITra, 56);
      /* S-Function Block: <Root>/I2C Transmit1 (c280xi2c_tx) */
        int unsigned tx_loop= 0;
        while (I2caRegs.I2CFFTX.bit.TXFFST!=0 && tx_loop<10000 )
          tx_loop++;
        if (tx_loop!=10000) {
          I2caRegs.I2CSAR = 53;        // Set slave address
          I2caRegs.I2CCNT= 2;          // Set data length
          /* mode:1 (1:master 0:slave)  Addressing mode:0 (1:10-bit 0:7-bit)
             free data mode:0 (1:enbaled 0:disabled) digital loopback mode:0 (1:enabled 0:disabled)
             bit count:0 (0:8bit) stop condition:0 (1:enabled 0: disabled)*/
          I2caRegs.I2CMDR.all = 26144;
          tx_loop= 0;
          while (I2caRegs.I2CFFTX.bit.TXFFST>14 && tx_loop<10000)
            tx_loop++;
            I2caRegs.I2CDXR = (uint8_T)(combine_3_P.Constant1_Value&0xFF);
            I2caRegs.I2CDXR = (uint8_T)((combine_3_P.Constant1_Value>>8&0xFF));
      /* S-Function Block: <Root>/I2C Transmit2 (c280xi2c_tx) */
          tx_loop++;
          I2caRegs.I2CSAR = 68;        // Set slave address
          tx_loop= 0;
            tx_loop++;
            I2caRegs.I2CDXR = (uint8_T)(combine_3_P.Constant5_Value&0xFF);
            I2caRegs.I2CDXR = (uint8_T)((combine_3_P.Constant5_Value>>8&0xFF));
      /* S-Function Block: <Root>/I2C Transmit3 (c280xi2c_tx) */
          tx_loop++;
          I2caRegs.I2CSAR = 1;         // Set slave address
          tx_loop= 0;
            tx_loop++;
            I2caRegs.I2CDXR = (uint8_T)(combine_3_P.Constant7_Value&0xFF);
            I2caRegs.I2CDXR = (uint8_T)((combine_3_P.Constant7_Value>>8&0xFF));
/* Model initialize function */
void combine_3_initialize(boolean_T firstTime)
  (void)firstTime;
  /* Registration code */
  /* initialize non-finites */
  rt_InitInfAndNaN(sizeof(real_T));
  /* initialize error status */
  rtmSetErrorStatus(combine_3_M, (NULL));
  /* block I/O */
  (void) memset(((void *) &combine_3_B),0,
                sizeof(BlockIO_combine_3));
  /* exported global signals */
  Rcv = 0;
  /* external inputs */
  (void) memset(fgyro,0,
                3*sizeof(real_T));
  (void) memset(facc,0,
                3*sizeof(real_T));
  (void) memset(fmag,0,
                3*sizeof(real_T));
  /* Start for S-Function (c28xsci_rx): '<Root>/SCI Receive' */
  /* Initialize Rcv */
  Rcv = 27;
      /* user code (Initialize function Header) */
      int i, j, k;
      for (i=0; i<10000; i++)
        for (j=0; j<1000; j++)
          k = i + j;
      /* user code (Initialize function Trailer) */
      counter = 0;
      I2caRegs.I2CMDR.all = 0x66A0;
      I2caRegs.I2CDXR = 0x16;          //DLPF_FS register
   /* I2caRegs.I2CMDR.bit.TRX = 1;     //Set to Transmit mode bit 9 =1
      I2caRegs.I2CMDR.bit.MST = 1;     //Set to Master mode   bit 10
      I2caRegs.I2CMDR.bit.FREE = 1;    //Run in FREE mode     bit 14
      I2caRegs.I2CMDR.bit.STP = 0;     //Stop when internal counter becomes 0 bit 11
      I2caRegs.I2CMDR.bit.RM = 1;      // bit 7
      I2caRegs.I2CMDR.bit.IRS = 1;     //bit 5
      I2caRegs.I2CMDR.bit.STT = 1;     //Send the start bit, transmission will follow bit 13 */
      I2caRegs.I2CDXR = 0x19;          //00011001 LPF bandwith 188Hz, internal Sampling rate 1kHz, full scale 2000 o/s
      I2caRegs.I2CSAR = 0x53;          // Set slave address
      I2caRegs.I2CDXR = 0x2c;          //measurement mode _ Power_ctl
      I2caRegs.I2CDXR = 0x09;          //data_format with full resolution
      I2caRegs.I2CDXR = 0x08;          //BW_rate 50Hz
      I2caRegs.I2CDXR = 0x00;
    /*I2caRegs.I2CMDR.bit.TRX = 1;     //Set to Transmit mode bit 9 =1
      I2caRegs.I2CDXR = 0x06;
      for (i=0; i<1000; i++)
          k = i + j;
/* Model terminate function */
void combine_3_terminate(void)
  /* (no terminate code required) */
 * File trailer for Real-Time Workshop generated code.
 * [EOF]
Thanks in advance,
hung
 PS : we just work with  the red text because this is generated code from matlab simulink.
