TMS320F28388D: DMA continue mode reading incorrect data from ADC SOC
Part Number: TMS320F28388D
I am trying to have DMA reading ADC data at the end of SOC15. SOC is triggered by ePWM. The example of "adc_ex6_soc_continuous_dma" only runs once, so I modified the DMA configuration from DMA_CFG_CONTINUOUS_DISABLE to DMA_CFG_CONTINUOUS_ENABLE. I also removed the trigger disable in dma interrupt. I also would like to have all SOC triggered by epwm1, so I changed the software tigger in the example.
I get correct data if the DMA_CFG_CONTINUOUS_DISABLE is set:
But the data reading is incorrect if I changed it to DMA_CFG_CONTINUOUS_ENABLE:
I have my modified c file attached. I am not sure what configuration I missed.
// FILE:   adc_ex6_soc_continuous_dma.c
// TITLE:  ADC continuous conversions read by DMA.
//! \addtogroup driver_example_list
//! <h1> ADC Continuous Conversions Read by DMA (adc_soc_continuous_dma)</h1>
//! This example sets up two ADC channels to convert simultaneously. The
//! results will be transferred by the DMA into a buffer in RAM.
//! \b External \b Connections \n
//!  - A3 & B3 pins should be connected to signals to convert
//! \b Watch \b Variables \n
//! - \b adcADataBuffer \b: a digital representation of the voltage on pin A3\n
//! - \b adcBDataBuffer \b: a digital representation of the voltage on pin B3\n
// $TI Release: F2838x Support Library v3.03.00.00 $
// $Release Date: Sun Oct  4 16:00:36 IST 2020 $
// $Copyright:
// Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// Function Prototypes
__interrupt void dmach1ISR(void);
void configureEPWM(uint32_t epwmBase);
void configureADC(uint32_t adcBase);
void setupADCContinuous(uint32_t adcBase, uint16_t channel);
void initializeDMA(void);
void configureDMAChannels(void);
// Defines0
#define RESULTS_BUFFER_SIZE 256    // Buffer for storing conversion results
                                    // (size must be multiple of 16)
#define EX_ADC_RESOLUTION   16
// Globals
#pragma DATA_SECTION(adcADataBuffer, "ramgs0");
#pragma DATA_SECTION(adcBDataBuffer, "ramgs0");
uint16_t adcADataBuffer[RESULTS_BUFFER_SIZE];
uint16_t adcBDataBuffer[RESULTS_BUFFER_SIZE];
volatile uint16_t dma_done;
void main(void)
    uint16_t resultsIndex;
    // Initialize device clock and peripherals
    Device_init();
    // Disable pin locks and enable internal pullups.
    Device_initGPIO();
    // Initialize PIE and clear PIE registers. Disables CPU interrupts.
    Interrupt_initModule();
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    Interrupt_initVectorTable();
    // Set up ISRs used by this example
    // ISR for DMA ch1 - occurs when DMA transfer is complete
    Interrupt_register(INT_DMA_CH1, &dmach1ISR);
    // Enable specific PIE & CPU interrupts:
    // DMA interrupt - Group 7, interrupt 1
    Interrupt_enable(INT_DMA_CH1);
    // Stop the ePWM clock
    SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // Call the set up function for ePWM 2
    configureEPWM(EPWM1_BASE);
    // Start the ePWM clock
    SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
    // Configure the ADCA & ADCB and power it up
    configureADC(ADCA_BASE);
    configureADC(ADCB_BASE);
    // Setup the ADC for continuous conversions on channels A3 and B3
    setupADCContinuous(ADCA_BASE, 2);
    setupADCContinuous(ADCB_BASE, 2);
    // Initialize the DMA & configure DMA channels 1 & 2
    initializeDMA();
    configureDMAChannels();
    // Initialize results buffer
    for(resultsIndex = 0; resultsIndex < RESULTS_BUFFER_SIZE; resultsIndex++)
        adcADataBuffer[resultsIndex] = 0;
        adcBDataBuffer[resultsIndex] = 0;
    // Clearing all pending interrupt flags
    DMA_clearTriggerFlag(DMA_CH1_BASE);   // DMA channel 1
    DMA_clearTriggerFlag(DMA_CH2_BASE);   // DMA channel 2
    HWREGH(ADCA_BASE + ADC_O_INTFLGCLR) = 0x3U; // ADCA
    HWREGH(ADCB_BASE + ADC_O_INTFLGCLR) = 0x3U; // ADCB
    EPWM_forceADCTriggerEventCountInit(EPWM1_BASE, EPWM_SOC_A); // EPWM1 SOCA
    EPWM_clearADCTriggerFlag(EPWM1_BASE, EPWM_SOC_A);    // EPWM1 SOCA
    // Enable global Interrupts and higher priority real-time debug events:
    EINT;  // Enable Global interrupt INTM
    ERTM;  // Enable Global realtime interrupt DBGM
    // Start DMA
    dma_done = 0;
    DMA_startChannel(DMA_CH1_BASE);
    DMA_startChannel(DMA_CH2_BASE);
    // Finally, enable the SOCA trigger from ePWM. This will kick off
    // conversions at the next ePWM event.
    EPWM_enableADCTrigger(EPWM1_BASE, EPWM_SOC_A);
    // Loop until the ISR signals the transfer is complete
    while(1)
        if (dma_done == 1){
            //dsp
            dma_done=0;
        __asm(" NOP");
// dmach1ISR - This is called at the end of the DMA transfer.
#pragma CODE_SECTION(dmach1ISR, ".TI.ramfunc");
    dma_done=1;
    // Acknowledge interrupt
    Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP7);
// configureEPWM - Set up the ePWM module so that the A output has a period
//                 of 5us with a 50% duty. The SOCA signal is coincident with
//                 the rising edge of this.
    // Make the timer count up with a period of 5us
    HWREGH(epwmBase + EPWM_O_TBCTL) = 0x0000U;
    EPWM_setTimeBasePeriod(epwmBase, 500U);
    // Set the A output on zero and reset on CMPA
    EPWM_setActionQualifierAction(epwmBase, EPWM_AQ_OUTPUT_A,
                                  EPWM_AQ_OUTPUT_HIGH,
                                  EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
                                  EPWM_AQ_OUTPUT_LOW,
                                  EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
    // Set CMPA to 2.5us to get a 50% duty
    EPWM_setCounterCompareValue(epwmBase, EPWM_COUNTER_COMPARE_A, 250U);
    // Start ADC when timer equals zero (note: don't enable yet)
    EPWM_setADCTriggerSource(epwmBase, EPWM_SOC_A, EPWM_SOC_TBCTR_ZERO);
    EPWM_setADCTriggerEventPrescale(epwmBase, EPWM_SOC_A, 1U);
    // Enable initialization of the SOCA event counter. Since we are
    // disabling the ETSEL.SOCAEN bit, we need a way to reset the SOCACNT.
    // Hence, enable the counter initialize control.
    EPWM_enableADCTriggerEventCountInit(epwmBase, EPWM_SOC_A);
// configureADC - Write ADC configurations and power up the ADC for both
//                ADC A and ADC B
    // Set ADCCLK divider to /4
    ADC_setPrescaler(adcBase, ADC_CLK_DIV_4_0);
    // Set resolution and signal mode (see #defines above) and load
    // corresponding trims.
#if(EX_ADC_RESOLUTION == 12)
    ADC_setMode(adcBase, ADC_RESOLUTION_12BIT, ADC_MODE_SINGLE_ENDED);
#elif(EX_ADC_RESOLUTION == 16)
    ADC_setMode(adcBase, ADC_RESOLUTION_16BIT, ADC_MODE_DIFFERENTIAL);
#endif
    // Set pulse positions to late
    ADC_setInterruptPulseMode(adcBase, ADC_PULSE_END_OF_CONV);
    // Power up the ADCs and then delay for 1 ms
    ADC_enableConverter(adcBase);
    // Delay for 1ms to allow ADC time to power up
    DEVICE_DELAY_US(1000);
// setupADCContinuous - setup the ADC to continuously convert on one channel
    uint16_t acqps=63;
    // Configure SOCs channel no. & acquisition window.
    // Trigger SCO0-15 from EPWM1SOCA.
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER0, ADC_TRIGGER_EPWM1_SOCA,
                 (ADC_Channel)channel, acqps);
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER1, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER2, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER3, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER4, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER5, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER6, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER7, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER8, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER9, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER10, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER11, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER12, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER13, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER14, ADC_TRIGGER_EPWM1_SOCA,
    ADC_setupSOC(adcBase, ADC_SOC_NUMBER15, ADC_TRIGGER_EPWM1_SOCA,
    // Enable ADCINT1 & ADCINT2. Disable ADCINT3 & ADCINT4.
    ADC_disableInterrupt(adcBase, ADC_INT_NUMBER1);
    ADC_enableInterrupt(adcBase, ADC_INT_NUMBER2);
    ADC_disableInterrupt(adcBase, ADC_INT_NUMBER3);
    ADC_disableInterrupt(adcBase, ADC_INT_NUMBER4);
    // Enable continuous mode
    //ADC_enableContinuousMode(adcBase, ADC_INT_NUMBER1);
    ADC_enableContinuousMode(adcBase, ADC_INT_NUMBER2);
    // Configure interrupt triggers
    //ADC_setInterruptSource(adcBase, ADC_INT_NUMBER1, ADC_SOC_NUMBER0);
    ADC_setInterruptSource(adcBase, ADC_INT_NUMBER2, ADC_SOC_NUMBER15);
// initializeDMA - Initialize DMA through hard reset
    // Perform a hard reset on DMA
    DMA_initController();
    // Allow DMA to run free on emulation suspend
    DMA_setEmulationMode(DMA_EMULATION_FREE_RUN);
// configureDMAChannels - Initialize DMA ch 1 to transfer ADCA results
//                        and DMA ch 2 to transfer ADCB results
    // DMA channel 1 set up for ADCA
    DMA_configAddresses(DMA_CH1_BASE, (uint16_t *)&adcADataBuffer,
                        (uint16_t *)ADCARESULT_BASE);
    // Perform enough 16-word bursts to fill the results buffer. Data will be
    // transferred 32 bits at a time hence the address steps below.
    DMA_configBurst(DMA_CH1_BASE, 16, 2, 2);
    DMA_configTransfer(DMA_CH1_BASE, (RESULTS_BUFFER_SIZE >> 4), -14, 2);
    DMA_configMode(DMA_CH1_BASE, DMA_TRIGGER_ADCA2,
                   (DMA_CFG_ONESHOT_DISABLE | DMA_CFG_CONTINUOUS_ENABLE |
                    DMA_CFG_SIZE_32BIT));
    DMA_enableTrigger(DMA_CH1_BASE);
    DMA_disableOverrunInterrupt(DMA_CH1_BASE);
    DMA_setInterruptMode(DMA_CH1_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH1_BASE);
    // DMA channel 2 set up for ADCB
    DMA_configAddresses(DMA_CH2_BASE, (uint16_t *)&adcBDataBuffer,
                        (uint16_t *)ADCBRESULT_BASE);
    DMA_configBurst(DMA_CH2_BASE, 16, 2, 2);
    DMA_configTransfer(DMA_CH2_BASE, (RESULTS_BUFFER_SIZE >> 4), -14, 2);
    DMA_configMode(DMA_CH2_BASE, DMA_TRIGGER_ADCA2,
    DMA_enableTrigger(DMA_CH2_BASE);
    DMA_disableOverrunInterrupt(DMA_CH2_BASE);
    DMA_setInterruptMode(DMA_CH2_BASE, DMA_INT_AT_END);
    DMA_enableInterrupt(DMA_CH2_BASE);
// End of file
// $Copyright:
// are met:
//   distribution.
// Included Files
#include "device.h"
// Defines0
// Globals
void main(void)
    Device_init();
    Device_initGPIO();
    initializeDMA();
    // Start DMA
    dma_done = 0;
    while(1)
        if (dma_done == 1){
            //dsp
            dma_done=0;
        __asm(" NOP");
    dma_done=1;
                                  EPWM_AQ_OUTPUT_LOW,
//                ADC A and ADC B
#endif
    uint16_t acqps=63;
// End of file
  • Can you confirm that difference between the first graph and the second is just DMA_CFG_CONTINUOUS_DISABLE/ENABLE? No other changes were made to the code? If you halt and look at the data in the ADC result registers in CCS, do they also look incorrect?
    Whitney
  • Hi Whitney,
    Yes the only change is the continuous mode of DMA. The ADC result register also has incorrect data in continuous mode.
    We somehow get correct data by changing the burst_size from 16 to 15 and removing the transfer configuration function. We are not sure how to correctly set the DMA_configTransfer(); function in our case:
    For each burst loop, we send SOC0-15 totally 16 words. For transfer loop, we only transfer one burst.
    Thank you.
  • The fact that the ADC result registers are showing incorrect data should have nothing to do with the DMA configuration. Can you check your ADC timings? In the datasheet there are some tables to help you calculate the amount of time from the ADC trigger to the interrupt. Can you do all 16 conversions within your PWM period?
    Whitney
  • Hi Whitney, thank you for the follow up. I think my program is able to perform properly now.
