TMS320F28386D: TI SSI high speed mode question
Part Number: TMS320F28386D
We ran into this problem as well: https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1029971/tms320f28386d-spi-communication-signal-is-fine-but-decode-result-is-wrong-with-cm-ssi
We saw this and applied the high speed mode,  and it works.
Is there any explanation of the high speed mode? Does this improve the SSI sample rate or less delay?
It'll be great if we know how it work
Thank you
  • Ryan,
    When SPI baud rate is greater 20 MHz, you need to enable high speed mode.
    When high speed mode is enabled, SSICLK is reflected back (looped back) to adjust clock to external timing requirements.This allows the time between the clock as seen by remote device and internal clock to match closely.
    Manoj
