hello, I bought a TMDSPREX28335 kit a month ago, it always works well , but today when I started to run a simple code( on debug mode) , the connection of the board with my computer was interrupted suddenly . then I tried to connect again, but it failed. so I switched off the USB power, and turn on again. once turn on the USB power switch, the LD1-LD5 on the board will flash once(can't light up again, usually, the LDs can light up) , and the LD1 of control card keeps lighting up status.
there was an error message that said the voltage is too low.
I don't know what's the reason, is the board broke?
does it caused by my code?
thanks in advance!
