Part Number: TMS320F28032
In the example HVPM_Sensorless Project in Control_Suite, the Pwm frequency specified in the software does not match the actual PWM frequency.
The PWM frequency is specified as 10KHz in the software. But in reality we measured it as 10.08 KHz. This causes the actual motor speed to be 1008 RPM, while it is processed as 1000 rpm in the software.
The situation does not change whether we use the internal clock or the Crystal oscillator. Looking forward to your help on the subject.
I am adding the relevant parts of the software below.
#define PWM_FREQ_CUSTOM 10000 float32 T = (float32)1 / (float32)PWM_FREQ_CUSTOM;
**** @ main function
// Initialize PWM module pwm1.PeriodMax = SYSTEM_FREQUENCY*1000000*T/2; pwm1.HalfPerMax=pwm1.PeriodMax/2; pwm1.Deadband = 0.9*SYSTEM_FREQUENCY; PWM_INIT_MACRO(1,2,3,pwm1)
And Device_Init Function is below:
void DeviceInit(void)
WDogDisable(); // Disable the watchdog initially
DINT; // Global Disable all Interrupts
IER = 0x0000; // Disable CPU interrupts
IFR = 0x0000; // Clear all CPU interrupt flags
// Switch to Internal Oscillator 1 and turn off all other clock
// sources to minimize power consumption
EALLOW;
SysCtrlRegs.CLKCTL.bit.INTOSC1OFF = 0;
SysCtrlRegs.CLKCTL.bit.OSCCLKSRCSEL=0; // Clk Src = INTOSC1
SysCtrlRegs.CLKCTL.bit.XCLKINOFF=1; // Turn off XCLKIN
SysCtrlRegs.CLKCTL.bit.XTALOSCOFF=1; // Turn off XTALOSC
SysCtrlRegs.CLKCTL.bit.INTOSC2OFF=1; // Turn off INTOSC2
// SysCtrlRegs.CLKCTL.bit.XCLKINOFF=1;//Turn off XCLKIN
// SysCtrlRegs.CLKCTL.bit.XTALOSCOFF =0;// OSC on (default on reset)
// SysCtrlRegs.CLKCTL.bit.OSCCLKSRCSEL=1; // Clk Src = INTOSC1
// SysCtrlRegs.CLKCTL.bit.INTOSC2OFF=1; // Turn off INTOSC2
// SysCtrlRegs.CLKCTL.bit.OSCCLKSRC2SEL=0;
EDIS;
// SYSTEM CLOCK speed based on internal oscillator = 10 MHz
// 0xC = 60 MHz (12)
// 0xB = 55 MHz (11)
// 0xA = 50 MHz (10)
// 0x9 = 45 MHz (9)
// 0x8 = 40 MHz (8)
// 0x7 = 35 MHz (7)
// 0x6 = 30 MHz (6)
// 0x5 = 25 MHz (5)
// 0x4 = 20 MHz (4)
// 0x3 = 15 MHz (3)
// 0x2 = 10 MHz (2)
PLLset(0xC); // choose from options above
// PLLset(0x6);
// Initialise interrupt controller and Vector Table
// to defaults for now. Application ISR mapping done later.
PieCntlInit();
PieVectTableInit();
EALLOW; // below registers are "protected", allow access.
// LOW SPEED CLOCKS prescale register settings
SysCtrlRegs.LOSPCP.all = 0x0002; // Sysclk / 4 (15 MHz)
SysCtrlRegs.XCLK.bit.XCLKOUTDIV=2;
// ADC CALIBRATION
// The Device_cal function, which copies the ADC & oscillator calibration values
// from TI reserved OTP into the appropriate trim registers, occurs automatically
// in the Boot ROM. If the boot ROM code is bypassed during the debug process, the
// following function MUST be called for the ADC and oscillators to function according
// to specification.
SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; // Enable ADC peripheral clock
(*Device_cal)(); // Auto-calibrate from TI OTP
SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 0; // Return ADC clock to original state
// PERIPHERAL CLOCK ENABLES
// If you are not using a peripheral you may want to switch
// the clock off to save power, i.e. set to =0
// Note: not all peripherals are available on all 280x derivates.
// Refer to the datasheet for your particular device.
SysCtrlRegs.PCLKCR0.bit.ADCENCLK = 1; // ADC
SysCtrlRegs.PCLKCR3.bit.COMP1ENCLK = 1; // COMP1
SysCtrlRegs.PCLKCR3.bit.COMP2ENCLK = 1; // COMP2
SysCtrlRegs.PCLKCR3.bit.COMP3ENCLK = 1; // COMP3
SysCtrlRegs.PCLKCR1.bit.ECAP1ENCLK = 1; //eCAP1
SysCtrlRegs.PCLKCR0.bit.ECANAENCLK=0; // eCAN-A
SysCtrlRegs.PCLKCR1.bit.EQEP1ENCLK = 1; // eQEP1
SysCtrlRegs.PCLKCR1.bit.EPWM1ENCLK = 1; // ePWM1
SysCtrlRegs.PCLKCR1.bit.EPWM2ENCLK = 1; // ePWM2
SysCtrlRegs.PCLKCR1.bit.EPWM3ENCLK = 1; // ePWM3
SysCtrlRegs.PCLKCR1.bit.EPWM4ENCLK = 1; // ePWM4
SysCtrlRegs.PCLKCR1.bit.EPWM5ENCLK = 1; // ePWM5
SysCtrlRegs.PCLKCR1.bit.EPWM6ENCLK = 1; // ePWM6
SysCtrlRegs.PCLKCR1.bit.EPWM7ENCLK = 1; // ePWM7
SysCtrlRegs.PCLKCR0.bit.HRPWMENCLK = 0; // HRPWM
SysCtrlRegs.PCLKCR0.bit.I2CAENCLK = 0; // I2C
SysCtrlRegs.PCLKCR0.bit.LINAENCLK = 1; // LIN-A
SysCtrlRegs.PCLKCR3.bit.CLA1ENCLK = 0; // CLA1
SysCtrlRegs.PCLKCR0.bit.SCIAENCLK = 1; // SCI-A
SysCtrlRegs.PCLKCR0.bit.SPIAENCLK = 0; // SPI-A
SysCtrlRegs.PCLKCR0.bit.SPIBENCLK = 0; // SPI-B
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1; // Enable TBCLK
// GPIO (GENERAL PURPOSE I/O) CONFIG
// QUICK NOTES on USAGE:
// If GpioCtrlRegs.GP?MUX?bit.GPIO?= 1, 2 or 3 (i.e. Non GPIO func), then leave
// rest of lines commented
// If GpioCtrlRegs.GP?MUX?bit.GPIO?= 0 (i.e. GPIO func), then:
// 1) uncomment GpioCtrlRegs.GP?DIR.bit.GPIO? = ? and choose pin to be IN or OUT
// 2) If IN, can leave next to lines commented
// 3) If OUT, uncomment line with ..GPACLEAR.. to force pin LOW or
// uncomment line with ..GPASET.. to force pin HIGH or
// GPIO-00 - PIN FUNCTION = PWM1A
GpioCtrlRegs.GPAMUX1.bit.GPIO0 = 1; // 0=GPIO, 1=EPWM1A, 2=Resv, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO0 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO0 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO0 = 1; // uncomment if --> Set High initially
// GPIO-01 - PIN FUNCTION = PWM1B
GpioCtrlRegs.GPAMUX1.bit.GPIO1 = 1; // 0=GPIO, 1=EPWM1B, 2=Resv, 3=COMP1OUT
// GpioCtrlRegs.GPADIR.bit.GPIO1 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO1 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO1 = 1; // uncomment if --> Set High initially
// GPIO-02 - PIN FUNCTION = PWM2A
GpioCtrlRegs.GPAMUX1.bit.GPIO2 = 1; // 0=GPIO, 1=EPWM2A, 2=Resv, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO2 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO2 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO2 = 1; // uncomment if --> Set High initially
// GPIO-03 - PIN FUNCTION = PWM2B
GpioCtrlRegs.GPAMUX1.bit.GPIO3 = 1; // 0=GPIO, 1=EPWM2B, 2=SPISOMI-A, 3=COMP2OUT
// GpioCtrlRegs.GPADIR.bit.GPIO3 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO3 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO3 = 1; // uncomment if --> Set High initially
// GPIO-04 - PIN FUNCTION = PWM3A
GpioCtrlRegs.GPAMUX1.bit.GPIO4 = 1; // 0=GPIO, 1=EPWM3A, 2=Resv, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO4 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO4 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO4 = 1; // uncomment if --> Set High initially
// GPIO-05 - PIN FUNCTION = PWM3B
GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 1; // 0=GPIO, 1=EPWM3B, 2=SPISIMO-A, 3=ECAP1
// GpioCtrlRegs.GPADIR.bit.GPIO5 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO5 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO5 = 1; // uncomment if --> Set High initially
// GPIO-06 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX1.bit.GPIO6 = 0; // 0=GPIO, 1=EPWM4A, 2=SYNCI, 3=SYNCO
// GpioCtrlRegs.GPADIR.bit.GPIO6 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO6 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO6 = 1; // uncomment if --> Set High initially
// GPIO-07 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX1.bit.GPIO7 = 0; // 0=GPIO, 1=EPWM4B, 2=SCIRX-A, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO7 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO7 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO7 = 1; // uncomment if --> Set High initially
// GPIO-08 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX1.bit.GPIO8 = 0; // 0=GPIO, 1=EPWM5A, 2=Resv, 3=ADCSOC-A
// GpioCtrlRegs.GPADIR.bit.GPIO8 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO8 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO8 = 1; // uncomment if --> Set High initially
// GPIO-09 - PIN FUNCTION = LIN_Tx
GpioCtrlRegs.GPAMUX1.bit.GPIO9 = 2; // 0=GPIO, 1=EPWM5B, 2=LINTX-A, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO9 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO9 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO9 = 1; // uncomment if --> Set High initially
// GPIO-10 - PIN FUNCTION = --PWMdebug--
GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 0; // 0=GPIO, 1=EPWM6A, 2=Resv, 3=ADCSOC-B
GpioCtrlRegs.GPADIR.bit.GPIO10 = 1; // 1=OUTput, 0=INput
GpioDataRegs.GPACLEAR.bit.GPIO10 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO10 = 1; // uncomment if --> Set High initially
// GPIO-11 - PIN FUNCTION = --unused--
GpioCtrlRegs.GPAMUX1.bit.GPIO11 = 0; // 0=GPIO, 1=EPWM6B, 2=LINRX-A, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO11 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO11 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO11 = 1; // uncomment if --> Set High initially
// GPIO-12 - PIN FUNCTION = POE
GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 1; // 0=GPIO, 1=TZ1, 2=SCITX-A, 3=SPISIMO-B
// GpioCtrlRegs.GPADIR.bit.GPIO12 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO12 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO12 = 1; // uncomment if --> Set High initially
// GPIO-16 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO16 = 0; // 0=GPIO, 1=SPISIMO-A, 2=Resv, 3=TZ2
// GpioCtrlRegs.GPADIR.bit.GPIO16 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO16 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO16 = 1; // uncomment if --> Set High initially
// GPIO-17 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 0; // 0=GPIO, 1=SPISOMI-A, 2=Resv, 3=TZ3
// GpioCtrlRegs.GPADIR.bit.GPIO17 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO17 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO17 = 1; // uncomment if --> Set High initially
// GPIO-18 - PIN FUNCTION = AC info
GpioCtrlRegs.GPAMUX2.bit.GPIO18 = 0; // 0=GPIO, 1=SPICLK-A, 2=LINTX-A, 3=XCLKOUT
GpioCtrlRegs.GPADIR.bit.GPIO18 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO18 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO18 = 1; // uncomment if --> Set High initially
// GPIO-19 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO19 = 0; // 0=GPIO, 1=SPISTE-A, 2=LINRX-A, 3=ECAP1
// GpioCtrlRegs.GPADIR.bit.GPIO19 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO19 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO19 = 1; // uncomment if --> Set High initially
// GPIO-20 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO20 = 0; // 0=GPIO, 1=EQEPA-1, 2=Resv, 3=COMP1OUT
// GpioCtrlRegs.GPADIR.bit.GPIO20 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO20 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO20 = 1; // uncomment if --> Set High initially
// GPIO-21 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO21 = 0; // 0=GPIO, 1=EQEPB-1, 2=Resv, 3=COMP2OUT
// GpioCtrlRegs.GPADIR.bit.GPIO21 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO21 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO21 = 1; // uncomment if --> Set High initially
// GPIO-22 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO22 = 0; // 0=GPIO, 1=EQEPS-1, 2=Resv, 3=LINTX-A
// GpioCtrlRegs.GPADIR.bit.GPIO22 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO22 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO22 = 1; // uncomment if --> Set High initially
// GPIO-23 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO23 = 0; // 0=GPIO, 1=EQEPI-1, 2=Resv, 3=LINRX-A
// GpioCtrlRegs.GPADIR.bit.GPIO23 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO23 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO23 = 1; // uncomment if --> Set High initially
// GPIO-24 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO24 = 0; // 0=GPIO, 1=ECAP1, 2=Resv, 3=SPISIMO-B
// GpioCtrlRegs.GPADIR.bit.GPIO24 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO24 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO24 = 1; // uncomment if --> Set High initially
// GPIO-28 - PIN FUNCTION = SCI-RX
GpioCtrlRegs.GPAMUX2.bit.GPIO28 = 1; // 0=GPIO, 1=SCIRX-A, 2=I2CSDA-A, 3=TZ2
// GpioCtrlRegs.GPADIR.bit.GPIO28 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO28 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO28 = 1; // uncomment if --> Set High initially
// GPIO-29 - PIN FUNCTION = SCI-TX
GpioCtrlRegs.GPAMUX2.bit.GPIO29 = 1; // 0=GPIO, 1=SCITXD-A, 2=I2CSCL-A, 3=TZ3
// GpioCtrlRegs.GPADIR.bit.GPIO29 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO29 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO29 = 1; // uncomment if --> Set High initially
// GPIO-30 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO30 = 0; // 0=GPIO, 1=CANRX-A, 2=Resv, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO30 = 0; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO30 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO30 = 1; // uncomment if --> Set High initially
// GPIO-31 - PIN FUNCTION = unused
GpioCtrlRegs.GPAMUX2.bit.GPIO31 = 0; // 0=GPIO, 1=CANTX-A, 2=Resv, 3=Resv
// GpioCtrlRegs.GPADIR.bit.GPIO31 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPACLEAR.bit.GPIO31 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPASET.bit.GPIO31 = 1; // uncomment if --> Set High initially
// GPIO-32 - PIN FUNCTION = unused
GpioCtrlRegs.GPBMUX1.bit.GPIO32 = 0; // 0=GPIO, 1=I2CSDA-A, 2=SYNCI, 3=ADCSOCA
// GpioCtrlRegs.GPBDIR.bit.GPIO32 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPBCLEAR.bit.GPIO32 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPBSET.bit.GPIO32 = 1; // uncomment if --> Set High initially
// GPIO-33 - PIN FUNCTION = unused
GpioCtrlRegs.GPBMUX1.bit.GPIO33 = 0; // 0=GPIO, 1=I2CSCL-A, 2=SYNCO, 3=ADCSOCB
// GpioCtrlRegs.GPBDIR.bit.GPIO33 = 1; // 1=OUTput, 0=INput
// GpioDataRegs.GPBCLEAR.bit.GPIO33 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPBSET.bit.GPIO33 = 1; // uncomment if --> Set High initially
// GPIO-34 - PIN FUNCTION = LED3 on controlCARD
GpioCtrlRegs.GPBMUX1.bit.GPIO34 = 0; // 0=GPIO, 1=Resv, 2=Resv, 3=Resv
GpioCtrlRegs.GPBDIR.bit.GPIO34 = 1; // 1=OUTput, 0=INput
GpioDataRegs.GPBCLEAR.bit.GPIO34 = 1; // uncomment if --> Set Low initially
// GpioDataRegs.GPBSET.bit.GPIO34 = 1; // uncomment if --> Set High initially
// GPIO 35-38 are defaulted to JTAG usage, and are not shown here to enforce JTAG debug
// usage.
EDIS; // Disable register access
