TMS320F2808: Flash API Flash_APIVersionHex( )
Part Number: TMS320F2808
Using Code Composer 10.3, I am importing the Flash API into my code and it builds as expected. I ensure the library paths as part of this discussion - https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/1012666/launchxl-f280025c-flash-api/3742724#3742724.
I added the necessary F2808.cmd links:
   Flash28_API:
        -lFlash2808_API_V302.lib(.econst)
        -lFlash2808_API_V302.lib(.text)
   }                     LOAD = FLASHD,
                         RUN = RAML0,
                         LOAD_START(_Flash28_API_LoadStart),
                         LOAD_END(_Flash28_API_LoadEnd),
                         RUN_START(_Flash28_API_RunStart),
                         PAGE = 0
   ramfuncs            : LOAD = FLASHD,
                         RUN = RAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         PAGE = 0
As a test, I moved just the Flash_APIVersionHex( ) into my main function (after the MemCopy and the PLL setup etc.) to ensure it will work. When I run, I get jumped to an ILLEGAL_ISR() ESTOP.
I also get the following: Can't find a source file at "Flash28_Version_Hex.c"
Locate the file or edit the source lookup path to include its location.
When I step into the Flash_APIVersionHex( ) and show the disassembly, I see the following and as I single step the code, it enters the CopyData function:
        Flash2808_APIVersionHex():
00851b:   FE0C        ADDB         SP, #12
00851c:   767F51E3    LCR          0x3f51e3
100     {
        CopyData(), RamfuncsRunStart:
00851e:   FE0C        ADDB         SP, #12
115         CsmUnlock();
00851f:   767F51E8    LCR          CsmUnlock
Any obvious reason why I can't seem to get the Flash API hex version with this simple setup?
  • Hi Jeffrey,
    Our F2808 Flash expert will get back to you by mid-next week.
    Thanks and regards,
    Vamsi
  • Much appreciated. Looking forward to the help.
  • Jeffrey,
    Can you let me know how/what function you are using for the MemCopy function?  I think there is a default C prototype that I've seen others have issues with.  In our API examples we have a simple routine(and you might be using this already) that look like below:
    // Copy the Flash API functions to SARAM
        Example_MemCopy(&Flash28_API_LoadStart, &Flash28_API_LoadEnd, &Flash28_API_RunStart);
        // We must also copy required user interface functions to RAM.
        Example_MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart);
    void Example_MemCopy(Uint16 *SourceAddr, Uint16* SourceEndAddr, Uint16* DestAddr)
        while(SourceAddr < SourceEndAddr)
           *DestAddr++ = *SourceAddr++;
        return;
    The interesting thing about the last screen shot you have is that the ASM call into the APIVersionHex() is calling into a flash address vs what the linker should have made a SRAM address.
    You could also manually check that the API functions are in RAM immediately after the memcopy function call as well.
    I think the .c file error is due to the packaging of the contents in the .lib vs standalone files, but I need to look into this some more.
    Matthew
  • MemCopy definition:
    void MemCopy(Uint16 *SourceAddr, Uint16* SourceEndAddr, Uint16* DestAddr)
        return;
    I have included the map file to see if that can help you find the issue.
                 TMS320C2000 Linker PC v20.2.4
    >> Linked Fri Jan 21 08:41:01 2022
    OUTPUT FILE NAME:   <Example_2808_Flash.out>
    ENTRY POINT SYMBOL: "_c_int00"  address: 003f5c9c
    MEMORY CONFIGURATION
             name            origin    length      used     unused   attr    fill
    PAGE 0:
      RAML0                 00008000   00001000  000005fb  00000a05  RWIX
      OTP                   003d7800   00000400  00000000  00000400  RWIX
      FLASHD                003e8000   00004000  000005fb  00003a05  RWIX
      FLASHC                003ec000   00004000  00000000  00004000  RWIX
      FLASHB                003f0000   00004000  00000000  00004000  RWIX
      FLASHA                003f4000   00003f80  000020c8  00001eb8  RWIX
      CSM_RSVD              003f7f80   00000076  00000076  00000000  RWIX
      BEGIN                 003f7ff6   00000002  00000002  00000000  RWIX
      CSM_PWL               003f7ff8   00000008  00000008  00000000  RWIX
      ROM                   003ff000   00000fc0  00000000  00000fc0  RWIX
      RESET                 003fffc0   00000002  00000000  00000002  RWIX
      VECTORS               003fffc2   0000003e  00000000  0000003e  RWIX
    PAGE 1:
      RAMM0                 00000000   00000400  00000380  00000080  RWIX
      BOOT_RSVD             00000400   00000080  00000000  00000080  RWIX
      RAMM1                 00000480   00000380  00000000  00000380  RWIX
      DEV_EMU               00000880   00000180  000000d0  000000b0  RWIX
      FLASH_REGS            00000a80   00000060  00000008  00000058  RWIX
      CSM                   00000ae0   00000010  00000010  00000000  RWIX
      ADC_MIRROR            00000b00   00000010  00000010  00000000  RWIX
      CPU_TIMER0            00000c00   00000008  00000008  00000000  RWIX
      CPU_TIMER1            00000c08   00000008  00000008  00000000  RWIX
      CPU_TIMER2            00000c10   00000008  00000008  00000000  RWIX
      PIE_CTRL              00000ce0   00000020  0000001a  00000006  RWIX
      PIE_VECT              00000d00   00000100  00000100  00000000  RWIX
      ECANA                 00006000   00000040  00000034  0000000c  RWIX
      ECANA_LAM             00006040   00000040  00000040  00000000  RWIX
      ECANA_MOTS            00006080   00000040  00000040  00000000  RWIX
      ECANA_MOTO            000060c0   00000040  00000040  00000000  RWIX
      ECANA_MBOX            00006100   00000100  00000100  00000000  RWIX
      ECANB                 00006200   00000040  00000034  0000000c  RWIX
      ECANB_LAM             00006240   00000040  00000040  00000000  RWIX
      ECANB_MOTS            00006280   00000040  00000040  00000000  RWIX
      ECANB_MOTO            000062c0   00000040  00000040  00000000  RWIX
      ECANB_MBOX            00006300   00000100  00000100  00000000  RWIX
      EPWM1                 00006800   00000022  00000022  00000000  RWIX
      EPWM2                 00006840   00000022  00000022  00000000  RWIX
      EPWM3                 00006880   00000022  00000022  00000000  RWIX
      EPWM4                 000068c0   00000022  00000022  00000000  RWIX
      EPWM5                 00006900   00000022  00000022  00000000  RWIX
      EPWM6                 00006940   00000022  00000022  00000000  RWIX
      ECAP1                 00006a00   00000020  00000020  00000000  RWIX
      ECAP2                 00006a20   00000020  00000020  00000000  RWIX
      ECAP3                 00006a40   00000020  00000020  00000000  RWIX
      ECAP4                 00006a60   00000020  00000020  00000000  RWIX
      EQEP1                 00006b00   00000040  00000040  00000000  RWIX
      EQEP2                 00006b40   00000040  00000040  00000000  RWIX
      GPIOCTRL              00006f80   00000040  00000040  00000000  RWIX
      GPIODAT               00006fc0   00000020  00000020  00000000  RWIX
      GPIOINT               00006fe0   00000020  0000000a  00000016  RWIX
      SYSTEM                00007010   00000020  00000020  00000000  RWIX
      SPIA                  00007040   00000010  00000010  00000000  RWIX
      SCIA                  00007050   00000010  00000010  00000000  RWIX
      XINTRUPT              00007070   00000010  00000010  00000000  RWIX
      ADC                   00007100   00000020  0000001e  00000002  RWIX
      SPIB                  00007740   00000010  00000010  00000000  RWIX
      SCIB                  00007750   00000010  00000010  00000000  RWIX
      SPIC                  00007760   00000010  00000010  00000000  RWIX
      SPID                  00007780   00000010  00000010  00000000  RWIX
      I2CA                  00007900   00000040  00000022  0000001e  RWIX
      RAML1                 00009000   00001000  000007bc  00000844  RWIX
      RAMH0                 003fa000   00002000  00000000  00002000  RWIX
    SECTION ALLOCATION MAP
     output                                  attributes/
    section   page    origin      length       input sections
    Flash28_API
    *          0    003e8000    0000051e     RUN ADDR = 00008000
                      003e8000    00000014     Flash2808_API_V302.lib : Flash28_Erase.obj (.econst)
                      003e8014    000000a9                            : Flash28_Prog.obj (.text)
                      003e80bd    000000a2                            : Flash28_Erase.obj (.text)
                      003e815f    0000009a                            : Flash28_Erase_Pulse.obj (.text)
                      003e81f9    00000084                            : Flash28_Internals.obj (.text)
                      003e827d    0000007f                            : Flash28_Prog_Pulse.obj (.text)
                      003e82fc    0000007d                            : Flash28_Compact_Pulse.obj (.text)
                      003e8379    0000005b                            : Flash28_EraseSector.obj (.text)
                      003e83d4    00000054                            : Flash28_CompactSector.obj (.text)
                      003e8428    00000041                            : Flash28_ClearLoop.obj (.text)
                      003e8469    00000033                            : Flash28_ClearSector.obj (.text)
                      003e849c    00000033                            : Flash28_Verify.obj (.text)
                      003e84cf    00000024                            : Flash28_Init.obj (.text)
                      003e84f3    00000014                            : Flash28_Utils.obj (.text)
                      003e8507    0000000d                            : Flash28_Delay.obj (.text)
                      003e8514    00000007                            : Flash28_DisInt.obj (.text)
                      003e851b    00000003                            : Flash28_Version_Hex.obj (.text)
    ramfuncs   0    003e851e    000000dd     RUN ADDR = 0000851e
                      003e851e    000000be     Shared_Boot.obj (ramfuncs)
                      003e85dc    0000001b     DSP280x_SysCtrl.obj (ramfuncs)
                      003e85f7    00000004     DSP280x_usDelay.obj (ramfuncs)
    .cinit     0    003f6092    00000036
                      003f6092    0000000e     rts2800_ml.lib : exit.c.obj (.cinit)
                      003f60a0    0000000a     DSP280x_Adc.obj (.cinit)
                      003f60aa    0000000a     Flash2808_API_V302.lib : Flash28_Globals.obj (.cinit)
                      003f60b4    00000005     rts2800_ml.lib : _lock.c.obj (.cinit:__lock)
                      003f60b9    00000005                    : _lock.c.obj (.cinit:__unlock)
                      003f60be    00000004     DSP280x_ECan.obj (.cinit)
                      003f60c2    00000004     Example_280xFlash_Main.obj (.cinit)
                      003f60c6    00000002     --HOLE-- [fill = 0]
    csm_rsvd   0    003f7f80    00000076
                      003f7f80    00000076     DSP280x_CSMPasswords.obj (csm_rsvd)
    DevEmuRegsFile
    *          1    00000880    000000d0     UNINITIALIZED
                      00000880    000000d0     DSP280x_GlobalVariableDefs.obj (DevEmuRegsFile)
    FlashRegsFile
    *          1    00000a80    00000008     UNINITIALIZED
                      00000a80    00000008     DSP280x_GlobalVariableDefs.obj (FlashRegsFile)
    CsmRegsFile
    *          1    00000ae0    00000010     UNINITIALIZED
                      00000ae0    00000010     DSP280x_GlobalVariableDefs.obj (CsmRegsFile)
    AdcMirrorFile
    *          1    00000b00    00000010     UNINITIALIZED
                      00000b00    00000010     DSP280x_GlobalVariableDefs.obj (AdcMirrorFile)
    CpuTimer0RegsFile
    *          1    00000c00    00000008     UNINITIALIZED
                      00000c00    00000008     DSP280x_GlobalVariableDefs.obj (CpuTimer0RegsFile)
    CpuTimer1RegsFile
    *          1    00000c08    00000008     UNINITIALIZED
                      00000c08    00000008     DSP280x_GlobalVariableDefs.obj (CpuTimer1RegsFile)
    CpuTimer2RegsFile
    *          1    00000c10    00000008     UNINITIALIZED
                      00000c10    00000008     DSP280x_GlobalVariableDefs.obj (CpuTimer2RegsFile)
    PieCtrlRegsFile
    *          1    00000ce0    0000001a     UNINITIALIZED
                      00000ce0    0000001a     DSP280x_GlobalVariableDefs.obj (PieCtrlRegsFile)
    PieVectTableFile
    *          1    00000d00    00000100     UNINITIALIZED
                      00000d00    00000100     DSP280x_GlobalVariableDefs.obj (PieVectTableFile)
    ECanaRegsFile
    *          1    00006000    00000034     UNINITIALIZED
                      00006000    00000034     DSP280x_GlobalVariableDefs.obj (ECanaRegsFile)
    ECanaLAMRegsFile
    *          1    00006040    00000040     UNINITIALIZED
                      00006040    00000040     DSP280x_GlobalVariableDefs.obj (ECanaLAMRegsFile)
    ECanaMOTSRegsFile
    *          1    00006080    00000040     UNINITIALIZED
                      00006080    00000040     DSP280x_GlobalVariableDefs.obj (ECanaMOTSRegsFile)
    ECanaMOTORegsFile
    *          1    000060c0    00000040     UNINITIALIZED
                      000060c0    00000040     DSP280x_GlobalVariableDefs.obj (ECanaMOTORegsFile)
    ECanaMboxesFile
    *          1    00006100    00000100     UNINITIALIZED
                      00006100    00000100     DSP280x_GlobalVariableDefs.obj (ECanaMboxesFile)
    ECanbRegsFile
    *          1    00006200    00000034     UNINITIALIZED
                      00006200    00000034     DSP280x_GlobalVariableDefs.obj (ECanbRegsFile)
    ECanbLAMRegsFile
    *          1    00006240    00000040     UNINITIALIZED
                      00006240    00000040     DSP280x_GlobalVariableDefs.obj (ECanbLAMRegsFile)
    ECanbMOTSRegsFile
    *          1    00006280    00000040     UNINITIALIZED
                      00006280    00000040     DSP280x_GlobalVariableDefs.obj (ECanbMOTSRegsFile)
    ECanbMOTORegsFile
    *          1    000062c0    00000040     UNINITIALIZED
                      000062c0    00000040     DSP280x_GlobalVariableDefs.obj (ECanbMOTORegsFile)
    ECanbMboxesFile
    *          1    00006300    00000100     UNINITIALIZED
                      00006300    00000100     DSP280x_GlobalVariableDefs.obj (ECanbMboxesFile)
    EPwm1RegsFile
    *          1    00006800    00000022     UNINITIALIZED
                      00006800    00000022     DSP280x_GlobalVariableDefs.obj (EPwm1RegsFile)
    EPwm2RegsFile
    *          1    00006840    00000022     UNINITIALIZED
                      00006840    00000022     DSP280x_GlobalVariableDefs.obj (EPwm2RegsFile)
    EPwm3RegsFile
    *          1    00006880    00000022     UNINITIALIZED
                      00006880    00000022     DSP280x_GlobalVariableDefs.obj (EPwm3RegsFile)
    EPwm4RegsFile
    *          1    000068c0    00000022     UNINITIALIZED
                      000068c0    00000022     DSP280x_GlobalVariableDefs.obj (EPwm4RegsFile)
    EPwm5RegsFile
    *          1    00006900    00000022     UNINITIALIZED
                      00006900    00000022     DSP280x_GlobalVariableDefs.obj (EPwm5RegsFile)
    EPwm6RegsFile
    *          1    00006940    00000022     UNINITIALIZED
                      00006940    00000022     DSP280x_GlobalVariableDefs.obj (EPwm6RegsFile)
    ECap1RegsFile
    *          1    00006a00    00000020     UNINITIALIZED
                      00006a00    00000020     DSP280x_GlobalVariableDefs.obj (ECap1RegsFile)
    ECap2RegsFile
    *          1    00006a20    00000020     UNINITIALIZED
                      00006a20    00000020     DSP280x_GlobalVariableDefs.obj (ECap2RegsFile)
    ECap3RegsFile
    *          1    00006a40    00000020     UNINITIALIZED
                      00006a40    00000020     DSP280x_GlobalVariableDefs.obj (ECap3RegsFile)
    ECap4RegsFile
    *          1    00006a60    00000020     UNINITIALIZED
                      00006a60    00000020     DSP280x_GlobalVariableDefs.obj (ECap4RegsFile)
    EQep1RegsFile
    *          1    00006b00    00000040     UNINITIALIZED
                      00006b00    00000040     DSP280x_GlobalVariableDefs.obj (EQep1RegsFile)
    EQep2RegsFile
    *          1    00006b40    00000040     UNINITIALIZED
                      00006b40    00000040     DSP280x_GlobalVariableDefs.obj (EQep2RegsFile)
    GpioCtrlRegsFile
    *          1    00006f80    00000040     UNINITIALIZED
                      00006f80    00000040     DSP280x_GlobalVariableDefs.obj (GpioCtrlRegsFile)
    GpioDataRegsFile
    *          1    00006fc0    00000020     UNINITIALIZED
                      00006fc0    00000020     DSP280x_GlobalVariableDefs.obj (GpioDataRegsFile)
    GpioIntRegsFile
    *          1    00006fe0    0000000a     UNINITIALIZED
                      00006fe0    0000000a     DSP280x_GlobalVariableDefs.obj (GpioIntRegsFile)
    SysCtrlRegsFile
    *          1    00007010    00000020     UNINITIALIZED
                      00007010    00000020     DSP280x_GlobalVariableDefs.obj (SysCtrlRegsFile)
    SpiaRegsFile
    *          1    00007040    00000010     UNINITIALIZED
                      00007040    00000010     DSP280x_GlobalVariableDefs.obj (SpiaRegsFile)
    SciaRegsFile
    *          1    00007050    00000010     UNINITIALIZED
                      00007050    00000010     DSP280x_GlobalVariableDefs.obj (SciaRegsFile)
    XIntruptRegsFile
    *          1    00007070    00000010     UNINITIALIZED
                      00007070    00000010     DSP280x_GlobalVariableDefs.obj (XIntruptRegsFile)
    AdcRegsFile
    *          1    00007100    0000001e     UNINITIALIZED
                      00007100    0000001e     DSP280x_GlobalVariableDefs.obj (AdcRegsFile)
    SpibRegsFile
    *          1    00007740    00000010     UNINITIALIZED
                      00007740    00000010     DSP280x_GlobalVariableDefs.obj (SpibRegsFile)
    ScibRegsFile
    *          1    00007750    00000010     UNINITIALIZED
                      00007750    00000010     DSP280x_GlobalVariableDefs.obj (ScibRegsFile)
    SpicRegsFile
    *          1    00007760    00000010     UNINITIALIZED
                      00007760    00000010     DSP280x_GlobalVariableDefs.obj (SpicRegsFile)
    SpidRegsFile
    *          1    00007780    00000010     UNINITIALIZED
                      00007780    00000010     DSP280x_GlobalVariableDefs.obj (SpidRegsFile)
    I2caRegsFile
    *          1    00007900    00000022     UNINITIALIZED
                      00007900    00000022     DSP280x_GlobalVariableDefs.obj (I2caRegsFile)
    CsmPwlFile
    *          1    003f7ff8    00000008     UNINITIALIZED
                      003f7ff8    00000008     DSP280x_GlobalVariableDefs.obj (CsmPwlFile)
    .pinit     0    003f4000    00000000     UNINITIALIZED
    .text      0    003f4000    00001f8c
                      003f4000    000007a3     MAX6639.obj (.text)
                      003f47a3    00000460     DSP280x_ECan.obj (.text)
                      003f4c03    00000423     DSP280x_ECan.obj (.text:retain)
                      003f5026    0000035b     DSP280x_I2C.obj (.text)
                      003f5381    0000026c     DSP280x_Spi.obj (.text)
                      003f55ed    000001b0     Example_280xFlash_Main.obj (.text)
                      003f579d    00000145     DSP280x_DefaultIsr.obj (.text:retain)
                      003f58e2    000000c5     DSP280x_SysCtrl.obj (.text)
                      003f59a7    000000be     DSP280x_I2C.obj (.text:retain)
                      003f5a65    00000087     DSP280x_CpuTimers.obj (.text)
                      003f5aec    00000078     rts2800_ml.lib : fs_add28.asm.obj (.text)
                      003f5b64    00000075     DSP280x_Adc.obj (.text:retain)
                      003f5bd9    00000069     rts2800_ml.lib : s_ceilf.c.obj (.text)
                      003f5c42    0000005a                    : fs_mpy28.asm.obj (.text)
                      003f5c9c    00000054                    : boot28.asm.obj (.text)
                      003f5cf0    00000044     Can_Boot.obj (.text)
                      003f5d34    00000038     DSP280x_Gpio.obj (.text)
                      003f5d6c    00000031     DSP280x_Adc.obj (.text)
                      003f5d9d    0000002a     DSP280x_CpuTimers.obj (.text:retain)
                      003f5dc7    0000002a     rts2800_ml.lib : l_div28.asm.obj (.text)
                      003f5df1    00000029                    : exit.c.obj (.text)
                      003f5e1a    00000029                    : fs_tol28.asm.obj (.text)
                      003f5e43    00000028     DSP280x_PieCtrl.obj (.text)
                      003f5e6b    00000025     rts2800_ml.lib : fs_toi28.asm.obj (.text)
                      003f5e90    00000024                    : cpy_tbl.c.obj (.text)
                      003f5eb4    00000022     Shared_Boot.obj (.text)
                      003f5ed6    00000020     DSP280x_PieVect.obj (.text)
                      003f5ef6    0000001d     rts2800_ml.lib : memcpy.c.obj (.text)
                      003f5f13    0000001a                    : i_tofs28.asm.obj (.text)
                      003f5f2d    00000017                    : fs_cmp28.asm.obj (.text)
                      003f5f44    00000013     DSP280x_MemCopy.obj (.text)
                      003f5f57    00000011     rts2800_ml.lib : args_main.c.obj (.text)
                      003f5f68    00000010                    : u_tofs28.asm.obj (.text)
                      003f5f78    00000009                    : _lock.c.obj (.text)
                      003f5f81    00000008     DSP280x_CodeStartBranch.obj (.text)
                      003f5f89    00000002     rts2800_ml.lib : pre_init.c.obj (.text)
                      003f5f8b    00000001                    : startup.c.obj (.text)
    codestart
    *          0    003f7ff6    00000002
                      003f7ff6    00000002     DSP280x_CodeStartBranch.obj (codestart)
    csmpasswds
    *          0    003f7ff8    00000008
                      003f7ff8    00000008     DSP280x_CSMPasswords.obj (csmpasswds)
    .stack     1    00000000    00000380     UNINITIALIZED
                      00000000    00000380     --HOLE--
    .ebss      1    00009000    000007bc     UNINITIALIZED
                      00009000    00000400     Shared_Boot.obj (.ebss:_progBuf)
                      00009400    00000225     DSP280x_I2C.obj (.ebss)
                      00009625    00000001     --HOLE--
                      00009626    00000018     DSP280x_CpuTimers.obj (.ebss)
                      0000963e    00000002     MAX6639.obj (.ebss:_SensorCorrection)
                      00009640    000000b4     DSP280x_ECan.obj (.ebss)
                      000096f4    0000000a     Shared_Boot.obj (.ebss)
                      000096fe    00000002     rts2800_ml.lib : _lock.c.obj (.ebss:__lock)
                      00009700    00000040     DSP280x_I2C.obj (.ebss:_RxMsgBuffer)
                      00009740    00000040     DSP280x_I2C.obj (.ebss:_TxMsgBuffer)
                      00009780    00000016     MAX6639.obj (.ebss)
                      00009796    00000011     Example_280xFlash_Main.obj (.ebss)
                      000097a7    00000001     --HOLE--
                      000097a8    00000006     rts2800_ml.lib : exit.c.obj (.ebss)
                      000097ae    00000004     DSP280x_Adc.obj (.ebss)
                      000097b2    00000004     DSP280x_Spi.obj (.ebss)
                      000097b6    00000004     Flash2808_API_V302.lib : Flash28_Globals.obj (.ebss)
                      000097ba    00000002     rts2800_ml.lib : _lock.c.obj (.ebss:__unlock)
    .econst    0    003f5f8c    00000106
                      003f5f8c    00000100     DSP280x_PieVect.obj (.econst:_PieVectTableInit)
                      003f608c    00000004     MAX6639.obj (.econst:_rpm_ranges)
                      003f6090    00000002     rts2800_ml.lib : s_ceilf.c.obj (.econst)
    .reset     0    003fffc0    00000002     DSECT
                      003fffc0    00000002     rts2800_ml.lib : boot28.asm.obj (.reset)
    vectors    0    003fffc2    00000000     DSECT
    MODULE SUMMARY
           Module                           code    initialized data   uninitialized data
           DSP280x_ECan.obj                 2179    4                  180
           DSP280x_GlobalVariableDefs.obj   0       0                  2336
           MAX6639.obj                      1955    4                  24
           DSP280x_I2C.obj                  1049    0                  677
           Shared_Boot.obj                  414     0                  1034
           DSP280x_Spi.obj                  620     0                  4
           Example_280xFlash_Main.obj       432     4                  17
           DSP280x_DefaultIsr.obj           325     0                  0
           DSP280x_PieVect.obj              32      256                0
           DSP280x_SysCtrl.obj              251     0                  0
           DSP280x_CpuTimers.obj            177     0                  24
           DSP280x_Adc.obj                  166     10                 4
           DSP280x_CSMPasswords.obj         0       126                0
           Can_Boot.obj                     68      0                  0
           DSP280x_Gpio.obj                 56      0                  0
           DSP280x_PieCtrl.obj              40      0                  0
           DSP280x_MemCopy.obj              19      0                  0
           DSP280x_CodeStartBranch.obj      10      0                  0
           DSP280x_usDelay.obj              8       0                  0
           Total:                           7801    404                4300
        C:/ti/ccs1031/ccs/tools/compiler/ti-cgt-c2000_20.2.4.LTS/lib/rts2800_ml.lib
           fs_add28.asm.obj                 120     0                  0
           s_ceilf.c.obj                    105     2                  0
           fs_mpy28.asm.obj                 90      0                  0
           boot28.asm.obj                   84      0                  0
           exit.c.obj                       41      14                 6
           l_div28.asm.obj                  42      0                  0
           fs_tol28.asm.obj                 41      0                  0
           fs_toi28.asm.obj                 37      0                  0
           cpy_tbl.c.obj                    36      0                  0
           memcpy.c.obj                     29      0                  0
           i_tofs28.asm.obj                 26      0                  0
           _lock.c.obj                      9       10                 4
           fs_cmp28.asm.obj                 23      0                  0
           args_main.c.obj                  17      0                  0
           u_tofs28.asm.obj                 16      0                  0
           pre_init.c.obj                   2       0                  0
           startup.c.obj                    1       0                  0
           Total:                           719     26                 10
        C:/tidcs/c28/Flash28_API/Flash2808_API_V302/lib/Flash2808_API_V302.lib
           Flash28_Erase.obj                324     40                 0
           Flash28_Prog.obj                 338     0                  0
           Flash28_Erase_Pulse.obj          308     0                  0
           Flash28_Internals.obj            264     0                  0
           Flash28_Prog_Pulse.obj           254     0                  0
           Flash28_Compact_Pulse.obj        250     0                  0
           Flash28_EraseSector.obj          182     0                  0
           Flash28_CompactSector.obj        168     0                  0
           Flash28_ClearLoop.obj            130     0                  0
           Flash28_ClearSector.obj          102     0                  0
           Flash28_Verify.obj               102     0                  0
           Flash28_Init.obj                 72      0                  0
           Flash28_Utils.obj                40      0                  0
           Flash28_Delay.obj                26      0                  0
           Flash28_DisInt.obj               14      0                  0
           Flash28_Globals.obj              0       10                 4
           Flash28_Version_Hex.obj          6       0                  0
           Total:                           2580    50                 4
           Stack:                           0       0                  896
           Grand Total:                     11100   480                5210
    GLOBAL DATA SYMBOLS: SORTED BY DATA PAGE
    address     data page           name
    00000000       0 (00000000)     __stack
    00000880      22 (00000880)     _DevEmuRegs
    00000a80      2a (00000a80)     _FlashRegs
    00000ae0      2b (00000ac0)     _CsmRegs
    00000b00      2c (00000b00)     _AdcMirror
    00000c00      30 (00000c00)     _CpuTimer0Regs
    00000c08      30 (00000c00)     _CpuTimer1Regs
    00000c10      30 (00000c00)     _CpuTimer2Regs
    00000ce0      33 (00000cc0)     _PieCtrlRegs
    00000d00      34 (00000d00)     _PieVectTable
    00006000     180 (00006000)     _ECanaRegs
    00006040     181 (00006040)     _ECanaLAMRegs
    00006080     182 (00006080)     _ECanaMOTSRegs
    000060c0     183 (000060c0)     _ECanaMOTORegs
    00006100     184 (00006100)     _ECanaMboxes
    00006200     188 (00006200)     _ECanbRegs
    00006240     189 (00006240)     _ECanbLAMRegs
    00006280     18a (00006280)     _ECanbMOTSRegs
    000062c0     18b (000062c0)     _ECanbMOTORegs
    00006300     18c (00006300)     _ECanbMboxes
    00006800     1a0 (00006800)     _EPwm1Regs
    00006840     1a1 (00006840)     _EPwm2Regs
    00006880     1a2 (00006880)     _EPwm3Regs
    000068c0     1a3 (000068c0)     _EPwm4Regs
    00006900     1a4 (00006900)     _EPwm5Regs
    00006940     1a5 (00006940)     _EPwm6Regs
    00006a00     1a8 (00006a00)     _ECap1Regs
    00006a20     1a8 (00006a00)     _ECap2Regs
    00006a40     1a9 (00006a40)     _ECap3Regs
    00006a60     1a9 (00006a40)     _ECap4Regs
    00006b00     1ac (00006b00)     _EQep1Regs
    00006b40     1ad (00006b40)     _EQep2Regs
    00006f80     1be (00006f80)     _GpioCtrlRegs
    00006fc0     1bf (00006fc0)     _GpioDataRegs
    00006fe0     1bf (00006fc0)     _GpioIntRegs
    00007010     1c0 (00007000)     _SysCtrlRegs
    00007040     1c1 (00007040)     _SpiaRegs
    00007050     1c1 (00007040)     _SciaRegs
    00007070     1c1 (00007040)     _XIntruptRegs
    00007100     1c4 (00007100)     _AdcRegs
    00007740     1dd (00007740)     _SpibRegs
    00007750     1dd (00007740)     _ScibRegs
    00007760     1dd (00007740)     _SpicRegs
    00007780     1de (00007780)     _SpidRegs
    00007900     1e4 (00007900)     _I2caRegs
    00008014     200 (00008000)     _Flash2808_Program
    000080bd     202 (00008080)     _Flash2808_Erase
    0000815f     205 (00008140)     _Fl28x_EraseVerify
    000081a7     206 (00008180)     _Fl28x_ErasePulse
    000081f9     207 (000081c0)     _Fl28x_LeaveCmdMode
    00008206     208 (00008200)     _Fl28x_EnterCmdMode
    0000822b     208 (00008200)     _Fl28x_FlashRegSleep
    0000824a     209 (00008240)     _Fl28x_OpenPulse
    0000825b     209 (00008240)     _Fl28x_ClosePulse
    00008272     209 (00008240)     _Fl28x_MaskAll
    0000827d     209 (00008240)     _Fl28x_ProgVerify
    000082ba     20a (00008280)     _Fl28x_ProgPulse
    000082fc     20b (000082c0)     _Fl28x_CompactVerify
    00008336     20c (00008300)     _Fl28x_CompactPulse
    00008379     20d (00008340)     _Fl2808_EraseSector
    000083d4     20f (000083c0)     _Fl2808_CompactSector
    00008428     210 (00008400)     _Fl28x_ClearLoop
    00008469     211 (00008440)     _Fl2808_ClearSector
    0000849c     212 (00008480)     _Flash2808_Verify
    000084cf     213 (000084c0)     _Fl2808_Init
    000084f3     213 (000084c0)     _Fl28x_WatchDogDisable
    000084fb     213 (000084c0)     _Fl28x_DisableNMI
    00008507     214 (00008500)     _Fl28x_Delay
    00008514     214 (00008500)     _Fl28x_DisableInt
    00008518     214 (00008500)     _Fl28x_RestoreInt
    0000851b     214 (00008500)     _Flash2808_APIVersionHex
    00009000     240 (00009000)     _progBuf
    00009400     250 (00009400)     _timeoutCheck
    00009401     250 (00009400)     _numofBytes
    00009402     250 (00009400)     _numof16Bytes
    00009403     250 (00009400)     _remainingBytes
    00009404     250 (00009400)     _currentResponderPtr
    00009406     250 (00009400)     _UcValues
    0000940a     250 (00009400)     _ADT7410Regs
    0000940e     250 (00009400)     _PaValues
    00009414     250 (00009400)     _I2cHdl_EEPROM
    0000941e     250 (00009400)     _I2cHdl_TempSensor
    00009440     251 (00009440)     _PaEepromData
    00009626     258 (00009600)     _CpuTimer0
    0000962e     258 (00009600)     _CpuTimer1
    00009636     258 (00009600)     _CpuTimer2
    0000963e     258 (00009600)     _SensorCorrection
    00009640     259 (00009640)     _NumCANWrites
    00009641     259 (00009640)     _Cdh_AdcDc
    00009643     259 (00009640)     _Cdh_AdcUc
    00009645     259 (00009640)     _Cdh_AdcPa
    00009647     259 (00009640)     _Cdh_TempSensor
    00009649     259 (00009640)     _Cdh_Bit
    0000964b     259 (00009640)     _Cdh_FanStatus
    0000964d     259 (00009640)     _Cdh_FanTach
    00009650     259 (00009640)     _CanGetTemp
    00009658     259 (00009640)     _CanGetFanSt
    00009660     259 (00009640)     _CanGetFanTach
    00009668     259 (00009640)     _CanGetDcrf
    00009670     259 (00009640)     _CanGetBit
    00009678     259 (00009640)     _CanF2808Task
    00009680     25a (00009680)     _CanGetUcrf
    00009688     25a (00009680)     _CanGetParf
    000096c0     25b (000096c0)     _ECanRegsShadow
    000096f4     25b (000096c0)     _GetOnlyWordData
    000096f6     25b (000096c0)     _FlashStatus
    000096fa     25b (000096c0)     _VerifyStatus
    000096fe     25b (000096c0)     __lock
    00009700     25c (00009700)     _RxMsgBuffer
    00009740     25d (00009740)     _TxMsgBuffer
    00009780     25e (00009780)     _returnme
    00009786     25e (00009780)     _temprtnme
    0000978c     25e (00009780)     _I2cHndl_FanControl
    0000979a     25e (00009780)     _Master_TaskPtr
    0000979c     25e (00009780)     _Timer0_TaskPtr
    0000979e     25e (00009780)     _Timer1_TaskPtr
    000097a0     25e (00009780)     _ECRxData
    000097a8     25e (00009780)     ___TI_enable_exit_profile_output
    000097aa     25e (00009780)     ___TI_cleanup_ptr
    000097ac     25e (00009780)     ___TI_dtors_ptr
    000097ae     25e (00009780)     _AdcInterruptCount
    000097b0     25e (00009780)     _PrevAdcInterruptCount
    000097b2     25e (00009780)     _ACCELEROMETER_STATE
    000097b4     25e (00009780)     _tmc262_rdrspms
    000097b6     25e (00009780)     _Flash_CallbackPtr
    000097b8     25e (00009780)     _Flash_CPUScaleFactor
    000097ba     25e (00009780)     __unlock
    003f5f8c    fd7e (003f5f80)     _PieVectTableInit
    003f7ff8    fdff (003f7fc0)     _CsmPwl
    GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name
    page  address   name
    0     003f4000  .text
    0     003f5df1  C$$EXIT
    0     003f5af1  FS$$ADD
    0     003f5f2d  FS$$CMP
    0     003f5c42  FS$$MPY
    0     003f5aec  FS$$SUB
    0     003f5e6b  FS$$TOI
    0     003f5e1a  FS$$TOL
    0     003f5f13  I$$TOFS
    0     003f5dc7  L$$DIV
    0     003f5dd6  L$$MOD
    0     003f5f68  U$$TOFS
    0     003f5de4  UL$$DIV
    0     003f5deb  UL$$MOD
    1     000097b2  _ACCELEROMETER_STATE
    0     003f5810  _ADCINT_ISR
    1     0000940a  _ADT7410Regs
    1     000097ae  _AdcInterruptCount
    1     00000b00  _AdcMirror
    1     00007100  _AdcRegs
    0     003f5b64  _Adc_IntIsr
    0     003f5239  _Adt7410_Init
    0     003f5263  _Adt7410_ReadReg
    0     003f4bbb  _CANGIF_Flags_OK
    0     003f5cf0  _CAN_FlashBoot
    0     003f5eb4  _CAN_FlashGetLongData
    0     003f5d1a  _CAN_FlashGetWordData
    0     003f492a  _CAN_GetWordData
    0     003f4b3b  _CAN_SendCmdMsg
    0     003f4bd6  _CAN_WaitandClearTA
    1     00009678  _CanF2808Task
    1     00009670  _CanGetBit
    1     00009668  _CanGetDcrf
    1     00009658  _CanGetFanSt
    1     00009660  _CanGetFanTach
    1     00009688  _CanGetParf
    1     00009650  _CanGetTemp
    1     00009680  _CanGetUcrf
    1     00009641  _Cdh_AdcDc
    1     00009645  _Cdh_AdcPa
    1     00009643  _Cdh_AdcUc
    1     00009649  _Cdh_Bit
    1     0000964b  _Cdh_FanStatus
    1     0000964d  _Cdh_FanTach
    1     00009647  _Cdh_TempSensor
    0     003f5abb  _ConfigCpuTimer
    0     0000851e  _CopyData
    1     00009626  _CpuTimer0
    1     00000c00  _CpuTimer0Regs
    1     0000962e  _CpuTimer1
    1     00000c08  _CpuTimer1Regs
    1     00009636  _CpuTimer2
    1     00000c10  _CpuTimer2Regs
    0     003f5d9d  _Cpu_Timer0_IntIsr
    0     003f5dab  _Cpu_Timer1_IntIsr
    0     003f5db9  _Cpu_Timer2_IntIsr
    1     003f7ff8  _CsmPwl
    1     00000ae0  _CsmRegs
    0     003f5976  _CsmUnlock
    0     003f57a7  _DATALOG_ISR
    0     000085f7  _DSP28x_usDelay
    1     00000880  _DevEmuRegs
    0     003f58fd  _DisableDog
    0     003f58bf  _ECAN0INTA_ISR
    0     003f58c9  _ECAN0INTB_ISR
    0     003f58c4  _ECAN1INTA_ISR
    0     003f58ce  _ECAN1INTB_ISR
    0     003f585b  _ECAP1_INT_ISR
    0     003f5860  _ECAP2_INT_ISR
    0     003f5865  _ECAP3_INT_ISR
    0     003f586a  _ECAP4_INT_ISR
    1     000097a0  _ECRxData
    0     003f4c03  _ECan0_IntIsr
    1     000096c0  _ECanRegsShadow
    1     00006040  _ECanaLAMRegs
    1     000060c0  _ECanaMOTORegs
    1     00006080  _ECanaMOTSRegs
    1     00006100  _ECanaMboxes
    1     00006000  _ECanaRegs
    1     00006240  _ECanbLAMRegs
    1     000062c0  _ECanbMOTORegs
    1     00006280  _ECanbMOTSRegs
    1     00006300  _ECanbMboxes
    1     00006200  _ECanbRegs
    1     00006a00  _ECap1Regs
    1     00006a20  _ECap2Regs
    1     00006a40  _ECap3Regs
    1     00006a60  _ECap4Regs
    0     003f58d3  _EMPTY_ISR
    0     003f57b1  _EMUINT_ISR
    0     003f583d  _EPWM1_INT_ISR
    0     003f581f  _EPWM1_TZINT_ISR
    0     003f5842  _EPWM2_INT_ISR
    0     003f5824  _EPWM2_TZINT_ISR
    0     003f5847  _EPWM3_INT_ISR
    0     003f5829  _EPWM3_TZINT_ISR
    0     003f584c  _EPWM4_INT_ISR
    0     003f582e  _EPWM4_TZINT_ISR
    0     003f5851  _EPWM5_INT_ISR
    0     003f5833  _EPWM5_TZINT_ISR
    0     003f5856  _EPWM6_INT_ISR
    0     003f5838  _EPWM6_TZINT_ISR
    1     00006800  _EPwm1Regs
    1     00006840  _EPwm2Regs
    1     00006880  _EPwm3Regs
    1     000068c0  _EPwm4Regs
    1     00006900  _EPwm5Regs
    1     00006940  _EPwm6Regs
    0     003f586f  _EQEP1_INT_ISR
    0     003f5874  _EQEP2_INT_ISR
    1     00006b00  _EQep1Regs
    1     00006b40  _EQep2Regs
    0     003f58f5  _EnableDog
    0     003f5e62  _EnableInterrupts
    0     00008469  _Fl2808_ClearSector
    0     000083d4  _Fl2808_CompactSector
    0     00008379  _Fl2808_EraseSector
    0     000084cf  _Fl2808_Init
    0     00008428  _Fl28x_ClearLoop
    0     0000825b  _Fl28x_ClosePulse
    0     00008336  _Fl28x_CompactPulse
    0     000082fc  _Fl28x_CompactVerify
    0     00008507  _Fl28x_Delay
    0     00008514  _Fl28x_DisableInt
    0     000084fb  _Fl28x_DisableNMI
    0     00008206  _Fl28x_EnterCmdMode
    0     000081a7  _Fl28x_ErasePulse
    0     0000815f  _Fl28x_EraseVerify
    0     0000822b  _Fl28x_FlashRegSleep
    0     000081f9  _Fl28x_LeaveCmdMode
    0     00008272  _Fl28x_MaskAll
    0     0000824a  _Fl28x_OpenPulse
    0     000082ba  _Fl28x_ProgPulse
    0     0000827d  _Fl28x_ProgVerify
    0     00008518  _Fl28x_RestoreInt
    0     000084f3  _Fl28x_WatchDogDisable
    0     0000851b  _Flash2808_APIVersionHex
    0     000080bd  _Flash2808_Erase
    0     00008014  _Flash2808_Program
    0     0000849c  _Flash2808_Verify
    0     003e851e  _Flash28_API_LoadEnd
    0     003e8000  _Flash28_API_LoadStart
    0     00008000  _Flash28_API_RunStart
    1     00000a80  _FlashRegs
    1     000096f6  _FlashStatus
    1     000097b8  _Flash_CPUScaleFactor
    1     000097b6  _Flash_CallbackPtr
    1     000096f4  _GetOnlyWordData
    1     00006f80  _GpioCtrlRegs
    1     00006fc0  _GpioDataRegs
    1     00006fe0  _GpioIntRegs
    0     003f5486  _Hmc8073_Init
    0     003f548d  _Hmc8073_Set_Attenuator
    0     003f58a1  _I2CINT1A_ISR
    0     003f58a6  _I2CINT2A_ISR
    0     003f50c7  _I2C_MasterRead
    0     003f507f  _I2C_MasterWrite
    0     003f51d7  _I2C_Read
    0     003f5048  _I2C_TxSlaveAddress_ControlBytes
    0     003f5172  _I2C_Write
    1     00009414  _I2cHdl_EEPROM
    1     0000941e  _I2cHdl_TempSensor
    1     0000978c  _I2cHndl_FanControl
    0     003f59d0  _I2c_Fifo_IntIsr
    0     003f59a7  _I2c_IntIsr
    1     00007900  _I2caRegs
    0     003f57bb  _ILLEGAL_ISR
    0     003f579d  _INT13_ISR
    0     003f57a2  _INT14_ISR
    0     003f5d34  _Init58113ResetGpio
    0     003f5d52  _InitAccelIntGpio
    0     003f5d6c  _InitAdc
    0     003f5a65  _InitCpuTimers
    0     003f56c0  _InitDevices
    0     003f47a3  _InitECan
    0     003f490c  _InitECanaGpio
    0     000085dc  _InitFlash
    0     003f5026  _InitI2C
    0     003f5032  _InitI2CGpio
    0     003f593a  _InitPeripheralClocks
    0     003f56b5  _InitPeripheralGPIO
    0     003f5672  _InitPeripherals
    0     003f5e43  _InitPieCtrl
    0     003f5643  _InitPieCtrlInts
    0     003f5ed6  _InitPieVectTable
    0     003f565a  _InitPieVectorTable
    0     003f5905  _InitPll
    0     003f5381  _InitSpi
    0     003f5460  _InitSpiFifo
    0     003f53c1  _InitSpiGpio
    0     003f53ca  _InitSpiaGpio
    0     003f53f0  _InitSpibGpio
    0     003f540e  _InitSpicGpio
    0     003f5438  _InitSpidGpio
    0     003f58e2  _InitSysCtrl
    1     0000979a  _Master_TaskPtr
    0     003f40ee  _Max6639_GetAlertLimit
    0     003f4086  _Max6639_GetConfig
    0     003f432c  _Max6639_GetDevID
    0     003f435c  _Max6639_GetDevRev
    0     003f40ab  _Max6639_GetDiodeFault
    0     003f40c7  _Max6639_GetExtTemp
    0     003f417b  _Max6639_GetFanConfig
    0     003f4295  _Max6639_GetFanDuty
    0     003f42b0  _Max6639_GetFanDutyPercent
    0     003f425e  _Max6639_GetFanMinTachCount
    0     003f4202  _Max6639_GetFanPPR
    0     003f421d  _Max6639_GetFanPPRVal
    0     003f43ce  _Max6639_GetFanPWMFreq
    0     003f4694  _Max6639_GetFanRPM
    0     003f4515  _Max6639_GetFanRPMRange
    0     003f45ca  _Max6639_GetFanRPMStepA
    0     003f4642  _Max6639_GetFanRPMStepB
    0     003f458f  _Max6639_GetFanRateOfChange
    0     003f473e  _Max6639_GetFanSensorCorrection
    0     003f467c  _Max6639_GetFanStartStep
    0     003f42f9  _Max6639_GetFanStartTempC
    0     003f41a2  _Max6639_GetFanTachCount
    0     003f41d9  _Max6639_GetFanTargetTach
    0     003f4605  _Max6639_GetFanTempStepA
    0     003f4344  _Max6639_GetManuID
    0     003f4061  _Max6639_GetMask
    0     003f411b  _Max6639_GetOTLimit
    0     003f4039  _Max6639_GetStatus
    0     003f4148  _Max6639_GetThermLimit
    0     003f4750  _Max6639_Init
    0     003f4000  _Max6639_ReadTempC
    0     003f401e  _Max6639_ReadTempF
    0     003f410d  _Max6639_SetAlertLimit
    0     003f44a2  _Max6639_SetChan2Source
    0     003f409e  _Max6639_SetConfig
    0     003f46db  _Max6639_SetFanAutoRPM
    0     003f4195  _Max6639_SetFanConfig
    0     003f44f8  _Max6639_SetFanControl
    0     003f42d0  _Max6639_SetFanDuty
    0     003f42de  _Max6639_SetFanDutyPercent
    0     003f471b  _Max6639_SetFanManualRPM
    0     003f427a  _Max6639_SetFanMinTachCount
    0     003f4548  _Max6639_SetFanMinimumSpeed
    0     003f423b  _Max6639_SetFanPPR
    0     003f4435  _Max6639_SetFanPWMFreq
    0     003f46f6  _Max6639_SetFanPWMMode
    0     003f43b0  _Max6639_SetFanPulseStretch
    0     003f452d  _Max6639_SetFanRPMRange
    0     003f45ac  _Max6639_SetFanRPMStepA
    0     003f4622  _Max6639_SetFanRPMStepB
    0     003f4571  _Max6639_SetFanRateOfChange
    0     003f4746  _Max6639_SetFanSensorCorrection
    0     003f4374  _Max6639_SetFanSpinup
    0     003f465f  _Max6639_SetFanStartStep
    0     003f4318  _Max6639_SetFanStartTempC
    0     003f41cb  _Max6639_SetFanTachCount
    0     003f41f4  _Max6639_SetFanTargetTach
    0     003f45e7  _Max6639_SetFanTempStepA
    0     003f4392  _Max6639_SetFanTherm
    0     003f4079  _Max6639_SetMask
    0     003f413a  _Max6639_SetOTLimit
    0     003f448b  _Max6639_SetPOR
    0     003f44d8  _Max6639_SetPWMMode
    0     003f44ba  _Max6639_SetPWMPolarity
    0     003f4463  _Max6639_SetRun
    0     003f4167  _Max6639_SetThermLimit
    0     003f5f44  _MemCopy
    0     003f57b6  _NMI_ISR
    1     00009640  _NumCANWrites
    0     003f58d8  _PIE_RESERVED
    1     00009440  _PaEepromData
    1     0000940e  _PaValues
    1     00000ce0  _PieCtrlRegs
    1     00000d00  _PieVectTable
    0     003f5f8c  _PieVectTableInit
    1     000097b0  _PrevAdcInterruptCount
    0     003f57ac  _RTOSINT_ISR
    0     003e85fb  _RamfuncsLoadEnd
    0     003e851e  _RamfuncsLoadStart
    0     0000851e  _RamfuncsRunStart
    0     003f5ec6  _ReadReservedFn
    1     00009700  _RxMsgBuffer
    0     003f58ab  _SCIRXINTA_ISR
    0     003f58b5  _SCIRXINTB_ISR
    0     003f58b0  _SCITXINTA_ISR
    0     003f58ba  _SCITXINTB_ISR
    0     003f57fc  _SEQ1INT_ISR
    0     003f5801  _SEQ2INT_ISR
    0     003f5879  _SPIRXINTA_ISR
    0     003f5883  _SPIRXINTB_ISR
    0     003f588d  _SPIRXINTC_ISR
    0     003f5897  _SPIRXINTD_ISR
    0     003f587e  _SPITXINTA_ISR
    0     003f5888  _SPITXINTB_ISR
    0     003f5892  _SPITXINTC_ISR
    0     003f589c  _SPITXINTD_ISR
    1     00007050  _SciaRegs
    1     00007750  _ScibRegs
    1     0000963e  _SensorCorrection
    0     003f58eb  _ServiceDog
    1     00007040  _SpiaRegs
    1     00007740  _SpibRegs
    1     00007760  _SpicRegs
    1     00007780  _SpidRegs
    0     003f4aa1  _StuffMailbox
    1     00007010  _SysCtrlRegs
    0     003f5815  _TINT0_ISR
    0     003f52d2  _TestI2CEEPROM
    0     003f56ef  _Timer0_Task1_KickWatchDog
    1     0000979c  _Timer0_TaskPtr
    0     003f56c9  _Timer0_TaskPtr_Master
    0     003f56fc  _Timer1_Task1_ToggleActiveLED
    0     003f5716  _Timer1_Task2_GetTemperature
    0     003f574e  _Timer1_Task3_GetAdcStatus
    0     003f5766  _Timer1_Task4_GetFanRpm
    0     003f5792  _Timer1_Task5_UpdateAttenuator
    1     0000979e  _Timer1_TaskPtr
    0     003f56dc  _Timer1_TaskPtr_Master
    0     003f5496  _Tmc262_Init
    0     003f5516  _Tmc262_ReadStatus
    1     00009740  _TxMsgBuffer
    0     003f57ed  _USER10_ISR
    0     003f57f2  _USER11_ISR
    0     003f57f7  _USER12_ISR
    0     003f57c0  _USER1_ISR
    0     003f57c5  _USER2_ISR
    0     003f57ca  _USER3_ISR
    0     003f57cf  _USER4_ISR
    0     003f57d4  _USER5_ISR
    0     003f57d9  _USER6_ISR
    0     003f57de  _USER7_ISR
    0     003f57e3  _USER8_ISR
    0     003f57e8  _USER9_ISR
    1     00009406  _UcValues
    0     003f4bf3  _UpdateCanMessage
    0     003f49e4  _UpdateECanMBXwr
    0     003f4a08  _UpdateECanMBoxes
    0     003f4a23  _UpdateECanRate
    1     000096fa  _VerifyStatus
    0     003f581a  _WAKEINT_ISR
    0     003f5806  _XINT1_ISR
    0     003f580b  _XINT2_ISR
    1     00007070  _XIntruptRegs
    1     00000380  __STACK_END
    abs   00000380  __STACK_SIZE
    1     000097aa  ___TI_cleanup_ptr
    1     000097ac  ___TI_dtors_ptr
    1     000097a8  ___TI_enable_exit_profile_output
    abs   ffffffff  ___TI_pprof_out_hndl
    abs   ffffffff  ___TI_prof_data_size
    abs   ffffffff  ___TI_prof_data_start
    abs   ffffffff  ___binit__
    abs   ffffffff  ___c_args__
    0     003f6092  ___cinit__
    0     003f5f8c  ___etext__
    abs   ffffffff  ___pinit__
    0     003f4000  ___text__
    0     003f5f57  __args_main
    1     000096fe  __lock
    0     003f5f80  __nop
    0     003f5f7c  __register_lock
    0     003f5f78  __register_unlock
    1     00000000  __stack
    0     003f5f8b  __system_post_cinit
    0     003f5f89  __system_pre_init
    1     000097ba  __unlock
    0     003f5df1  _abort
    0     003f5c9c  _c_int00
    0     003f5bd9  _ceil
    0     003f5bd9  _ceilf
    0     003f512c  _checkBusStatus
    0     003f5367  _compareData
    0     003f5e90  _copy_in
    1     00009404  _currentResponderPtr
    0     003f55eb  _error
    0     003f5df3  _exit
    0     003f5140  _handleNACK
    0     003f5152  _handleNACKandTimeout
    0     003f537f  _i2cerror
    0     003f447a  _isRunning
    0     003f55ed  _main
    0     003f5ef6  _memcpy
    1     00009402  _numof16Bytes
    1     00009401  _numofBytes
    1     00009000  _progBuf
    1     00009403  _remainingBytes
    1     00009780  _returnme
    0     003f58dd  _rsvd_ISR
    0     003f55b5  _spi_read
    0     003f553a  _spi_write
    0     003f5564  _spi_write_read
    1     00009786  _temprtnme
    1     00009400  _timeoutCheck
    1     000097b4  _tmc262_rdrspms
    abs   ffffffff  binit
    0     003f6092  cinit
    0     003f7ff6  code_start
    0     003f5f8c  etext
    abs   ffffffff  pinit
    GLOBAL SYMBOLS: SORTED BY Symbol Address
    page  address   name
    0     003f4000  .text
    0     003f5026  _InitI2C
    0     003f5381  _InitSpi
    0     003f55eb  _error
    0     003f55ed  _main
    0     003f57b6  _NMI_ISR
    0     003f5905  _InitPll
    0     003f5aec  FS$$SUB
    0     003f5af1  FS$$ADD
    0     003f5bd9  _ceil
    0     003f5bd9  _ceilf
    0     003f5c42  FS$$MPY
    0     003f5c9c  _c_int00
    0     003f5d6c  _InitAdc
    0     003f5dc7  L$$DIV
    0     003f5dd6  L$$MOD
    0     003f5de4  UL$$DIV
    0     003f5deb  UL$$MOD
    0     003f5df1  C$$EXIT
    0     003f5df1  _abort
    0     003f5df3  _exit
    0     003f5e1a  FS$$TOL
    0     003f5e6b  FS$$TOI
    0     003f5e90  _copy_in
    0     003f5ef6  _memcpy
    0     003f5f13  I$$TOFS
    0     003f5f2d  FS$$CMP
    0     003f5f44  _MemCopy
    0     003f5f68  U$$TOFS
    0     003f5f80  __nop
    0     003f5f8c  etext
    0     003f6092  cinit
    1     00000000  __stack
    1     00000ae0  _CsmRegs
    1     00007100  _AdcRegs
    1     00009000  _progBuf
    1     00009649  _Cdh_Bit
    1     000096fe  __lock
    1     000097ba  __unlock
    1     003f7ff8  _CsmPwl
    abs   ffffffff  binit
    abs   ffffffff  pinit
    [395 symbols]
  • Jeffrey,
    Thanks for including the map file, everything appears to be in order for this to work.  From you earlier screenshot of the ASM you've also jumped into your ramfuncs based on the address so we know the CSM isn't locked either.
    1)Can you import the example we include in the API package and load/run it?  It is doing almost exactly the same thing with a call to the flash version function after the code copy.  Path is C:\tidcs\c28\Flash28_API\Flash2808_API_V302\example
    2)If we are debugging your current code we can use the stack to look back at where the ITRAP was fetched.  Once you are in the Illegal ISR, open up a memory window to the location pointed to by the SP register(in the CPU register view).  If we look back 2 words we should see the return address, which would be 1 instruction past the ITRAP.  Or you could single step the code into the Flash Version function to see when this happens as well.
    Between the above 2 actions I think we can narrow down the differences in the code and correct whatever is causing the code it misbehave.
    Matthew
  • Thanks Mathew - I haven't forgotten but have been side tracked. I should be on this in the next day or 2.
  • Thanks for the update Jeffrey, will look for your update and we can go from there.
    Matthew
  • So it appears I had 2 versions of the globals
    Uint16 Flash28_API_LoadStart;
    Uint16 Flash28_API_LoadEnd;
    Uint16 Flash28_API_RunStart;
    in my code. So I removed one set and it made the MemCopy address' args better. (Before the Start and End was 0xFFFF)
    So now the Flash_APIVersionHex() gave me the correct response - 0x0302 but it was running from Flash.
    From main(), I then wrapped it in a
    #pragma CODE_SECTION(GetVersion, "ramfuncs");
    GetVersion();
    and now it is giving me the correct version from SRAM (0x8537). So I obviously just need to ensure all the copying functions are enclosed in a pragma.
    Using the C:\tidcs\c28\Flash28_API\Flash2808_API_V302\example helped - although it is quite ancient.
    When I wrap all the Flash functions in the pragma and get the copy to work, I will mark this ticket as Resolved. Holding off in case of another question or two.
