Part Number: TMS320F28027
Other Parts Discussed in Thread: SFRA, CONTROLSUITE
Hi team,
Here's some issues from the customer may need your help:
UPS,i.e. an inverting power supply is applied, its auxiliary power supply is a push-pull switching power supply, PWM4 drives a push-pull circuit, and AD samples to capture the voltage and current of the output.
1. The customer would like to know if TI has the similar or same push-pull switching power supply scheme.
Does this control take SFRA and DCL, or other control method to control the duty cycle of the PWM?
2. Also, is there any other way or software to burn chips in bulk? CSS for the is too large.
Could you help check this case? Thanks.
Cherry
