Part Number: TMS320F28034
Hello E2E,
How to add. Out and. Bin file to write to TMS320F28034 chip?
Carlo
Hello E2E,
Carlo
Carlo,
You will need to give some additional details here, these are both generated files from building a project.
The .out file is typically should be loaded via code composer IDE (and created when a project is compiled) through a JTAG connection. A .bin file is a binary file that is typically created in parallel with the .out for a bootloader to load code into the device via a serial protocol.
There are many examples in C2000Ware https://dev.ti.com/tirex/explore/node?node=AE5EvIlRW3usarSqmtpC.Q__gYkahfz__LATEST for projects that can be imported into CCS and built and ran.
Let me know where we want to go from here.
Matthew
