Part Number: TMS320F28388D
Hello team,
I'm using sys bios + driver lib + flash lib for my development.
I'm facing a problem here, I have a GPIO connected and as configured as interrupt for both edges.
I'm getting an interrupt and is hitting callback ISR function but after that execution is stuck in exit.c Abort() function.
Below is my linker file:
* Copyright (c) 2018-2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* ======== TMS320F2838X1.cmd ========
* Define the memory map for Cpu 1 of TMS320F2838X.
MEMORY
/* BEGIN is used for the "boot to Flash" bootloader mode */
BEGIN : origin = 0x084000, length = 0x000002
//BEGIN : origin = 0x080000, length = 0x000002
/* Part of M0, BOOT rom will use this for stack */
BOOT_RSVD : origin = 0x000002, length = 0x0001AE
RAMM0 : origin = 0x0001B0, length = 0x000250
RAMM1 : origin = 0x000400, length = 0x000400
//GRL-EDIT
//RAMM2 : origin = 0x002400, length = 0x001000
/*RAMM3 : origin = 0x001800, length = 0x001000
RAMM4 : origin = 0x002800, length = 0x001000
RAMM5 : origin = 0x003800, length = 0x001000
RAMM6 : origin = 0x004800, length = 0x001000
RAMM7 : origin = 0x005800, length = 0x001000
RAMM8 : origin = 0x006800, length = 0x001000
RAMM9 : origin = 0x007800, length = 0x000200*/
RAMD0 : origin = 0x00C000, length = 0x000800
RAMD1 : origin = 0x00C800, length = 0x000800
RAMLS0_5 : origin = 0x008000, length = 0x003000
RAMLS0 : origin = 0x008000, length = 0x000800
RAMLS1 : origin = 0x008800, length = 0x000800
RAMLS2 : origin = 0x009000, length = 0x000800
RAMLS3 : origin = 0x009800, length = 0x000800
RAMLS4 : origin = 0x00A000, length = 0x000800
RAMLS5 : origin = 0x00A800, length = 0x000800
RAMLS6 : origin = 0x00B000, length = 0x000800
RAMLS7 : origin = 0x00B800, length = 0x000800
RAMGS0 : origin = 0x00D000, length = 0x001000
RAMGS1 : origin = 0x00E000, length = 0x001000
RAMGS2 : origin = 0x00F000, length = 0x001000
RAMGS3 : origin = 0x010000, length = 0x001000
RAMGS4 : origin = 0x011000, length = 0x001000
RAMGS5 : origin = 0x012000, length = 0x001000
RAMGS6 : origin = 0x013000, length = 0x001000
RAMGS7 : origin = 0x014000, length = 0x001000
RAMGS8 : origin = 0x015000, length = 0x001000
RAMGS9 : origin = 0x016000, length = 0x001000
RAMGS10 : origin = 0x017000, length = 0x001000
RAMGS11 : origin = 0x018000, length = 0x001000
RAMGS12 : origin = 0x019000, length = 0x001000
RAMGS13 : origin = 0x01A000, length = 0x001000
RAMGS14 : origin = 0x01B000, length = 0x001000
RAMGS15 : origin = 0x01C000, length = 0x001000
/* Flash sectors */
BOOTPGM : origin = 0x080002, length = 0x000002 /* on-chip Flash */
FLASH0 : origin = 0x080004, length = 0x001FFC /* on-chip Flash */
//FLASH0 : origin = 0x080002, length = 0x001FFE /* on-chip Flash */
FLASH1 : origin = 0x082000, length = 0x002000 /* on-chip Flash */
FLASH2 : origin = 0x084002, length = 0x001FFE /* on-chip Flash */
FLASH3 : origin = 0x086000, length = 0x002000 /* on-chip Flash */
FLASH4 : origin = 0x088000, length = 0x008000 /* on-chip Flash */
FLASH5 : origin = 0x090000, length = 0x008000 /* on-chip Flash */
FLASH6 : origin = 0x098000, length = 0x008000 /* on-chip Flash */
FLASH7 : origin = 0x0A0000, length = 0x008000 /* on-chip Flash */
FLASH8 : origin = 0x0A8000, length = 0x008000 /* on-chip Flash */
FLASH9 : origin = 0x0B0000, length = 0x008000 /* on-chip Flash */
FLASH10 : origin = 0x0B8000, length = 0x002000 /* on-chip Flash */
FLASH11 : origin = 0x0BA000, length = 0x002000 /* on-chip Flash */
FLASH12 : origin = 0x0BC000, length = 0x002000 /* on-chip Flash */
FLASH13 : origin = 0x0BE000, length = 0x002000 /* on-chip Flash */
CPU1TOCPU2RAM : origin = 0x03A000, length = 0x000800
CPU2TOCPU1RAM : origin = 0x03B000, length = 0x000800
CPUTOCMRAM : origin = 0x039000, length = 0x000800
CMTOCPURAM : origin = 0x038000, length = 0x000800
CANA_MSG_RAM : origin = 0x049000, length = 0x000800
CANB_MSG_RAM : origin = 0x04B000, length = 0x000800
RESET : origin = 0x3FFFC0, length = 0x000002
SECTIONS
codestart : > BEGIN
.text : >> FLASH2 | FLASH3 | FLASH4 | FLASH5 |
FLASH6 | FLASH7 | FLASH8 | FLASH9 | FLASH10 | FLASH11 |
FLASH12 | FLASH13
.cinit : > FLASH2 | FLASH3 | FLASH4 | FLASH5 |
FLASH12 | FLASH13
.switch : > FLASH2 | FLASH3 | FLASH4 | FLASH5 |
FLASH12 | FLASH13
.reset : > RESET, TYPE = DSECT /* not used, */
//.stack : > RAMM1 | RAMD0 |RAMD1 |RAMGS13
.stack : > RAMM1 | RAMLS0_5
.bss : > RAMLS0_5
.bss:output : > RAMLS6
// .stack : > RAMM1 | RAMM2 | RAMM3
// .bss : > RAMLS0_5
// .bss:output : > RAMLS6
.init_array : > FLASH2 | FLASH3 | FLASH4 | FLASH5
.const : > FLASH2 | FLASH3 | FLASH4 | FLASH5 |
FLASH12 | FLASH13
.data : >> RAMGS0 | RAMGS1 | RAMGS2 |RAMGS3 | RAMGS4
.sysmem : >> RAMGS0 | RAMGS1 | RAMGS2 |RAMGS3 | RAMGS4
.binit : > FLASH2 | FLASH3 | FLASH4
ramgs0 : > RAMGS0
ramgs1 : > RAMGS1
.TI.ramfunc : {} LOAD = FLASH3,
RUN = RAMGS8 | RAMGS9, table(BINIT),
LOAD_START(RamfuncsLoadStart),
LOAD_SIZE(RamfuncsLoadSize),
LOAD_END(RamfuncsLoadEnd),
RUN_START(RamfuncsRunStart),
RUN_SIZE(RamfuncsRunSize),
RUN_END(RamfuncsRunEnd),
PAGE = 0, ALIGN(4)
MSGRAM_CPU1_TO_CPU2 > CPU1TOCPU2RAM, type=NOINIT
MSGRAM_CPU2_TO_CPU1 > CPU2TOCPU1RAM, type=NOINIT
MSGRAM_CPU_TO_CM > CPUTOCMRAM, type=NOINIT
MSGRAM_CM_TO_CPU > CMTOCPURAM, type=NOINIT
My Project screenshot:
Error window hierarchy:
.cfg declarations :
BIOS.heapSize = 0x2200;
Program.stack = 0x800;
Properties screenshot:
I tired increasing sizes but ending up with different errors related to linker.
can anyone please let me know what could be the issue here.
--Pranay
