Part Number: TMS320F280039C
Hi Experts,
I am working with the DMA, starting with the example adc_ex6_soc_continuous_dma.c.
I am sampling two ADCs at the same time, with 2 channels on each. I want that on each transfer, the moved word from the ADC goes to a different array.
After reading all the documentation, it is supposed that if you write a value to DSTBURSTSTEP, on each transfer the destination is incremented by this value.
So together with DSTTRANSFERSTEP it should let me move the values to different arrays.
Well, It doesn't matter what I write on the DSTBURSTSTEP register, the values are moved together. In other words, the moved data is one value next to the other.
Here is the modified example. I have checked with the debugger that the register is properly wrtitten
// FILE: adc_ex6_soc_continuous_dma.c
// TITLE: ADC continuous conversions read by DMA.
//! \addtogroup driver_example_list
//! <h1> ADC Continuous Conversions Read by DMA (adc_soc_continuous_dma)</h1>
//! This example sets up two ADC channels to convert simultaneously. The
//! results will be transferred by the DMA into a buffer in RAM.
//! \b External \b Connections \n
//! - A3 & C3 pins should be connected to signals to convert
//! \b Watch \b Variables \n
//! - \b myADC0DataBuffer \b: a digital representation of the voltage on pin A3\n
//! - \b myADC1DataBuffer \b: a digital representation of the voltage on pin C3\n
// $Copyright:
// Copyright (C) 2021 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
#include "board.h"
// Function Prototypes
__interrupt void dmach1ISR(void);
void configureEPWM(uint32_t epwmBase);
void initializeDMA(void);
void configureDMAChannels(void);
// Defines
#define RESULTS_BUFFER_SIZE 80 //buffer for storing conversion results
#define CHANNELS 2
// Globals
#pragma DATA_SECTION(myADC0DataBuffer, "ramgs0");
#pragma DATA_SECTION(myADC1DataBuffer, "ramgs0");
uint16_t myADC0DataBuffer[CHANNELS][RESULTS_BUFFER_SIZE];
uint16_t myADC1DataBuffer[CHANNELS][RESULTS_BUFFER_SIZE];
volatile uint16_t done;
void main(void)
uint16_t resultsIndex;
// Initialize device clock and peripherals
Device_init();
// Disable pin locks and enable internal pullups.
Device_initGPIO();
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Board Initializatrion
// - Configure the ADCA & ADCC and power it up
// - Setup the ADC for continuous conversions on channels A3 and C3
// - Set up ISR for ADCA INT1 - occurs after first conversion
// - Enable specific PIE & CPU interrupts: ADCA INT1 - Group 1, interrupt 1
Board_init();
// Set up ISRs used by this example
// ISR for DMA ch1 - occurs when DMA transfer is complete
Interrupt_register(INT_DMA_CH1, &dmach1ISR);
// Enable specific PIE & CPU interrupts:
// DMA interrupt - Group 7, interrupt 1
Interrupt_enable(INT_DMA_CH1);
// Stop the ePWM clock
SysCtl_disablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// Call the set up function for ePWM 2
configureEPWM(EPWM2_BASE);
// Start the ePWM clock
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
// Initialize the DMA & configure DMA channels 1 & 2
initializeDMA();
configureDMAChannels();
// Initialize results buffer
for(resultsIndex = 0; resultsIndex < RESULTS_BUFFER_SIZE; resultsIndex++)
myADC0DataBuffer[0][resultsIndex] = 0;
myADC0DataBuffer[1][resultsIndex] = 0;
myADC1DataBuffer[0][resultsIndex] = 0;
myADC1DataBuffer[1][resultsIndex] = 0;
// Clearing all pending interrupt flags
DMA_clearTriggerFlag(DMA_CH1_BASE); // DMA channel 1
DMA_clearTriggerFlag(DMA_CH2_BASE); // DMA channel 2
HWREGH(myADC0_BASE + ADC_O_INTFLGCLR) = 0x3U; // ADCA
HWREGH(myADC1_BASE + ADC_O_INTFLGCLR) = 0x3U; // ADCC
EPWM_forceADCTriggerEventCountInit(EPWM2_BASE, EPWM_SOC_A); // EPWM2 SOCA
EPWM_clearADCTriggerFlag(EPWM2_BASE, EPWM_SOC_A); // EPWM2 SOCA
// Enable global Interrupts and higher priority real-time debug events:
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
// Start DMA
done = 0;
DMA_startChannel(DMA_CH1_BASE);
DMA_startChannel(DMA_CH2_BASE);
// Finally, enable the SOCA trigger from ePWM. This will kick off
// conversions at the next ePWM event.
EPWM_enableADCTrigger(EPWM2_BASE, EPWM_SOC_A);
// Loop until the ISR signals the transfer is complete
while(done == 0)
__asm(" NOP");
//ESTOP0;
// adcA1ISR - This is called after the very first conversion and will disable
// the ePWM SOC to avoid re-triggering problems.
#pragma CODE_SECTION(adcA1ISR, ".TI.ramfunc");
__interrupt void adcA1ISR(void)
// Disable this interrupt from happening again
Interrupt_disable(INT_ADCA1);
// Acknowledge interrupt
Interrupt_clearACKGroup(INT_myADC0_1_INTERRUPT_ACK_GROUP);
// dmach1ISR - This is called at the end of the DMA transfer, the conversions
// are stopped by removing the trigger of the first SOC from
// the last.
#pragma CODE_SECTION(dmach1ISR, ".TI.ramfunc");
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP7);
// configureEPWM - Set up the ePWM2 module so that the A output has a period
// of 40us with a 50% duty. The SOCA signal is coincident with
// the rising edge of this.
// Make the timer count up with a period of 40us
HWREGH(epwmBase + EPWM_O_TBCTL) = 0x0000U;
EPWM_setTimeBasePeriod(epwmBase, 124U);
// Set the A output on zero and reset on CMPA
EPWM_setActionQualifierAction(epwmBase, EPWM_AQ_OUTPUT_A,
EPWM_AQ_OUTPUT_HIGH,
EPWM_AQ_OUTPUT_ON_TIMEBASE_ZERO);
EPWM_AQ_OUTPUT_LOW,
EPWM_AQ_OUTPUT_ON_TIMEBASE_UP_CMPA);
// Set CMPA to 20us to get a 50% duty
EPWM_setCounterCompareValue(epwmBase, EPWM_COUNTER_COMPARE_A, 60U);
// Start ADC when timer equals zero (note: don't enable yet)
EPWM_setADCTriggerSource(epwmBase, EPWM_SOC_A, EPWM_SOC_TBCTR_ZERO);
EPWM_setADCTriggerEventPrescale(epwmBase, EPWM_SOC_A, 1U);
// Enable initialization of the SOCA event counter. Since we are
// disabling the ETSEL.SOCAEN bit, we need a way to reset the SOCACNT.
// Hence, enable the counter initialize control.
EPWM_enableADCTriggerEventCountInit(epwmBase, EPWM_SOC_A);
// initializeDMA - Initialize DMA through hard reset
// Perform a hard reset on DMA
DMA_initController();
// Allow DMA to run free on emulation suspend
DMA_setEmulationMode(DMA_EMULATION_FREE_RUN);
// configureDMAChannels - Initialize DMA ch 1 to transfer ADCA results
// and DMA ch 2 to transfer ADCB results
// DMA channel 1 set up for ADCA
DMA_configAddresses(DMA_CH1_BASE, (uint16_t *)&myADC0DataBuffer,
(uint16_t *)ADCARESULT_BASE);
// Perform enough 2-word bursts to fill the results buffer. Data will be
// transferred 32 bits at a time hence the address steps below.
DMA_configBurst(DMA_CH1_BASE, 2, 2, 2); // It doesn't matters the value of DSTBURSTSTEP, the values are moved one nect to the other
DMA_configTransfer(DMA_CH1_BASE, (RESULTS_BUFFER_SIZE), 0, 2);
DMA_configMode(DMA_CH1_BASE, DMA_TRIGGER_ADCA2,
(DMA_CFG_ONESHOT_DISABLE | DMA_CFG_CONTINUOUS_ENABLE |
DMA_CFG_SIZE_32BIT));
DMA_enableTrigger(DMA_CH1_BASE);
DMA_disableOverrunInterrupt(DMA_CH1_BASE);
DMA_setInterruptMode(DMA_CH1_BASE, DMA_INT_AT_END);
DMA_enableInterrupt(DMA_CH1_BASE);
// DMA channel 2 set up for ADCC
DMA_configAddresses(DMA_CH2_BASE, (uint16_t *)&myADC1DataBuffer,
(uint16_t *)ADCCRESULT_BASE);
DMA_configBurst(DMA_CH2_BASE, 2, 2, 2);
DMA_configTransfer(DMA_CH2_BASE, (RESULTS_BUFFER_SIZE), 0, 2);
DMA_configMode(DMA_CH2_BASE, DMA_TRIGGER_ADCA2,
DMA_enableTrigger(DMA_CH2_BASE);
DMA_disableOverrunInterrupt(DMA_CH2_BASE);
DMA_setInterruptMode(DMA_CH2_BASE, DMA_INT_AT_END);
DMA_enableInterrupt(DMA_CH2_BASE);
// End of file
Probably there is something that I don't configure properly
Thanks in Advance,
Fernando Gatto
