Part Number: TMDXIDDK379D
Other Parts Discussed in Thread: C2000WARE, TMDSCNCD28379D
Hi Team,
I need your help with the TMDXIDDK379D. I am trying to output a signal out of the available DAC pins, but I'm not exactly sure how. I tried backtracking the exact pin that needs to output that signal on the TMS320F2807x microcontroller, but the buffdac_ex1.c code provided through the C2000ware library does not explain how to edit the exact pin.
I also wanted to figure out exactly how to measure the current through the V,W,M phases on the IDDK board. The servo code provided has a current sensing block, but I'm not exactly sure how to isolate it and use it without running anything else. I need to know what physical connections need to be made, and what "build level" I am supposed to be at. Thanks in advance!
Kind Regards,
Jejomar
