Part Number: F28004x
Hello, I have the following questions when learning to use FSI bus:
1. Will the link in the communication topology continue to send data after successful access through the handshake system to keep the link connection normal? Or does the data line change only when sending data frames?
2. Is there a corresponding compensation mechanism for the delay of each node of FSI? For example, when daisy chain topology connection is adopted, if the synchronization control on each node is guaranteed?
