Part Number: TMS320F28388D
Other Parts Discussed in Thread: TMS320F28386D
I am trying to integrate my bare metal application into sys bios application.
I am working on CM core of TMS320F28386D.
However, I am coming across problems with interrupt library and I am unable to find any documentation related to it.
in interrupt.h, there is macro that disables vector table.
//***************************************************************************** // // Flash Vector Table defined in startup.ccs. // //***************************************************************************** #ifndef USE_RTOS extern void (*vectorTableFlash[NUM_INTERRUPTS])(void); #endif //***************************************************************************** // // RAM Vector Table to be used as dstVectorTable in // Interrupt_initRAMVectorTable(). Set the size of the vector table to the // largest number of interrupts of any device. // //***************************************************************************** #ifndef USE_RTOS extern void (*vectorTableRAM[NUM_INTERRUPTS])(void); #endif #endif
USE_RTOS.
How is this integrated with overall sys bios? Are there any example or documentation that I can refer to related to this?
Thanks for your help
swapnil
