LAUNCHXL-F280025C: Board Wont Connect to Code Composer Studio in Windows
Part Number: LAUNCHXL-F280025C
Other Parts Discussed in Thread: MSP432E401Y, CCSTUDIO, ENERGYTRACE, CC2538, CONTROLSUITE, ENERGIA, SYSCONFIG, SEGGER, SHA-256,
I connect the board in windows and I can see it in the device manager
Under Ports (COM & LPT)
XDS110 Class Application/User UART (COM5)
XDS110 Class Auxilary Data Port (COM8)
Under Texas Instrument Debug Probes
XDS110 Class Data Port
XDS110 Class Debug Port
When I go to run the example project from Code Composer Studio I get this message
Error connecting to the target:
(Error -151 @ 0x0)
One of the FTDI driver functions used during the connect
returned bad status or an error. The cause may be one or
more of: no XDS100 is plugged in, invalid XDS100 serial number,
blank XDS100 EEPROM, missing FTDI drivers, faulty USB cable.
Use the xds100serial command-line utility in the 'common/uscif'
folder to verify the XDS100 can be located.
(Emulation package 9.6.0.00172)
I am using the following system
Windows 10 Pro
Code Composer Studio  Version: 11.1.0.00011
This is the CC about system
*** Date: Wednesday, March 30, 2022 at 10:20:26 p.m. Pacific Daylight Time
*** Platform Details:
*** System properties:
DEFAULT_CCS_TARGET_CONFIGURATION=D:\workspaces2022\ti_exp432\blinky_MSP_EXP432E401Y_nortos_ccs\targetConfigs\MSP432E401Y.ccxml
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
ccs.debugServerDir=G:\ti\ccs1110\ccs\ccs_base\DebugServer
ccs.inCleanMode=false
ccs.inDevelopmentMode=false
ccs.inTestMode=false
ccs.minXDCVersion=3.25.5.1
ds.delayed.keepInstances=true
ds.delayed.keepInstances.default=true
dvt.binDir=G:\ti\ccs1110\ccs\ccs_base\DebugServer\..\dvt\bin
dvt.dir=G:\ti\ccs1110\ccs\ccs_base\DebugServer\..\dvt
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=4.19.0.I20210303-1800
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
-showsplash
G:\ti\ccs1110\ccs\eclipse\\plugins\com.ti.ccstudio.branding_10.0.0.202112011800\splash.bmp
-launcher
G:\ti\ccs1110\ccs\eclipse\ccstudio.exe
-name
Ccstudio
--launcher.library
G:\ti\ccs1110\ccs\eclipse\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.2.100.v20210209-1541\eclipse_11301.dll
-startup
G:\ti\ccs1110\ccs\eclipse\\plugins/org.eclipse.equinox.launcher_1.6.100.v20201223-0822.jar
--launcher.appendVmargs
-product
com.ti.ccstudio.branding.product
-vm
G:\ti\ccs1110\ccs\eclipse\jre\bin\client\jvm.dll
eclipse.home.location=file:/G:/ti/ccs1110/ccs/eclipse/
eclipse.launcher=G:\ti\ccs1110\ccs\eclipse\ccstudio.exe
eclipse.launcher.name=Ccstudio
eclipse.p2.data.area=@config.dir/../p2/
eclipse.p2.profile=epp.package.cpp
eclipse.product=com.ti.ccstudio.branding.product
eclipse.startTime=1648702963611
eclipse.stateSaveDelayInterval=30000
eclipse.vm=G:\ti\ccs1110\ccs\eclipse\jre\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.instance.area.default=@user.home/workspace_v11
-Djxbrowser.ipc.external=true
-Dorg.eclipse.equinox.http.jetty.customizer.class=com.ti.ccstudio.gui.composer.http.jetty.MaqettaJettyCustomizer
-Dccs.minXDCVersion=3.25.5.1
-Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000
-Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000
-Dsun.net.client.defaultReadTimeout=30000
-Dsun.net.client.defaultConnectTimeout=10000
-Xms256m
-Xmx2048m
-XX:ErrorFile=C:\Users\marcu\AppData\Local\TEXASI~1\CCS\ccs1110\0\dmp\\hs_err_%p.log
-Djava.class.path=G:\ti\ccs1110\ccs\eclipse\\plugins/org.eclipse.equinox.launcher_1.6.100.v20201223-0822.jar
equinox.init.uuid=true
file.encoding=Cp1252
file.separator=\
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=55.0
java.home=G:\ti\ccs1110\ccs\eclipse\jre
java.io.tmpdir=C:\Users\marcu\AppData\Local\Temp\
java.library.path=G:\ti\ccs1110\ccs\eclipse;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;u:\MWLite\MetaWare\arc\bin;u:\MWLite\MetaWare\ide;U:\winTools\;G:\mypath;C:\Python310\Scripts\;C:\Python310\;U:\Program Files (x86)\VMware\VMware Player\bin\;X:\SDKs\Vulkan\1.2.170.0\Bin;U:\ActivelTCL\bin;U:\CUDA\v11.1\bin;U:\CUDA\v11.1\libnvvp;K:\Oculus\Support\oculus-runtime;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;F:\curl\curl-7.54.0-win64-mingw\bin;u:\Program Files\MATLAB\MATLAB Runtime\v910\runtime\win64;F:\Go\bin;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;u:\Program Files (x86)\Gpg4win\..\GnuPG\bin;U:\Program Files\PuTTY\;U:\Program Files\Go\bin;C:\Program Files\NVIDIA Corporation\Nsight Compute 2020.2.1\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;U:\CUDA\v11.1\bin\extras\CUPTI\lib64;U:\CUDA\v11.1\bin\include;D:\scripts;C:\ProgramData\chocolatey\bin;M:\apache\apache-maven-3.8.1\bin;C:\Program Files (x86)\GnuWin32\bin;M:\MiniTools;Q:\Strawberry\perl\bin;Q:\Strawberry\perl\site\bin;Q:\Strawberry\c\bin;U:\Program Files\CMake\bin\;D:\Projects19\repos\3rd\ninja\build-cmake\Debug;u:\Program Files\MATLAB\MATLAB Runtime\v93\runtime\win64;u:\Program Files\Graphviz\bin;u:\Program Files\LLVM\bin;u:\Program Files\R\R-4.0.3\bin;C:\Program Files (x86)\gsudo\;C:\Program Files\dotnet\;U:\Programs\Microsoft VS Code;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;U:\Program Files\nodejs\;M:\IBM_Aspera_CLI\cli\bin;U:\Program Files (x86)\sbt\bin;U:\Program Files\Java\jdk1.8.0_301\\bin;M:\pyspark\spark-3.1.2-bin-hadoop3.2\bin;M:\pyspark\spark-3.1.2-bin-hadoop3.2\bin;u:\Program Files\Git\cmd;U:\Program Files\CMake\bin;C:\Program Files\Docker\Docker\resources\bin;C:\ProgramData\DockerDesktop\version-bin;C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility;X:\Microchip\xc8\v2.36\bin;X:\Microchip\xc16\v2.00\bin;X:\Microchip\xc32\v4.00\bin;C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.10\bin;C:\Program Files (x86)\Atmel\sam-ba_2.16\drv\;C:\Program Files (x86)\Atmel\sam-ba_2.16;u:\Program Files (x86)\GnuPG\bin;C:\Program Files (x86)\NVIDIA Corporation\;C:\Users\marcu\AppData\Local\GitHubDesktop\bin;C:\Users\marcu\AppData\Roaming\npm;C:\Users\marcu\.dotnet\tools;M:\PhoenixSuite\PhoenixSuit_V1.10\;u:\Program Files (x86)\Atmel\Flip 3.4.7\bin;.
java.runtime.name=OpenJDK Runtime Environment
java.runtime.version=11.0.13+8
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=11
java.vendor=Eclipse Adoptium
java.vendor.url=https://adoptium.net/
java.vendor.url.bug=https://github.com/adoptium/adoptium-support/issues
java.vendor.version=Temurin-11.0.13+8
java.version=11.0.13
java.version.date=2021-10-19
java.vm.info=mixed mode
java.vm.name=OpenJDK 64-Bit Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=11
java.vm.vendor=Eclipse Adoptium
java.vm.version=11.0.13+8
jdk.debug=release
jetty.git.hash=27afab2bd37780d179836e313e0fe11bc4fa0ce9
jna.loaded=true
jnidispatch.path=C:\Users\marcu\AppData\Local\Temp\jna-103666256\jna3837011790440303165.dll
line.separator=
org.eclipse.cdt.debug.core.toggleBreakpointModel=true
org.eclipse.cdt.debug.ui.debuggerActive=false
org.eclipse.cdt.dsf.gdb.ui.debuggerActive=false
org.eclipse.debug.ui.breakpoints.toggleFactoriesUsed=true
org.eclipse.debug.ui.debugViewToolbarVisible=false
org.eclipse.equinox.launcher.splash.location=G:\ti\ccs1110\ccs\eclipse\\plugins\com.ti.ccstudio.branding_10.0.0.202112011800\splash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.eclipse.equinox.simpleconfigurator/bundles.info
org.eclipse.rtsc.gui.productId=com.ti.ccstudio.branding.product
org.eclipse.swt.internal.deviceZoom=100
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0, OSGi/Minimum-1.1, OSGi/Minimum-1.2, JavaSE/compact1-1.8, JavaSE/compact2-1.8, JavaSE/compact3-1.8, JRE-1.1, J2SE-1.2, J2SE-1.3, J2SE-1.4, J2SE-1.5, JavaSE-1.6, JavaSE-1.7, JavaSE-1.8, JavaSE-9, JavaSE-10, JavaSE-11
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows10
org.osgi.framework.os.version=10.0.0
org.osgi.framework.processor=x86-64
org.osgi.framework.storage=G:\ti\ccs1110\ccs\eclipse\configuration
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List<Version>="1.0, 1.1, 1.2", osgi.ee; osgi.ee="JRE"; version:List<Version>="1.0, 1.1", osgi.ee; osgi.ee="JavaSE"; version:List<Version>="1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.8, 9.0, 10.0, 11.0",osgi.ee; osgi.ee="JavaSE/compact1"; version:List<Version>="1.8, 9.0, 10.0, 11.0",osgi.ee; osgi.ee="JavaSE/compact2"; version:List<Version>="1.8, 9.0, 10.0, 11.0",osgi.ee; osgi.ee="JavaSE/compact3"; version:List<Version>="1.8, 9.0, 10.0, 11.0"
org.osgi.framework.system.packages=com.sun.java.accessibility.util, com.sun.jndi.ldap.spi, com.sun.management, com.sun.net.httpserver, com.sun.net.httpserver.spi, com.sun.nio.file, com.sun.nio.sctp, com.sun.security.auth, com.sun.security.auth.callback, com.sun.security.auth.login, com.sun.security.auth.module, com.sun.security.jgss, java.applet, java.awt, java.awt.color, java.awt.datatransfer, java.awt.desktop, java.awt.dnd, java.awt.event, java.awt.font, java.awt.geom, java.awt.im, java.awt.im.spi, java.awt.image, java.awt.image.renderable, java.awt.print, java.beans, java.beans.beancontext, java.io, java.lang, java.lang.annotation, java.lang.instrument, java.lang.invoke, java.lang.management, java.lang.module, java.lang.ref, java.lang.reflect, java.math, java.net, java.net.http, java.net.spi, java.nio, java.nio.channels, java.nio.channels.spi, java.nio.charset, java.nio.charset.spi, java.nio.file, java.nio.file.attribute, java.nio.file.spi, java.rmi, java.rmi.activation, java.rmi.dgc, java.rmi.registry, java.rmi.server, java.security, java.security.acl, java.security.cert, java.security.interfaces, java.security.spec, java.sql, java.text, java.text.spi, java.time, java.time.chrono, java.time.format, java.time.temporal, java.time.zone, java.util, java.util.concurrent, java.util.concurrent.atomic, java.util.concurrent.locks, java.util.function, java.util.jar, java.util.logging, java.util.prefs, java.util.regex, java.util.spi, java.util.stream, java.util.zip, javax.accessibility, javax.annotation.processing, javax.crypto, javax.crypto.interfaces, javax.crypto.spec, javax.imageio, javax.imageio.event, javax.imageio.metadata, javax.imageio.plugins.bmp, javax.imageio.plugins.jpeg, javax.imageio.plugins.tiff, javax.imageio.spi, javax.imageio.stream, javax.lang.model, javax.lang.model.element, javax.lang.model.type, javax.lang.model.util, javax.management, javax.management.loading, javax.management.modelmbean, javax.management.monitor, javax.management.openmbean, javax.management.relation, javax.management.remote, javax.management.remote.rmi, javax.management.timer, javax.naming, javax.naming.directory, javax.naming.event, javax.naming.ldap, javax.naming.spi, javax.net, javax.net.ssl, javax.print, javax.print.attribute, javax.print.attribute.standard, javax.print.event, javax.rmi.ssl, javax.script, javax.security.auth, javax.security.auth.callback, javax.security.auth.kerberos, javax.security.auth.login, javax.security.auth.spi, javax.security.auth.x500, javax.security.cert, javax.security.sasl, javax.smartcardio, javax.sound.midi, javax.sound.midi.spi, javax.sound.sampled, javax.sound.sampled.spi, javax.sql, javax.sql.rowset, javax.sql.rowset.serial, javax.sql.rowset.spi, javax.swing, javax.swing.border, javax.swing.colorchooser, javax.swing.event, javax.swing.filechooser, javax.swing.plaf, javax.swing.plaf.basic, javax.swing.plaf.metal, javax.swing.plaf.multi, javax.swing.plaf.nimbus, javax.swing.plaf.synth, javax.swing.table, javax.swing.text, javax.swing.text.html, javax.swing.text.html.parser, javax.swing.text.rtf, javax.swing.tree, javax.swing.undo, javax.tools, javax.transaction.xa, javax.xml, javax.xml.catalog, javax.xml.crypto, javax.xml.crypto.dom, javax.xml.crypto.dsig, javax.xml.crypto.dsig.dom, javax.xml.crypto.dsig.keyinfo, javax.xml.crypto.dsig.spec, javax.xml.datatype, javax.xml.namespace, javax.xml.parsers, javax.xml.stream, javax.xml.stream.events, javax.xml.stream.util, javax.xml.transform, javax.xml.transform.dom, javax.xml.transform.sax, javax.xml.transform.stax, javax.xml.transform.stream, javax.xml.validation, javax.xml.xpath, jdk.dynalink, jdk.dynalink.beans, jdk.dynalink.linker, jdk.dynalink.linker.support, jdk.dynalink.support, jdk.jfr, jdk.jfr.consumer, jdk.management.jfr, jdk.nashorn.api.scripting, jdk.nashorn.api.tree, jdk.net, jdk.nio, netscape.javascript, org.ietf.jgss, org.w3c.dom, org.w3c.dom.bootstrap, org.w3c.dom.css, org.w3c.dom.events, org.w3c.dom.html, org.w3c.dom.ls, org.w3c.dom.ranges, org.w3c.dom.stylesheets, org.w3c.dom.traversal, org.w3c.dom.views, org.w3c.dom.xpath, org.xml.sax, org.xml.sax.ext, org.xml.sax.helpers, sun.misc, sun.reflect
org.osgi.framework.uuid=9ad8fa89-dba4-435d-a143-f7a29cca82d4
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.10.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Windows 10
os.version=10.0
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.2.300.v20210212-1137.jar,reference:file:org.eclipse.equinox.simpleconfigurator_1.3.600.v20200721-1308.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.compatibility.bootdelegation.default=true
osgi.configuration.area=file:/G:/ti/ccs1110/ccs/eclipse/configuration/
osgi.framework=file:/g:/ti/ccs1110/ccs/eclipse/plugins/org.eclipse.osgi_3.16.200.v20210226-1447.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.2.300.v20210212-1137.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:g:/ti/ccs1110/ccs/eclipse/plugins/org.eclipse.osgi.compatibility.state_1.2.300.v20210212-1137.jar
osgi.install.area=file:/G:/ti/ccs1110/ccs/eclipse/
osgi.instance.area=file:/G:/EmbedWorkSpaces/workspace_v11/
osgi.instance.area.default=file:/C:/Users/marcu/workspace_v11/
osgi.logfile=G:\EmbedWorkSpaces\workspace_v11\.metadata\.log
osgi.nl=en_CA
osgi.os=win32
osgi.splashLocation=G:\ti\ccs1110\ccs\eclipse\\plugins\com.ti.ccstudio.branding_10.0.0.202112011800\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=g:\ti\ccs1110\ccs\eclipse\plugins
osgi.tracefile=G:\EmbedWorkSpaces\workspace_v11\.metadata\trace.log
osgi.user.area=file:/C:/Users/marcu/user/
osgi.ws=win32
path.separator=;
sun.arch.data.model=64
sun.awt.enableExtraMouseButtons=true
sun.boot.library.path=G:\ti\ccs1110\ccs\eclipse\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=amd64
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot 64-Bit Client Compiler
sun.os.patch.level=
user.country=CA
user.dir=G:\ti\ccs1110\ccs\eclipse
user.home=C:\Users\marcu
user.language=en
user.name=marcu
user.script=
user.timezone=America/Los_Angeles
user.variant=
*** System environment variables:
ALLUSERSPROFILE=C:\ProgramData
AMDRMPATH=C:\Program Files\AMD\RyzenMaster\
APPDATA=C:\Users\marcu\AppData\Roaming
BOMBER_SERVERDIAG=1
CARBON_MEM_DISABLE=1
COMPUTERNAME=LIGHTNING-II
CUDA_PATH=U:\CUDA\v10.2
CUDA_PATH_V10_2=U:\CUDA\v10.2
CUDA_PATH_V11_1=U:\CUDA\v11.1
ChocolateyInstall=C:\ProgramData\chocolatey
ChocolateyLastPathUpdate=132602453492166011
ComSpec=C:\WINDOWS\system32\cmd.exe
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
DriverData=C:\Windows\System32\Drivers\DriverData
EMWI_DIR=C:\Program Files (x86)\Embedded Wizard 11.00\
GOPATH=C:\Users\marcu\go
HADOOP_HOME=M:\pyspark\spark-3.1.2-bin-hadoop3.2
HOME=C:\Users\marcu
HOMEDRIVE=C:
HOMEPATH=\Users\marcu
HP=c:\users\marcu
JAVA_HOME=U:\Program Files\Java\jdk1.8.0_301\
KAGGLE_CONFIG_DIR=\Users\marcu\.kaggle
LOCALAPPDATA=C:\Users\marcu\AppData\Local
LOGONSERVER=\\LIGHTNING-II
METAWARE_ROOT=u:\MWLite\MetaWare
NUMBER_OF_PROCESSORS=32
NVCUDASAMPLES10_2_ROOT=U:\CUDA\v10.2
NVCUDASAMPLES11_1_ROOT=U:\CUDA\v11.1\Samples
NVCUDASAMPLES_ROOT=U:\CUDA\v10.2
NVTOOLSEXT_PATH=C:\Program Files\NVIDIA Corporation\NvToolsExt\
OPENOCD_SCRIPTS=M:\newOPENOCD\openocd-esp32\share\openocd\scripts
OS=Windows_NT
OculusBase=K:\Oculus\
OneDrive=Q:\OneDrive
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY;.PYW
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=AMD64 Family 25 Model 33 Stepping 0, AuthenticAMD
PROCESSOR_LEVEL=25
PROCESSOR_REVISION=2100
PSModulePath=C:\Users\marcu\Documents\WindowsPowerShell\Modules;X:\SDKs\google-cloud-sdk\platform\PowerShell;
PUBLIC=C:\Users\Public
Path=G:/ti/ccs1110/ccs/eclipse/jre/bin/client;G:/ti/ccs1110/ccs/eclipse/jre/bin;u:\MWLite\MetaWare\arc\bin;u:\MWLite\MetaWare\ide;U:\winTools\;G:\mypath;C:\Python310\Scripts\;C:\Python310\;U:\Program Files (x86)\VMware\VMware Player\bin\;X:\SDKs\Vulkan\1.2.170.0\Bin;U:\ActivelTCL\bin;U:\CUDA\v11.1\bin;U:\CUDA\v11.1\libnvvp;K:\Oculus\Support\oculus-runtime;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;F:\curl\curl-7.54.0-win64-mingw\bin;u:\Program Files\MATLAB\MATLAB Runtime\v910\runtime\win64;F:\Go\bin;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;u:\Program Files (x86)\Gpg4win\..\GnuPG\bin;U:\Program Files\PuTTY\;U:\Program Files\Go\bin;C:\Program Files\NVIDIA Corporation\Nsight Compute 2020.2.1\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;U:\CUDA\v11.1\bin\extras\CUPTI\lib64;U:\CUDA\v11.1\bin\include;D:\scripts;C:\ProgramData\chocolatey\bin;M:\apache\apache-maven-3.8.1\bin;C:\Program Files (x86)\GnuWin32\bin;M:\MiniTools;Q:\Strawberry\perl\bin;Q:\Strawberry\perl\site\bin;Q:\Strawberry\c\bin;U:\Program Files\CMake\bin\;D:\Projects19\repos\3rd\ninja\build-cmake\Debug;u:\Program Files\MATLAB\MATLAB Runtime\v93\runtime\win64;u:\Program Files\Graphviz\bin;u:\Program Files\LLVM\bin;u:\Program Files\R\R-4.0.3\bin;C:\Program Files (x86)\gsudo\;C:\Program Files\dotnet\;U:\Programs\Microsoft VS Code;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;U:\Program Files\nodejs\;M:\IBM_Aspera_CLI\cli\bin;U:\Program Files (x86)\sbt\bin;U:\Program Files\Java\jdk1.8.0_301\\bin;M:\pyspark\spark-3.1.2-bin-hadoop3.2\bin;M:\pyspark\spark-3.1.2-bin-hadoop3.2\bin;u:\Program Files\Git\cmd;U:\Program Files\CMake\bin;C:\Program Files\Docker\Docker\resources\bin;C:\ProgramData\DockerDesktop\version-bin;C:\Program Files (x86)\STMicroelectronics\STM32 ST-LINK Utility\ST-LINK Utility;X:\Microchip\xc8\v2.36\bin;X:\Microchip\xc16\v2.00\bin;X:\Microchip\xc32\v4.00\bin;C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.10\bin;C:\Program Files (x86)\Atmel\sam-ba_2.16\drv\;C:\Program Files (x86)\Atmel\sam-ba_2.16;u:\Program Files (x86)\GnuPG\bin;C:\Program Files (x86)\NVIDIA Corporation\;C:\Users\marcu\AppData\Local\GitHubDesktop\bin;C:\Users\marcu\AppData\Roaming\npm;C:\Users\marcu\.dotnet\tools;M:\PhoenixSuite\PhoenixSuit_V1.10\;u:\Program Files (x86)\Atmel\Flip 3.4.7\bin;G:\ti\ccs1110\ccs\eclipse;
PhoenixPath=M:\PhoenixSuite\PhoenixSuit_V1.10\
ProgramData=C:\ProgramData
PyCharm Community Edition with Anaconda plugin=u:\Program Files\JetBrains\PyCharm Community Edition with Anaconda plugin 2020.2.5\bin;
SBT_HOME=U:\Program Files (x86)\sbt\
SPARK_HOME=M:\pyspark\spark-3.1.2-bin-hadoop3.2
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Users\marcu\AppData\Local\Temp
TMP=C:\Users\marcu\AppData\Local\Temp
USERDOMAIN=LIGHTNING-II
USERDOMAIN_ROAMINGPROFILE=LIGHTNING-II
USERNAME=marcu
USERPROFILE=C:\Users\marcu
VBOX_MSI_INSTALL_PATH=U:\Program Files\Oracle\VirtualBox\
VISUALGDB_DIR=U:\Program Files (x86)\Sysprogs\VisualGDB
VK_SDK_PATH=X:\SDKs\Vulkan\1.2.170.0
VULKAN_SDK=X:\SDKs\Vulkan\1.2.170.0
windir=C:\WINDOWS
*** Features:
com.ti.ccstudio (11.1.0.202112011800) "CCS Product Branding"
com.ti.ccstudio.base (11.1.0.02593) "CCS Base Components"
com.ti.chromium.browser (11.0.0.202112011800) "Chromium Browser"
com.ti.dvt.codecoverage (4.1.0.202106281057) "Code Coverage"
com.ti.dvt.energytrace (4.1.0.202106281057) "EnergyTrace"
gnu.io.rxtx (2.1.8.0_201606281300) "RXTX"
org.eclipse.cdt (10.2.0.202103011047) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.build.crossgcc (10.2.0.202102261947) "CDT GCC Cross Compiler Support"
org.eclipse.cdt.debug.ui.memory (10.2.0.202012191711) "Memory Browser"
org.eclipse.cdt.gdb (10.2.0.202012191711) "GDB Common"
org.eclipse.cdt.gnu.build (10.2.0.202012191711) "GCC ToolChain Support UI"
org.eclipse.cdt.gnu.debug (10.2.0.202012191801) "C/C++ Development Tools Launching Support"
org.eclipse.cdt.gnu.dsf (10.2.0.202102231601) "GDB DSF Debugger Integration UI"
org.eclipse.cdt.launch.remote (10.2.0.202012191711) "C/C++ Remote Debug Launcher"
org.eclipse.cdt.native (10.2.0.202102030214) "C/C++ Development Tools Core Native Utilities"
org.eclipse.cdt.platform (10.2.0.202103011047) "C/C++ Development Platform"
org.eclipse.draw2d (3.10.100.201606061308) "Draw2d"
org.eclipse.egit (5.11.0.202103091610-r) "Git integration for Eclipse"
org.eclipse.emf.common (2.22.0.v20210114-1734) "EMF Common"
org.eclipse.emf.ecore (2.23.0.v20200630-0516) "EMF Ecore"
org.eclipse.epp.mpc (1.9.1.v20210204-1408) "Marketplace Client"
org.eclipse.gef (3.11.0.201606061308) "GEF (MVC)"
org.eclipse.help (2.3.500.v20210303-1800) "Help System Base"
org.eclipse.jgit (5.11.0.202103091610-r) "JGit Core"
org.eclipse.jgit.gpg.bc (5.11.0.202103091610-r) "JGit Core"
org.eclipse.jgit.http.apache (5.11.0.202103091610-r) "JGit Apache httpclient based HTTP support"
org.eclipse.jgit.ssh.apache (5.11.0.202103091610-r) "JGit SSH support based on Apache MINA sshd"
org.eclipse.platform (4.19.0.v20210303-1800) "Eclipse Platform"
org.eclipse.rcp (4.19.0.v20210303-1800) "Eclipse RCP"
org.eclipse.rse (4.5.300.202101081641) "Remote System Explorer End-User Runtime"
org.eclipse.rse.core (4.5.300.202101081641) "RSE Core"
org.eclipse.rse.dstore (4.5.300.202101081641) "RSE DStore Services"
org.eclipse.rse.ftp (4.5.300.202101081641) "RSE FTP Service"
org.eclipse.rse.local (4.5.300.202101081641) "RSE Local Services"
org.eclipse.rse.ssh (4.5.300.202101081641) "RSE SSH Services"
org.eclipse.rse.telnet (4.5.300.202101081641) "RSE Telnet Service"
org.eclipse.rtsc.xdctools.product_3.62.1.16 (3.62.1.16) "XDCtools Embedded Runtime Content"
org.eclipse.rtsc.xdctools.product.ui (3.62.1.16) "XDCtools IDE Tooling"
org.eclipse.tm.terminal.connector.ssh.feature (10.2.0.202012191711) "Terminal SSH Connector"
org.eclipse.tm.terminal.control.feature (10.2.0.202103012351) "Terminal Control (Embeddable Widget)"
org.eclipse.tm.terminal.feature (10.2.0.202012191711) "Terminal View Core"
org.eclipse.tm.terminal.view.feature (10.2.0.202103012351) "Terminal View"
org.eclipse.userstorage (1.2.0.v20191120-1614) "Eclipse User Storage"
*** Plug-in Registry:
com.google.gson (2.8.6.v20201231-1626) "Gson: Google Json Library for Java" [Resolved]
com.ibm.icu (67.1.0.v20200706-1749) "ICU4J" [Active]
com.jcraft.jsch (0.1.55.v20190404-1902) "JSch" [Resolved]
com.sun.el (2.2.0.v201303151357) "Javax Expression Language Reference Implementation Bundle" [Resolved]
com.sun.jna (4.5.1.v20190425-1842) "Java Native Access" [Starting]
com.sun.jna (5.6.0.v20200716-0148) "Java Native Access" [Active]
com.sun.jna.platform (4.5.1.v20190425-1842) "Java Native Access Platform" [Resolved]
com.sun.jna.platform (5.6.0.v20200722-0209) "Java Native Access Platform" [Resolved]
com.sun.xml.bind (2.3.3.v20201118-1818) "Old JAXB Runtime" [Resolved]
com.ti.arm.18.1.help_18.1.0.20181119225258 (18.1.0) "ARM Compiler Version 18.1 User's Guides" [Resolved]
com.ti.backplane (8.0.0.202112011800) "Code Composer Tools Backplane" [Starting]
com.ti.base.ui (8.0.0.202112011800) "Common Debug Server Properties UI" [Active]
com.ti.binding.program (8.0.0.202112011800) "GUI Composer Bindings Program" [Starting]
com.ti.binding.stream (8.0.0.202112011800) "GUI Composer Streaming Model" [Starting]
com.ti.browser (8.0.0.202112011800) "Browser Wrapper" [Active]
com.ti.c2000.18.1.help_18.1.0.20180221222139 (18.1.0) "C2000 Compiler Version 18.1 User's Guides" [Resolved]
com.ti.cc2538 (2.0.4.11) "CC2538 Project Templates" [Starting]
com.ti.ccscloud.server (11.1.0.202112011800) "CCS Cloud Server" [Active]
com.ti.ccscloud.xcs (8.0.0.202112011800) "XCS" [Starting]
com.ti.ccstudio.abc (8.0.0.202112011800) "Code Composer Studio Expressions" [Starting]
com.ti.ccstudio.activities (8.0.0.202112011800) "Code Composer Studio Activities" [Starting]
com.ti.ccstudio.app.center (8.0.0.202112011800) "Code Composer Studio App Center" [Active]
com.ti.ccstudio.app.center.p2 (8.0.0.202112011800) "AppCenter Application" [Active]
com.ti.ccstudio.apps (11.0.0.202112011800) "CCS Headless Applications" [Starting]
com.ti.ccstudio.base (11.1.0.02593) "CCS Base Components" [Resolved]
com.ti.ccstudio.binaryparser (8.0.0.202112011800) "CCS Binary Parser" [Active]
com.ti.ccstudio.branding (10.0.0.202112011800) "CCS Product Branding" [Active]
com.ti.ccstudio.buildDefinitions.C2000 (11.0.0.202112011800) "CCS C2000 Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.C2000_legacy (5.1.0.202112011800) "CCS C2000 Legacy Managed Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.C5500 (8.0.0.202112011800) "CCS C5500 Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.C5500_legacy (5.1.0.202112011800) "CCS C5500 Legacy Managed Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.C6000 (11.0.0.202112011800) "CCS C6000 Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.C6000_legacy (5.1.0.202112011800) "CCS C6000 Legacy Managed Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.C7000 (11.0.0.202112011800) "CCS C7000 Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.EVE (8.0.0.202112011800) "CCS EVE Build Definitions" [Starting]
com.ti.ccstudio.builddefinitions.generator (11.0.0.202112011800) "CCS Build Definitions Generator" [Active]
com.ti.ccstudio.buildDefinitions.GNU (11.0.0.202112011800) "CCS GNU Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.GNU_legacy (5.4.0.202112011800) "CCS GNU Legacy Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.LLVM (9.1.0.202112011800) "[Legacy] CCS LLVM Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430 (11.0.0.202112011800) "CCS MSP430 Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP430_legacy (6.0.0.202112011800) "CCS MSP430 Legacy Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.MSP432 (11.0.0.202112011800) "CCS MSP432 Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.PRU (11.0.0.202112011800) "CCS PRU Build Definitions" [Starting]
com.ti.ccstudio.buildDefinitions.TICLANG (11.0.0.202112011800) "CCS TICLANG Managed Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.TMS470 (11.0.0.202112011800) "CCS TMS470 Build Definitions" [Active]
com.ti.ccstudio.buildDefinitions.TMS470_legacy (5.1.0.202112011800) "CCS TMS470 Legacy Managed Build Definitions" [Starting]
com.ti.ccstudio.controlsuite (8.0.0.202112011800) "Code Composer Studio ControlSuite" [Starting]
com.ti.ccstudio.core (11.0.0.202112011800) "Code Composer Studio Core" [Active]
com.ti.ccstudio.debug (11.0.0.202112011800) "Code Composer Studio Debug" [Active]
com.ti.ccstudio.debug.cacheView (8.0.0.202112011800) "Code Composer Studio Cache View" [Starting]
com.ti.ccstudio.debug.dsf.extensions (8.0.0.202112011800) "Code Composer Studio DSF Extensions" [Active]
com.ti.ccstudio.debug.server (8.0.0.202112011800) "CCS Debug Server" [Active]
com.ti.ccstudio.debug.server.core (8.0.0.202112011800) "CCS Debug Server Core" [Active]
com.ti.ccstudio.debug.trace.core (8.0.0.202112011800) "Trace Core" [Starting]
com.ti.ccstudio.debug.trace.msp430 (8.0.0.202112011800) "MSP430 State Storage" [Starting]
com.ti.ccstudio.debug.trace.ui (8.0.0.202112011800) "Trace UI" [Starting]
com.ti.ccstudio.debug.ui (11.1.0.202112011800) "CCS Debug UI" [Active]
com.ti.ccstudio.debug.ui.msp430 (8.0.0.202112011800) "CCS Debug User Interface for MSP430 " [Active]
com.ti.ccstudio.energia.core (10.3.0.202112011800) "Energia Core Support" [Active]
com.ti.ccstudio.energia.ui (10.0.0.202112011800) "Energia Support" [Starting]
com.ti.ccstudio.errorparser (11.0.0.202112011800) "CCS Error Parser" [Active]
com.ti.ccstudio.errorparser.ui (10.2.0.202112011800) "CCS Error Parser UI" [Active]
com.ti.ccstudio.errorreporting (8.0.0.202112011800) "CCS Error Reporting" [Active]
com.ti.ccstudio.grace (1.0.0.202003291417) "Grace" [Resolved]
com.ti.ccstudio.grace.ui (1.0.0.202003291417) "Graphical Properties UI" [Starting]
com.ti.ccstudio.help (8.0.0.202112011800) "CCS Help" [Starting]
com.ti.ccstudio.highlights (8.0.0.202112011800) "Code Composer Studio Highlights" [Starting]
com.ti.ccstudio.highlights.msp430 (8.0.0.202112011800) "Code Composer Studio MSP430 Highlights" [Starting]
com.ti.ccstudio.ide (8.0.0.202112011800) "CCS IDE" [Starting]
com.ti.ccstudio.jline (8.0.0.202112011800) "JLine Console Library" [Starting]
com.ti.ccstudio.lerm (8.0.0.202112011800) "Variables Expressions Registers Models" [Active]
com.ti.ccstudio.lers (8.0.0.202112011800) "Variables Expressions Registers Scripting" [Active]
com.ti.ccstudio.leru (8.0.0.202112011800) "Variables Expressions Registers Views" [Active]
com.ti.ccstudio.log4j (8.0.0.202112011800) "Log4j" [Resolved]
com.ti.ccstudio.multi.purpose.view (8.0.0.202112011800) "CCS Control Panel View" [Active]
com.ti.ccstudio.multi.purpose.view.contributors (8.0.0.202112011800) "Control Panel View Contributors" [Active]
com.ti.ccstudio.p2.actions (7.0.0.202001271514) "Code Composer Studio P2 Touchpoint Actions" [Starting]
com.ti.ccstudio.p2.common (7.0.0.202001271514) "Common" [Starting]
com.ti.ccstudio.p2app (8.0.0.202112011800) "CCStudio P2App" [Active]
com.ti.ccstudio.p2ui (8.0.0.202112011800) "P2ui" [Starting]
com.ti.ccstudio.project.core (11.1.0.202112011800) "CCS Project Core" [Active]
com.ti.ccstudio.project.templates (10.3.0.202112011800) "CCS Built-in Project Templates" [Starting]
com.ti.ccstudio.project.ui (11.1.0.202112011800) "CCS Project User Interface" [Active]
com.ti.ccstudio.project.ui.views (11.0.0.202112011800) "CCS Project Views" [Active]
com.ti.ccstudio.project.ui.webcontent (11.0.0.202112011800) "CCS Project Web Content" [Active]
com.ti.ccstudio.resource.explorer (8.0.0.202112011800) "TI Resource Explorer" [Starting]
com.ti.ccstudio.resource.explorer.packages (8.0.0.202112011800) "Resource Explorer Package Discovery" [Resolved]
com.ti.ccstudio.rhino (11.0.0.202112011800) "CCS Rhino JavaScript Engine" [Active]
com.ti.ccstudio.scripting.console (8.0.0.202112011800) "CCS Scripting Console" [Active]
com.ti.ccstudio.scripting.dss (8.0.0.202112011800) "Debug Server Scripting Provider" [Active]
com.ti.ccstudio.scripting.gss (10.2.0.202112011800) "User Interface Scripting Provider" [Active]
com.ti.ccstudio.scripting.ui (9.2.0.202112011800) "Base User Interface Scripting" [Active]
com.ti.ccstudio.scripting.ui.win32 (5.3.0.202112011800) "Base User Interface Scripting" [Resolved]
com.ti.ccstudio.startupInstaller (6.0.0.202001271514) "CCStudio Installer" [Active]
com.ti.ccstudio.swt (5.3.0.202112011800) "CCS SWT Fragment" [Resolved]
com.ti.ccstudio.system.hotmenu (8.0.0.202112011800) "CCS System Hotmenu Plug-in" [Active]
com.ti.ccstudio.system.setup (10.3.0.202112011800) "CCS System Setup" [Active]
com.ti.ccstudio.system.setup.ui (8.0.0.202112011800) "CCS System Setup UI" [Active]
com.ti.ccstudio.ui (10.3.0.202112011800) "CCS Platform User Interface" [Active]
com.ti.ccstudio.ui.forms (10.2.0.202112011800) "Forms Plug-in" [Starting]
com.ti.ccstudio.usersguide.doc (11.1.0.202111291008) "CCS User's Guide" [Resolved]
com.ti.ccstudio.webcontent (8.0.0.202112011800) "CCStudio WebContent" [Active]
com.ti.cgt.c6000.7.4.help (7.4.0) "C6000 Compiler Version 7.4 User's Guides" [Resolved]
com.ti.chromium.browser (2.0.0.202112011800) "Chromium Browser" [Active]
com.ti.chromium.browser.win32.win32.x86_64 (2.0.0.202112011800) "Chromium for Windows" [Resolved]
com.ti.common.core (11.0.0.202112011800) "Common TI Platform Core" [Active]
com.ti.common.core.utils.ds (8.0.0.202112011800) "Utility functions contributed by debug server" [Active]
com.ti.common.core.utils.local (8.0.0.202112011800) "Utility functions provided locally" [Starting]
com.ti.common.project.core (11.1.0.202112011800) "Common TI Project Core" [Active]
com.ti.common.project.ui (10.3.0.202112011800) "Common TI Project UI" [Active]
com.ti.common.ui (11.0.0.202112011800) "Common TI User Interface" [Active]
com.ti.dbgtrc.webapp (1.1.0.202005140757) "TI Emulators Plugin" [Active]
com.ti.dvt.analysis.framework (4.1.0.202106281057) "DVT Analysis Framework" [Active]
com.ti.dvt.analysis.suite (4.1.0.202106281057) "Analysis Suite" [Active]
com.ti.dvt.analysis.suite.gui (4.1.0.202106281057) "Analysis Suite" [Active]
com.ti.dvt.analysis.traceviewer (4.1.0.202106281057) "Trace Viewer Manager" [Active]
com.ti.dvt.analyzersuite (3.5.0.202106281057) "Analyzer Suite" [Active]
com.ti.dvt.ccstudioideadapter (4.1.0.202106281057) "CCStudio v6 IDE Adapter GUI" [Active]
com.ti.dvt.ccstudioideadapter.bin (4.1.0.202106281057) "CCStudio v6 IDE Adapter Binary" [Resolved]
com.ti.dvt.ccstudiosymbolmanager (4.1.0.202106281057) "CCStudio Symbol Manager" [Resolved]
com.ti.dvt.codecoverage (4.1.0.202106281057) "Code Coverage" [Active]
com.ti.dvt.codegenCoverage (4.1.0.202106281057) "Codegen_Code_Coverage Plug-in" [Active]
com.ti.dvt.control.engine (4.1.0.202106281057) "DVT Control Engine" [Active]
com.ti.dvt.control.gui (4.1.0.202106281057) "DVT Control GUI" [Active]
com.ti.dvt.core (4.1.0.202106281057) "DVT Core" [Active]
com.ti.dvt.coverageplugin (4.1.0.202106281057) "Coverageplugin Plug-in" [Active]
com.ti.dvt.datamodel (4.1.0.202106281057) "DVT Model" [Active]
com.ti.dvt.energytrace (4.1.0.202106281057) "EnergyTrace" [Active]
com.ti.dvt.graph.visualization (4.1.0.202106281057) "Visualization Plug-in" [Active]
com.ti.dvt.graph.visualization.doc (4.1.0.202106281057) "Graph Visualization Help  Plug-in" [Resolved]
com.ti.dvt.gridview (4.1.0.202106281057) "Gridview Plug-in" [Starting]
com.ti.dvt.ideadapter (4.1.0.202106281057) "IDEAdapter GUI" [Active]
com.ti.dvt.ideadapter2 (4.1.0.202106281057) "IDEAdapter Binary" [Resolved]
com.ti.dvt.ofssymbolmanager (4.1.0.202106281057) "OFSSymbolManager Plug-in" [Resolved]
com.ti.dvt.profile.setup.ui (4.1.0.202106281057) "Profile SetupUI Plug-in" [Starting]
com.ti.dvt.profileanalysis (4.1.0.202106281057) "DVT Profile Analysis Providers" [Resolved]
com.ti.dvt.profileanalysis.doc (4.1.0.202106281057) "DVT Profile Analysis Providers Help" [Resolved]
com.ti.dvt.profileanalysismanager (4.1.0.202106281057) "Profiler Analysis Manager" [Resolved]
com.ti.dvt.profileanalysismanagerplugin (4.1.0.202106281057) "Profile Server Plug-in" [Active]
com.ti.dvt.profiledata (4.1.0.202106281057) "Profile Data Source" [Resolved]
com.ti.dvt.rcp (3.1.0.202106281057) "DvtRcp Plug-in" [Starting]
com.ti.dvt.rovsupport (4.1.0.202106281057) "Rovsupport Plug-in" [Active]
com.ti.dvt.rovsupport.doc (4.1.0.202106281057) "ROV Support Doc Plug-in" [Resolved]
com.ti.dvt.rta.interfaces (4.1.0.202106281057) "RTA interfaces" [Resolved]
com.ti.dvt.scripting.engine (4.1.0.202106281057) "DVT Scripting Engine" [Resolved]
com.ti.dvt.scripting.ui (4.1.0.202106281057) "DVT Scripting Plugin" [Active]
com.ti.dvt.scripting.ui.graphvisualization (4.1.0.202106281057) "Visualization Scripting Plug-in" [Resolved]
com.ti.dvt.scripting.ui.profileanalysis (4.1.0.202106281057) "Profile Analysis Scripting Plug-in" [Resolved]
com.ti.dvt.scripting.ui.rov (4.1.0.202106281057) "ROV Scripting Plug-in" [Resolved]
com.ti.dvt.scripting.ui.trace (4.1.0.202106281057) "Trace Scripting Plug-in" [Resolved]
com.ti.dvt.scripting.ui.via (4.1.0.202106281057) "Image Analyzer Scripting Plug-in" [Resolved]
com.ti.dvt.server (3.62.1.16) "ROV Controller" [Starting]
com.ti.dvt.sourceref (4.1.0.202106281057) "Source Reference Plug-in" [Starting]
com.ti.dvt.sourcerefplugin (4.1.0.202106281057) "Source Reference Preference Plug-in" [Starting]
com.ti.dvt.symbolmanager (4.1.0.202106281057) "SymbolManager GUI" [Active]
com.ti.dvt.symbolmanager.bin (4.1.0.202106281057) "SymbolManager Binary" [Resolved]
com.ti.dvt.tidisassembly (4.1.0.202106281057) "TIDisassembly Plug-in" [Resolved]
com.ti.dvt.trace.doc (4.1.0.202106281057) "Trace_Analyzer_User_Guide" [Starting]
com.ti.dvt.ui (4.1.0.202106281057) "DvtUI Plug-in" [Active]
com.ti.dvt.ui.doc (4.1.0.202106281057) "com.ti.dvt.ui.doc" [Resolved]
com.ti.dvt.uia (4.1.0.202106281057) "DVT UIA GUI" [Active]
com.ti.dvt.uia.bin (4.1.0.202106281057) "DVT UIA Binary" [Resolved]
com.ti.dvt.uia.doc (4.1.0.202106281057) "System Analyzer Help" [Resolved]
com.ti.dvt.via.doc (4.1.0.202106281057) "Image Analyzer" [Starting]
com.ti.dvt.via.imvr (4.1.0.202106281057) "Image Viewer Plug-in" [Starting]
com.ti.dvt.via.plugin (4.1.0.202106281057) "Image Analyzer" [Active]
com.ti.dvt.via.plugin.ccs (4.1.0.202106281057) "Image Analyzer (CCS)" [Active]
com.ti.gui.composer.webserver.adapter (8.0.0.202112011800) "GUI Composer Web Server Adaptor" [Resolved]
com.ti.jna (8.0.0.202112011800) "JNA TI Wrapper" [Resolved]
com.ti.msp430.18.1.help_18.1.0.20181119225106 (18.1.0) "MSP430 Compiler Version 18.1 User's Guides" [Resolved]
com.ti.rex.ccsplugin (1.0.0.202106281057) "Resource Explorer" [Starting]
com.ti.rov (1.0.0.202108240702) "Runtime Object View Support" [Active]
com.ti.rta (3.62.1.16) "XDC RTA Plug-in" [Starting]
com.ti.rta.support (3.62.1.16) "Shared ROV interface implementations" [Starting]
com.ti.targets.omf (3.62.1.16) "Object file readers" [Starting]
com.ti.uia.autostart (4.1.0.202106281057) "System Analyzer Autostart" [Resolved]
com.ti.uia.autostart.view (4.1.0.202106281057) "System Analyzer Welcome" [Active]
com.ti.uia.globaltimebase (1.0.0.202106281057) "Globaltimebase" [Resolved]
com.ti.uia.sessionmgr.view (4.1.0.202106281057) "UIA Session Mgr View Plugin" [Active]
com.ti.uia.transport.jtag (4.1.0.202106281057) "Jtag Transport" [Resolved]
com.ti.uia.transport.monitor (4.1.0.202106281057) "UIA Transport Monitor" [Starting]
com.ti.util (4.1.0.202106281057) "Util Plug-in" [Resolved]
com.ti.util.diskspacemonitor (4.1.0.202106281057) "Diskspacemonitor GUI" [Active]
com.ti.util.diskspacemonitor.bin (4.1.0.202106281057) "Diskspacemonitor Binary" [Resolved]
com.ti.util.ui (4.1.0.202106281057) "Util Plug-in" [Active]
com.ti.xdctools_3_62.base (3.62.1.16) "XDCtools Core Install Plugin" [Resolved]
com.ti.xdctools_3_62.win32 (3.62.1.16) "XDCtools Core - native win64 binaries" [Resolved]
gnu.io.rxtx (2.1.8.0_201606281300) "RXTX" [Resolved]
jakarta.xml.bind (2.3.3.v20201118-1818) "Jakarta XML Binding API" [Resolved]
javaewah (1.1.7.v20200107-0831) "javaewah" [Resolved]
javax.activation (1.2.2.v20201119-1642) "Jakarta Activation" [Resolved]
javax.annotation (1.3.5.v20200909-1856) "Jakarta Annotations API" [Resolved]
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle" [Resolved]
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations" [Resolved]
javax.servlet (3.1.0.v201410161800) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle" [Resolved]
javax.xml (1.3.4.v201005080400) "JAXP XML" [Resolved]
net.i2p.crypto.eddsa (0.3.0.v20181102-1323) "EdDSA-Java" [Resolved]
org.apache.ant (1.10.9.v20201106-1946) "Apache Ant" [Resolved]
org.apache.batik.bridge (1.6.0.v201011041432) "Apache Batik Bridge/GVT/Scripting" [Resolved]
org.apache.batik.constants (1.13.0.v20200622-2037) "Batik constants library" [Resolved]
org.apache.batik.css (1.13.0.v20200622-2037) "Batik CSS engine" [Resolved]
org.apache.batik.css (1.6.0.v201011041432) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.1.v201505192100) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v201011041432) "Apache Batik SVG DOM" [Resolved]
org.apache.batik.ext.awt (1.6.0.v201011041432) "Apache Batik AWT Utilities" [Resolved]
org.apache.batik.i18n (1.13.0.v20200622-2037) "Batik i18n library" [Resolved]
org.apache.batik.parser (1.6.0.v201011041432) "Apache Batik Parser" [Resolved]
org.apache.batik.pdf (1.6.0.v201105071520) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v201011041432) "Apache Batik SVG Generation" [Resolved]
org.apache.batik.transcoder (1.6.0.v201011041432) "Apache Batik Transcoder" [Resolved]
org.apache.batik.util (1.13.0.v20200622-2037) "Batik utility library" [Resolved]
org.apache.batik.util (1.6.0.v201011041432) "Apache Batik Utilities" [Resolved]
org.apache.batik.util.gui (1.6.0.v201011041432) "Apache Batik GUI Utilities" [Resolved]
org.apache.batik.xml (1.6.0.v201011041432) "Apache Batik XML" [Resolved]
org.apache.commons.codec (1.14.0.v20200818-1422) "Apache Commons Codec" [Resolved]
org.apache.commons.compress (1.19.0.v20200106-2343) "Apache Commons Compress" [Resolved]
org.apache.commons.io (2.6.0.v20190123-2029) "Apache Commons IO" [Resolved]
org.apache.commons.io (8.0.0.202112011800) "org.apache.commons.fileupload" [Resolved]
org.apache.commons.jxpath (1.3.0.v200911051830) "Apache Commons JXPath" [Resolved]
org.apache.commons.logging (1.2.0.v20180409-1502) "Apache Commons Logging" [Resolved]
org.apache.commons.net (3.2.0.v201305141515) "Apache Commons Net" [Resolved]
org.apache.felix.gogo.command (1.1.2.v20210111-1007) "Apache Felix Gogo Command" [Active]
org.apache.felix.gogo.runtime (1.1.4.v20210111-1007) "Apache Felix Gogo Runtime" [Active]
org.apache.felix.gogo.shell (1.1.4.v20210111-1007) "Apache Felix Gogo Shell" [Active]
org.apache.felix.scr (2.1.24.v20200924-1939) "Apache Felix Declarative Services" [Active]
org.apache.httpcomponents.httpclient (4.5.10.v20200830-2311) "Apache HttpClient" [Resolved]
org.apache.httpcomponents.httpclient.win (4.5.10.v20200830-2311) "Apache HttpClient Windows features" [Resolved]
org.apache.httpcomponents.httpcore (4.4.12.v20200108-1212) "Apache HttpCore" [Resolved]
org.apache.jasper.glassfish (2.2.2.v201501141630) "JSP 2.2 implementation from Glassfish" [Resolved]
org.apache.log4j (1.2.15.v201012070815) "Apache Jakarta log4j Plug-in" [Resolved]
org.apache.lucene.analyzers-common (8.4.1.v20200122-1459) "Lucene Common Analyzers" [Resolved]
org.apache.lucene.analyzers-smartcn (8.4.1.v20200122-1459) "Lucene Smart Chinese Analyzer" [Resolved]
org.apache.lucene.core (8.4.1.v20200122-1459) "Lucene Core" [Resolved]
org.apache.sshd.osgi (2.6.0.v20210201-2003) "Apache Mina SSHD :: OSGi" [Resolved]
org.apache.sshd.sftp (2.6.0.v20210201-2003) "Apache Mina SSHD :: SFTP" [Resolved]
org.apache.xerces (2.9.0.v201101211617) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v201005080400) "Apache XmlResolver" [Resolved]
org.apache.xml.serializer (2.7.1.v201005080400) "Apache XML Commons Serializer" [Resolved]
org.apache.xmlgraphics (2.4.0.v20200622-2037) "Apache XML Graphics Commons" [Resolved]
org.bouncycastle.bcpg (1.65.0.v20200527-1955) "Bouncy Castle OpenPGP API" [Resolved]
org.bouncycastle.bcprov (1.65.1.v20200529-1514) "Bouncy Castle Provider" [Resolved]
org.eclipse.ant.core (3.5.800.v20200608-1251) "Ant Build Tool Core" [Active]
org.eclipse.cdt (10.2.0.202012191711) "Eclipse C/C++ Development Tools" [Starting]
org.eclipse.cdt.build.crossgcc (1.2.200.202102261947) "CDT GCC Cross Compiler Support" [Active]
org.eclipse.cdt.build.gcc.core (1.1.0.202008310002) "GCC support for CDT Build Core" [Starting]
org.eclipse.cdt.build.gcc.ui (1.1.0.202008310002) "GCC ToolChain Support UI" [Starting]
org.eclipse.cdt.codan.checkers (3.4.100.202010121414) "Codan Checkers" [Active]
org.eclipse.cdt.codan.checkers.ui (3.3.0.202008310002) "Codan Checkers UI" [Starting]
org.eclipse.cdt.codan.core (4.1.100.202010121414) "Code Analysis Core" [Active]
org.eclipse.cdt.codan.core.cxx (3.5.100.202011201553) "Code Analysis Core for C/C++" [Active]
org.eclipse.cdt.codan.ui (3.4.100.202011201553) "Code Analysis UI" [Active]
org.eclipse.cdt.codan.ui.cxx (3.6.0.202008310002) "Codan Analysis UI for C/C++" [Active]
org.eclipse.cdt.core (7.2.0.202102251239) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.native (6.1.100.202102030214) "C/C++ Development Tools Core Native Utilities" [Active]
org.eclipse.cdt.core.win32 (6.0.200.202102030214) "C/C++ Development Tools Core Native Utilities for Windows" [Resolved]
org.eclipse.cdt.core.win32.x86_64 (6.0.100.202011060124) "C/C++ Development Tools Core Native Utilities for Windows (x86_64)" [Resolved]
org.eclipse.cdt.debug.core (8.6.0.202011181638) "C/C++ Development Tools Debug Model" [Active]
org.eclipse.cdt.debug.core.memory (0.1.100.202012012315) "Debug Core Memory" [Resolved]
org.eclipse.cdt.debug.ui (8.4.100.202011181638) "C/C++ Development Tools Debugger UI" [Active]
org.eclipse.cdt.debug.ui.memory.floatingpoint (1.1.0.202008310002) "Floating Point Memory Renderer" [Starting]
org.eclipse.cdt.debug.ui.memory.memorybrowser (1.4.100.202011181638) "Memory Browser" [Starting]
org.eclipse.cdt.debug.ui.memory.search (1.4.0.202008310002) "Memory Search" [Starting]
org.eclipse.cdt.debug.ui.memory.traditional (1.6.100.202011181638) "Traditional Memory Rendering" [Starting]
org.eclipse.cdt.debug.ui.memory.transport (2.2.0.202008310002) "Memory Transport Plug-in" [Starting]
org.eclipse.cdt.doc.user (5.4.700.202012191711) "C/C++ Development User Guide" [Starting]
org.eclipse.cdt.dsf (2.10.100.202012191801) "Debug Services Framework Core" [Active]
org.eclipse.cdt.dsf.gdb (6.2.0.202102231601) "GDB DSF Debugger Integration Core" [Active]
org.eclipse.cdt.dsf.gdb.ui (2.7.100.202011181638) "GDB DSF Debugger Integration UI" [Active]
org.eclipse.cdt.dsf.ui (2.6.100.202011291939) "Debugger Services Framework UI" [Active]
org.eclipse.cdt.flatpak.launcher (1.0.100.202101160252) "C/C++ Flatpak Launch Plug-in" [Active]
org.eclipse.cdt.gdb (7.1.0.202008310002) "GDB Common" [Starting]
org.eclipse.cdt.gdb.ui (7.1.0.202008310002) "GDB UI Common" [Starting]
org.eclipse.cdt.launch (10.2.100.202012191801) "C/C++ Development Tools Launching Support" [Starting]
org.eclipse.cdt.launch.remote (2.6.0.202008310002) "C/C++ Remote Debug Launcher" [Starting]
org.eclipse.cdt.make.core (7.5.100.202011171450) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (8.0.100.202011181841) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (9.2.0.202103011047) "CDT Build System Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (8.4.0.202008310002) "GNU Managed Build Definitions" [Starting]
org.eclipse.cdt.managedbuilder.headlessbuilderapp (1.0.0.202103010740) "CDT Headless Builder Application" [Starting]
org.eclipse.cdt.managedbuilder.ui (9.3.0.202012011707) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.native.serial (1.2.100.202011111956) "Serial Port" [Resolved]
org.eclipse.cdt.platform.branding (10.2.0.202103010740) "C/C++ Development Platform" [Resolved]
org.eclipse.cdt.ui (7.1.100.202101112014) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.7.1300.v20210114-0707) "Compare Support" [Active]
org.eclipse.compare.core (3.6.1000.v20201020-1107) "Core Compare Support" [Active]
org.eclipse.compare.win32 (1.2.800.v20200127-1343) "Compare Support for Word" [Starting]
org.eclipse.core.commands (3.9.800.v20201021-1339) "Commands" [Resolved]
org.eclipse.core.contenttype (3.7.900.v20210111-0918) "Eclipse Content Mechanism" [Active]
org.eclipse.core.databinding (1.10.100.v20200926-1123) "JFace Data Binding" [Starting]
org.eclipse.core.databinding.beans (1.7.200.v20210111-0759) "JFace Data Binding for JavaBeans" [Resolved]
org.eclipse.core.databinding.observable (1.10.0.v20200730-0848) "JFace Data Binding Observables" [Resolved]
org.eclipse.core.databinding.property (1.8.100.v20200619-0651) "JFace Data Binding Properties" [Starting]
org.eclipse.core.expressions (3.7.100.v20210203-1000) "Expression Language" [Active]
org.eclipse.core.externaltools (1.1.800.v20201105-0600) "External Tools Headless Support" [Starting]
org.eclipse.core.filebuffers (3.6.1100.v20201029-1159) "File Buffers" [Resolved]
org.eclipse.core.filesystem (1.7.700.v20200110-1734) "Core File Systems" [Active]
org.eclipse.core.filesystem.win32.x86_64 (1.4.200.v20190812-0909) "Core File System for Windows 64 bit" [Resolved]
org.eclipse.core.jobs (3.10.1100.v20210111-0815) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.3.1000.v20200715-0827) "Internet Connection Management" [Active]
org.eclipse.core.net.win32.x86_64 (1.1.500.v20190925-1337) "Proxy for Windows" [Resolved]
org.eclipse.core.resources (3.14.0.v20210215-0934) "Core Resource Management" [Active]
org.eclipse.core.resources.win32.x86_64 (3.5.400.v20190812-0909) "Core Resource Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.20.100.v20210111-0815) "Core Runtime" [Active]
org.eclipse.core.variables (3.4.800.v20200120-1101) "Core Variables" [Active]
org.eclipse.debug.core (3.18.0.v20210222-1101) "Debug Core" [Active]
org.eclipse.debug.ui (3.14.800.v20210222-1101) "Debug UI" [Active]
org.eclipse.draw2d (3.10.100.201606061308) "Draw2d" [Starting]
org.eclipse.dstore.core (4.5.300.202101081027) "RSE DStore Core" [Starting]
org.eclipse.dstore.extra (4.5.300.202101081027) "RSE DStore Platform Support" [Starting]
org.eclipse.e4.core.commands (0.13.0.v20201119-1132) "Eclipse e4 core commands" [Resolved]
org.eclipse.e4.core.contexts (1.8.400.v20191217-1710) "Eclipse Contexts" [Active]
org.eclipse.e4.core.di (1.7.700.v20210128-2123) "Eclipse Dependency Injection" [Active]
org.eclipse.e4.core.di.annotations (1.6.600.v20191216-2352) "Eclipse Dependency Injection Annotations" [Resolved]
org.eclipse.e4.core.di.extensions (0.16.0.v20200507-0938) "Eclipse Dependency Injection Extensions" [Active]
org.eclipse.e4.core.di.extensions.supplier (0.15.800.v20210110-1654) "Eclipse Dependency Injection Extensions Supplier" [Active]
org.eclipse.e4.core.services (2.2.600.v20210110-1654) "Eclipse Application Services" [Active]
org.eclipse.e4.emf.xpath (0.2.800.v20200609-0849) "Eclipse Model Xpath" [Resolved]
org.eclipse.e4.ui.bindings (0.13.0.v20201119-1132) "Eclipse Bindings Support" [Active]
org.eclipse.e4.ui.css.core (0.13.0.v20201015-0653) "Eclipse CSS Core Support" [Resolved]
org.eclipse.e4.ui.css.swt (0.14.100.v20201217-1340) "Eclipse CSS SWT Support" [Active]
org.eclipse.e4.ui.css.swt.theme (0.13.0.v20201026-1147) "Eclipse CSS SWT Theme Support" [Active]
org.eclipse.e4.ui.di (1.3.0.v20210222-1018) "Eclipse UI Dependency Injection" [Active]
org.eclipse.e4.ui.dialogs (1.2.100.v20201109-2317) "Eclipse e4 dialogs" [Resolved]
org.eclipse.e4.ui.ide (3.15.200.v20210108-1832) "E4 IDE UI" [Resolved]
org.eclipse.e4.ui.model.workbench (2.1.1000.v20210111-0958) "Eclipse Workbench Model" [Active]
org.eclipse.e4.ui.services (1.5.0.v20210115-1333) "Eclipse UI Application Services" [Active]
org.eclipse.e4.ui.swt.win32 (1.1.0.v20201119-1132) "Eclipse UI WIN32 Enhancements" [Resolved]
org.eclipse.e4.ui.widgets (1.2.800.v20201021-1339) "Eclipse UI Custom widgets" [Resolved]
org.eclipse.e4.ui.workbench (1.12.100.v20210122-1731) "Eclipse e4 Workbench" [Active]
org.eclipse.e4.ui.workbench.addons.swt (1.4.100.v20201221-2332) "Eclipse e4 Workbench Add-ons" [Active]
org.eclipse.e4.ui.workbench.renderers.swt (0.15.0.v20201125-0918) "Eclipse e4 Workbench SWT Renderer" [Active]
org.eclipse.e4.ui.workbench.swt (0.16.0.v20201230-1610) "Eclipse e4 Workbench SWT" [Active]
org.eclipse.e4.ui.workbench3 (0.15.500.v20201021-1339) "Bundle for Workbench APIs available in e4" [Resolved]
org.eclipse.ecf (3.9.101.v20201027-0547) "ECF Core API" [Active]
org.eclipse.ecf.filetransfer (5.1.101.v20201025-2315) "ECF Filetransfer API" [Active]
org.eclipse.ecf.identity (3.9.401.v20201027-0550) "ECF Identity Core API" [Active]
org.eclipse.ecf.provider.filetransfer (3.2.601.v20201025-0700) "ECF Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient45 (1.0.301.v20201025-0700) "ECF HttpComponents 4.5 Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.httpclient45.win32 (1.0.300.v20200816-1842) "ECF HttpComponents 4.5 Filetransfer Windows Components" [Active]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.200.v20200611-1836) "ECF Filetransfer Provider" [Resolved]
org.eclipse.ecf.ssl (1.2.400.v20200611-2220) "ECF Core API" [Resolved]
org.eclipse.egit (5.11.0.202103091610-r) "Git integration for Eclipse" [Starting]
org.eclipse.egit.core (5.11.0.202103091610-r) "Git integration for Eclipse - Core" [Active]
org.eclipse.egit.doc (5.11.0.202103091610-r) "Git integration for Eclipse - Documentation" [Starting]
org.eclipse.egit.ui (5.11.0.202103091610-r) "Git integration for Eclipse - UI" [Active]
org.eclipse.emf.common (2.22.0.v20210114-1734) "EMF Common" [Active]
org.eclipse.emf.ecore (2.23.0.v20200630-0516) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.14.0.v20190528-0725) "EMF Change Model" [Starting]
org.eclipse.emf.ecore.xmi (2.16.0.v20190528-0725) "EMF XML/XMI Persistence" [Active]
org.eclipse.epp.mpc.core (1.9.1.v20210204-1408) "Marketplace Client Core" [Active]
org.eclipse.epp.mpc.core.win32 (1.9.1.v20210204-1338) "Marketplace Client Core Win32 Proxy Support" [Starting]
org.eclipse.epp.mpc.help.ui (1.9.1.v20210204-1408) "Marketplace Client Help" [Resolved]
org.eclipse.epp.mpc.ui (1.9.1.v20210204-1408) "Marketplace Client" [Active]
org.eclipse.epp.mpc.ui.css (1.9.1.v20210204-1408) "Marketplace Client Theme Support" [Active]
org.eclipse.equinox.app (1.5.100.v20210212-1143) "Equinox Application Container" [Active]
org.eclipse.equinox.bidi (1.3.100.v20210212-1143) "Bidirectional Text Support" [Starting]
org.eclipse.equinox.common (3.14.100.v20210212-1143) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.concurrent (1.2.0.v20210202-1157) "Equinox Concurrent API" [Active]
org.eclipse.equinox.console (1.4.300.v20210211-2058) "Console plug-in" [Active]
org.eclipse.equinox.event (1.6.0.v20210212-1143) "Event Admin" [Active]
org.eclipse.equinox.frameworkadmin (2.1.400.v20191002-0702) "Equinox Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.1.400.v20200319-1546) "Equinox Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (3.7.600.v20210224-2143) "Jetty Http Service" [Starting]
org.eclipse.equinox.http.registry (1.2.0.v20200614-1851) "Http Service Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.7.0.v20210202-1229) "Http Services Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.1.500.v20200422-1833) "Jasper Jsp Support Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.1.400.v20200422-1833) "Jasper Jsp Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.6.100.v20201223-0822) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86_64 (1.2.100.v20210209-1541) "Equinox Launcher Win32 X86_64 Fragment" [Resolved]
org.eclipse.equinox.p2.artifact.repository (1.4.0.v20210129-2007) "Equinox Provisioning Artifact Repository Support" [Active]
org.eclipse.equinox.p2.console (1.1.500.v20210116-1227) "Equinox Provisioning Console" [Starting]
org.eclipse.equinox.p2.core (2.6.300.v20200211-1504) "Equinox Provisioning Core" [Active]
org.eclipse.equinox.p2.director (2.4.700.v20200511-1530) "Equinox Provisioning Director" [Active]
org.eclipse.equinox.p2.director.app (1.1.600.v20200511-1530) "Equinox Provisioning Director Application" [Starting]
org.eclipse.equinox.p2.directorywatcher (1.2.500.v20191211-1631) "Equinox Provisioning Directory Watcher" [Active]
org.eclipse.equinox.p2.discovery (1.1.200.v20190611-1008) "Equinox Provisioning Discovery" [Resolved]
org.eclipse.equinox.p2.discovery.compatibility (1.2.0.v20200916-1234) "Equinox Provisioning Discovery" [Starting]
org.eclipse.equinox.p2.engine (2.6.700.v20200511-1530) "Equinox Provisioning Engine" [Active]
org.eclipse.equinox.p2.extensionlocation (1.3.400.v20191213-1911) "Equinox Provisioning Extension Location Repository Support" [Active]
org.eclipse.equinox.p2.garbagecollector (1.1.400.v20200221-1022) "Equinox Provisioning Garbage Collector" [Active]
org.eclipse.equinox.p2.jarprocessor (1.1.700.v20210227-0235) "Equinox Provisioning JAR Processor" [Resolved]
org.eclipse.equinox.p2.metadata (2.5.100.v20200908-1020) "Equinox Provisioning Metadata" [Active]
org.eclipse.equinox.p2.metadata.repository (1.3.500.v20210108-0738) "Equinox Provisioning Metadata Repository" [Active]
org.eclipse.equinox.p2.operations (2.5.1000.v20201106-1246) "Equinox Provisioning Operations API" [Active]
org.eclipse.equinox.p2.publisher (1.5.500.v20210211-1133) "Equinox Provisioning Publisher Infrastructure" [Active]
org.eclipse.equinox.p2.publisher.eclipse (1.3.800.v20210205-1231) "Equinox Provisioning Publisher for Eclipse" [Starting]
org.eclipse.equinox.p2.reconciler.dropins (1.3.500.v20210116-1855) "Equinox Provisioning Drop-in" [Active]
org.eclipse.equinox.p2.repository (2.5.0.v20201013-0853) "Equinox Provisioning Repository" [Active]
org.eclipse.equinox.p2.repository.tools (2.2.600.v20210114-1107) "Equinox Provisioning Repository Tools" [Starting]
org.eclipse.equinox.p2.touchpoint.eclipse (2.2.800.v20210115-1344) "Equinox Provisioning Eclipse Touchpoint" [Active]
org.eclipse.equinox.p2.touchpoint.natives (1.3.600.v20200511-1530) "Equinox Provisioning Native Touchpoint" [Starting]
org.eclipse.equinox.p2.transport.ecf (1.3.0.v20201012-1345) "Equinox Provisioning ECF based Transport" [Active]
org.eclipse.equinox.p2.ui (2.7.0.v20210114-1216) "Equinox Provisioning UI Support" [Active]
org.eclipse.equinox.p2.ui.discovery (1.2.0.v20200916-1234) "Equinox Provisioning Discovery UI" [Resolved]
org.eclipse.equinox.p2.ui.importexport (1.3.0.v20210217-1009) "Equinox Provisioning Import and Export" [Starting]
org.eclipse.equinox.p2.ui.sdk (1.2.0.v20210114-1214) "Equinox Provisioning Platform Update Support" [Active]
org.eclipse.equinox.p2.ui.sdk.scheduler (1.5.0.v20201012-1421) "Equinox Provisioning Platform Automatic Update Support" [Active]
org.eclipse.equinox.p2.updatechecker (1.2.300.v20200222-1600) "Equinox Provisioning Update Checker" [Active]
org.eclipse.equinox.p2.updatesite (1.1.500.v20210108-0738) "Equinox Provisioning Legacy Update Site Support" [Starting]
org.eclipse.equinox.preferences (3.8.200.v20210212-1143) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.10.100.v20210212-1143) "Extension Registry Support" [Active]
org.eclipse.equinox.security (1.3.600.v20210126-1005) "Equinox Java Authentication and Authorization Service (JAAS)" [Active]
org.eclipse.equinox.security.ui (1.3.0.v20210121-0947) "Equinox Security Default UI" [Starting]
org.eclipse.equinox.security.win32.x86_64 (1.1.200.v20190812-0919) "Windows Data Protection services integration (64 bit)" [Resolved]
org.eclipse.equinox.simpleconfigurator (1.3.600.v20200721-1308) "Simple Configurator" [Active]
org.eclipse.equinox.simpleconfigurator.manipulator (2.1.500.v20200211-1505) "Simple Configurator Manipulator" [Starting]
org.eclipse.gef (3.11.0.201606061308) "GEF (MVC)" [Starting]
org.eclipse.help (3.8.800.v20200525-0755) "Help System Core" [Active]
org.eclipse.help.base (4.3.200.v20210303-1800) "Help System Base" [Starting]
org.eclipse.help.ui (4.2.200.v20210123-1004) "Help System UI" [Starting]
org.eclipse.help.webapp (3.10.200.v20210222-1057) "Help System Webapp" [Starting]
org.eclipse.jetty.continuation (9.4.37.v20210219) "Jetty :: Continuation" [Resolved]
org.eclipse.jetty.http (9.4.37.v20210219) "Jetty :: Http Utility" [Resolved]
org.eclipse.jetty.io (9.4.37.v20210219) "Jetty :: IO Utility" [Resolved]
org.eclipse.jetty.security (9.4.37.v20210219) "Jetty :: Security" [Resolved]
org.eclipse.jetty.server (9.4.37.v20210219) "Jetty :: Server Core" [Resolved]
org.eclipse.jetty.servlet (9.4.37.v20210219) "Jetty :: Servlet Handling" [Resolved]
org.eclipse.jetty.util (9.4.37.v20210219) "Jetty :: Utilities" [Resolved]
org.eclipse.jetty.util.ajax (9.4.37.v20210219) "Jetty :: Utilities :: Ajax(JSON)" [Resolved]
org.eclipse.jface (3.22.100.v20210126-0831) "JFace" [Resolved]
org.eclipse.jface.databinding (1.12.200.v20210111-0911) "JFace Data Binding for SWT and JFace" [Resolved]
org.eclipse.jface.notifications (0.3.0.v20210218-1820) "Notification API" [Resolved]
org.eclipse.jface.text (3.17.0.v20210213-0904) "JFace Text" [Resolved]
org.eclipse.jgit (5.11.0.202103091610-r) "JGit Core" [Resolved]
org.eclipse.jgit.archive (5.11.0.202103091610-r) "JGit Archive Formats" [Starting]
org.eclipse.jgit.gpg.bc (5.11.0.202103091610-r) "JGit Core" [Resolved]
org.eclipse.jgit.http.apache (5.11.0.202103091610-r) "JGit Apache httpclient based HTTP support" [Active]
org.eclipse.jgit.ssh.apache (5.11.0.202103091610-r) "JGit SSH support based on Apache MINA sshd" [Active]
org.eclipse.jsch.core (1.3.900.v20200422-1935) "JSch Core" [Active]
org.eclipse.jsch.ui (1.3.1100.v20200916-0731) "JSch UI" [Starting]
org.eclipse.launchbar.core (2.4.100.202010121414) "LaunchBar Core" [Active]
org.eclipse.launchbar.ui (2.4.100.202012041937) "LaunchBar UI" [Starting]
org.eclipse.ltk.core.refactoring (3.11.300.v20210208-1217) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.11.300.v20210112-0706) "Refactoring UI" [Active]
org.eclipse.osgi (3.16.200.v20210226-1447) "OSGi System Bundle" [Active]
org.eclipse.osgi.compatibility.state (1.2.300.v20210212-1137) "Equinox State and Resolver Compatibility Fragment" [Resolved]
org.eclipse.osgi.services (3.10.0.v20210212-1137) "OSGi Release 4.2.0 Services" [Resolved]
org.eclipse.osgi.util (3.6.0.v20210212-1137) "OSGi Release 4.2.0 Utility Classes" [Resolved]
org.eclipse.platform (4.19.0.v20210303-1800) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (4.19.0.v20210303-0957) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (4.19.0.v20210303-1800) "Eclipse RCP" [Starting]
org.eclipse.remote.console (1.2.0.201909031456) "Remote Console" [Starting]
org.eclipse.remote.core (4.0.0.201909031456) "Remote Services Core" [Starting]
org.eclipse.remote.doc.isv (1.0.0.201909031456) "Eclipse Remote Development documentation plug-in" [Resolved]
org.eclipse.remote.jsch.core (1.0.0.201909031456) "JSch Remote Support" [Starting]
org.eclipse.remote.jsch.ui (1.0.0.201909031456) "JSch UI Remote Support" [Starting]
org.eclipse.remote.serial.core (1.0.0.201909031456) "Remote Serial Port Services" [Starting]
org.eclipse.remote.serial.ui (1.0.0.201909031456) "Remote Serial Port Services UI" [Starting]
org.eclipse.remote.telnet.core (1.0.0.201909031456) "Remote Serial Port Services" [Starting]
org.eclipse.remote.telnet.ui (1.0.0.201909031456) "Remote Serial Port Services UI" [Starting]
org.eclipse.remote.ui (2.1.1.201909031456) "Remote Services UI" [Starting]
org.eclipse.rse (4.5.300.202101081027) "Remote System Explorer End-User Runtime" [Resolved]
org.eclipse.rse.connectorservice.dstore (4.5.300.202101081027) "RSE DStore Connector Service" [Starting]
org.eclipse.rse.connectorservice.local (4.5.300.202101081027) "RSE Local Connector Service" [Active]
org.eclipse.rse.connectorservice.ssh (4.5.300.202101081027) "RSE SSH Connector Service" [Starting]
org.eclipse.rse.connectorservice.telnet (4.5.300.202101081027) "RSE Telnet Connector Service" [Starting]
org.eclipse.rse.core (4.5.300.202101081027) "RSE Core" [Active]
org.eclipse.rse.doc.user (4.5.300.202101081027) "RSE User Guide" [Resolved]
org.eclipse.rse.dstore.security (4.5.300.202101081027) "RSE DStore SSL Support" [Starting]
org.eclipse.rse.efs (4.5.300.202101081027) "RSE Eclipse Filesystem (EFS) Provider" [Starting]
org.eclipse.rse.efs.ui (4.5.300.202101081027) "RSE Eclipse Filesystem (EFS) Provider UI Support" [Resolved]
org.eclipse.rse.files.ui (4.5.300.202101081027) "RSE Files UI" [Active]
org.eclipse.rse.importexport (4.5.101.201904091623) "RSE Import/Export" [Starting]
org.eclipse.rse.processes.ui (4.5.300.202101081027) "RSE Processes UI" [Starting]
org.eclipse.rse.services (4.5.300.202101081027) "RSE Services Framework" [Active]
org.eclipse.rse.services.dstore (4.5.300.202101081027) "RSE DStore Services" [Starting]
org.eclipse.rse.services.files.ftp (4.5.300.202101081027) "RSE FTP Service" [Starting]
org.eclipse.rse.services.local (4.5.300.202101081027) "RSE Local Services" [Active]
org.eclipse.rse.services.ssh (4.5.300.202101081027) "RSE SSH Services" [Starting]
org.eclipse.rse.services.telnet (4.5.300.202101081027) "RSE Telnet Service" [Starting]
org.eclipse.rse.shells.ui (4.5.300.202101081027) "RSE Shells UI" [Starting]
org.eclipse.rse.subsystems.files.core (4.5.300.202101081027) "RSE Files Core" [Active]
org.eclipse.rse.subsystems.files.dstore (4.5.300.202101081027) "RSE DStore Files" [Starting]
org.eclipse.rse.subsystems.files.ftp (4.5.300.202101081027) "RSE FTP Files" [Starting]
org.eclipse.rse.subsystems.files.local (4.5.300.202101081027) "RSE Local Files" [Active]
org.eclipse.rse.subsystems.files.ssh (4.5.300.202101081027) "RSE SSH Files" [Starting]
org.eclipse.rse.subsystems.processes.core (4.5.300.202101081027) "RSE Processes Core" [Starting]
org.eclipse.rse.subsystems.processes.dstore (4.5.300.202101081027) "RSE DStore Processes" [Starting]
org.eclipse.rse.subsystems.processes.local (4.5.300.202101081027) "RSE Local Processes" [Starting]
org.eclipse.rse.subsystems.processes.shell.linux (4.5.300.202101081027) "RSE Linux Shell Processes" [Starting]
org.eclipse.rse.subsystems.shells.core (4.5.300.202101081027) "RSE Shells Core" [Active]
org.eclipse.rse.subsystems.shells.dstore (4.5.300.202101081027) "RSE DStore Shells" [Starting]
org.eclipse.rse.subsystems.shells.local (4.5.300.202101081027) "RSE Local Shells" [Active]
org.eclipse.rse.subsystems.shells.ssh (4.5.300.202101081027) "RSE SSH Shells" [Starting]
org.eclipse.rse.subsystems.shells.telnet (4.5.300.202101081027) "RSE Telnet Shells" [Starting]
org.eclipse.rse.ui (4.5.300.202101081027) "RSE UI" [Active]
org.eclipse.rtsc.project.templates (3.62.1.16) "RTSC Built-in Project Templates" [Starting]
org.eclipse.rtsc.xdctools.adapter (3.62.1.16) "Adapter" [Active]
org.eclipse.rtsc.xdctools.adapter.ccsplugin (1.0.0.202003291417) "Ccsplugin" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions (9.2.0.202112011800) "RTSC Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS (10.1.0.202112011800) "DSP/BIOS Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31 (8.2.0.202112011800) "DSP/BIOS v5.31 Managed Build Definitions" [Starting]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40 (8.2.0.202112011800) "DSP/BIOS v5.40 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.42 (8.2.0.202112011800) "DSP/BIOS v5.42 Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC (10.1.0.202112011800) "XDC Managed Build Definitions" [Active]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00 (10.0.0.202112011800) "XDC v3.00 Managed Build Definitions" [Starting]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10 (10.0.0.202112011800) "XDC v3.10 Managed Build Definitions" [Starting]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15 (10.0.0.202112011800) "XDC v3.15 Managed Build Definitions" [Starting]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16 (10.0.0.202112011800) "XDC v3.16 Managed Build Definitions" [Starting]
org.eclipse.rtsc.xdctools.buildDefinitions.XDC.minimal (10.1.0.202112011800) "XDC Managed Build Definitions (Minimal)" [Active]
org.eclipse.rtsc.xdctools.contenttype (3.62.1.16) "RTSC file content describers" [Resolved]
org.eclipse.rtsc.xdctools.core (3.62.1.16) "XDCtools core" [Starting]
org.eclipse.rtsc.xdctools.managedbuild.core (11.0.0.202112011800) "RTSC Managed Build Core" [Active]
org.eclipse.rtsc.xdctools.managedbuild.ui (10.0.0.202112011800) "RTSC Managed Build UI" [Active]
org.eclipse.rtsc.xdctools.model (3.62.1.16) "Model Plug-in" [Active]
org.eclipse.rtsc.xdctools.model.scripting (3.62.1.16) "Scripting" [Resolved]
org.eclipse.rtsc.xdctools.parsers (3.62.1.16) "Parsers Plug-in" [Active]
org.eclipse.rtsc.xdctools.product_3.62.1.16 (3.62.1.16) "XDCtools Embedded Runtime Content" [Starting]
org.eclipse.rtsc.xdctools.product.ui (3.62.1.16) "XDCtools IDE Tooling" [Starting]
org.eclipse.rtsc.xdctools.rta (3.62.1.16) "XDCtools RTA" [Starting]
org.eclipse.rtsc.xdctools.server (3.62.1.16) "XDCscript command server" [Starting]
org.eclipse.rtsc.xdctools.sg (3.62.1.16) "XDCtools SG  Plug-in" [Starting]
org.eclipse.rtsc.xdctools.sg.def (3.62.1.16) "XDCtools SG Def Plug-in" [Starting]
org.eclipse.rtsc.xdctools.ui (3.62.1.16) "Eclipse Plug-in" [Active]
org.eclipse.rtsc.xdctools.ui.cdt (3.62.1.16) "Eclipse Plug-in" [Starting]
org.eclipse.rtsc.xdctools.ui.contentassist (3.62.1.16) "RTSC C/C++ Content Assist" [Starting]
org.eclipse.rtsc.xdctools.ui.editors (3.62.1.16) "Editors Plug-in" [Starting]
org.eclipse.search (3.13.0.v20210212-0759) "Search Support" [Active]
org.eclipse.swt (3.116.0.v20210302-1107) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.browser.chromium.win32.win32.x86_64 (3.116.0.v20210302-1107) "Chromium SWT Widget for Windows" [Resolved]
org.eclipse.swt.win32.win32.x86_64 (3.116.0.v20210302-1107) "Standard Widget Toolkit for Windows" [Resolved]
org.eclipse.team.core (3.8.1100.v20200806-0621) "Team Support Core" [Active]
org.eclipse.team.genericeditor.diff.extension (1.0.600.v20200212-1524) "Diff Extension for Generic Editor" [Resolved]
org.eclipse.team.ui (3.8.1200.v20210204-1156) "Team Support UI" [Active]
org.eclipse.text (3.11.0.v20210203-1022) "Text" [Resolved]
org.eclipse.text.quicksearch (1.1.0.v20210120-0733) "Quick Search" [Starting]
org.eclipse.tm.terminal.connector.cdtserial (4.7.100.202008310315) "Terminal Serial Connector" [Starting]
org.eclipse.tm.terminal.connector.local (4.7.0.202008310315) "Terminal Local Connector" [Active]
org.eclipse.tm.terminal.connector.process (4.7.0.202008310315) "Terminal Process Connector" [Starting]
org.eclipse.tm.terminal.connector.ssh (4.7.0.202011161527) "Terminal SSH Connector" [Starting]
org.eclipse.tm.terminal.connector.telnet (4.7.100.202010121414) "Terminal Telnet Connector" [Starting]
org.eclipse.tm.terminal.control (5.1.0.202103012351) "Terminal Control (Embeddable Widget)" [Active]
org.eclipse.tm.terminal.view.core (4.7.0.202008310315) "Terminal View Core" [Starting]
org.eclipse.tm.terminal.view.ui (4.8.0.202103012351) "Terminal View" [Active]
org.eclipse.tools.templates.core (1.2.0.202008310315) "Template Engine Core" [Starting]
org.eclipse.tools.templates.freemarker (1.2.100.202011191931) "Template Engine Freemarker Support" [Starting]
org.eclipse.tools.templates.ui (1.2.100.202010121414) "Template Engine UI" [Starting]
org.eclipse.ui (3.119.0.v20210111-1350) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.6.1100.v20210118-1327) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.7.200.v20210121-1039) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.10.100.v20201211-1511) "Console" [Active]
org.eclipse.ui.editors (3.14.0.v20210215-0846) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.4.900.v20201105-0600) "External Tools" [Starting]
org.eclipse.ui.forms (3.11.100.v20210108-1139) "Eclipse Forms" [Resolved]
org.eclipse.ui.genericeditor (1.2.0.v20210129-1224) "Generic and Extensible Text Editor" [Active]
org.eclipse.ui.ide (3.18.100.v20210122-1536) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.4.0.v20210122-1423) "Eclipse IDE UI Application" [Active]
org.eclipse.ui.intro (3.6.100.v20210119-2223) "Welcome Framework" [Starting]
org.eclipse.ui.intro.quicklinks (1.1.0.v20200724-0708) "Quicklinks for the Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.4.100.v20210108-1131) "Universal Welcome" [Starting]
org.eclipse.ui.monitoring (1.2.0.v20210111-1353) "UI Freeze Monitoring" [Active]
org.eclipse.ui.navigator (3.10.0.v20210111-1352) "Common Navigator View" [Active]
org.eclipse.ui.navigator.resources (3.8.0.v20210209-1136) "Navigator Workbench Components" [Active]
org.eclipse.ui.net (1.3.800.v20200422-1935) "Internet Connection Management UI" [Active]
org.eclipse.ui.themes (1.2.1300.v20210108-1832) "Eclipse SDK Themes" [Active]
org.eclipse.ui.views (3.11.0.v20210111-1351) "Views" [Resolved]
org.eclipse.ui.views.log (1.2.1400.v20210122-1423) "Log View" [Starting]
org.eclipse.ui.views.properties.tabbed (3.9.100.v20201223-1348) "Tabbed Properties View" [Resolved]
org.eclipse.ui.win32 (3.4.400.v20200414-1247) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.122.100.v20210215-1525) "Eclipse Workbench" [Active]
org.eclipse.ui.workbench.texteditor (3.16.0.v20210120-0733) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.4.700.v20200907-1237) "Install/Update Configurator" [Active]
org.eclipse.urischeme (1.1.300.v20210113-1544) "Eclipse URI Scheme Handling" [Resolved]
org.eclipse.userstorage (1.2.0.v20190307-0457) "Eclipse User Storage" [Starting]
org.eclipse.userstorage.oauth (1.1.0.v20190307-0457) "OAuth support for Eclipse User Storage" [Active]
org.eclipse.userstorage.ui (1.1.0.v20190307-0457) "Eclipse User Storage UI" [Starting]
org.freemarker (2.3.22.v20160210-1233) "FreeMarker" [Resolved]
org.json (8.0.0.202112011800) "JSON" [Resolved]
org.sat4j.core (2.3.5.v201308161310) "SAT4J Core" [Resolved]
org.sat4j.pb (2.3.5.v201404071733) "SAT4J Pseudo" [Resolved]
org.slf4j.api (1.7.30.v20200204-2150) "SLF4J API Module" [Resolved]
org.tukaani.xz (1.8.0.v20180207-1613) "XZ for Java" [Resolved]
org.w3c.css.sac (1.3.1.v200903091627) "W3C CSS SAC" [Resolved]
org.w3c.dom.events (3.0.0.draft20060413_v201105210656) "W3C DOM Level 3 Events" [Resolved]
org.w3c.dom.smil (1.0.1.v200903091627) "W3C SMIL DOM" [Resolved]
org.w3c.dom.svg (1.1.0.v201011041433) "W3C SVG DOM" [Resolved]
xdc.tools.xgconf.modeldata (3.62.1.16) "Modeldata Plug-in" [Starting]
*** User Preferences:
#Wed Mar 30 22:20:26 PDT 2022
/bundle_defaults/com.ti.browser/BROWSER_TYPE=chrome
/bundle_defaults/com.ti.ccstudio.debug.ui/AUTOMATICALLY_ACTIVATE_DEBUG_VIEW=false
/bundle_defaults/com.ti.ccstudio.debug.ui/AUTOMATICALLY_OPEN_DEBUG_VIEW=true
/bundle_defaults/com.ti.ccstudio.debug.ui/BUILD_BEFORE_LOAD=true
/bundle_defaults/com.ti.ccstudio.debug.ui/CONTINUE_REFRESH_AUTO_DISABLE_ON_SEVERE_ERROR=true
/bundle_defaults/com.ti.ccstudio.debug.ui/CONTINUE_REFRESH_INTERVAL=500
/bundle_defaults/com.ti.ccstudio.debug.ui/HIDE_LIBRARY_SYMBOLS=true
/bundle_defaults/com.ti.ccstudio.debug.ui/HIDE_SYMBOLS_WITH_DOLLAR_SIGN=false
/bundle_defaults/com.ti.ccstudio.debug.ui/HIDE_SYMBOLS_WITH_DOUBLE_UNDERSCORE=false
/bundle_defaults/com.ti.ccstudio.debug.ui/MemoryAttributesDisplay=true
/bundle_defaults/com.ti.ccstudio.debug.ui/PREF_PORMPT_FOR_SYNC_GROUP=true
/bundle_defaults/com.ti.ccstudio.debug.ui/PREF_SORT_GROUPS_BY_NAME=false
/bundle_defaults/com.ti.ccstudio.debug.ui/PROMPT_FOR_ADVISOR_REMARKS_ON_LAUNCH=true
/bundle_defaults/com.ti.ccstudio.debug.ui/QValue=0
/bundle_defaults/com.ti.ccstudio.debug.ui/REBUILD_PROGRAM_BEFORE_LOADING=false
/bundle_defaults/com.ti.ccstudio.debug.ui/RELOAD_ASSOCIATED_PROGRAM=false
/bundle_defaults/com.ti.ccstudio.debug.ui/RELOAD_PROGRAM_IF_CHANGED=prompt
/bundle_defaults/com.ti.ccstudio.debug.ui/SWITCH_TO_CCS_EDIT_ON_TERMINATE=true
/bundle_defaults/com.ti.ccstudio.debug.ui/SymbolDisplay=true
/bundle_defaults/com.ti.ccstudio.debug.ui/TrackExpression=false
/bundle_defaults/com.ti.ccstudio.debug.ui/backgroundColoringMode=CACHE_AND_MEMORY_LEVEL_VISIBILITY
/bundle_defaults/com.ti.ccstudio.debug.ui/cacheBoundaryMarkMode=L1D
/bundle_defaults/com.ti.ccstudio.debug.ui/enableMemoryAnalysis=false
/bundle_defaults/com.ti.ccstudio.debug.ui/memoryAnalysisMode=false
/bundle_defaults/com.ti.ccstudio.debug.ui/memoryAnalyzer1=enabled
/bundle_defaults/com.ti.ccstudio.debug.ui/memoryAnalyzer2=enabled
/bundle_defaults/com.ti.ccstudio.debug.ui/memoryAnalyzer3=enabled
/bundle_defaults/com.ti.ccstudio.debug.ui/memoryAnalyzer4=enabled
/bundle_defaults/com.ti.ccstudio.debug.ui/memoryEditBufferSave=saveOnEnterCancelOnFocusLost
/bundle_defaults/com.ti.ccstudio.debug.ui/showCacheBoundaryMarker=true
/bundle_defaults/com.ti.ccstudio.debug.ui/showCacheColor=true
/bundle_defaults/com.ti.ccstudio.debug/SHOW_NON_DEBUGABBLE_DEVICES=false
/bundle_defaults/com.ti.ccstudio.debug/projectCreateTargetConfiguration=auto
/bundle_defaults/com.ti.ccstudio.ui/com.ti.ccstudio.ui.JVM_HEAP_PING_FREQUENCY=1000
/bundle_defaults/com.ti.ccstudio.ui/com.ti.ccstudio.ui.JVM_HEAP_THRESHOLD_PERCENTAGE=90
/bundle_defaults/com.ti.ccstudio.ui/com.ti.ccstudio.ui.MAXIMIZE_WELCOME_PAGE=true
/bundle_defaults/com.ti.ccstudio.ui/com.ti.ccstudio.ui.SHOW_INACTIVE_WINDOW_MESSAGES=true
/bundle_defaults/com.ti.ccstudio.ui/com.ti.ccstudio.ui.SHOW_JVM_HEAP_WARNING=true
/bundle_defaults/com.ti.dvt.datamodel/saveInterval=1
/bundle_defaults/com.ti.dvt.datamodel/tempDirectory=G\:\\EmbedWorkSpaces\\workspace_v11\\.metadata\\.plugins\\com.ti.dvt.datamodel\\temp
/bundle_defaults/com.ti.dvt.energytrace/AutoStart=false
/bundle_defaults/com.ti.dvt.energytrace/CellCapacity=220
/bundle_defaults/com.ti.dvt.energytrace/CellType=CR2032
/bundle_defaults/com.ti.dvt.energytrace/CellVoltage=3.0
/bundle_defaults/com.ti.dvt.energytrace/Mode=EnergyTrace
/bundle_defaults/com.ti.dvt.energytrace/SaveCST=false
/bundle_defaults/com.ti.dvt.energytrace/SaveCSV=false
/bundle_defaults/com.ti.dvt.energytrace/ShuntCurrent=Low
/bundle_defaults/com.ti.dvt.energytrace/TargetConnection=USB1
/bundle_defaults/com.ti.dvt.energytrace/TargetDevice=MSP430
/bundle_defaults/com.ti.dvt.energytrace/TargetVoltage=3000
/bundle_defaults/com.ti.dvt.energytrace/TargetVoltageUSB1=3000
/bundle_defaults/com.ti.dvt.energytrace/TargetVoltageUSB2=3000
/bundle_defaults/com.ti.dvt.energytrace/TargetVoltageUSB3=3000
/bundle_defaults/com.ti.dvt.energytrace/TargetVoltageXDS110=3300
/bundle_defaults/com.ti.util.diskspacemonitor/minFreeDiskSpace=0
/bundle_defaults/org.eclipse.cdt.codan.core/inEditor=true
/bundle_defaults/org.eclipse.cdt.codan.core/onBuild=false
/bundle_defaults/org.eclipse.cdt.codan.core/useParentScope=true
/bundle_defaults/org.eclipse.cdt.core/astwriter.addOverride=false
/bundle_defaults/org.eclipse.cdt.core/astwriter.placeConstRightOfType=false
/bundle_defaults/org.eclipse.cdt.core/astwriter.preserveVirtual=true
/bundle_defaults/org.eclipse.cdt.core/build.all.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.core/build.proj.ref.configs.enabled=false
/bundle_defaults/org.eclipse.cdt.core/includes.beginExportsPattern=IWYU\\s+(pragma\:?\\s+)?begin_exports?
/bundle_defaults/org.eclipse.cdt.core/includes.endExportsPattern=IWYU\\s+(pragma\:?\\s+)?end_exports?
/bundle_defaults/org.eclipse.cdt.core/includes.exportPattern=IWYU\\s+(pragma\:?\\s+)?export
/bundle_defaults/org.eclipse.cdt.core/includes.keepPattern=IWYU\\s+(pragma\:?\\s+)?keep
/bundle_defaults/org.eclipse.cdt.core/includes.privatePattern=IWYU\\s+(pragma\:?\\s+)?private(,\\s+include\\s+(?<header>\\S+))?
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllFiles=true
/bundle_defaults/org.eclipse.cdt.core/indexer/indexAllHeaderVersions=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexImportLocation=.settings/cdt-index.zip
/bundle_defaults/org.eclipse.cdt.core/indexer/indexOnOpen=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithAlternateLang=false
/bundle_defaults/org.eclipse.cdt.core/indexer/indexUnusedHeadersWithDefaultLang=true
/bundle_defaults/org.eclipse.cdt.core/indexer/indexerId=org.eclipse.cdt.core.fastIndexer
/bundle_defaults/org.eclipse.cdt.core/indexer/skipFilesLargerThanMB=8
/bundle_defaults/org.eclipse.cdt.core/indexer/skipImplicitReferences=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipIncludedFilesLargerThanMB=16
/bundle_defaults/org.eclipse.cdt.core/indexer/skipMacroReferences=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipReferences=false
/bundle_defaults/org.eclipse.cdt.core/indexer/skipTypeReferences=false
/bundle_defaults/org.eclipse.cdt.core/indexer/useHeuristicIncludeResolution=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.codeReaderCache=64
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.code_formatter=org.eclipse.cdt.core.defaultCodeFormatter
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_arguments_in_method_invocation=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_assignment=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_type_declaration=80
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_binary_expression=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_compact_if=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression=34
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression_chain=18
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_constructor_initializer_list=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_declarator_list=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_enumerator_list=48
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expression_list=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expressions_in_array_initializer=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_lambda_expression=20
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_member_access=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_overloaded_left_shift_chain=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_parameters_in_method_declaration=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_throws_clause_in_method_declaration=16
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_array_initializer=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block_in_case=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_linkage_declaration=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_method_declaration=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_namespace_declaration=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_switch=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_type_declaration=end_of_line
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.line_up_line_comment_in_blocks_on_first_column=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.min_distance_between_code_and_line_comment=1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.never_indent_line_comments_on_first_column=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment_formatter_off_tag=@formatter\:off
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment_formatter_on_tag=@formatter\:on
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.compact_else_if=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation=2
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation_for_array_initializer=2
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_block_comment=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_guardian_clause_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_header_comment=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_line_comment=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_compare_to_type_header=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_extra_spaces=0
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_access_specifier=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_linkage=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_namespace_header=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_breaks_compare_to_cases=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_declaration_compare_to_template_header=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_empty_lines=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_label_compare_to_statements=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_block=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_body=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_cases=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_switch=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indentation.size=4
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_colon_in_constructor_initializer_list=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_label=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_template_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_file_if_missing=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_catch_in_try_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_colon_in_constructor_initializer_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_else_in_if_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_identifier_in_function_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_while_in_do_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_in_empty_block=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_assignment_operator=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_binary_operator=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_arguments=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_parameters=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_paren_in_cast=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_base_clause=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_case=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_labeled_statement=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_base_types=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_declarator_list=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_enum_declarations=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_expression_list=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_throws=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_structured_binding_name_list=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_arguments=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_parameters=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_lambda_return=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_brace_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_bracket=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_cast=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_structured_binding_name_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_pointer_in_declarator_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_pointer_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_postfix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_prefix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_question_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_semicolon_in_for=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_unary_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_assignment_operator=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_binary_operator=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_brace_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_bracket=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_cast=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_catch=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_if=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_switch=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_while=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_structured_binding_name_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_base_clause=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_case=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_default=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_labeled_statement=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_base_types=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_declarator_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_enum_declarations=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_expression_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_throws=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_structured_binding_name_list=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_lambda_return=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_arguments=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_parameters=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_array_initializer=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_block=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_linkage_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_method_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_namespace_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_switch=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_type_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_bracket=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_catch=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_exception_specification=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_for=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_if=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_switch=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_while=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_structured_binding_name_list=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_pointer_in_declarator_list=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_pointer_in_method_declaration=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_postfix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_prefix_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_question_in_conditional=insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_ref_qualifier_in_structured_binding=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon_in_for=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_unary_operator=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_braces_in_array_initializer=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_brackets=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_exception_specification=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_declaration=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_invocation=do not insert
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.join_wrapped_lines=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_else_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_empty_array_initializer_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_imple_if_on_one_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_then_statement_on_same_line=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.lineSplit=80
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.number_of_empty_lines_to_preserve=1
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.put_empty_statement_on_new_line=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.char=tab
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.size=4
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_comment_formatter_tag=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_indentations=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.indexDBCacheSizePct=10
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.maxIndexDBCacheSizeMB=256
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.path_canonicalization=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceFilesInBinaries=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.showSourceRootsAtTopLevelOfProject=true
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskCaseSensitive=false
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskPriorities=normal
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.taskTags=TODO,FIXME,XXX
/bundle_defaults/org.eclipse.cdt.core/org.eclipse.cdt.core.workspaceLanguageMappings=
/bundle_defaults/org.eclipse.cdt.core/scalability.limitTokensPerTU=false
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTokens=25000000
/bundle_defaults/org.eclipse.cdt.core/scalability.maximumTrivialExpressions=1000
/bundle_defaults/org.eclipse.cdt.core/scalability.skipTrivialExpressions=true
/bundle_defaults/org.eclipse.cdt.core/useStructualParseMode=false
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.Disassembly.instructionStepOn=false
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.character_set=UTF-16
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.max_number_of_instructions=100
/bundle_defaults/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.corecDebug.non_wide_character_set=windows-1252
/bundle_defaults/org.eclipse.cdt.debug.ui/booleanPreference=true
/bundle_defaults/org.eclipse.cdt.debug.ui/choicePreference=choice2
/bundle_defaults/org.eclipse.cdt.debug.ui/org.eclipse.cdt.debug.ui.cDebug.showHexValues=false
/bundle_defaults/org.eclipse.cdt.debug.ui/org.eclipse.cdt.debug.ui.disassembly.openNoSourceInfo=true
/bundle_defaults/org.eclipse.cdt.debug.ui/org.eclipse.cdt.debug.ui.disassembly.openSourceNotFound=false
/bundle_defaults/org.eclipse.cdt.debug.ui/org.eclipse.cdt.debug.ui.disassembly.showInstructions=true
/bundle_defaults/org.eclipse.cdt.debug.ui/org.eclipse.cdt.debug.ui.disassembly.showSource=true
/bundle_defaults/org.eclipse.cdt.debug.ui/stringPreference=Default value
/bundle_defaults/org.eclipse.cdt.dsf.gdb/autoTerminateGdb=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbCommand=gdb
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultGdbInit=.gdbinit
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultNonStop=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultRemoteTimeoutEnabled=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultRemoteTimeoutValue=
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMain=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/defaultStopAtMainSymbol=main
/bundle_defaults/org.eclipse.cdt.dsf.gdb/enablePrettyPrinting=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/initialChildCountLimitForCollections=100
/bundle_defaults/org.eclipse.cdt.dsf.gdb/maxGdbTraces=500000
/bundle_defaults/org.eclipse.cdt.dsf.gdb/maxMiOutputLines=5
/bundle_defaults/org.eclipse.cdt.dsf.gdb/maxMiOutputLinesEnable=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb..reversedebugpref.tracemethodHardware=UseGdbTrace
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.aggressiveBpFilter=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeout=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.commandTimeoutValue=10000
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.consoleBufferLines=1000
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.consoleInvertedColors=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.externalConsole=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.hideRunningThreads=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/org.eclipse.cdt.dsf.gdb.useRtti=true
/bundle_defaults/org.eclipse.cdt.dsf.gdb/tracesEnable=false
/bundle_defaults/org.eclipse.cdt.dsf.gdb/useInspectorHover=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/delaySteppingForViewUpdatesEnable=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressColor=0,96,0
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.addressRadix=16
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.avoidReadBeforePC=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.codeBytesColor=96,0,0
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.endAddress=0x10000000000000000
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.errorColor=96,0,0
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.functionOffsetsColor=96,0,0
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.instructionColor=0,0,96
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.labelColor=0,0,96
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.opcodeRadix=16
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.pcHistorySize=4
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.rulerBackgroundColor=255,255,255
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showAddressRadix=false
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSource=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.showSymbols=true
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.sourceColor=64,0,80
/bundle_defaults/org.eclipse.cdt.dsf.ui/disassembly.startAddress=0
/bundle_defaults/org.eclipse.cdt.dsf.ui/minStepInterval=100
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimit=10
/bundle_defaults/org.eclipse.cdt.dsf.ui/stackFrameLimitEnable=true
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.makefileGenerator.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.makefileGenerator.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.makefileGenerator.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerFileProfile.makefileGenerator.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.make.core.GCCStandardMakePerProjectProfile.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfile.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileC.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCManagedMakePerProjectProfileCPP.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfile.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileC.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.BOP.open.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.BOP.open.path=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.BOP.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.specsFile.parser.enabled=false
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.specsFile.run.arguments=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.specsFile.run.command=
/bundle_defaults/org.eclipse.cdt.make.core/SCD.org.eclipse.cdt.managedbuilder.core.GCCWinManagedMakePerProjectProfileCPP.specsFile.run.useDefault=false
/bundle_defaults/org.eclipse.cdt.make.core/binaryparser=org.eclipse.cdt.core.ELF
/bundle_defaults/org.eclipse.cdt.make.core/enabled=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.core.errorOutputParser=org.eclipse.cdt.core.GASErrorParser;org.eclipse.cdt.core.GLDErrorParser;org.eclipse.cdt.core.GCCErrorParser;org.eclipse.cdt.core.GmakeErrorParser;org.eclipse.cdt.core.VCErrorParser;com.ti.ccstudio.errorparser.AsmErrorParser;com.ti.ccstudio.errorparser.CoffErrorParser;com.ti.ccstudio.errorparser.LinkErrorParser;com.ti.ccstudio.errorparser.SysConfigErrorParser;org.eclipse.rtsc.xdctools.parsers.ErrorParser;org.eclipse.cdt.core.CWDLocator;org.eclipse.cdt.core.MakeErrorParser;
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.ScannerConfigDiscoveryEnabled=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.append_environment=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.build.command=make
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.build.location=
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.build.target.auto=all
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.build.target.clean=clean
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.build.target.inc=all
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.editor_makefile_style=GNU
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.enableAutoBuild=false
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.enableCleanBuild=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.enableFullBuild=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.enabledIncrementalBuild=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.esiProviderArguments=-E -P -v -dD ${plugin_state_location}/${specs_file}
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.esiProviderCommand=gcc
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.esiProviderCommandEnabled=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.esiProviderParserId=org.eclipse.cdt.make.core.GCCSpecsConsoleParser
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.makeBuilderParserEnabled=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.makeBuilderParserId=org.eclipse.cdt.make.core.GCCScannerInfoConsoleParser
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.siProblemGenerationEnabled=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.stopOnError=false
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.useDefaultBuildCmd=true
/bundle_defaults/org.eclipse.cdt.make.core/org.eclipse.cdt.make.core.useDefaultESIProviderCmd=true
/bundle_defaults/org.eclipse.cdt.make.core/problemReportingEnabled=true
/bundle_defaults/org.eclipse.cdt.make.core/selectedProfileId=
/bundle_defaults/org.eclipse.cdt.ui/CEditor.ShowTemporaryProblem=false
/bundle_defaults/org.eclipse.cdt.ui/Refactor.lightweight=true
/bundle_defaults/org.eclipse.cdt.ui/Refactoring.savealleditors=false
/bundle_defaults/org.eclipse.cdt.ui/alignConst=false
/bundle_defaults/org.eclipse.cdt.ui/asm_directive=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/asm_directive_italic=false
/bundle_defaults/org.eclipse.cdt.ui/asm_label=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/asm_label_bold=true
/bundle_defaults/org.eclipse.cdt.ui/asm_label_italic=false
/bundle_defaults/org.eclipse.cdt.ui/autoIndent=true
/bundle_defaults/org.eclipse.cdt.ui/autoOpenConsole=true
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleBackgroundColor=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleErrorStreamColor=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleInfoStreamColor=0,0,255
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleLines=500
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleOutputStreamColor=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemBackgroundColor=254,231,224
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemHighlightedColor=255,0,0
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemInfoBackgroundColor=244,247,254
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleProblemWarningBackgroundColor=254,243,218
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleTabWith=4
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleUpdateDelayMs=75
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleWrapLines=false
/bundle_defaults/org.eclipse.cdt.ui/buildConsoleWrapLinesMax=5000
/bundle_defaults/org.eclipse.cdt.ui/c_braces=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/c_braces_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_braces_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_bold=true
/bundle_defaults/org.eclipse.cdt.ui/c_comment_task_tag_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_default=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/c_default_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_default_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_keyword=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_bold=true
/bundle_defaults/org.eclipse.cdt.ui/c_keyword_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment=63,127,95
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_multi_line_comment_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_numbers_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_operators=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/c_operators_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_operators_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment=63,127,95
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_single_line_comment_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_string=42,0,255
/bundle_defaults/org.eclipse.cdt.ui/c_string_bold=false
/bundle_defaults/org.eclipse.cdt.ui/c_string_italic=false
/bundle_defaults/org.eclipse.cdt.ui/c_type=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/c_type_bold=true
/bundle_defaults/org.eclipse.cdt.ui/c_type_italic=false
/bundle_defaults/org.eclipse.cdt.ui/class_member_ascending_visibility_order=false
/bundle_defaults/org.eclipse.cdt.ui/clearConsole=true
/bundle_defaults/org.eclipse.cdt.ui/closeAngularBrackets=true
/bundle_defaults/org.eclipse.cdt.ui/closeBraces=true
/bundle_defaults/org.eclipse.cdt.ui/closeBrackets=true
/bundle_defaults/org.eclipse.cdt.ui/closeStrings=true
/bundle_defaults/org.eclipse.cdt.ui/codetemplates.includeGuardGenerationScheme=2
/bundle_defaults/org.eclipse.cdt.ui/consoleOnTop=true
/bundle_defaults/org.eclipse.cdt.ui/contentAssist.showCamelCaseMatches=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_delay=500
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_arrow=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_dot=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_doublecolon=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoactivation_trigger_replace_dot_with_arrow=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_autoinsert=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_category_order=org.eclipse.cdt.ui.parserProposalCategory\:65539\u0000org.eclipse.cdt.ui.textProposalCategory\:65541\u0000org.eclipse.cdt.ui.templateProposalCategory\:2\u0000org.eclipse.cdt.ui.helpProposalCategory\:5\u0000
/bundle_defaults/org.eclipse.cdt.ui/content_assist_current_file_search_scope=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_arguments=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_default_argument_display_parameters_with_default_argument=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_disabled_computers=org.eclipse.cdt.ui.textProposalCategory\u0000
/bundle_defaults/org.eclipse.cdt.ui/content_assist_guess_arguments=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_order_proposals=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_background=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/content_assist_parameters_foreground=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/content_assist_prefix_completion=true
/bundle_defaults/org.eclipse.cdt.ui/content_assist_project_search_scope=false
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposal_filter=0;<Default Filter>;CCS Product Content;RTSC Content
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_background=255,255,255
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_foreground=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/content_assist_proposals_timeout=5000
/bundle_defaults/org.eclipse.cdt.ui/editor_annotation_roll_over=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_comments=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_doc_comments=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_functions=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_headers=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_inactive=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_macros=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_methods=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_non_doc_comments=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_default_structures=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_enabled=true
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_preprocessor_enabled=false
/bundle_defaults/org.eclipse.cdt.ui/editor_folding_provider=org.eclipse.cdt.ui.text.defaultFoldingProvider
/bundle_defaults/org.eclipse.cdt.ui/ensureNewlineAtEOF=true
/bundle_defaults/org.eclipse.cdt.ui/escapeStrings=false
/bundle_defaults/org.eclipse.cdt.ui/formatSourceCode=false
/bundle_defaults/org.eclipse.cdt.ui/formatSourceCodeEditedLines=true
/bundle_defaults/org.eclipse.cdt.ui/formatter_profile=org.eclipse.cdt.ui.default.kandr_profile
/bundle_defaults/org.eclipse.cdt.ui/formattingConfirmScopeForEmptySelection=true
/bundle_defaults/org.eclipse.cdt.ui/formattingScopeForEmptySelection=document
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.compositeTypes=true
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.enums=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.externalVariables=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.functions=false
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.namespaceElements=true
/bundle_defaults/org.eclipse.cdt.ui/forwardDeclare.templates=false
/bundle_defaults/org.eclipse.cdt.ui/function_output_parameters_before_input=false
/bundle_defaults/org.eclipse.cdt.ui/function_pass_output_parameters_by_pointer=false
/bundle_defaults/org.eclipse.cdt.ui/handleTemporaryProblems=true
/bundle_defaults/org.eclipse.cdt.ui/hoverModifierMasks=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;131072
/bundle_defaults/org.eclipse.cdt.ui/hoverModifiers=org.eclipse.cdt.ui.BestMatchHover;0;org.eclipse.cdt.ui.CSourceHover;Shift
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeColor=224,224,224
/bundle_defaults/org.eclipse.cdt.ui/inactiveCodeEnable=true
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.external=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inOtherProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.inSameProject=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.matchingPattern=
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.other=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="3"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.partner=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="true" keep_together\="true" order\="0" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.related=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="false" keep_together\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.sameFolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.subfolder=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="false" blank_line_before\="false" keep_together\="false" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.system=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style blank_line_before\="true" keep_together\="true" order\="0"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="1" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includeStyle.systemWithoutExtension=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<style angle_brackets\="true" blank_line_before\="false" keep_together\="true" order\="2" relative_path\="false"/>
/bundle_defaults/org.eclipse.cdt.ui/includes.extensionsOfAutoExportedFiles=inc
/bundle_defaults/org.eclipse.cdt.ui/includes.partnerFileSuffixes=test,unittest
/bundle_defaults/org.eclipse.cdt.ui/markOccurrences=true
/bundle_defaults/org.eclipse.cdt.ui/markOverloadedOperatorsOccurrences=false
/bundle_defaults/org.eclipse.cdt.ui/matchingBrackets=true
/bundle_defaults/org.eclipse.cdt.ui/matchingBracketsColor=170,170,170
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.capitalization=1
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.suffix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.constant.wordDelimiter=_
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.capitalization=0
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.suffix=.h
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.header.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.capitalization=0
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.suffix=.cpp
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.source.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.capitalization=0
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.suffix=_test.cpp
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.cpp.test.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.capitalization=4
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.suffix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.field.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.capitalization=3
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefix=get
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.prefixForBoolean=is
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.suffix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.getter.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.capitalization=4
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.suffix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.method.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.capitalization=3
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.prefix=set
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.suffix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.setter.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.capitalization=4
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.prefix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.suffix=
/bundle_defaults/org.eclipse.cdt.ui/nameStyle.variable.wordDelimiter=
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.multi=63,95,191
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.recognizedTag=127,159,191
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.internal.ui.text.doctools.doxygen.single=63,95,191
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.add_comments=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.CUChildren=true
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.UseStructuralMode=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.linkToEditor=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.editor.showSegments=false
/bundle_defaults/org.eclipse.cdt.ui/org.eclipse.cdt.ui.outline.linktoeditor=true
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowPartnerIndirectInclusion=true
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.allowReordering=true
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.headerSubstitution=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map cpp_only\="false" name\="GCC C Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;asm/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/errno-base.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;asm/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_32.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/posix_types_64.h&gt;" value\="&lt;asm/posix_types.h&gt;"/>\r\n<mapping key\="&lt;asm/ptrace-abi.h&gt;" value\="&lt;asm/ptrace.h&gt;"/>\r\n<mapping key\="&lt;asm/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_32.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;asm/unistd_64.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/a.out.h&gt;" value\="&lt;a.out.h&gt;"/>\r\n<mapping key\="&lt;bits/byteswap.h&gt;" value\="&lt;byteswap.h&gt;"/>\r\n<mapping key\="&lt;bits/cmathcalls.h&gt;" value\="&lt;complex.h&gt;"/>\r\n<mapping key\="&lt;bits/confname.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/dirent.h&gt;" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="&lt;bits/dlfcn.h&gt;" value\="&lt;dlfcn.h&gt;"/>\r\n<mapping key\="&lt;bits/elfclass.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/endian.h&gt;" value\="&lt;endian.h&gt;"/>\r\n<mapping key\="&lt;bits/environments.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;bits/error.h&gt;" value\="&lt;error.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl-linux.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fcntl2.h&gt;" value\="&lt;fcntl.h&gt;"/>\r\n<mapping key\="&lt;bits/fenv.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/fenvinline.h&gt;" value\="&lt;fenv.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_val.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_valf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/huge_vall.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/in.h&gt;" value\="&lt;netinet/in.h&gt;"/>\r\n<mapping key\="&lt;bits/inf.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctl-types.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ioctls.h&gt;" value\="&lt;sys/ioctl.h&gt;"/>\r\n<mapping key\="&lt;bits/ipc.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/ipctypes.h&gt;" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="&lt;bits/libio-ldbl.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/link.h&gt;" value\="&lt;link.h&gt;"/>\r\n<mapping key\="&lt;bits/locale.h&gt;" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="&lt;bits/mathcalls.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathdef.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mathinline.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/mman.h&gt;" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="&lt;bits/monetary-ldbl.h&gt;" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/mqueue2.h&gt;" value\="&lt;mqueue.h&gt;"/>\r\n<mapping key\="&lt;bits/msq.h&gt;" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="&lt;bits/nan.h&gt;" value\="&lt;math.h&gt;"/>\r\n<mapping key\="&lt;bits/netdb.h&gt;" value\="&lt;netdb.h&gt;"/>\r\n<mapping key\="&lt;bits/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;bits/posix_opt.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/posix1_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/posix2_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/predefs.h&gt;" value\="&lt;features.h&gt;"/>\r\n<mapping key\="&lt;bits/printf-ldbl.h&gt;" value\="&lt;printf.h&gt;"/>\r\n<mapping key\="&lt;bits/pthreadtypes.h&gt;" value\="&lt;pthread.h&gt;"/>\r\n<mapping key\="&lt;bits/resource.h&gt;" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="&lt;bits/sched.h&gt;" value\="&lt;sched.h&gt;"/>\r\n<mapping key\="&lt;bits/select.h&gt;" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="&lt;bits/sem.h&gt;" value\="&lt;sys/sem.h&gt;"/>\r\n<mapping key\="&lt;bits/semaphore.h&gt;" value\="&lt;semaphore.h&gt;"/>\r\n<mapping key\="&lt;bits/setjmp.h&gt;" value\="&lt;setjmp.h&gt;"/>\r\n<mapping key\="&lt;bits/shm.h&gt;" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="&lt;bits/sigaction.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigcontext.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/siginfo.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/signum.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigset.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigstack.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sigthread.h&gt;" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="&lt;bits/sockaddr.h&gt;" value\="&lt;sys/un.h&gt;"/>\r\n<mapping key\="&lt;bits/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;bits/stab.def&gt;" value\="&lt;stab.h&gt;"/>\r\n<mapping key\="&lt;bits/stat.h&gt;" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="&lt;bits/statfs.h&gt;" value\="&lt;sys/statfs.h&gt;"/>\r\n<mapping key\="&lt;bits/statvfs.h&gt;" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-ldbl.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio-lock.h&gt;" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio_lim.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdio2.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/stdlib-ldbl.h&gt;" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="&lt;bits/string.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string2.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/string3.h&gt;" value\="&lt;string.h&gt;"/>\r\n<mapping key\="&lt;bits/stropts.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;bits/sys_errlist.h&gt;" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="&lt;bits/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-ldbl.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/syslog-path.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;bits/termios.h&gt;" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="&lt;bits/time.h&gt;" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="&lt;bits/types.h&gt;" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="&lt;bits/uio.h&gt;" value\="&lt;sys/uio.h&gt;"/>\r\n<mapping key\="&lt;bits/unistd.h&gt;" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="&lt;bits/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;bits/utmp.h&gt;" value\="&lt;utmp.h&gt;"/>\r\n<mapping key\="&lt;bits/utmpx.h&gt;" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="&lt;bits/utsname.h&gt;" value\="&lt;sys/utsname.h&gt;"/>\r\n<mapping key\="&lt;bits/waitflags.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/waitstatus.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar-ldbl.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/wchar2.h&gt;" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="&lt;bits/xopen_lim.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;bits/xtitypes.h&gt;" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="&lt;linux/errno.h&gt;" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="&lt;linux/limits.h&gt;" value\="&lt;limits.h&gt;"/>\r\n<mapping key\="&lt;linux/socket.h&gt;" value\="&lt;sys/socket.h&gt;"/>\r\n<mapping key\="&lt;sys/poll.h&gt;" value\="&lt;poll.h&gt;"/>\r\n<mapping key\="&lt;sys/syscall.h&gt;" value\="&lt;syscall.h&gt;"/>\r\n<mapping key\="&lt;sys/syslog.h&gt;" value\="&lt;syslog.h&gt;"/>\r\n<mapping key\="&lt;sys/ucontext.h&gt;" value\="&lt;ucontext.h&gt;"/>\r\n<mapping key\="&lt;sys/ustat.h&gt;" value\="&lt;ustat.h&gt;"/>\r\n<mapping key\="&lt;wait.h&gt;" value\="&lt;sys/wait.h&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map/>\r\n</map>\r\n<map cpp_only\="true" name\="GCC C++ Header Substitution">\r\n<unconditional_substitution_map>\r\n<mapping key\="&lt;auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/auto_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;backward/binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;backward/hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;backward/strstream&gt;" value\="&lt;strstream&gt;"/>\r\n<mapping key\="&lt;binders.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/algorithmfwd.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/atomic_word.h&gt;" value\="&lt;ext/atomicity.h&gt;"/>\r\n<mapping key\="&lt;bits/basic_file.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/basic_ios.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/basic_string.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/boost_concept_check.h&gt;" value\="&lt;bits/concept_check.h&gt;"/>\r\n<mapping key\="&lt;bits/boost_sp_shared_count.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++allocator.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/c++config.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;bits/c++io.h&gt;" value\="&lt;ext/stdio_sync_filebuf.h&gt;"/>\r\n<mapping key\="&lt;bits/char_traits.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/cmath.tcc&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/codecvt.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/ctype_inline.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/cxxabi_tweaks.h&gt;" value\="&lt;cxxabi.h&gt;"/>\r\n<mapping key\="&lt;bits/deque.tcc&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;bits/fstream.tcc&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;bits/functexcept.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/functional_hash.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/gslice.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/gslice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;bits/hashtable.h&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;bits/indirect_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/ios_base.h&gt;" value\="&lt;iomanip&gt;"/>\r\n<mapping key\="&lt;bits/istream.tcc&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;bits/list.tcc&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_classes.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets.tcc&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/locale_facets_nonio.tcc&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/localefwd.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/mask_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/messages_members.h&gt;" value\="&lt;locale&gt;"/>\r\n<mapping key\="&lt;bits/move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/ostream.tcc&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/ostream_insert.h&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;bits/postypes.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/slice_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/sstream.tcc&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;bits/stl_algo.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_algobase.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_bvector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stl_construct.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_deque.h&gt;" value\="&lt;deque&gt;"/>\r\n<mapping key\="&lt;bits/stl_function.h&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;bits/stl_heap.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_funcs.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_iterator_base_types.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/stl_list.h&gt;" value\="&lt;list&gt;"/>\r\n<mapping key\="&lt;bits/stl_map.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_move.h&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;bits/stl_multimap.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_multiset.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_numeric.h&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_pair.h&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_queue.h&gt;" value\="&lt;queue&gt;"/>\r\n<mapping key\="&lt;bits/stl_raw_storage_iter.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_relops.h&gt;" value\="&lt;utility&gt;"/>\r\n<mapping key\="&lt;bits/stl_set.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_stack.h&gt;" value\="&lt;stack&gt;"/>\r\n<mapping key\="&lt;bits/stl_tempbuf.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;map&gt;"/>\r\n<mapping key\="&lt;bits/stl_tree.h&gt;" value\="&lt;set&gt;"/>\r\n<mapping key\="&lt;bits/stl_uninitialized.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/stl_vector.h&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;bits/stream_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf.tcc&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;iterator&gt;"/>\r\n<mapping key\="&lt;bits/streambuf_iterator.h&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;bits/stringfwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;bits/unique_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;bits/valarray_after.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_array.tcc&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/valarray_before.h&gt;" value\="&lt;valarray&gt;"/>\r\n<mapping key\="&lt;bits/vector.tcc&gt;" value\="&lt;vector&gt;"/>\r\n<mapping key\="&lt;debug/safe_iterator.tcc&gt;" value\="&lt;debug/safe_iterator.h&gt;"/>\r\n<mapping key\="&lt;exception_defines.h&gt;" value\="&lt;exception&gt;"/>\r\n<mapping key\="&lt;ext/algorithm&gt;" value\="&lt;algorithm&gt;"/>\r\n<mapping key\="&lt;ext/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;ext/hash_map&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;ext/hash_set&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;ext/numeric&gt;" value\="&lt;numeric&gt;"/>\r\n<mapping key\="&lt;ext/slist&gt;" value\="&lt;slist&gt;"/>\r\n<mapping key\="&lt;ext/sso_string_base.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring.tcc&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;ext/vstring_fwd.h&gt;" value\="&lt;string&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hash_fun.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_map&gt;"/>\r\n<mapping key\="&lt;hashtable.h&gt;" value\="&lt;hash_set&gt;"/>\r\n<mapping key\="&lt;tr1/bessel_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/beta_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/ell_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/exp_integral.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/gamma.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/hypergeometric.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/legendre_function.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/modified_bessel_func.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_hermite.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/poly_laguerre.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1/riemann_zeta.tcc&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/array&gt;" value\="&lt;tr1/array&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_shared_ptr.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/boost_sp_counted_base.h&gt;" value\="&lt;tr1/memory&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cctype&gt;" value\="&lt;tr1/cctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cfenv&gt;" value\="&lt;tr1/cfenv&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cinttypes&gt;" value\="&lt;tr1/cinttypes&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cmath&gt;" value\="&lt;tr1/cmath&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/complex&gt;" value\="&lt;tr1/complex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdint&gt;" value\="&lt;tr1/cstdint&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdio&gt;" value\="&lt;tr1/cstdio&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cstdlib&gt;" value\="&lt;tr1/cstdlib&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwchar&gt;" value\="&lt;tr1/cwchar&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/cwctype&gt;" value\="&lt;tr1/cwctype&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional&gt;" value\="&lt;tr1/functional&gt;"/>\r\n<mapping key\="&lt;tr1_impl/functional_hash.h&gt;" value\="&lt;tr1/functional_hash.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/hashtable&gt;" value\="&lt;tr1/hashtable.h&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/random.tcc&gt;" value\="&lt;tr1/random&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/regex&gt;" value\="&lt;tr1/regex&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;tr1/type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/type_traits&gt;" value\="&lt;type_traits&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;tr1/unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_map&gt;" value\="&lt;unordered_map&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;tr1/unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/unordered_set&gt;" value\="&lt;unordered_set&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;tr1/utility&gt;"/>\r\n<mapping key\="&lt;tr1_impl/utility&gt;" value\="&lt;utility&gt;"/>\r\n</unconditional_substitution_map>\r\n<optional_substitution_map>\r\n<mapping key\="&lt;assert.h&gt;" value\="&lt;cassert&gt;"/>\r\n<mapping key\="&lt;complex.h&gt;" value\="&lt;ccomplex&gt;"/>\r\n<mapping key\="&lt;ctype.h&gt;" value\="&lt;cctype&gt;"/>\r\n<mapping key\="&lt;errno.h&gt;" value\="&lt;cerrno&gt;"/>\r\n<mapping key\="&lt;fenv.h&gt;" value\="&lt;cfenv&gt;"/>\r\n<mapping key\="&lt;float.h&gt;" value\="&lt;cfloat&gt;"/>\r\n<mapping key\="&lt;inttypes.h&gt;" value\="&lt;cinttypes&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ios&gt;" value\="&lt;ostream&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;iosfwd&gt;" value\="&lt;streambuf&gt;"/>\r\n<mapping key\="&lt;iso646.h&gt;" value\="&lt;ciso646&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;istream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;limits.h&gt;" value\="&lt;climits&gt;"/>\r\n<mapping key\="&lt;locale.h&gt;" value\="&lt;clocale&gt;"/>\r\n<mapping key\="&lt;math.h&gt;" value\="&lt;cmath&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;iostream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;fstream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;istream&gt;"/>\r\n<mapping key\="&lt;ostream&gt;" value\="&lt;sstream&gt;"/>\r\n<mapping key\="&lt;setjmp.h&gt;" value\="&lt;csetjmp&gt;"/>\r\n<mapping key\="&lt;signal.h&gt;" value\="&lt;csignal&gt;"/>\r\n<mapping key\="&lt;stdalign.h&gt;" value\="&lt;cstdalign&gt;"/>\r\n<mapping key\="&lt;stdarg.h&gt;" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="&lt;stdbool.h&gt;" value\="&lt;cstdbool&gt;"/>\r\n<mapping key\="&lt;stddef.h&gt;" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="&lt;stdint.h&gt;" value\="&lt;cstdint&gt;"/>\r\n<mapping key\="&lt;stdio.h&gt;" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="&lt;stdlib.h&gt;" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="&lt;streambuf&gt;" value\="&lt;ios&gt;"/>\r\n<mapping key\="&lt;string.h&gt;" value\="&lt;cstring&gt;"/>\r\n<mapping key\="&lt;tgmath.h&gt;" value\="&lt;ctgmath&gt;"/>\r\n<mapping key\="&lt;time.h&gt;" value\="&lt;ctime&gt;"/>\r\n<mapping key\="&lt;uchar.h&gt;" value\="&lt;cuchar&gt;"/>\r\n<mapping key\="&lt;wchar.h&gt;" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="&lt;wctype.h&gt;" value\="&lt;cwctype&gt;"/>\r\n</optional_substitution_map>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.heuristicHeader_substitution=true
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.symbolExportingHeaders=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<maps>\r\n<map>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="blksize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="calloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="calloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="daddr_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="dev_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="EOF" value\="&lt;libio.h&gt;"/>\r\n<mapping key\="EOF" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argp.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;argz.h&gt;"/>\r\n<mapping key\="error_t" value\="&lt;errno.h&gt;"/>\r\n<mapping key\="free" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="free" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsblkcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/statvfs.h&gt;"/>\r\n<mapping key\="fsfilcnt_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;grp.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="gid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/resource.h&gt;"/>\r\n<mapping key\="id_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="ino_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;dirent.h&gt;"/>\r\n<mapping key\="ino64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="int8_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;stdint.h&gt;"/>\r\n<mapping key\="intptr_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="key_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="malloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="malloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="mode_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="nlink_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdio&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cstring&gt;"/>\r\n<mapping key\="NULL" value\="&lt;ctime&gt;"/>\r\n<mapping key\="NULL" value\="&lt;cwchar&gt;"/>\r\n<mapping key\="NULL" value\="&lt;locale.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdio.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string&gt;"/>\r\n<mapping key\="NULL" value\="&lt;string.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;time.h&gt;"/>\r\n<mapping key\="NULL" value\="&lt;wchar.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/mman.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="off64_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;ctime&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/shm.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;termios.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;time.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="pid_t" value\="&lt;utmpx.h&gt;"/>\r\n<mapping key\="realloc" value\="&lt;cstdlib&gt;"/>\r\n<mapping key\="realloc" value\="&lt;stdlib.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/epoll.h&gt;"/>\r\n<mapping key\="sigset_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="size_t" value\="&lt;cstddef&gt;"/>\r\n<mapping key\="size_t" value\="&lt;stddef.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;arpa/inet.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;bits/socket.h&gt;"/>\r\n<mapping key\="socklen_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;monetary.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/msg.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="ssize_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;map&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;memory&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;set&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;string&gt;"/>\r\n<mapping key\="std\:\:allocator" value\="&lt;vector&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;istream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;ostream&gt;"/>\r\n<mapping key\="std\:\:char_traits" value\="&lt;string&gt;"/>\r\n<mapping key\="std\:\:swap" value\="&lt;bits/move.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/select.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/time.h&gt;"/>\r\n<mapping key\="suseconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;rpc/types.h&gt;"/>\r\n<mapping key\="u_char" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;pwd.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;signal.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;stropts.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/ipc.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/stat.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="uid_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;sys/types.h&gt;"/>\r\n<mapping key\="useconds_t" value\="&lt;unistd.h&gt;"/>\r\n<mapping key\="va_list" value\="&lt;cstdarg&gt;"/>\r\n<mapping key\="va_list" value\="&lt;stdarg.h&gt;"/>\r\n</map>\r\n</maps>
/bundle_defaults/org.eclipse.cdt.ui/organizeIncludes.unusedStatements=REMOVE
/bundle_defaults/org.eclipse.cdt.ui/pp_default=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/pp_default_bold=false
/bundle_defaults/org.eclipse.cdt.ui/pp_default_italic=false
/bundle_defaults/org.eclipse.cdt.ui/pp_directive=127,0,85
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_bold=true
/bundle_defaults/org.eclipse.cdt.ui/pp_directive_italic=false
/bundle_defaults/org.eclipse.cdt.ui/pp_header=42,0,255
/bundle_defaults/org.eclipse.cdt.ui/pp_header_bold=false
/bundle_defaults/org.eclipse.cdt.ui/pp_header_italic=false
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespace=true
/bundle_defaults/org.eclipse.cdt.ui/removeTrailingWhitespaceEditedLines=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.contentAssistAutoActivation=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.detect=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.enableAll=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.numberOfLines=5000
/bundle_defaults/org.eclipse.cdt.ui/scalability.parserBasedContentAssist=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.reconciler=true
/bundle_defaults/org.eclipse.cdt.ui/scalability.semanticHighlight=false
/bundle_defaults/org.eclipse.cdt.ui/scalability.syntaxColor=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.c_keyword.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.color=0,80,50
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.class.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.color=100,70,50
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enum.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumClass.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumClass.color=0,80,50
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumClass.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumClass.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumClass.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumClass.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.italic=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.enumerator.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.color=100,40,128
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.externalSDK.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.field.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.function.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.functionDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.italic=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.globalVariable.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.label.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariable.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.color=128,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.localVariableDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroDefinition.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.macroSubstitution.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.method.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.methodDeclaration.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.namespace.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.color=200,100,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.overloadedOperator.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.parameterVariable.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.color=224,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.problem.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.color=0,0,192
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.italic=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticField.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.color=0,0,0
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.italic=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.staticMethod.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.color=100,70,50
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.templateParameter.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.color=0,80,50
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.enabled=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.typedef.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.udlSuffix.bold=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.udlSuffix.color=92,53,102
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.udlSuffix.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.udlSuffix.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.udlSuffix.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.udlSuffix.underline=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.variablePassedByNonconstRef.bold=true
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.variablePassedByNonconstRef.color=200,100,150
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.variablePassedByNonconstRef.enabled=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.variablePassedByNonconstRef.italic=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.variablePassedByNonconstRef.strikethrough=false
/bundle_defaults/org.eclipse.cdt.ui/semanticHighlighting.variablePassedByNonconstRef.underline=false
/bundle_defaults/org.eclipse.cdt.ui/smartPaste=true
/bundle_defaults/org.eclipse.cdt.ui/smart_tab=true
/bundle_defaults/org.eclipse.cdt.ui/sourceHoverBackgroundColor.SystemDefault=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_digits=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_mixed=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_non_letters=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_sentence=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_single_letters=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_string_literals=false
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_upper=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_ignore_urls=true
/bundle_defaults/org.eclipse.cdt.ui/spelling_locale=en_US
/bundle_defaults/org.eclipse.cdt.ui/spelling_problems_threshold=100
/bundle_defaults/org.eclipse.cdt.ui/spelling_proposal_threshold=20
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary=
/bundle_defaults/org.eclipse.cdt.ui/spelling_user_dictionary_encoding=Cp1252
/bundle_defaults/org.eclipse.cdt.ui/stickyOccurrences=true
/bundle_defaults/org.eclipse.cdt.ui/subWordNavigation=true
/bundle_defaults/org.eclipse.cdt.ui/wizard.group.others.enable=true
/bundle_defaults/org.eclipse.cdt.ui/wrapStrings=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.AddedLinesRegex=
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.CappingDisable=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.HighlightTokenChanges=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.IgnoreWhitespace=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.InitiallyShowAncestorPane=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndAction=prompt
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndActionLocal=loop
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.OpenStructureCompare=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.PathFilter=
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.RemovedLinesRegex=
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SaveAllEditors=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.ShowPseudoConflicts=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.Swapped=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SynchronizeScrolling=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseOutlineView=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseSingleLine=true
/bundle_defaults/org.eclipse.core.net/nonProxiedHosts=localhost|127.0.0.1
/bundle_defaults/org.eclipse.core.net/proxiesEnabled=true
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/hasAuth=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTP/port=-1
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/hasAuth=false
/bundle_defaults/org.eclipse.core.net/proxyData/HTTPS/port=-1
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/hasAuth=false
/bundle_defaults/org.eclipse.core.net/proxyData/SOCKS/port=-1
/bundle_defaults/org.eclipse.core.net/systemProxiesEnabled=true
/bundle_defaults/org.eclipse.core.resources/delta.expiration=2592000000
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.core.resources/description.autobuilding=true
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.core.resources/description.disableLinking=false
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.core.resources/description.maxbuilditerations=10
/bundle_defaults/org.eclipse.core.resources/description.maxfilestates=50
/bundle_defaults/org.eclipse.core.resources/description.maxfilestatesize=1048576
/bundle_defaults/org.eclipse.core.resources/description.snapshotinterval=300000
/bundle_defaults/org.eclipse.core.resources/encoding=
/bundle_defaults/org.eclipse.core.resources/maxConcurrentBuilds=1
/bundle_defaults/org.eclipse.core.resources/missingNatureMarkerSeverity=1
/bundle_defaults/org.eclipse.core.resources/refresh.enabled=false
/bundle_defaults/org.eclipse.core.resources/refresh.lightweight.enabled=true
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_BREAKPOINT_MANAGER_ENABLED_STATE=true
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_DELETE_CONFIGS_ON_PROJECT_DELETE=false
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.PREF_ENABLE_STATUS_HANDLERS=true
/bundle_defaults/org.eclipse.debug.core/org.eclipse.debug.core.USE_STEP_FILTERS=false
/bundle_defaults/org.eclipse.debug.ui/Breakpoints.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.debug.ui/Console.console_tab_width=8
/bundle_defaults/org.eclipse.debug.ui/Console.highWaterMark=100000
/bundle_defaults/org.eclipse.debug.ui/Console.interpret_control_characters=false
/bundle_defaults/org.eclipse.debug.ui/Console.interpret_cr_as_control_characters=true
/bundle_defaults/org.eclipse.debug.ui/Console.limitConsoleOutput=true
/bundle_defaults/org.eclipse.debug.ui/Console.lowWaterMark=80000
/bundle_defaults/org.eclipse.debug.ui/Console.width=80
/bundle_defaults/org.eclipse.debug.ui/Console.wrap=false
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnErr=true
/bundle_defaults/org.eclipse.debug.ui/DEBUG.consoleOpenOnOut=true
/bundle_defaults/org.eclipse.debug.ui/Expressions.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.debug.ui/Modules.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.debug.ui/Registers.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.debug.ui/Variables.detail.orientation=Variables.detail.orientation.underneath
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.BreakpointSortingOrder=0
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.ExpressionView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchLastIfNotLaunchable=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.LaunchParentProject=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryKnownColor=0,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryHistoryUnknownColor=114,119,129
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_CHANGED_VALUE_BACKGROUND=255,255,0
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_CLOSED=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_DELETED=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_LAUNCH_TYPES=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_FILTER_WORKING_SETS=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.RelaunchAndTerminateLaunchAction=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.RemoveFromLaunchHistory=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.UseContextualLaunch=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowDetailPaneAction=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.VariableView+org.eclipse.debug.ui.ShowTypeNamesAction=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_debug_view=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.activate_workbench=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.auto_remove_old_launches=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.build_before_launch=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.cancel_launch_with_compile_errors=prompt
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.changedDebugElement=255,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.consoleBackground=255,255,255
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultAsciiCodePage=CP1252
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.defaultEbcdicCodePage=CP037
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.detail_pane_word_wrap=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.disable_all_breakpoints_prompt=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.errorColor=255,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.inColor=0,200,125
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.manage_view_perspectives=DEFAULT
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_detail_length=10000
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.max_history_size=10
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.columnSize=4
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.paddedStr=??
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.memory.rowSize=16
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.outColor=0,0,0
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.relaunch_in_debug_mode=never
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_breakpoints_prompt=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_expressions_prompt=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_all_trigger_breakpoints_prompt=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.remove_breakpoints_from_container_prompt=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reset_memory_block=org.eclipse.debug.uiresetMemoryBlock.visible
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.reuse_editor=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.save_dirty_editors_before_launch=prompt
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_debug_perspective_default=org.eclipse.debug.ui.DebugPerspective
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.show_run_perspective_default=perspective_none
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.skip_breakpoints_during_run_to_line=false
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_perspective_on_suspend=prompt
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.switch_to_perspective=never
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.track_views=true
/bundle_defaults/org.eclipse.debug.ui/org.eclipse.debug.ui.wait_for_build=always
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.Debug_view.mode=Debug_view.mode.auto
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.pageSize=20
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.postBufferSize=20
/bundle_defaults/org.eclipse.debug.ui/org.eclispe.debug.ui.memory.preBufferSize=20
/bundle_defaults/org.eclipse.debug.ui/org.eclpise.debug.ui.memory.dynamicLoad=true
/bundle_defaults/org.eclipse.egit.core/core_autoIgnoreDerivedResources=true
/bundle_defaults/org.eclipse.egit.core/core_autoShareProjects=true
/bundle_defaults/org.eclipse.egit.core/core_auto_stage_deletion=false
/bundle_defaults/org.eclipse.egit.core/core_auto_stage_moves=true
/bundle_defaults/org.eclipse.egit.core/core_defaultRepositoryDir=C\:\\Users\\marcu\\git
/bundle_defaults/org.eclipse.egit.core/core_deltaBaseCacheLimit=10485760
/bundle_defaults/org.eclipse.egit.core/core_gpg_signer=bc
/bundle_defaults/org.eclipse.egit.core/core_http_client=apache
/bundle_defaults/org.eclipse.egit.core/core_max_pull_threads_count=3
/bundle_defaults/org.eclipse.egit.core/core_packedGitLimit=10485760
/bundle_defaults/org.eclipse.egit.core/core_packedGitMMAP=false
/bundle_defaults/org.eclipse.egit.core/core_packedGitWindowSize=8192
/bundle_defaults/org.eclipse.egit.core/core_remote_connection_timeout=30
/bundle_defaults/org.eclipse.egit.core/core_save_credentials_in_secure_store=true
/bundle_defaults/org.eclipse.egit.core/core_streamFileThreshold=52428800
/bundle_defaults/org.eclipse.egit.ui/Blame_IgnoreWhitespace=false
/bundle_defaults/org.eclipse.egit.ui/CloneWizard_ShowDetailedFailureDialog=true
/bundle_defaults/org.eclipse.egit.ui/CloneWizard_StoreInSecureStore=false
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ColumnAuthorDateShow=true
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ColumnAuthorShow=true
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ColumnCommitterDateShow=true
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ColumnCommitterShow=true
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ColumnIdShow=true
/bundle_defaults/org.eclipse.egit.ui/HistoryView_MaxBranchLength=18
/bundle_defaults/org.eclipse.egit.ui/HistoryView_MaxDiffLines=1000
/bundle_defaults/org.eclipse.egit.ui/HistoryView_MaxNumberOfCommmits=10000
/bundle_defaults/org.eclipse.egit.ui/HistoryView_MaxTagLength=18
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ShowBranchSequence=true
/bundle_defaults/org.eclipse.egit.ui/HistoryView_ShowTagSequence=false
/bundle_defaults/org.eclipse.egit.ui/HistoryView_VerifySignatures=false
/bundle_defaults/org.eclipse.egit.ui/RebaseInteractive_SyncWithSelection=true
/bundle_defaults/org.eclipse.egit.ui/StagingView_CompareMode=true
/bundle_defaults/org.eclipse.egit.ui/StagingView_FileNameMode=true
/bundle_defaults/org.eclipse.egit.ui/StagingView_MaxLimitListMode=10000
/bundle_defaults/org.eclipse.egit.ui/StagingView_Presentation=LIST
/bundle_defaults/org.eclipse.egit.ui/StagingView_Presentation_Changed=false
/bundle_defaults/org.eclipse.egit.ui/always_show_push_wizard=false
/bundle_defaults/org.eclipse.egit.ui/always_use_staging_view=true
/bundle_defaults/org.eclipse.egit.ui/auto_lfs_config=false
/bundle_defaults/org.eclipse.egit.ui/auto_stage_on_commit=true
/bundle_defaults/org.eclipse.egit.ui/blockCommit=false
/bundle_defaults/org.eclipse.egit.ui/blockCommitCombo=2
/bundle_defaults/org.eclipse.egit.ui/checkBeforeCommitting=false
/bundle_defaults/org.eclipse.egit.ui/commit_dialog_hard_wrap_message=true
/bundle_defaults/org.eclipse.egit.ui/commit_dialog_history_size=10
/bundle_defaults/org.eclipse.egit.ui/commit_dialog_signed_off_by=false
/bundle_defaults/org.eclipse.egit.ui/commit_dialog_warn_about_message_second_line=true
/bundle_defaults/org.eclipse.egit.ui/date_format=yyyy-MM-dd HH\:mm\:ss
/bundle_defaults/org.eclipse.egit.ui/date_format_choice=CUSTOM
/bundle_defaults/org.eclipse.egit.ui/decorator_filetext_decoration={dirty\:>} {name}
/bundle_defaults/org.eclipse.egit.ui/decorator_foldertext_decoration={dirty\:>} {name}
/bundle_defaults/org.eclipse.egit.ui/decorator_projecttext_decoration={dirty\:>} {name} [{repository }{branch}{ branch_status}]
/bundle_defaults/org.eclipse.egit.ui/decorator_recompute_ancestors=true
/bundle_defaults/org.eclipse.egit.ui/decorator_show_assume_valid_icon=true
/bundle_defaults/org.eclipse.egit.ui/decorator_show_conflicts_icon=true
/bundle_defaults/org.eclipse.egit.ui/decorator_show_dirty_icon=false
/bundle_defaults/org.eclipse.egit.ui/decorator_show_staged_icon=true
/bundle_defaults/org.eclipse.egit.ui/decorator_show_tracked_icon=true
/bundle_defaults/org.eclipse.egit.ui/decorator_show_untracked_icon=true
/bundle_defaults/org.eclipse.egit.ui/decorator_submoduletext_decoration={dirty\:>} {name} [{branch}{ branch_status}]{ short_message}
/bundle_defaults/org.eclipse.egit.ui/enable_logical_model=true
/bundle_defaults/org.eclipse.egit.ui/findtoolbar_find_in=0
/bundle_defaults/org.eclipse.egit.ui/findtoolbar_ignore_case=true
/bundle_defaults/org.eclipse.egit.ui/merge_mode=2
/bundle_defaults/org.eclipse.egit.ui/refesh_index_interval=300
/bundle_defaults/org.eclipse.egit.ui/refesh_only_when_active=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_compare_mode=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_follow_renames=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_graph_split=500,500
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_last_selected_ref_filters=refs/tags/**\:HEAD\:refs/heads/**\:refs/remotes/**
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_ref_filters=
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_rev_split=700,300
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_selected_ref_filters=HEAD
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_additionalrefs=false
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_all_branches=false
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_comment_wrap=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_email_addresses=false
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_first_parent_only=false
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_notes=false
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_relative_date=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_rev_comment=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_rev_detail=true
/bundle_defaults/org.eclipse.egit.ui/resourcehistory_show_tooltips=false
/bundle_defaults/org.eclipse.egit.ui/restore_projects_on_checkout=true
/bundle_defaults/org.eclipse.egit.ui/show_checkout_confirmation=true
/bundle_defaults/org.eclipse.egit.ui/show_delete_repo_group_warning=true
/bundle_defaults/org.eclipse.egit.ui/show_detached_head_warning=true
/bundle_defaults/org.eclipse.egit.ui/show_fetch_success_dialog=true
/bundle_defaults/org.eclipse.egit.ui/show_home_drive_warning=true
/bundle_defaults/org.eclipse.egit.ui/show_initial_config_dialog=true
/bundle_defaults/org.eclipse.egit.ui/show_push_success_dialog=true
/bundle_defaults/org.eclipse.egit.ui/show_rebase_confirm=false
/bundle_defaults/org.eclipse.egit.ui/show_running_launch_on_checkout_warning=true
/bundle_defaults/org.eclipse.egit.ui/sync_view_changeset_pattern=[{author}] ({date}) {short_message}
/bundle_defaults/org.eclipse.egit.ui/sync_view_fetch_before_launch=true
/bundle_defaults/org.eclipse.egit.ui/sync_view_show_changeset_model=false
/bundle_defaults/org.eclipse.egit.ui/warnBeforeCommitting=2
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/download=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/enabled=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindElapsedTime=30 minutes
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/remindOnSchedule=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/schedule=on-startup
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk.scheduler/showUpdateWizard=false
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/checkAgainstCurrentJRE=true
/bundle_defaults/org.eclipse.equinox.p2.ui.sdk/showLatestVersion=true
/bundle_defaults/org.eclipse.jsch.core/PRIVATEKEY=id_dsa,id_rsa
/bundle_defaults/org.eclipse.jsch.core/SSH2HOME=C\:\\Users\\marcu\\.ssh
/bundle_defaults/org.eclipse.rse.core/CREATE_LOCAL_CONNECTION=true
/bundle_defaults/org.eclipse.rse.core/DEFAULT_PERSISTENCE_PROVIDER=org.eclipse.rse.persistence.MetadataPropertyFileProvider
/bundle_defaults/org.eclipse.rse.core/activeuserprofiles=Team;Lightning-II
/bundle_defaults/org.eclipse.rse.core/logging_level=0
/bundle_defaults/org.eclipse.rse.core/useDeferredQueries=true
/bundle_defaults/org.eclipse.rse.ui/APPEND_MNEMONICS_PATTERN=zh.*|ja.*|ko.*
/bundle_defaults/org.eclipse.rse.ui/MNEMONICS_POLICY=3
/bundle_defaults/org.eclipse.rse.ui/SHOW_EMPTY_LISTS=true
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.filterpools.show=false
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.history.folder=
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.order.connections=
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.qualifyconnectionnames=false
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.rememberState=true
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.restoreStateFromCache=true
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.shownewconnection=false
/bundle_defaults/org.eclipse.rse.ui/org.eclipse.rse.preferences.uda.cascade=false
/bundle_defaults/org.eclipse.ui.console/org.eclipse.ui.console.P_CONSOLE_AUTO_SCROLL_LOCK=true
/bundle_defaults/org.eclipse.ui.console/org.eclipse.ui.console.P_CONSOLE_WORD_WRAP=false
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.UseCustomCarets=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Accessibility.WideCaret=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background=255,255,255
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Background.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.FindScope=185,176,180
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground=0,0,0
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.Foreground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionBackground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Color.SelectionForeground.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/AbstractTextEditor.Navigation.SmartHomeEnd=true
/bundle_defaults/org.eclipse.ui.editors/Accessibility.UseSaturatedColors=false
/bundle_defaults/org.eclipse.ui.editors/TextOccurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/TextOccurrenceIndication=false
/bundle_defaults/org.eclipse.ui.editors/TextOccurrenceIndicationColor=212,212,212
/bundle_defaults/org.eclipse.ui.editors/TextOccurrenceIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/TextOccurrenceIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/TextOccurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/additionIndication=false
/bundle_defaults/org.eclipse.ui.editors/additionIndicationColor=188,188,222
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/additionIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndication=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationColor=34,164,99
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/bookmarkTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/breakpointHighlight=false
/bundle_defaults/org.eclipse.ui.editors/breakpointIndication=false
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationColor=0,0,255
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/breakpointIndicatorColor=0,0,255
/bundle_defaults/org.eclipse.ui.editors/breakpointTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/breakpointVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/changeIndication=false
/bundle_defaults/org.eclipse.ui.editors/changeIndicationColor=204,163,205
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/changeIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/currentIPColor=198,219,174
/bundle_defaults/org.eclipse.ui.editors/currentIPHighlight=true
/bundle_defaults/org.eclipse.ui.editors/currentIPIndication=false
/bundle_defaults/org.eclipse.ui.editors/currentIPOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/currentIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/currentIPVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/currentLine=true
/bundle_defaults/org.eclipse.ui.editors/currentLineColor=232,242,254
/bundle_defaults/org.eclipse.ui.editors/deletionIndication=false
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/deletionIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/errorIndication=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationColor=255,0,128
/bundle_defaults/org.eclipse.ui.editors/errorIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/errorIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/errorTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndication=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationColor=237,237,252
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/filteredSearchResultTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/hoverReplaceMode=0
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor=0,102,204
/bundle_defaults/org.eclipse.ui.editors/hyperlinkColor.SystemDefault=true
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifier=Ctrl
/bundle_defaults/org.eclipse.ui.editors/hyperlinkKeyModifierMask=262144
/bundle_defaults/org.eclipse.ui.editors/hyperlinksEnabled=true
/bundle_defaults/org.eclipse.ui.editors/indexResultIndication=true
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationColor=254,155,0
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/indexResultIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/infoIndication=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationColor=130,160,190
/bundle_defaults/org.eclipse.ui.editors/infoIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/infoIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/infoTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isAdditionGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isBookmarkGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isBreakpointIndicationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isChangeGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isDeletionGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isErrorGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isFilteredSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isIndexResultGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isIndexResultInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isInfoGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isRevisionAnnotationGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isSearchResultGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isSpellingGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isTaskGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isUnchangedGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/isWarningGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/lineNumberColor=120,120,120
/bundle_defaults/org.eclipse.ui.editors/lineNumberRuler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.color=0,180,0
/bundle_defaults/org.eclipse.ui.editors/linked.exit.highlight=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text=true
/bundle_defaults/org.eclipse.ui.editors/linked.exit.text.style=IBEAM
/bundle_defaults/org.eclipse.ui.editors/linked.exit.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.color=50,70,120
/bundle_defaults/org.eclipse.ui.editors/linked.focus.highlight=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text=true
/bundle_defaults/org.eclipse.ui.editors/linked.focus.text.style=BOX
/bundle_defaults/org.eclipse.ui.editors/linked.focus.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.color=180,215,255
/bundle_defaults/org.eclipse.ui.editors/linked.slave.highlight=true
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text=false
/bundle_defaults/org.eclipse.ui.editors/linked.slave.text.style=NONE
/bundle_defaults/org.eclipse.ui.editors/linked.slave.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.color=170,185,220
/bundle_defaults/org.eclipse.ui.editors/linked.target.highlight=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.dropdown=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.next=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.navigation.previous=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.overviewruler=false
/bundle_defaults/org.eclipse.ui.editors/linked.target.text=true
/bundle_defaults/org.eclipse.ui.editors/linked.target.text.style=BOX
/bundle_defaults/org.eclipse.ui.editors/linked.target.verticalruler=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.color=255,0,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.overview=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.ruler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.text=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.error.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.GoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.NextPrevDropdownToolbar=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.color=255,255,0
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.overview=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.ruler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.text=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.codan.ui.annotation.warning.textstyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.dsf.debug.ui.hyperlinkdetector.stepIntoSelection_stateMask=327680
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.editor.CElementHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOccurrenceGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToNextNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.isOverrideIndicatorGoToPreviousNavigationTarget=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndication=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationColor=212,212,212
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.occurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicator=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorColor=180,207,205
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.overrideIndicatorTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showOccurrenceInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.showoverrideIndicatorInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationColor=240,216,168
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.cdt.ui.writeOccurrenceTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedColor=221,255,221
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffAddedIndication=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedColor=255,221,221
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedGoToNextNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedGoToPreviousNavigationTarget=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.egit.ui.commitEditor.diffRemovedIndication=false
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.colorGreen=192,255,192
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.colorRed=255,192,192
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.highlightGreen=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.highlightRed=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.overviewGreen=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.overviewRed=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.rulerGreen=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.rulerRed=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.textGreen=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.linecoverage.slice.textRed=true
/bundle_defaults/org.eclipse.ui.editors/org.eclipse.ui.internal.editors.text.URLHyperlinkDetector_stateMask=-1
/bundle_defaults/org.eclipse.ui.editors/othersIndication=false
/bundle_defaults/org.eclipse.ui.editors/othersIndicationColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/othersIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/overviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/printMargin=false
/bundle_defaults/org.eclipse.ui.editors/printMarginAllowOverride=false
/bundle_defaults/org.eclipse.ui.editors/printMarginColor=176,180,185
/bundle_defaults/org.eclipse.ui.editors/printMarginColumn=80
/bundle_defaults/org.eclipse.ui.editors/quickdiff.characterMode=false
/bundle_defaults/org.eclipse.ui.editors/quickdiff.defaultProvider=org.eclipse.ui.internal.editors.quickdiff.LastSaveReferenceProvider
/bundle_defaults/org.eclipse.ui.editors/quickdiff.nowarn.before.switch=always
/bundle_defaults/org.eclipse.ui.editors/quickdiff.quickDiff=true
/bundle_defaults/org.eclipse.ui.editors/removeSpacesAsTabs=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndication=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationColor=88,88,22
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/revisionAnnotationIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerRenderingMode=Age
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowAuthor=false
/bundle_defaults/org.eclipse.ui.editors/revisionRulerShowRevision=false
/bundle_defaults/org.eclipse.ui.editors/rulerContributions=
/bundle_defaults/org.eclipse.ui.editors/searchResultHighlighting=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndication=false
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationColor=206,204,247
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/searchResultIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/searchResultTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/secondaryIPColor=219,235,204
/bundle_defaults/org.eclipse.ui.editors/secondaryIPHighlight=true
/bundle_defaults/org.eclipse.ui.editors/secondaryIPIndication=false
/bundle_defaults/org.eclipse.ui.editors/secondaryIPOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/secondaryIPTextStyle=NONE
/bundle_defaults/org.eclipse.ui.editors/secondaryIPVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/showAdditionInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showAnnotationAsCodeMiningLevel=0
/bundle_defaults/org.eclipse.ui.editors/showAnnotationAsCodeMiningMax=100
/bundle_defaults/org.eclipse.ui.editors/showBookmarkInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showBreakpointIndicationInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showCaretOffset=true
/bundle_defaults/org.eclipse.ui.editors/showCarriageReturn=true
/bundle_defaults/org.eclipse.ui.editors/showChangeInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showDeletionInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/showEnclosedIdeographicSpaces=true
/bundle_defaults/org.eclipse.ui.editors/showEnclosedSpaces=true
/bundle_defaults/org.eclipse.ui.editors/showEnclosedTabs=true
/bundle_defaults/org.eclipse.ui.editors/showErrorInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showFilteredSearchResultInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/showInfoInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showLeadingIdeographicSpaces=true
/bundle_defaults/org.eclipse.ui.editors/showLeadingSpaces=true
/bundle_defaults/org.eclipse.ui.editors/showLeadingTabs=true
/bundle_defaults/org.eclipse.ui.editors/showLineFeed=true
/bundle_defaults/org.eclipse.ui.editors/showRevisionAnnotationInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/showSearchResultInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showSelectionSize=true
/bundle_defaults/org.eclipse.ui.editors/showSpellingInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showTaskInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showTextHoverAffordance=true
/bundle_defaults/org.eclipse.ui.editors/showTrailingIdeographicSpaces=true
/bundle_defaults/org.eclipse.ui.editors/showTrailingSpaces=true
/bundle_defaults/org.eclipse.ui.editors/showTrailingTabs=true
/bundle_defaults/org.eclipse.ui.editors/showUnchangedInNextPrevDropdownToolbarAction=false
/bundle_defaults/org.eclipse.ui.editors/showWarningInNextPrevDropdownToolbarAction=true
/bundle_defaults/org.eclipse.ui.editors/showWhitespaceCharacters=false
/bundle_defaults/org.eclipse.ui.editors/show_range_indicator=true
/bundle_defaults/org.eclipse.ui.editors/spacesForTabs=false
/bundle_defaults/org.eclipse.ui.editors/spellingEnabled=true
/bundle_defaults/org.eclipse.ui.editors/spellingEngine=
/bundle_defaults/org.eclipse.ui.editors/spellingIndication=true
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationColor=255,128,64
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/spellingIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/spellingTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.editors/tabWidth=4
/bundle_defaults/org.eclipse.ui.editors/taskIndication=false
/bundle_defaults/org.eclipse.ui.editors/taskIndicationColor=0,128,255
/bundle_defaults/org.eclipse.ui.editors/taskIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/taskIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/taskTextStyle=SQUIGGLES
/bundle_defaults/org.eclipse.ui.editors/textDragAndDropEnabled=true
/bundle_defaults/org.eclipse.ui.editors/unchangedIndication=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationColor=0,0,0
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInOverviewRuler=false
/bundle_defaults/org.eclipse.ui.editors/unchangedIndicationInVerticalRuler=false
/bundle_defaults/org.eclipse.ui.editors/undoHistorySize=200
/bundle_defaults/org.eclipse.ui.editors/useAnnotationsPrefPage=false
/bundle_defaults/org.eclipse.ui.editors/useQuickDiffPrefPage=false
/bundle_defaults/org.eclipse.ui.editors/warn_if_input_derived=true
/bundle_defaults/org.eclipse.ui.editors/warningIndication=true
/bundle_defaults/org.eclipse.ui.editors/warningIndicationColor=244,200,45
/bundle_defaults/org.eclipse.ui.editors/warningIndicationHighlighting=false
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInOverviewRuler=true
/bundle_defaults/org.eclipse.ui.editors/warningIndicationInVerticalRuler=true
/bundle_defaults/org.eclipse.ui.editors/warningTextStyle=PROBLEM_UNDERLINE
/bundle_defaults/org.eclipse.ui.editors/whitespaceCharacterAlphaValue=80
/bundle_defaults/org.eclipse.ui.editors/wordwrap.enabled=false
/bundle_defaults/org.eclipse.ui.ide/CLOSE_UNRELATED_PROJECTS=false
/bundle_defaults/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW=false
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_MODE=prompt
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_RELATIVE=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_TYPE=
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_VIRTUAL_FOLDER_MODE=prompt
/bundle_defaults/org.eclipse.ui.ide/LIMIT_PROBLEMS=true
/bundle_defaults/org.eclipse.ui.ide/MARKER_LIMITS_VALUE=100
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.ide/REFRESH_WORKSPACE_ON_STARTUP=false
/bundle_defaults/org.eclipse.ui.ide/SAVE_ALL_BEFORE_BUILD=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_LOCATION=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_LOCATION_NAME=true
/bundle_defaults/org.eclipse.ui.ide/SHOW_PERSPECTIVE_IN_TITLE=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_PROBLEMS_VIEW_DECORATIONS_ON_STARTUP=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_PRODUCT_IN_TITLE=true
/bundle_defaults/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/bundle_defaults/org.eclipse.ui.ide/SYSTEM_EXPLORER=explorer /E,/select\=${selected_resource_loc}
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/bundle_defaults/org.eclipse.ui.ide/WARN_ABOUT_WORKSPACE_INCOMPATIBILITY=true
/bundle_defaults/org.eclipse.ui.ide/WELCOME_DIALOG=true
/bundle_defaults/org.eclipse.ui.ide/helpContextAvailabilityCheck=true
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/bundle_defaults/org.eclipse.ui.ide/unassociatedEditorStrategy=org.eclipse.ui.ide.systemEditorThenTextEditor
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.assist=true
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.main=true
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.updates=true
/bundle_defaults/org.eclipse.ui.monitoring/deadlock_reporting_threshold=300000
/bundle_defaults/org.eclipse.ui.monitoring/log_to_error_log=true
/bundle_defaults/org.eclipse.ui.monitoring/long_event_error_threshold=1200
/bundle_defaults/org.eclipse.ui.monitoring/long_event_warning_threshold=500
/bundle_defaults/org.eclipse.ui.monitoring/max_stack_samples=3
/bundle_defaults/org.eclipse.ui.monitoring/monitoring_enabled=false
/bundle_defaults/org.eclipse.ui.monitoring/noninteresting_thread_filter=java.*,sun.*,org.eclipse.core.internal.jobs.WorkerPool.sleep,org.eclipse.core.internal.jobs.WorkerPool.startJob,org.eclipse.core.internal.jobs.Worker.run,org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent,org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run,org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.run,org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run
/bundle_defaults/org.eclipse.ui.monitoring/ui_thread_filter=
/bundle_defaults/org.eclipse.ui.workbench/BIDI_SUPPORT=false
/bundle_defaults/org.eclipse.ui.workbench/COLOR_ICONS=true
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_DIALOG_FONT=false
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_OPEN_EDITOR_IN_PLACE=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_DISPLAY_FULL_NAME=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SELECTION_SCOPE=1
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SORT_CRITERIA=0
/bundle_defaults/org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=3
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_CONFIGURABLE_PROJECT_WIZARD=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_COOL_BARS=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_NEW_MENUS=true
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/bundle_defaults/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_TAB=0
/bundle_defaults/org.eclipse.ui.workbench/LAYOUT_DIRECTION=0
/bundle_defaults/org.eclipse.ui.workbench/MAX_PROGRESS_ENTRIES=20
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST=true
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/bundle_defaults/org.eclipse.ui.workbench/NL_EXTENSIONS=
/bundle_defaults/org.eclipse.ui.workbench/OPEN_AFTER_DELAY=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_ON_SINGLE_CLICK=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_PERSPECTIVE_MODE=0
/bundle_defaults/org.eclipse.ui.workbench/RECENT_FILES=20
/bundle_defaults/org.eclipse.ui.workbench/RESOURCE_RENAME_MODE=inline
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS=99
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=true
/bundle_defaults/org.eclipse.ui.workbench/RUN_IN_BACKGROUND=true
/bundle_defaults/org.eclipse.ui.workbench/SAVE_AUTOMATICALLY=false
/bundle_defaults/org.eclipse.ui.workbench/SAVE_AUTOMATICALLY_INTERVAL=20
/bundle_defaults/org.eclipse.ui.workbench/SELECT_ON_HOVER=false
/bundle_defaults/org.eclipse.ui.workbench/SINGLE_CLICK_METHOD=0
/bundle_defaults/org.eclipse.ui.workbench/STICKY_CYCLE=false
/bundle_defaults/org.eclipse.ui.workbench/TEXT_DIRECTION=
/bundle_defaults/org.eclipse.ui.workbench/USE_IPERSISTABLE_EDITORS=true
/bundle_defaults/org.eclipse.ui.workbench/WORKBENCH_SAVE_INTERVAL=5
/bundle_defaults/org.eclipse.ui.workbench/coolBarVisible=true
/bundle_defaults/org.eclipse.ui.workbench/overridepresentation=false
/bundle_defaults/org.eclipse.ui.workbench/perspectiveBarVisible=true
/bundle_defaults/org.eclipse.ui.workbench/shouldPromptForEnablement=true
/bundle_defaults/org.eclipse.ui.workbench/showCommandKeysForKeyboard=false
/bundle_defaults/org.eclipse.ui.workbench/showCommandKeysForMouseEvents=false
/bundle_defaults/org.eclipse.ui.workbench/showCommandKeys_timeToClose=3000
/bundle_defaults/org.eclipse.ui/ALTERNATE_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/bundle_defaults/org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=-1
/bundle_defaults/org.eclipse.ui/EDITOR_TAB_POSITION=128
/bundle_defaults/org.eclipse.ui/ENABLE_32_STICKY_CLOSE_BEHAVIOR=false
/bundle_defaults/org.eclipse.ui/ENABLE_DETACHED_VIEWS=true
/bundle_defaults/org.eclipse.ui/ENABLE_MIN_MAX=true
/bundle_defaults/org.eclipse.ui/KEY_CONFIGURATION_ID=org.eclipse.ui.defaultAcceleratorConfiguration
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/bundle_defaults/org.eclipse.ui/OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/PROMPT_WHEN_SAVEABLE_STILL_OPEN=true
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/bundle_defaults/org.eclipse.ui/SHOW_MEMORY_MONITOR=false
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/bundle_defaults/org.eclipse.ui/SHOW_OPEN_ON_PERSPECTIVE_BAR=true
/bundle_defaults/org.eclipse.ui/SHOW_OTHER_IN_PERSPECTIVE_MENU=true
/bundle_defaults/org.eclipse.ui/SHOW_SYSTEM_JOBS=false
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=false
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_QUICK_ACCESS=false
/bundle_defaults/org.eclipse.ui/USE_COLORED_LABELS=true
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/bundle_defaults/org.eclipse.ui/VIEW_MINIMUM_CHARACTERS=1
/bundle_defaults/org.eclipse.ui/VIEW_TAB_POSITION=128
/bundle_defaults/org.eclipse.ui/disableNewFastView=false
/bundle_defaults/org.eclipse.ui/initialFastViewBarLocation=bottom
/bundle_defaults/org.eclipse.ui/showIntro=true
/configuration/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=10
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=G\:\\EmbedWorkSpaces\\workspace_v11
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=3
/configuration/org.eclipse.ui.ide/SHOW_RECENT_WORKSPACES=false
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=false
/instance/com.ti.ccstudio.branding/initialized=true
/instance/com.ti.ccstudio.debug.ui/useAnnotationsPrefPage=true
/instance/com.ti.ccstudio.lerm/Pref_Default_Format_Details__=0
/instance/com.ti.ccstudio.system.setup/DEFAULT_CCS_TARGET_CONFIGURATION=D\:\\workspaces2022\\ti_exp432\\blinky_MSP_EXP432E401Y_nortos_ccs\\targetConfigs\\MSP432E401Y.ccxml
/instance/com.ti.ccstudio.ui/CCStudioUIStartup.CCS_IMAGE_INFO=G\:/EmbedWorkSpaces/workspace_v11|G\:/ti/ccs1110/ccs|11.1.0.00011
/instance/com.ti.ccstudio.ui/com.ti.ccstudio.ui.CCS_INSTALL_LOCATION=G\:/ti/ccs1110/ccs
/instance/com.ti.ccstudio.ui/com.ti.ccstudio.ui.CCS_VERSION=11.1.0.00011
/instance/com.ti.ccstudio.ui/com.ti.ccstudio.ui.CCS_WORKSPACE_LOCATION=G\:/EmbedWorkSpaces/workspace_v11
/instance/com.ti.ccstudio.ui/com.ti.ccstudio.ui.IS_NOT_FIRST_CCS_LAUNCH=true
/instance/org.eclipse.cdt.core.prj-blinky_MSP_EXP432E401Y_nortos_ccs/indexer/preferenceScope=0
/instance/org.eclipse.cdt.core.prj-led_ex1_blinky/indexer/preferenceScope=0
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_arguments_in_method_invocation=18
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_assignment=16
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_type_declaration=82
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_binary_expression=16
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_compact_if=16
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression=34
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_conditional_expression_chain=18
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_constructor_initializer_list=0
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_declarator_list=16
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_enumerator_list=48
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expression_list=0
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_expressions_in_array_initializer=18
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_lambda_expression=20
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_member_access=0
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_overloaded_left_shift_chain=18
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_parameters_in_method_declaration=18
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.alignment_for_throws_clause_in_method_declaration=16
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_array_initializer=end_of_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block=next_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_block_in_case=next_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_linkage_declaration=end_of_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_method_declaration=next_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_namespace_declaration=next_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_switch=next_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.brace_position_for_type_declaration=next_line
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.line_up_line_comment_in_blocks_on_first_column=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.min_distance_between_code_and_line_comment=1
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.never_indent_line_comments_on_first_column=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment_formatter_off_tag=@formatter\:off
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.comment_formatter_on_tag=@formatter\:on
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.compact_else_if=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation=2
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.continuation_indentation_for_array_initializer=2
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_block_comment=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_guardian_clause_on_one_line=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_header_comment=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.format_line_comment=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_compare_to_type_header=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_access_specifier_extra_spaces=0
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_access_specifier=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_linkage=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_namespace_header=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_breaks_compare_to_cases=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_declaration_compare_to_template_header=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_empty_lines=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_label_compare_to_statements=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_block=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_statements_compare_to_body=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_cases=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_switch=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.indentation.size=4
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_colon_in_constructor_initializer_list=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_label=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_after_template_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_file_if_missing=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_catch_in_try_statement=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_colon_in_constructor_initializer_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_else_in_if_statement=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_identifier_in_function_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_before_while_in_do_statement=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_new_line_in_empty_block=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_assignment_operator=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_binary_operator=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_arguments=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_parameters=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_brace_in_block=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_closing_paren_in_cast=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_base_clause=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_case=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_conditional=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_colon_in_labeled_statement=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_array_initializer=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_base_types=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_declarator_list=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_enum_declarations=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_expression_list=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_throws=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_structured_binding_name_list=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_arguments=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_parameters=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_lambda_return=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_arguments=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_parameters=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_bracket=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_cast=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_catch=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_exception_specification=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_for=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_if=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_invocation=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_switch=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_while=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_opening_structured_binding_name_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_pointer_in_declarator_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_pointer_in_method_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_postfix_operator=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_prefix_operator=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_question_in_conditional=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_semicolon_in_for=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_after_unary_operator=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_assignment_operator=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_binary_operator=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_arguments=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_parameters=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_bracket=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_cast=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_catch=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_exception_specification=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_for=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_if=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_invocation=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_switch=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_while=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_closing_structured_binding_name_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_base_clause=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_case=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_conditional=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_default=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_colon_in_labeled_statement=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_array_initializer=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_base_types=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_declarator_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_enum_declarations=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_expression_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_throws=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_structured_binding_name_list=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_arguments=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_parameters=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_lambda_return=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_arguments=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_parameters=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_array_initializer=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_block=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_linkage_declaration=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_method_declaration=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_namespace_declaration=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_switch=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_type_declaration=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_bracket=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_catch=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_exception_specification=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_for=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_if=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_invocation=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_switch=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_while=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_opening_structured_binding_name_list=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_pointer_in_declarator_list=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_pointer_in_method_declaration=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_postfix_operator=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_prefix_operator=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_question_in_conditional=insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_ref_qualifier_in_structured_binding=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_semicolon_in_for=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_before_unary_operator=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_braces_in_array_initializer=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_brackets=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_exception_specification=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_declaration=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_invocation=do not insert
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.join_wrapped_lines=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_else_statement_on_same_line=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_empty_array_initializer_on_one_line=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_imple_if_on_one_line=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.keep_then_statement_on_same_line=false
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.lineSplit=80
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.number_of_empty_lines_to_preserve=1
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.put_empty_statement_on_new_line=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.char=space
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.tabulation.size=space
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_comment_formatter_tag=true
/instance/org.eclipse.cdt.core/org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_indentations=false
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.default_source_containers=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<sourceLookupDirector>\r\n    <sourceContainers duplicates\="false">\r\n        <container memento\="AbsolutePath" typeId\="org.eclipse.cdt.debug.core.containerType.absolutePath"/>\r\n        <container memento\="programRelativePath" typeId\="org.eclipse.cdt.debug.core.containerType.programRelativePath"/>\r\n        <container memento\="&lt;?xml version\=&quot;1.0&quot; encoding\=&quot;UTF-8&quot; standalone\=&quot;no&quot;?&gt;&\#13;&\#10;&lt;project referencedProjects\=&quot;true&quot;/&gt;&\#13;&\#10;" typeId\="org.eclipse.cdt.debug.core.containerType.project"/>\r\n    </sourceContainers>\r\n</sourceLookupDirector>\r\n
/instance/org.eclipse.cdt.dsf.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/blinky_MSP_EXP432E401Y_nortos_ccs.com.ti.ccstudio.buildDefinitions.MSP432.ProjectType.1625390038/com.ti.ccstudio.buildDefinitions.MSP432.Debug.1818425925=com.ti.ccstudio.buildDefinitions.MSP432_20.2.hex.22374989\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP432_20.2.exe.DebugToolchain.1225355512\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP432_20.2.exe.linkerDebug.1272274424\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.MSP432_20.2.exe.compilerDebug.2078005391\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/led_ex1_blinky.com.ti.ccstudio.buildDefinitions.C2000.ProjectType.1083171218/com.ti.ccstudio.buildDefinitions.C2000.Default.1139463476=com.ti.ccstudio.buildDefinitions.C2000_21.6.hex.1512288798\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.DebugToolchain.806653237\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.sysConfig.1674251713\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.linkerDebug.1823435406\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.compilerDebug.930531835\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.1139463476\=rebuildState\\\=true\\r\\nrcState\\\=4\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.ToolchainPlaceholder.219910720\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/led_ex1_blinky.com.ti.ccstudio.buildDefinitions.C2000.ProjectType.1083171218/com.ti.ccstudio.buildDefinitions.C2000.Default.1455916397=com.ti.ccstudio.buildDefinitions.C2000_21.6.exe.compilerDebug.352673644\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.sysConfig.2068294036\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.hex.1101380257\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.ToolchainPlaceholder.1158076371\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.1455916397\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.DebugToolchain.1393162451\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.linkerDebug.395219883\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/led_ex1_blinky.com.ti.ccstudio.buildDefinitions.C2000.ProjectType.1083171218/com.ti.ccstudio.buildDefinitions.C2000.Default.1925378080=com.ti.ccstudio.buildDefinitions.C2000.Default.ToolchainPlaceholder.1983995171\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.DebugToolchain.298916517\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.linkerDebug.373712595\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.sysConfig.730061591\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.1925378080\=rebuildState\\\=true\\r\\nrcState\\\=4\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.hex.1350728228\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.compilerDebug.18592075\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/led_ex1_blinky.com.ti.ccstudio.buildDefinitions.C2000.ProjectType.1083171218/com.ti.ccstudio.buildDefinitions.C2000.Default.598720797=com.ti.ccstudio.buildDefinitions.C2000.Default.ToolchainPlaceholder.558030837\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.sysConfig.288223799\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.598720797\=rebuildState\\\=true\\r\\nrcState\\\=4\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.DebugToolchain.2024087467\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.compilerDebug.711568907\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.hex.2007122121\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.linkerDebug.1752410666\=rebuildState\\\=true\\r\\n\r\n
/instance/org.eclipse.cdt.managedbuilder.core/properties/sdl_ex_flash_ecc_test.com.ti.ccstudio.buildDefinitions.C2000.ProjectType.1749333098/com.ti.ccstudio.buildDefinitions.C2000.Default.1981019448=com.ti.ccstudio.buildDefinitions.C2000_21.6.hex.1872558479\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.1981019448\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.DebugToolchain.1893505228\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.linkerDebug.983635608\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.hex.372090404\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000.Default.ToolchainPlaceholder.122664298\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.linkerDebug.1313609804\=rebuildState\\\=false\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.DebugToolchain.1062029460\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.compilerDebug.1600430294\=rebuildState\\\=true\\r\\n\r\ncom.ti.ccstudio.buildDefinitions.C2000_21.6.exe.compilerDebug.122013182\=rebuildState\\\=false\\r\\n\r\n
/instance/org.eclipse.cdt.ui/buildConsoleWrapLines_COPY=true
/instance/org.eclipse.cdt.ui/formatter_profile=_CCS
/instance/org.eclipse.cdt.ui/formatter_settings_version=1
/instance/org.eclipse.cdt.ui/org.eclipse.cdt.ui.formatterprofiles=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<profiles version\="1">\r\n    <profile kind\="CodeFormatterProfile" name\="CCS" version\="1">\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_exception_specification" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_pointer_in_method_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.format_header_comment" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_parenthesized_expression" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_for" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_brace_in_array_initializer" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_for" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_statements_compare_to_body" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_structured_binding_name_list" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_colon_in_base_clause" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_array_initializer" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_switch" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_linkage_declaration" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_conditional_expression" value\="34"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_colon_in_labeled_statement" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_empty_lines" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_cast" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_prefix_operator" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_after_opening_brace_in_array_initializer" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.comment.preserve_white_space_between_code_and_line_comments" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_closing_paren_in_cast" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_structured_binding_name_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_invocation" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_throws_clause_in_method_declaration" value\="16"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_enum_declarations" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_binary_operator" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_semicolon" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_binary_expression" value\="16"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_method_declaration" value\="next_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_semicolon_in_for" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_array_initializer" value\="end_of_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_method_declaration" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_method_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_between_empty_braces_in_array_initializer" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_pointer_in_declarator_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_switch" value\="next_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_expression_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.keep_else_statement_on_same_line" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_colon_in_base_clause" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_base_types" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.use_tabs_only_for_leading_indentations" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_method_invocation" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.keep_then_statement_on_same_line" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_at_end_of_file_if_missing" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.comment.line_up_line_comment_in_blocks_on_first_column" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_namespace_header" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.keep_empty_array_initializer_on_one_line" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_access_specifier_extra_spaces" value\="0"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_lambda_return" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.comment.never_indent_line_comments_on_first_column" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_before_else_in_if_statement" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_expression_list" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_block" value\="next_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_bracket" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_base_clause_in_type_declaration" value\="82"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_parameters" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_throws" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_member_access" value\="0"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_after_colon_in_constructor_initializer_list" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_if" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_namespace_declaration" value\="next_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_block" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_for" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_parenthesized_expression" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_parameters_in_method_declaration" value\="18"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.lineSplit" value\="80"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_colon_in_default" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.comment_formatter_off_tag" value\="@formatter\:off"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.number_of_empty_lines_to_preserve" value\="1"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_parameters" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_between_empty_brackets" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_angle_bracket_in_template_arguments" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_declaration_throws" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_bracket" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_arguments" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_arguments" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_compact_if" value\="16"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_prefix_operator" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_declarator_list" value\="16"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_expressions_in_array_initializer" value\="18"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_while" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_between_empty_parens_in_exception_specification" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_cast" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.continuation_indentation_for_array_initializer" value\="2"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_lambda_expression" value\="20"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.comment.min_distance_between_code_and_line_comment" value\="1"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_bracket" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_constructor_initializer_list" value\="0"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_colon_in_case" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_switch" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_catch" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_exception_specification" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_brace_in_array_initializer" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_declarator_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_catch" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.format_line_comment" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_angle_bracket_in_template_parameters" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_type_declaration" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_semicolon_in_for" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_if" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_invocation_arguments" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.format_block_comment" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_block_in_case" value\="next_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_postfix_operator" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_parameters" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.compact_else_if" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_switch" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_overloaded_left_shift_chain" value\="18"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_method_invocation_arguments" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_before_identifier_in_function_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_in_empty_block" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.comment_formatter_on_tag" value\="@formatter\:on"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_linkage" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_lambda_return" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_after_label" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_declarator_list" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_colon_in_labeled_statement" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_statements_compare_to_block" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_brace_in_namespace_declaration" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_access_specifier_compare_to_type_header" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_parameters" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_if" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_pointer_in_declarator_list" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_conditional_expression_chain" value\="18"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.tabulation.char" value\="space"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_after_template_declaration" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_ref_qualifier_in_structured_binding" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_before_colon_in_constructor_initializer_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_enum_declarations" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_before_catch_in_try_statement" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_type_declaration" value\="next_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_assignment_operator" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_binary_operator" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.keep_imple_if_on_one_line" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_before_closing_brace_in_array_initializer" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.continuation_indentation" value\="2"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_new_line_before_while_in_do_statement" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_structured_binding_name_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.put_empty_statement_on_new_line" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_structured_binding_name_list" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_closing_brace_in_block" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.format_guardian_clause_on_one_line" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indentation.size" value\="4"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_parameters" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_switch" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_expression_list" value\="0"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_method_invocation" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_colon_in_conditional" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_unary_operator" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_array_initializer" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_colon_in_case" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_base_types" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_assignment_operator" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_breaks_compare_to_cases" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_label_compare_to_statements" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_array_initializer" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_switchstatements_compare_to_cases" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_declaration_compare_to_template_header" value\="false"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_method_declaration_parameters" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.use_comment_formatter_tag" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_angle_bracket_in_template_arguments" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_opening_paren_in_catch" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_parenthesized_expression" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_arguments_in_method_invocation" value\="18"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_while" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_exception_specification" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_question_in_conditional" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_paren_in_switch" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_unary_operator" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.join_wrapped_lines" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_colon_in_conditional" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_postfix_operator" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_assignment" value\="16"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.brace_position_for_linkage_declaration" value\="end_of_line"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_while" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_comma_in_template_arguments" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_after_closing_angle_bracket_in_template_arguments" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_comma_in_template_parameters" value\="do not insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_question_in_conditional" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.indent_body_declarations_compare_to_access_specifier" value\="true"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.alignment_for_enumerator_list" value\="48"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_opening_structured_binding_name_list" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_pointer_in_method_declaration" value\="insert"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.tabulation.size" value\="space"/>\r\n        <setting id\="org.eclipse.cdt.core.formatter.insert_space_before_closing_paren_in_method_invocation" value\="do not insert"/>\r\n    </profile>\r\n</profiles>\r\n
/instance/org.eclipse.cdt.ui/org.eclipse.cdt.ui.formatterprofiles.version=1
/instance/org.eclipse.cdt.ui/spelling_locale_initialized=true
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.core.net/org.eclipse.core.net.hasMigrated=true
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.applicationLaunchType=org.eclipse.cdt.dsf.gdb.launch.localCLaunch,debug,;org.eclipse.cdt.cdi.launch.localCLaunch,run,;
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.attachLaunchType=org.eclipse.cdt.dsf.gdb.launch.attachCLaunch,debug,;
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.postmortemLaunchType=org.eclipse.cdt.dsf.gdb.launch.coreCLaunch,debug,;
/instance/org.eclipse.debug.core//org.eclipse.debug.core.PREFERRED_DELEGATES/org.eclipse.cdt.launch.remoteApplicationLaunchType=org.eclipse.rse.remotecdt.dsf.debug,debug,;
/instance/org.eclipse.debug.core/prefWatchExpressions=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<watchExpressions/>\r\n
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAUNCH_PERSPECTIVES=<?xml version\="1.0" encoding\="UTF-8" standalone\="no"?>\r\n<launchPerspectives>\r\n    <launchPerspective configurationType\="com.ti.ccstudio.debug.launchType.device.debugging" mode\="debug" perspective\="perspective_none"/>\r\n    <launchPerspective configurationType\="com.ti.ccstudio.debug.launchType.device.debugging" delegate\="com.ti.ccstudio.debug.launchType.device.debugging" mode\="debug" perspective\="perspective_none"/>\r\n</launchPerspectives>\r\n
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.DebugVieworg.eclipse.debug.ui.DebugView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<DebugViewMemento org.eclipse.debug.ui.BREADCRUMB_DROPDOWN_AUTO_EXPAND\="false"/>
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.ExpressionView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.ExpressionView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="PRESENTATION_SHOW_LOGICAL_STRUCTURES"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.RegisterView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.RegisterView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="PRESENTATION_SHOW_LOGICAL_STRUCTURES"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclipse.debug.ui.VariableView=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<VariablesViewMemento org.eclipse.debug.ui.SASH_DETAILS_PART\="315" org.eclipse.debug.ui.SASH_VIEW_PART\="684">\r\n<PRESENTATION_CONTEXT_PROPERTIES IMemento.internal.id\="org.eclipse.debug.ui.VariableView">\r\n<BOOLEAN BOOLEAN\="true" IMemento.internal.id\="PRESENTATION_SHOW_LOGICAL_STRUCTURES"/>\r\n</PRESENTATION_CONTEXT_PROPERTIES>\r\n</VariablesViewMemento>
/instance/org.eclipse.debug.ui/preferredTargets=com.ti.ccstudio.debug.ui.editorToggleBreakpointTarget,org.eclipse.cdt.debug.ui.toggleCBreakpointTarget,org.eclipse.cdt.debug.ui.toggleCDynamicPrintfTarget\:com.ti.ccstudio.debug.ui.editorToggleBreakpointTarget|
/instance/org.eclipse.jsch.core/org.eclipse.jsch.core.hasChangedDefaultWin32SshHome=true
/instance/org.eclipse.jsch.core/org.eclipse.jsch.core.hasMigratedSsh2Preferences=true
/instance/org.eclipse.launchbar.core/LaunchTargetManager/org.eclipse.launchbar.core.launchTargetType.local,Local/arch=x86_64
/instance/org.eclipse.launchbar.core/LaunchTargetManager/org.eclipse.launchbar.core.launchTargetType.local,Local/name=Local
/instance/org.eclipse.launchbar.core/LaunchTargetManager/org.eclipse.launchbar.core.launchTargetType.local,Local/os=win32
/instance/org.eclipse.launchbar.core/configDescList=org.eclipse.launchbar.core.descriptorType.default\:led_ex1_blinky
/instance/org.eclipse.launchbar.core/org.eclipse.launchbar.core.descriptorType.default\:blinky_MSP_EXP432E401Y_nortos_ccs/activeLaunchMode=debug
/instance/org.eclipse.launchbar.core/org.eclipse.launchbar.core.descriptorType.default\:blinky_MSP_EXP432E401Y_nortos_ccs/activeLaunchTarget=org.eclipse.launchbar.core.launchTargetType.local\:Local
/instance/org.eclipse.launchbar.core/org.eclipse.launchbar.core.descriptorType.default\:led_ex1_blinky/activeLaunchMode=debug
/instance/org.eclipse.launchbar.core/org.eclipse.launchbar.core.descriptorType.default\:led_ex1_blinky/activeLaunchTarget=org.eclipse.launchbar.core.launchTargetType.local\:Local
/instance/org.eclipse.rse.core/activeuserprofiles=Lightning-II;Team
/instance/org.eclipse.rse.core/org.eclipse.rse.systemtype.local.systemType.defaultUserId=marcu
/instance/org.eclipse.rse.core/useridperkey=Lightning-II.Local\=marcu;
/instance/org.eclipse.rse.ui/org.eclipse.rse.preferences.order.connections=Lightning-II.Local
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0" encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external location\="C\:\\Program Files\\Mozilla Firefox\\firefox.exe" name\="Firefox"/>\r\n<external location\="C\:\\Program Files (x86)\\Microsoft\\Edge\\Application\\msedge.exe" name\="Microsoft Edge"/>\r\n</web-browsers>
/instance/org.eclipse.ui.ide/platformState=1648281285694
/instance/org.eclipse.ui.ide/quickStart=false
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.navigator/org.eclipse.ui.navigator.ProjectExplorer.filterActivation=\:org.eclipse.rse.project.filters.RemoteSystemsProjects\:org.eclipse.ui.navigator.resources.filters.startsWithDot\:org.eclipse.cdt.ui.navigator.filters.AnonymousStructFilter\:org.eclipse.ui.navigator.resources.nested.HideTopLevelProjectIfNested\:org.eclipse.ui.navigator.resources.nested.HideFolderWhenProjectIsShownAsNested\:org.eclipse.cdt.ui.navigator.filters.ForwardDeclarationFilter\:
/instance/org.eclipse.ui.workbench//org.eclipse.ui.commands/state/org.eclipse.ui.navigator.resources.nested.changeProjectPresentation/org.eclipse.ui.commands.radioState=false
/instance/org.eclipse.ui.workbench/RUN_IN_BACKGROUND=false
/instance/org.eclipse.ui.workbench/UIActivities.com.ti.ccstudio.activities.RSEActivity=true
/instance/org.eclipse.ui.workbench/org.eclipse.ui.workbench.ACTIVE_NOFOCUS_TAB_BG_END=255,255,255
/instance/org.eclipse.ui.workbench/org.eclipse.ui.workbench.ACTIVE_NOFOCUS_TAB_BG_START=255,255,255
/instance/org.eclipse.ui.workbench/org.eclipse.ui.workbench.ACTIVE_NOFOCUS_TAB_TEXT_COLOR=16,16,16
/instance/org.eclipse.ui.workbench/org.eclipse.ui.workbench.ACTIVE_TAB_BG_END=255,255,255
/instance/org.eclipse.ui.workbench/org.eclipse.ui.workbench.ACTIVE_TAB_BG_START=255,255,255
/instance/org.eclipse.ui.workbench/org.eclipse.ui.workbench.INACTIVE_TAB_BG_END=255,255,255
/instance/org.eclipse.ui/showIntro=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/name=Bundle pool
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/name=G\:\\ti\\ccs1110\\ccs\\eclipse\\.eclipseextension
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/suffix=eclipse
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/type=org.eclipse.equinox.p2.extensionlocation.artifactRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/.eclipseextension
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/version=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/name=dropins
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/configuration/org.eclipse.osgi/373/data/listener_1925729951/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/name=download cache
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/p2/org.eclipse.equinox.p2.core/cache/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.core_cache/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/name=Bundle pool
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/p2/org.eclipse.equinox.p2.touchpoint.eclipse/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.touchpoint.eclipse/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_modeling_emf_emf_builds/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_modeling_emf_emf_builds/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_modeling_emf_emf_builds/uri=http\://download.eclipse.org/modeling/emf/emf/builds/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_modeling_gmp_gmf-runtime_updates_releases/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_modeling_gmp_gmf-runtime_updates_releases/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_modeling_gmp_gmf-runtime_updates_releases/uri=http\://download.eclipse.org/modeling/gmp/gmf-runtime/updates/releases/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_legacy_releases/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_legacy_releases/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_legacy_releases/uri=http\://download.eclipse.org/tools/gef/updates/legacy/releases/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__rxtx.qbang.org_eclipse/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__rxtx.qbang.org_eclipse/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__rxtx.qbang.org_eclipse/uri=http\://rxtx.qbang.org/eclipse
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_TargetContent_Updates_full_site.xml/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_TargetContent_Updates_full_site.xml/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_TargetContent_Updates_full_site.xml/uri=http\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/TargetContent/Updates/full/site.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_P2/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_P2/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_P2/uri=http\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/P2
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/count=3
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/nickname=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/uri=http\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/name=Blackhawk CCSv9.0 Emulation Update
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/uri=http\://www.blackhawk-dsp.com/updates/win64/com.bh.ccstudio.emulation.win64_9.0.0.001
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.eclipse.org_egit_updates/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.eclipse.org_egit_updates/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.eclipse.org_egit_updates/uri=https\://download.eclipse.org/egit/updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/name=SEGGER JLink TI CCS plugin
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/uri=https\://download.segger.com/J-Link/JLink_TI_CCS_plugin
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/name=TI C2000 Device Support 6.1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/uri=https\://software-dl.ti.com/C2000/esd/ccsv7/p2linux
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/name=TI C2000 Device Support 6.1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/uri=https\://software-dl.ti.com/C2000/esd/ccsv7/p2osx
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/name=TI C2000 Device Support 6.1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/uri=https\://software-dl.ti.com/C2000/esd/ccsv7/p2win32
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/count=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/name="Code Composer Studio Updates"
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/nickname=Code Composer Studio v11 Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/suffix=compositeArtifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/type=org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/uri=https\://software-dl.ti.com/ccs/esd/CCSv11/Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/name=Code Composer Studio v11 Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/uri=https\://software-dl.ti.com/ccs/esd/CCSv11/Updates/CCS11.1.0.00011_update
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/auto
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/digital_power
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/keystone2
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/radar
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/sitara
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/sitara_mcu
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/unified
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/count=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/name=Exported Repository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/nickname=DVT Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/uri=https\://software-dl.ti.com/ccs/non-esd/dvt/ccs6.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/name=MSP430 GCC
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/uri=https\://software-dl.ti.com/codegen/esd/mspgcc
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/count=6
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/name=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/nickname=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/suffix=artifacts.xml.xz
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/uri=https\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/name=Low Power RF Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/uri=https\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/smartrf/CCSv6
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/name=EMUPack SR Release
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/uri=https\://software-dl.ti.com/emulation/esd/emupack/ccsv9up/linux/latest
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/name=EMUPack SR Release
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/uri=https\://software-dl.ti.com/emulation/esd/emupack/ccsv9up/osx/latest
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/name=EMUPack SR Release
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/uri=https\://software-dl.ti.com/emulation/esd/emupack/ccsv9up/win64/latest
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/name=Exported Repository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/uri=https\://software-dl.ti.com/msp430/esd/v10/updates-430/gcc
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/name=Exported Repository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/uri=https\://software-dl.ti.com/msp430/esd/v10/updates-430/ti
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/name=Split MSP Components Test
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/suffix=artifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/type=org.eclipse.equinox.p2.artifact.repository.simpleRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/uri=https\://software-dl.ti.com/msp430/esd/v10/updates-432/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/count=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/name=Blackhawk CCS v9.0 P2 Update Site
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/nickname=Blackhawk CCSv10 Emulation Update
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/suffix=compositeArtifacts.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/type=org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/uri=https\://www.blackhawk-dsp.com/updates/ccsv9
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.artifact.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/name=G\:\\ti\\ccs1110\\ccs\\eclipse\\.eclipseextension
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/suffix=eclipse
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/type=org.eclipse.equinox.p2.extensionlocation.metadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/.eclipseextension
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_.eclipseextension/version=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/name=dropins
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/configuration/org.eclipse.osgi/373/data/listener_1925729951/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/name=file\:/G\:/ti/ccs1110/ccs/eclipse/p2/org.eclipse.equinox.p2.engine/profileRegistry/epp.package.cpp.profile
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/suffix=profile
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/type=org.eclipse.equinox.p2.engine.repo.metadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/uri=file\:/G\:/ti/ccs1110/ccs/eclipse/p2/org.eclipse.equinox.p2.engine/profileRegistry/epp.package.cpp.profile
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/file\:_G\:_ti_ccs1110_ccs_eclipse_p2_org.eclipse.equinox.p2.engine_profileRegistry_epp.package.cpp.profile/version=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emf_emf_builds/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emf_emf_builds/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_emf_emf_builds/uri=http\://download.eclipse.org/modeling/emf/emf/builds/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmp_gmf-runtime_updates_releases/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmp_gmf-runtime_updates_releases/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_modeling_gmp_gmf-runtime_updates_releases/uri=http\://download.eclipse.org/modeling/gmp/gmf-runtime/updates/releases/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_legacy_releases/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_legacy_releases/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__download.eclipse.org_tools_gef_updates_legacy_releases/uri=http\://download.eclipse.org/tools/gef/updates/legacy/releases/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__rxtx.qbang.org_eclipse/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__rxtx.qbang.org_eclipse/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__rxtx.qbang.org_eclipse/uri=http\://rxtx.qbang.org/eclipse
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_TargetContent_Updates_full_site.xml/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_TargetContent_Updates_full_site.xml/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_TargetContent_Updates_full_site.xml/uri=http\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/TargetContent/Updates/full/site.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_P2/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_P2/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_P2/uri=http\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/P2
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/count=3
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/name=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/nickname=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/suffix=content.xml.xz
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/uri=http\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/name=Blackhawk CCSv9.0 Emulation Update
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/uri=http\://www.blackhawk-dsp.com/updates/win64/com.bh.ccstudio.emulation.win64_9.0.0.001
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/http\:__www.blackhawk-dsp.com_updates_win64_com.bh.ccstudio.emulation.win64_9.0.0.001/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.eclipse.org_egit_updates/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.eclipse.org_egit_updates/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.eclipse.org_egit_updates/uri=https\://download.eclipse.org/egit/updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/name=SEGGER JLink TI CCS plugin
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/uri=https\://download.segger.com/J-Link/JLink_TI_CCS_plugin
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__download.segger.com_J-Link_JLink_TI_CCS_plugin/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/name=TI C2000 Device Support 6.1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/uri=https\://software-dl.ti.com/C2000/esd/ccsv7/p2linux
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2linux/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/name=TI C2000 Device Support 6.1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/uri=https\://software-dl.ti.com/C2000/esd/ccsv7/p2osx
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2osx/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/name=TI C2000 Device Support 6.1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/uri=https\://software-dl.ti.com/C2000/esd/ccsv7/p2win32
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_C2000_esd_ccsv7_p2win32/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/count=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/name="Code Composer Studio Updates"
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/nickname=Code Composer Studio v11 Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/suffix=compositeContent.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/type=org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/uri=https\://software-dl.ti.com/ccs/esd/CCSv11/Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/name=Code Composer Studio v11 Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/uri=https\://software-dl.ti.com/ccs/esd/CCSv11/Updates/CCS11.1.0.00011_update
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_CCSv11_Updates_CCS11.1.0.00011_update/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/auto
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_auto/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/digital_power
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_digital_power/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/keystone2
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_keystone2/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/radar
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_radar/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/sitara
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/sitara_mcu
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_sitara_mcu/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/name=Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/uri=https\://software-dl.ti.com/ccs/esd/device_support_ccsv9/unified
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_esd_device_support_ccsv9_unified/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/count=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/name=Exported Repository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/nickname=DVT Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/uri=https\://software-dl.ti.com/ccs/non-esd/dvt/ccs6.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_ccs_non-esd_dvt_ccs6.0/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/name=MSP430 GCC
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/uri=https\://software-dl.ti.com/codegen/esd/mspgcc
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_codegen_esd_mspgcc/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/count=6
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/name=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/nickname=Code Generation Tools Updates
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/suffix=content.xml.xz
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/uri=https\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_codegen_Updates_p2win32/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/name=Low Power RF Device Support
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/uri=https\://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/smartrf/CCSv6
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_dsps_dsps_public_sw_sdo_ccstudio_smartrf_CCSv6/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/name=EMUPack SR Release
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/uri=https\://software-dl.ti.com/emulation/esd/emupack/ccsv9up/linux/latest
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_linux_latest/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/name=EMUPack SR Release
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/uri=https\://software-dl.ti.com/emulation/esd/emupack/ccsv9up/osx/latest
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_osx_latest/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/name=EMUPack SR Release
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/uri=https\://software-dl.ti.com/emulation/esd/emupack/ccsv9up/win64/latest
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_emulation_esd_emupack_ccsv9up_win64_latest/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/name=Exported Repository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/uri=https\://software-dl.ti.com/msp430/esd/v10/updates-430/gcc
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_gcc/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/name=Exported Repository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/uri=https\://software-dl.ti.com/msp430/esd/v10/updates-430/ti
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-430_ti/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/enabled=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/isSystem=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/name=Split MSP Components Test
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/suffix=content.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/type=org.eclipse.equinox.internal.p2.metadata.repository.LocalMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/uri=https\://software-dl.ti.com/msp430/esd/v10/updates-432/
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__software-dl.ti.com_msp430_esd_v10_updates-432/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/count=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/description=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/enabled=true
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/isSystem=false
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/name=Blackhawk CCS v9.0 P2 Update Site
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/nickname=Blackhawk CCSv10 Emulation Update
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/provider=
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/suffix=compositeContent.xml
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/type=org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/uri=https\://www.blackhawk-dsp.com/updates/ccsv9
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/repositories/https\:__www.blackhawk-dsp.com_updates_ccsv9/version=1.0.0
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.metadata.repository/s/file\:_G\:_ti_ccs1110_ccs_eclipse_configuration_org.eclipse.osgi_373_data_listener_1925729951/version=1
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk.scheduler/lastAutoCheckForUpdates=2022-03-30T22\:03\:12.108-0700
/profile/file\:\\2fG\:\\2fti\\2fccs1110\\2fccs\\2feclipse\\2fconfiguration\\2f..\\2fp2\\2f/_SELF_/org.eclipse.equinox.p2.ui.sdk/allowNonOKPlan=prompt
/project/led_ex1_blinky/org.eclipse.cdt.codan.core/inEditor=false
/project/led_ex1_blinky/org.eclipse.cdt.codan.core/onBuild=false
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/device/subdir_rules.mk=UTF-8
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/device/subdir_vars.mk=UTF-8
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/makefile=UTF-8
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/objects.mk=UTF-8
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/sources.mk=UTF-8
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/subdir_rules.mk=UTF-8
/project/led_ex1_blinky/org.eclipse.core.resources/encoding//CPU1_RAM/subdir_vars.mk=UTF-8
@com.ti.ccstudio.branding=10.0.0.202112011800
@com.ti.ccstudio.debug.ui=11.1.0.202112011800
@com.ti.ccstudio.lerm=8.0.0.202112011800
@com.ti.ccstudio.system.setup=10.3.0.202112011800
@com.ti.ccstudio.ui=10.3.0.202112011800
@org.eclipse.cdt.core=7.2.0.202102251239
@org.eclipse.cdt.debug.core=8.6.0.202011181638
@org.eclipse.cdt.dsf.ui=2.6.100.202011291939
@org.eclipse.cdt.managedbuilder.core=9.2.0.202103011047
@org.eclipse.cdt.ui=7.1.100.202101112014
@org.eclipse.core.net=1.3.1000.v20200715-0827
@org.eclipse.core.resources=3.14.0.v20210215-0934
@org.eclipse.debug.core=3.18.0.v20210222-1101
@org.eclipse.debug.ui=3.14.800.v20210222-1101
@org.eclipse.jsch.core=1.3.900.v20200422-1935
@org.eclipse.launchbar.core=2.4.100.202010121414
@org.eclipse.rse.core=4.5.300.202101081027
@org.eclipse.rse.ui=4.5.300.202101081027
@org.eclipse.ui=3.119.0.v20210111-1350
@org.eclipse.ui.browser=3.6.1100.v20210118-1327
@org.eclipse.ui.ide=3.18.100.v20210122-1536
@org.eclipse.ui.navigator=3.10.0.v20210111-1352
@org.eclipse.ui.workbench=3.122.100.v20210215-1525
file_export_version=3.0
*** Current Install Configuration:
Bundles in the system:
Id: com.google.gson, Version: 2.8.6.v20201231-1626, Location: reference:file:plugins/com.google.gson_2.8.6.v20201231-1626.jar
Id: com.ibm.icu, Version: 67.1.0.v20200706-1749, Location: reference:file:plugins/com.ibm.icu_67.1.0.v20200706-1749.jar
Id: com.jcraft.jsch, Version: 0.1.55.v20190404-1902, Location: reference:file:plugins/com.jcraft.jsch_0.1.55.v20190404-1902.jar
Id: com.sun.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/com.sun.el_2.2.0.v201303151357.jar
Id: com.sun.jna, Version: 4.5.1.v20190425-1842, Location: reference:file:plugins/com.sun.jna_4.5.1.v20190425-1842.jar
Id: com.sun.jna, Version: 5.6.0.v20200716-0148, Location: reference:file:plugins/com.sun.jna_5.6.0.v20200716-0148.jar
Id: com.sun.jna.platform, Version: 4.5.1.v20190425-1842, Location: reference:file:plugins/com.sun.jna.platform_4.5.1.v20190425-1842.jar
Id: com.sun.jna.platform, Version: 5.6.0.v20200722-0209, Location: reference:file:plugins/com.sun.jna.platform_5.6.0.v20200722-0209.jar
Id: com.sun.xml.bind, Version: 2.3.3.v20201118-1818, Location: reference:file:plugins/com.sun.xml.bind_2.3.3.v20201118-1818.jar
Id: com.ti.arm.18.1.help_18.1.0.20181119225258, Version: 18.1.0, Location: reference:file:plugins/com.ti.arm.18.1.help_18.1.0.20181119225258_18.1.0/
Id: com.ti.backplane, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.backplane_8.0.0.202112011800.jar
Id: com.ti.base.ui, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.base.ui_8.0.0.202112011800.jar
Id: com.ti.binding.program, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.binding.program_8.0.0.202112011800.jar
Id: com.ti.binding.stream, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.binding.stream_8.0.0.202112011800/
Id: com.ti.browser, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.browser_8.0.0.202112011800.jar
Id: com.ti.c2000.18.1.help_18.1.0.20180221222139, Version: 18.1.0, Location: reference:file:plugins/com.ti.c2000.18.1.help_18.1.0.20180221222139_18.1.0/
Id: com.ti.cc2538, Version: 2.0.4.11, Location: reference:file:plugins/com.ti.cc2538_2.00.04.11/
Id: com.ti.ccscloud.server, Version: 11.1.0.202112011800, Location: reference:file:plugins/com.ti.ccscloud.server_11.1.0.202112011800.jar
Id: com.ti.ccscloud.xcs, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccscloud.xcs_8.0.0.202112011800.jar
Id: com.ti.ccstudio.abc, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.abc_8.0.0.202112011800.jar
Id: com.ti.ccstudio.activities, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.activities_8.0.0.202112011800.jar
Id: com.ti.ccstudio.app.center, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.app.center_8.0.0.202112011800/
Id: com.ti.ccstudio.app.center.p2, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.app.center.p2_8.0.0.202112011800.jar
Id: com.ti.ccstudio.apps, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.apps_11.0.0.202112011800.jar
Id: com.ti.ccstudio.base, Version: 11.1.0.02593, Location: reference:file:plugins/com.ti.ccstudio.base_11.1.0.02593/
Id: com.ti.ccstudio.binaryparser, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.binaryparser_8.0.0.202112011800.jar
Id: com.ti.ccstudio.branding, Version: 10.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.branding_10.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.C2000, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C2000_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.C2000_legacy, Version: 5.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C2000_legacy_5.1.0.202112011800.jar
Id: com.ti.ccstudio.buildDefinitions.C5500, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C5500_8.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.C5500_legacy, Version: 5.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C5500_legacy_5.1.0.202112011800.jar
Id: com.ti.ccstudio.buildDefinitions.C6000, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C6000_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.C6000_legacy, Version: 5.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C6000_legacy_5.1.0.202112011800.jar
Id: com.ti.ccstudio.buildDefinitions.C7000, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.C7000_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.EVE, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.EVE_8.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.GNU, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.GNU_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.GNU_legacy, Version: 5.4.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.GNU_legacy_5.4.0.202112011800.jar
Id: com.ti.ccstudio.buildDefinitions.LLVM, Version: 9.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.LLVM_9.1.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.MSP430, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.MSP430_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.MSP430_legacy, Version: 6.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.MSP430_legacy_6.0.0.202112011800.jar
Id: com.ti.ccstudio.buildDefinitions.MSP432, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.MSP432_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.PRU, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.PRU_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.TICLANG, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.TICLANG_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.TMS470, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.TMS470_11.0.0.202112011800/
Id: com.ti.ccstudio.buildDefinitions.TMS470_legacy, Version: 5.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.buildDefinitions.TMS470_legacy_5.1.0.202112011800.jar
Id: com.ti.ccstudio.builddefinitions.generator, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.builddefinitions.generator_11.0.0.202112011800.jar
Id: com.ti.ccstudio.controlsuite, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.controlsuite_8.0.0.202112011800.jar
Id: com.ti.ccstudio.core, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.core_11.0.0.202112011800.jar
Id: com.ti.ccstudio.debug, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug_11.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.cacheView, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.cacheView_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.dsf.extensions, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.dsf.extensions_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.server, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.server_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.server.core, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.server.core_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.trace.core, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.trace.core_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.trace.msp430, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.trace.msp430_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.trace.ui, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.trace.ui_8.0.0.202112011800.jar
Id: com.ti.ccstudio.debug.ui, Version: 11.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.ui_11.1.0.202112011800.jar
Id: com.ti.ccstudio.debug.ui.msp430, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.debug.ui.msp430_8.0.0.202112011800.jar
Id: com.ti.ccstudio.energia.core, Version: 10.3.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.energia.core_10.3.0.202112011800/
Id: com.ti.ccstudio.energia.ui, Version: 10.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.energia.ui_10.0.0.202112011800/
Id: com.ti.ccstudio.errorparser, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.errorparser_11.0.0.202112011800/
Id: com.ti.ccstudio.errorparser.ui, Version: 10.2.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.errorparser.ui_10.2.0.202112011800.jar
Id: com.ti.ccstudio.errorreporting, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.errorreporting_8.0.0.202112011800.jar
Id: com.ti.ccstudio.grace, Version: 1.0.0.202003291417, Location: reference:file:plugins/com.ti.ccstudio.grace_1.0.0.202003291417.jar
Id: com.ti.ccstudio.grace.ui, Version: 1.0.0.202003291417, Location: reference:file:plugins/com.ti.ccstudio.grace.ui_1.0.0.202003291417.jar
Id: com.ti.ccstudio.help, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.help_8.0.0.202112011800.jar
Id: com.ti.ccstudio.highlights, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.highlights_8.0.0.202112011800.jar
Id: com.ti.ccstudio.highlights.msp430, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.highlights.msp430_8.0.0.202112011800/
Id: com.ti.ccstudio.ide, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.ide_8.0.0.202112011800.jar
Id: com.ti.ccstudio.jline, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.jline_8.0.0.202112011800.jar
Id: com.ti.ccstudio.lerm, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.lerm_8.0.0.202112011800.jar
Id: com.ti.ccstudio.lers, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.lers_8.0.0.202112011800.jar
Id: com.ti.ccstudio.leru, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.leru_8.0.0.202112011800.jar
Id: com.ti.ccstudio.log4j, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.log4j_8.0.0.202112011800/
Id: com.ti.ccstudio.multi.purpose.view, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.multi.purpose.view_8.0.0.202112011800.jar
Id: com.ti.ccstudio.multi.purpose.view.contributors, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.multi.purpose.view.contributors_8.0.0.202112011800.jar
Id: com.ti.ccstudio.p2.actions, Version: 7.0.0.202001271514, Location: reference:file:plugins/com.ti.ccstudio.p2.actions_7.0.0.202001271514.jar
Id: com.ti.ccstudio.p2.common, Version: 7.0.0.202001271514, Location: reference:file:plugins/com.ti.ccstudio.p2.common_7.0.0.202001271514.jar
Id: com.ti.ccstudio.p2app, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.p2app_8.0.0.202112011800.jar
Id: com.ti.ccstudio.p2ui, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.p2ui_8.0.0.202112011800.jar
Id: com.ti.ccstudio.project.core, Version: 11.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.project.core_11.1.0.202112011800.jar
Id: com.ti.ccstudio.project.templates, Version: 10.3.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.project.templates_10.3.0.202112011800/
Id: com.ti.ccstudio.project.ui, Version: 11.1.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.project.ui_11.1.0.202112011800.jar
Id: com.ti.ccstudio.project.ui.views, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.project.ui.views_11.0.0.202112011800.jar
Id: com.ti.ccstudio.project.ui.webcontent, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.project.ui.webcontent_11.0.0.202112011800.jar
Id: com.ti.ccstudio.resource.explorer, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.resource.explorer_8.0.0.202112011800/
Id: com.ti.ccstudio.resource.explorer.packages, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.resource.explorer.packages_8.0.0.202112011800.jar
Id: com.ti.ccstudio.rhino, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.rhino_11.0.0.202112011800.jar
Id: com.ti.ccstudio.scripting.console, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.scripting.console_8.0.0.202112011800.jar
Id: com.ti.ccstudio.scripting.dss, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.scripting.dss_8.0.0.202112011800.jar
Id: com.ti.ccstudio.scripting.gss, Version: 10.2.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.scripting.gss_10.2.0.202112011800.jar
Id: com.ti.ccstudio.scripting.ui, Version: 9.2.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.scripting.ui_9.2.0.202112011800.jar
Id: com.ti.ccstudio.scripting.ui.win32, Version: 5.3.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.scripting.ui.win32_5.3.0.202112011800.jar
Id: com.ti.ccstudio.startupInstaller, Version: 6.0.0.202001271514, Location: reference:file:plugins/com.ti.ccstudio.startupInstaller_6.0.0.202001271514.jar
Id: com.ti.ccstudio.swt, Version: 5.3.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.swt_5.3.0.202112011800.jar
Id: com.ti.ccstudio.system.hotmenu, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.system.hotmenu_8.0.0.202112011800.jar
Id: com.ti.ccstudio.system.setup, Version: 10.3.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.system.setup_10.3.0.202112011800.jar
Id: com.ti.ccstudio.system.setup.ui, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.system.setup.ui_8.0.0.202112011800.jar
Id: com.ti.ccstudio.ui, Version: 10.3.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.ui_10.3.0.202112011800.jar
Id: com.ti.ccstudio.ui.forms, Version: 10.2.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.ui.forms_10.2.0.202112011800.jar
Id: com.ti.ccstudio.usersguide.doc, Version: 11.1.0.202111291008, Location: reference:file:plugins/com.ti.ccstudio.usersguide.doc_11.1.0.202111291008/
Id: com.ti.ccstudio.webcontent, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.ccstudio.webcontent_8.0.0.202112011800/
Id: com.ti.cgt.c6000.7.4.help, Version: 7.4.0, Location: reference:file:plugins/com.ti.cgt.c6000.7.4.help_7.4.0/
Id: com.ti.chromium.browser, Version: 2.0.0.202112011800, Location: reference:file:plugins/com.ti.chromium.browser_2.0.0.202112011800.jar
Id: com.ti.chromium.browser.win32.win32.x86_64, Version: 2.0.0.202112011800, Location: reference:file:plugins/com.ti.chromium.browser.win32.win32.x86_64_2.0.0.202112011800/
Id: com.ti.common.core, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.common.core_11.0.0.202112011800.jar
Id: com.ti.common.core.utils.ds, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.common.core.utils.ds_8.0.0.202112011800.jar
Id: com.ti.common.core.utils.local, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.common.core.utils.local_8.0.0.202112011800.jar
Id: com.ti.common.project.core, Version: 11.1.0.202112011800, Location: reference:file:plugins/com.ti.common.project.core_11.1.0.202112011800.jar
Id: com.ti.common.project.ui, Version: 10.3.0.202112011800, Location: reference:file:plugins/com.ti.common.project.ui_10.3.0.202112011800.jar
Id: com.ti.common.ui, Version: 11.0.0.202112011800, Location: reference:file:plugins/com.ti.common.ui_11.0.0.202112011800.jar
Id: com.ti.dbgtrc.webapp, Version: 1.1.0.202005140757, Location: reference:file:plugins/com.ti.dbgtrc.webapp_1.1.0.202005140757.jar
Id: com.ti.dvt.analysis.framework, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.analysis.framework_4.1.0.202106281057/
Id: com.ti.dvt.analysis.suite, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.analysis.suite_4.1.0.202106281057/
Id: com.ti.dvt.analysis.suite.gui, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.analysis.suite.gui_4.1.0.202106281057/
Id: com.ti.dvt.analysis.traceviewer, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.analysis.traceviewer_4.1.0.202106281057/
Id: com.ti.dvt.analyzersuite, Version: 3.5.0.202106281057, Location: reference:file:plugins/com.ti.dvt.analyzersuite_3.5.0.202106281057.jar
Id: com.ti.dvt.ccstudioideadapter, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ccstudioideadapter_4.1.0.202106281057.jar
Id: com.ti.dvt.ccstudioideadapter.bin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ccstudioideadapter.bin_4.1.0.202106281057/
Id: com.ti.dvt.ccstudiosymbolmanager, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ccstudiosymbolmanager_4.1.0.202106281057.jar
Id: com.ti.dvt.codecoverage, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.codecoverage_4.1.0.202106281057.jar
Id: com.ti.dvt.codegenCoverage, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.codegenCoverage_4.1.0.202106281057/
Id: com.ti.dvt.control.engine, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.control.engine_4.1.0.202106281057/
Id: com.ti.dvt.control.gui, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.control.gui_4.1.0.202106281057.jar
Id: com.ti.dvt.core, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.core_4.1.0.202106281057.jar
Id: com.ti.dvt.coverageplugin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.coverageplugin_4.1.0.202106281057.jar
Id: com.ti.dvt.datamodel, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.datamodel_4.1.0.202106281057/
Id: com.ti.dvt.energytrace, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.energytrace_4.1.0.202106281057/
Id: com.ti.dvt.graph.visualization, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.graph.visualization_4.1.0.202106281057/
Id: com.ti.dvt.graph.visualization.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.graph.visualization.doc_4.1.0.202106281057.jar
Id: com.ti.dvt.gridview, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.gridview_4.1.0.202106281057.jar
Id: com.ti.dvt.ideadapter, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ideadapter_4.1.0.202106281057/
Id: com.ti.dvt.ideadapter2, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ideadapter2_4.1.0.202106281057/
Id: com.ti.dvt.ofssymbolmanager, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ofssymbolmanager_4.1.0.202106281057/
Id: com.ti.dvt.profile.setup.ui, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.profile.setup.ui_4.1.0.202106281057.jar
Id: com.ti.dvt.profileanalysis, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.profileanalysis_4.1.0.202106281057/
Id: com.ti.dvt.profileanalysis.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.profileanalysis.doc_4.1.0.202106281057.jar
Id: com.ti.dvt.profileanalysismanager, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.profileanalysismanager_4.1.0.202106281057.jar
Id: com.ti.dvt.profileanalysismanagerplugin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.profileanalysismanagerplugin_4.1.0.202106281057.jar
Id: com.ti.dvt.profiledata, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.profiledata_4.1.0.202106281057.jar
Id: com.ti.dvt.rcp, Version: 3.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.rcp_3.1.0.202106281057/
Id: com.ti.dvt.rovsupport, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.rovsupport_4.1.0.202106281057.jar
Id: com.ti.dvt.rovsupport.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.rovsupport.doc_4.1.0.202106281057.jar
Id: com.ti.dvt.rta.interfaces, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.rta.interfaces_4.1.0.202106281057.jar
Id: com.ti.dvt.scripting.engine, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.engine_4.1.0.202106281057/
Id: com.ti.dvt.scripting.ui, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.ui_4.1.0.202106281057.jar
Id: com.ti.dvt.scripting.ui.graphvisualization, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.ui.graphvisualization_4.1.0.202106281057.jar
Id: com.ti.dvt.scripting.ui.profileanalysis, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.ui.profileanalysis_4.1.0.202106281057.jar
Id: com.ti.dvt.scripting.ui.rov, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.ui.rov_4.1.0.202106281057.jar
Id: com.ti.dvt.scripting.ui.trace, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.ui.trace_4.1.0.202106281057.jar
Id: com.ti.dvt.scripting.ui.via, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.scripting.ui.via_4.1.0.202106281057.jar
Id: com.ti.dvt.server, Version: 3.62.1.16, Location: reference:file:plugins/com.ti.dvt.server_3.62.1.16.jar
Id: com.ti.dvt.sourceref, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.sourceref_4.1.0.202106281057/
Id: com.ti.dvt.sourcerefplugin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.sourcerefplugin_4.1.0.202106281057/
Id: com.ti.dvt.symbolmanager, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.symbolmanager_4.1.0.202106281057/
Id: com.ti.dvt.symbolmanager.bin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.symbolmanager.bin_4.1.0.202106281057/
Id: com.ti.dvt.tidisassembly, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.tidisassembly_4.1.0.202106281057/
Id: com.ti.dvt.trace.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.trace.doc_4.1.0.202106281057.jar
Id: com.ti.dvt.ui, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ui_4.1.0.202106281057/
Id: com.ti.dvt.ui.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.ui.doc_4.1.0.202106281057/
Id: com.ti.dvt.uia, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.uia_4.1.0.202106281057/
Id: com.ti.dvt.uia.bin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.uia.bin_4.1.0.202106281057/
Id: com.ti.dvt.uia.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.uia.doc_4.1.0.202106281057.jar
Id: com.ti.dvt.via.doc, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.via.doc_4.1.0.202106281057/
Id: com.ti.dvt.via.imvr, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.via.imvr_4.1.0.202106281057/
Id: com.ti.dvt.via.plugin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.via.plugin_4.1.0.202106281057.jar
Id: com.ti.dvt.via.plugin.ccs, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.dvt.via.plugin.ccs_4.1.0.202106281057.jar
Id: com.ti.gui.composer.webserver.adapter, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.gui.composer.webserver.adapter_8.0.0.202112011800.jar
Id: com.ti.jna, Version: 8.0.0.202112011800, Location: reference:file:plugins/com.ti.jna_8.0.0.202112011800.jar
Id: com.ti.msp430.18.1.help_18.1.0.20181119225106, Version: 18.1.0, Location: reference:file:plugins/com.ti.msp430.18.1.help_18.1.0.20181119225106_18.1.0/
Id: com.ti.rex.ccsplugin, Version: 1.0.0.202106281057, Location: reference:file:plugins/com.ti.rex.ccsplugin_1.0.0.202106281057/
Id: com.ti.rov, Version: 1.0.0.202108240702, Location: reference:file:plugins/com.ti.rov_1.0.0.202108240702/
Id: com.ti.rta, Version: 3.62.1.16, Location: reference:file:plugins/com.ti.rta_3.62.1.16.jar
Id: com.ti.rta.support, Version: 3.62.1.16, Location: reference:file:plugins/com.ti.rta.support_3.62.1.16.jar
Id: com.ti.targets.omf, Version: 3.62.1.16, Location: reference:file:plugins/com.ti.targets.omf_3.62.1.16/
Id: com.ti.uia.autostart, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.uia.autostart_4.1.0.202106281057.jar
Id: com.ti.uia.autostart.view, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.uia.autostart.view_4.1.0.202106281057.jar
Id: com.ti.uia.globaltimebase, Version: 1.0.0.202106281057, Location: reference:file:plugins/com.ti.uia.globaltimebase_1.0.0.202106281057.jar
Id: com.ti.uia.sessionmgr.view, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.uia.sessionmgr.view_4.1.0.202106281057/
Id: com.ti.uia.transport.jtag, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.uia.transport.jtag_4.1.0.202106281057.jar
Id: com.ti.uia.transport.monitor, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.uia.transport.monitor_4.1.0.202106281057.jar
Id: com.ti.util, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.util_4.1.0.202106281057/
Id: com.ti.util.diskspacemonitor, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.util.diskspacemonitor_4.1.0.202106281057/
Id: com.ti.util.diskspacemonitor.bin, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.util.diskspacemonitor.bin_4.1.0.202106281057/
Id: com.ti.util.ui, Version: 4.1.0.202106281057, Location: reference:file:plugins/com.ti.util.ui_4.1.0.202106281057.jar
Id: com.ti.xdctools_3_62.base, Version: 3.62.1.16, Location: reference:file:plugins/com.ti.xdctools_3_62.base_3.62.1.16/
Id: com.ti.xdctools_3_62.win32, Version: 3.62.1.16, Location: reference:file:plugins/com.ti.xdctools_3_62.win32_3.62.1.16/
Id: gnu.io.rxtx, Version: 2.1.8.0_201606281300, Location: reference:file:plugins/gnu.io.rxtx_2.1.8.0_201606281300.jar
Id: jakarta.xml.bind, Version: 2.3.3.v20201118-1818, Location: reference:file:plugins/jakarta.xml.bind_2.3.3.v20201118-1818.jar
Id: javaewah, Version: 1.1.7.v20200107-0831, Location: reference:file:plugins/javaewah_1.1.7.v20200107-0831.jar
Id: javax.activation, Version: 1.2.2.v20201119-1642, Location: reference:file:plugins/javax.activation_1.2.2.v20201119-1642.jar
Id: javax.annotation, Version: 1.3.5.v20200909-1856, Location: reference:file:plugins/javax.annotation_1.3.5.v20200909-1856.jar
Id: javax.el, Version: 2.2.0.v201303151357, Location: reference:file:plugins/javax.el_2.2.0.v201303151357.jar
Id: javax.inject, Version: 1.0.0.v20091030, Location: reference:file:plugins/javax.inject_1.0.0.v20091030.jar
Id: javax.servlet, Version: 3.1.0.v201410161800, Location: reference:file:plugins/javax.servlet_3.1.0.v201410161800.jar
Id: javax.servlet.jsp, Version: 2.2.0.v201112011158, Location: reference:file:plugins/javax.servlet.jsp_2.2.0.v201112011158.jar
Id: javax.xml, Version: 1.3.4.v201005080400, Location: reference:file:plugins/javax.xml_1.3.4.v201005080400.jar
Id: net.i2p.crypto.eddsa, Version: 0.3.0.v20181102-1323, Location: reference:file:plugins/net.i2p.crypto.eddsa_0.3.0.v20181102-1323.jar
Id: org.apache.ant, Version: 1.10.9.v20201106-1946, Location: reference:file:plugins/org.apache.ant_1.10.9.v20201106-1946/
Id: org.apache.batik.bridge, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.bridge_1.6.0.v201011041432.jar
Id: org.apache.batik.constants, Version: 1.13.0.v20200622-2037, Location: reference:file:plugins/org.apache.batik.constants_1.13.0.v20200622-2037.jar
Id: org.apache.batik.css, Version: 1.13.0.v20200622-2037, Location: reference:file:plugins/org.apache.batik.css_1.13.0.v20200622-2037.jar
Id: org.apache.batik.css, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.css_1.6.0.v201011041432.jar
Id: org.apache.batik.dom, Version: 1.6.1.v201505192100, Location: reference:file:plugins/org.apache.batik.dom_1.6.1.v201505192100.jar
Id: org.apache.batik.dom.svg, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.dom.svg_1.6.0.v201011041432.jar
Id: org.apache.batik.ext.awt, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.ext.awt_1.6.0.v201011041432.jar
Id: org.apache.batik.i18n, Version: 1.13.0.v20200622-2037, Location: reference:file:plugins/org.apache.batik.i18n_1.13.0.v20200622-2037.jar
Id: org.apache.batik.parser, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.parser_1.6.0.v201011041432.jar
Id: org.apache.batik.pdf, Version: 1.6.0.v201105071520, Location: reference:file:plugins/org.apache.batik.pdf_1.6.0.v201105071520.jar
Id: org.apache.batik.svggen, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.svggen_1.6.0.v201011041432.jar
Id: org.apache.batik.transcoder, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.transcoder_1.6.0.v201011041432.jar
Id: org.apache.batik.util, Version: 1.13.0.v20200622-2037, Location: reference:file:plugins/org.apache.batik.util_1.13.0.v20200622-2037.jar
Id: org.apache.batik.util, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.util_1.6.0.v201011041432.jar
Id: org.apache.batik.util.gui, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.util.gui_1.6.0.v201011041432.jar
Id: org.apache.batik.xml, Version: 1.6.0.v201011041432, Location: reference:file:plugins/org.apache.batik.xml_1.6.0.v201011041432.jar
Id: org.apache.commons.codec, Version: 1.14.0.v20200818-1422, Location: reference:file:plugins/org.apache.commons.codec_1.14.0.v20200818-1422.jar
Id: org.apache.commons.compress, Version: 1.19.0.v20200106-2343, Location: reference:file:plugins/org.apache.commons.compress_1.19.0.v20200106-2343.jar
Id: org.apache.commons.io, Version: 2.6.0.v20190123-2029, Location: reference:file:plugins/org.apache.commons.io_2.6.0.v20190123-2029.jar
Id: org.apache.commons.io, Version: 8.0.0.202112011800, Location: reference:file:plugins/org.apache.commons.io_8.0.0.202112011800.jar
Id: org.apache.commons.jxpath, Version: 1.3.0.v200911051830, Location: reference:file:plugins/org.apache.commons.jxpath_1.3.0.v200911051830.jar
Id: org.apache.commons.logging, Version: 1.2.0.v20180409-1502, Location: reference:file:plugins/org.apache.commons.logging_1.2.0.v20180409-1502.jar
Id: org.apache.commons.net, Version: 3.2.0.v201305141515, Location: reference:file:plugins/org.apache.commons.net_3.2.0.v201305141515.jar
Id: org.apache.felix.gogo.command, Version: 1.1.2.v20210111-1007, Location: reference:file:plugins/org.apache.felix.gogo.command_1.1.2.v20210111-1007.jar
Id: org.apache.felix.gogo.runtime, Version: 1.1.4.v20210111-1007, Location: reference:file:plugins/org.apache.felix.gogo.runtime_1.1.4.v20210111-1007.jar
Id: org.apache.felix.gogo.shell, Version: 1.1.4.v20210111-1007, Location: reference:file:plugins/org.apache.felix.gogo.shell_1.1.4.v20210111-1007.jar
Id: org.apache.felix.scr, Version: 2.1.24.v20200924-1939, Location: reference:file:plugins/org.apache.felix.scr_2.1.24.v20200924-1939.jar
Id: org.apache.httpcomponents.httpclient, Version: 4.5.10.v20200830-2311, Location: reference:file:plugins/org.apache.httpcomponents.httpclient_4.5.10.v20200830-2311.jar
Id: org.apache.httpcomponents.httpclient.win, Version: 4.5.10.v20200830-2311, Location: reference:file:plugins/org.apache.httpcomponents.httpclient.win_4.5.10.v20200830-2311.jar
Id: org.apache.httpcomponents.httpcore, Version: 4.4.12.v20200108-1212, Location: reference:file:plugins/org.apache.httpcomponents.httpcore_4.4.12.v20200108-1212.jar
Id: org.apache.jasper.glassfish, Version: 2.2.2.v201501141630, Location: reference:file:plugins/org.apache.jasper.glassfish_2.2.2.v201501141630.jar
Id: org.apache.log4j, Version: 1.2.15.v201012070815, Location: reference:file:plugins/org.apache.log4j_1.2.15.v201012070815.jar
Id: org.apache.lucene.analyzers-common, Version: 8.4.1.v20200122-1459, Location: reference:file:plugins/org.apache.lucene.analyzers-common_8.4.1.v20200122-1459.jar
Id: org.apache.lucene.analyzers-smartcn, Version: 8.4.1.v20200122-1459, Location: reference:file:plugins/org.apache.lucene.analyzers-smartcn_8.4.1.v20200122-1459.jar
Id: org.apache.lucene.core, Version: 8.4.1.v20200122-1459, Location: reference:file:plugins/org.apache.lucene.core_8.4.1.v20200122-1459.jar
Id: org.apache.sshd.osgi, Version: 2.6.0.v20210201-2003, Location: reference:file:plugins/org.apache.sshd.osgi_2.6.0.v20210201-2003.jar
Id: org.apache.sshd.sftp, Version: 2.6.0.v20210201-2003, Location: reference:file:plugins/org.apache.sshd.sftp_2.6.0.v20210201-2003.jar
Id: org.apache.xerces, Version: 2.9.0.v201101211617, Location: reference:file:plugins/org.apache.xerces_2.9.0.v201101211617.jar
Id: org.apache.xml.resolver, Version: 1.2.0.v201005080400, Location: reference:file:plugins/org.apache.xml.resolver_1.2.0.v201005080400.jar
Id: org.apache.xml.serializer, Version: 2.7.1.v201005080400, Location: reference:file:plugins/org.apache.xml.serializer_2.7.1.v201005080400.jar
Id: org.apache.xmlgraphics, Version: 2.4.0.v20200622-2037, Location: reference:file:plugins/org.apache.xmlgraphics_2.4.0.v20200622-2037.jar
Id: org.bouncycastle.bcpg, Version: 1.65.0.v20200527-1955, Location: reference:file:plugins/org.bouncycastle.bcpg_1.65.0.v20200527-1955.jar
Id: org.bouncycastle.bcprov, Version: 1.65.1.v20200529-1514, Location: reference:file:plugins/org.bouncycastle.bcprov_1.65.1.v20200529-1514.jar
Id: org.eclipse.ant.core, Version: 3.5.800.v20200608-1251, Location: reference:file:plugins/org.eclipse.ant.core_3.5.800.v20200608-1251.jar
Id: org.eclipse.cdt, Version: 10.2.0.202012191711, Location: reference:file:plugins/org.eclipse.cdt_10.2.0.202012191711.jar
Id: org.eclipse.cdt.build.crossgcc, Version: 1.2.200.202102261947, Location: reference:file:plugins/org.eclipse.cdt.build.crossgcc_1.2.200.202102261947.jar
Id: org.eclipse.cdt.build.gcc.core, Version: 1.1.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.build.gcc.core_1.1.0.202008310002.jar
Id: org.eclipse.cdt.build.gcc.ui, Version: 1.1.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.build.gcc.ui_1.1.0.202008310002.jar
Id: org.eclipse.cdt.codan.checkers, Version: 3.4.100.202010121414, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers_3.4.100.202010121414.jar
Id: org.eclipse.cdt.codan.checkers.ui, Version: 3.3.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.codan.checkers.ui_3.3.0.202008310002.jar
Id: org.eclipse.cdt.codan.core, Version: 4.1.100.202010121414, Location: reference:file:plugins/org.eclipse.cdt.codan.core_4.1.100.202010121414.jar
Id: org.eclipse.cdt.codan.core.cxx, Version: 3.5.100.202011201553, Location: reference:file:plugins/org.eclipse.cdt.codan.core.cxx_3.5.100.202011201553.jar
Id: org.eclipse.cdt.codan.ui, Version: 3.4.100.202011201553, Location: reference:file:plugins/org.eclipse.cdt.codan.ui_3.4.100.202011201553.jar
Id: org.eclipse.cdt.codan.ui.cxx, Version: 3.6.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.codan.ui.cxx_3.6.0.202008310002.jar
Id: org.eclipse.cdt.core, Version: 7.2.0.202102251239, Location: reference:file:plugins/org.eclipse.cdt.core_7.2.0.202102251239.jar
Id: org.eclipse.cdt.core.native, Version: 6.1.100.202102030214, Location: reference:file:plugins/org.eclipse.cdt.core.native_6.1.100.202102030214.jar
Id: org.eclipse.cdt.core.win32, Version: 6.0.200.202102030214, Location: reference:file:plugins/org.eclipse.cdt.core.win32_6.0.200.202102030214.jar
Id: org.eclipse.cdt.core.win32.x86_64, Version: 6.0.100.202011060124, Location: reference:file:plugins/org.eclipse.cdt.core.win32.x86_64_6.0.100.202011060124/
Id: org.eclipse.cdt.debug.core, Version: 8.6.0.202011181638, Location: reference:file:plugins/org.eclipse.cdt.debug.core_8.6.0.202011181638.jar
Id: org.eclipse.cdt.debug.core.memory, Version: 0.1.100.202012012315, Location: reference:file:plugins/org.eclipse.cdt.debug.core.memory_0.1.100.202012012315.jar
Id: org.eclipse.cdt.debug.ui, Version: 8.4.100.202011181638, Location: reference:file:plugins/org.eclipse.cdt.debug.ui_8.4.100.202011181638.jar
Id: org.eclipse.cdt.debug.ui.memory.floatingpoint, Version: 1.1.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.floatingpoint_1.1.0.202008310002.jar
Id: org.eclipse.cdt.debug.ui.memory.memorybrowser, Version: 1.4.100.202011181638, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.memorybrowser_1.4.100.202011181638.jar
Id: org.eclipse.cdt.debug.ui.memory.search, Version: 1.4.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.search_1.4.0.202008310002.jar
Id: org.eclipse.cdt.debug.ui.memory.traditional, Version: 1.6.100.202011181638, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.traditional_1.6.100.202011181638.jar
Id: org.eclipse.cdt.debug.ui.memory.transport, Version: 2.2.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.debug.ui.memory.transport_2.2.0.202008310002.jar
Id: org.eclipse.cdt.doc.user, Version: 5.4.700.202012191711, Location: reference:file:plugins/org.eclipse.cdt.doc.user_5.4.700.202012191711.jar
Id: org.eclipse.cdt.dsf, Version: 2.10.100.202012191801, Location: reference:file:plugins/org.eclipse.cdt.dsf_2.10.100.202012191801.jar
Id: org.eclipse.cdt.dsf.gdb, Version: 6.2.0.202102231601, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb_6.2.0.202102231601.jar
Id: org.eclipse.cdt.dsf.gdb.ui, Version: 2.7.100.202011181638, Location: reference:file:plugins/org.eclipse.cdt.dsf.gdb.ui_2.7.100.202011181638.jar
Id: org.eclipse.cdt.dsf.ui, Version: 2.6.100.202011291939, Location: reference:file:plugins/org.eclipse.cdt.dsf.ui_2.6.100.202011291939.jar
Id: org.eclipse.cdt.flatpak.launcher, Version: 1.0.100.202101160252, Location: reference:file:plugins/org.eclipse.cdt.flatpak.launcher_1.0.100.202101160252.jar
Id: org.eclipse.cdt.gdb, Version: 7.1.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.gdb_7.1.0.202008310002.jar
Id: org.eclipse.cdt.gdb.ui, Version: 7.1.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.gdb.ui_7.1.0.202008310002.jar
Id: org.eclipse.cdt.launch, Version: 10.2.100.202012191801, Location: reference:file:plugins/org.eclipse.cdt.launch_10.2.100.202012191801.jar
Id: org.eclipse.cdt.launch.remote, Version: 2.6.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.launch.remote_2.6.0.202008310002.jar
Id: org.eclipse.cdt.make.core, Version: 7.5.100.202011171450, Location: reference:file:plugins/org.eclipse.cdt.make.core_7.5.100.202011171450.jar
Id: org.eclipse.cdt.make.ui, Version: 8.0.100.202011181841, Location: reference:file:plugins/org.eclipse.cdt.make.ui_8.0.100.202011181841.jar
Id: org.eclipse.cdt.managedbuilder.core, Version: 9.2.0.202103011047, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.core_9.2.0.202103011047.jar
Id: org.eclipse.cdt.managedbuilder.gnu.ui, Version: 8.4.0.202008310002, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.gnu.ui_8.4.0.202008310002.jar
Id: org.eclipse.cdt.managedbuilder.headlessbuilderapp, Version: 1.0.0.202103010740, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.headlessbuilderapp_1.0.0.202103010740.jar
Id: org.eclipse.cdt.managedbuilder.ui, Version: 9.3.0.202012011707, Location: reference:file:plugins/org.eclipse.cdt.managedbuilder.ui_9.3.0.202012011707.jar
Id: org.eclipse.cdt.native.serial, Version: 1.2.100.202011111956, Location: reference:file:plugins/org.eclipse.cdt.native.serial_1.2.100.202011111956.jar
Id: org.eclipse.cdt.platform.branding, Version: 10.2.0.202103010740, Location: reference:file:plugins/org.eclipse.cdt.platform.branding_10.2.0.202103010740.jar
Id: org.eclipse.cdt.ui, Version: 7.1.100.202101112014, Location: reference:file:plugins/org.eclipse.cdt.ui_7.1.100.202101112014.jar
Id: org.eclipse.compare, Version: 3.7.1300.v20210114-0707, Location: reference:file:plugins/org.eclipse.compare_3.7.1300.v20210114-0707.jar
Id: org.eclipse.compare.core, Version: 3.6.1000.v20201020-1107, Location: reference:file:plugins/org.eclipse.compare.core_3.6.1000.v20201020-1107.jar
Id: org.eclipse.compare.win32, Version: 1.2.800.v20200127-1343, Location: reference:file:plugins/org.eclipse.compare.win32_1.2.800.v20200127-1343.jar
Id: org.eclipse.core.commands, Version: 3.9.800.v20201021-1339, Location: reference:file:plugins/org.eclipse.core.commands_3.9.800.v20201021-1339.jar
Id: org.eclipse.core.contenttype, Version: 3.7.900.v20210111-0918, Location: reference:file:plugins/org.eclipse.core.contenttype_3.7.900.v20210111-0918.jar
Id: org.eclipse.core.databinding, Version: 1.10.100.v20200926-1123, Location: reference:file:plugins/org.eclipse.core.databinding_1.10.100.v20200926-1123.jar
Id: org.eclipse.core.databinding.beans, Version: 1.7.200.v20210111-0759, Location: reference:file:plugins/org.eclipse.core.databinding.beans_1.7.200.v20210111-0759.jar
Id: org.eclipse.core.databinding.observable, Version: 1.10.0.v20200730-0848, Location: reference:file:plugins/org.eclipse.core.databinding.observable_1.10.0.v20200730-0848.jar
Id: org.eclipse.core.databinding.property, Version: 1.8.100.v20200619-0651, Location: reference:file:plugins/org.eclipse.core.databinding.property_1.8.100.v20200619-0651.jar
Id: org.eclipse.core.expressions, Version: 3.7.100.v20210203-1000, Location: reference:file:plugins/org.eclipse.core.expressions_3.7.100.v20210203-1000.jar
Id: org.eclipse.core.externaltools, Version: 1.1.800.v20201105-0600, Location: reference:file:plugins/org.eclipse.core.externaltools_1.1.800.v20201105-0600.jar
Id: org.eclipse.core.filebuffers, Version: 3.6.1100.v20201029-1159, Location: reference:file:plugins/org.eclipse.core.filebuffers_3.6.1100.v20201029-1159.jar
Id: org.eclipse.core.filesystem, Version: 1.7.700.v20200110-1734, Location: reference:file:plugins/org.eclipse.core.filesystem_1.7.700.v20200110-1734.jar
Id: org.eclipse.core.filesystem.win32.x86_64, Version: 1.4.200.v20190812-0909, Location: reference:file:plugins/org.eclipse.core.filesystem.win32.x86_64_1.4.200.v20190812-0909.jar
Id: org.eclipse.core.jobs, Version: 3.10.1100.v20210111-0815, Location: reference:file:plugins/org.eclipse.core.jobs_3.10.1100.v20210111-0815.jar
Id: org.eclipse.core.net, Version: 1.3.1000.v20200715-0827, Location: reference:file:plugins/org.eclipse.core.net_1.3.1000.v20200715-0827.jar
Id: org.eclipse.core.net.win32.x86_64, Version: 1.1.500.v20190925-1337, Location: reference:file:plugins/org.eclipse.core.net.win32.x86_64_1.1.500.v20190925-1337.jar
Id: org.eclipse.core.resources, Version: 3.14.0.v20210215-0934, Location: reference:file:plugins/org.eclipse.core.resources_3.14.0.v20210215-0934.jar
Id: org.eclipse.core.resources.win32.x86_64, Version: 3.5.400.v20190812-0909, Location: reference:file:plugins/org.eclipse.core.resources.win32.x86_64_3.5.400.v20190812-0909.jar
Id: org.eclipse.core.runtime, Version: 3.20.100.v20210111-0815, Location: reference:file:plugins/org.eclipse.core.runtime_3.20.100.v20210111-0815.jar
Id: org.eclipse.core.variables, Version: 3.4.800.v20200120-1101, Location: reference:file:plugins/org.eclipse.core.variables_3.4.800.v20200120-1101.jar
Id: org.eclipse.debug.core, Version: 3.18.0.v20210222-1101, Location: reference:file:plugins/org.eclipse.debug.core_3.18.0.v20210222-1101.jar
Id: org.eclipse.debug.ui, Version: 3.14.800.v20210222-1101, Location: reference:file:plugins/org.eclipse.debug.ui_3.14.800.v20210222-1101.jar
Id: org.eclipse.draw2d, Version: 3.10.100.201606061308, Location: reference:file:plugins/org.eclipse.draw2d_3.10.100.201606061308.jar
Id: org.eclipse.dstore.core, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.dstore.core_4.5.300.202101081027.jar
Id: org.eclipse.dstore.extra, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.dstore.extra_4.5.300.202101081027.jar
Id: org.eclipse.e4.core.commands, Version: 0.13.0.v20201119-1132, Location: reference:file:plugins/org.eclipse.e4.core.commands_0.13.0.v20201119-1132.jar
Id: org.eclipse.e4.core.contexts, Version: 1.8.400.v20191217-1710, Location: reference:file:plugins/org.eclipse.e4.core.contexts_1.8.400.v20191217-1710.jar
Id: org.eclipse.e4.core.di, Version: 1.7.700.v20210128-2123, Location: reference:file:plugins/org.eclipse.e4.core.di_1.7.700.v20210128-2123.jar
Id: org.eclipse.e4.core.di.annotations, Version: 1.6.600.v20191216-2352, Location: reference:file:plugins/org.eclipse.e4.core.di.annotations_1.6.600.v20191216-2352.jar
Id: org.eclipse.e4.core.di.extensions, Version: 0.16.0.v20200507-0938, Location: reference:file:plugins/org.eclipse.e4.core.di.extensions_0.16.0.v20200507-0938.jar
Id: org.eclipse.e4.core.di.extensions.supplier, Version: 0.15.800.v20210110-1654, Location: reference:file:plugins/org.eclipse.e4.core.di.extensions.supplier_0.15.800.v20210110-1654.jar
Id: org.eclipse.e4.core.services, Version: 2.2.600.v20210110-1654, Location: reference:file:plugins/org.eclipse.e4.core.services_2.2.600.v20210110-1654.jar
Id: org.eclipse.e4.emf.xpath, Version: 0.2.800.v20200609-0849, Location: reference:file:plugins/org.eclipse.e4.emf.xpath_0.2.800.v20200609-0849.jar
Id: org.eclipse.e4.ui.bindings, Version: 0.13.0.v20201119-1132, Location: reference:file:plugins/org.eclipse.e4.ui.bindings_0.13.0.v20201119-1132.jar
Id: org.eclipse.e4.ui.css.core, Version: 0.13.0.v20201015-0653, Location: reference:file:plugins/org.eclipse.e4.ui.css.core_0.13.0.v20201015-0653.jar
Id: org.eclipse.e4.ui.css.swt, Version: 0.14.100.v20201217-1340, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt_0.14.100.v20201217-1340.jar
Id: org.eclipse.e4.ui.css.swt.theme, Version: 0.13.0.v20201026-1147, Location: reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.13.0.v20201026-1147.jar
Id: org.eclipse.e4.ui.di, Version: 1.3.0.v20210222-1018, Location: reference:file:plugins/org.eclipse.e4.ui.di_1.3.0.v20210222-1018.jar
Id: org.eclipse.e4.ui.dialogs, Version: 1.2.100.v20201109-2317, Location: reference:file:plugins/org.eclipse.e4.ui.dialogs_1.2.100.v20201109-2317.jar
Id: org.eclipse.e4.ui.ide, Version: 3.15.200.v20210108-1832, Location: reference:file:plugins/org.eclipse.e4.ui.ide_3.15.200.v20210108-1832.jar
Id: org.eclipse.e4.ui.model.workbench, Version: 2.1.1000.v20210111-0958, Location: reference:file:plugins/org.eclipse.e4.ui.model.workbench_2.1.1000.v20210111-0958.jar
Id: org.eclipse.e4.ui.services, Version: 1.5.0.v20210115-1333, Location: reference:file:plugins/org.eclipse.e4.ui.services_1.5.0.v20210115-1333.jar
Id: org.eclipse.e4.ui.swt.win32, Version: 1.1.0.v20201119-1132, Location: reference:file:plugins/org.eclipse.e4.ui.swt.win32_1.1.0.v20201119-1132.jar
Id: org.eclipse.e4.ui.widgets, Version: 1.2.800.v20201021-1339, Location: reference:file:plugins/org.eclipse.e4.ui.widgets_1.2.800.v20201021-1339.jar
Id: org.eclipse.e4.ui.workbench, Version: 1.12.100.v20210122-1731, Location: reference:file:plugins/org.eclipse.e4.ui.workbench_1.12.100.v20210122-1731.jar
Id: org.eclipse.e4.ui.workbench.addons.swt, Version: 1.4.100.v20201221-2332, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.addons.swt_1.4.100.v20201221-2332.jar
Id: org.eclipse.e4.ui.workbench.renderers.swt, Version: 0.15.0.v20201125-0918, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.15.0.v20201125-0918.jar
Id: org.eclipse.e4.ui.workbench.swt, Version: 0.16.0.v20201230-1610, Location: reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.16.0.v20201230-1610.jar
Id: org.eclipse.e4.ui.workbench3, Version: 0.15.500.v20201021-1339, Location: reference:file:plugins/org.eclipse.e4.ui.workbench3_0.15.500.v20201021-1339.jar
Id: org.eclipse.ecf, Version: 3.9.101.v20201027-0547, Location: reference:file:plugins/org.eclipse.ecf_3.9.101.v20201027-0547.jar
Id: org.eclipse.ecf.filetransfer, Version: 5.1.101.v20201025-2315, Location: reference:file:plugins/org.eclipse.ecf.filetransfer_5.1.101.v20201025-2315.jar
Id: org.eclipse.ecf.identity, Version: 3.9.401.v20201027-0550, Location: reference:file:plugins/org.eclipse.ecf.identity_3.9.401.v20201027-0550.jar
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.2.601.v20201025-0700, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.2.601.v20201025-0700.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient45, Version: 1.0.301.v20201025-0700, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient45_1.0.301.v20201025-0700.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient45.win32, Version: 1.0.300.v20200816-1842, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient45.win32_1.0.300.v20200816-1842.jar
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.200.v20200611-1836, Location: reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.200.v20200611-1836.jar
Id: org.eclipse.ecf.ssl, Version: 1.2.400.v20200611-2220, Location: reference:file:plugins/org.eclipse.ecf.ssl_1.2.400.v20200611-2220.jar
Id: org.eclipse.egit, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.egit_5.11.0.202103091610-r.jar
Id: org.eclipse.egit.core, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.egit.core_5.11.0.202103091610-r.jar
Id: org.eclipse.egit.doc, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.egit.doc_5.11.0.202103091610-r.jar
Id: org.eclipse.egit.ui, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.egit.ui_5.11.0.202103091610-r.jar
Id: org.eclipse.emf.common, Version: 2.22.0.v20210114-1734, Location: reference:file:plugins/org.eclipse.emf.common_2.22.0.v20210114-1734.jar
Id: org.eclipse.emf.ecore, Version: 2.23.0.v20200630-0516, Location: reference:file:plugins/org.eclipse.emf.ecore_2.23.0.v20200630-0516.jar
Id: org.eclipse.emf.ecore.change, Version: 2.14.0.v20190528-0725, Location: reference:file:plugins/org.eclipse.emf.ecore.change_2.14.0.v20190528-0725.jar
Id: org.eclipse.emf.ecore.xmi, Version: 2.16.0.v20190528-0725, Location: reference:file:plugins/org.eclipse.emf.ecore.xmi_2.16.0.v20190528-0725.jar
Id: org.eclipse.epp.mpc.core, Version: 1.9.1.v20210204-1408, Location: reference:file:plugins/org.eclipse.epp.mpc.core_1.9.1.v20210204-1408.jar
Id: org.eclipse.epp.mpc.core.win32, Version: 1.9.1.v20210204-1338, Location: reference:file:plugins/org.eclipse.epp.mpc.core.win32_1.9.1.v20210204-1338.jar
Id: org.eclipse.epp.mpc.help.ui, Version: 1.9.1.v20210204-1408, Location: reference:file:plugins/org.eclipse.epp.mpc.help.ui_1.9.1.v20210204-1408.jar
Id: org.eclipse.epp.mpc.ui, Version: 1.9.1.v20210204-1408, Location: reference:file:plugins/org.eclipse.epp.mpc.ui_1.9.1.v20210204-1408.jar
Id: org.eclipse.epp.mpc.ui.css, Version: 1.9.1.v20210204-1408, Location: reference:file:plugins/org.eclipse.epp.mpc.ui.css_1.9.1.v20210204-1408.jar
Id: org.eclipse.equinox.app, Version: 1.5.100.v20210212-1143, Location: reference:file:plugins/org.eclipse.equinox.app_1.5.100.v20210212-1143.jar
Id: org.eclipse.equinox.bidi, Version: 1.3.100.v20210212-1143, Location: reference:file:plugins/org.eclipse.equinox.bidi_1.3.100.v20210212-1143.jar
Id: org.eclipse.equinox.common, Version: 3.14.100.v20210212-1143, Location: reference:file:plugins/org.eclipse.equinox.common_3.14.100.v20210212-1143.jar
Id: org.eclipse.equinox.concurrent, Version: 1.2.0.v20210202-1157, Location: reference:file:plugins/org.eclipse.equinox.concurrent_1.2.0.v20210202-1157.jar
Id: org.eclipse.equinox.console, Version: 1.4.300.v20210211-2058, Location: reference:file:plugins/org.eclipse.equinox.console_1.4.300.v20210211-2058.jar
Id: org.eclipse.equinox.event, Version: 1.6.0.v20210212-1143, Location: reference:file:plugins/org.eclipse.equinox.event_1.6.0.v20210212-1143.jar
Id: org.eclipse.equinox.frameworkadmin, Version: 2.1.400.v20191002-0702, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin_2.1.400.v20191002-0702.jar
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.1.400.v20200319-1546, Location: reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.1.400.v20200319-1546.jar
Id: org.eclipse.equinox.http.jetty, Version: 3.7.600.v20210224-2143, Location: reference:file:plugins/org.eclipse.equinox.http.jetty_3.7.600.v20210224-2143.jar
Id: org.eclipse.equinox.http.registry, Version: 1.2.0.v20200614-1851, Location: reference:file:plugins/org.eclipse.equinox.http.registry_1.2.0.v20200614-1851.jar
Id: org.eclipse.equinox.http.servlet, Version: 1.7.0.v20210202-1229, Location: reference:file:plugins/org.eclipse.equinox.http.servlet_1.7.0.v20210202-1229.jar
Id: org.eclipse.equinox.jsp.jasper, Version: 1.1.500.v20200422-1833, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.1.500.v20200422-1833.jar
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.1.400.v20200422-1833, Location: reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.1.400.v20200422-1833.jar
Id: org.eclipse.equinox.launcher, Version: 1.6.100.v20201223-0822, Location: reference:file:plugins/org.eclipse.equinox.launcher_1.6.100.v20201223-0822.jar
Id: org.eclipse.equinox.launcher.win32.win32.x86_64, Version: 1.2.100.v20210209-1541, Location: reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.2.100.v20210209-1541/
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.4.0.v20210129-2007, Location: reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.4.0.v20210129-2007.jar
Id: org.eclipse.equinox.p2.console, Version: 1.1.500.v20210116-1227, Location: reference:file:plugins/org.eclipse.equinox.p2.console_1.1.500.v20210116-1227.jar
Id: org.eclipse.equinox.p2.core, Version: 2.6.300.v20200211-1504, Location: reference:file:plugins/org.eclipse.equinox.p2.core_2.6.300.v20200211-1504.jar
Id: org.eclipse.equinox.p2.director, Version: 2.4.700.v20200511-1530, Location: reference:file:plugins/org.eclipse.equinox.p2.director_2.4.700.v20200511-1530.jar
Id: org.eclipse.equinox.p2.director.app, Version: 1.1.600.v20200511-1530, Location: reference:file:plugins/org.eclipse.equinox.p2.director.app_1.1.600.v20200511-1530.jar
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.2.500.v20191211-1631, Location: reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.2.500.v20191211-1631.jar
Id: org.eclipse.equinox.p2.discovery, Version: 1.1.200.v20190611-1008, Location: reference:file:plugins/org.eclipse.equinox.p2.discovery_1.1.200.v20190611-1008.jar
Id: org.eclipse.equinox.p2.discovery.compatibility, Version: 1.2.0.v20200916-1234, Location: reference:file:plugins/org.eclipse.equinox.p2.discovery.compatibility_1.2.0.v20200916-1234.jar
Id: org.eclipse.equinox.p2.engine, Version: 2.6.700.v20200511-1530, Location: reference:file:plugins/org.eclipse.equinox.p2.engine_2.6.700.v20200511-1530.jar
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.3.400.v20191213-1911, Location: reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.3.400.v20191213-1911.jar
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.1.400.v20200221-1022, Location: reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.1.400.v20200221-1022.jar
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.1.700.v20210227-0235, Location: reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.1.700.v20210227-0235.jar
Id: org.eclipse.equinox.p2.metadata, Version: 2.5.100.v20200908-1020, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata_2.5.100.v20200908-1020.jar
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.3.500.v20210108-0738, Location: reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.3.500.v20210108-0738.jar
Id: org.eclipse.equinox.p2.operations, Version: 2.5.1000.v20201106-1246, Location: reference:file:plugins/org.eclipse.equinox.p2.operations_2.5.1000.v20201106-1246.jar
Id: org.eclipse.equinox.p2.publisher, Version: 1.5.500.v20210211-1133, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher_1.5.500.v20210211-1133.jar
Id: org.eclipse.equinox.p2.publisher.eclipse, Version: 1.3.800.v20210205-1231, Location: reference:file:plugins/org.eclipse.equinox.p2.publisher.eclipse_1.3.800.v20210205-1231.jar
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.3.500.v20210116-1855, Location: reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.3.500.v20210116-1855.jar
Id: org.eclipse.equinox.p2.repository, Version: 2.5.0.v20201013-0853, Location: reference:file:plugins/org.eclipse.equinox.p2.repository_2.5.0.v20201013-0853.jar
Id: org.eclipse.equinox.p2.repository.tools, Version: 2.2.600.v20210114-1107, Location: reference:file:plugins/org.eclipse.equinox.p2.repository.tools_2.2.600.v20210114-1107.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 2.2.800.v20210115-1344, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_2.2.800.v20210115-1344.jar
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.3.600.v20200511-1530, Location: reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.3.600.v20200511-1530.jar
Id: org.eclipse.equinox.p2.transport.ecf, Version: 1.3.0.v20201012-1345, Location: reference:file:plugins/org.eclipse.equinox.p2.transport.ecf_1.3.0.v20201012-1345.jar
Id: org.eclipse.equinox.p2.ui, Version: 2.7.0.v20210114-1216, Location: reference:file:plugins/org.eclipse.equinox.p2.ui_2.7.0.v20210114-1216.jar
Id: org.eclipse.equinox.p2.ui.discovery, Version: 1.2.0.v20200916-1234, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.discovery_1.2.0.v20200916-1234.jar
Id: org.eclipse.equinox.p2.ui.importexport, Version: 1.3.0.v20210217-1009, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.importexport_1.3.0.v20210217-1009.jar
Id: org.eclipse.equinox.p2.ui.sdk, Version: 1.2.0.v20210114-1214, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk_1.2.0.v20210114-1214.jar
Id: org.eclipse.equinox.p2.ui.sdk.scheduler, Version: 1.5.0.v20201012-1421, Location: reference:file:plugins/org.eclipse.equinox.p2.ui.sdk.scheduler_1.5.0.v20201012-1421.jar
Id: org.eclipse.equinox.p2.updatechecker, Version: 1.2.300.v20200222-1600, Location: reference:file:plugins/org.eclipse.equinox.p2.updatechecker_1.2.300.v20200222-1600.jar
Id: org.eclipse.equinox.p2.updatesite, Version: 1.1.500.v20210108-0738, Location: reference:file:plugins/org.eclipse.equinox.p2.updatesite_1.1.500.v20210108-0738.jar
Id: org.eclipse.equinox.preferences, Version: 3.8.200.v20210212-1143, Location: reference:file:plugins/org.eclipse.equinox.preferences_3.8.200.v20210212-1143.jar
Id: org.eclipse.equinox.registry, Version: 3.10.100.v20210212-1143, Location: reference:file:plugins/org.eclipse.equinox.registry_3.10.100.v20210212-1143.jar
Id: org.eclipse.equinox.security, Version: 1.3.600.v20210126-1005, Location: reference:file:plugins/org.eclipse.equinox.security_1.3.600.v20210126-1005.jar
Id: org.eclipse.equinox.security.ui, Version: 1.3.0.v20210121-0947, Location: reference:file:plugins/org.eclipse.equinox.security.ui_1.3.0.v20210121-0947.jar
Id: org.eclipse.equinox.security.win32.x86_64, Version: 1.1.200.v20190812-0919, Location: reference:file:plugins/org.eclipse.equinox.security.win32.x86_64_1.1.200.v20190812-0919.jar
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.3.600.v20200721-1308, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.3.600.v20200721-1308.jar
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 2.1.500.v20200211-1505, Location: reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_2.1.500.v20200211-1505.jar
Id: org.eclipse.gef, Version: 3.11.0.201606061308, Location: reference:file:plugins/org.eclipse.gef_3.11.0.201606061308.jar
Id: org.eclipse.help, Version: 3.8.800.v20200525-0755, Location: reference:file:plugins/org.eclipse.help_3.8.800.v20200525-0755.jar
Id: org.eclipse.help.base, Version: 4.3.200.v20210303-1800, Location: reference:file:plugins/org.eclipse.help.base_4.3.200.v20210303-1800.jar
Id: org.eclipse.help.ui, Version: 4.2.200.v20210123-1004, Location: reference:file:plugins/org.eclipse.help.ui_4.2.200.v20210123-1004.jar
Id: org.eclipse.help.webapp, Version: 3.10.200.v20210222-1057, Location: reference:file:plugins/org.eclipse.help.webapp_3.10.200.v20210222-1057.jar
Id: org.eclipse.jetty.continuation, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.continuation_9.4.37.v20210219.jar
Id: org.eclipse.jetty.http, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.http_9.4.37.v20210219.jar
Id: org.eclipse.jetty.io, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.io_9.4.37.v20210219.jar
Id: org.eclipse.jetty.security, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.security_9.4.37.v20210219.jar
Id: org.eclipse.jetty.server, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.server_9.4.37.v20210219.jar
Id: org.eclipse.jetty.servlet, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.servlet_9.4.37.v20210219.jar
Id: org.eclipse.jetty.util, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.util_9.4.37.v20210219.jar
Id: org.eclipse.jetty.util.ajax, Version: 9.4.37.v20210219, Location: reference:file:plugins/org.eclipse.jetty.util.ajax_9.4.37.v20210219.jar
Id: org.eclipse.jface, Version: 3.22.100.v20210126-0831, Location: reference:file:plugins/org.eclipse.jface_3.22.100.v20210126-0831.jar
Id: org.eclipse.jface.databinding, Version: 1.12.200.v20210111-0911, Location: reference:file:plugins/org.eclipse.jface.databinding_1.12.200.v20210111-0911.jar
Id: org.eclipse.jface.notifications, Version: 0.3.0.v20210218-1820, Location: reference:file:plugins/org.eclipse.jface.notifications_0.3.0.v20210218-1820.jar
Id: org.eclipse.jface.text, Version: 3.17.0.v20210213-0904, Location: reference:file:plugins/org.eclipse.jface.text_3.17.0.v20210213-0904.jar
Id: org.eclipse.jgit, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.jgit_5.11.0.202103091610-r.jar
Id: org.eclipse.jgit.archive, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.jgit.archive_5.11.0.202103091610-r.jar
Id: org.eclipse.jgit.gpg.bc, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.jgit.gpg.bc_5.11.0.202103091610-r.jar
Id: org.eclipse.jgit.http.apache, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.jgit.http.apache_5.11.0.202103091610-r.jar
Id: org.eclipse.jgit.ssh.apache, Version: 5.11.0.202103091610-r, Location: reference:file:plugins/org.eclipse.jgit.ssh.apache_5.11.0.202103091610-r.jar
Id: org.eclipse.jsch.core, Version: 1.3.900.v20200422-1935, Location: reference:file:plugins/org.eclipse.jsch.core_1.3.900.v20200422-1935.jar
Id: org.eclipse.jsch.ui, Version: 1.3.1100.v20200916-0731, Location: reference:file:plugins/org.eclipse.jsch.ui_1.3.1100.v20200916-0731.jar
Id: org.eclipse.launchbar.core, Version: 2.4.100.202010121414, Location: reference:file:plugins/org.eclipse.launchbar.core_2.4.100.202010121414.jar
Id: org.eclipse.launchbar.ui, Version: 2.4.100.202012041937, Location: reference:file:plugins/org.eclipse.launchbar.ui_2.4.100.202012041937.jar
Id: org.eclipse.ltk.core.refactoring, Version: 3.11.300.v20210208-1217, Location: reference:file:plugins/org.eclipse.ltk.core.refactoring_3.11.300.v20210208-1217.jar
Id: org.eclipse.ltk.ui.refactoring, Version: 3.11.300.v20210112-0706, Location: reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.11.300.v20210112-0706.jar
Id: org.eclipse.osgi, Version: 3.16.200.v20210226-1447, Location: System Bundle
Id: org.eclipse.osgi.compatibility.state, Version: 1.2.300.v20210212-1137, Location: initial@reference:file:plugins/org.eclipse.osgi.compatibility.state_1.2.300.v20210212-1137.jar
Id: org.eclipse.osgi.services, Version: 3.10.0.v20210212-1137, Location: reference:file:plugins/org.eclipse.osgi.services_3.10.0.v20210212-1137.jar
Id: org.eclipse.osgi.util, Version: 3.6.0.v20210212-1137, Location: reference:file:plugins/org.eclipse.osgi.util_3.6.0.v20210212-1137.jar
Id: org.eclipse.platform, Version: 4.19.0.v20210303-1800, Location: reference:file:plugins/org.eclipse.platform_4.19.0.v20210303-1800/
Id: org.eclipse.platform.doc.user, Version: 4.19.0.v20210303-0957, Location: reference:file:plugins/org.eclipse.platform.doc.user_4.19.0.v20210303-0957.jar
Id: org.eclipse.rcp, Version: 4.19.0.v20210303-1800, Location: reference:file:plugins/org.eclipse.rcp_4.19.0.v20210303-1800.jar
Id: org.eclipse.remote.console, Version: 1.2.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.console_1.2.0.201909031456.jar
Id: org.eclipse.remote.core, Version: 4.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.core_4.0.0.201909031456.jar
Id: org.eclipse.remote.doc.isv, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.doc.isv_1.0.0.201909031456.jar
Id: org.eclipse.remote.jsch.core, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.jsch.core_1.0.0.201909031456.jar
Id: org.eclipse.remote.jsch.ui, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.jsch.ui_1.0.0.201909031456.jar
Id: org.eclipse.remote.serial.core, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.serial.core_1.0.0.201909031456.jar
Id: org.eclipse.remote.serial.ui, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.serial.ui_1.0.0.201909031456.jar
Id: org.eclipse.remote.telnet.core, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.telnet.core_1.0.0.201909031456.jar
Id: org.eclipse.remote.telnet.ui, Version: 1.0.0.201909031456, Location: reference:file:plugins/org.eclipse.remote.telnet.ui_1.0.0.201909031456.jar
Id: org.eclipse.remote.ui, Version: 2.1.1.201909031456, Location: reference:file:plugins/org.eclipse.remote.ui_2.1.1.201909031456.jar
Id: org.eclipse.rse, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse_4.5.300.202101081027.jar
Id: org.eclipse.rse.connectorservice.dstore, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.connectorservice.dstore_4.5.300.202101081027.jar
Id: org.eclipse.rse.connectorservice.local, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.connectorservice.local_4.5.300.202101081027.jar
Id: org.eclipse.rse.connectorservice.ssh, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.connectorservice.ssh_4.5.300.202101081027.jar
Id: org.eclipse.rse.connectorservice.telnet, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.connectorservice.telnet_4.5.300.202101081027.jar
Id: org.eclipse.rse.core, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.core_4.5.300.202101081027.jar
Id: org.eclipse.rse.doc.user, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.doc.user_4.5.300.202101081027.jar
Id: org.eclipse.rse.dstore.security, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.dstore.security_4.5.300.202101081027.jar
Id: org.eclipse.rse.efs, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.efs_4.5.300.202101081027.jar
Id: org.eclipse.rse.efs.ui, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.efs.ui_4.5.300.202101081027.jar
Id: org.eclipse.rse.files.ui, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.files.ui_4.5.300.202101081027.jar
Id: org.eclipse.rse.importexport, Version: 4.5.101.201904091623, Location: reference:file:plugins/org.eclipse.rse.importexport_4.5.101.201904091623.jar
Id: org.eclipse.rse.processes.ui, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.processes.ui_4.5.300.202101081027.jar
Id: org.eclipse.rse.services, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.services_4.5.300.202101081027.jar
Id: org.eclipse.rse.services.dstore, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.services.dstore_4.5.300.202101081027.jar
Id: org.eclipse.rse.services.files.ftp, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.services.files.ftp_4.5.300.202101081027.jar
Id: org.eclipse.rse.services.local, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.services.local_4.5.300.202101081027.jar
Id: org.eclipse.rse.services.ssh, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.services.ssh_4.5.300.202101081027.jar
Id: org.eclipse.rse.services.telnet, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.services.telnet_4.5.300.202101081027.jar
Id: org.eclipse.rse.shells.ui, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.shells.ui_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.files.core, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.files.core_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.files.dstore, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.files.dstore_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.files.ftp, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.files.ftp_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.files.local, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.files.local_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.files.ssh, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.files.ssh_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.processes.core, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.processes.core_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.processes.dstore, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.processes.dstore_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.processes.local, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.processes.local_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.processes.shell.linux, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.processes.shell.linux_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.shells.core, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.shells.core_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.shells.dstore, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.shells.dstore_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.shells.local, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.shells.local_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.shells.ssh, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.shells.ssh_4.5.300.202101081027.jar
Id: org.eclipse.rse.subsystems.shells.telnet, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.subsystems.shells.telnet_4.5.300.202101081027.jar
Id: org.eclipse.rse.ui, Version: 4.5.300.202101081027, Location: reference:file:plugins/org.eclipse.rse.ui_4.5.300.202101081027.jar
Id: org.eclipse.rtsc.project.templates, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.project.templates_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.adapter, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.adapter_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.adapter.ccsplugin, Version: 1.0.0.202003291417, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.adapter.ccsplugin_1.0.0.202003291417.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions, Version: 9.2.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions_9.2.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS, Version: 10.1.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_10.1.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31, Version: 8.2.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.31_8.2.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40, Version: 8.2.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.40_8.2.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.42, Version: 8.2.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.DSPBIOS_5.42_8.2.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.XDC, Version: 10.1.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_10.1.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.XDC.minimal, Version: 10.1.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC.minimal_10.1.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00, Version: 10.0.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.00_10.0.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10, Version: 10.0.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.10_10.0.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15, Version: 10.0.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.15_10.0.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16, Version: 10.0.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.buildDefinitions.XDC_3.16_10.0.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.contenttype, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.contenttype_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.core, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.core_3.62.1.16/
Id: org.eclipse.rtsc.xdctools.managedbuild.core, Version: 11.0.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.managedbuild.core_11.0.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.managedbuild.ui, Version: 10.0.0.202112011800, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.managedbuild.ui_10.0.0.202112011800.jar
Id: org.eclipse.rtsc.xdctools.model, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.model_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.model.scripting, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.model.scripting_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.parsers, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.parsers_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.product.ui, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.product.ui_3.62.1.16/
Id: org.eclipse.rtsc.xdctools.product_3.62.1.16, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.product_3.62.1.16_3.62.1.16/
Id: org.eclipse.rtsc.xdctools.rta, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.rta_3.62.1.16/
Id: org.eclipse.rtsc.xdctools.server, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.server_3.62.1.16/
Id: org.eclipse.rtsc.xdctools.sg, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.sg_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.sg.def, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.sg.def_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.ui, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.ui_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.ui.cdt, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.ui.cdt_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.ui.contentassist, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.ui.contentassist_3.62.1.16.jar
Id: org.eclipse.rtsc.xdctools.ui.editors, Version: 3.62.1.16, Location: reference:file:plugins/org.eclipse.rtsc.xdctools.ui.editors_3.62.1.16.jar
Id: org.eclipse.search, Version: 3.13.0.v20210212-0759, Location: reference:file:plugins/org.eclipse.search_3.13.0.v20210212-0759.jar
Id: org.eclipse.swt, Version: 3.116.0.v20210302-1107, Location: reference:file:plugins/org.eclipse.swt_3.116.0.v20210302-1107.jar
Id: org.eclipse.swt.browser.chromium.win32.win32.x86_64, Version: 3.116.0.v20210302-1107, Location: reference:file:plugins/org.eclipse.swt.browser.chromium.win32.win32.x86_64_3.116.0.v20210302-1107.jar
Id: org.eclipse.swt.win32.win32.x86_64, Version: 3.116.0.v20210302-1107, Location: reference:file:plugins/org.eclipse.swt.win32.win32.x86_64_3.116.0.v20210302-1107.jar
Id: org.eclipse.team.core, Version: 3.8.1100.v20200806-0621, Location: reference:file:plugins/org.eclipse.team.core_3.8.1100.v20200806-0621.jar
Id: org.eclipse.team.genericeditor.diff.extension, Version: 1.0.600.v20200212-1524, Location: reference:file:plugins/org.eclipse.team.genericeditor.diff.extension_1.0.600.v20200212-1524.jar
Id: org.eclipse.team.ui, Version: 3.8.1200.v20210204-1156, Location: reference:file:plugins/org.eclipse.team.ui_3.8.1200.v20210204-1156.jar
Id: org.eclipse.text, Version: 3.11.0.v20210203-1022, Location: reference:file:plugins/org.eclipse.text_3.11.0.v20210203-1022.jar
Id: org.eclipse.text.quicksearch, Version: 1.1.0.v20210120-0733, Location: reference:file:plugins/org.eclipse.text.quicksearch_1.1.0.v20210120-0733.jar
Id: org.eclipse.tm.terminal.connector.cdtserial, Version: 4.7.100.202008310315, Location: reference:file:plugins/org.eclipse.tm.terminal.connector.cdtserial_4.7.100.202008310315.jar
Id: org.eclipse.tm.terminal.connector.local, Version: 4.7.0.202008310315, Location: reference:file:plugins/org.eclipse.tm.terminal.connector.local_4.7.0.202008310315.jar
Id: org.eclipse.tm.terminal.connector.process, Version: 4.7.0.202008310315, Location: reference:file:plugins/org.eclipse.tm.terminal.connector.process_4.7.0.202008310315.jar
Id: org.eclipse.tm.terminal.connector.ssh, Version: 4.7.0.202011161527, Location: reference:file:plugins/org.eclipse.tm.terminal.connector.ssh_4.7.0.202011161527.jar
Id: org.eclipse.tm.terminal.connector.telnet, Version: 4.7.100.202010121414, Location: reference:file:plugins/org.eclipse.tm.terminal.connector.telnet_4.7.100.202010121414.jar
Id: org.eclipse.tm.terminal.control, Version: 5.1.0.202103012351, Location: reference:file:plugins/org.eclipse.tm.terminal.control_5.1.0.202103012351.jar
Id: org.eclipse.tm.terminal.view.core, Version: 4.7.0.202008310315, Location: reference:file:plugins/org.eclipse.tm.terminal.view.core_4.7.0.202008310315.jar
Id: org.eclipse.tm.terminal.view.ui, Version: 4.8.0.202103012351, Location: reference:file:plugins/org.eclipse.tm.terminal.view.ui_4.8.0.202103012351.jar
Id: org.eclipse.tools.templates.core, Version: 1.2.0.202008310315, Location: reference:file:plugins/org.eclipse.tools.templates.core_1.2.0.202008310315.jar
Id: org.eclipse.tools.templates.freemarker, Version: 1.2.100.202011191931, Location: reference:file:plugins/org.eclipse.tools.templates.freemarker_1.2.100.202011191931.jar
Id: org.eclipse.tools.templates.ui, Version: 1.2.100.202010121414, Location: reference:file:plugins/org.eclipse.tools.templates.ui_1.2.100.202010121414.jar
Id: org.eclipse.ui, Version: 3.119.0.v20210111-1350, Location: reference:file:plugins/org.eclipse.ui_3.119.0.v20210111-1350.jar
Id: org.eclipse.ui.browser, Version: 3.6.1100.v20210118-1327, Location: reference:file:plugins/org.eclipse.ui.browser_3.6.1100.v20210118-1327.jar
Id: org.eclipse.ui.cheatsheets, Version: 3.7.200.v20210121-1039, Location: reference:file:plugins/org.eclipse.ui.cheatsheets_3.7.200.v20210121-1039.jar
Id: org.eclipse.ui.console, Version: 3.10.100.v20201211-1511, Location: reference:file:plugins/org.eclipse.ui.console_3.10.100.v20201211-1511.jar
Id: org.eclipse.ui.editors, Version: 3.14.0.v20210215-0846, Location: reference:file:plugins/org.eclipse.ui.editors_3.14.0.v20210215-0846.jar
Id: org.eclipse.ui.externaltools, Version: 3.4.900.v20201105-0600, Location: reference:file:plugins/org.eclipse.ui.externaltools_3.4.900.v20201105-0600.jar
Id: org.eclipse.ui.forms, Version: 3.11.100.v20210108-1139, Location: reference:file:plugins/org.eclipse.ui.forms_3.11.100.v20210108-1139.jar
Id: org.eclipse.ui.genericeditor, Version: 1.2.0.v20210129-1224, Location: reference:file:plugins/org.eclipse.ui.genericeditor_1.2.0.v20210129-1224.jar
Id: org.eclipse.ui.ide, Version: 3.18.100.v20210122-1536, Location: reference:file:plugins/org.eclipse.ui.ide_3.18.100.v20210122-1536.jar
Id: org.eclipse.ui.ide.application, Version: 1.4.0.v20210122-1423, Location: reference:file:plugins/org.eclipse.ui.ide.application_1.4.0.v20210122-1423.jar
Id: org.eclipse.ui.intro, Version: 3.6.100.v20210119-2223, Location: reference:file:plugins/org.eclipse.ui.intro_3.6.100.v20210119-2223.jar
Id: org.eclipse.ui.intro.quicklinks, Version: 1.1.0.v20200724-0708, Location: reference:file:plugins/org.eclipse.ui.intro.quicklinks_1.1.0.v20200724-0708.jar
Id: org.eclipse.ui.intro.universal, Version: 3.4.100.v20210108-1131, Location: reference:file:plugins/org.eclipse.ui.intro.universal_3.4.100.v20210108-1131.jar
Id: org.eclipse.ui.monitoring, Version: 1.2.0.v20210111-1353, Location: reference:file:plugins/org.eclipse.ui.monitoring_1.2.0.v20210111-1353.jar
Id: org.eclipse.ui.navigator, Version: 3.10.0.v20210111-1352, Location: reference:file:plugins/org.eclipse.ui.navigator_3.10.0.v20210111-1352.jar
Id: org.eclipse.ui.navigator.resources, Version: 3.8.0.v20210209-1136, Location: reference:file:plugins/org.eclipse.ui.navigator.resources_3.8.0.v20210209-1136.jar
Id: org.eclipse.ui.net, Version: 1.3.800.v20200422-1935, Location: reference:file:plugins/org.eclipse.ui.net_1.3.800.v20200422-1935.jar
Id: org.eclipse.ui.themes, Version: 1.2.1300.v20210108-1832, Location: reference:file:plugins/org.eclipse.ui.themes_1.2.1300.v20210108-1832/
Id: org.eclipse.ui.views, Version: 3.11.0.v20210111-1351, Location: reference:file:plugins/org.eclipse.ui.views_3.11.0.v20210111-1351.jar
Id: org.eclipse.ui.views.log, Version: 1.2.1400.v20210122-1423, Location: reference:file:plugins/org.eclipse.ui.views.log_1.2.1400.v20210122-1423.jar
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.9.100.v20201223-1348, Location: reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.9.100.v20201223-1348.jar
Id: org.eclipse.ui.win32, Version: 3.4.400.v20200414-1247, Location: reference:file:plugins/org.eclipse.ui.win32_3.4.400.v20200414-1247.jar
Id: org.eclipse.ui.workbench, Version: 3.122.100.v20210215-1525, Location: reference:file:plugins/org.eclipse.ui.workbench_3.122.100.v20210215-1525.jar
Id: org.eclipse.ui.workbench.texteditor, Version: 3.16.0.v20210120-0733, Location: reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.16.0.v20210120-0733.jar
Id: org.eclipse.update.configurator, Version: 3.4.700.v20200907-1237, Location: reference:file:plugins/org.eclipse.update.configurator_3.4.700.v20200907-1237.jar
Id: org.eclipse.urischeme, Version: 1.1.300.v20210113-1544, Location: reference:file:plugins/org.eclipse.urischeme_1.1.300.v20210113-1544.jar
Id: org.eclipse.userstorage, Version: 1.2.0.v20190307-0457, Location: reference:file:plugins/org.eclipse.userstorage_1.2.0.v20190307-0457.jar
Id: org.eclipse.userstorage.oauth, Version: 1.1.0.v20190307-0457, Location: reference:file:plugins/org.eclipse.userstorage.oauth_1.1.0.v20190307-0457.jar
Id: org.eclipse.userstorage.ui, Version: 1.1.0.v20190307-0457, Location: reference:file:plugins/org.eclipse.userstorage.ui_1.1.0.v20190307-0457.jar
Id: org.freemarker, Version: 2.3.22.v20160210-1233, Location: reference:file:plugins/org.freemarker_2.3.22.v20160210-1233.jar
Id: org.json, Version: 8.0.0.202112011800, Location: reference:file:plugins/org.json_8.0.0.202112011800.jar
Id: org.sat4j.core, Version: 2.3.5.v201308161310, Location: reference:file:plugins/org.sat4j.core_2.3.5.v201308161310.jar
Id: org.sat4j.pb, Version: 2.3.5.v201404071733, Location: reference:file:plugins/org.sat4j.pb_2.3.5.v201404071733.jar
Id: org.slf4j.api, Version: 1.7.30.v20200204-2150, Location: reference:file:plugins/org.slf4j.api_1.7.30.v20200204-2150.jar
Id: org.tukaani.xz, Version: 1.8.0.v20180207-1613, Location: reference:file:plugins/org.tukaani.xz_1.8.0.v20180207-1613.jar
Id: org.w3c.css.sac, Version: 1.3.1.v200903091627, Location: reference:file:plugins/org.w3c.css.sac_1.3.1.v200903091627.jar
Id: org.w3c.dom.events, Version: 3.0.0.draft20060413_v201105210656, Location: reference:file:plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar
Id: org.w3c.dom.smil, Version: 1.0.1.v200903091627, Location: reference:file:plugins/org.w3c.dom.smil_1.0.1.v200903091627.jar
Id: org.w3c.dom.svg, Version: 1.1.0.v201011041433, Location: reference:file:plugins/org.w3c.dom.svg_1.1.0.v201011041433.jar
Id: xdc.tools.xgconf.modeldata, Version: 3.62.1.16, Location: reference:file:plugins/xdc.tools.xgconf.modeldata_3.62.1.16.jar
*** Security Configuration:
Providers (14):
 Provider: SUN, Version: 11.0, Class: sun.security.provider.Sun
  Description: SUN (DSA key/parameter generation; DSA signing; SHA-1, MD5 digests; SecureRandom; X.509 certificates; PKCS12, JKS & DKS keystores; PKIX CertPathValidator; PKIX CertPathBuilder; LDAP, Collection CertStores, JavaPolicy Policy; JavaLoginConfig Configuration)
  Services (38):
   Service: MessageDigest, Algorithm: SHA-384, Class: sun.security.provider.SHA5$SHA384
    Aliases: 2.16.840.1.101.3.4.2.2
    Attributes:
      ImplementedIn: Software
   Service: CertPathBuilder, Algorithm: PKIX, Class: sun.security.provider.certpath.SunCertPathBuilder
    Attributes:
      ValidationAlgorithm: RFC5280
   Service: Signature, Algorithm: SHA256withDSA, Class: sun.security.provider.DSA$SHA256withDSA
    Aliases: OID.2.16.840.1.101.3.4.3.2
    Attributes:
      KeySize: 2048
      SupportedKeyClasses: java.security.interfaces.DSAPublicKey|java.security.interfaces.DSAPrivateKey
   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: sun.security.provider.DSAParameterGenerator
    Aliases: OID.1.2.840.10040.4.1
    Attributes:
      KeySize: 2048
   Service: MessageDigest, Algorithm: SHA-224, Class: sun.security.provider.SHA2$SHA224
    Aliases: 2.16.840.1.101.3.4.2.4
    Attributes:
   Service: MessageDigest, Algorithm: SHA-256, Class: sun.security.provider.SHA2$SHA256
    Aliases: 2.16.840.1.101.3.4.2.1
    Attributes:
   Service: MessageDigest, Algorithm: SHA-512, Class: sun.security.provider.SHA5$SHA512
    Aliases: 2.16.840.1.101.3.4.2.3
    Attributes:
   Service: KeyStore, Algorithm: DKS, Class: sun.security.provider.DomainKeyStore$DKS
    Attributes:
   Service: SecureRandom, Algorithm: SHA1PRNG, Class: sun.security.provider.SecureRandom
    Attributes:
      ThreadSafe: true
   Service: CertStore, Algorithm: Collection, Class: sun.security.provider.certpath.CollectionCertStore
    Attributes:
   Service: Signature, Algorithm: SHA1withDSA, Class: sun.security.provider.DSA$SHA1withDSA
    Aliases: 1.3.14.3.2.27
    Attributes:
      KeySize: 1024
   Service: AlgorithmParameters, Algorithm: DSA, Class: sun.security.provider.DSAParameters
    Attributes:
   Service: MessageDigest, Algorithm: SHA, Class: sun.security.provider.SHA
    Aliases: OID.1.3.14.3.2.26
    Attributes:
   Service: SecureRandom, Algorithm: DRBG, Class: sun.security.provider.DRBG
    Attributes:
      ThreadSafe: true
   Service: Signature, Algorithm: SHA224withDSAinP1363Format, Class: sun.security.provider.DSA$SHA224withDSAinP1363Format
   Service: KeyStore, Algorithm: JKS, Class: sun.security.provider.JavaKeyStore$DualFormatJKS
    Attributes:
   Service: KeyStore, Algorithm: PKCS12, Class: sun.security.pkcs12.PKCS12KeyStore$DualFormatPKCS12
   Service: CertificateFactory, Algorithm: X.509, Class: sun.security.provider.X509Factory
    Aliases: X509
    Attributes:
   Service: MessageDigest, Algorithm: SHA-512/224, Class: sun.security.provider.SHA5$SHA512_224
    Aliases: 2.16.840.1.101.3.4.2.5
    Attributes:
   Service: MessageDigest, Algorithm: SHA-512/256, Class: sun.security.provider.SHA5$SHA512_256
    Aliases: 2.16.840.1.101.3.4.2.6
    Attributes:
   Service: MessageDigest, Algorithm: MD5, Class: sun.security.provider.MD5
    Attributes:
   Service: KeyPairGenerator, Algorithm: DSA, Class: sun.security.provider.DSAKeyPairGenerator$Current
    Attributes:
      KeySize: 2048
   Service: MessageDigest, Algorithm: MD2, Class: sun.security.provider.MD2
    Attributes:
   Service: MessageDigest, Algorithm: SHA3-384, Class: sun.security.provider.SHA3$SHA384
    Aliases: 2.16.840.1.101.3.4.2.9
    Attributes:
   Service: Configuration, Algorithm: JavaLoginConfig, Class: sun.security.provider.ConfigFile$Spi
   Service: CertPathValidator, Algorithm: PKIX, Class: sun.security.provider.certpath.PKIXCertPathValidator
    Attributes:
   Service: Signature, Algorithm: NONEwithDSAinP1363Format, Class: sun.security.provider.DSA$RawDSAinP1363Format
   Service: MessageDigest, Algorithm: SHA3-512, Class: sun.security.provider.SHA3$SHA512
    Aliases: OID.2.16.840.1.101.3.4.2.10
    Attributes:
   Service: MessageDigest, Algorithm: SHA3-224, Class: sun.security.provider.SHA3$SHA224
    Aliases: 2.16.840.1.101.3.4.2.7
    Attributes:
   Service: MessageDigest, Algorithm: SHA3-256, Class: sun.security.provider.SHA3$SHA256
    Aliases: 2.16.840.1.101.3.4.2.8
    Attributes:
   Service: KeyStore, Algorithm: CaseExactJKS, Class: sun.security.provider.JavaKeyStore$CaseExactJKS
    Attributes:
   Service: Policy, Algorithm: JavaPolicy, Class: sun.security.provider.PolicySpiFile
   Service: Signature, Algorithm: SHA224withDSA, Class: sun.security.provider.DSA$SHA224withDSA
    Aliases: OID.2.16.840.1.101.3.4.3.1
    Attributes:
      KeySize: 2048
   Service: Signature, Algorithm: NONEwithDSA, Class: sun.security.provider.DSA$RawDSA
    Aliases: RawDSA
    Attributes:
      KeySize: 1024
   Service: Signature, Algorithm: SHA256withDSAinP1363Format, Class: sun.security.provider.DSA$SHA256withDSAinP1363Format
   Service: CertStore, Algorithm: com.sun.security.IndexedCollection, Class: sun.security.provider.certpath.IndexedCollectionCertStore
    Attributes:
   Service: KeyFactory, Algorithm: DSA, Class: sun.security.provider.DSAKeyFactory
    Attributes:
   Service: Signature, Algorithm: SHA1withDSAinP1363Format, Class: sun.security.provider.DSA$SHA1withDSAinP1363Format
 Provider: SunRsaSign, Version: 11.0, Class: sun.security.rsa.SunRsaSign
  Description: Sun RSA signature provider
  Services (15):
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.rsa.RSASignature$SHA512withRSA
    Aliases: 1.2.840.113549.1.1.13
    Attributes:
      SupportedKeyClasses: java.security.interfaces.RSAPublicKey|java.security.interfaces.RSAPrivateKey
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.rsa.RSASignature$MD5withRSA
    Aliases: OID.1.2.840.113549.1.1.4
    Attributes:
   Service: KeyFactory, Algorithm: RSA, Class: sun.security.rsa.RSAKeyFactory$Legacy
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.rsa.RSASignature$SHA1withRSA
    Aliases: OID.1.2.840.113549.1.1.5
    Attributes:
   Service: AlgorithmParameters, Algorithm: RSASSA-PSS, Class: sun.security.rsa.PSSParameters
    Aliases: 1.2.840.113549.1.1.10
   Service: Signature, Algorithm: SHA512/224withRSA, Class: sun.security.rsa.RSASignature$SHA512_224withRSA
    Aliases: 1.2.840.113549.1.1.15
    Attributes:
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.rsa.RSASignature$SHA384withRSA
    Aliases: 1.2.840.113549.1.1.12
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.rsa.RSAKeyPairGenerator$Legacy
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.rsa.RSASignature$SHA256withRSA
    Aliases: 1.2.840.113549.1.1.11
    Attributes:
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.rsa.RSASignature$MD2withRSA
    Aliases: OID.1.2.840.113549.1.1.2
    Attributes:
   Service: Signature, Algorithm: SHA512/256withRSA, Class: sun.security.rsa.RSASignature$SHA512_256withRSA
    Aliases: 1.2.840.113549.1.1.16
    Attributes:
   Service: Signature, Algorithm: SHA224withRSA, Class: sun.security.rsa.RSASignature$SHA224withRSA
    Aliases: 1.2.840.113549.1.1.14
    Attributes:
   Service: KeyPairGenerator, Algorithm: RSASSA-PSS, Class: sun.security.rsa.RSAKeyPairGenerator$PSS
   Service: KeyFactory, Algorithm: RSASSA-PSS, Class: sun.security.rsa.RSAKeyFactory$PSS
   Service: Signature, Algorithm: RSASSA-PSS, Class: sun.security.rsa.RSAPSSSignature
    Attributes:
 Provider: SunEC, Version: 11.0, Class: sun.security.ec.SunEC
  Description: Sun Elliptic Curve provider (EC, ECDSA, ECDH)
  Services (25):
   Service: KeyFactory, Algorithm: EC, Class: sun.security.ec.ECKeyFactory
    Aliases: EllipticCurve
    Attributes:
      KeySize: 256
      SupportedKeyClasses: java.security.interfaces.ECPublicKey|java.security.interfaces.ECPrivateKey
   Service: KeyAgreement, Algorithm: XDH, Class: sun.security.ec.XDHKeyAgreement
    Attributes:
   Service: Signature, Algorithm: SHA224withECDSA, Class: sun.security.ec.ECDSASignature$SHA224
    Aliases: OID.1.2.840.10045.4.3.1
    Attributes:
      KeySize: 256
   Service: Signature, Algorithm: SHA512withECDSAinP1363Format, Class: sun.security.ec.ECDSASignature$SHA512inP1363Format
   Service: AlgorithmParameters, Algorithm: EC, Class: sun.security.util.ECParameters
    Attributes:
      SupportedCurves: [secp112r1,1.3.132.0.6]|[secp112r2,1.3.132.0.7]|[secp128r1,1.3.132.0.28]|[secp128r2,1.3.132.0.29]|[secp160k1,1.3.132.0.9]|[secp160r1,1.3.132.0.8]|[secp160r2,1.3.132.0.30]|[secp192k1,1.3.132.0.31]|[secp192r1,NIST P-192,X9.62 prime192v1,1.2.840.10045.3.1.1]|[secp224k1,1.3.132.0.32]|[secp224r1,NIST P-224,1.3.132.0.33]|[secp256k1,1.3.132.0.10]|[secp256r1,NIST P-256,X9.62 prime256v1,1.2.840.10045.3.1.7]|[secp384r1,NIST P-384,1.3.132.0.34]|[secp521r1,NIST P-521,1.3.132.0.35]|[X9.62 prime192v2,1.2.840.10045.3.1.2]|[X9.62 prime192v3,1.2.840.10045.3.1.3]|[X9.62 prime239v1,1.2.840.10045.3.1.4]|[X9.62 prime239v2,1.2.840.10045.3.1.5]|[X9.62 prime239v3,1.2.840.10045.3.1.6]|[sect113r1,1.3.132.0.4]|[sect113r2,1.3.132.0.5]|[sect131r1,1.3.132.0.22]|[sect131r2,1.3.132.0.23]|[sect163k1,NIST K-163,1.3.132.0.1]|[sect163r1,1.3.132.0.2]|[sect163r2,NIST B-163,1.3.132.0.15]|[sect193r1,1.3.132.0.24]|[sect193r2,1.3.132.0.25]|[sect233k1,NIST K-233,1.3.132.0.26]|[sect233r1,NIST B-233,1.3.132.0.27]|[sect239k1,1.3.132.0.3]|[sect283k1,NIST K-283,1.3.132.0.16]|[sect283r1,NIST B-283,1.3.132.0.17]|[sect409k1,NIST K-409,1.3.132.0.36]|[sect409r1,NIST B-409,1.3.132.0.37]|[sect571k1,NIST K-571,1.3.132.0.38]|[sect571r1,NIST B-571,1.3.132.0.39]|[X9.62 c2tnb191v1,1.2.840.10045.3.0.5]|[X9.62 c2tnb191v2,1.2.840.10045.3.0.6]|[X9.62 c2tnb191v3,1.2.840.10045.3.0.7]|[X9.62 c2tnb239v1,1.2.840.10045.3.0.11]|[X9.62 c2tnb239v2,1.2.840.10045.3.0.12]|[X9.62 c2tnb239v3,1.2.840.10045.3.0.13]|[X9.62 c2tnb359v1,1.2.840.10045.3.0.18]|[X9.62 c2tnb431r1,1.2.840.10045.3.0.20]|[brainpoolP160r1,1.3.36.3.3.2.8.1.1.1]|[brainpoolP192r1,1.3.36.3.3.2.8.1.1.3]|[brainpoolP224r1,1.3.36.3.3.2.8.1.1.5]|[brainpoolP256r1,1.3.36.3.3.2.8.1.1.7]|[brainpoolP320r1,1.3.36.3.3.2.8.1.1.9]|[brainpoolP384r1,1.3.36.3.3.2.8.1.1.11]|[brainpoolP512r1,1.3.36.3.3.2.8.1.1.13]
      KeySize: 256
   Service: KeyPairGenerator, Algorithm: XDH, Class: sun.security.ec.XDHKeyPairGenerator
    Attributes:
   Service: KeyPairGenerator, Algorithm: X448, Class: sun.security.ec.XDHKeyPairGenerator.X448
    Aliases: 1.3.101.111
    Attributes:
   Service: KeyAgreement, Algorithm: X25519, Class: sun.security.ec.XDHKeyAgreement.X25519
    Aliases: 1.3.101.110
    Attributes:
   Service: KeyPairGenerator, Algorithm: X25519, Class: sun.security.ec.XDHKeyPairGenerator.X25519
    Attributes:
   Service: KeyFactory, Algorithm: X25519, Class: sun.security.ec.XDHKeyFactory.X25519
    Attributes:
   Service: Signature, Algorithm: SHA384withECDSAinP1363Format, Class: sun.security.ec.ECDSASignature$SHA384inP1363Format
   Service: KeyAgreement, Algorithm: ECDH, Class: sun.security.ec.ECDHKeyAgreement
    Attributes:
      KeySize: 256
   Service: KeyFactory, Algorithm: XDH, Class: sun.security.ec.XDHKeyFactory
    Attributes:
   Service: Signature, Algorithm: SHA256withECDSA, Class: sun.security.ec.ECDSASignature$SHA256
    Aliases: OID.1.2.840.10045.4.3.2
    Attributes:
      KeySize: 256
   Service: KeyFactory, Algorithm: X448, Class: sun.security.ec.XDHKeyFactory.X448
    Attributes:
   Service: KeyPairGenerator, Algorithm: EC, Class: sun.security.ec.ECKeyPairGenerator
    Attributes:
      KeySize: 256
   Service: Signature, Algorithm: NONEwithECDSA, Class: sun.security.ec.ECDSASignature$Raw
    Attributes:
      KeySize: 256
   Service: Signature, Algorithm: SHA512withECDSA, Class: sun.security.ec.ECDSASignature$SHA512
    Aliases: OID.1.2.840.10045.4.3.4
    Attributes:
      KeySize: 256
   Service: Signature, Algorithm: SHA256withECDSAinP1363Format, Class: sun.security.ec.ECDSASignature$SHA256inP1363Format
   Service: Signature, Algorithm: SHA1withECDSAinP1363Format, Class: sun.security.ec.ECDSASignature$SHA1inP1363Format
   Service: Signature, Algorithm: SHA1withECDSA, Class: sun.security.ec.ECDSASignature$SHA1
    Aliases: 1.2.840.10045.4.1
    Attributes:
      KeySize: 256
   Service: Signature, Algorithm: SHA224withECDSAinP1363Format, Class: sun.security.ec.ECDSASignature$SHA224inP1363Format
   Service: Signature, Algorithm: NONEwithECDSAinP1363Format, Class: sun.security.ec.ECDSASignature$RawinP1363Format
   Service: KeyAgreement, Algorithm: X448, Class: sun.security.ec.XDHKeyAgreement.X448
    Attributes:
   Service: Signature, Algorithm: SHA384withECDSA, Class: sun.security.ec.ECDSASignature$SHA384
    Aliases: OID.1.2.840.10045.4.3.3
    Attributes:
      KeySize: 256
 Provider: SunJSSE, Version: 11.0, Class: com.sun.net.ssl.internal.ssl.Provider
  Description: Sun JSSE provider(PKCS12, SunX509/PKIX key/trust factories, SSLv3/TLSv1/TLSv1.1/TLSv1.2/TLSv1.3/DTLSv1.0/DTLSv1.2)
  Services (30):
   Service: SSLContext, Algorithm: DTLSv1.2, Class: sun.security.ssl.SSLContextImpl$DTLS12Context
    Attributes:
   Service: SSLContext, Algorithm: DTLSv1.0, Class: sun.security.ssl.SSLContextImpl$DTLS10Context
   Service: SSLContext, Algorithm: Default, Class: sun.security.ssl.SSLContextImpl$DefaultSSLContext
   Service: TrustManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.TrustManagerFactoryImpl$SimpleFactory
   Service: KeyManagerFactory, Algorithm: NewSunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$X509
    Aliases: PKIX
    Attributes:
   Service: SSLContext, Algorithm: DTLS, Class: sun.security.ssl.SSLContextImpl$DTLSContext
   Service: Signature, Algorithm: MD5andSHA1withRSA, Class: sun.security.ssl.RSASignature
    Attributes:
    Attributes:
    Attributes:
    Attributes:
    Attributes:
    Attributes:
    Attributes:
   Service: TrustManagerFactory, Algorithm: PKIX, Class: sun.security.ssl.TrustManagerFactoryImpl$PKIXFactory
    Aliases: X509
   Service: SSLContext, Algorithm: TLS, Class: sun.security.ssl.SSLContextImpl$TLSContext
    Aliases: SSL
   Service: SSLContext, Algorithm: TLSv1, Class: sun.security.ssl.SSLContextImpl$TLS10Context
    Aliases: SSLv3
   Service: KeyManagerFactory, Algorithm: SunX509, Class: sun.security.ssl.KeyManagerFactoryImpl$SunX509
    Attributes:
   Service: SSLContext, Algorithm: TLSv1.3, Class: sun.security.ssl.SSLContextImpl$TLS13Context
   Service: SSLContext, Algorithm: TLSv1.2, Class: sun.security.ssl.SSLContextImpl$TLS12Context
   Service: SSLContext, Algorithm: TLSv1.1, Class: sun.security.ssl.SSLContextImpl$TLS11Context
 Provider: SunJCE, Version: 11.0, Class: com.sun.crypto.provider.SunJCE
  Description: SunJCE Provider (implements RSA, DES, Triple DES, AES, Blowfish, ARCFOUR, RC2, PBE, Diffie-Hellman, HMAC, ChaCha20)
  Services (142):
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA512, Class: com.sun.crypto.provider.PBKDF2Core$HmacSHA512
   Service: KeyGenerator, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishKeyGenerator
   Service: Mac, Algorithm: HmacPBESHA1, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA1
    Attributes:
      SupportedKeyFormats: RAW
   Service: KeyGenerator, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA2KG$SHA512
    Aliases: OID.1.2.840.113549.2.11
   Service: AlgorithmParameters, Algorithm: GCM, Class: com.sun.crypto.provider.GCMParameters
   Service: Cipher, Algorithm: ChaCha20, Class: com.sun.crypto.provider.ChaCha20Cipher$ChaCha20Only
    Attributes:
   Service: Cipher, Algorithm: PBEWithHmacSHA1AndAES_128, Class: com.sun.crypto.provider.PBES2Core$HmacSHA1AndAES_128
   Service: KeyGenerator, Algorithm: SunTlsMasterSecret, Class: com.sun.crypto.provider.TlsMasterSecretGenerator
    Aliases: SunTlsExtendedMasterSecret
   Service: AlgorithmParameters, Algorithm: PBES2, Class: com.sun.crypto.provider.PBES2Parameters$General
    Aliases: OID.1.2.840.113549.1.5.13
   Service: Cipher, Algorithm: DES, Class: com.sun.crypto.provider.DESCipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS5PADDING|ISO10126PADDING
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64
   Service: Cipher, Algorithm: AES_192/CBC/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES192_CBC_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.22
    Attributes:
   Service: Cipher, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishCipher
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA1, Class: com.sun.crypto.provider.PBKDF2Core$HmacSHA1
    Aliases: 1.2.840.113549.1.5.12
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEParameters
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA512AndAES_128, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA512AndAES_128
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA384AndAES_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA384AndAES_128
   Service: Cipher, Algorithm: PBEWithHmacSHA256AndAES_128, Class: com.sun.crypto.provider.PBES2Core$HmacSHA256AndAES_128
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEParameters
    Aliases: 1.2.840.113549.1.12.1.6
   Service: Cipher, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Cipher
    Attributes:
   Service: Cipher, Algorithm: AES_256/OFB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES256_OFB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.43
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEParameters
    Aliases: 1.2.840.113549.1.12.1.3
   Service: Cipher, Algorithm: AES_128/GCM/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES128_GCM_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.6
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC4_128, Class: com.sun.crypto.provider.PBEParameters
    Aliases: 1.2.840.113549.1.12.1.1
   Service: Cipher, Algorithm: PBEWithHmacSHA224AndAES_256, Class: com.sun.crypto.provider.PBES2Core$HmacSHA224AndAES_256
   Service: Mac, Algorithm: HmacPBESHA512/256, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA512_256
    Attributes:
   Service: KeyGenerator, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1KeyGenerator
    Aliases: OID.1.2.840.113549.2.7
   Service: Cipher, Algorithm: AES, Class: com.sun.crypto.provider.AESCipher$General
    Aliases: Rijndael
    Attributes:
      SupportedModes: ECB|CBC|PCBC|CTR|CTS|CFB|OFB|CFB8|CFB16|CFB24|CFB32|CFB40|CFB48|CFB56|CFB64|OFB8|OFB16|OFB24|OFB32|OFB40|OFB48|OFB56|OFB64|GCM|CFB72|CFB80|CFB88|CFB96|CFB104|CFB112|CFB120|CFB128|OFB72|OFB80|OFB88|OFB96|OFB104|OFB112|OFB120|OFB128
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC4_40, Class: com.sun.crypto.provider.PBEParameters
    Aliases: 1.2.840.113549.1.12.1.2
   Service: Mac, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.HmacCore$HmacSHA384
    Aliases: OID.1.2.840.113549.2.10
    Attributes:
   Service: Mac, Algorithm: HmacSHA224, Class: com.sun.crypto.provider.HmacCore$HmacSHA224
    Aliases: OID.1.2.840.113549.2.8
    Attributes:
   Service: Cipher, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeCipher
    Aliases: TripleDES
    Attributes:
   Service: KeyFactory, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyFactory
    Aliases: OID.1.2.840.113549.1.3.1
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA384AndAES_256, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA384AndAES_256
   Service: Cipher, Algorithm: AES_256/CFB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES256_CFB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.44
    Attributes:
   Service: Cipher, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEWithMD5AndDESCipher
    Aliases: OID.1.2.840.113549.1.5.3
   Service: AlgorithmParameters, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeParameters
    Aliases: TripleDES
   Service: Mac, Algorithm: HmacSHA512/224, Class: com.sun.crypto.provider.HmacCore$HmacSHA512_224
    Attributes:
   Service: Cipher, Algorithm: PBEWithHmacSHA512AndAES_256, Class: com.sun.crypto.provider.PBES2Core$HmacSHA512AndAES_256
   Service: Mac, Algorithm: HmacSHA512, Class: com.sun.crypto.provider.HmacCore$HmacSHA512
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA256AndAES_256, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA256AndAES_256
   Service: Cipher, Algorithm: AES_128/CBC/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES128_CBC_NoPadding
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC4_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC4_128
   Service: Cipher, Algorithm: AES_256/ECB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES256_ECB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.41
    Attributes:
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA1AndAES_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA1AndAES_128
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA256AndAES_128, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA256AndAES_128
   Service: Cipher, Algorithm: AESWrap_192, Class: com.sun.crypto.provider.AESWrapCipher$AES192
    Aliases: OID.2.16.840.1.101.3.4.1.25
    Attributes:
      SupportedModes: ECB
   Service: Mac, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5
    Attributes:
   Service: Mac, Algorithm: SslMacMD5, Class: com.sun.crypto.provider.SslMacCore$SslMacMD5
    Attributes:
   Service: Mac, Algorithm: HmacSHA1, Class: com.sun.crypto.provider.HmacSHA1
    Attributes:
   Service: KeyGenerator, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyGenerator
   Service: Mac, Algorithm: SslMacSHA1, Class: com.sun.crypto.provider.SslMacCore$SslMacSHA1
    Attributes:
   Service: AlgorithmParameters, Algorithm: ChaCha20-Poly1305, Class: com.sun.crypto.provider.ChaCha20Poly1305Parameters
    Aliases: OID.1.2.840.113549.1.9.16.3.18
   Service: Cipher, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEWithMD5AndTripleDESCipher
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA224AndAES_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA224AndAES_128
   Service: Mac, Algorithm: HmacPBESHA256, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA256
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA224AndAES_256, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA224AndAES_256
   Service: Mac, Algorithm: PBEWithHmacSHA384, Class: com.sun.crypto.provider.PBMAC1Core$HmacSHA384
    Attributes:
   Service: SecretKeyFactory, Algorithm: DES, Class: com.sun.crypto.provider.DESKeyFactory
   Service: Mac, Algorithm: PBEWithHmacSHA224, Class: com.sun.crypto.provider.PBMAC1Core$HmacSHA224
    Attributes:
   Service: KeyGenerator, Algorithm: RC2, Class: com.sun.crypto.provider.KeyGeneratorCore$RC2KeyGenerator
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA256, Class: com.sun.crypto.provider.PBKDF2Core$HmacSHA256
   Service: Cipher, Algorithm: AES_256/GCM/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES256_GCM_NoPadding
    Aliases: 2.16.840.1.101.3.4.1.46
    Attributes:
   Service: Cipher, Algorithm: PBEWithHmacSHA384AndAES_128, Class: com.sun.crypto.provider.PBES2Core$HmacSHA384AndAES_128
   Service: KeyGenerator, Algorithm: AES, Class: com.sun.crypto.provider.AESKeyGenerator
    Aliases: Rijndael
   Service: SecretKeyFactory, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyFactory
    Aliases: TripleDES
   Service: Cipher, Algorithm: AESWrap_128, Class: com.sun.crypto.provider.AESWrapCipher$AES128
    Aliases: OID.2.16.840.1.101.3.4.1.5
    Attributes:
      SupportedModes: ECB
   Service: Cipher, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.ARCFOURCipher
    Aliases: RC4
    Attributes:
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA2KG$SHA256
    Aliases: OID.1.2.840.113549.2.9
   Service: Mac, Algorithm: PBEWithHmacSHA512, Class: com.sun.crypto.provider.PBMAC1Core$HmacSHA512
    Attributes:
   Service: Cipher, Algorithm: RSA, Class: com.sun.crypto.provider.RSACipher
    Attributes:
      SupportedPaddings: NOPADDING|PKCS1PADDING|OAEPPADDING|OAEPWITHMD5ANDMGF1PADDING|OAEPWITHSHA1ANDMGF1PADDING|OAEPWITHSHA-1ANDMGF1PADDING|OAEPWITHSHA-224ANDMGF1PADDING|OAEPWITHSHA-256ANDMGF1PADDING|OAEPWITHSHA-384ANDMGF1PADDING|OAEPWITHSHA-512ANDMGF1PADDING|OAEPWITHSHA-512/224ANDMGF1PADDING|OAEPWITHSHA-512/256ANDMGF1PADDING
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: SunTls12Prf, Class: com.sun.crypto.provider.TlsPrfGenerator$V12
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA512AndAES_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA512AndAES_128
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA1AndAES_128, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA1AndAES_128
   Service: Cipher, Algorithm: PBEWithSHA1AndRC4_128, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC4_128
   Service: KeyGenerator, Algorithm: ARCFOUR, Class: com.sun.crypto.provider.KeyGeneratorCore$ARCFOURKeyGenerator
    Aliases: RC4
   Service: Cipher, Algorithm: ChaCha20-Poly1305, Class: com.sun.crypto.provider.ChaCha20Cipher$ChaCha20Poly1305
    Attributes:
   Service: AlgorithmParameters, Algorithm: PBEWithSHA1AndRC2_128, Class: com.sun.crypto.provider.PBEParameters
    Aliases: 1.2.840.113549.1.12.1.5
   Service: Cipher, Algorithm: PBEWithHmacSHA1AndAES_256, Class: com.sun.crypto.provider.PBES2Core$HmacSHA1AndAES_256
   Service: KeyGenerator, Algorithm: SunTlsPrf, Class: com.sun.crypto.provider.TlsPrfGenerator$V10
   Service: AlgorithmParameters, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameters
   Service: Mac, Algorithm: PBEWithHmacSHA1, Class: com.sun.crypto.provider.PBMAC1Core$HmacSHA1
    Attributes:
   Service: KeyGenerator, Algorithm: HmacMD5, Class: com.sun.crypto.provider.HmacMD5KeyGenerator
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA512AndAES_256, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA512AndAES_256
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA384AndAES_256, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA384AndAES_256
   Service: Cipher, Algorithm: PBEWithHmacSHA256AndAES_256, Class: com.sun.crypto.provider.PBES2Core$HmacSHA256AndAES_256
   Service: Cipher, Algorithm: AESWrap, Class: com.sun.crypto.provider.AESWrapCipher$General
    Attributes:
      SupportedModes: ECB
   Service: AlgorithmParameters, Algorithm: OAEP, Class: com.sun.crypto.provider.OAEPParameters
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_40
   Service: Cipher, Algorithm: AES_192/CFB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES192_CFB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.24
    Attributes:
   Service: Cipher, Algorithm: AES_192/OFB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES192_OFB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.23
    Attributes:
   Service: Mac, Algorithm: HmacPBESHA512/224, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA512_224
    Attributes:
   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_40
   Service: Cipher, Algorithm: PBEWithHmacSHA224AndAES_128, Class: com.sun.crypto.provider.PBES2Core$HmacSHA224AndAES_128
   Service: KeyGenerator, Algorithm: SunTlsKeyMaterial, Class: com.sun.crypto.provider.TlsKeyMaterialGenerator
    Aliases: SunTls12KeyMaterial
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndDESede
   Service: Cipher, Algorithm: AES_256/CBC/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES256_CBC_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.42
    Attributes:
   Service: KeyPairGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyPairGenerator
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC2_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC2_128
   Service: SecretKeyFactory, Algorithm: PBEWithSHA1AndRC4_40, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithSHA1AndRC4_40
   Service: Cipher, Algorithm: PBEWithSHA1AndDESede, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndDESede
   Service: Mac, Algorithm: HmacSHA256, Class: com.sun.crypto.provider.HmacCore$HmacSHA256
    Attributes:
   Service: Cipher, Algorithm: AES_192/ECB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES192_ECB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.21
    Attributes:
   Service: Cipher, Algorithm: PBEWithSHA1AndRC4_40, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC4_40
   Service: AlgorithmParameters, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEParameters
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA384AndAES_128, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA384AndAES_128
   Service: AlgorithmParameters, Algorithm: DES, Class: com.sun.crypto.provider.DESParameters
   Service: Mac, Algorithm: HmacSHA512/256, Class: com.sun.crypto.provider.HmacCore$HmacSHA512_256
    Attributes:
   Service: KeyAgreement, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHKeyAgreement
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
   Service: Cipher, Algorithm: PBEWithHmacSHA512AndAES_128, Class: com.sun.crypto.provider.PBES2Core$HmacSHA512AndAES_128
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA256AndAES_128, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA256AndAES_128
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA1AndAES_256, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA1AndAES_256
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA256AndAES_256, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA256AndAES_256
   Service: AlgorithmParameters, Algorithm: RC2, Class: com.sun.crypto.provider.RC2Parameters
   Service: AlgorithmParameterGenerator, Algorithm: DiffieHellman, Class: com.sun.crypto.provider.DHParameterGenerator
   Service: KeyGenerator, Algorithm: SunTlsRsaPremasterSecret, Class: com.sun.crypto.provider.TlsRsaPremasterSecretGenerator
    Aliases: SunTls12RsaPremasterSecret
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA224AndAES_256, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA224AndAES_256
   Service: Mac, Algorithm: HmacPBESHA384, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA384
    Attributes:
   Service: Mac, Algorithm: HmacPBESHA224, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA224
    Attributes:
   Service: AlgorithmParameters, Algorithm: AES, Class: com.sun.crypto.provider.AESParameters
    Aliases: Rijndael
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA224AndAES_128, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA224AndAES_128
   Service: Mac, Algorithm: PBEWithHmacSHA256, Class: com.sun.crypto.provider.PBMAC1Core$HmacSHA256
    Attributes:
   Service: Cipher, Algorithm: AES_128/CFB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES128_CFB_NoPadding
    Attributes:
   Service: Cipher, Algorithm: AES_128/OFB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES128_OFB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.3
    Attributes:
   Service: Cipher, Algorithm: PBEWithSHA1AndRC2_128, Class: com.sun.crypto.provider.PKCS12PBECipherCore$PBEWithSHA1AndRC2_128
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndTripleDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndTripleDES
   Service: SecretKeyFactory, Algorithm: PBEWithMD5AndDES, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithMD5AndDES
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA384, Class: com.sun.crypto.provider.PBKDF2Core$HmacSHA384
   Service: SecretKeyFactory, Algorithm: PBKDF2WithHmacSHA224, Class: com.sun.crypto.provider.PBKDF2Core$HmacSHA224
   Service: Cipher, Algorithm: PBEWithHmacSHA384AndAES_256, Class: com.sun.crypto.provider.PBES2Core$HmacSHA384AndAES_256
   Service: Cipher, Algorithm: AES_128/ECB/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES128_ECB_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.1
    Attributes:
   Service: Mac, Algorithm: HmacPBESHA512, Class: com.sun.crypto.provider.HmacPKCS12PBECore$HmacPKCS12PBE_SHA512
    Attributes:
   Service: Cipher, Algorithm: AESWrap_256, Class: com.sun.crypto.provider.AESWrapCipher$AES256
    Aliases: 2.16.840.1.101.3.4.1.45
    Attributes:
      SupportedModes: ECB
   Service: KeyGenerator, Algorithm: HmacSHA384, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA2KG$SHA384
   Service: KeyGenerator, Algorithm: HmacSHA224, Class: com.sun.crypto.provider.KeyGeneratorCore$HmacSHA2KG$SHA224
   Service: Cipher, Algorithm: DESedeWrap, Class: com.sun.crypto.provider.DESedeWrapCipher
    Attributes:
      SupportedModes: CBC
   Service: Cipher, Algorithm: AES_192/GCM/NoPadding, Class: com.sun.crypto.provider.AESCipher$AES192_GCM_NoPadding
    Aliases: OID.2.16.840.1.101.3.4.1.26
    Attributes:
   Service: KeyStore, Algorithm: JCEKS, Class: com.sun.crypto.provider.JceKeyStore
   Service: KeyGenerator, Algorithm: ChaCha20, Class: com.sun.crypto.provider.KeyGeneratorCore$ChaCha20KeyGenerator
   Service: AlgorithmParameters, Algorithm: Blowfish, Class: com.sun.crypto.provider.BlowfishParameters
   Service: SecretKeyFactory, Algorithm: PBEWithHmacSHA512AndAES_256, Class: com.sun.crypto.provider.PBEKeyFactory$PBEWithHmacSHA512AndAES_256
   Service: AlgorithmParameters, Algorithm: PBEWithHmacSHA1AndAES_256, Class: com.sun.crypto.provider.PBES2Parameters$HmacSHA1AndAES_256
   Service: KeyGenerator, Algorithm: DESede, Class: com.sun.crypto.provider.DESedeKeyGenerator
    Aliases: TripleDES
 Provider: SunJGSS, Version: 11.0, Class: sun.security.jgss.SunProvider
  Description: Sun (Kerberos v5, SPNEGO)
  Services (2):
   Service: GssApiMechanism, Algorithm: 1.3.6.1.5.5.2, Class: sun.security.jgss.spnego.SpNegoMechFactory
   Service: GssApiMechanism, Algorithm: 1.2.840.113554.1.2.2, Class: sun.security.jgss.krb5.Krb5MechFactory
 Provider: SunSASL, Version: 11.0, Class: com.sun.security.sasl.Provider
  Description: Sun SASL provider(implements client mechanisms for: DIGEST-MD5, EXTERNAL, PLAIN, CRAM-MD5, NTLM; server mechanisms for: DIGEST-MD5, CRAM-MD5, NTLM)
  Services (8):
   Service: SaslClientFactory, Algorithm: PLAIN, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ServerFactoryImpl
   Service: SaslClientFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslClientFactory, Algorithm: EXTERNAL, Class: com.sun.security.sasl.ClientFactoryImpl
   Service: SaslServerFactory, Algorithm: NTLM, Class: com.sun.security.sasl.ntlm.FactoryImpl
   Service: SaslServerFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: DIGEST-MD5, Class: com.sun.security.sasl.digest.FactoryImpl
   Service: SaslClientFactory, Algorithm: CRAM-MD5, Class: com.sun.security.sasl.ClientFactoryImpl
 Provider: XMLDSig, Version: 11.0, Class: org.jcp.xml.dsig.internal.dom.XMLDSigRI
  Description: XMLDSig (DOM XMLSignatureFactory; DOM KeyInfoFactory; C14N 1.0, C14N 1.1, Exclusive C14N, Base64, Enveloped, XPath, XPath2, XSLT TransformServices)
  Services (13):
   Service: KeyInfoFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMKeyInfoFactory
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xpath-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXPathTransform
    Aliases: XPATH
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#base64, Class: org.jcp.xml.dsig.internal.dom.DOMBase64Transform
    Aliases: BASE64
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2000/09/xmldsig#enveloped-signature, Class: org.jcp.xml.dsig.internal.dom.DOMEnvelopedTransform
    Aliases: ENVELOPED
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/2001/REC-xml-c14n-20010315, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14NMethod
    Aliases: INCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: XMLSignatureFactory, Algorithm: DOM, Class: org.jcp.xml.dsig.internal.dom.DOMXMLSignatureFactory
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2002/06/xmldsig-filter2, Class: org.jcp.xml.dsig.internal.dom.DOMXPathFilter2Transform
    Aliases: XPATH2
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/TR/1999/REC-xslt-19991116, Class: org.jcp.xml.dsig.internal.dom.DOMXSLTTransform
    Aliases: XSLT
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2006/12/xml-c14n11, Class: org.jcp.xml.dsig.internal.dom.DOMCanonicalXMLC14N11Method
    Attributes:
      MechanismType: DOM
   Service: TransformService, Algorithm: http://www.w3.org/2001/10/xml-exc-c14n#WithComments, Class: org.jcp.xml.dsig.internal.dom.DOMExcC14NMethod
    Aliases: EXCLUSIVE_WITH_COMMENTS
    Attributes:
      MechanismType: DOM
 Provider: SunPCSC, Version: 11.0, Class: sun.security.smartcardio.SunPCSC
  Description: Sun PC/SC provider
  Services (1):
   Service: TerminalFactory, Algorithm: PC/SC, Class: sun.security.smartcardio.SunPCSC$Factory
 Provider: JdkLDAP, Version: 11.0, Class: sun.security.provider.certpath.ldap.JdkLDAP
  Description: JdkLDAP Provider (implements LDAP CertStore)
  Services (1):
   Service: CertStore, Algorithm: LDAP, Class: sun.security.provider.certpath.ldap.LDAPCertStore
    Attributes:
      LDAPSchema: RFC2587
 Provider: JdkSASL, Version: 11.0, Class: com.sun.security.sasl.gsskerb.JdkSASL
  Description: JDK SASL provider(implements client and server mechanisms for GSSAPI)
  Services (2):
   Service: SaslClientFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
   Service: SaslServerFactory, Algorithm: GSSAPI, Class: com.sun.security.sasl.gsskerb.FactoryImpl
 Provider: SunMSCAPI, Version: 11.0, Class: sun.security.mscapi.SunMSCAPI
  Description: Sun's Microsoft Crypto API provider
  Services (19):
   Service: Signature, Algorithm: RSASSA-PSS, Class: sun.security.mscapi.CSignature$PSS
    Attributes:
      SupportedKeyClasses: sun.security.mscapi.CKey
   Service: SecureRandom, Algorithm: Windows-PRNG, Class: sun.security.mscapi.PRNG
    Attributes:
      ThreadSafe: true
   Service: Signature, Algorithm: SHA224withECDSA, Class: sun.security.mscapi.CSignature$SHA224withECDSA
    Attributes:
   Service: Cipher, Algorithm: RSA/ECB/PKCS1Padding, Class: sun.security.mscapi.CRSACipher
    Attributes:
      SupportedPaddings: PKCS1PADDING
      SupportedModes: ECB
   Service: KeyPairGenerator, Algorithm: RSA, Class: sun.security.mscapi.CKeyPairGenerator$RSA
    Attributes:
      KeySize: 16384
   Service: KeyStore, Algorithm: Windows-ROOT, Class: sun.security.mscapi.CKeyStore$ROOT
   Service: Signature, Algorithm: SHA256withECDSA, Class: sun.security.mscapi.CSignature$SHA256withECDSA
    Attributes:
   Service: Signature, Algorithm: MD2withRSA, Class: sun.security.mscapi.CSignature$MD2withRSA
    Attributes:
   Service: Signature, Algorithm: SHA384withRSA, Class: sun.security.mscapi.CSignature$SHA384withRSA
    Attributes:
   Service: Signature, Algorithm: MD5withRSA, Class: sun.security.mscapi.CSignature$MD5withRSA
    Attributes:
   Service: Signature, Algorithm: SHA1withRSA, Class: sun.security.mscapi.CSignature$SHA1withRSA
    Attributes:
   Service: Signature, Algorithm: SHA512withECDSA, Class: sun.security.mscapi.CSignature$SHA512withECDSA
    Attributes:
   Service: Signature, Algorithm: SHA256withRSA, Class: sun.security.mscapi.CSignature$SHA256withRSA
    Attributes:
   Service: Signature, Algorithm: SHA1withECDSA, Class: sun.security.mscapi.CSignature$SHA1withECDSA
    Attributes:
   Service: Signature, Algorithm: NONEwithRSA, Class: sun.security.mscapi.CSignature$NONEwithRSA
    Attributes:
   Service: Signature, Algorithm: SHA384withECDSA, Class: sun.security.mscapi.CSignature$SHA384withECDSA
    Attributes:
   Service: Cipher, Algorithm: RSA, Class: sun.security.mscapi.CRSACipher
    Attributes:
      SupportedModes: ECB
   Service: Signature, Algorithm: SHA512withRSA, Class: sun.security.mscapi.CSignature$SHA512withRSA
    Attributes:
   Service: KeyStore, Algorithm: Windows-MY, Class: sun.security.mscapi.CKeyStore$MY
 Provider: SunPKCS11, Version: 11.0, Class: sun.security.pkcs11.SunPKCS11
  Description: Unconfigured and unusable PKCS11 provider
  Services (0):
 Provider: BC, Version: 1.6501, Class: org.bouncycastle.jce.provider.BouncyCastleProvider
  Description: BouncyCastle Security Provider v1.65.01
  Services (1279):
   Service: Cipher, Algorithm: PBEWITHMD5AND128BITAES-CBC-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithAESCBC
   Service: MessageDigest, Algorithm: SHAKE256-512, Class: org.bouncycastle.jcajce.provider.digest.SHA3$DigestShake256_512
   Service: Signature, Algorithm: MD2WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$MD2
    Aliases: MD2WithRSAEncryption
   Service: KeyGenerator, Algorithm: CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen
    Aliases: 1.2.392.200011.61.1.1.1.4
   Service: Signature, Algorithm: SHA1WITHDETDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA
   Service: KeyAgreement, Algorithm: DHUWITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA384CKDF
   Service: Cipher, Algorithm: OID.2.5.8.1.1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding
   Service: Mac, Algorithm: SM4-CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$CMAC
    Aliases: SM4CMAC
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.45, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: AlgorithmParameters, Algorithm: SHACAL-2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$AlgParams
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.44, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.43, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.42, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: Mac, Algorithm: POLY1305-SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$Poly1305
    Aliases: POLY1305SEED
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.41, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.40, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: MessageDigest, Algorithm: KECCAK-224, Class: org.bouncycastle.jcajce.provider.digest.Keccak$Digest224
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.14, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: Cipher, Algorithm: 1.2.410.200004.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$CBC
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.13, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.12, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.11, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: Skein-MAC-512-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_512_384
    Aliases: Skein-MAC512/384
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.39, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.38, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.37, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA256KDF
   Service: SecretKeyFactory, Algorithm: PBEWITHSHA1ANDRC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithSHA1KeyFactory
    Aliases: OID.1.2.840.113549.1.5.11
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.36, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: Shacal2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$KeyGen
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.35, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.34, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.24, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CFB
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.23, Class: org.bouncycastle.jcajce.provider.symmetric.AES$OFB
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.22, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CBC
   Service: KeyAgreement, Algorithm: ECDHWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA1KDFAndSharedInfo
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.21, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
   Service: Signature, Algorithm: SHA1WITHPLAIN-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA
    Aliases: SHA1withPLAIN-ECDSA
   Service: Signature, Algorithm: RIPEMD160WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$RIPEMD160WithRSAEncryption
    Aliases: RIPEMD160withRSA/X9.31
   Service: Cipher, Algorithm: PBEWITHMD5ANDRC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithMD5AndRC2
    Aliases: PBEWITHMD5ANDRC2-CBC
   Service: Cipher, Algorithm: CHACHA7539, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$Base7539
    Aliases: CHACHA20
   Service: KeyGenerator, Algorithm: HMACSkein-256-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_256_224
    Aliases: HMAC-Skein-256-224
   Service: Mac, Algorithm: Threefish-1024CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$CMAC_1024
   Service: KeyGenerator, Algorithm: HMACSkein-1024-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_1024_512
    Aliases: HMAC-Skein-1024-512
   Service: KeyFactory, Algorithm: ECMQV, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyFactorySpi$ECMQV
    Aliases: 1.3.133.16.840.63.0.16
   Service: Signature, Algorithm: DSTU4145, Class: org.bouncycastle.jcajce.provider.asymmetric.dstu.SignatureSpi
    Aliases: 1.2.804.2.1.1.1.1.3.1.1.1.1
   Service: Cipher, Algorithm: ECIESWITHDESEDE-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.IESCipher$ECIESwithDESedeCBC
   Service: Mac, Algorithm: HMACSkein-1024-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_1024_512
   Service: MessageDigest, Algorithm: OID.1.0.10118.3.0.55, Class: org.bouncycastle.jcajce.provider.digest.Whirlpool$Digest
   Service: Cipher, Algorithm: DSTU7624-128, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB_128
   Service: KeyAgreement, Algorithm: MQVWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA384KDF
   Service: KeyAgreement, Algorithm: X25519WITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519withSHA256CKDF
   Service: Signature, Algorithm: SHA384WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA384
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.4, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CFB
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.3, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$OFB
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.2, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CBC
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.1, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND128BITRC2-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithSHAAnd128BitKeyFactory
    Aliases: PBEWITHSHA1AND128BITRC2-CBC
   Service: AlgorithmParameterGenerator, Algorithm: Shacal2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$AlgParamGen
   Service: MessageDigest, Algorithm: SHA3-512, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest512
   Service: KeyGenerator, Algorithm: OID.1.2.410.200004.7.1.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
   Service: KeyGenerator, Algorithm: POLY1305, Class: org.bouncycastle.jcajce.provider.symmetric.Poly1305$KeyGen
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.14, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.13, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyFactory, Algorithm: RSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.KeyFactorySpi
    Aliases: 1.2.840.113549.1.1.7
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.12, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.11, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyAgreement, Algorithm: DHWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithSHA384KDF
   Service: KeyGenerator, Algorithm: Threefish-512, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$KeyGen_512
   Service: Mac, Algorithm: Skein-MAC-512-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_512_384
   Service: KeyAgreement, Algorithm: 1.3.133.16.840.63.0.16, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA1KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: SEED-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
    Aliases: SEEDGMAC
   Service: Signature, Algorithm: ED448, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.SignatureSpi$Ed448
    Aliases: 1.3.101.113
   Service: AlgorithmParameters, Algorithm: CCM, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AlgParamsCCM
    Aliases: OID.2.16.840.1.101.3.4.1.47
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA384CKDF
   Service: Signature, Algorithm: SHA3-224WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSASha3_224
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.6.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$OFB512
   Service: Mac, Algorithm: HMACGOST3411-2012-256, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$HashMac2012_256
    Aliases: HMAC/GOST3411-2012-256
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.6.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$OFB256
   Service: KeyGenerator, Algorithm: HMACTIGER, Class: org.bouncycastle.jcajce.provider.digest.Tiger$KeyGenerator
    Aliases: HMAC-TIGER
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.6.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$OFB128
   Service: Cipher, Algorithm: PBEWITHSHA1ANDDES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$PBEWithSHA1
    Aliases: PBEWITHSHA1ANDDES-CBC
   Service: Cipher, Algorithm: AESRFC3211WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.AES$RFC3211Wrap
   Service: Mac, Algorithm: HMACRIPEMD256, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD256$HashMac
    Aliases: HMAC/RIPEMD256
   Service: Cipher, Algorithm: OID.1.2.392.200011.61.1.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$CBC
   Service: Cipher, Algorithm: OID.1.2.392.200011.61.1.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$CBC
   Service: Cipher, Algorithm: OID.1.2.392.200011.61.1.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$CBC
   Service: Mac, Algorithm: Threefish-256CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$CMAC_256
   Service: AlgorithmParameterGenerator, Algorithm: AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AlgParamGen
   Service: MessageDigest, Algorithm: RIPEMD160, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD160$Digest
    Aliases: 1.3.36.3.2.1
   Service: Mac, Algorithm: CAST6-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$GMAC
    Aliases: CAST6GMAC
   Service: Cipher, Algorithm: IESWITHAES-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IESwithAESCBC
   Service: Cipher, Algorithm: PBEWITHMD5AND192BITAES-CBC-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithAESCBC
   Service: KeyFactory, Algorithm: ECGOST3410-2012, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.KeyFactorySpi
    Aliases: GOST-3410-2012
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND2-KEYTRIPLEDES-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$PBEWithSHAAndDES2KeyFactory
    Aliases: 1.2.840.113549.1.12.1.4
   Service: Cipher, Algorithm: PBEWITHSHAAND128BITRC2-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithSHAAnd128BitRC2
   Service: Cipher, Algorithm: 1.2.643.2.2.13.1, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$CryptoProWrap
   Service: Cipher, Algorithm: 1.2.643.2.2.13.0, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$GostWrap
   Service: Cipher, Algorithm: RC5-64, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$ECB64
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA3-512, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA3_512
   Service: Signature, Algorithm: MD5WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$MD5WithRSAEncryption
    Aliases: MD5WithRSA/ISO9796-2
   Service: Signature, Algorithm: SHA512(224)WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA512_224WithRSAEncryption
    Aliases: SHA512(224)withRSA/ISO9796-2
   Service: Mac, Algorithm: NOEKEON-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$GMAC
    Aliases: NOEKEONGMAC
   Service: X509Store, Algorithm: CRL/COLLECTION, Class: org.bouncycastle.jce.provider.X509StoreCRLCollection
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA224KDF
   Service: AlgorithmParameterGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen512
   Service: X509Store, Algorithm: CERTIFICATEPAIR/COLLECTION, Class: org.bouncycastle.jce.provider.X509StoreCertPairCollection
   Service: AlgorithmParameterGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen256
   Service: AlgorithmParameterGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen128
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.4, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CFB
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.3, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$OFB
   Service: KeyAgreement, Algorithm: 1.3.132.1.15.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA512KDFAndSharedInfo
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.2, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CBC
   Service: KeyAgreement, Algorithm: 1.3.132.1.15.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA384KDFAndSharedInfo
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.1, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: KeyAgreement, Algorithm: 1.3.132.1.15.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA256KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.15.0, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA224KDFAndSharedInfo
   Service: Cipher, Algorithm: ZUC-128, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$Zuc128
   Service: KeyGenerator, Algorithm: RIJNDAEL, Class: org.bouncycastle.jcajce.provider.symmetric.Rijndael$KeyGen
   Service: Mac, Algorithm: DSTU7624-256GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$GMAC256
    Aliases: 1.2.804.2.1.1.1.1.1.3.7.2
   Service: Cipher, Algorithm: ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
    Aliases: OID.1.2.410.200046.1.1.14
   Service: KeyAgreement, Algorithm: ECGOST3410-2012-256, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.KeyAgreementSpi$ECVKO256
    Aliases: 1.2.643.7.1.1.1.1
   Service: MessageDigest, Algorithm: KECCAK-512, Class: org.bouncycastle.jcajce.provider.digest.Keccak$Digest512
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA512CKDF
   Service: AlgorithmParameterGenerator, Algorithm: ARIACCM, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$AlgParamGen
    Aliases: 1.2.410.200046.1.1.37
   Service: SecretKeyFactory, Algorithm: CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyFactory
   Service: Cipher, Algorithm: PBEWITHSHAAND192BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA1AESCBC192
    Aliases: 1.3.6.1.4.1.22554.1.1.2.1.22
   Service: Cipher, Algorithm: ECIESwithDESEDE-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.IESCipher$ECIESwithDESedeCBC
   Service: KeyGenerator, Algorithm: SALSA20, Class: org.bouncycastle.jcajce.provider.symmetric.Salsa20$KeyGen
   Service: MessageDigest, Algorithm: RIPEMD128, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD128$Digest
    Aliases: 1.3.36.3.2.2
   Service: Cipher, Algorithm: SM2WITHRIPEMD160, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withRMD
    Aliases: 1.2.156.10197.1.301.3.2.7
   Service: MessageDigest, Algorithm: 2.16.840.1.101.3.4.2.10, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest512
   Service: KeyAgreement, Algorithm: MQVWITHSHA1CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA1CKDF
   Service: KeyGenerator, Algorithm: SM4-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$KeyGen
    Aliases: SM4GMAC
   Service: Signature, Algorithm: SHA3-512WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsaSha3_512
    Aliases: 2.16.840.1.101.3.4.3.8
   Service: Mac, Algorithm: HMACGOST3411, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$HashMac
   Service: KeyStore, Algorithm: BCFKS-DEF, Class: org.bouncycastle.jcajce.provider.keystore.bcfks.BcFKSKeyStoreSpi$Def
   Service: KeyPairGenerator, Algorithm: ECDH, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$ECDH
   Service: KeyGenerator, Algorithm: Grainv1, Class: org.bouncycastle.jcajce.provider.symmetric.Grainv1$KeyGen
   Service: Cipher, Algorithm: AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
    Attributes:
      SupportedKeyClasses: javax.crypto.SecretKey
   Service: Cipher, Algorithm: PBEWITHMD2ANDDES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$PBEWithMD2
    Aliases: PBEWITHMD2ANDDES-CBC
   Service: MessageDigest, Algorithm: BLAKE2B-384, Class: org.bouncycastle.jcajce.provider.digest.Blake2b$Blake2b384
    Aliases: 1.3.6.1.4.1.1722.12.2.1.12
   Service: SecretKeyFactory, Algorithm: OID.1.3.14.3.2.17, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$KeyFactory
   Service: SecretKeyFactory, Algorithm: 2.16.840.1.101.3.4.1, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyFactory
   Service: KeyAgreement, Algorithm: ECDHWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA512KDFAndSharedInfo
   Service: Cipher, Algorithm: SM2WITHBLAKE2S, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withBlake2s
    Aliases: 1.2.156.10197.1.301.3.2.10
   Service: KeyGenerator, Algorithm: Threefish-1024, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$KeyGen_1024
   Service: AlgorithmParameterGenerator, Algorithm: 1.2.840.113549.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$AlgParamGen
   Service: Cipher, Algorithm: DESRFC3211WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.DES$RFC3211
   Service: AlgorithmParameterGenerator, Algorithm: DES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$AlgParamGen
    Aliases: 1.3.14.3.2.7
   Service: Signature, Algorithm: SHA512WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsa512
    Aliases: SHA512WithDSA
   Service: KeyFactory, Algorithm: X25519, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyFactorySpi$X25519
   Service: Cipher, Algorithm: SM2WITHBLAKE2B, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withBlake2b
    Aliases: 1.2.156.10197.1.301.3.2.9
   Service: Cipher, Algorithm: BROKENPBEWITHSHA1ANDDES, Class: org.bouncycastle.jce.provider.BrokenJCEBlockCipher$BrokePBEWithSHA1AndDES
   Service: Mac, Algorithm: OLDHMACSHA512, Class: org.bouncycastle.jcajce.provider.digest.SHA512$OldSHA512
   Service: MessageDigest, Algorithm: Skein-512-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_512_256
   Service: Signature, Algorithm: SHA1WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA1
    Aliases: SHA1WithRSAEncryption
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.7.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.7.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.7.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Mac, Algorithm: POLY1305-RC6, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$Poly1305
    Aliases: POLY1305RC6
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA512CKDF
   Service: KeyFactory, Algorithm: EDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyFactorySpi$EdDSA
   Service: Mac, Algorithm: HMACKECCAK384, Class: org.bouncycastle.jcajce.provider.digest.Keccak$HashMac384
    Aliases: HMAC/KECCAK384
   Service: KeyAgreement, Algorithm: X448WITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448withSHA384CKDF
   Service: Cipher, Algorithm: ARIAWRAPPAD, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$WrapPad
    Aliases: OID.1.2.410.200046.1.1.45
   Service: Cipher, Algorithm: SHACAL-2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$ECB
   Service: AlgorithmParameters, Algorithm: 1.2.840.113549.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$AlgParams
   Service: KeyGenerator, Algorithm: Twofish-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$KeyGen
    Aliases: TwofishGMAC
   Service: KeyGenerator, Algorithm: HMACSkein-512-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_512_160
    Aliases: HMAC-Skein-512-160
   Service: Cipher, Algorithm: Threefish-256, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$ECB_256
   Service: MessageDigest, Algorithm: WHIRLPOOL, Class: org.bouncycastle.jcajce.provider.digest.Whirlpool$Digest
   Service: MessageDigest, Algorithm: OID.2.16.840.1.101.3.4.2.10, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest512
   Service: AlgorithmParameters, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: AlgorithmParameters, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: AlgorithmParameters, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND128BITRC4, Class: org.bouncycastle.jcajce.provider.symmetric.ARC4$PBEWithSHAAnd128BitKeyFactory
   Service: Cipher, Algorithm: ELGAMAL/PKCS1, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.CipherSpi$PKCS1v1_5Padding
    Aliases: ELGAMAL/NONE/PKCS1PADDING
   Service: Mac, Algorithm: POLY1305, Class: org.bouncycastle.jcajce.provider.symmetric.Poly1305$Mac
   Service: Mac, Algorithm: HMACSHA3-384, Class: org.bouncycastle.jcajce.provider.digest.SHA3$HashMac384
    Aliases: HMAC-SHA3-384
   Service: AlgorithmParameterGenerator, Algorithm: ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$AlgParamGen
   Service: KeyStore, Algorithm: PKCS12-DEF-3DES-3DES, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$DefPKCS12KeyStore3DES
   Service: AlgorithmParameters, Algorithm: IES, Class: org.bouncycastle.jcajce.provider.asymmetric.ies.AlgorithmParametersSpi
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.2.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.2.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.2.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Cipher, Algorithm: ARC4, Class: org.bouncycastle.jcajce.provider.symmetric.ARC4$Base
    Aliases: RC4
   Service: SecretKeyFactory, Algorithm: PBEWITHMD5ANDDES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$PBEWithMD5KeyFactory
   Service: Mac, Algorithm: HMACSkein-512-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_512_256
    Aliases: HMAC-Skein-512-256
   Service: CertStore, Algorithm: Collection, Class: org.bouncycastle.jce.provider.CertStoreCollectionSpi
   Service: Mac, Algorithm: DESEDEMAC64WITHISO7816-4PADDING, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$DESede64with7816d4
    Aliases: DESEDEISO9797ALG1WITHISO7816-4PADDING
   Service: KeyGenerator, Algorithm: 1.2.410.200004.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
   Service: AlgorithmParameterGenerator, Algorithm: GOST28147, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$AlgParamGen
    Aliases: GOST-28147
   Service: AlgorithmParameters, Algorithm: RC5-64, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$AlgParams
   Service: Signature, Algorithm: SHA1WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA1WithRSAEncryption
    Aliases: SHA1WithRSA/ISO9796-2
   Service: Mac, Algorithm: HMACGOST3411-2012-512, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$HashMac2012_512
    Aliases: HMAC/GOST3411-2012-512
   Service: MessageDigest, Algorithm: Skein-512-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_512_224
   Service: Cipher, Algorithm: 1.2.392.200011.61.1.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$CBC
   Service: Cipher, Algorithm: Shacal2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$ECB
   Service: Cipher, Algorithm: 1.2.392.200011.61.1.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$CBC
   Service: Cipher, Algorithm: 1.2.392.200011.61.1.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$CBC
   Service: Signature, Algorithm: SHA3-384WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSASha3_384
   Service: MessageDigest, Algorithm: BLAKE2S-256, Class: org.bouncycastle.jcajce.provider.digest.Blake2s$Blake2s256
    Aliases: 1.3.6.1.4.1.1722.12.2.2.8
   Service: MessageDigest, Algorithm: Skein-1024-1024, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_1024_1024
   Service: KeyAgreement, Algorithm: ECCDH, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHC
    Attributes:
      SupportedKeyFormats: PKCS#8|X.509
   Service: Cipher, Algorithm: ARIAWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$Wrap
    Aliases: OID.1.2.410.200046.1.1.42
   Service: KeyGenerator, Algorithm: XTEA, Class: org.bouncycastle.jcajce.provider.symmetric.XTEA$KeyGen
   Service: KeyGenerator, Algorithm: HMACSkein-512-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_512_128
    Aliases: HMAC-Skein-512-128
   Service: Cipher, Algorithm: TEA, Class: org.bouncycastle.jcajce.provider.symmetric.TEA$ECB
   Service: Cipher, Algorithm: DES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$ECB
   Service: AlgorithmParameters, Algorithm: CHACHA7539, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$AlgParams
    Aliases: CHACHA20
   Service: KeyPairGenerator, Algorithm: XDH, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$XDH
   Service: Signature, Algorithm: SHA512WITHDETDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA512
   Service: Cipher, Algorithm: SM2WITHWHIRLPOOL, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withWhirlpool
    Aliases: 1.2.156.10197.1.301.3.2.8
   Service: Cipher, Algorithm: ECIESwithAES-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.IESCipher$ECIESwithAESCBC
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.14, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$OFB
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.13, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CFB
   Service: Signature, Algorithm: MD5WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$MD5
    Aliases: MD5WithRSAEncryption
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.12, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CBC
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.11, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
   Service: KeyAgreement, Algorithm: ECDH, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DH
    Attributes:
      SupportedKeyClasses: java.security.interfaces.ECPublicKey|java.security.interfaces.ECPrivateKey
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA1KDF
   Service: Mac, Algorithm: HMACMD5, Class: org.bouncycastle.jcajce.provider.digest.MD5$HashMac
    Aliases: HMAC/MD5
   Service: Mac, Algorithm: HMACMD4, Class: org.bouncycastle.jcajce.provider.digest.MD4$HashMac
    Aliases: HMAC/MD4
   Service: Mac, Algorithm: HMACSkein-512-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_512_224
    Aliases: HMAC-Skein-512-224
   Service: SecretKeyFactory, Algorithm: 1.3.14.3.2.17, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$KeyFactory
   Service: Mac, Algorithm: HMACMD2, Class: org.bouncycastle.jcajce.provider.digest.MD2$HashMac
    Aliases: HMAC/MD2
   Service: KeyFactory, Algorithm: ELGAMAL, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.KeyFactorySpi
    Aliases: 1.3.14.7.2.1.1
   Service: Signature, Algorithm: SHA384WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA384WithRSAEncryption
    Aliases: SHA384WithRSA/X9.31
   Service: KeyAgreement, Algorithm: ECGOST3410-2012-512, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.KeyAgreementSpi$ECVKO512
    Aliases: ECGOST3410-2012-512
   Service: KeyGenerator, Algorithm: HMACRIPEMD320, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD320$KeyGenerator
    Aliases: HMAC-RIPEMD320
   Service: KeyGenerator, Algorithm: SM4, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$KeyGen
   Service: X509Store, Algorithm: CERTIFICATEPAIR/LDAP, Class: org.bouncycastle.jce.provider.X509StoreLDAPCertPairs
   Service: MessageDigest, Algorithm: BLAKE2S-224, Class: org.bouncycastle.jcajce.provider.digest.Blake2s$Blake2s224
    Aliases: 1.3.6.1.4.1.1722.12.2.2.7
   Service: Cipher, Algorithm: 1.2.840.113533.7.66.10, Class: org.bouncycastle.jcajce.provider.symmetric.CAST5$CBC
   Service: KeyAgreement, Algorithm: OID.1.3.133.16.840.63.0.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA1KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: OID.1.2.840.113549.1.9.16.3.5, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithRFC2631KDF
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND192BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHAAnd192BitAESBC
   Service: KeyAgreement, Algorithm: OID.1.3.133.16.840.63.0.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA1KDFAndSharedInfo
   Service: Mac, Algorithm: DESEDEMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$CBCMAC
    Aliases: DESEDE
   Service: AlgorithmParameters, Algorithm: ZUC-128, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$AlgParams
   Service: SecretKeyFactory, Algorithm: OID.1.3.6.1.4.1.11591.4.11, Class: org.bouncycastle.jcajce.provider.symmetric.SCRYPT$ScryptWithUTF8
   Service: SecretKeyFactory, Algorithm: PBEWITHSHA256AND128BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA256And128BitAESBC
    Aliases: PBEWITHSHA-256AND128BITAES-CBC-BC
   Service: AlgorithmParameterGenerator, Algorithm: GCM, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AlgParamGenGCM
    Aliases: OID.2.16.840.1.101.3.4.1.46
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.2.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CTR512
   Service: KeyGenerator, Algorithm: AESWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen
    Aliases: OID.2.16.840.1.101.3.4.1.45
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.2.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CTR256
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.2.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CTR128
   Service: Cipher, Algorithm: IESwithAES-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IESwithAESCBC
   Service: Mac, Algorithm: DESEDEMAC64, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$DESede64
    Aliases: DESEDE64
   Service: Mac, Algorithm: SM4-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$GMAC
    Aliases: SM4GMAC
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyAgreement, Algorithm: MQVWITHSHA224CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA224CKDF
   Service: Cipher, Algorithm: ARIACCM, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CCM
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: KeyGenerator, Algorithm: SIPHASH, Class: org.bouncycastle.jcajce.provider.symmetric.SipHash$KeyGen
    Aliases: SIPHASH-4-8
   Service: KeyAgreement, Algorithm: X25519WITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519withSHA384CKDF
   Service: KeyStore, Algorithm: BKS, Class: org.bouncycastle.jcajce.provider.keystore.bc.BcKeyStoreSpi$Std
   Service: MessageDigest, Algorithm: SHA-1, Class: org.bouncycastle.jcajce.provider.digest.SHA1$Digest
    Aliases: 1.3.14.3.2.26
   Service: Mac, Algorithm: HMACSHA1, Class: org.bouncycastle.jcajce.provider.digest.SHA1$HashMac
    Aliases: 1.3.6.1.5.5.8.1.2
   Service: KeyGenerator, Algorithm: Tnepres, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$TKeyGen
   Service: AlgorithmParameters, Algorithm: Threefish-1024, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$AlgParams_1024
   Service: MessageDigest, Algorithm: SHA-384, Class: org.bouncycastle.jcajce.provider.digest.SHA384$Digest
    Aliases: SHA384
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.9, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.8, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.7, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.6, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyAgreement, Algorithm: MQVWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA256KDF
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: MessageDigest, Algorithm: 2.16.840.1.101.3.4.2.9, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest384
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: MessageDigest, Algorithm: 2.16.840.1.101.3.4.2.8, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest256
   Service: Cipher, Algorithm: PBEWITHSHA256AND256BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA256AESCBC256
    Aliases: PBEWITHSHA-256AND256BITAES-BC
   Service: MessageDigest, Algorithm: 2.16.840.1.101.3.4.2.7, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest224
   Service: Signature, Algorithm: SHA3-256WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSASha3_256
   Service: Mac, Algorithm: GOST28147MAC, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$Mac
    Aliases: GOST28147
   Service: KeyGenerator, Algorithm: HMACDSTU7564-384, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$KeyGenerator384
    Aliases: HMAC-DSTU7564-384
   Service: MessageDigest, Algorithm: Skein-512-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_512_512
   Service: KeyGenerator, Algorithm: HMACMD5, Class: org.bouncycastle.jcajce.provider.digest.MD5$KeyGenerator
    Aliases: HMAC/MD5
   Service: KeyGenerator, Algorithm: HMACMD4, Class: org.bouncycastle.jcajce.provider.digest.MD4$KeyGenerator
    Aliases: HMAC/MD4
   Service: KeyGenerator, Algorithm: HMACMD2, Class: org.bouncycastle.jcajce.provider.digest.MD2$KeyGenerator
    Aliases: HMAC/MD2
   Service: Cipher, Algorithm: SALSA20, Class: org.bouncycastle.jcajce.provider.symmetric.Salsa20$Base
   Service: KeyAgreement, Algorithm: DHWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithSHA256KDF
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.9, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$OFB
   Service: Cipher, Algorithm: NOEKEON, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$ECB
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.8, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CFB
   Service: AlgorithmParameterGenerator, Algorithm: SHACAL-2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$AlgParamGen
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.7, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CBC
   Service: KeyGenerator, Algorithm: POLY1305-SERPENT, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$Poly1305KeyGen
    Aliases: POLY1305SERPENT
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.6, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
   Service: KeyAgreement, Algorithm: OID.0.4.0.127.0.7.1.1.5.1.1.6, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithRIPEMD160KDF
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$OFB
   Service: KeyAgreement, Algorithm: OID.0.4.0.127.0.7.1.1.5.1.1.5, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA512KDF
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CFB
   Service: KeyAgreement, Algorithm: OID.0.4.0.127.0.7.1.1.5.1.1.4, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA384KDF
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CBC
   Service: KeyAgreement, Algorithm: OID.0.4.0.127.0.7.1.1.5.1.1.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA256KDF
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
   Service: KeyAgreement, Algorithm: OID.0.4.0.127.0.7.1.1.5.1.1.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA224KDF
   Service: Cipher, Algorithm: OID.1.2.840.113533.7.66.10, Class: org.bouncycastle.jcajce.provider.symmetric.CAST5$CBC
   Service: KeyAgreement, Algorithm: OID.0.4.0.127.0.7.1.1.5.1.1.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA1KDF
   Service: KeyGenerator, Algorithm: DESEDEWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$KeyGenerator
    Aliases: DESEDERFC3217WRAP
   Service: Mac, Algorithm: CAMELLIA-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$GMAC
    Aliases: CAMELLIAGMAC
   Service: Cipher, Algorithm: Threefish-512, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$ECB_512
   Service: Mac, Algorithm: SEED-CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$CMAC
    Aliases: SEEDCMAC
   Service: KeyGenerator, Algorithm: OID.1.2.410.200004.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
   Service: KeyAgreement, Algorithm: DHUWITHSHA224CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA224CKDF
   Service: Signature, Algorithm: SHA256WITHECNR, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecNR256
   Service: Signature, Algorithm: RIPEMD160WITHPLAIN-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecPlainDSARP160
    Aliases: RIPEMD160/PLAIN-ECDSA
   Service: Signature, Algorithm: RMD256WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$RIPEMD256
    Aliases: RMD256WithRSA
   Service: Cipher, Algorithm: Grainv1, Class: org.bouncycastle.jcajce.provider.symmetric.Grainv1$Base
   Service: Signature, Algorithm: SHA3-224WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsaSha3_224
    Aliases: SHA3-224WithDSA
   Service: Signature, Algorithm: SHA1WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSA
    Aliases: SHA1WITHDETECDSA
   Service: Signature, Algorithm: SHA384WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA384withRSA
    Aliases: SHA384withRSA/PSS
   Service: Cipher, Algorithm: PBEWITHSHAAND2-KEYTRIPLEDES-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$PBEWithSHAAndDES2Key
   Service: Mac, Algorithm: SIPHASH-2-4, Class: org.bouncycastle.jcajce.provider.symmetric.SipHash$Mac24
    Aliases: SIPHASH
   Service: Mac, Algorithm: HMACSkein-512-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_512_512
    Aliases: HMAC/Skein-512-512
   Service: KeyAgreement, Algorithm: ECDHWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA224KDFAndSharedInfo
   Service: Signature, Algorithm: WHIRLPOOLWITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$WhirlpoolWithRSAEncryption
    Aliases: WHIRLPOOLWithRSA/X9.31
   Service: KeyPairGenerator, Algorithm: DSTU4145, Class: org.bouncycastle.jcajce.provider.asymmetric.dstu.KeyPairGeneratorSpi
   Service: KeyAgreement, Algorithm: DHUWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA512KDF
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA256CKDF
   Service: Cipher, Algorithm: GCM, Class: org.bouncycastle.jcajce.provider.symmetric.AES$GCM
    Attributes:
      SupportedKeyFormats: RAW
   Service: Signature, Algorithm: SHA1WITHECNR, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecNR
   Service: Cipher, Algorithm: DSTU7624-512KW, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$Wrap512
    Aliases: 1.2.804.2.1.1.1.1.1.3.10.3
   Service: KeyGenerator, Algorithm: DESEDE, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$KeyGenerator
    Aliases: TDEA
   Service: MessageDigest, Algorithm: GOST3411, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$Digest
    Aliases: 1.2.643.2.2.9
   Service: KeyGenerator, Algorithm: CHACHA7539, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$KeyGen7539
    Aliases: CHACHA20
   Service: Signature, Algorithm: SHA224WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsa224
    Aliases: SHA224/DSA
   Service: MessageDigest, Algorithm: Skein-1024-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_1024_512
   Service: Mac, Algorithm: DESMAC64, Class: org.bouncycastle.jcajce.provider.symmetric.DES$DES64
    Aliases: DES64
   Service: Cipher, Algorithm: PBEWITHSHAAND128BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA1AESCBC128
    Aliases: PBEWITHSHA1AND128BITAES-BC
   Service: KeyGenerator, Algorithm: POLY1305-AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$Poly1305KeyGen
    Aliases: POLY1305AES
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CBC512
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CBC256
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CBC128
   Service: KeyPairGenerator, Algorithm: ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$ECDSA
    Aliases: ECDSAwithSHA1
   Service: Signature, Algorithm: SHA1WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA1withRSA
    Aliases: SHA1WithRSA/PSS
   Service: Signature, Algorithm: RIPEMD128WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$RIPEMD128
    Aliases: RIPEMD128WITHRSAENCRYPTION
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.8.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.8.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.8.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Cipher, Algorithm: CHACHA, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$Base
   Service: Cipher, Algorithm: GOST3412-2015/CTR, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$CTR
   Service: AlgorithmParameters, Algorithm: Shacal2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$AlgParams
   Service: KeyGenerator, Algorithm: POLY1305-CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$Poly1305KeyGen
    Aliases: POLY1305CAMELLIA
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND3-KEYTRIPLEDES-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$PBEWithSHAAndDES3KeyFactory
    Aliases: 1.2.840.113549.1.12.1.3
   Service: KeyPairGenerator, Algorithm: DSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.KeyPairGeneratorSpi
    Aliases: DSAWITHSHA1
   Service: Signature, Algorithm: SHA512WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA512WithRSAEncryption
    Aliases: SHA512WithRSA/X9.31
   Service: Cipher, Algorithm: RIJNDAEL, Class: org.bouncycastle.jcajce.provider.symmetric.Rijndael$ECB
   Service: Mac, Algorithm: Twofish-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$GMAC
   Service: Signature, Algorithm: SHA1WITHCVC-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA
    Aliases: 0.4.0.127.0.7.2.2.2.2.1
   Service: SecretKeyFactory, Algorithm: DESEDE, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$KeyFactory
    Aliases: TDEA
   Service: AlgorithmParameterGenerator, Algorithm: ElGamal, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.AlgorithmParameterGeneratorSpi
   Service: Signature, Algorithm: SHA224WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA224WithRSAEncryption
    Aliases: SHA224WithRSA/X9.31
   Service: Signature, Algorithm: SHA224WITHECNR, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecNR224
   Service: Cipher, Algorithm: OID.1.3.14.3.2.7, Class: org.bouncycastle.jcajce.provider.symmetric.DES$CBC
   Service: KeyPairGenerator, Algorithm: 1.3.101.113, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$Ed448
   Service: KeyPairGenerator, Algorithm: 1.3.101.112, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$Ed25519
   Service: KeyPairGenerator, Algorithm: 1.3.101.111, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$X448
   Service: KeyPairGenerator, Algorithm: 1.3.101.110, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$X25519
   Service: Signature, Algorithm: RSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$noneRSA
   Service: MessageDigest, Algorithm: Skein-256-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_256_256
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA256CKDF
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACGOST3411, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withGOST3411
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA512KDFAndSharedInfo
   Service: Cipher, Algorithm: DHIESWITHDESEDE-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IESwithDESedeCBC
   Service: KeyGenerator, Algorithm: GOST3412-2015, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$KeyGen
   Service: KeyStore, Algorithm: PKCS12-DEF-3DES-40RC2, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$DefPKCS12KeyStore
   Service: AlgorithmParameters, Algorithm: XTEA, Class: org.bouncycastle.jcajce.provider.symmetric.XTEA$AlgParams
   Service: KeyGenerator, Algorithm: HMACSkein-256-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_256_160
    Aliases: HMAC-Skein-256-160
   Service: Mac, Algorithm: POLY1305-CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$Poly1305
   Service: MessageDigest, Algorithm: MD5, Class: org.bouncycastle.jcajce.provider.digest.MD5$Digest
    Aliases: 1.2.840.113549.2.5
   Service: MessageDigest, Algorithm: MD4, Class: org.bouncycastle.jcajce.provider.digest.MD4$Digest
    Aliases: 1.2.840.113549.2.4
   Service: Signature, Algorithm: SHA256WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA256WithRSAEncryption
    Aliases: SHA256WithRSA/ISO9796-2
   Service: MessageDigest, Algorithm: MD2, Class: org.bouncycastle.jcajce.provider.digest.MD2$Digest
    Aliases: 1.2.840.113549.2.2
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.2.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CTR512
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.2.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CTR256
   Service: KeyGenerator, Algorithm: ZUC-256, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$KeyGen256
    Aliases: ZUC-256-128
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.2.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CTR128
   Service: AlgorithmParameters, Algorithm: ECGOST3410-2012, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.AlgorithmParametersSpi
   Service: MessageDigest, Algorithm: DSTU7564-384, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest384
   Service: Cipher, Algorithm: CAMELLIARFC3211WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$RFC3211Wrap
   Service: Mac, Algorithm: POLY1305-CAST6, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$Poly1305
    Aliases: POLY1305CAST6
   Service: AlgorithmParameterGenerator, Algorithm: CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$AlgParamGen
   Service: AlgorithmParameters, Algorithm: EC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.AlgorithmParametersSpi
    Aliases: 1.3.132.1.14.0
   Service: KeyFactory, Algorithm: XDH, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyFactorySpi$XDH
    Aliases: 1.3.101.110
   Service: Signature, Algorithm: SHA512WITHECNR, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecNR512
   Service: SecretKeyFactory, Algorithm: TLS12WITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.symmetric.TLSKDF$TLS12withSHA384
   Service: Mac, Algorithm: HMACSkein-256-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_256_256
    Aliases: HMAC-Skein-256-256
   Service: Cipher, Algorithm: HC128, Class: org.bouncycastle.jcajce.provider.symmetric.HC128$Base
   Service: AlgorithmParameters, Algorithm: PKCS12PBE, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPKCS12$AlgParams
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA384KDF
   Service: AlgorithmParameters, Algorithm: DH, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.AlgorithmParametersSpi
    Aliases: 1.2.840.10046.2.1
   Service: Mac, Algorithm: SIPHASH128-2-4, Class: org.bouncycastle.jcajce.provider.symmetric.SipHash128$Mac24
    Aliases: SIPHASH128
   Service: KeyGenerator, Algorithm: Skein-MAC-1024-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_1024_512
    Aliases: Skein-MAC1024/512
   Service: KeyGenerator, Algorithm: TNEPRES-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$TKeyGen
    Aliases: TNEPRESGMAC
   Service: SecretKeyFactory, Algorithm: PBEWITHSHA256AND192BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA256And192BitAESBC
    Aliases: PBEWITHSHA-256AND192BITAES-CBC-BC
   Service: MessageDigest, Algorithm: Skein-256-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_256_224
   Service: SecretKeyFactory, Algorithm: PBKDF2, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withUTF8
    Aliases: PBKDF2WITHHMACSHA1ANDUTF8
   Service: Mac, Algorithm: RC5MAC/CFB8, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$CFB8Mac32
    Aliases: RC5/CFB8
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.8.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CCM512
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.8.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CCM256
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.8.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CCM128
   Service: Cipher, Algorithm: Twofish, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$ECB
   Service: Mac, Algorithm: Skein-MAC-1024-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_1024_512
   Service: Signature, Algorithm: SM3WITHSM2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMSignatureSpi$sm3WithSM2
    Aliases: 1.2.156.10197.1.501
   Service: KeyGenerator, Algorithm: HC128, Class: org.bouncycastle.jcajce.provider.symmetric.HC128$KeyGen
   Service: KeyAgreement, Algorithm: 1.3.132.1.11.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA512KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.11.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA384KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.11.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA256KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.11.0, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA224KDFAndSharedInfo
   Service: Mac, Algorithm: PBEWITHHMACRIPEMD160, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD160$PBEWithHmac
   Service: KeyGenerator, Algorithm: HMACSHA3-256, Class: org.bouncycastle.jcajce.provider.digest.SHA3$KeyGenerator256
    Aliases: 2.16.840.1.101.3.4.2.14
   Service: KeyStore, Algorithm: PKCS12-3DES-40RC2, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$BCPKCS12KeyStore
   Service: Mac, Algorithm: DESMAC/CFB8, Class: org.bouncycastle.jcajce.provider.symmetric.DES$DESCFB8
    Aliases: DES/CFB8
   Service: MessageDigest, Algorithm: SM3, Class: org.bouncycastle.jcajce.provider.digest.SM3$Digest
    Aliases: 1.2.156.10197.1.401
   Service: Signature, Algorithm: NONEWITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$noneDSA
    Aliases: RAWDSA
   Service: KeyGenerator, Algorithm: HMACSkein-256-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_256_128
    Aliases: HMAC/Skein-256-128
   Service: Cipher, Algorithm: AESWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.AES$Wrap
    Attributes:
   Service: Cipher, Algorithm: PBEWITHSHAAND40BITRC2-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithSHAAnd40BitRC2
    Aliases: 1.2.840.113549.1.12.1.6
   Service: Signature, Algorithm: SHA512(224)WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA512_224WithRSAEncryption
    Aliases: SHA512(224)WithRSA/X9.31
   Service: Signature, Algorithm: SHA3-256WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsaSha3_256
    Aliases: SHA3-256/DSA
   Service: Mac, Algorithm: HMACSkein-256-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_256_224
   Service: KeyPairGenerator, Algorithm: ELGAMAL, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.KeyPairGeneratorSpi
   Service: AlgorithmParameterGenerator, Algorithm: DH, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.AlgorithmParameterGeneratorSpi
   Service: AlgorithmParameters, Algorithm: NOEKEON, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$AlgParams
   Service: KeyStore, Algorithm: BouncyCastle, Class: org.bouncycastle.jcajce.provider.keystore.bc.BcKeyStoreSpi$BouncyCastleStore
    Aliases: BOUNCYCASTLE
   Service: Cipher, Algorithm: CAST6, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$ECB
   Service: Cipher, Algorithm: CAST5, Class: org.bouncycastle.jcajce.provider.symmetric.CAST5$ECB
    Aliases: 1.2.840.113533.7.66.10
   Service: AlgorithmParameters, Algorithm: ECIES, Class: org.bouncycastle.jcajce.provider.asymmetric.ies.AlgorithmParametersSpi
   Service: Cipher, Algorithm: Tnepres, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$TECB
   Service: Mac, Algorithm: HMACDSTU7564-384, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$HashMac384
   Service: AlgorithmParameterGenerator, Algorithm: SM4, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$AlgParamGen
   Service: Signature, Algorithm: NONEwithECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSAnone
   Service: AlgorithmParameters, Algorithm: RC6, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$AlgParams
   Service: Mac, Algorithm: PBEWITHHMACSHA, Class: org.bouncycastle.jcajce.provider.digest.SHA1$SHA1Mac
   Service: AlgorithmParameters, Algorithm: RC5, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$AlgParams
    Aliases: RC5-32
   Service: Mac, Algorithm: POLY1305-SERPENT, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$Poly1305
   Service: AlgorithmParameters, Algorithm: RC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$AlgParams
   Service: Mac, Algorithm: HMACRIPEMD160, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD160$HashMac
    Aliases: HMAC/RIPEMD160
   Service: KeyGenerator, Algorithm: Skein-MAC-512-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_512_256
    Aliases: Skein-MAC512/256
   Service: Signature, Algorithm: SHA256WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsa256
    Aliases: SHA256withDSA
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.42, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: HMACSHA3-224, Class: org.bouncycastle.jcajce.provider.digest.SHA3$KeyGenerator224
    Aliases: 2.16.840.1.101.3.4.2.13
   Service: KeyGenerator, Algorithm: CAST6, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$KeyGen
   Service: AlgorithmParameters, Algorithm: Grainv1, Class: org.bouncycastle.jcajce.provider.symmetric.Grainv1$AlgParams
   Service: KeyFactory, Algorithm: X448, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyFactorySpi$X448
   Service: KeyGenerator, Algorithm: CAST5, Class: org.bouncycastle.jcajce.provider.symmetric.CAST5$KeyGen
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CBC512
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CBC256
   Service: KeyGenerator, Algorithm: SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
    Aliases: OID.1.2.410.200004.1.4
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CBC128
   Service: Mac, Algorithm: SKIPJACKMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Skipjack$Mac
    Aliases: SKIPJACK
   Service: Cipher, Algorithm: DESEDERFC3211WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$RFC3211
   Service: Cipher, Algorithm: DSTU7624-256KW, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$Wrap256
    Aliases: DSTU7624-256WRAP
   Service: KeyAgreement, Algorithm: DHUWITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA512CKDF
   Service: SecretKeyFactory, Algorithm: PBEWITHSHA1ANDDES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$PBEWithSHA1KeyFactory
   Service: KeyPairGenerator, Algorithm: OID.1.3.101.113, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$Ed448
   Service: KeyPairGenerator, Algorithm: OID.1.3.101.112, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$Ed25519
   Service: KeyPairGenerator, Algorithm: OID.1.3.101.111, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$X448
   Service: KeyGenerator, Algorithm: HMACSHA384, Class: org.bouncycastle.jcajce.provider.digest.SHA384$KeyGenerator
    Aliases: HMAC/SHA384
   Service: KeyPairGenerator, Algorithm: OID.1.3.101.110, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$X25519
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND128BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHAAnd128BitAESBC
   Service: KeyGenerator, Algorithm: 1.2.392.200011.61.1.1.3.4, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.392.200011.61.1.1.3.3, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.392.200011.61.1.1.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen128
   Service: Cipher, Algorithm: PBEWITHSHAAND128BITRC4, Class: org.bouncycastle.jcajce.provider.symmetric.ARC4$PBEWithSHAAnd128Bit
    Aliases: 1.2.840.113549.1.12.1.1
   Service: Signature, Algorithm: SHA512(256)WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA512_256withRSA
    Aliases: SHA512(256)WithRSAAndMGF1
   Service: Cipher, Algorithm: PBEWITHMD5ANDDES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$PBEWithMD5
    Aliases: OID.1.2.840.113549.1.5.3
   Service: Signature, Algorithm: DDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA
   Service: KeyAgreement, Algorithm: ECKAEGWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA512KDF
   Service: KeyPairGenerator, Algorithm: ECDHC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$ECDHC
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.3.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.3.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: KeyStore, Algorithm: IBCFKS-DEF, Class: org.bouncycastle.jcajce.provider.keystore.bcfks.BcFKSKeyStoreSpi$DefShared
   Service: Cipher, Algorithm: Threefish-1024, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$ECB_1024
   Service: Cipher, Algorithm: XTEA, Class: org.bouncycastle.jcajce.provider.symmetric.XTEA$ECB
   Service: KeyAgreement, Algorithm: XDH, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$XDH
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.22, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: Cipher, Algorithm: RSA/RAW, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$NoPadding
   Service: Mac, Algorithm: ARIA-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$GMAC
    Aliases: ARIAGMAC
   Service: Mac, Algorithm: RC5MAC, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$Mac32
    Aliases: RC5
   Service: Mac, Algorithm: Skein-MAC-512-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_512_256
   Service: X509Store, Algorithm: CRL/LDAP, Class: org.bouncycastle.jce.provider.X509StoreLDAPCRLs
   Service: Mac, Algorithm: PBEWITHHMACSHA1, Class: org.bouncycastle.jcajce.provider.digest.SHA1$SHA1Mac
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA384, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA384
   Service: KeyAgreement, Algorithm: DHUWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA224KDF
   Service: SecretKeyFactory, Algorithm: PBEWITHHMACSHA1, Class: org.bouncycastle.jcajce.provider.digest.SHA1$PBEWithMacKeyFactory
   Service: KeyAgreement, Algorithm: 1.3.132.1.14.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA512KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.14.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA384KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.14.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA256KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: 1.3.132.1.14.0, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA224KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: Skein-MAC-512-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_512_224
    Aliases: Skein-MAC512/224
   Service: MessageDigest, Algorithm: OID.2.16.840.1.101.3.4.2.9, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest384
   Service: MessageDigest, Algorithm: OID.2.16.840.1.101.3.4.2.8, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest256
   Service: MessageDigest, Algorithm: OID.2.16.840.1.101.3.4.2.7, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest224
   Service: Signature, Algorithm: SHA3-512WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA3_512withRSA
    Aliases: SHA3-512withRSAandMGF1
   Service: KeyPairGenerator, Algorithm: X25519, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$X25519
   Service: SecretKeyFactory, Algorithm: PBEWITHMD5AND256BITAES-CBC-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithMD5And256BitAESCBCOpenSSL
   Service: Mac, Algorithm: HMACRIPEMD128, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD128$HashMac
    Aliases: HMAC/RIPEMD128
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.11.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA512KDFAndSharedInfo
   Service: Mac, Algorithm: HMACSHA512/256, Class: org.bouncycastle.jcajce.provider.digest.SHA512$HashMacT256
    Aliases: HMAC/SHA512/256
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.11.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA384KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.11.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA256KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.11.0, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA224KDFAndSharedInfo
   Service: AlgorithmParameters, Algorithm: GOST28147, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$AlgParams
    Aliases: GOST-28147
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.9, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$OFB
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.8, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CFB
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.7, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CBC
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.6, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$OFB
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CFB
   Service: Cipher, Algorithm: ElGamal, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.CipherSpi$NoPadding
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CBC
   Service: Cipher, Algorithm: OID.1.2.410.200046.1.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
   Service: Cipher, Algorithm: SM4, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$ECB
   Service: Cipher, Algorithm: SM2WITHSHA384, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withSha384
    Aliases: 1.2.156.10197.1.301.3.2.5
   Service: Cipher, Algorithm: SM2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2
   Service: SecureRandom, Algorithm: NONCEANDIV, Class: org.bouncycastle.jcajce.provider.drbg.DRBG$NonceAndIV
   Service: KeyGenerator, Algorithm: HMACSHA1, Class: org.bouncycastle.jcajce.provider.digest.SHA1$KeyGenerator
   Service: Signature, Algorithm: RAWRSASSA-PSS, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$nonePSS
    Aliases: NONEWITHRSAANDMGF1
   Service: SecretKeyFactory, Algorithm: PBEWITHHMACGOST3411, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$PBEWithMacKeyFactory
   Service: Signature, Algorithm: SHA512WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSA512
    Aliases: SHA512WITHDETECDSA
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND40BITRC4, Class: org.bouncycastle.jcajce.provider.symmetric.ARC4$PBEWithSHAAnd40BitKeyFactory
    Aliases: 1.2.840.113549.1.12.1.2
   Service: Cipher, Algorithm: OID.1.2.410.200004.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$CBC
   Service: Mac, Algorithm: Skein-MAC-512-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_512_224
   Service: Mac, Algorithm: POLY1305-AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$Poly1305
   Service: AlgorithmParameters, Algorithm: SKIPJACK, Class: org.bouncycastle.jcajce.provider.symmetric.Skipjack$AlgParams
   Service: KeyPairGenerator, Algorithm: ECDHWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$ECDH
   Service: Cipher, Algorithm: DSTU7624KW, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$Wrap
    Aliases: DSTU7624WRAP
   Service: Cipher, Algorithm: GOST3412-2015/CFB, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$GCFB
   Service: KeyFactory, Algorithm: DSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.KeyFactorySpi
   Service: Signature, Algorithm: ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSA
   Service: Cipher, Algorithm: BROKENPBEWITHMD5ANDDES, Class: org.bouncycastle.jce.provider.BrokenJCEBlockCipher$BrokePBEWithMD5AndDES
   Service: KeyGenerator, Algorithm: POLY1305-SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$Poly1305KeyGen
    Aliases: POLY1305SEED
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.8.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CCM512
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.8.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CCM256
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.8.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CCM128
   Service: KeyAgreement, Algorithm: 1.3.133.16.840.63.0.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA1KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.9, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyAgreement, Algorithm: 1.3.133.16.840.63.0.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA1KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.8, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.7, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAANDTWOFISH-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$PBEWithSHAKeyFactory
   Service: Mac, Algorithm: PBEWITHHMACSHA384, Class: org.bouncycastle.jcajce.provider.digest.SHA384$HashMac
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.6, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA224KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: 1.2.410.200046.1.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: MessageDigest, Algorithm: Skein-512-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_512_160
   Service: SecretKeyFactory, Algorithm: ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyFactory
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHASCII, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2with8BIT
    Aliases: PBKDF2WITH8BIT
   Service: Cipher, Algorithm: 1.3.14.3.2.7, Class: org.bouncycastle.jcajce.provider.symmetric.DES$CBC
   Service: Signature, Algorithm: SHA256WITHCVC-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA256
    Aliases: 0.4.0.127.0.7.2.2.2.2.3
   Service: AlgorithmParameterGenerator, Algorithm: DESEDE, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$AlgParamGen
    Aliases: TDEA
   Service: Mac, Algorithm: HMACSHA512/224, Class: org.bouncycastle.jcajce.provider.digest.SHA512$HashMacT224
    Aliases: HMAC/SHA512/224
   Service: Signature, Algorithm: 1.2.840.113549.1.1.10, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$PSSwithRSA
   Service: Signature, Algorithm: GOST3411-2012-256WITHECGOST3410-2012-256, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.ECGOST2012SignatureSpi256
    Aliases: OID.1.2.643.7.1.1.3.2
   Service: SecureRandom, Algorithm: DEFAULT, Class: org.bouncycastle.jcajce.provider.drbg.DRBG$Default
   Service: Mac, Algorithm: SEED-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$GMAC
    Aliases: SEEDGMAC
   Service: KeyGenerator, Algorithm: HMACSHA3-512, Class: org.bouncycastle.jcajce.provider.digest.SHA3$KeyGenerator512
    Aliases: HMAC/SHA3-512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.6.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.6.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.6.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Mac, Algorithm: HMACWHIRLPOOL, Class: org.bouncycastle.jcajce.provider.digest.Whirlpool$HashMac
    Aliases: HMAC-WHIRLPOOL
   Service: KeyPairGenerator, Algorithm: ElGamal, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.KeyPairGeneratorSpi
   Service: Mac, Algorithm: HMACKECCAK288, Class: org.bouncycastle.jcajce.provider.digest.Keccak$HashMac288
    Aliases: HMAC-KECCAK288
   Service: Mac, Algorithm: HMACSHA384, Class: org.bouncycastle.jcajce.provider.digest.SHA384$HashMac
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.14, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$OFB
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.13, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CFB
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.12, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$CBC
   Service: Cipher, Algorithm: 1.2.410.200046.1.1.11, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$ECB
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.48, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.47, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Mac, Algorithm: HMACTIGER, Class: org.bouncycastle.jcajce.provider.digest.Tiger$HashMac
    Aliases: HMAC-TIGER
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.46, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.45, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.44, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Signature, Algorithm: RIPEMD160WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$RIPEMD160
    Aliases: RIPEMD160WithRSA
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.43, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: Grain128, Class: org.bouncycastle.jcajce.provider.symmetric.Grain128$KeyGen
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.42, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: AlgorithmParameters, Algorithm: Twofish, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$AlgParams
   Service: Signature, Algorithm: RIPEMD128WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$RIPEMD128WithRSAEncryption
    Aliases: RIPEMD128WithRSA/X9.31
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.41, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Signature, Algorithm: SHA3-384WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA3_384withRSA
    Aliases: SHA3-384withRSA/PSS
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.2, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: Mac, Algorithm: Skein-MAC-1024-1024, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_1024_1024
    Aliases: Skein-MAC1024/1024
   Service: KeyFactory, Algorithm: ED448, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyFactorySpi$Ed448
    Aliases: 1.3.101.113
   Service: Mac, Algorithm: HMACSkein-512-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_512_160
   Service: AlgorithmParameterGenerator, Algorithm: CCM, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AlgParamGenCCM
    Aliases: OID.2.16.840.1.101.3.4.1.47
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA512KDF
   Service: MessageDigest, Algorithm: BLAKE2B-256, Class: org.bouncycastle.jcajce.provider.digest.Blake2b$Blake2b256
    Aliases: 1.3.6.1.4.1.1722.12.2.1.8
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.14.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA512KDFAndSharedInfo
   Service: Cipher, Algorithm: GOST3412-2015/CBC, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$CBC
   Service: KeyPairGenerator, Algorithm: ECMQV, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$ECMQV
    Aliases: 1.3.133.16.840.63.0.16
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.14.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA384KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.14.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA256KDFAndSharedInfo
   Service: KeyAgreement, Algorithm: OID.1.3.132.1.14.0, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA224KDFAndSharedInfo
   Service: Cipher, Algorithm: PBEWITHSHAAND3-KEYTRIPLEDES-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$PBEWithSHAAndDES3Key
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.28, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.27, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: Skein-MAC-512-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_512_512
    Aliases: Skein-MAC512/512
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.26, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.25, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.24, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.23, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.22, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.21, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: MessageDigest, Algorithm: BLAKE2S-160, Class: org.bouncycastle.jcajce.provider.digest.Blake2s$Blake2s160
    Aliases: 1.3.6.1.4.1.1722.12.2.2.5
   Service: MessageDigest, Algorithm: Skein-512-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_512_128
   Service: KeyFactory, Algorithm: GOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.gost.KeyFactorySpi
    Aliases: GOST-3410
   Service: KeyGenerator, Algorithm: HMACRIPEMD256, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD256$KeyGenerator
    Aliases: HMAC/RIPEMD256
   Service: Signature, Algorithm: SHA3-256WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA3_256withRSA
    Aliases: SHA3-256WithRSAAndMGF1
   Service: AlgorithmParameters, Algorithm: DSTU7624, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: Mac, Algorithm: HMACKECCAK256, Class: org.bouncycastle.jcajce.provider.digest.Keccak$HashMac256
    Aliases: HMAC-KECCAK256
   Service: MessageDigest, Algorithm: RIPEMD320, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD320$Digest
   Service: Signature, Algorithm: SHA3-384WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA3_384
    Aliases: SHA3-384WithRSA
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND40BITRC2-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithSHAAnd40BitKeyFactory
   Service: Mac, Algorithm: TNEPRES-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$TSerpentGMAC
   Service: Cipher, Algorithm: IESWITHDESEDE-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IESwithDESedeCBC
   Service: MessageDigest, Algorithm: HARAKA-256, Class: org.bouncycastle.jcajce.provider.digest.Haraka$Digest256
   Service: Signature, Algorithm: RMD128WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$RIPEMD128WithRSAEncryption
    Aliases: RMD128withRSA/X9.31
   Service: AlgorithmParameters, Algorithm: XSALSA20, Class: org.bouncycastle.jcajce.provider.symmetric.XSalsa20$AlgParams
   Service: KeyGenerator, Algorithm: HMACSkein-512-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_512_384
    Aliases: HMAC-Skein-512-384
   Service: Mac, Algorithm: HMACSHA3-256, Class: org.bouncycastle.jcajce.provider.digest.SHA3$HashMac256
   Service: Mac, Algorithm: RC2MAC, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$CBCMAC
    Aliases: RC2
   Service: Mac, Algorithm: Skein-MAC-512-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_512_512
   Service: AlgorithmParameterGenerator, Algorithm: ELGAMAL, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.AlgorithmParameterGeneratorSpi
   Service: KeyAgreement, Algorithm: 0.4.0.127.0.7.1.1.5.1.1.6, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithRIPEMD160KDF
   Service: Mac, Algorithm: HMACSkein-512-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_512_128
   Service: KeyAgreement, Algorithm: 0.4.0.127.0.7.1.1.5.1.1.5, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA512KDF
   Service: KeyAgreement, Algorithm: 0.4.0.127.0.7.1.1.5.1.1.4, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA384KDF
   Service: Signature, Algorithm: SHA384WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA384
    Aliases: SHA384/RSA
   Service: KeyAgreement, Algorithm: 0.4.0.127.0.7.1.1.5.1.1.3, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA256KDF
   Service: KeyAgreement, Algorithm: 0.4.0.127.0.7.1.1.5.1.1.2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA224KDF
   Service: KeyAgreement, Algorithm: 0.4.0.127.0.7.1.1.5.1.1.1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA1KDF
   Service: Cipher, Algorithm: GOST3412-2015, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$ECB
   Service: KeyAgreement, Algorithm: ECDHWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA384KDFAndSharedInfo
   Service: AlgorithmParameterGenerator, Algorithm: GOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.gost.AlgorithmParameterGeneratorSpi
    Aliases: GOST-3410
   Service: SecretKeyFactory, Algorithm: TLS10KDF, Class: org.bouncycastle.jcajce.provider.symmetric.TLSKDF$TLS10
   Service: AlgorithmParameters, Algorithm: SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$AlgParams
   Service: KeyStore, Algorithm: BCFKS, Class: org.bouncycastle.jcajce.provider.keystore.bcfks.BcFKSKeyStoreSpi$Std
   Service: Cipher, Algorithm: AESWRAPPAD, Class: org.bouncycastle.jcajce.provider.symmetric.AES$WrapPad
    Aliases: OID.2.16.840.1.101.3.4.1.48
    Attributes:
      SupportedKeyClasses: javax.crypto.SecretKey
   Service: Cipher, Algorithm: VMPC-KSA3, Class: org.bouncycastle.jcajce.provider.symmetric.VMPCKSA3$Base
   Service: KeyAgreement, Algorithm: MQVWITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA256CKDF
   Service: SecretKeyFactory, Algorithm: TLS12WITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.symmetric.TLSKDF$TLS12withSHA256
   Service: Mac, Algorithm: HMACKECCAK224, Class: org.bouncycastle.jcajce.provider.digest.Keccak$HashMac224
    Aliases: HMAC-KECCAK224
   Service: KeyAgreement, Algorithm: X25519UWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519UwithSHA256KDF
   Service: MessageDigest, Algorithm: BLAKE2S-128, Class: org.bouncycastle.jcajce.provider.digest.Blake2s$Blake2s128
    Aliases: 1.3.6.1.4.1.1722.12.2.2.4
   Service: X509StreamParser, Algorithm: ATTRIBUTECERTIFICATE, Class: org.bouncycastle.jce.provider.X509AttrCertParser
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA256KDF
   Service: KeyGenerator, Algorithm: RC5-64, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$KeyGen64
   Service: KeyGenerator, Algorithm: SERPENT-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$KeyGen
    Aliases: SERPENTGMAC
   Service: Cipher, Algorithm: CCM, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CCM
    Attributes:
   Service: KeyAgreement, Algorithm: ECGOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost.KeyAgreementSpi$ECVKO
    Aliases: 1.2.643.2.2.96
   Service: CertStore, Algorithm: LDAP, Class: org.bouncycastle.jce.provider.X509LDAPCertStoreSpi
    Aliases: X509LDAP
   Service: KeyAgreement, Algorithm: ECKAEGWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA224KDF
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.10.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.10.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.10.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Mac, Algorithm: DESEDEMAC/CFB8, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$DESedeCFB8
    Aliases: DESEDE/CFB8
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB512
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB256
   Service: Mac, Algorithm: HMACSHA3-224, Class: org.bouncycastle.jcajce.provider.digest.SHA3$HashMac224
   Service: Signature, Algorithm: SHA384WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA384WithRSAEncryption
    Aliases: SHA384withRSA/ISO9796-2
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB128
   Service: Mac, Algorithm: POLY1305-ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$Poly1305
    Aliases: POLY1305ARIA
   Service: Mac, Algorithm: ISO9797ALG3MAC, Class: org.bouncycastle.jcajce.provider.symmetric.DES$DES9797Alg3
    Aliases: ISO9797ALG3
   Service: KeyAgreement, Algorithm: 1.3.101.111, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448
   Service: KeyAgreement, Algorithm: 1.2.840.113549.1.9.16.3.10, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithRFC2631KDF
   Service: KeyAgreement, Algorithm: 1.3.101.110, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519
   Service: CertPathValidator, Algorithm: PKIX, Class: org.bouncycastle.jce.provider.PKIXCertPathValidatorSpi_8
   Service: KeyAgreement, Algorithm: ECKAEGWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA1KDF
   Service: KeyStore, Algorithm: PKCS12, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$BCPKCS12KeyStore
   Service: AlgorithmParameters, Algorithm: ElGamal, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.AlgorithmParametersSpi
   Service: Mac, Algorithm: POLY1305-NOEKEON, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$Poly1305
    Aliases: POLY1305NOEKEON
   Service: KeyGenerator, Algorithm: Skein-MAC-256-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_256_256
    Aliases: Skein-MAC256/256
   Service: CertPathBuilder, Algorithm: RFC3281, Class: org.bouncycastle.jce.provider.PKIXAttrCertPathBuilderSpi
   Service: CertPathBuilder, Algorithm: RFC3280, Class: org.bouncycastle.jce.provider.PKIXCertPathBuilderSpi_8
   Service: Cipher, Algorithm: RSA/ISO9796-1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$ISO9796d1Padding
    Aliases: RSA//ISO9796-1PADDING
   Service: Cipher, Algorithm: AESRFC5649WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.AES$RFC5649Wrap
   Service: Signature, Algorithm: SHA3-256WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSASha3_256
    Aliases: SHA3-256WithECDSA
   Service: SecretKeyFactory, Algorithm: PBEWITHMD2ANDRC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithMD2KeyFactory
    Aliases: PBEWITHMD2ANDRC2-CBC
   Service: KeyAgreement, Algorithm: DHUWITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA256CKDF
   Service: Cipher, Algorithm: SKIPJACK, Class: org.bouncycastle.jcajce.provider.symmetric.Skipjack$ECB
   Service: KeyGenerator, Algorithm: HMACKECCAK384, Class: org.bouncycastle.jcajce.provider.digest.Keccak$KeyGenerator384
    Aliases: HMAC/KECCAK384
   Service: KeyGenerator, Algorithm: OID.1.2.392.200011.61.1.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.392.200011.61.1.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.392.200011.61.1.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen128
   Service: KeyGenerator, Algorithm: 1.2.410.200004.7.1.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
   Service: MessageDigest, Algorithm: GOST3411-2012-256, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$Digest2012_256
    Aliases: 1.2.643.7.1.1.2.2
   Service: AlgorithmParameters, Algorithm: OAEP, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.AlgorithmParametersSpi$OAEP
    Aliases: 1.2.840.113549.1.1.7
   Service: SecretKeyFactory, Algorithm: AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyFactory
   Service: AlgorithmParameters, Algorithm: HC256, Class: org.bouncycastle.jcajce.provider.symmetric.HC256$AlgParams
   Service: Signature, Algorithm: SHA3-224WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSASha3_224
    Aliases: 2.16.840.1.101.3.4.3.9
   Service: Mac, Algorithm: ZUC-256, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$ZucMac256
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA1CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA1CKDF
   Service: Mac, Algorithm: Skein-MAC-256-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_256_256
   Service: Signature, Algorithm: SHA384WITHPLAIN-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA384
    Aliases: SHA384WithPLAIN-ECDSA
   Service: KeyAgreement, Algorithm: OID.1.2.840.113549.1.9.16.3.10, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithRFC2631KDF
   Service: KeyGenerator, Algorithm: Skein-MAC-256-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_256_224
    Aliases: Skein-MAC256/224
   Service: MessageDigest, Algorithm: BLAKE2B-512, Class: org.bouncycastle.jcajce.provider.digest.Blake2b$Blake2b512
    Aliases: 1.3.6.1.4.1.1722.12.2.1.16
   Service: KeyGenerator, Algorithm: POLY1305-SM4, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$Poly1305KeyGen
    Aliases: POLY1305SM4
   Service: MessageDigest, Algorithm: SHA-256, Class: org.bouncycastle.jcajce.provider.digest.SHA256$Digest
    Aliases: SHA256
   Service: Signature, Algorithm: SHA224WITHDETDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA224
   Service: MessageDigest, Algorithm: 1.2.804.2.1.1.1.1.2.2.3, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest512
   Service: MessageDigest, Algorithm: 1.2.804.2.1.1.1.1.2.2.2, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest384
   Service: MessageDigest, Algorithm: 1.2.804.2.1.1.1.1.2.2.1, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest256
   Service: KeyPairGenerator, Algorithm: EDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$EdDSA
   Service: KeyGenerator, Algorithm: HMACDSTU7564-256, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$KeyGenerator256
    Aliases: HMAC-DSTU7564-256
   Service: Cipher, Algorithm: DSTU7624-128KW, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$Wrap128
    Aliases: 1.2.804.2.1.1.1.1.1.3.10.1
   Service: AlgorithmParameters, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: AlgorithmParameters, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: AlgorithmParameters, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParams
   Service: Cipher, Algorithm: PBEWITHSHA256AND128BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA256AESCBC128
    Aliases: PBEWITHSHA-256AND128BITAES-CBC-BC
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.8, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.7, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.6, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.5, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.44, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CFB
   Service: KeyGenerator, Algorithm: 2.16.840.1.101.3.4.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.43, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$OFB
   Service: AlgorithmParameters, Algorithm: DSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.AlgorithmParametersSpi
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.42, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CBC
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.48, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.41, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.47, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Mac, Algorithm: HMACKECCAK512, Class: org.bouncycastle.jcajce.provider.digest.Keccak$HashMac512
    Aliases: HMAC-KECCAK512
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.46, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.45, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.44, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.43, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.42, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Cipher, Algorithm: SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$ECB
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.41, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen256
   Service: Signature, Algorithm: WhirlpoolWITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$WhirlpoolWithRSAEncryption
    Aliases: WhirlpoolWithRSA/X9.31
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA224CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA224CKDF
   Service: Cipher, Algorithm: 1.3.6.1.4.1.3029.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.Blowfish$CBC
   Service: KeyGenerator, Algorithm: VMPC-KSA3, Class: org.bouncycastle.jcajce.provider.symmetric.VMPCKSA3$KeyGen
   Service: KeyGenerator, Algorithm: HMACSkein-1024-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_1024_384
    Aliases: HMAC-Skein-1024-384
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.7.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.7.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: Serpent, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$KeyGen
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.7.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: KeyGenerator, Algorithm: Skein-MAC-1024-1024, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_1024_1024
   Service: Mac, Algorithm: Skein-MAC-256-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_256_224
   Service: MessageDigest, Algorithm: HARAKA-512, Class: org.bouncycastle.jcajce.provider.digest.Haraka$Digest512
   Service: MessageDigest, Algorithm: 1.0.10118.3.0.55, Class: org.bouncycastle.jcajce.provider.digest.Whirlpool$Digest
   Service: KeyAgreement, Algorithm: DHUWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA1KDF
   Service: Signature, Algorithm: SHA256WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA256
   Service: Signature, Algorithm: SHA512(256)WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA512_256WithRSAEncryption
    Aliases: SHA512(256)WithRSA/ISO9796-2
   Service: Mac, Algorithm: HMACSkein-1024-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_1024_384
   Service: Mac, Algorithm: HMACSHA3-512, Class: org.bouncycastle.jcajce.provider.digest.SHA3$HashMac512
   Service: Signature, Algorithm: GOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.gost.SignatureSpi
    Aliases: GOST-3410
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA224KDF
   Service: Cipher, Algorithm: 1.2.840.113549.3.7, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$CBC
   Service: MessageDigest, Algorithm: SHA-224, Class: org.bouncycastle.jcajce.provider.digest.SHA224$Digest
    Aliases: SHA224
   Service: Mac, Algorithm: HMACSkein-1024-1024, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_1024_1024
    Aliases: HMAC-Skein-1024-1024
   Service: MessageDigest, Algorithm: SHA3-384, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest384
   Service: Mac, Algorithm: DESEDECMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$CMAC
   Service: Cipher, Algorithm: 1.2.840.113549.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$CBC
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.24, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CFB
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.23, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$OFB
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.22, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CBC
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.28, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.11591.13.2.21, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.27, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.26, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.25, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.24, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.23, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.22, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.21, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen192
   Service: MessageDigest, Algorithm: Skein-256-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_256_160
   Service: Signature, Algorithm: SHA1WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA
   Service: MessageDigest, Algorithm: OID.1.2.804.2.1.1.1.1.2.2.3, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest512
   Service: KeyGenerator, Algorithm: RC6, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$KeyGen
   Service: MessageDigest, Algorithm: OID.1.2.804.2.1.1.1.1.2.2.2, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest384
   Service: KeyGenerator, Algorithm: RC5, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$KeyGen32
    Aliases: RC5-32
   Service: MessageDigest, Algorithm: OID.1.2.804.2.1.1.1.1.2.2.1, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest256
   Service: KeyGenerator, Algorithm: RC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$KeyGenerator
   Service: Cipher, Algorithm: IES, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IES
   Service: AlgorithmParameters, Algorithm: DESEDE, Class: org.bouncycastle.jcajce.provider.symmetric.util.IvAlgorithmParameters
    Aliases: TDEA
   Service: Cipher, Algorithm: ELGAMAL, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.CipherSpi$NoPadding
    Aliases: 1.3.14.7.2.1.1
   Service: SecretKeyFactory, Algorithm: DES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$KeyFactory
    Aliases: 1.3.14.3.2.7
   Service: KeyAgreement, Algorithm: DHWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithSHA1KDF
   Service: Signature, Algorithm: ECGOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost.SignatureSpi
   Service: KeyFactory, Algorithm: DSTU4145, Class: org.bouncycastle.jcajce.provider.asymmetric.dstu.KeyFactorySpi
    Aliases: 1.2.804.2.1.1.1.1.3.1.1.1.1
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.10.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.10.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.10.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB512
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB256
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB128
   Service: Cipher, Algorithm: OID.1.3.6.1.4.1.3029.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.Blowfish$CBC
   Service: Cipher, Algorithm: PBEWITHSHAAND256BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA1AESCBC256
    Aliases: PBEWITHSHA1AND256BITAES-CBC-BC
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.44, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CFB
   Service: Mac, Algorithm: HMACSkein-256-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_256_160
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.43, Class: org.bouncycastle.jcajce.provider.symmetric.AES$OFB
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.42, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CBC
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.41, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
   Service: Signature, Algorithm: SHA3-384WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSASha3_384
   Service: Mac, Algorithm: POLY1305-Twofish, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$Poly1305
    Aliases: POLY1305Twofish
   Service: Mac, Algorithm: SIPHASH-4-8, Class: org.bouncycastle.jcajce.provider.symmetric.SipHash$Mac48
   Service: X509StreamParser, Algorithm: CRL, Class: org.bouncycastle.jce.provider.X509CRLParser
   Service: KeyGenerator, Algorithm: NOEKEON-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$KeyGen
    Aliases: NOEKEONGMAC
   Service: Cipher, Algorithm: CAMELLIAWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$Wrap
    Aliases: 1.2.392.200011.61.1.1.3.4
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA3-384, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA3_384
   Service: KeyAgreement, Algorithm: DHUWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA384KDF
   Service: KeyAgreement, Algorithm: ECKAEGWITHRIPEMD160KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithRIPEMD160KDF
   Service: Signature, Algorithm: SHA224WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA224
   Service: KeyGenerator, Algorithm: SKIPJACK, Class: org.bouncycastle.jcajce.provider.symmetric.Skipjack$KeyGen
   Service: KeyAgreement, Algorithm: MQVWITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA512CKDF
   Service: X509Store, Algorithm: CERTIFICATE/COLLECTION, Class: org.bouncycastle.jce.provider.X509StoreCertCollection
   Service: MessageDigest, Algorithm: Skein-256-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_256_128
   Service: AlgorithmParameterGenerator, Algorithm: SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$AlgParamGen
   Service: KeyStore, Algorithm: PKCS12-DEF, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$DefPKCS12KeyStore
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.24, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CFB
   Service: AlgorithmParameters, Algorithm: CHACHA20-POLY1305, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$AlgParamsCC1305
    Aliases: OID.1.2.840.113549.1.9.16.3.18
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.23, Class: org.bouncycastle.jcajce.provider.symmetric.AES$OFB
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.22, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CBC
   Service: MessageDigest, Algorithm: KECCAK-384, Class: org.bouncycastle.jcajce.provider.digest.Keccak$Digest384
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.21, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
   Service: AlgorithmParameters, Algorithm: SALSA20, Class: org.bouncycastle.jcajce.provider.symmetric.Salsa20$AlgParams
   Service: KeyGenerator, Algorithm: ZUC-128, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$KeyGen128
   Service: AlgorithmParameters, Algorithm: AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AlgParams
   Service: MessageDigest, Algorithm: DSTU7564-256, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest256
   Service: MessageDigest, Algorithm: GOST3411-2012-512, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$Digest2012_512
    Aliases: 1.2.643.7.1.1.2.3
   Service: Cipher, Algorithm: Grain128, Class: org.bouncycastle.jcajce.provider.symmetric.Grain128$Base
   Service: Cipher, Algorithm: RSA/PKCS1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding
    Aliases: RSA//PKCS1PADDING
   Service: KeyGenerator, Algorithm: VMPC, Class: org.bouncycastle.jcajce.provider.symmetric.VMPC$KeyGen
   Service: Signature, Algorithm: ED25519, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.SignatureSpi$Ed25519
    Aliases: 1.3.101.112
   Service: AlgorithmParameters, Algorithm: Threefish-256, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$AlgParams_256
   Service: KeyAgreement, Algorithm: ECCDHU, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUC
    Attributes:
      SupportedKeyFormats: PKCS#8|X.509
      SupportedKeyClasses: java.security.interfaces.ECPublicKey|java.security.interfaces.ECPrivateKey
   Service: KeyGenerator, Algorithm: CAMELLIA-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen
    Aliases: CAMELLIAGMAC
   Service: KeyPairGenerator, Algorithm: X448, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$X448
   Service: Cipher, Algorithm: RSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$NoPadding
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.RSAPublicKey|javax.crypto.interfaces.RSAPrivateKey
   Service: SecretKeyFactory, Algorithm: PBEWITHHMACRIPEMD160, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD160$PBEWithHmacKeyFactory
   Service: Signature, Algorithm: SHA512WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA512
   Service: Mac, Algorithm: HMACSkein-256-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_256_128
   Service: Cipher, Algorithm: OID.1.2.840.113549.1.9.16.3.6, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$Wrap
   Service: KeyGenerator, Algorithm: HMACGOST3411, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$KeyGenerator
    Aliases: HMAC/GOST3411
   Service: Signature, Algorithm: ECGOST3410-2012-256, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.ECGOST2012SignatureSpi256
    Aliases: 1.2.643.7.1.1.1.1
   Service: KeyAgreement, Algorithm: MQVWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA512KDF
   Service: MessageDigest, Algorithm: TIGER, Class: org.bouncycastle.jcajce.provider.digest.Tiger$Digest
   Service: Mac, Algorithm: SERPENT-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$SerpentGMAC
   Service: SecretKeyFactory, Algorithm: 1.3.6.1.4.1.11591.4.11, Class: org.bouncycastle.jcajce.provider.symmetric.SCRYPT$ScryptWithUTF8
   Service: KeyPairGenerator, Algorithm: RSASSA-PSS, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.KeyPairGeneratorSpi$PSS
    Aliases: RSAPSS
   Service: Signature, Algorithm: SHA3-512WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSASha3_512
   Service: MessageDigest, Algorithm: SHA-512, Class: org.bouncycastle.jcajce.provider.digest.SHA512$Digest
    Aliases: 2.16.840.1.101.3.4.2.3
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA1KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: Skein-MAC-512-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_512_160
    Aliases: Skein-MAC512/160
   Service: KeyAgreement, Algorithm: DHWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithSHA512KDF
   Service: MessageDigest, Algorithm: SHA-512/256, Class: org.bouncycastle.jcajce.provider.digest.SHA512$DigestT256
    Aliases: SHA512256
   Service: Cipher, Algorithm: GOST3412-2015/OFB, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$OFB
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA384KDFAndSharedInfo
   Service: Mac, Algorithm: GOST3412MAC, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$Mac
    Aliases: GOST3412-2015
   Service: KeyGenerator, Algorithm: HMACDSTU7564-512, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$KeyGenerator512
    Aliases: 1.2.804.2.1.1.1.1.2.2.6
   Service: Signature, Algorithm: SHA512(224)WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA512_224withRSA
    Aliases: SHA512(224)withRSA/PSS
   Service: Signature, Algorithm: SHA384WITHDETDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA384
   Service: Signature, Algorithm: DSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$stdDSA
    Aliases: DSAWITHSHA1
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.44, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CFB
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.43, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$OFB
   Service: X509Store, Algorithm: ATTRIBUTECERTIFICATE/COLLECTION, Class: org.bouncycastle.jce.provider.X509StoreAttrCertCollection
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.42, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CBC
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.41, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: KeyAgreement, Algorithm: OID.1.3.101.111, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448
   Service: KeyAgreement, Algorithm: OID.1.3.101.110, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519
   Service: Mac, Algorithm: OLDHMACSHA384, Class: org.bouncycastle.jcajce.provider.digest.SHA384$OldSHA384
   Service: KeyAgreement, Algorithm: ECDHWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA256KDFAndSharedInfo
   Service: Signature, Algorithm: SHA1WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA1WithRSAEncryption
    Aliases: SHA1WithRSA/X9.31
   Service: KeyGenerator, Algorithm: AES-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
    Aliases: AESGMAC
   Service: KeyGenerator, Algorithm: DSTU7624, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen
   Service: Mac, Algorithm: Skein-MAC-512-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_512_160
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.2.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.2.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: Cipher, Algorithm: DSTU7624-256, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB_256
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.2.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: Signature, Algorithm: SHA384WITHECNR, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecNR384
   Service: Cipher, Algorithm: PBEWITHSHA256AND192BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA256AESCBC192
    Aliases: PBEWITHSHA-256AND192BITAES-CBC-BC
   Service: Mac, Algorithm: SIPHASH128-4-8, Class: org.bouncycastle.jcajce.provider.symmetric.SipHash128$Mac48
   Service: KeyGenerator, Algorithm: POLY1305-NOEKEON, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$Poly1305KeyGen
   Service: KeyStore, Algorithm: PKCS12-3DES-3DES, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$BCPKCS12KeyStore3DES
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.24, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CFB
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.23, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$OFB
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.22, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$CBC
   Service: Cipher, Algorithm: 1.3.6.1.4.1.11591.13.2.21, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: KeyGenerator, Algorithm: ARIA-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen
    Aliases: ARIAGMAC
   Service: Mac, Algorithm: DESMAC64WITHISO7816-4PADDING, Class: org.bouncycastle.jcajce.provider.symmetric.DES$DES64with7816d4
    Aliases: DESISO9797ALG1WITHISO7816-4PADDING
   Service: Mac, Algorithm: HMACDSTU7564-256, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$HashMac256
   Service: Mac, Algorithm: Shacal-2CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$CMAC
   Service: MessageDigest, Algorithm: SHA-512/224, Class: org.bouncycastle.jcajce.provider.digest.SHA512$DigestT224
    Aliases: 2.16.840.1.101.3.4.2.5
   Service: KeyGenerator, Algorithm: XSALSA20, Class: org.bouncycastle.jcajce.provider.symmetric.XSalsa20$KeyGen
   Service: Cipher, Algorithm: DHIESWITHAES-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IESwithAESCBC
   Service: KeyGenerator, Algorithm: Skein-MAC-512-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_512_128
    Aliases: Skein-MAC512/128
   Service: Cipher, Algorithm: PBEWITHSHA1ANDRC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithSHA1AndRC2
    Aliases: OID.1.2.840.113549.1.5.11
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA512CKDF
   Service: X509Store, Algorithm: CERTIFICATE/LDAP, Class: org.bouncycastle.jce.provider.X509StoreLDAPCerts
   Service: Signature, Algorithm: RIPEMD160withRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$RIPEMD160WithRSAEncryption
    Aliases: RIPEMD160WithRSA/ISO9796-2
   Service: Cipher, Algorithm: SM2WITHSHA1, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withSha1
    Aliases: 1.2.156.10197.1.301.3.2.2
   Service: KeyGenerator, Algorithm: SIPHASH128, Class: org.bouncycastle.jcajce.provider.symmetric.SipHash128$KeyGen
    Aliases: SIPHASH128-4-8
   Service: KeyGenerator, Algorithm: CHACHA, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$KeyGen
   Service: KeyStore, Algorithm: BKS-V1, Class: org.bouncycastle.jcajce.provider.keystore.bc.BcKeyStoreSpi$Version1
   Service: KeyGenerator, Algorithm: RC6-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$KeyGen
    Aliases: RC6GMAC
   Service: KeyAgreement, Algorithm: MQVWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA1KDF
   Service: AlgorithmParameters, Algorithm: TEA, Class: org.bouncycastle.jcajce.provider.symmetric.TEA$AlgParams
   Service: AlgorithmParameters, Algorithm: DES, Class: org.bouncycastle.jcajce.provider.symmetric.util.IvAlgorithmParameters
   Service: Mac, Algorithm: POLY1305-SM4, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$Poly1305
   Service: KeyGenerator, Algorithm: HMACSHA256, Class: org.bouncycastle.jcajce.provider.digest.SHA256$KeyGenerator
    Aliases: HMAC/SHA256
   Service: KeyAgreement, Algorithm: X25519WITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519withSHA256KDF
   Service: KeyAgreement, Algorithm: X25519, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519
   Service: Signature, Algorithm: DETDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA
   Service: Cipher, Algorithm: Serpent, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$ECB
   Service: Signature, Algorithm: EDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.SignatureSpi$EdDSA
   Service: KeyGenerator, Algorithm: HMACSkein-1024-1024, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_1024_1024
   Service: Signature, Algorithm: SHA3-512WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA3_512
    Aliases: SHA3-512/RSA
   Service: KeyAgreement, Algorithm: X448, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448
   Service: Mac, Algorithm: DSTU7624GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$GMAC
   Service: KeyFactory, Algorithm: RSASSA-PSS, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.KeyFactorySpi
    Aliases: RSAPSS
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA384CKDF
   Service: CertStore, Algorithm: Multi, Class: org.bouncycastle.jce.provider.MultiCertStoreSpi
   Service: Cipher, Algorithm: ARIARFC3211WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$RFC3211Wrap
   Service: KeyGenerator, Algorithm: 1.2.840.113549.3.7, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$KeyGenerator3
   Service: MessageDigest, Algorithm: SHAKE128-256, Class: org.bouncycastle.jcajce.provider.digest.SHA3$DigestShake128_256
   Service: SecretKeyFactory, Algorithm: PBEWITHSHAAND256BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHAAnd256BitAESBC
   Service: KeyGenerator, Algorithm: 1.2.840.113549.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$KeyGenerator
   Service: Mac, Algorithm: Skein-MAC-512-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_512_128
   Service: AlgorithmParameters, Algorithm: ELGAMAL, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.AlgorithmParametersSpi
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA256, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA256
   Service: Signature, Algorithm: SHA256WITHSM2, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMSignatureSpi$sha256WithSM2
    Aliases: 1.2.156.10197.1.503
   Service: Signature, Algorithm: SHA224WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA224withRSA
    Aliases: SHA224WithRSA/PSS
   Service: Signature, Algorithm: SHA256WITHDETDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSA256
   Service: KeyPairGenerator, Algorithm: ECGOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost.KeyPairGeneratorSpi
   Service: Signature, Algorithm: RMD128WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$RIPEMD128
    Aliases: RMD128WithRSAEncryption
   Service: KeyGenerator, Algorithm: AESWRAPPAD, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen
   Service: Cipher, Algorithm: ECIESWITHAES-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.IESCipher$ECIESwithAESCBC
   Service: Mac, Algorithm: AESCCMMAC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AESCCMMAC
    Aliases: 2.16.840.1.101.3.4.1.47
   Service: Mac, Algorithm: AESCMAC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AESCMAC
   Service: Cipher, Algorithm: ZUC-256, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$Zuc256
    Aliases: ZUC-256-128
   Service: Signature, Algorithm: SHA3-384WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSASha3_384
    Aliases: SHA3-384/ECDSA
   Service: Signature, Algorithm: SHA3-512WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSASha3_512
    Aliases: SHA3-512WithECDSA
   Service: X509Store, Algorithm: ATTRIBUTECERTIFICATE/LDAP, Class: org.bouncycastle.jce.provider.X509StoreLDAPAttrCerts
   Service: Signature, Algorithm: SHA512WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA512
    Aliases: SHA512withRSA
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA1CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA1CKDF
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA1KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA1KDF
   Service: KeyGenerator, Algorithm: HMACSHA224, Class: org.bouncycastle.jcajce.provider.digest.SHA224$KeyGenerator
    Aliases: HMAC/SHA224
   Service: Cipher, Algorithm: SM2WITHSHA256, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withSha256
    Aliases: 1.2.156.10197.1.301.3.2.4
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CFB
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.AES$OFB
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CBC
   Service: KeyAgreement, Algorithm: ECKAEGWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA384KDF
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
   Service: MessageDigest, Algorithm: DSTU7564-512, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$Digest512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyAgreement, Algorithm: 1.2.840.113549.1.9.16.3.5, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithRFC2631KDF
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: SecretKeyFactory, Algorithm: SCRYPT, Class: org.bouncycastle.jcajce.provider.symmetric.SCRYPT$ScryptWithUTF8
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: AlgorithmParameters, Algorithm: Threefish-512, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$AlgParams_512
   Service: MessageDigest, Algorithm: RIPEMD256, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD256$Digest
    Aliases: 1.3.36.3.2.3
   Service: KeyGenerator, Algorithm: BLOWFISH, Class: org.bouncycastle.jcajce.provider.symmetric.Blowfish$KeyGen
    Aliases: 1.3.6.1.4.1.3029.1.1.2
   Service: Cipher, Algorithm: 1.2.840.113549.1.9.16.3.6, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$Wrap
   Service: Signature, Algorithm: SHA512WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA512WithRSAEncryption
    Aliases: SHA512withRSA/ISO9796-2
   Service: Signature, Algorithm: ECGOST3410-2012-512, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.ECGOST2012SignatureSpi512
    Aliases: ECGOST3410-2012-512
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA224, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA224
   Service: MessageDigest, Algorithm: BLAKE2B-160, Class: org.bouncycastle.jcajce.provider.digest.Blake2b$Blake2b160
    Aliases: 1.3.6.1.4.1.1722.12.2.1.5
   Service: Signature, Algorithm: RMD160WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$RIPEMD160WithRSAEncryption
    Aliases: RMD160WithRSA/X9.31
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA384CKDF
   Service: Signature, Algorithm: GOST3411WITHDSTU4145, Class: org.bouncycastle.jcajce.provider.asymmetric.dstu.SignatureSpi
    Aliases: GOST3411withDSTU4145
   Service: KeyStore, Algorithm: IBCFKS, Class: org.bouncycastle.jcajce.provider.keystore.bcfks.BcFKSKeyStoreSpi$StdShared
   Service: CertPathBuilder, Algorithm: PKIX, Class: org.bouncycastle.jce.provider.PKIXCertPathBuilderSpi_8
   Service: Signature, Algorithm: GOST3411WITHDSTU4145LE, Class: org.bouncycastle.jcajce.provider.asymmetric.dstu.SignatureSpiLe
    Aliases: OID.1.2.804.2.1.1.1.1.3.1.1
   Service: AlgorithmParameterGenerator, Algorithm: RC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$AlgParamGen
   Service: AlgorithmParameters, Algorithm: Tnepres, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$TAlgParams
   Service: Mac, Algorithm: PBEWITHHMACSHA256, Class: org.bouncycastle.jcajce.provider.digest.SHA256$HashMac
    Aliases: PBEWITHHMACSHA-256
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.8, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.7, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.6, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.5, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: Signature, Algorithm: SHA256WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSA256
    Aliases: SHA256/ECDSA
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: KeyGenerator, Algorithm: OID.2.16.840.1.101.3.4.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen128
   Service: Signature, Algorithm: SHA224WITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$SHA224WithRSAEncryption
    Aliases: SHA224withRSA/ISO9796-2
   Service: Cipher, Algorithm: ECIES, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.IESCipher$ECIES
   Service: KeyGenerator, Algorithm: HMACRIPEMD160, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD160$KeyGenerator
    Aliases: HMAC/RIPEMD160
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA1CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHwithSHA1CKDF
   Service: Mac, Algorithm: HMACRIPEMD320, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD320$HashMac
    Aliases: HMAC-RIPEMD320
   Service: Signature, Algorithm: RIPEMD256WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$RIPEMD256
    Aliases: RIPEMD256withRSAEncryption
   Service: Cipher, Algorithm: SM2WITHSHA224, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withSha224
    Aliases: 1.2.156.10197.1.301.3.2.3
   Service: Signature, Algorithm: SHA512WITHPLAIN-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA512
    Aliases: SHA512/PLAIN-ECDSA
   Service: MessageDigest, Algorithm: Skein-512-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_512_384
   Service: Mac, Algorithm: HMACSHA256, Class: org.bouncycastle.jcajce.provider.digest.SHA256$HashMac
   Service: Cipher, Algorithm: PBEWITHMD5AND256BITAES-CBC-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithAESCBC
   Service: Cipher, Algorithm: OLDPBEWITHSHAANDTWOFISH-CBC, Class: org.bouncycastle.jce.provider.BrokenJCEBlockCipher$OldPBEWithSHAAndTwofish
   Service: KeyAgreement, Algorithm: X448WITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448withSHA512CKDF
   Service: Signature, Algorithm: SHA384WITHCVC-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA384
    Aliases: 0.4.0.127.0.7.2.2.2.2.4
   Service: Mac, Algorithm: AES-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AESGMAC
    Aliases: AESGMAC
   Service: Signature, Algorithm: SHA224WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSA224
    Aliases: SHA224WithECDSA
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CFB
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.AES$OFB
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CBC
   Service: Cipher, Algorithm: OID.2.16.840.1.101.3.4.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
   Service: KeyGenerator, Algorithm: POLY1305-Twofish, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$Poly1305KeyGen
   Service: Cipher, Algorithm: 1.2.840.113549.1.1.7, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$OAEPPadding
   Service: CertPathValidator, Algorithm: RFC3281, Class: org.bouncycastle.jce.provider.PKIXAttrCertPathValidatorSpi
   Service: CertPathValidator, Algorithm: RFC3280, Class: org.bouncycastle.jce.provider.PKIXCertPathValidatorSpi_8
   Service: Cipher, Algorithm: 1.2.840.113549.1.1.1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding
   Service: SecretKeyFactory, Algorithm: TLS11KDF, Class: org.bouncycastle.jcajce.provider.symmetric.TLSKDF$TLS11
   Service: Mac, Algorithm: DESMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DES$CBCMAC
    Aliases: DES
   Service: KeyAgreement, Algorithm: MQVWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA224KDF
   Service: AlgorithmParameters, Algorithm: GCM, Class: org.bouncycastle.jcajce.provider.symmetric.AES$AlgParamsGCM
    Aliases: OID.2.16.840.1.101.3.4.1.46
   Service: AlgorithmParameters, Algorithm: CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$AlgParams
    Aliases: 1.2.392.200011.61.1.1.1.4
   Service: Cipher, Algorithm: DSTU7624-512, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB_512
   Service: KeyGenerator, Algorithm: POLY1305-CAST6, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$Poly1305KeyGen
    Aliases: POLY1305CAST6
   Service: KeyGenerator, Algorithm: NOEKEON, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$KeyGen
   Service: SecretKeyFactory, Algorithm: PBEWITHMD5ANDRC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$PBEWithMD5KeyFactory
    Aliases: PBEWITHMD5ANDRC2-CBC
   Service: KeyFactory, Algorithm: ECGOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost.KeyFactorySpi
   Service: Mac, Algorithm: HMACDSTU7564-512, Class: org.bouncycastle.jcajce.provider.digest.DSTU7564$HashMac512
   Service: Signature, Algorithm: SHA224WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSA224
    Aliases: SHA224WITHDETECDSA
   Service: KeyAgreement, Algorithm: DHWITHSHA224KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHwithSHA224KDF
   Service: Mac, Algorithm: PBEWITHHMACSHA224, Class: org.bouncycastle.jcajce.provider.digest.SHA224$HashMac
   Service: SecretKeyFactory, Algorithm: PBEWITHHMACTIGER, Class: org.bouncycastle.jcajce.provider.digest.Tiger$PBEWithMacKeyFactory
   Service: Mac, Algorithm: HMACSkein-512-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$HashMac_512_384
   Service: Mac, Algorithm: RC6-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$GMAC
    Aliases: RC6GMAC
   Service: KeyPairGenerator, Algorithm: GOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.gost.KeyPairGeneratorSpi
    Aliases: GOST-3410
   Service: KeyFactory, Algorithm: ED25519, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyFactorySpi$Ed25519
   Service: KeyGenerator, Algorithm: HMACRIPEMD128, Class: org.bouncycastle.jcajce.provider.digest.RIPEMD128$KeyGenerator
    Aliases: HMAC/RIPEMD128
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.8.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.8.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: AlgorithmParameters, Algorithm: PSS, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.AlgorithmParametersSpi$PSS
    Aliases: SHA224withRSA/PSS
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.8.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: AlgorithmParameterGenerator, Algorithm: NOEKEON, Class: org.bouncycastle.jcajce.provider.symmetric.Noekeon$AlgParamGen
   Service: AlgorithmParameterGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen512
   Service: AlgorithmParameterGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen256
   Service: AlgorithmParameterGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.5.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen128
   Service: Mac, Algorithm: HMACSHA224, Class: org.bouncycastle.jcajce.provider.digest.SHA224$HashMac
   Service: KeyAgreement, Algorithm: ECDHC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHC
    Attributes:
   Service: KeyAgreement, Algorithm: DHUWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA256KDF
   Service: KeyGenerator, Algorithm: HMACSHA512, Class: org.bouncycastle.jcajce.provider.digest.SHA512$KeyGenerator
    Aliases: HMAC/SHA512
   Service: MessageDigest, Algorithm: Skein-1024-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$Digest_1024_384
   Service: KeyAgreement, Algorithm: DHUWITHSHA1CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$DHUwithSHA1CKDF
   Service: KeyFactory, Algorithm: ECDH, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyFactorySpi$ECDH
   Service: Cipher, Algorithm: RC6, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$ECB
   Service: Cipher, Algorithm: RC5, Class: org.bouncycastle.jcajce.provider.symmetric.RC5$ECB32
    Aliases: RC5-32
   Service: Cipher, Algorithm: RC2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$ECB
   Service: Cipher, Algorithm: DESEDE, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$ECB
    Aliases: TDEA
   Service: Mac, Algorithm: BLOWFISHCMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Blowfish$CMAC
   Service: KeyGenerator, Algorithm: HMACSkein-512-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_512_256
    Aliases: HMAC-Skein-512-256
   Service: Signature, Algorithm: SHA256WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA256WithRSAEncryption
    Aliases: SHA256WithRSA/X9.31
   Service: KeyFactory, Algorithm: ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyFactorySpi$ECDSA
    Aliases: ECDSAwithSHA1
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA384KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA384KDF
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.3.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.3.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA512, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA512
   Service: KeyGenerator, Algorithm: Skein-MAC-256-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_256_160
    Aliases: Skein-MAC256/160
   Service: Signature, Algorithm: RSASSA-PSS, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$PSSwithRSA
    Aliases: RSAPSS
   Service: AlgorithmParameterGenerator, Algorithm: ARIAGCM, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$AlgParamGen
    Aliases: OID.1.2.410.200046.1.1.35
   Service: KeyPairGenerator, Algorithm: ECIES, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$ECDH
   Service: AlgorithmParameters, Algorithm: Serpent, Class: org.bouncycastle.jcajce.provider.symmetric.Serpent$AlgParams
   Service: Cipher, Algorithm: RSA/OAEP, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$OAEPPadding
    Aliases: RSA//OAEPPADDING
   Service: AlgorithmParameters, Algorithm: BLOWFISH, Class: org.bouncycastle.jcajce.provider.symmetric.Blowfish$AlgParams
   Service: AlgorithmParameterGenerator, Algorithm: CAST5, Class: org.bouncycastle.jcajce.provider.symmetric.CAST5$AlgParamGen
    Aliases: 1.2.840.113533.7.66.10
   Service: Cipher, Algorithm: DHIESwithAES-CBC, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IESwithAESCBC
   Service: Signature, Algorithm: WhirlpoolWITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$WhirlpoolWithRSAEncryption
    Aliases: WhirlpoolWithRSA/ISO9796-2
   Service: Signature, Algorithm: SHA256WITHPLAIN-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA256
    Aliases: SHA256withPLAIN-ECDSA
   Service: Signature, Algorithm: SHA224WITHPLAIN-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA224
    Aliases: SHA224WithPLAIN-ECDSA
   Service: KeyGenerator, Algorithm: SEED-CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyGen
    Aliases: SEEDCMAC
   Service: CertificateFactory, Algorithm: X.509, Class: org.bouncycastle.jcajce.provider.asymmetric.x509.CertificateFactory
    Aliases: X509
   Service: KeyStore, Algorithm: BCPKCS12, Class: org.bouncycastle.jcajce.provider.keystore.pkcs12.PKCS12KeyStoreSpi$BCPKCS12KeyStore
   Service: Cipher, Algorithm: SM2WITHSHA512, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withSha512
    Aliases: 1.2.156.10197.1.301.3.2.6
   Service: SecretKeyFactory, Algorithm: PBEWITHSHA256AND256BITAES-CBC-BC, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithSHA256And256BitAESBC
    Aliases: PBEWITHSHA-256AND256BITAES-BC
   Service: KeyGenerator, Algorithm: HMACWHIRLPOOL, Class: org.bouncycastle.jcajce.provider.digest.Whirlpool$KeyGenerator
    Aliases: HMAC-WHIRLPOOL
   Service: KeyFactory, Algorithm: X.509, Class: org.bouncycastle.jcajce.provider.asymmetric.x509.KeyFactory
    Aliases: X509
   Service: KeyGenerator, Algorithm: HMACKECCAK288, Class: org.bouncycastle.jcajce.provider.digest.Keccak$KeyGenerator288
    Aliases: HMAC-KECCAK288
   Service: Signature, Algorithm: SHA3-384WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsaSha3_384
    Aliases: SHA3-384withDSA
   Service: SecretKeyFactory, Algorithm: OID.2.16.840.1.101.3.4.1, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyFactory
   Service: AlgorithmParameters, Algorithm: ZUC-256, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$AlgParams
   Service: Mac, Algorithm: ISO9797ALG3WITHISO7816-4PADDING, Class: org.bouncycastle.jcajce.provider.symmetric.DES$DES9797Alg3with7816d4
    Aliases: ISO9797ALG3MACWITHISO7816-4PADDING
   Service: Mac, Algorithm: Skein-MAC-256-160, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_256_160
   Service: KeyAgreement, Algorithm: ECCDHWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$CDHwithSHA256KDFAndSharedInfo
   Service: KeyGenerator, Algorithm: HMACSkein-512-224, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_512_224
    Aliases: HMAC-Skein-512-224
   Service: Cipher, Algorithm: VMPC, Class: org.bouncycastle.jcajce.provider.symmetric.VMPC$Base
   Service: KeyAgreement, Algorithm: X448UWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448UwithSHA512KDF
   Service: Signature, Algorithm: SHA3-224WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA3_224
    Aliases: SHA3-224WithRSAEncryption
   Service: AlgorithmParameters, Algorithm: RIJNDAEL, Class: org.bouncycastle.jcajce.provider.symmetric.Rijndael$AlgParams
   Service: Mac, Algorithm: ZUC-256-64, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$ZucMac256_64
   Service: KeyAgreement, Algorithm: X25519WITHSHA512CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X25519withSHA512CKDF
   Service: KeyGenerator, Algorithm: HMACGOST3411-2012-256, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$KeyGenerator2012_256
    Aliases: HMAC/GOST3411-2012-256
   Service: Cipher, Algorithm: GOST28147, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$ECB
    Aliases: GOST-28147
   Service: KeyGenerator, Algorithm: Skein-MAC-256-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_256_128
    Aliases: Skein-MAC256/128
   Service: KeyGenerator, Algorithm: ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen
    Aliases: OID.1.2.410.200046.1.1.14
   Service: Signature, Algorithm: SHA384WITHDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$dsa384
    Aliases: SHA384withDSA
   Service: KeyAgreement, Algorithm: ECCDHUWITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$DHUwithSHA256CKDF
   Service: Mac, Algorithm: PBEWITHHMACSHA512, Class: org.bouncycastle.jcajce.provider.digest.SHA512$HashMac
   Service: KeyGenerator, Algorithm: Skein-MAC-1024-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMacKeyGenerator_1024_384
    Aliases: Skein-MAC1024/384
   Service: Signature, Algorithm: SHA3-256WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSASha3_256
   Service: Signature, Algorithm: SHA512(256)WITHRSA/X9.31, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.X931SignatureSpi$SHA512_256WithRSAEncryption
    Aliases: SHA512(256)WithRSA/X9.31
   Service: Signature, Algorithm: SHA224WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA224
    Aliases: 1.2.840.113549.1.1.14
   Service: Mac, Algorithm: Skein-MAC-1024-384, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_1024_384
   Service: Signature, Algorithm: SHA512WITHCVC-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA512
    Aliases: 0.4.0.127.0.7.2.2.2.2.5
   Service: KeyGenerator, Algorithm: HMACKECCAK256, Class: org.bouncycastle.jcajce.provider.digest.Keccak$KeyGenerator256
    Aliases: HMAC-KECCAK256
   Service: SecretKeyFactory, Algorithm: PBEWITHMD2ANDDES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$PBEWithMD2KeyFactory
    Aliases: PBEWITHMD2ANDDES-CBC
   Service: Mac, Algorithm: HMACSHA512, Class: org.bouncycastle.jcajce.provider.digest.SHA512$HashMac
   Service: KeyPairGenerator, Algorithm: ED448, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$Ed448
    Aliases: 1.3.101.113
   Service: KeyGenerator, Algorithm: HMACSHA512/256, Class: org.bouncycastle.jcajce.provider.digest.SHA512$KeyGeneratorT256
    Aliases: HMAC/SHA512/256
   Service: MessageDigest, Algorithm: Tiger, Class: org.bouncycastle.jcajce.provider.digest.Tiger$Digest
   Service: Cipher, Algorithm: DSTU7624, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$ECB_128
   Service: Signature, Algorithm: SHA224WITHCVC-ECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecCVCDSA224
    Aliases: 0.4.0.127.0.7.2.2.2.2.2
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.3.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CFB512
   Service: Mac, Algorithm: Threefish-512CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$CMAC_512
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CFB256
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.3.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CFB128
   Service: Mac, Algorithm: ZUC-128, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$ZucMac128
   Service: AlgorithmParameters, Algorithm: HC128, Class: org.bouncycastle.jcajce.provider.symmetric.HC128$AlgParams
   Service: Mac, Algorithm: DESWITHISO9797, Class: org.bouncycastle.jcajce.provider.symmetric.DES$DES9797Alg3
    Aliases: DESISO9797MAC
   Service: KeyGenerator, Algorithm: Twofish, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$KeyGen
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.6.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.6.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: AES, Class: org.bouncycastle.jcajce.provider.symmetric.AES$KeyGen
   Service: KeyGenerator, Algorithm: 1.2.804.2.1.1.1.1.1.3.6.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
   Service: KeyPairGenerator, Algorithm: ECGOST3410-2012, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.KeyPairGeneratorSpi
    Aliases: GOST-3410-2012
   Service: Mac, Algorithm: Skein-MAC-256-128, Class: org.bouncycastle.jcajce.provider.digest.Skein$SkeinMac_256_128
   Service: Cipher, Algorithm: RSA/2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding_PublicOnly
   Service: Signature, Algorithm: OID.1.2.840.113549.1.1.10, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$PSSwithRSA
   Service: Cipher, Algorithm: RSA/1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding_PrivateOnly
   Service: Mac, Algorithm: ZUC-256-32, Class: org.bouncycastle.jcajce.provider.symmetric.Zuc$ZucMac256_32
   Service: SecretKeyFactory, Algorithm: PBKDF-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.OpenSSLPBKDF$PBKDF
   Service: X509StreamParser, Algorithm: CERTIFICATE, Class: org.bouncycastle.jce.provider.X509CertParser
   Service: Signature, Algorithm: SHA512WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA512withRSA
    Aliases: SHA512withRSAandMGF1
   Service: Cipher, Algorithm: XSALSA20, Class: org.bouncycastle.jcajce.provider.symmetric.XSalsa20$Base
   Service: KeyPairGenerator, Algorithm: RSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.KeyPairGeneratorSpi
   Service: KeyAgreement, Algorithm: ECMQV, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQV
    Aliases: 1.3.133.16.840.63.0.16
   Service: Signature, Algorithm: GOST3411-2012-512WITHECGOST3410-2012-512, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost12.ECGOST2012SignatureSpi512
    Aliases: OID.1.2.643.7.1.1.3.3
   Service: Mac, Algorithm: DSTU7624-128GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$GMAC128
    Aliases: 1.2.804.2.1.1.1.1.1.3.7.1
   Service: X509StreamParser, Algorithm: CERTIFICATEPAIR, Class: org.bouncycastle.jce.provider.X509CertPairParser
   Service: AlgorithmParameters, Algorithm: ECGOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.AlgorithmParametersSpi
    Aliases: 1.2.643.2.2.96
   Service: KeyGenerator, Algorithm: SM4-CMAC, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$KeyGen
    Aliases: SM4CMAC
   Service: Mac, Algorithm: RC2MAC/CFB8, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$CFB8MAC
    Aliases: RC2/CFB8
   Service: SecretKeyFactory, Algorithm: PBEWITHHMACSHA256, Class: org.bouncycastle.jcajce.provider.digest.SHA256$PBEWithMacKeyFactory
   Service: Signature, Algorithm: SHA384WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSA384
    Aliases: SHA384WITHDETECDSA
   Service: SecretKeyFactory, Algorithm: PBEWITHMD5AND128BITAES-CBC-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithMD5And128BitAESCBCOpenSSL
   Service: Mac, Algorithm: DSTU7624-512GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$GMAC512
    Aliases: 1.2.804.2.1.1.1.1.1.3.7.3
   Service: Signature, Algorithm: RMD160WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$RIPEMD160
   Service: Cipher, Algorithm: CAMELLIA, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$ECB
   Service: KeyAgreement, Algorithm: X448WITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448withSHA512KDF
   Service: KeyGenerator, Algorithm: HMACKECCAK224, Class: org.bouncycastle.jcajce.provider.digest.Keccak$KeyGenerator224
    Aliases: HMAC-KECCAK224
   Service: KeyGenerator, Algorithm: OID.1.2.392.200011.61.1.1.3.4, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.392.200011.61.1.1.3.3, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen192
   Service: KeyGenerator, Algorithm: HMACSHA512/224, Class: org.bouncycastle.jcajce.provider.digest.SHA512$KeyGeneratorT224
    Aliases: HMAC/SHA512/224
   Service: KeyGenerator, Algorithm: OID.1.2.392.200011.61.1.1.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen128
   Service: Signature, Algorithm: SHA3-224WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSASha3_224
   Service: Cipher, Algorithm: RC2WRAP, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$Wrap
    Aliases: OID.1.2.840.113549.1.9.16.3.7
   Service: Cipher, Algorithm: PBEWITHSHAAND40BITRC4, Class: org.bouncycastle.jcajce.provider.symmetric.ARC4$PBEWithSHAAnd40Bit
    Aliases: 1.2.840.113549.1.12.1.2
   Service: KeyPairGenerator, Algorithm: EC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyPairGeneratorSpi$EC
    Aliases: 1.3.132.1.14.0
   Service: SecretKeyFactory, Algorithm: SEED, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$KeyFactory
    Aliases: OID.1.2.410.200004.1.4
   Service: KeyGenerator, Algorithm: SHACAL-2, Class: org.bouncycastle.jcajce.provider.symmetric.Shacal2$KeyGen
   Service: AlgorithmParameters, Algorithm: CAST6, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$AlgParams
   Service: AlgorithmParameters, Algorithm: CAST5, Class: org.bouncycastle.jcajce.provider.symmetric.CAST5$AlgParams
   Service: KeyPairGenerator, Algorithm: DH, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyPairGeneratorSpi
    Aliases: 1.2.840.10046.2.1
   Service: KeyGenerator, Algorithm: HMACSkein-512-512, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_512_512
    Aliases: HMAC/Skein-512-512
   Service: KeyGenerator, Algorithm: POLY1305-ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$Poly1305KeyGen
    Aliases: POLY1305ARIA
   Service: Signature, Algorithm: SHA3-224WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA3_224withRSA
    Aliases: SHA3-224withRSAandMGF1
   Service: MessageDigest, Algorithm: SHA3-256, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest256
   Service: KeyGenerator, Algorithm: ARC4, Class: org.bouncycastle.jcajce.provider.symmetric.ARC4$KeyGen
    Aliases: RC4
   Service: SecretKeyFactory, Algorithm: TLS12WITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.symmetric.TLSKDF$TLS12withSHA512
   Service: KeyAgreement, Algorithm: ECKAEGWITHSHA256KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$ECKAEGwithSHA256KDF
   Service: KeyGenerator, Algorithm: Threefish-256, Class: org.bouncycastle.jcajce.provider.symmetric.Threefish$KeyGen_256
   Service: KeyFactory, Algorithm: ECDHC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyFactorySpi$ECDHC
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSM3, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSM3
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA512KDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA512KDF
   Service: AlgorithmParameters, Algorithm: PBKDF2, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$AlgParams
    Aliases: PBKDF2WITHHMACSHA1ANDUTF8
   Service: AlgorithmParameters, Algorithm: PBKDF1, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF1$AlgParams
    Aliases: 1.2.840.113549.1.5.1
   Service: Cipher, Algorithm: GOST3412-2015/CFB8, Class: org.bouncycastle.jcajce.provider.symmetric.GOST3412_2015$GCFB8
   Service: AlgorithmParameters, Algorithm: SM4, Class: org.bouncycastle.jcajce.provider.symmetric.SM4$AlgParams
   Service: Signature, Algorithm: SHA3-512WITHDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.DSASigner$detDSASha3_512
   Service: Signature, Algorithm: SHA512(256)WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA512_256
    Aliases: SHA512(256)/RSA
   Service: Signature, Algorithm: GOST3411WITHECGOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.ecgost.SignatureSpi
    Aliases: GOST3411WithECGOST3410
   Service: KeyGenerator, Algorithm: GOST28147, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$KeyGen
    Aliases: GOST-28147
   Service: MessageDigest, Algorithm: KECCAK-288, Class: org.bouncycastle.jcajce.provider.digest.Keccak$Digest288
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.6.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$OFB512
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.6.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$OFB256
   Service: Cipher, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.6.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$OFB128
   Service: Cipher, Algorithm: CHACHA20-POLY1305, Class: org.bouncycastle.jcajce.provider.symmetric.ChaCha$BaseCC20P1305
   Service: Cipher, Algorithm: SM2WITHMD5, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.GMCipherSpi$SM2withMD5
    Aliases: 1.2.156.10197.1.301.3.2.11
   Service: KeyAgreement, Algorithm: X448WITHSHA256CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyAgreementSpi$X448withSHA256CKDF
   Service: KeyGenerator, Algorithm: TEA, Class: org.bouncycastle.jcajce.provider.symmetric.TEA$KeyGen
   Service: KeyGenerator, Algorithm: DES, Class: org.bouncycastle.jcajce.provider.symmetric.DES$KeyGenerator
   Service: Cipher, Algorithm: ARIAGCM, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$GCM
   Service: Signature, Algorithm: ECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSA
    Aliases: DETECDSA
   Service: Cipher, Algorithm: 2.5.8.1.1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding
   Service: Cipher, Algorithm: BLOWFISH, Class: org.bouncycastle.jcajce.provider.symmetric.Blowfish$ECB
   Service: KeyAgreement, Algorithm: DH, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi
    Attributes:
      SupportedKeyClasses: javax.crypto.interfaces.DHPublicKey|javax.crypto.interfaces.DHPrivateKey
   Service: Cipher, Algorithm: SEEDWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.SEED$Wrap
    Aliases: SEEDKW
   Service: Signature, Algorithm: SHA3-256WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA3_256
    Aliases: SHA3-256withRSA
   Service: Cipher, Algorithm: OID.1.2.840.113549.1.1.7, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$OAEPPadding
   Service: MessageDigest, Algorithm: SHA3-224, Class: org.bouncycastle.jcajce.provider.digest.SHA3$Digest224
   Service: Cipher, Algorithm: OID.1.2.840.113549.1.1.1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.CipherSpi$PKCS1v1_5Padding
   Service: Mac, Algorithm: SKIPJACKMAC/CFB8, Class: org.bouncycastle.jcajce.provider.symmetric.Skipjack$MacCFB8
    Aliases: SKIPJACK/CFB8
   Service: Mac, Algorithm: VMPCMAC, Class: org.bouncycastle.jcajce.provider.symmetric.VMPC$Mac
    Aliases: VMPC
   Service: SecretKeyFactory, Algorithm: PBEWITHMD5AND192BITAES-CBC-OPENSSL, Class: org.bouncycastle.jcajce.provider.symmetric.AES$PBEWithMD5And192BitAESCBCOpenSSL
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA3-256, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA3_256
   Service: KeyGenerator, Algorithm: HMACGOST3411-2012-512, Class: org.bouncycastle.jcajce.provider.digest.GOST3411$KeyGenerator2012_512
    Aliases: HMAC/GOST3411-2012-512
   Service: Cipher, Algorithm: HC256, Class: org.bouncycastle.jcajce.provider.symmetric.HC256$Base
   Service: Signature, Algorithm: SHA256WITHECDDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDetDSA256
    Aliases: SHA256WITHDETECDSA
   Service: KeyAgreement, Algorithm: MQVWITHSHA384CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyAgreementSpi$MQVwithSHA384CKDF
   Service: KeyGenerator, Algorithm: POLY1305-RC6, Class: org.bouncycastle.jcajce.provider.symmetric.RC6$Poly1305KeyGen
    Aliases: POLY1305RC6
   Service: Signature, Algorithm: SHA256WITHRSAANDMGF1, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.PSSSignatureSpi$SHA256withRSA
    Aliases: SHA256withRSA/PSS
   Service: Signature, Algorithm: SHA384WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSA384
    Aliases: SHA384/ECDSA
   Service: AlgorithmParameters, Algorithm: GOST3410, Class: org.bouncycastle.jcajce.provider.asymmetric.gost.AlgorithmParametersSpi
    Aliases: GOST-3410
   Service: Signature, Algorithm: SHA512WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSA512
    Aliases: OID.1.2.840.10045.4.3.4
   Service: KeyFactory, Algorithm: ElGamal, Class: org.bouncycastle.jcajce.provider.asymmetric.elgamal.KeyFactorySpi
   Service: KeyPairGenerator, Algorithm: ED25519, Class: org.bouncycastle.jcajce.provider.asymmetric.edec.KeyPairGeneratorSpi$Ed25519
   Service: Signature, Algorithm: SHA256WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA256
   Service: MessageDigest, Algorithm: KECCAK-256, Class: org.bouncycastle.jcajce.provider.digest.Keccak$Digest256
   Service: KeyFactory, Algorithm: EC, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyFactorySpi$EC
   Service: Signature, Algorithm: MD4WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$MD4
    Aliases: MD4WITHRSAENCRYPTION
   Service: AlgorithmParameterGenerator, Algorithm: DSA, Class: org.bouncycastle.jcajce.provider.asymmetric.dsa.AlgorithmParameterGeneratorSpi
   Service: KeyGenerator, Algorithm: HC256, Class: org.bouncycastle.jcajce.provider.symmetric.HC256$KeyGen
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.45, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.44, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.43, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.42, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.41, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.40, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: AlgorithmParameterGenerator, Algorithm: DSTU7624, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$AlgParamGen128
   Service: KeyGenerator, Algorithm: HMACKECCAK512, Class: org.bouncycastle.jcajce.provider.digest.Keccak$KeyGenerator512
    Aliases: HMAC-KECCAK512
   Service: Signature, Algorithm: SHA512(224)WITHRSA, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.DigestSignatureSpi$SHA512_224
    Aliases: SHA512(224)WithRSA
   Service: KeyGenerator, Algorithm: CAST6-GMAC, Class: org.bouncycastle.jcajce.provider.symmetric.CAST6$KeyGen
    Aliases: CAST6GMAC
   Service: Cipher, Algorithm: OID.1.2.840.113549.3.7, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$CBC
   Service: Signature, Algorithm: RIPEMD160WITHECDSA, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.SignatureSpi$ecDSARipeMD160
    Aliases: OID.1.3.36.3.3.2.2
   Service: KeyGenerator, Algorithm: HMACSHA3-384, Class: org.bouncycastle.jcajce.provider.digest.SHA3$KeyGenerator384
    Aliases: HMAC-SHA3-384
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.3.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CFB512
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CFB256
   Service: Cipher, Algorithm: 1.2.804.2.1.1.1.1.1.3.3.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$CFB128
   Service: Cipher, Algorithm: OID.1.2.840.113549.3.2, Class: org.bouncycastle.jcajce.provider.symmetric.RC2$CBC
   Service: KeyFactory, Algorithm: DH, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.KeyFactorySpi
   Service: Cipher, Algorithm: DHIES, Class: org.bouncycastle.jcajce.provider.asymmetric.dh.IESCipher$IES
   Service: KeyGenerator, Algorithm: HMACSkein-256-256, Class: org.bouncycastle.jcajce.provider.digest.Skein$HMacKeyGenerator_256_256
    Aliases: HMAC-Skein-256-256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.39, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.38, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.37, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.36, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.35, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen192
   Service: Cipher, Algorithm: DESEDEWRAP, Class: org.bouncycastle.jcajce.provider.symmetric.DESede$Wrap
    Aliases: DESEDERFC3217WRAP
   Service: KeyGenerator, Algorithm: OID.1.2.410.200046.1.1.34, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$KeyGen128
   Service: Mac, Algorithm: DESCMAC, Class: org.bouncycastle.jcajce.provider.symmetric.DES$CMAC
   Service: Cipher, Algorithm: 1.2.643.2.2.21, Class: org.bouncycastle.jcajce.provider.symmetric.GOST28147$GCFB
   Service: KeyGenerator, Algorithm: 1.2.392.200011.61.1.1.1.4, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen256
   Service: KeyGenerator, Algorithm: 1.2.392.200011.61.1.1.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen192
   Service: KeyGenerator, Algorithm: 1.2.392.200011.61.1.1.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.Camellia$KeyGen128
   Service: KeyAgreement, Algorithm: ECMQVWITHSHA224CKDF, Class: org.bouncycastle.jcajce.provider.asymmetric.ec.KeyAgreementSpi$MQVwithSHA224CKDF
   Service: Cipher, Algorithm: PBEWITHSHAANDTWOFISH-CBC, Class: org.bouncycastle.jcajce.provider.symmetric.Twofish$PBEWithSHA
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.44, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CFB
   Service: SecretKeyFactory, Algorithm: PBKDF2WITHHMACSHA3-224, Class: org.bouncycastle.jcajce.provider.symmetric.PBEPBKDF2$PBKDF2withSHA3_224
   Service: Signature, Algorithm: WHIRLPOOLWITHRSA/ISO9796-2, Class: org.bouncycastle.jcajce.provider.asymmetric.rsa.ISOSignatureSpi$WhirlpoolWithRSAEncryption
    Aliases: WHIRLPOOLWithRSA/ISO9796-2
   Service: AlgorithmParameters, Algorithm: ARIA, Class: org.bouncycastle.jcajce.provider.symmetric.ARIA$AlgParams
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.43, Class: org.bouncycastle.jcajce.provider.symmetric.AES$OFB
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.42, Class: org.bouncycastle.jcajce.provider.symmetric.AES$CBC
   Service: Cipher, Algorithm: 2.16.840.1.101.3.4.1.41, Class: org.bouncycastle.jcajce.provider.symmetric.AES$ECB
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.1.3, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen512
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.1.2, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen256
   Service: KeyGenerator, Algorithm: OID.1.2.804.2.1.1.1.1.1.3.1.1, Class: org.bouncycastle.jcajce.provider.symmetric.DSTU7624$KeyGen128
