Part Number: TMS320F28335
Flash Programmer: Error encountered when writing to flash memory
screenshot from CCS:
screenshot from UNIFLASH:
Hi Gudivada,
Here is the screenshot of console.I pressed the "Unlock" botton first then I press the "Erase Flash" botton.
Any answer will be appreciate.
Andy.
Cheng-an,
Not sure from your last post, if you mean that it is working or not; i.e. a different .out file works OK but the original is the issue. Please confirm.
Can you comment on the development board you are using, is it the controlCARD or a custom PCB? There is a section of the Flash tool to set the input clock, we first should make sure that this matches the setting in CCS/Uniflash.
Matthew
Hi MatthewPate,
I just check my input clock, I found that my input clock OSC has welding mistakes.
Andy.
