Part Number: TMS320F28388D
Hello everyone
I am using the TMS320F28388D control card to control a power electronic converter that is connected to a PC via TCP. On the F28388D I am running the lwIP TCP/IP stack but I have the issue that the Control Manager (CM) enters FaultISR() after around 10 minutes of operation and I loose communication to the device. (The exact time when the Fault occurs seems to vary from time to time, sometimes the TCP connection works fine for 25min before the fault and sometimes only 5min).
I found the document AN01286 ("Diagnosing Software Faults in Stellaris® Microcontrollers") but I'm not sure if that is the correct reference for this microcontroller?
The document mentions (section 3.2.1) examining the "NVIC_FAULT_STAT" register with the debugger as a first step but I cannot find such a register?
I attach a record of all the registers that I took with the debugger,
521177 14
R PC 0x0000000B 0x00214BDE
R SP 0x0000000B 0x1FFFC5F0
R LR 0x0000000B 0xFFFFFFF1
R xPSR 0x0000000B 0x01000003
R R0 0x0000000B 0x00989680
R R1 0x0000000B 0x00000000
R R2 0x0000000B 0x2000B4F8
R R3 0x0000000B 0x00989680
R R4 0x0000000B 0x00000048
R R5 0x0000000B 0x00000000
R R6 0x0000000B 0x00000024
R R7 0x0000000B 0x2000B4C8
R R8 0x0000000B 0x00000280
R R9 0x0000000B 0x2000B740
R R10 0x0000000B 0x2000B534
R R11 0x0000000B 0x2000B6CC
R R12 0x0000000B 0x2000B084
R R13 0x0000000B 0x1FFFC5F0
R R14 0x0000000B 0xFFFFFFF1
R MSP 0x0000000B 0x1FFFC5F0
R PSP 0x0000000B 0x00000000
R DSP 0x0000000B 0x00000000
R CTRL_FAULT_BASE_PRI 0x0000000B 0x00000000
R AES_AES_KEY2_6 0x0000000B 0x00000000
R AES_AES_KEY2_7 0x0000000B 0x00000000
R AES_AES_KEY2_4 0x0000000B 0x00000000
R AES_AES_KEY2_5 0x0000000B 0x00000000
R AES_AES_KEY2_2 0x0000000B 0x00000000
R AES_AES_KEY2_3 0x0000000B 0x00000000
R AES_AES_KEY2_0 0x0000000B 0x00000000
R AES_AES_KEY2_1 0x0000000B 0x00000000
R AES_AES_KEY1_6 0x0000000B 0x00000000
R AES_AES_KEY1_7 0x0000000B 0x00000000
R AES_AES_KEY1_4 0x0000000B 0x00000000
R AES_AES_KEY1_5 0x0000000B 0x00000000
R AES_AES_KEY1_2 0x0000000B 0x00000000
R AES_AES_KEY1_3 0x0000000B 0x00000000
R AES_AES_KEY1_0 0x0000000B 0x00000000
R AES_AES_KEY1_1 0x0000000B 0x00000000
R AES_AES_IV_IN_OUT_0 0x0000000B 0x00000000
R AES_AES_IV_IN_OUT_1 0x0000000B 0x00000000
R AES_AES_IV_IN_OUT_2 0x0000000B 0x00000000
R AES_AES_IV_IN_OUT_3 0x0000000B 0x00000000
R AES_AES_CTRL 0x0000000B 0x00000000
R AES_AES_C_LENGTH_0 0x0000000B 0x00000000
R AES_AES_C_LENGTH_1 0x0000000B 0x00000000
R AES_AES_AUTH_LENGTH 0x0000000B 0x00000000
R AES_AES_DATA_IN_OUT_0 0x0000000B 0x00000000
R AES_AES_DATA_IN_OUT_1 0x0000000B 0x00000000
R AES_AES_DATA_IN_OUT_2 0x0000000B 0x00000000
R AES_AES_DATA_IN_OUT_3 0x0000000B 0x00000000
R AES_AES_TAG_OUT_0 0x0000000B 0x00000000
R AES_AES_TAG_OUT_1 0x0000000B 0x00000000
R AES_AES_TAG_OUT_2 0x0000000B 0x00000000
R AES_AES_TAG_OUT_3 0x0000000B 0x00000000
R AES_AES_REV 0x0000000B 0x00000000
R AES_AES_SYSCONFIG 0x0000000B 0x00000000
R AES_AES_SYSSTATUS 0x0000000B 0x00000000
R AES_AES_IRQSTATUS 0x0000000B 0x00000000
R AES_AES_IRQENABLE 0x0000000B 0x00000000
R AES_AES_DIRTY_BITS 0x0000000B 0x00000000
R AES_SS_AESDMAINTEN 0x0000000B 0x00000000
R AES_SS_AESDMASTATUS 0x0000000B 0x00000000
R AES_SS_AESDMASTATUSCLR 0x0000000B 0x00000000
R CANA_CAN_CTL 0x0000000B 0x00000000
R CANA_CAN_ES 0x0000000B 0x00000000
R CANA_CAN_ERRC 0x0000000B 0x00000000
R CANA_CAN_BTR 0x0000000B 0x00000000
R CANA_CAN_INT 0x0000000B 0x00000000
R CANA_CAN_TEST 0x0000000B 0x00000000
R CANA_CAN_PERR 0x0000000B 0x00000000
R CANA_CAN_RAM_INIT 0x0000000B 0x00000000
R CANA_CAN_GLB_INT_EN 0x0000000B 0x00000000
R CANA_CAN_GLB_INT_FLG 0x0000000B 0x00000000
R CANA_CAN_GLB_INT_CLR 0x0000000B 0x00000000
R CANA_CAN_ABOTR 0x0000000B 0x00000000
R CANA_CAN_TXRQ_X 0x0000000B 0x00000000
R CANA_CAN_TXRQ_21 0x0000000B 0x00000000
R CANA_CAN_NDAT_X 0x0000000B 0x00000000
R CANA_CAN_NDAT_21 0x0000000B 0x00000000
R CANA_CAN_IPEN_X 0x0000000B 0x00000000
R CANA_CAN_IPEN_21 0x0000000B 0x00000000
R CANA_CAN_MVAL_X 0x0000000B 0x00000000
R CANA_CAN_MVAL_21 0x0000000B 0x00000000
R CANA_CAN_IP_MUX21 0x0000000B 0x00000000
R CANA_CAN_IF1CMD 0x0000000B 0x00000000
R CANA_CAN_IF1MSK 0x0000000B 0x00000000
R CANA_CAN_IF1ARB 0x0000000B 0x00000000
R CANA_CAN_IF1MCTL 0x0000000B 0x00000000
R CANA_CAN_IF1DATA 0x0000000B 0x00000000
R CANA_CAN_IF1DATB 0x0000000B 0x00000000
R CANA_CAN_IF2CMD 0x0000000B 0x00000000
R CANA_CAN_IF2MSK 0x0000000B 0x00000000
R CANA_CAN_IF2ARB 0x0000000B 0x00000000
R CANA_CAN_IF2MCTL 0x0000000B 0x00000000
R CANA_CAN_IF2DATA 0x0000000B 0x00000000
R CANA_CAN_IF2DATB 0x0000000B 0x00000000
R CANA_CAN_IF3OBS 0x0000000B 0x00000000
R CANA_CAN_IF3MSK 0x0000000B 0x00000000
R CANA_CAN_IF3ARB 0x0000000B 0x00000000
R CANA_CAN_IF3MCTL 0x0000000B 0x00000000
R CANA_CAN_IF3DATA 0x0000000B 0x00000000
R CANA_CAN_IF3DATB 0x0000000B 0x00000000
R CANA_CAN_IF3UPD 0x0000000B 0x00000000
R CANB_CAN_CTL 0x0000000B 0x00000000
R CANB_CAN_ES 0x0000000B 0x00000000
R CANB_CAN_ERRC 0x0000000B 0x00000000
R CANB_CAN_BTR 0x0000000B 0x00000000
R CANB_CAN_INT 0x0000000B 0x00000000
R CANB_CAN_TEST 0x0000000B 0x00000000
R CANB_CAN_PERR 0x0000000B 0x00000000
R CANB_CAN_RAM_INIT 0x0000000B 0x00000000
R CANB_CAN_GLB_INT_EN 0x0000000B 0x00000000
R CANB_CAN_GLB_INT_FLG 0x0000000B 0x00000000
R CANB_CAN_GLB_INT_CLR 0x0000000B 0x00000000
R CANB_CAN_ABOTR 0x0000000B 0x00000000
R CANB_CAN_TXRQ_X 0x0000000B 0x00000000
R CANB_CAN_TXRQ_21 0x0000000B 0x00000000
R CANB_CAN_NDAT_X 0x0000000B 0x00000000
R CANB_CAN_NDAT_21 0x0000000B 0x00000000
R CANB_CAN_IPEN_X 0x0000000B 0x00000000
R CANB_CAN_IPEN_21 0x0000000B 0x00000000
R CANB_CAN_MVAL_X 0x0000000B 0x00000000
R CANB_CAN_MVAL_21 0x0000000B 0x00000000
R CANB_CAN_IP_MUX21 0x0000000B 0x00000000
R CANB_CAN_IF1CMD 0x0000000B 0x00000000
R CANB_CAN_IF1MSK 0x0000000B 0x00000000
R CANB_CAN_IF1ARB 0x0000000B 0x00000000
R CANB_CAN_IF1MCTL 0x0000000B 0x00000000
R CANB_CAN_IF1DATA 0x0000000B 0x00000000
R CANB_CAN_IF1DATB 0x0000000B 0x00000000
R CANB_CAN_IF2CMD 0x0000000B 0x00000000
R CANB_CAN_IF2MSK 0x0000000B 0x00000000
R CANB_CAN_IF2ARB 0x0000000B 0x00000000
R CANB_CAN_IF2MCTL 0x0000000B 0x00000000
R CANB_CAN_IF2DATA 0x0000000B 0x00000000
R CANB_CAN_IF2DATB 0x0000000B 0x00000000
R CANB_CAN_IF3OBS 0x0000000B 0x00000000
R CANB_CAN_IF3MSK 0x0000000B 0x00000000
R CANB_CAN_IF3ARB 0x0000000B 0x00000000
R CANB_CAN_IF3MCTL 0x0000000B 0x00000000
R CANB_CAN_IF3DATA 0x0000000B 0x00000000
R CANB_CAN_IF3DATB 0x0000000B 0x00000000
R CANB_CAN_IF3UPD 0x0000000B 0x00000000
R ERRORLOG_UCERRFLG 0x0000000B 0x00000000
R ERRORLOG_UCERRSET 0x0000000B 0x00000000
R ERRORLOG_UCERRCLR 0x0000000B 0x00000000
R ERRORLOG_UCM4EADDR 0x0000000B 0x00000000
R ERRORLOG_UCEMACEADDR 0x0000000B 0x00000000
R ERRORLOG_UCuDMAEADDR 0x0000000B 0x00000000
R ERRORLOG_UCEtherCATMEMREADDR 0x0000000B 0x00000000
R ERRORLOG_UCEMACMEMREADDR 0x0000000B 0x00000000
R ERRORLOG_BUSFAULTFLG 0x0000000B 0x00000001
R ERRORLOG_BUSFAULTCLR 0x0000000B 0x00000000
R ERRORLOG_M4BUSFAULTADDR 0x0000000B 0x00989684
R ERRORLOG_uDMABUSFAULTADDR 0x0000000B 0x00000000
R ERRORLOG_EMACBUSFAULTADDR 0x0000000B 0x00000000
R ERRORLOG_CERRFLG 0x0000000B 0x00000000
R ERRORLOG_CERRSET 0x0000000B 0x00000000
R ERRORLOG_CERRCLR 0x0000000B 0x00000000
R ERRORLOG_CM4EADDR 0x0000000B 0x00000000
R ERRORLOG_CEMACEADDR 0x0000000B 0x00000000
R ERRORLOG_CuDMAEADDR 0x0000000B 0x00000000
R ERRORLOG_CERRCNT 0x0000000B 0x00000000
R ERRORLOG_CERRTHRES 0x0000000B 0x00000000
R ERRORLOG_CEINTFLG 0x0000000B 0x00000000
R ERRORLOG_CEINTSET 0x0000000B 0x00000000
R ERRORLOG_CEINTCLR 0x0000000B 0x00000000
R ERRORLOG_CEINTEN 0x0000000B 0x00000000
R DcsmCommonRegs_FLSEM 0x0000000B 0x00000000
R DcsmCommonRegs_SECTSTAT1 0x0000000B 0x0FFFFFFF
R DcsmCommonRegs_SECTSTAT2 0x0000000B 0x0FFFFFFF
R DcsmCommonRegs_SECTSTAT3 0x0000000B 0x0FFFFFFF
R DcsmCommonRegs_RAMSTAT1 0x0000000B 0x000FFFFF
R DcsmCommonRegs_RAMSTAT2 0x0000000B 0xFFFFFF0F
R DcsmCommonRegs_RAMSTAT3 0x0000000B 0x000FFFFF
R DcsmCommonRegs_SECERRSTAT 0x0000000B 0x00000000
R DcsmCommonRegs_SECERRCLR 0x0000000B 0x00000000
R DcsmCommonRegs_SECERRFRC 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_LINKPOINTER 0x0000000B 0xFFFFFFFF
R DcsmZ1Regs_Z1_OTPSECLOCK 0x0000000B 0x00000FF0
R DcsmZ1Regs_Z1_JLM_ENABLE 0x0000000B 0x0000000F
R DcsmZ1Regs_Z1_LINKPOINTERERR 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_GPREG1 0x0000000B 0xFFFFFFFF
R DcsmZ1Regs_Z1_GPREG2 0x0000000B 0xFFFFFFFF
R DcsmZ1Regs_Z1_GPREG3 0x0000000B 0xFFFFFFFF
R DcsmZ1Regs_Z1_GPREG4 0x0000000B 0xFFFFFFFF
R DcsmZ1Regs_Z1_CSMKEY0 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CSMKEY1 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CSMKEY2 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CSMKEY3 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CR 0x0000000B 0x0060000F
R DcsmZ1Regs_Z1_GRABSECT1R 0x0000000B 0x0FFFFFFF
R DcsmZ1Regs_Z1_GRABSECT2R 0x0000000B 0x0FFFFFFF
R DcsmZ1Regs_Z1_GRABSECT3R 0x0000000B 0x0FFFFFFF
R DcsmZ1Regs_Z1_GRABRAM1R 0x0000000B 0x000FFFFF
R DcsmZ1Regs_Z1_GRABRAM2R 0x0000000B 0xFFFFFF0F
R DcsmZ1Regs_Z1_GRABRAM3R 0x0000000B 0x000FFFFF
R DcsmZ1Regs_Z1_EXEONLYSECT1R 0x0000000B 0x3FFF3FFF
R DcsmZ1Regs_Z1_EXEONLYSECT2R 0x0000000B 0x00003FFF
R DcsmZ1Regs_Z1_EXEONLYRAM1R 0x0000000B 0xFFC303FF
R DcsmZ1Regs_Z1_JTAGKEY0 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_JTAGKEY1 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_JTAGKEY2 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_JTAGKEY3 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CMACKEY0 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CMACKEY1 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CMACKEY2 0x0000000B 0x00000000
R DcsmZ1Regs_Z1_CMACKEY3 0x0000000B 0x00000000
R DcsmZ2Regs_Z2_LINKPOINTER 0x0000000B 0xFFFFFFFF
R DcsmZ2Regs_Z2_OTPSECLOCK 0x0000000B 0x00000FF0
R DcsmZ2Regs_Z2_LINKPOINTERERR 0x0000000B 0x00000000
R DcsmZ2Regs_Z2_GPREG1 0x0000000B 0xFFFFFFFF
R DcsmZ2Regs_Z2_GPREG2 0x0000000B 0xFFFFFFFF
R DcsmZ2Regs_Z2_GPREG3 0x0000000B 0xFFFFFFFF
R DcsmZ2Regs_Z2_GPREG4 0x0000000B 0xFFFFFFFF
R DcsmZ2Regs_Z2_CSMKEY0 0x0000000B 0x00000000
R DcsmZ2Regs_Z2_CSMKEY1 0x0000000B 0x00000000
R DcsmZ2Regs_Z2_CSMKEY2 0x0000000B 0x00000000
R DcsmZ2Regs_Z2_CSMKEY3 0x0000000B 0x00000000
R DcsmZ2Regs_Z2_CR 0x0000000B 0x0060000F
R DcsmZ2Regs_Z2_GRABSECT1R 0x0000000B 0x0FFFFFFF
R DcsmZ2Regs_Z2_GRABSECT2R 0x0000000B 0x0FFFFFFF
R DcsmZ2Regs_Z2_GRABSECT3R 0x0000000B 0x0FFFFFFF
R DcsmZ2Regs_Z2_GRABRAM1R 0x0000000B 0x000FFFFF
R DcsmZ2Regs_Z2_GRABRAM2R 0x0000000B 0xFFFFFF0F
R DcsmZ2Regs_Z2_GRABRAM3R 0x0000000B 0x000FFFFF
R DcsmZ2Regs_Z2_EXEONLYSECT1R 0x0000000B 0x3FFF3FFF
R DcsmZ2Regs_Z2_EXEONLYSECT2R 0x0000000B 0x00003FFF
R DcsmZ2Regs_Z2_EXEONLYRAM1R 0x0000000B 0xFFC303FF
R DIAGERRORLOG_DIAGERRFLG 0x0000000B 0x00000000
R DIAGERRORLOG_DIAGERRCLR 0x0000000B 0x00000000
R DIAGERRORLOG_DIAGERRADDR 0x0000000B 0x00000000
R CSFR_MMSR 0x0000000D 0x00
R CSFR_BFSR 0x0000000D 0x82
R CSFR_UFSR 0x0000000F 0x0000
R ESCSS_ESCSS_IPREVNUM 0x0000000B 0x00000000
R ESCSS_ESCSS_INTR_RIS 0x0000000B 0x00000000
R ESCSS_ESCSS_INTR_MASK 0x0000000B 0x00000000
R ESCSS_ESCSS_INTR_MIS 0x0000000B 0x00000000
R ESCSS_ESCSS_INTR_CLR 0x0000000B 0x00000000
R ESCSS_ESCSS_INTR_SET 0x0000000B 0x00000000
R ESCSS_ESCSS_LATCH_SEL 0x0000000B 0x00000000
R ESCSS_ESCSS_ACCESS_CTRL 0x0000000B 0x00000000
R ESCSS_ESCSS_GPIN_DAT 0x0000000B 0x00000000
R ESCSS_ESCSS_GPIN_PIPE 0x0000000B 0x00000000
R ESCSS_ESCSS_GPIN_GRP_CAP_SEL 0x0000000B 0x00000000
R ESCSS_ESCSS_GPOUT_DAT 0x0000000B 0x00000000
R ESCSS_ESCSS_GPOUT_PIPE 0x0000000B 0x00000000
R ESCSS_ESCSS_GPOUT_GRP_CAP_SEL 0x0000000B 0x00000000
R ESCSS_ESCSS_MEM_TEST 0x0000000B 0x00000000
R ESCSS_ESCSS_RESET_DEST_CONFIG 0x0000000B 0x00000000
R ESCSS_ESCSS_SYNC0_CONFIG 0x0000000B 0x00000000
R ESCSS_ESCSS_SYNC1_CONFIG 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_CONFIG_LOCK 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_MISC_IO_CONFIG 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_PHY_IO_CONFIG 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_SYNC_IO_CONFIG 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_LATCH_IO_CONFIG 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_GPIN_SEL 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_GPIN_IOPAD_SEL 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_GPOUT_SEL 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_GPOUT_IOPAD_SEL 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_LED_CONFIG 0x0000000B 0x00000000
R ESCSSCONFIG_ESCSS_MISC_CONFIG 0x0000000B 0x00000000
R ETHERNET_MAC_Configuration 0x0000000B 0x0000A003
R ETHERNET_MAC_Ext_Configuration 0x0000000B 0x00000000
R ETHERNET_MAC_Packet_Filter 0x0000000B 0x00000000
R ETHERNET_MAC_Watchdog_Timeout 0x0000000B 0x00000000
R ETHERNET_MAC_Hash_Table_Reg0 0x0000000B 0x00000000
R ETHERNET_MAC_Hash_Table_Reg1 0x0000000B 0x00000000
R ETHERNET_MAC_VLAN_Tag_Ctrl 0x0000000B 0x00000000
R ETHERNET_MAC_VLAN_Tag_Data 0x0000000B 0x00000000
R ETHERNET_MAC_VLAN_Hash_Table 0x0000000B 0x00000000
R ETHERNET_MAC_VLAN_Incl 0x0000000B 0x00000000
R ETHERNET_MAC_Inner_VLAN_Incl 0x0000000B 0x00000000
R ETHERNET_MAC_Q0_Tx_Flow_Ctrl 0x0000000B 0x00000000
R ETHERNET_MAC_Rx_Flow_Ctrl 0x0000000B 0x00000000
R ETHERNET_MAC_RxQ_Ctrl4 0x0000000B 0x00000000
R ETHERNET_MAC_RxQ_Ctrl0 0x0000000B 0x0000000A
R ETHERNET_MAC_RxQ_Ctrl1 0x0000000B 0x00000000
R ETHERNET_MAC_RxQ_Ctrl2 0x0000000B 0x00000000
R ETHERNET_MAC_Interrupt_Status 0x0000000B 0x00040000
R ETHERNET_MAC_Interrupt_Enable 0x0000000B 0x00000000
R ETHERNET_MAC_Rx_Tx_Status 0x0000000B 0x00000000
R ETHERNET_MAC_PMT_Control_Status 0x0000000B 0x00000000
R ETHERNET_MAC_RWK_Packet_Filter 0x0000000B 0x00000000
R ETHERNET_MAC_LPI_Control_Status 0x0000000B 0x00000000
R ETHERNET_MAC_LPI_Timers_Control 0x0000000B 0x03E80000
R ETHERNET_MAC_LPI_Entry_Timer 0x0000000B 0x00000000
R ETHERNET_MAC_1US_Tic_Counter 0x0000000B 0x00000063
R ETHERNET_MAC_Version 0x0000000B 0x00000050
R ETHERNET_MAC_Debug 0x0000000B 0x00000000
R ETHERNET_MAC_HW_Feature0 0x0000000B 0x0E1D73F5
R ETHERNET_MAC_HW_Feature1 0x0000000B 0x218E3965
R ETHERNET_MAC_HW_Feature2 0x0000000B 0x22041041
R ETHERNET_MAC_HW_Feature3 0x0000000B 0x00320031
R ETHERNET_MAC_MDIO_Address 0x0000000B 0x0001080C
R ETHERNET_MAC_MDIO_Data 0x0000000B 0x0000FFFF
R ETHERNET_MAC_ARP_Address 0x0000000B 0x00000000
R ETHERNET_MAC_CSR_SW_Ctrl 0x0000000B 0x00000000
R ETHERNET_MAC_Ext_Cfg1 0x0000000B 0x00000002
R ETHERNET_MAC_Address0_High 0x0000000B 0x80008000
R ETHERNET_MAC_Address0_Low 0x0000000B 0x00F263A8
R ETHERNET_MAC_Address1_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address1_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MAC_Address2_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address2_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MAC_Address3_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address3_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MAC_Address4_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address4_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MAC_Address5_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address5_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MAC_Address6_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address6_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MAC_Address7_High 0x0000000B 0x0000FFFF
R ETHERNET_MAC_Address7_Low 0x0000000B 0xFFFFFFFF
R ETHERNET_MMC_Control 0x0000000B 0x00000000
R ETHERNET_MMC_Rx_Interrupt 0x0000000B 0x00000000
R ETHERNET_MMC_Tx_Interrupt 0x0000000B 0x00000000
R ETHERNET_MMC_Rx_Interrupt_Mask 0x0000000B 0x0FFFFFFF
R ETHERNET_MMC_Tx_Interrupt_Mask 0x0000000B 0x00000000
R ETHERNET_Tx_Octet_Count_Good_Bad 0x0000000B 0x005D21C0
R ETHERNET_Tx_Packet_Count_Good_Bad 0x0000000B 0x00017487
R ETHERNET_Tx_Broadcast_Packets_Good 0x0000000B 0x00000001
R ETHERNET_Tx_Multicast_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Tx_64Octets_Packets_Good_Bad 0x0000000B 0x00017487
R ETHERNET_Tx_65To127Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Tx_128To255Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Tx_256To511Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Tx_512To1023Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Tx_1024ToMaxOctets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Tx_Unicast_Packets_Good_Bad 0x0000000B 0x00017486
R ETHERNET_Tx_Multicast_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Tx_Broadcast_Packets_Good_Bad 0x0000000B 0x00000001
R ETHERNET_Tx_Underflow_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Single_Collision_Good_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Multiple_Collision_Good_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Deferred_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Late_Collision_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Excessive_Collision_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Carrier_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_Octet_Count_Good 0x0000000B 0x005D21C0
R ETHERNET_Tx_Packet_Count_Good 0x0000000B 0x00017487
R ETHERNET_Tx_Excessive_Deferral_Error 0x0000000B 0x00000000
R ETHERNET_Tx_Pause_Packets 0x0000000B 0x00000000
R ETHERNET_Tx_VLAN_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Tx_OSize_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Rx_Packets_Count_Good_Bad 0x0000000B 0x000174A8
R ETHERNET_Rx_Octet_Count_Good_Bad 0x0000000B 0x00B168A0
R ETHERNET_Rx_Octet_Count_Good 0x0000000B 0x00B168A0
R ETHERNET_Rx_Broadcast_Packets_Good 0x0000000B 0x00000016
R ETHERNET_Rx_Multicast_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Rx_CRC_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Alignment_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Runt_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Jabber_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Undersize_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Rx_Oversize_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Rx_64Octets_Packets_Good_Bad 0x0000000B 0x00000177
R ETHERNET_Rx_65To127Octets_Packets_Good_Bad 0x0000000B 0x00017329
R ETHERNET_Rx_128To255Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Rx_256To511Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Rx_512To1023Octets_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Rx_1024ToMaxOctets_Packets_Good_Bad 0x0000000B 0x00000008
R ETHERNET_Rx_Unicast_Packets_Good 0x0000000B 0x00017492
R ETHERNET_Rx_Length_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Out_Of_Range_Type_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Pause_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_FIFO_Overflow_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_VLAN_Packets_Good_Bad 0x0000000B 0x00000000
R ETHERNET_Rx_Watchdog_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Receive_Error_Packets 0x0000000B 0x00000000
R ETHERNET_Rx_Control_Packets_Good 0x0000000B 0x00000000
R ETHERNET_Tx_LPI_USEC_Cntr 0x0000000B 0x00000000
R ETHERNET_Tx_LPI_Tran_Cntr 0x0000000B 0x00000000
R ETHERNET_Rx_LPI_USEC_Cntr 0x0000000B 0x00000000
R ETHERNET_Rx_LPI_Tran_Cntr 0x0000000B 0x00000000
R ETHERNET_MMC_IPC_Rx_Interrupt_Mask 0x0000000B 0x3FFF3FFF
R ETHERNET_MMC_IPC_Rx_Interrupt 0x0000000B 0x00000000
R ETHERNET_RxIPv4_Good_Packets 0x0000000B 0x00017332
R ETHERNET_RxIPv4_Header_Error_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_No_Payload_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_Fragmented_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_UDP_Checksum_Disabled_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv6_Good_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv6_Header_Error_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv6_No_Payload_Packets 0x0000000B 0x00000000
R ETHERNET_RxUDP_Good_Packets 0x0000000B 0x00000003
R ETHERNET_RxUDP_Error_Packets 0x0000000B 0x00000000
R ETHERNET_RxTCP_Good_Packets 0x0000000B 0x0001732F
R ETHERNET_RxTCP_Error_Packets 0x0000000B 0x00000000
R ETHERNET_RxICMP_Good_Packets 0x0000000B 0x00000000
R ETHERNET_RxICMP_Error_Packets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_Good_Octets 0x0000000B 0x0096F196
R ETHERNET_RxIPv4_Header_Error_Octets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_No_Payload_Octets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_Fragmented_Octets 0x0000000B 0x00000000
R ETHERNET_RxIPv4_UDP_Checksum_Disable_Octets 0x0000000B 0x00000000
R ETHERNET_RxIPv6_Good_Octets 0x0000000B 0x00000000
R ETHERNET_RxIPv6_Header_Error_Octets 0x0000000B 0x00000000
R ETHERNET_RxIPv6_No_Payload_Octets 0x0000000B 0x00000000
R ETHERNET_RxUDP_Good_Octets 0x0000000B 0x000000AE
R ETHERNET_RxUDP_Error_Octets 0x0000000B 0x00000000
R ETHERNET_RxTCP_Good_Octets 0x0000000B 0x0079F100
R ETHERNET_RxTCP_Error_Octets 0x0000000B 0x00000000
R ETHERNET_RxICMP_Good_Octets 0x0000000B 0x00000000
R ETHERNET_RxICMP_Error_Octets 0x0000000B 0x00000000
R ETHERNET_MAC_L3_L4_Control0 0x0000000B 0x00000000
R ETHERNET_MAC_Layer4_Address0 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr0_Reg0 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr1_Reg0 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr2_Reg0 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr3_Reg0 0x0000000B 0x00000000
R ETHERNET_MAC_L3_L4_Control1 0x0000000B 0x00000000
R ETHERNET_MAC_Layer4_Address1 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr0_Reg1 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr1_Reg1 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr2_Reg1 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr3_Reg1 0x0000000B 0x00000000
R ETHERNET_MAC_L3_L4_Control2 0x0000000B 0x00000000
R ETHERNET_MAC_Layer4_Address2 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr0_Reg2 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr1_Reg2 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr2_Reg2 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr3_Reg2 0x0000000B 0x00000000
R ETHERNET_MAC_L3_L4_Control3 0x0000000B 0x00000000
R ETHERNET_MAC_Layer4_Address3 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr0_Reg3 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr1_Reg3 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr2_Reg3 0x0000000B 0x00000000
R ETHERNET_MAC_Layer3_Addr3_Reg3 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Control 0x0000000B 0x00002000
R ETHERNET_MAC_Sub_Second_Increment 0x0000000B 0x00000000
R ETHERNET_MAC_System_Time_Seconds 0x0000000B 0x00000000
R ETHERNET_MAC_System_Time_Nanoseconds 0x0000000B 0x00000000
R ETHERNET_MAC_System_Time_Seconds_Update 0x0000000B 0x00000000
R ETHERNET_MAC_System_Time_Nanoseconds_Update 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Addend 0x0000000B 0x00000000
R ETHERNET_MAC_System_Time_Higher_Word_Seconds 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Status 0x0000000B 0x00000000
R ETHERNET_MAC_Tx_Timestamp_Status_Nanoseconds 0x0000000B 0x00000000
R ETHERNET_MAC_Tx_Timestamp_Status_Seconds 0x0000000B 0x00000000
R ETHERNET_MAC_Auxiliary_Control 0x0000000B 0x00000000
R ETHERNET_MAC_Auxiliary_Timestamp_Nanoseconds 0x0000000B 0x00000000
R ETHERNET_MAC_Auxiliary_Timestamp_Seconds 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Ingress_Asym_Corr 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Egress_Asym_Corr 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Ingress_Corr_Nanosecond 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Egress_Corr_Nanosecond 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Ingress_Corr_Subnanosec 0x0000000B 0x00000000
R ETHERNET_MAC_Timestamp_Egress_Corr_Subnanosec 0x0000000B 0x00000000
R ETHERNET_MAC_PPS_Control 0x0000000B 0x00000000
R ETHERNET_MAC_PPS0_Target_Time_Seconds 0x0000000B 0x00000000
R ETHERNET_MAC_PPS0_Target_Time_Nanoseconds 0x0000000B 0x00000000
R ETHERNET_MAC_PPS0_Interval 0x0000000B 0x00000000
R ETHERNET_MAC_PPS0_Width 0x0000000B 0x00000000
R ETHERNET_MAC_PPS1_Target_Time_Seconds 0x0000000B 0x00000000
R ETHERNET_MAC_PPS1_Target_Time_Nanoseconds 0x0000000B 0x00000000
R ETHERNET_MAC_PPS1_Interval 0x0000000B 0x00000000
R ETHERNET_MAC_PPS1_Width 0x0000000B 0x00000000
R ETHERNET_MAC_PTO_Control 0x0000000B 0x00000000
R ETHERNET_MAC_Source_Port_Identity0 0x0000000B 0x00000000
R ETHERNET_MAC_Source_Port_Identity1 0x0000000B 0x00000000
R ETHERNET_MAC_Source_Port_Identity2 0x0000000B 0x00000000
R ETHERNET_MAC_Log_Message_Interval 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_IPREVNUM 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_CTRLSTS 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTPTSTRIGSEL0 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTPTSTRIGSEL1 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTPTSSWTRIG0 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTPTSSWTRIG1 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTPPPSR0 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTPPPSR1 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTP_TSRL 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTP_TSRH 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTP_TSWL 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_PTP_TSWH 0x0000000B 0x00000000
R ETHERNETSS_ETHERNETSS_REVMII_CTRL 0x0000000B 0x00000000
R FLASHCTRL_FRDCNTL 0x0000000B 0x00000200
R FLASHCTRL_FBAC 0x0000000B 0x0000000F
R FLASHCTRL_FBFALLBACK 0x0000000B 0x00000003
R FLASHCTRL_FBPRDY 0x0000000B 0x00008001
R FLASHCTRL_FPAC1 0x0000000B 0x00000001
R FLASHCTRL_FMSTAT 0x0000000B 0x00000000
R FLASHCTRL_FRD_INTF_CTRL_LOCK 0x0000000B 0xA5A5A5A5
R FLASHCTRL_FRD_INTF_CTRL 0x0000000B 0x00000003
R FLASHECC_ECC_ENABLE 0x0000000B 0x0000000A
R FLASHECC_SINGLE_ERR_ADDR_LOW 0x0000000B 0x00000000
R FLASHECC_SINGLE_ERR_ADDR_HIGH 0x0000000B 0x00000000
R FLASHECC_UNC_ERR_ADDR_LOW 0x0000000B 0x00000000
R FLASHECC_UNC_ERR_ADDR_HIGH 0x0000000B 0x00000000
R FLASHECC_ERR_STATUS 0x0000000B 0x00000000
R FLASHECC_ERR_POS 0x0000000B 0x00000000
R FLASHECC_ERR_STATUS_CLR 0x0000000B 0x00000000
R FLASHECC_ERR_CNT 0x0000000B 0x00000000
R FLASHECC_ERR_THRESHOLD 0x0000000B 0x00000000
R FLASHECC_ERR_INTFLG 0x0000000B 0x00000000
R FLASHECC_ERR_INTCLR 0x0000000B 0x00000000
R FLASHECC_FDATAH_TEST 0x0000000B 0x00000000
R FLASHECC_FDATAL_TEST 0x0000000B 0x00000000
R FLASHECC_FADDR_TEST 0x0000000B 0x00000000
R FLASHECC_FECC_TEST 0x0000000B 0x00000000
R FLASHECC_FECC_CTRL 0x0000000B 0x00000000
R FLASHECC_FOUTH_TEST 0x0000000B 0x00000000
R FLASHECC_FOUTL_TEST 0x0000000B 0x00000000
R FLASHECC_FECC_STATUS 0x0000000B 0x00000000
R FLASHECC_FLASH_ECC_REGS_LOCK 0x0000000B 0xA5A5A5A5
R GCRC_CRCCTRL 0x0000000B 0x00000000
R GCRC_CRCPOLY 0x0000000B 0x00000000
R GCRC_CRCDATAMASK 0x0000000B 0x00000000
R GCRC_CRCDATAIN 0x0000000B 0x00000000
R GCRC_CRCDATAOUT 0x0000000B 0x00000000
R GCRC_CRCDATATRANS 0x0000000B 0x00000000
R GPIODATA_GPADAT 0x0000000B 0xFA3AA9A9
R GPIODATA_GPASET 0x0000000B 0x00000000
R GPIODATA_GPACLEAR 0x0000000B 0x00000000
R GPIODATA_GPATOGGLE 0x0000000B 0x00000000
R GPIODATA_GPBDAT 0x0000000B 0x5FFFB987
R GPIODATA_GPBSET 0x0000000B 0x00000000
R GPIODATA_GPBCLEAR 0x0000000B 0x00000000
R GPIODATA_GPBTOGGLE 0x0000000B 0x00000000
R GPIODATA_GPCDAT 0x0000000B 0xC85437E1
R GPIODATA_GPCSET 0x0000000B 0x00000000
R GPIODATA_GPCCLEAR 0x0000000B 0x00000000
R GPIODATA_GPCTOGGLE 0x0000000B 0x00000000
R GPIODATA_GPDDAT 0x0000000B 0xE1B01DFF
R GPIODATA_GPDSET 0x0000000B 0x00000000
R GPIODATA_GPDCLEAR 0x0000000B 0x00000000
R GPIODATA_GPDTOGGLE 0x0000000B 0x00000000
R GPIODATA_GPEDAT 0x0000000B 0x0EF98001
R GPIODATA_GPESET 0x0000000B 0x00000000
R GPIODATA_GPECLEAR 0x0000000B 0x00000000
R GPIODATA_GPETOGGLE 0x0000000B 0x00000000
R GPIODATA_GPFDAT 0x0000000B 0x00000008
R GPIODATA_GPFSET 0x0000000B 0x00000000
R GPIODATA_GPFCLEAR 0x0000000B 0x00000000
R GPIODATA_GPFTOGGLE 0x0000000B 0x00000000
R GPIODATAREAD_GPADAT_R 0x0000000B 0x40000000
R GPIODATAREAD_GPBDAT_R 0x0000000B 0x40150101
R GPIODATAREAD_GPCDAT_R 0x0000000B 0x90000000
R GPIODATAREAD_GPDDAT_R 0x0000000B 0x20801801
R GPIODATAREAD_GPEDAT_R 0x0000000B 0x00000000
R GPIODATAREAD_GPFDAT_R 0x0000000B 0x00000000
R GPIODATAREAD_GPGDAT_R 0x0000000B 0x00000000
R GPIODATAREAD_GPHDAT_R 0x0000000B 0x00000000
R I2C0_I2CMSA 0x0000000B 0x00000000
R I2C0_I2CMCS 0x0000000B 0x00000020
R I2C0_I2CMDR 0x0000000B 0x00000000
R I2C0_I2CMTPR 0x0000000B 0x00010001
R I2C0_I2CMIMR 0x0000000B 0x00000000
R I2C0_I2CMRIS 0x0000000B 0x00000000
R I2C0_I2CMMIS 0x0000000B 0x00000000
R I2C0_I2CMICR 0x0000000B 0x00000000
R I2C0_I2CMCR 0x0000000B 0x00000000
R I2C0_I2CMCLKOCNT 0x0000000B 0x00000000
R I2C0_I2CMBMON 0x0000000B 0x00000003
R I2C0_I2CMBLEN 0x0000000B 0x00000000
R I2C0_I2CMBCNT 0x0000000B 0x00000000
R I2C0_I2CSOAR 0x0000000B 0x00000000
R I2C0_I2CSCSR 0x0000000B 0x00000000
R I2C0_I2CSDR 0x0000000B 0x00000000
R I2C0_I2CSIMR 0x0000000B 0x00000000
R I2C0_I2CSRIS 0x0000000B 0x00000000
R I2C0_I2CSMIS 0x0000000B 0x00000000
R I2C0_I2CSICR 0x0000000B 0x00000000
R I2C0_I2CSOAR2 0x0000000B 0x00000000
R I2C0_I2CSACKCTL 0x0000000B 0x00000000
R I2C0_I2CFIFODATARX 0x0000000B 0x000000DA
R I2C0_I2CFIFOCTL 0x0000000B 0x00040004
R I2C0_I2CFIFOSTATUS 0x0000000B 0x00010005
R I2C0_I2CPP 0x0000000B 0x00000001
R I2C0_I2CPC 0x0000000B 0x00000001
R IPCCMTOCPU1_CMTOCPU1IPCACK 0x0000000B 0x00000000
R IPCCMTOCPU1_CPU1TOCMIPCSTS 0x0000000B 0x00000000
R IPCCMTOCPU1_CMTOCPU1IPCSET 0x0000000B 0x00000000
R IPCCMTOCPU1_CMTOCPU1IPCCLR 0x0000000B 0x00000000
R IPCCMTOCPU1_CMTOCPU1IPCFLG 0x0000000B 0x00000000
R IPCCMTOCPU1_IPCCOUNTERL 0x0000000B 0x17E4677A
R IPCCMTOCPU1_IPCCOUNTERH 0x0000000B 0x00000042
R IPCCMTOCPU1_CPU1TOCMIPCRECVCOM 0x0000000B 0x00000000
R IPCCMTOCPU1_CPU1TOCMIPCRECVADDR 0x0000000B 0x00000000
R IPCCMTOCPU1_CPU1TOCMIPCRECVDATA 0x0000000B 0x00000000
R IPCCMTOCPU1_CMTOCPU1IPCREPLY 0x0000000B 0x00000000
R IPCCMTOCPU1_CMTOCPU1IPCSENDCOM 0x0000000B 0x00000001
R IPCCMTOCPU1_CMTOCPU1IPCSENDADDR 0x0000000B 0x00000138
R IPCCMTOCPU1_CMTOCPU1IPCSENDDATA 0x0000000B 0x00000044
R IPCCMTOCPU1_CPU1TOCMIPCREPLY 0x0000000B 0x00005555
R IPCCMTOCPU1_CMTOCPU1IPCBOOTSTS 0x0000000B 0x00001007
R IPCCMTOCPU1_CPU1TOCMIPCBOOTMODE 0x0000000B 0x5A007D03
R IPCCMTOCPU1_PUMPREQUEST 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCACK 0x0000000B 0x00000000
R IPCCMTOCPU2_CPU2TOCMIPCSTS 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCSET 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCCLR 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCFLG 0x0000000B 0x00000000
R IPCCMTOCPU2_IPCCOUNTERL 0x0000000B 0xFC666CC1
R IPCCMTOCPU2_IPCCOUNTERH 0x0000000B 0x00000042
R IPCCMTOCPU2_CPU2TOCMIPCRECVCOM 0x0000000B 0x00000000
R IPCCMTOCPU2_CPU2TOCMIPCRECVADDR 0x0000000B 0x00000000
R IPCCMTOCPU2_CPU2TOCMIPCRECVDATA 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCREPLY 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCSENDCOM 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCSENDADDR 0x0000000B 0x00000000
R IPCCMTOCPU2_CMTOCPU2IPCSENDDATA 0x0000000B 0x00000000
R IPCCMTOCPU2_CPU2TOCMIPCREPLY 0x0000000B 0x00000000
R MCANSS_MCANSS_PID 0x0000000B 0x00000000
R MCANSS_MCANSS_CTRL 0x0000000B 0x00000000
R MCANSS_MCANSS_STAT 0x0000000B 0x00000000
R MCANSS_MCANSS_ICS 0x0000000B 0x00000000
R MCANSS_MCANSS_IRS 0x0000000B 0x00000000
R MCANSS_MCANSS_IECS 0x0000000B 0x00000000
R MCANSS_MCANSS_IE 0x0000000B 0x00000000
R MCANSS_MCANSS_IES 0x0000000B 0x00000000
R MCANSS_MCANSS_EOI 0x0000000B 0x00000000
R MCANSS_MCANSS_EXT_TS_PRESCALER 0x0000000B 0x00000000
R MCANSS_MCANSS_EXT_TS_UNSERVICED_INTR_CNTR 0x0000000B 0x00000000
R MCAN_MCAN_CREL 0x0000000B 0x00000000
R MCAN_MCAN_ENDN 0x0000000B 0x00000000
R MCAN_MCAN_DBTP 0x0000000B 0x00000000
R MCAN_MCAN_TEST 0x0000000B 0x00000000
R MCAN_MCAN_RWD 0x0000000B 0x00000000
R MCAN_MCAN_CCCR 0x0000000B 0x00000000
R MCAN_MCAN_NBTP 0x0000000B 0x00000000
R MCAN_MCAN_TSCC 0x0000000B 0x00000000
R MCAN_MCAN_TSCV 0x0000000B 0x00000000
R MCAN_MCAN_TOCC 0x0000000B 0x00000000
R MCAN_MCAN_TOCV 0x0000000B 0x00000000
R MCAN_MCAN_ECR 0x0000000B 0x00000000
R MCAN_MCAN_PSR 0x0000000B 0x00000000
R MCAN_MCAN_TDCR 0x0000000B 0x00000000
R MCAN_MCAN_IR 0x0000000B 0x00000000
R MCAN_MCAN_IE 0x0000000B 0x00000000
R MCAN_MCAN_ILS 0x0000000B 0x00000000
R MCAN_MCAN_ILE 0x0000000B 0x00000000
R MCAN_MCAN_GFC 0x0000000B 0x00000000
R MCAN_MCAN_SIDFC 0x0000000B 0x00000000
R MCAN_MCAN_XIDFC 0x0000000B 0x00000000
R MCAN_MCAN_XIDAM 0x0000000B 0x00000000
R MCAN_MCAN_HPMS 0x0000000B 0x00000000
R MCAN_MCAN_NDAT1 0x0000000B 0x00000000
R MCAN_MCAN_NDAT2 0x0000000B 0x00000000
R MCAN_MCAN_RXF0C 0x0000000B 0x00000000
R MCAN_MCAN_RXF0S 0x0000000B 0x00000000
R MCAN_MCAN_RXF0A 0x0000000B 0x00000000
R MCAN_MCAN_RXBC 0x0000000B 0x00000000
R MCAN_MCAN_RXF1C 0x0000000B 0x00000000
R MCAN_MCAN_RXF1S 0x0000000B 0x00000000
R MCAN_MCAN_RXF1A 0x0000000B 0x00000000
R MCAN_MCAN_RXESC 0x0000000B 0x00000000
R MCAN_MCAN_TXBC 0x0000000B 0x00000000
R MCAN_MCAN_TXFQS 0x0000000B 0x00000000
R MCAN_MCAN_TXESC 0x0000000B 0x00000000
R MCAN_MCAN_TXBRP 0x0000000B 0x00000000
R MCAN_MCAN_TXBAR 0x0000000B 0x00000000
R MCAN_MCAN_TXBCR 0x0000000B 0x00000000
R MCAN_MCAN_TXBTO 0x0000000B 0x00000000
R MCAN_MCAN_TXBCF 0x0000000B 0x00000000
R MCAN_MCAN_TXBTIE 0x0000000B 0x00000000
R MCAN_MCAN_TXBCIE 0x0000000B 0x00000000
R MCAN_MCAN_TXEFC 0x0000000B 0x00000000
R MCAN_MCAN_TXEFS 0x0000000B 0x00000000
R MCAN_MCAN_TXEFA 0x0000000B 0x00000000
R MCANERR_MCANERR_REV 0x0000000B 0x00000000
R MCANERR_MCANERR_VECTOR 0x0000000B 0x00000000
R MCANERR_MCANERR_STAT 0x0000000B 0x00000000
R MCANERR_MCANERR_WRAP_REV 0x0000000B 0x00000000
R MCANERR_MCANERR_CTRL 0x0000000B 0x00000000
R MCANERR_MCANERR_ERR_CTRL1 0x0000000B 0x00000000
R MCANERR_MCANERR_ERR_CTRL2 0x0000000B 0x00000000
R MCANERR_MCANERR_ERR_STAT1 0x0000000B 0x00000000
R MCANERR_MCANERR_ERR_STAT2 0x0000000B 0x00000000
R MCANERR_MCANERR_ERR_STAT3 0x0000000B 0x00000000
R MCANERR_MCANERR_SEC_EOI 0x0000000B 0x00000000
R MCANERR_MCANERR_SEC_STATUS 0x0000000B 0x00000000
R MCANERR_MCANERR_SEC_ENABLE_SET 0x0000000B 0x00000000
R MCANERR_MCANERR_SEC_ENABLE_CLR 0x0000000B 0x00000000
R MCANERR_MCANERR_DED_EOI 0x0000000B 0x00000000
R MCANERR_MCANERR_DED_STATUS 0x0000000B 0x00000000
R MCANERR_MCANERR_DED_ENABLE_SET 0x0000000B 0x00000000
R MCANERR_MCANERR_DED_ENABLE_CLR 0x0000000B 0x00000000
R MCANERR_MCANERR_AGGR_ENABLE_SET 0x0000000B 0x00000000
R MCANERR_MCANERR_AGGR_ENABLE_CLR 0x0000000B 0x00000000
R MCANERR_MCANERR_AGGR_STATUS_SET 0x0000000B 0x00000000
R MCANERR_MCANERR_AGGR_STATUS_CLR 0x0000000B 0x00000000
R MEMINITANDTEST_CxLOCK 0x0000000B 0x00000000
R MEMINITANDTEST_CxTEST 0x0000000B 0x00000000
R MEMINITANDTEST_CxINIT 0x0000000B 0x00000000
R MEMINITANDTEST_CxINITDONE 0x0000000B 0x00000003
R MEMINITANDTEST_CMMSGxLOCK 0x0000000B 0x00000000
R MEMINITANDTEST_CMMSGxTEST 0x0000000B 0x00000000
R MEMINITANDTEST_CMMSGxINIT 0x0000000B 0x00000000
R MEMINITANDTEST_CMMSGxINITDONE 0x0000000B 0x0000000F
R MEMINITANDTEST_SxGROUP1_LOCK 0x0000000B 0x00000000
R MEMINITANDTEST_SxGROUP1_TEST 0x0000000B 0x00000000
R MEMINITANDTEST_SxGROUP1_INIT 0x0000000B 0x00000000
R MEMINITANDTEST_SxGROUP1_INITDONE 0x0000000B 0x0000001F
R MEMINITANDTEST_ROM_LOCK 0x0000000B 0x00000000
R MEMINITANDTEST_ROM_TEST 0x0000000B 0x00000000
R MEMINITANDTEST_ROM_FORCE_ERROR 0x0000000B 0x00000000
R MEMINITANDTEST_PERI_MEM_TEST_LOCK 0x0000000B 0x00000000
R MEMINITANDTEST_PERI_MEM_TEST_CONTROL 0x0000000B 0x00000000
R MPU_MPU_TYPE 0x0000000B 0x00000800
R MPU_MPU_CTRL 0x0000000B 0x00000000
R MPU_MPU_RNR 0x0000000B 0x00000000
R MPU_MPU_RBAR 0x0000000B 0x00000000
R MPU_MPU_RASR 0x0000000B 0x00000000
R MPU_MPU_RBAR_A1 0x0000000B 0x00000000
R MPU_MPU_RASR_A1 0x0000000B 0x00000000
R MPU_MPU_RBAR_A2 0x0000000B 0x00000000
R MPU_MPU_RASR_A2 0x0000000B 0x00000000
R MPU_MPU_RBAR_A3 0x0000000B 0x00000000
R MPU_MPU_RASR_A3 0x0000000B 0x00000000
R NMI_CMNMICFG 0x0000000B 0x00000001
R NMI_CMNMIFLG 0x0000000B 0x00000000
R NMI_CMNMIFLGCLR 0x0000000B 0x00000000
R NMI_CMNMIFLGFRC 0x0000000B 0x00000000
R NMI_CMNMIWDCNT 0x0000000B 0x00000000
R NMI_CMNMIWDPRD 0x0000000B 0x0000FFFF
R NMI_CMNMISHDWFLG 0x0000000B 0x00000000
R NVIC_NVIC_ISER0 0x0000000B 0x00002000
R NVIC_NVIC_ISER1 0x0000000B 0x00000000
R NVIC_NVIC_ICER0 0x0000000B 0x00002000
R NVIC_NVIC_ICER1 0x0000000B 0x00000000
R NVIC_NVIC_ISPR0 0x0000000B 0x20002000
R NVIC_NVIC_ISPR1 0x0000000B 0x00000000
R NVIC_NVIC_ISPR2 0x0000000B 0x00000000
R NVIC_NVIC_ICPR0 0x0000000B 0x20002000
R NVIC_NVIC_ICPR1 0x0000000B 0x00000000
R NVIC_NVIC_IABR0 0x0000000B 0x00010000
R NVIC_NVIC_IABR1 0x0000000B 0x00000000
R NVIC_NVIC_IPR0 0x0000000B 0x00000000
R NVIC_NVIC_IPR1 0x0000000B 0x00000000
R NVIC_NVIC_IPR2 0x0000000B 0x00000000
R NVIC_NVIC_IPR3 0x0000000B 0x00000000
R NVIC_NVIC_IPR4 0x0000000B 0x00000000
R NVIC_NVIC_IPR5 0x0000000B 0x00000000
R NVIC_NVIC_IPR6 0x0000000B 0x00000000
R NVIC_NVIC_IPR7 0x0000000B 0x00000000
R NVIC_NVIC_IPR8 0x0000000B 0x00000000
R NVIC_NVIC_IPR9 0x0000000B 0x00000000
R NVIC_NVIC_IPR10 0x0000000B 0x00000000
R NVIC_NVIC_IPR11 0x0000000B 0x00000000
R NVIC_NVIC_IPR12 0x0000000B 0x00000000
R NVIC_NVIC_IPR13 0x0000000B 0x00000000
R NVIC_NVIC_IPR14 0x0000000B 0x00000000
R NVIC_NVIC_IPR15 0x0000000B 0x00000000
R NVIC_STIR 0x0000000B 0x00000000
R SSI0_SSICR0 0x0000000B 0x00000000
R SSI0_SSICR1 0x0000000B 0x00000000
R SSI0_SSIDR 0x0000000B 0x00000000
R SSI0_SSISR 0x0000000B 0x00000003
R SSI0_SSICPSR 0x0000000B 0x00000000
R SSI0_SSIIM 0x0000000B 0x00000000
R SSI0_SSIRIS 0x0000000B 0x00000008
R SSI0_SSIMIS 0x0000000B 0x00000000
R SSI0_SSIICR 0x0000000B 0x00000000
R SSI0_SSIDMACTL 0x0000000B 0x00000000
R SSI0_SSIPV 0x0000000B 0x00000000
R SSI0_SSIPP 0x0000000B 0x00000009
R SSI0_SSIPC 0x0000000B 0x00000000
R SSI0_SSIPeriphID4 0x0000000B 0x00000000
R SSI0_SSIPeriphID5 0x0000000B 0x00000000
R SSI0_SSIPeriphID6 0x0000000B 0x00000000
R SSI0_SSIPeriphID7 0x0000000B 0x00000000
R SSI0_SSIPeriphID0 0x0000000B 0x00000022
R SSI0_SSIPeriphID1 0x0000000B 0x00000000
R SSI0_SSIPeriphID2 0x0000000B 0x00000018
R SSI0_SSIPeriphID3 0x0000000B 0x00000001
R SSI0_SSIPCellID0 0x0000000B 0x0000000D
R SSI0_SSIPCellID1 0x0000000B 0x000000F0
R SSI0_SSIPCellID2 0x0000000B 0x00000005
R SSI0_SSIPCellID3 0x0000000B 0x000000B1
R CMSYSCTL_CMPCLKCR0 0x0000000B 0x00000000
R CMSYSCTL_CMPCLKCR1 0x0000000B 0x00000001
R CMSYSCTL_CMPCLKCR2 0x0000000B 0x00000000
R CMSYSCTL_CMSOFTPRESET0 0x0000000B 0x00000000
R CMSYSCTL_CMSOFTPRESET1 0x0000000B 0x00000004
R CMSYSCTL_CMSOFTPRESET2 0x0000000B 0x00000000
R CMSYSCTL_CMCLKSTOPREQ0 0x0000000B 0x00000000
R CMSYSCTL_CMCLKSTOPREQ1 0x0000000B 0x00000000
R CMSYSCTL_CMCLKSTOPREQ2 0x0000000B 0x00000000
R CMSYSCTL_CMCLKSTOPACK0 0x0000000B 0x00000000
R CMSYSCTL_CMCLKSTOPACK1 0x0000000B 0x00000000
R CMSYSCTL_CMCLKSTOPACK2 0x0000000B 0x00000000
R CMSYSCTL_MCANWAKESTATUS 0x0000000B 0x00000000
R CMSYSCTL_MCANWAKESTATUSCLR 0x0000000B 0x00000000
R CMSYSCTL_CMECATCTL 0x0000000B 0x00000000
R CMSYSCTL_PALLOCATESTS 0x0000000B 0x00000010
R CMSYSCTL_CMRESCCLR 0x0000000B 0x00000000
R CMSYSCTL_CMRESC 0x0000000B 0x00010116
R CMSYSCTL_CMSYSCTLLOCK 0x0000000B 0x00000000
R SCB_ACTLR 0x0000000B 0x00000000
R SCB_CPUID 0x0000000B 0x410FC241
R SCB_ICSR 0x0000000B 0x0440F003
R SCB_VTOR 0x0000000B 0x2000BC00
R SCB_AIRCR 0x0000000B 0xFA050000
R SCB_SCR 0x0000000B 0x00000000
R SCB_CCR 0x0000000B 0x00000200
R SCB_SHPR1 0x0000000B 0x00000000
R SCB_SHPR2 0x0000000B 0x00000000
R SCB_SHPR3 0x0000000B 0x00000000
R SCB_SHCSRS 0x0000000B 0x00000000
R SCB_CFSR 0x0000000B 0x00008200
R SCB_HFSR 0x0000000B 0x40000000
R SCB_MMFAR 0x0000000B 0x00989684
R SCB_BFAR 0x0000000B 0x00989684
R SCB_AFSR 0x0000000B 0x00000000
R SYSTICK_SYST_CSR 0x0000000B 0x00010007
R SYSTICK_SYST_RVR 0x0000000B 0x000F423F
R SYSTICK_SYST_CVR 0x0000000B 0x0002AD3E
R SYSTICK_SYST_CALIB 0x0000000B 0x80000000
R TIMER0_TIM 0x0000000B 0x00000000
R TIMER0_PRD 0x0000000B 0x00000000
R TIMER0_TCR 0x0000000B 0x00000000
R TIMER0_TPR 0x0000000B 0x00000000
R TIMER1_TIM 0x0000000B 0x00000000
R TIMER1_PRD 0x0000000B 0x00000000
R TIMER1_TCR 0x0000000B 0x00000000
R TIMER1_TPR 0x0000000B 0x00000000
R TIMER2_TIM 0x0000000B 0x00000000
R TIMER2_PRD 0x0000000B 0x00000000
R TIMER2_TCR 0x0000000B 0x00000000
R TIMER2_TPR 0x0000000B 0x00000000
R UART0_UARTDR 0x0000000B 0x00000000
R UART0_UARTRSR 0x0000000B 0x00000000
R UART0_UARTFR 0x0000000B 0x00000000
R UART0_UARTILPR 0x0000000B 0x00000000
R UART0_UARTIBRD 0x0000000B 0x00000000
R UART0_UARTFBRD 0x0000000B 0x00000000
R UART0_UARTLCRH 0x0000000B 0x01970000
R UART0_UARTCTL 0x0000000B 0x00000197
R UART0_UARTIFLS 0x0000000B 0x00000000
R UART0_UARTIM 0x0000000B 0x00000000
R UART0_UARTRIS 0x0000000B 0x00000000
R UART0_UARTMIS 0x0000000B 0x00000000
R UART0_UARTICR 0x0000000B 0x00000000
R UART0_UARTDMACTL 0x0000000B 0x00000000
R UART0_UART9BITADDR 0x0000000B 0x00000000
R UART0_UART9BITAMASK 0x0000000B 0x00000000
R UART0_UARTPP 0x0000000B 0x00000000
R UART0_UARTPeriphID4 0x0000000B 0x00000000
R UART0_UARTPeriphID5 0x0000000B 0x00000000
R UART0_UARTPeriphID6 0x0000000B 0x00000000
R UART0_UARTPeriphID7 0x0000000B 0x00000000
R UART0_UARTPeriphID0 0x0000000B 0x00000000
R UART0_UARTPeriphID1 0x0000000B 0x00000000
R UART0_UARTPeriphID2 0x0000000B 0x00000000
R UART0_UARTPeriphID3 0x0000000B 0x00000000
R UART0_UARTPCellID0 0x0000000B 0x00000000
R UART0_UARTPCellID1 0x0000000B 0x00000000
R UART0_UARTPCellID2 0x0000000B 0x00000000
R UART0_UARTPCellID3 0x0000000B 0x00000000
R UDMA_DMASTAT 0x0000000B 0x001F0000
R UDMA_DMACFG 0x0000000B 0x00000000
R UDMA_DMACTLBASE 0x0000000B 0x00000000
R UDMA_DMAALTBASE 0x0000000B 0x00000200
R UDMA_DMASWREQ 0x0000000B 0x00000000
R UDMA_DMAUSEBURSTSET 0x0000000B 0x00000000
R UDMA_DMAUSEBURSTCLR 0x0000000B 0x00000000
R UDMA_DMAREQMASKSET 0x0000000B 0x00000000
R UDMA_DMAREQMASKCLR 0x0000000B 0x00000000
R UDMA_DMAENASET 0x0000000B 0x00000000
R UDMA_DMAENACLR 0x0000000B 0x00000000
R UDMA_DMAALTSET 0x0000000B 0x00000000
R UDMA_DMAALTCLR 0x0000000B 0x00000000
R UDMA_DMAPRIOSET 0x0000000B 0x00000000
R UDMA_DMAPRIOCLR 0x0000000B 0x00000000
R UDMA_DMAERRCLR 0x0000000B 0x00000000
R UDMA_DMACHMAP0 0x0000000B 0x00000000
R UDMA_DMACHMAP1 0x0000000B 0x00000000
R UDMA_DMACHMAP2 0x0000000B 0x00000000
R UDMA_DMACHMAP3 0x0000000B 0x00000000
R UDMA_DMAPeriphID4 0x0000000B 0x00000004
R UDMA_DMAPeriphID0 0x0000000B 0x00000030
R UDMA_DMAPeriphID1 0x0000000B 0x000000B2
R UDMA_DMAPeriphID2 0x0000000B 0x0000000B
R UDMA_DMAPeriphID3 0x0000000B 0x00000000
R UDMA_DMAPCellID0 0x0000000B 0x0000000D
R UDMA_DMAPCellID1 0x0000000B 0x000000F0
R UDMA_DMAPCellID2 0x0000000B 0x00000005
R UDMA_DMAPCellID3 0x0000000B 0x000000B1
R WDT_SCSR 0x0000000B 0x00000003
R WDT_WDCNTR 0x0000000B 0x00000000
R WDT_WDKEY 0x0000000B 0x00000040
R WDT_WDCR 0x0000000B 0x00000040
R WDT_WDWCR 0x0000000B 0x00000000
Does anyone have an idea how I could start tracking down the cause of the Fault?
