Part Number: TMS320F28335
I'd like to use synchronized PWM (or harmonics elimination PWM, or "synchronous" PWM) on 28335 DSP. I believe there are many ways on how to do it, but maybe there is some "best practice" solution on how to do it (for production quality). To describe it in more details, the PWM is driven by the argument of stator frequency and the argument together with precalculated angles determine the instant of switching.
The angles are given by modulation depth and wt is calculated from the speed sensor + slip frequency (ACIM is the target). This technique is very popular for low-switching frequency converters or high-speed drives (traction drives).
I'd like to keep certain features of ePWM module active, like deadtime insertion and double-buffered (shadow mode) access. I'm also planning to switch between classical PWM and HEPWM in runtime.
Thank you in advance!
Matej
