TMS320F28388D: CPU2, CM firmware update using CPU1
Part Number: TMS320F28388D
Hello.
Last time I asked the firmware update all cores. And firmware update of CPU1 has been completed.
Next step is that CPU1 core do firmware update for CPU2 and CM.
I also read this thread
https://e2e.ti.com/support/microcontrollers/c2000-microcontrollers-group/c2000/f/c2000-microcontrollers-forum/921166/tms320f28388d-firmware-update/3403335?tisearch=e2e-sitesearch&keymatch=CPU2%2525252525252520firmware#3403335
Then, I want to CPU2(Flash API, Flash file), CM(Flash API, Flash file) be streamed via CPU1.
1. I intend to refer to ipc_ex1_basic_c28x1. Is it right way?? or Could you recommend an example or thread to refer to??
2. I use the Flash API(Fapi functions) in CPU1.  And I don't know What Flash API be streamed via CPU1 means. Do you means CPU2, CM cores get the Flash API header file from CPU1??
