Hello
Good afternoon, hope everyone is doing well and safe. I have a little query as I am new CAN through TI TMS320f28379d. I am trying to send around 16 signals through CAN into another controller platform. I am using f28379d and using the example codes. I am unable to realize exactly which one I should use for the CAN ID as in the example codes (mentioned below) the message ID is a macro definition and that is the CAN ID as per my understanding and as the number of signals increase the CAN buffer length changes. Are defined values RX_MSG_OBJ_ID and TX_MSG_OBJ_ID the CAN ID and if the that is the case for every interrupt for different signals if the buffer length is changed then this same ID can be used?
Kindly clarify, I am attaching the code I am using at the end of this message.
Thank you.
Stay safe.
// FILE: can_ex2_loopback_interrupts.c
// TITLE: CAN External Loopback with Interrupts Example
//! \addtogroup driver_example_list
//! <h1> CAN External Loopback with Interrupts </h1>
//! This example shows the basic setup of CAN in order to transmit and receive
//! messages on the CAN bus. The CAN peripheral is configured to transmit
//! messages with a specific CAN ID. A message is then transmitted once per
//! second, using a simple delay loop for timing. The message that is sent is
//! a 4 byte message that contains an incrementing pattern. A CAN interrupt
//! handler is used to confirm message transmission and count the number of
//! messages that have been sent.
//! This example sets up the CAN controller in External Loopback test mode.
//! Data transmitted is visible on the CANTXA pin and is received internally
//! back to the CAN Core.
//! \b External \b Connections \n
//! - None.
//! \b Watch \b Variables \n
//! - txMsgCount - A counter for the number of messages sent
//! - rxMsgCount - A counter for the number of messages received
//! - txMsgData - An array with the data being sent
//! - rxMsgData - An array with the data that was received
//! - errorFlag - A flag that indicates an error has occurred
// $TI Release: F2837xD Support Library v3.01.00.00 $
// $Release Date: Mon May 22 15:43:40 CDT 2017 $
// $Copyright:
// Copyright (C) 2013-2017 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#define MSG_DATA_LENGTH 4
#define TX_MSG_OBJ_ID 1
#define RX_MSG_OBJ_ID 2
// Globals
volatile uint32_t txMsgCount = 0;
volatile uint32_t rxMsgCount = 0;
volatile uint32_t errorFlag = 0;
uint16_t txMsgData[4];
uint16_t rxMsgData[4];
// Function Prototypes
__interrupt void canISR(void);
// Main
void main(void)
// Initialize device clock and peripherals
Device_init();
// Initialize GPIO and configure GPIO pins for CANTX/CANRX
Device_initGPIO();
GPIO_setPinConfig(DEVICE_GPIO_CFG_CANRXA);
GPIO_setPinConfig(DEVICE_GPIO_CFG_CANTXA);
// Initialize the CAN controller
CAN_initModule(CANA_BASE);
// Set up the CAN bus bit rate to 500kHz
// Refer to the Driver Library User Guide for information on how to set
// tighter timing control. Additionally, consult the device data sheet
// for more information about the CAN module clocking.
CAN_setBitRate(CANA_BASE, DEVICE_SYSCLK_FREQ, 500000, 16);
// Enable interrupts on the CAN peripheral.
CAN_enableInterrupt(CANA_BASE, CAN_INT_IE0 | CAN_INT_ERROR |
CAN_INT_STATUS);
// Initialize PIE and clear PIE registers. Disables CPU interrupts.
Interrupt_initModule();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
Interrupt_initVectorTable();
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
// This registers the interrupt handler in PIE vector table.
Interrupt_register(INT_CANA_1, &canISR);
// Enable the CAN interrupt signal
Interrupt_enable(INT_CANA_1);
CAN_enableGlobalInterrupt(CANA_BASE, CAN_GLOBAL_INT_CANINT0);
// Enable CAN test mode with external loopback
CAN_enableTestMode(CANA_BASE, CAN_TEST_EXL);
// Initialize the transmit message object used for sending CAN messages.
// Message Object Parameters:
// Message Object ID Number: 1
// Message Identifier: 0x1
// Message Frame: Standard
// Message Type: Transmit
// Message ID Mask: 0x0
// Message Object Flags: Transmit Interrupt
// Message Data Length: 4 Bytes
CAN_setupMessageObject(CANA_BASE, TX_MSG_OBJ_ID, 0x1, CAN_MSG_FRAME_STD,
CAN_MSG_OBJ_TYPE_TX, 0, CAN_MSG_OBJ_TX_INT_ENABLE,
MSG_DATA_LENGTH);
// Initialize the receive message object used for receiving CAN messages.
// Message Object ID Number: 2
// Message Type: Receive
// Message Object Flags: Receive Interrupt
CAN_setupMessageObject(CANA_BASE, RX_MSG_OBJ_ID, 0x1, CAN_MSG_FRAME_STD,
CAN_MSG_OBJ_TYPE_RX, 0, CAN_MSG_OBJ_RX_INT_ENABLE,
MSG_DATA_LENGTH);
// Initialize the transmit message object data buffer to be sent
txMsgData[0] = 0x12;
txMsgData[1] = 0x34;
txMsgData[2] = 0x56;
txMsgData[3] = 0x78;
// Start CAN module operations
CAN_startModule(CANA_BASE);
// Loop Forever - A new message will be sent once per second.
for(;;)
// Check the error flag to see if errors occurred
if(errorFlag)
asm(" ESTOP0");
// Verify that the number of transmitted messages equal the number of
// messages received before sending a new message
if(txMsgCount == rxMsgCount)
CAN_sendMessage(CANA_BASE, TX_MSG_OBJ_ID, MSG_DATA_LENGTH,
txMsgData);
else
errorFlag = 1;
// Delay 1 second before continuing
DEVICE_DELAY_US(1000000);
// Increment the value in the transmitted message data.
txMsgData[0] += 0x01;
txMsgData[1] += 0x01;
txMsgData[2] += 0x01;
txMsgData[3] += 0x01;
// Reset data if exceeds a byte
if(txMsgData[0] > 0xFF)
txMsgData[0] = 0;
if(txMsgData[1] > 0xFF)
txMsgData[1] = 0;
if(txMsgData[2] > 0xFF)
txMsgData[2] = 0;
if(txMsgData[3] > 0xFF)
txMsgData[3] = 0;
// CAN ISR - The interrupt service routine called when a CAN interrupt is
// triggered. It checks for the cause of the interrupt, and
// maintains a count of all messages that have been transmitted.
__interrupt void
canISR(void)
uint32_t status;
// Read the CAN interrupt status to find the cause of the interrupt
status = CAN_getInterruptCause(CANA_BASE);
// If the cause is a controller status interrupt, then get the status
if(status == CAN_INT_INT0ID_STATUS)
// Read the controller status. This will return a field of status
// error bits that can indicate various errors. Error processing
// is not done in this example for simplicity. Refer to the
// API documentation for details about the error status bits.
// The act of reading this status will clear the interrupt.
status = CAN_getStatus(CANA_BASE);
// Check to see if an error occurred.
if(((status & ~(CAN_STATUS_TXOK | CAN_STATUS_RXOK)) != 7) &&
((status & ~(CAN_STATUS_TXOK | CAN_STATUS_RXOK)) != 0))
// Set a flag to indicate some errors may have occurred.
errorFlag = 1;
// Check if the cause is the transmit message object 1
else if(status == TX_MSG_OBJ_ID)
// Getting to this point means that the TX interrupt occurred on
// message object 1, and the message TX is complete. Clear the
// message object interrupt.
CAN_clearInterruptStatus(CANA_BASE, TX_MSG_OBJ_ID);
// Increment a counter to keep track of how many messages have been
// sent. In a real application this could be used to set flags to
// indicate when a message is sent.
txMsgCount++;
// Since the message was sent, clear any error flags.
errorFlag = 0;
// Check if the cause is the receive message object 2
else if(status == RX_MSG_OBJ_ID)
// Get the received message
CAN_readMessage(CANA_BASE, RX_MSG_OBJ_ID, rxMsgData);
// Getting to this point means that the RX interrupt occurred on
// message object 2, and the message RX is complete. Clear the
CAN_clearInterruptStatus(CANA_BASE, RX_MSG_OBJ_ID);
// received. In a real application this could be used to set flags to
// indicate when a message is received.
rxMsgCount++;
// Since the message was received, clear any error flags.
errorFlag = 0;
// If something unexpected caused the interrupt, this would handle it.
else
// Spurious interrupt handling can go here.
// Clear the global interrupt flag for the CAN interrupt line
CAN_clearGlobalInterruptStatus(CANA_BASE, CAN_GLOBAL_INT_CANINT0);
// Acknowledge this interrupt located in group 9
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP9);
// End of File
