Part Number: TMS320F28069
When I flash that using CCS the code works and starts functioning.
But when we remove the supply and then reconnect it the execution stops. I have attached the image below of the schematic.
I presume your code works fine from flash right after you program it through CCS, but does not when attempting to run code without the JTAG connector. If so, there are two things to check:
The schematics you sent is not clear.
