Part Number: TMS320F28388D
Dear team:
My customer want to change the communication method of routine(ipc_ex2_msgqueue_c28x1.c) into interrupt method. And he made the following modifications:
1, Added interrupt receiving function
// IPC ISR for Flag 1
// C28x core sends data with message queue using Flag 0
__interrupt void IPC_ISR1()
int i;
//IPC_Message_t TxMsg, RxMsg;
bool status = false;
// Read the message from the message queue
IPC_readMessageFromQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
&RxMsg, IPC_NONBLOCKING_CALL);
if(RxMsg.command == IPC_CMD_READ_MEM)
status = true;
// Read and compare data
for(i=0; i<RxMsg.dataw1; i++)
if((*(uint32_t *)RxMsg.address + i) != i)
status = false;
// Acknowledge the flag
IPC_ackFlagRtoL(IPC_CPU1_L_CM_R, IPC_FLAG1);
// Acknowledge the PIE interrupt.
Interrupt_clearACKGroup(INTERRUPT_ACK_GROUP1);
2, Enable IPC interrupts
IPC_registerInterrupt(IPC_CPU1_L_CM_R, IPC_INT1, IPC_ISR1);
Initialize message queue
IPC_initMessageQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_INT1, IPC_INT1);
3, Added send loop for testing
while(1)
DEVICE_DELAY_US(100000);
IPC_sendMessageToQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_ADDR_CORRECTION_ENABLE,
&TxMsg, IPC_NONBLOCKING_CALL);
The test result is that the IPC communication between CPU1 and CM cannot be interrupted. What is the problem? Here is the complete code:
// Included Files
#include "driverlib.h"
#include "device.h"
// Defines
#define IPC_CMD_READ_MEM 0x1001
#define IPC_CMD_RESP 0x2001
#define TEST_PASS 0x5555
#define TEST_FAIL 0xAAAA
#pragma DATA_SECTION(readData, "MSGRAM_CPU_TO_CM")
uint32_t readData[10];
uint32_t pass;
IPC_MessageQueue_t messageQueue;
__interrupt void IPC_ISR1() //增加了中断接收函数
int i;
status = true;
status = false;
// Main
void main(void)
int i;
// Initialize device clock and peripherals
Device_init();
// Boot CM core
#ifdef _FLASH
Device_bootCM(BOOTMODE_BOOT_TO_FLASH_SECTOR0);
#else
Device_bootCM(BOOTMODE_BOOT_TO_S0RAM);
#endif
// Clear any IPC flags if set already
IPC_clearFlagLtoR(IPC_CPU1_L_CM_R, IPC_FLAG_ALL);
// Enable IPC interrupts
IPC_registerInterrupt(IPC_CPU1_L_CM_R, IPC_INT1, IPC_ISR1); //注册了中断
// Initialize message queue
IPC_initMessageQueue(IPC_CPU1_L_CM_R, &messageQueue, IPC_INT1, IPC_INT1); //初始化中断
// Synchronize both the cores
// Enable Global Interrupt (INTM) and realtime interrupt (DBGM)
EINT;
ERTM;
IPC_sync(IPC_CPU1_L_CM_R, IPC_FLAG31);
// Fill in the data to be sent
for(i=0; i<10; i++)
readData[i] = i;
// Update the message
TxMsg.command = IPC_CMD_READ_MEM;
TxMsg.address = (uint32_t)readData;
TxMsg.dataw1 = 10; // Using dataw1 as data length
TxMsg.dataw2 = 1; // Message identifier
// End of example. Loop forever
while(1) //增加了循环发送用于测试
Green
