TMS320F28388D: TMS320F28388D
Part Number: TMS320F28388D
I am trying to build my project in CCS after which I get the following below error.
I have a custom linker .cmd file please find the code that contains the undefined symbol(error) mentioned in the above attachment.
#include "MW_F2838x_MemoryMap.h"
#ifdef CLA_BLOCK_INCLUDED
// Define a size for the CLA scratchpad area that will be used
// by the CLA compiler for local symbols and temps
// Also force references to the special symbols that mark the
// scratchpad are.
CLA_SCRATCHPAD_SIZE = 0x100;
--undef_sym=__cla_scratchpad_end
--undef_sym=__cla_scratchpad_start
#endif //CLA_BLOCK_INCLUDED
MEMORY
PAGE 0 :
   /* BEGIN is used for the "boot to SARAM" bootloader mode   */
   BEGIN                    : origin = 0x000000,                length = 0x000002
   BEGIN_FLASH              : origin = 0x080000,                length = 0x000002
        RAMLS_PROG      	: origin = 0x008000, 				length = 0x001800
        RAMLS_CLA_PROG      : origin = 0x00B000, 				length = 0x001000
   #else
        #if BOOT_FROM_FLASH
            RAMLS_PROG      : origin = 0x008000, 				length = 0x002800
        #else
            RAMLS_PROG      : origin = 0x008000, 				length = 0x004000
        #endif //BOOT_FROM_FLASH
   #ifdef CPU1
        #if (CPU1_RAMGS_PROG_LENGTH > 0)
            RAMGS_PROG      : origin = CPU1_RAMGS_PROG_START, 	length = CPU1_RAMGS_PROG_LENGTH
        #endif //(CPU1_RAMGS_PROG_LENGTH > 0)
   #else
        #if (CPU2_RAMGS_PROG_LENGTH > 0)
            RAMGS_PROG      : origin = CPU2_RAMGS_PROG_START, 	length = CPU2_RAMGS_PROG_LENGTH
       #endif //(CPU2_RAMGS_PROG_LENGTH > 0)
   #endif //CPU1
   /* Flash sectors */
   FLASHA_N                 : origin = 0x080002, 				length = 0x03FFFE	/* on-chip Flash */
   RESET                    : origin = 0x3FFFC0,                length = 0x000002
PAGE 1 :
   BOOT_RSVD           		: origin = 0x000002, 				length = 0x0001AE     /* Part of M0, BOOT rom will use this for stack */
   RAMM0M1                  : origin = 0x0001B0,                length = 0x000650
   RAMD0D1                  : origin = 0x00C000,                length = 0x001000
        RAMLS_CLA_DATA      : origin = 0x009800, 				length = 0x001800
   #else
        #if BOOT_FROM_FLASH
            RAMLS_DATA      : origin = 0x00A800, 				length = 0x001800
   #ifdef CPU1
        RAMGS_DATA       	: origin = CPU1_RAMGS_DATA_START, 	length = CPU1_RAMGS_DATA_LENGTH
   #else
		RAMGS_DATA       	: origin = CPU2_RAMGS_DATA_START, 	length = CPU2_RAMGS_DATA_LENGTH
   #endif //CPU1
   RAMGS_IPCBuffCPU1        : origin = 0x00D000,                length = 0x001000
   RAMGS_IPCBuffCPU2        : origin = 0x00E000,                length = 0x001000
   CLA1_MSGRAMLOW           : origin = 0x001480,                length = 0x000080
   CLA1_MSGRAMHIGH          : origin = 0x001500,                length = 0x000080
   CPU1TOCPU2RAM            : origin = 0x03A000,                length = 0x000800
   CPU2TOCPU1RAM            : origin = 0x03B000,                length = 0x000800
   CPUTOCMRAM               : origin = 0x039000,                length = 0x000800
   CMTOCPURAM               : origin = 0x038000,                length = 0x000800
   CANA_MSG_RAM             : origin = 0x049000,                length = 0x000800
   CANB_MSG_RAM             : origin = 0x04B000,                length = 0x000800
   #ifdef EMIF1_CS0_INCLUDED
      EMIF1_CS0_MEMORY    : origin = 0x80000000,                length = 0x10000000
   #endif //EMIF1_CS0_INCLUDED
   #ifdef EMIF1_CS2_INCLUDED
      EMIF1_CS2_MEMORY    : origin = 0x00100000,                length = 0x00200000
   #endif //EMIF1_CS2_INCLUDED
   #ifdef EMIF1_CS3_INCLUDED
      EMIF1_CS3_MEMORY    : origin = 0x00300000, 				length = 0x00080000
   #endif //EMIF1_CS3_INCLUDED
   #ifdef EMIF1_CS4_INCLUDED
      EMIF1_CS4_MEMORY    : origin = 0x00380000, 				length = 0x00060000
   #endif //EMIF1_CS4_INCLUDED
   #ifdef EMIF2_CS0_INCLUDED
      EMIF2_CS0_MEMORY    : origin = 0x90000000, 				length = 0x10000000
   #endif //EMIF2_CS0_INCLUDED
   #ifdef EMIF2_CS2_INCLUDED
      EMIF2_CS2_MEMORY    : origin = 0x00002000, 				length = 0x00001000
   #endif //EMIF2_CS2_INCLUDED
SECTIONS
#if BOOT_FROM_FLASH
   /* Allocate program areas: */
   .cinit               : > FLASHA_N,               PAGE = 0,        ALIGN(4)
   .pinit               : > FLASHA_N,               PAGE = 0,        ALIGN(4)
   .text                : > FLASHA_N,               PAGE = 0,        ALIGN(4)
   codestart            : > BEGIN_FLASH,            PAGE = 0,        ALIGN(4)
   .TI.ramfunc          : {} LOAD = FLASHA_N,
                         RUN = RAMLS_PROG,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_SIZE(_RamfuncsLoadSize),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         RUN_SIZE(_RamfuncsRunSize),
                         RUN_END(_RamfuncsRunEnd),
                         PAGE = 0, ALIGN(4)
   ramfuncs          	: LOAD = FLASHA_N,
                         RUN = RAMLS_PROG,
                         LOAD_START(_MW_RamfuncsLoadStart),
                         LOAD_SIZE(_MW_RamfuncsLoadSize),
                         LOAD_END(_MW_RamfuncsLoadEnd),
                         RUN_START(_MW_RamfuncsRunStart),
                         RUN_SIZE(_MW_RamfuncsRunSize),
                         RUN_END(__MW_RamfuncsRunEnd),
                         PAGE = 0, ALIGN(4)
   /* Initalized sections go in Flash */
   .econst              : > FLASHA_N,                 PAGE = 0,      ALIGN(4)
   .switch              : > FLASHA_N,                 PAGE = 0,      ALIGN(4)
   /* Allocate IQmath areas: */
   IQmath			: > FLASHA_N,                     PAGE = 0,      ALIGN(4)  /* Math Code */
   IQmathTables		: > FLASHA_N,                     PAGE = 0,      ALIGN(4)
       /* CLA specific sections */
       Cla1Prog         : LOAD = FLASHA_N,
                          RUN = RAMLS_CLA_PROG,
                          LOAD_START(_Cla1funcsLoadStart),
                          LOAD_END(_Cla1funcsLoadEnd),
                          RUN_START(_Cla1funcsRunStart),
                          LOAD_SIZE(_Cla1funcsLoadSize),
                          PAGE = 0, ALIGN(4)
       .ebss            : > RAMGS_DATA,               PAGE = 1
   #else
       .ebss            : >> RAMGS_DATA | RAMLS_DATA, PAGE = 1
#else
   codestart        	: > BEGIN,                    PAGE = 0
   .TI.ramfunc          : > RAMLS_PROG,               PAGE = 0
   ramfuncs         	: > RAMLS_PROG,               PAGE = 0
   .cinit           	: > RAMLS_PROG,               PAGE = 0
   .pinit           	: > RAMLS_PROG,               PAGE = 0
   .switch          	: > RAMLS_PROG,               PAGE = 0
   .econst          	: > RAMLS_PROG,               PAGE = 0
   /* Allocate IQ math areas: */
   IQmath				: > RAMLS_PROG,               PAGE = 0	/* Math Code */
   IQmathTables			: > RAMLS_PROG,               PAGE = 0
       Cla1Prog         : > RAMLS_CLA_PROG,           PAGE = 0
   .text                : >> RAMLS_PROG | RAMGS_PROG, PAGE = 0
//   .stack               : > RAMM0M1,                  PAGE = 1
   .stack               : > RAMGS_DATA,                  PAGE = 1
   .reset               : > RESET,                    PAGE = 0,      TYPE = DSECT /* not used, */
   .esysmem             : > RAMD0D1,                  PAGE = 1
   .cio                 : > RAMLS_PROG,               PAGE = 0
   MSGRAM_CPU1_TO_CPU2  : > CPU1TOCPU2RAM,            PAGE = 1
   MSGRAM_CPU2_TO_CPU1  : > CPU2TOCPU1RAM,            PAGE = 1
   MSGRAM_CPU_TO_CM     : > CPUTOCMRAM,               PAGE = 1
   MSGRAM_CM_TO_CPU     : > CMTOCPURAM,               PAGE = 1
   #if defined(EMIF1_CS0_INCLUDED) && defined(EMIF2_CS0_INCLUDED)
      .farbss          : > EMIF1_CS0_MEMORY | EMIF2_CS0_MEMORY,      PAGE = 1
      .farconst        : > EMIF1_CS0_MEMORY | EMIF2_CS0_MEMORY,      PAGE = 1
   #elif !defined(EMIF1_CS0_INCLUDED) && defined(EMIF2_CS0_INCLUDED)
      .farbss          : > EMIF2_CS0_MEMORY,          PAGE = 1
      .farconst        : > EMIF2_CS0_MEMORY,          PAGE = 1
   #elif defined(EMIF1_CS0_INCLUDED) && !defined(EMIF2_CS0_INCLUDED)
      .farbss          : > EMIF1_CS0_MEMORY,          PAGE = 1
      .farconst        : > EMIF1_CS0_MEMORY,          PAGE = 1
   #else
      //No EMIF memory sections
   #endif //defined(EMIF1_CS0_INCLUDED) && defined(EMIF2_CS0_INCLUDED)
      Em1Cs0           : > EMIF1_CS0_MEMORY,          PAGE = 1
       Em2Cs0          : > EMIF2_CS0_MEMORY,          PAGE = 1
       Em1Cs2          : > EMIF1_CS2_MEMORY,          PAGE = 1
       Em1Cs3          : > EMIF1_CS3_MEMORY,          PAGE = 1
       Em1Cs4          : > EMIF1_CS4_MEMORY,          PAGE = 1
   #ifdef MW_EMIF2_CS2_INCLUDED
       Em2Cs2          : > EMIF2_CS2_MEMORY,          PAGE = 1
   #endif //MW_EMIF2_CS2_INCLUDED
       /* CLA C compiler sections */
       // Must be allocated to memory the CLA has write access to
       Cla1DataRam0		: > RAMLS_CLA_DATA,           PAGE = 1
       Cla1ToCpuMsgRAM  : > CLA1_MSGRAMLOW,           PAGE = 1
       CpuToCla1MsgRAM  : > CLA1_MSGRAMHIGH,          PAGE = 1
       CLAscratch       :
							 *.obj(CLAscratch)
							 . += CLA_SCRATCHPAD_SIZE;
							 *.obj(CLAscratch_end)
						 } >  RAMLS_CLA_DATA,         PAGE = 1
       .scratchpad      : > RAMLS_CLA_DATA,           PAGE = 1
       .bss_cla		    : > RAMLS_CLA_DATA,           PAGE = 1
       .const_cla	    :  LOAD = FLASHA_N,
                           RUN = RAMLS_CLA_DATA,
                           RUN_START(_Cla1ConstRunStart),
                           LOAD_START(_Cla1ConstLoadStart),
                           LOAD_SIZE(_Cla1ConstLoadSize),
                           PAGE = 1
   #if defined(CPU1)
       /* The following section definitions are required when using the IPC API Drivers */
            GROUP : > CPU1TOCPU2RAM,                      PAGE = 1
                PUTBUFFER
                PUTWRITEIDX
                GETREADIDX
                WRITEFLAG1CPU1
                WRITEFLAG2CPU1
                READFLAG1CPU1
                READFLAG2CPU1
            GROUP : > CPU2TOCPU1RAM,                      PAGE = 1
                GETBUFFER :     TYPE = DSECT
                GETWRITEIDX :   TYPE = DSECT
                PUTREADIDX :    TYPE = DSECT
                WRITEFLAG1CPU2 : TYPE = DSECT
                WRITEFLAG2CPU2 : TYPE = DSECT
                READFLAG1CPU2  : TYPE = DSECT
                READFLAG2CPU2  : TYPE = DSECT
   #else
                PUTBUFFER
                PUTWRITEIDX
                GETREADIDX
                WRITEFLAG1CPU2
                WRITEFLAG2CPU2
                READFLAG1CPU2
                READFLAG2CPU2
                WRITEFLAG1CPU1 : TYPE = DSECT
                WRITEFLAG2CPU1 : TYPE = DSECT
                READFLAG1CPU1  : TYPE = DSECT
                READFLAG2CPU1  : TYPE = DSECT
   #endif //CPU1
    GROUP : > CPUTOCMRAM,                         PAGE = 1
        PUTBUFFERCPUX
        PUTWRITEIDXCPUX
        GETREADIDXCPUX
        WRITEFLAG1CPUX
        WRITEFLAG2CPUX
        READFLAG1CPUX
        READFLAG2CPUX
        VECTORDATA
    GROUP : > CMTOCPURAM,                         PAGE = 1
        GETBUFFERCM :     TYPE = DSECT
        GETWRITEIDXCM :   TYPE = DSECT
        PUTREADIDXCM :    TYPE = DSECT
        WRITEFLAG1CM : TYPE = DSECT
        WRITEFLAG2CM : TYPE = DSECT
        READFLAG1CM  : TYPE = DSECT
        READFLAG2CM  : TYPE = DSECT
        VECTORDATA   : TYPE = DSECT
	GROUP : > RAMGS_IPCBuffCPU1,                    PAGE = 1
		CPU1TOCPU2GSRAM
	GROUP : > RAMGS_IPCBuffCPU2,                     PAGE = 1
		CPU2TOCPU1GSRAM
// End of file.
Please help me fix this error. I am guessing these are the required files if anymore details are needed please let me know I ll be responding as soon as possible.
Thank you
  • Hi Laxmi,
    Please take a look at the error message. It is referring to a app note which guides through the steps needed to migrate your project from COFF format to EABI format. Looks like in your linker command file, there are section sections defined for COFF format.
    You can take a look at linker command file in C2000Ware SDK, and then compare the sections.
    C:/ti/c2000/C2000Ware_4_01_00_00/device_support/f2838x/common/cmd/2838x_RAM_combined_lnk_cpu1_far.cmd
    Thanks & Regards,
    Santosh
  • Hello Santosh,
    I am not able to open the .cmd file that you have sent it just comes like  a flash in the command window and disappears .
    Thank you,
    T.Akshaya
  • Laxmi,
    You will need to open in a text editor - notepad or other editor, and then review the linker command file.
    Did you review the migration guide?
    Here is another document you can review to get understanding how linker command works.
    https://software-dl.ti.com/ccs/esd/documents/sdto_cgt_Linker-Command-File-Primer.html
    Thanks & Regards,
    Santosh
  • Hello Santosh,
    Hoping that you are able to see screenshot clearly so you were helping me to resolve the warnings thanks for the help.
    So what my manager told me was warnings is not an issue but I have to first fix the errors .Could you help me with resolving the errors.
    And the .cmd file that you were referring to open in notepad I am having an issue with this it does not give me open with opting when I right cluck on the .cmd file instead it runs in the cmd window like a flash and closes as I don't have the " open with " but "open" to look into .cmd file.
    Thank you,
    Akshaya
  • Akshaya,
    Did you go through the link I sent earlier? The document explain all the Linker Command questions.
    Launch Notepad on your laptop.
    Open the file:
    C:/ti/c2000/C2000Ware_4_01_00_00/device_support/f2838x/common/cmd/2838x_FLASH_lnk_cpu1.cmd
    Then take a look at:
    #if defined(__TI_EABI__)
       .init_array      : > FLASH1, ALIGN(8)
       .bss             : > RAMLS5
       .bss:output      : > RAMLS3
       .bss:cio         : > RAMLS5
       .data            : > RAMLS5
       .sysmem          : > RAMLS5
       .const           : > FLASH5, ALIGN(8)
    #else
       .pinit           : > FLASH1, ALIGN(8)
       .ebss            : > RAMLS5
       .esysmem         : > RAMLS5
       .cio             : > RAMLS5
       .econst          : >> FLASH4 | FLASH5, ALIGN(8)
    #endif
           .TI.ramfunc : {} LOAD = FLASH3,
                            RUN = RAMLS0 | RAMLS1 | RAMLS2 |RAMLS3,
                            LOAD_START(RamfuncsLoadStart),
                            LOAD_SIZE(RamfuncsLoadSize),
                            LOAD_END(RamfuncsLoadEnd),
                            RUN_START(RamfuncsRunStart),
                            RUN_SIZE(RamfuncsRunSize),
                            RUN_END(RamfuncsRunEnd),
                            ALIGN(8)
       #else
                            ALIGN(8)
       #endif
    In your linker command file, you will need to make changes accordingly.
    Hope this helps.
    Thanks & Regards,
    Santosh
