Part Number: LAUNCHXL-F280049C
hello!
I run an gui composer v3 example to use graph display ADC data, I use launchxl-f280049c,.when I run the example in dev.ti.com/gc, it can display data graph, but I export to stand-alone ,it can't display .
hello!
Thanks. It doesn't look like you defined any lines for the plot and bound them.
Have you seen the help:
https://dev.ti.com/gc/v3/components/index.html#gc-widget-plot
Can you point me to this example?
ki
Thank you Ki , I have seen the index.html#gc-widget-plot help , it's demo use gc-model-streaming , I think it use USB-UART communication . I use xds110 , the way of bind data look like
when program is running in cloud it can plot data line. the DSP pro'gram is TI demo 'dual_axis_servo_drive_fcl_qep_f28004x' .
it's demo usegc-model-streaming, I think it use USB-UART communication . I use xds110 , the way of bind data
After discussion with the GUI Composer engeineers, it looks like binding to point is not officially supported and that streaming mode needs to be used. The fact that you got it to work in GC online was actually surprising and likely just a coincidence. They are trying to confirm this but so far it appears to be the case.
ki
Apparently this is the case. The documentation is misleading in exposing the binding option and will need to be corrected. My apologies for this.
ki
