Part Number: LAUNCHXL-F28069M
Other Parts Discussed in Thread: TMS320F28062F,
I'm using C2000 series microcontroller TMS320F28062F. How can I program TMS320F28062F microcontroller using launchpad LAUNCHXL-F28069M ?
Yusuf
Yusuf
Yusuf,
I assume you want to use the XDS100v2 connection on the LP to connect to your F28062. I think the simplest soln would be to remove the isolators U5 and U7; below these ICs there are some bigger pads for soldiering wires for the JTAG signals. Once you run these(and ground) to your board the emulator should connect.
The only thing to consider is that you would need to re-attach the U5/U7 if you still want to use the F28069 on the LP.
Matthew
