Part Number: DRV8301-69M-KIT
Hi Yanming:
Since the problem of offline operation was solved last time, the program debugging has been very smooth.
Until recently, when I wanted to test the program encryption, I found that once the project was encrypted through the tools - on chip flash provided by CCS and then powered on, the program could not run offline.
However, LD2 will still flash normally, but the motor will not rotate.
What part of the program should I modify?
Keng
