Part Number: C2000-GANG
I'll inform Elpro to take a look at this post. They will need to evaluate as well. Have you tried a different USB port and/or different PC host? From the flicker it seems the Elpro GANG is not getting enough current, but that is just a guess.
Matthew
Please also try the following to eliminate the power supply as the issue.
1)Don't use the external power supply, but connect the USB directly to your PC and see if that resolves the issue
2)Try a different DC 9V power supply to see if that corrects things.
Matthew
