Part Number: TMS320F280021
HELP ME WITH MEMMORY ALLOCATION OF TMS320F280021
Can you provide more details ? It's difficult to answer your query with the current details that you have provided.
You can refer the data sheet to get to know the memory map.
Best Regards
Siddharth
Can you describe the error that you are seeing while flashing the code?
Best Regards
Siddharth
You can refer the examples provided in C2000Ware for F28002x device , these are located in the folder C:\ti\c2000\C2000Ware_4_01_00_00\driverlib\f28002x\examples\gpio
Best Regards
Siddharth
Can you tell the steps that you carried out after compiling the code? Were you able to load the code to the deivce?
Best Regards
Siddharth
// FILE: device.c
// TITLE: Device setup for examples.
// $Copyright:
// Copyright (C) 2022 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
// Redistributions of source code must retain the above copyright
// notice, this list of conditions and the following disclaimer.
// Redistributions in binary form must reproduce the above copyright
// notice, this list of conditions and the following disclaimer in the
// documentation and/or other materials provided with the
// distribution.
// Neither the name of Texas Instruments Incorporated nor the names of
// its contributors may be used to endorse or promote products derived
// from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "device.h"
#include "driverlib.h"
#ifdef __cplusplus
using std::memcpy;
#endif
// Function to initialize the device. Primarily initializes system control to a
// known state by disabling the watchdog, setting up the SYSCLKOUT frequency,
// and enabling the clocks to the peripherals.
// Note : In case XTAL is used as the PLL source, it is recommended to invoke
// the Device_verifyXTAL() before configuring PLL
void Device_init(void)
// Disable the watchdog
SysCtl_disableWatchdog();
//#ifdef _FLASH
// Copy time critical code and flash setup code to RAM. This includes the
// following functions: InitFlash();
//InitFlash();
// The RamfuncsLoadStart, RamfuncsLoadSize, and RamfuncsRunStart symbols
// are created by the linker. Refer to the device .cmd file.
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
// Call Flash Initialization to setup flash waitstates. This function must
// reside in RAM.
Flash_initModule(FLASH0CTRL_BASE, FLASH0ECC_BASE, DEVICE_FLASH_WAITSTATES);
//#endif
// Set up PLL control and clock dividers
SysCtl_setClock(DEVICE_SETCLOCK_CFG);
// Make sure the LSPCLK divider is set to the default (divide by 4)
SysCtl_setLowSpeedClock(SYSCTL_LSPCLK_PRESCALE_4);
// These asserts will check that the #defines for the clock rates in
// device.h match the actual rates that have been configured. If they do
// not match, check that the calculations of DEVICE_SYSCLK_FREQ and
// DEVICE_LSPCLK_FREQ are accurate. Some examples will not perform as
// expected if these are not correct.
ASSERT(SysCtl_getClock(DEVICE_OSCSRC_FREQ) == DEVICE_SYSCLK_FREQ);
ASSERT(SysCtl_getLowSpeedClock(DEVICE_OSCSRC_FREQ) == DEVICE_LSPCLK_FREQ);
//#ifndef _FLASH
// Call Device_cal function when run using debugger
// This function is called as part of the Boot code. The function is called
// in the Device_init function since during debug time resets, the boot code
// will not be executed and the gel script will reinitialize all the
// registers and the calibrated values will be lost.
// Sysctl_deviceCal is a wrapper function for Device_Cal
//SysCtl_deviceCal();
//#endif
// Turn on all peripherals
Device_enableAllPeripherals();
// Lock VREGCTL Register
// The register VREGCTL is not supported in this device. It is locked to
// prevent any writes to this register
ASysCtl_lockVREG();
// Function to turn on all peripherals, enabling reads and writes to the
// peripherals' registers.
// Note that to reduce power, unused peripherals should be disabled.
void Device_enableAllPeripherals(void)
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DMA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TIMER0);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TIMER1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TIMER2);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CPUBGCRC);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_HRCAL);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_TBCLKSYNC);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ERAD);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM2);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM3);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM4);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM5);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM6);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EPWM7);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP2);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ECAP3);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EQEP1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_EQEP2);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SCIA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SPIA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_SPIB);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_I2CA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_I2CB);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CANA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ADCA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_ADCC);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS2);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS3);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CMPSS4);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_FSITXA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_FSIRXA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_LINA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_LINB);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_PMBUSA);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DCC0);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_DCC1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLB1);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_CLB2);
SysCtl_enablePeripheral(SYSCTL_PERIPH_CLK_HICA);
// Function to disable pin locks and enable pullups on GPIOs.
void Device_initGPIO(void)
// Disable pin locks.
GPIO_unlockPortConfig(GPIO_PORT_A, 0xFFFFFFFF);
GPIO_unlockPortConfig(GPIO_PORT_B, 0xFFFFFFFF);
GPIO_unlockPortConfig(GPIO_PORT_H, 0xFFFFFFFF);
// Function to verify the XTAL frequency
// freq is the XTAL frequency in MHz
// The function return true if the the actual XTAL frequency matches with the
// input value
// Note that this function assumes that the PLL is not already configured and
// hence uses SysClk freq = 10MHz for DCC calculation
bool Device_verifyXTAL(float freq)
// Use DCC to verify the XTAL frequency using INTOSC2 as reference clock
// Turn on XTAL and wait for it to power up using X1CNT
SysCtl_turnOnOsc(SYSCTL_OSCSRC_XTAL);
SysCtl_clearExternalOscCounterValue();
while(SysCtl_getExternalOscCounterValue() != SYSCTL_X1CNT_X1CNT_M);
// Enable DCC0 clock
// Insert atleast 5 cycles delay after enabling the peripheral clock
asm(" RPT #5 || NOP");
// Configures XTAL as CLKSRC0 and INTOSC2 as CLKSRC1
// Fclk0 = XTAL frequency (input parameter)
// Fclk1 = INTOSC2 frequency = 10MHz
// Configuring DCC error tolerance of +/-1%
// INTOSC2 can have a variance in frequency of +/-10%
// Assuming PLL is not already configured, SysClk freq = 10MHz
// Note : Update the tolerance and INTOSC2 frequency variance as necessary.
return (DCC_verifyClockFrequency(DCC0_BASE,
DCC_COUNT1SRC_INTOSC2, 10.0F,
DCC_COUNT0SRC_XTAL, freq,
1.0F, 10.0F, 10.0F));
// Error handling function to be called when an ASSERT is violated
void __error__(const char *filename, uint32_t line)
// An ASSERT condition was evaluated as false. You can use the filename and
// line parameters to determine what went wrong.
ESTOP0;
Looks like you are using an incorrect linker command file. Are you trying to run the code from RAM or Flash?
If RAM, then use the "28002x_generic_ram_lnk" linker command file.
If Flash, then use the "28002x_generic_flash_lnk" linker command file.
Best Regards
Siddharth
