Part Number: LAUNCHXL-F280039C
Dear Sir
My customer has mature product base on F280049 and already MP, now they just transfer from F280049 to F280039, and found a strange issue that F280039 will hang up after running for a while. While device hang up, the PWM will stop running and continue high or low, even after device generate reset signal, the PWM still keep continue high or low.
Below is the waveform for reference. The Blue, Green and Yellow color is PWM signal, and Red color is Reset signal. We can see the Green color PWM signal change to continue high suddenly, and keep high even after reset signal.
I check customer firmware setting that PWM FREE-SOFT bit set to 11 (free run) and TZ set to force low for both PWMA&B. So I think the PWM should be always continue running or all turn off. I cannot understand why PWM will continue high even after device reset.
May I get expert advice what any possible condition maybe cause device PWM continue high?
